[PATCH] doc: Remove the obsolete README.AMCC-eval-boards-cleanup file
The related boards have been removed four years ago already, in commit 98f705c9cefd ("powerpc: remove 4xx support"), so this README file is not required anymore.
Signed-off-by: Thomas Huth thuth@redhat.com --- doc/README.AMCC-eval-boards-cleanup | 31 ----------------------------- 1 file changed, 31 deletions(-) delete mode 100644 doc/README.AMCC-eval-boards-cleanup
diff --git a/doc/README.AMCC-eval-boards-cleanup b/doc/README.AMCC-eval-boards-cleanup deleted file mode 100644 index 901bd875c6..0000000000 --- a/doc/README.AMCC-eval-boards-cleanup +++ /dev/null @@ -1,31 +0,0 @@ ---------------------------------------------------------------------- -Cleanup of AMCC eval boards (Walnut/Sycamore, Bubinga, Ebony, Ocotea) ---------------------------------------------------------------------- - -Changes to all AMCC eval boards: --------------------------------- - -o Changed u-boot image size to 256 kBytes instead of 512 kBytes on most - boards. - -o Use 115200 baud as default console baudrate. - -o Added config option to use redundant environment in flash. This is also - the default setting. Option for environment in nvram is still available - for backward compatibility. - -o Merged board specific flash drivers to common flash driver: - board/amcc/common/flash.c - - -Sycamore/Walnut (one port supporting both eval boards): -------------------------------------------------------- - -o Cleanup to allow easier "cloning" for different (custom) boards: - - o Moved EBC configuration from board specific asm-file "init.S" - using defines in board configuration file. No board specific - asm file needed anymore. - - -August 01 2005, Stefan Roese sr@denx.de
Thanks, Stefan
- boards.
Viele Grüße, Stefan
Stefan Roese
Thomas Huth
