[U-Boot] [PATCH 1/3] ARM: dts: sun8i: Sync r40 dtsi from Linux
Sync sun8i-r40.dtsi changes from Linux with
Merge: a406778618d0 088345fc3553 Author: Stephen Rothwell sfr@canb.auug.org.au Date: Tue Apr 24 14:15:02 2018 +1000
Merge branch 'akpm/master'
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/dts/sun8i-r40.dtsi | 43 +++++++ include/dt-bindings/clock/sun8i-r40-ccu.h | 187 ++++++++++++++++++++++++++++++ include/dt-bindings/reset/sun8i-r40-ccu.h | 130 +++++++++++++++++++++ 3 files changed, 360 insertions(+) create mode 100644 include/dt-bindings/clock/sun8i-r40-ccu.h create mode 100644 include/dt-bindings/reset/sun8i-r40-ccu.h
diff --git a/arch/arm/dts/sun8i-r40.dtsi b/arch/arm/dts/sun8i-r40.dtsi index 48ec2e855a..0aa76a2f10 100644 --- a/arch/arm/dts/sun8i-r40.dtsi +++ b/arch/arm/dts/sun8i-r40.dtsi @@ -43,6 +43,8 @@ */
#include <dt-bindings/interrupt-controller/arm-gic.h> +#include <dt-bindings/clock/sun8i-r40-ccu.h> +#include <dt-bindings/reset/sun8i-r40-ccu.h>
/ { #address-cells = <1>; @@ -114,6 +116,39 @@ #size-cells = <1>; ranges;
+ nmi_intc: interrupt-controller@1c00030 { + compatible = "allwinner,sun7i-a20-sc-nmi"; + interrupt-controller; + #interrupt-cells = <2>; + reg = <0x01c00030 0x0c>; + interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>; + }; + + mmc0: mmc@1c0f000 { + compatible = "allwinner,sun8i-r40-mmc", + "allwinner,sun50i-a64-mmc"; + reg = <0x01c0f000 0x1000>; + clocks = <&ccu CLK_BUS_MMC0>, <&ccu CLK_MMC0>; + clock-names = "ahb", "mmc"; + resets = <&ccu RST_BUS_MMC0>; + reset-names = "ahb"; + pinctrl-0 = <&mmc0_pins>; + pinctrl-names = "default"; + interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>; + status = "disabled"; + #address-cells = <1>; + #size-cells = <0>; + }; + + ccu: clock@1c20000 { + compatible = "allwinner,sun8i-r40-ccu"; + reg = <0x01c20000 0x400>; + clocks = <&osc24M>, <&osc32k>; + clock-names = "hosc", "losc"; + #clock-cells = <1>; + #reset-cells = <1>; + }; + pio: pinctrl@1c20800 { compatible = "allwinner,sun8i-r40-pinctrl"; reg = <0x01c20800 0x400>; @@ -132,6 +167,14 @@ bias-pull-up; };
+ mmc0_pins: mmc0-pins { + pins = "PF0", "PF1", "PF2", + "PF3", "PF4", "PF5"; + function = "mmc0"; + drive-strength = <30>; + bias-pull-up; + }; + uart0_pb_pins: uart0_pb_pins { pins = "PB22", "PB23"; function = "uart0"; diff --git a/include/dt-bindings/clock/sun8i-r40-ccu.h b/include/dt-bindings/clock/sun8i-r40-ccu.h new file mode 100644 index 0000000000..4fa5f69fc2 --- /dev/null +++ b/include/dt-bindings/clock/sun8i-r40-ccu.h @@ -0,0 +1,187 @@ +/* + * Copyright (C) 2017 Icenowy Zheng icenowy@aosc.io + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +#ifndef _DT_BINDINGS_CLK_SUN8I_R40_H_ +#define _DT_BINDINGS_CLK_SUN8I_R40_H_ + +#define CLK_CPU 24 + +#define CLK_BUS_MIPI_DSI 29 +#define CLK_BUS_CE 30 +#define CLK_BUS_DMA 31 +#define CLK_BUS_MMC0 32 +#define CLK_BUS_MMC1 33 +#define CLK_BUS_MMC2 34 +#define CLK_BUS_MMC3 35 +#define CLK_BUS_NAND 36 +#define CLK_BUS_DRAM 37 +#define CLK_BUS_EMAC 38 +#define CLK_BUS_TS 39 +#define CLK_BUS_HSTIMER 40 +#define CLK_BUS_SPI0 41 +#define CLK_BUS_SPI1 42 +#define CLK_BUS_SPI2 43 +#define CLK_BUS_SPI3 44 +#define CLK_BUS_SATA 45 +#define CLK_BUS_OTG 46 +#define CLK_BUS_EHCI0 47 +#define CLK_BUS_EHCI1 48 +#define CLK_BUS_EHCI2 49 +#define CLK_BUS_OHCI0 50 +#define CLK_BUS_OHCI1 51 +#define CLK_BUS_OHCI2 52 +#define CLK_BUS_VE 53 +#define CLK_BUS_MP 54 +#define CLK_BUS_DEINTERLACE 55 +#define CLK_BUS_CSI0 56 +#define CLK_BUS_CSI1 57 +#define CLK_BUS_HDMI1 58 +#define CLK_BUS_HDMI0 59 +#define CLK_BUS_DE 60 +#define CLK_BUS_TVE0 61 +#define CLK_BUS_TVE1 62 +#define CLK_BUS_TVE_TOP 63 +#define CLK_BUS_GMAC 64 +#define CLK_BUS_GPU 65 +#define CLK_BUS_TVD0 66 +#define CLK_BUS_TVD1 67 +#define CLK_BUS_TVD2 68 +#define CLK_BUS_TVD3 69 +#define CLK_BUS_TVD_TOP 70 +#define CLK_BUS_TCON_LCD0 71 +#define CLK_BUS_TCON_LCD1 72 +#define CLK_BUS_TCON_TV0 73 +#define CLK_BUS_TCON_TV1 74 +#define CLK_BUS_TCON_TOP 75 +#define CLK_BUS_CODEC 76 +#define CLK_BUS_SPDIF 77 +#define CLK_BUS_AC97 78 +#define CLK_BUS_PIO 79 +#define CLK_BUS_IR0 80 +#define CLK_BUS_IR1 81 +#define CLK_BUS_THS 82 +#define CLK_BUS_KEYPAD 83 +#define CLK_BUS_I2S0 84 +#define CLK_BUS_I2S1 85 +#define CLK_BUS_I2S2 86 +#define CLK_BUS_I2C0 87 +#define CLK_BUS_I2C1 88 +#define CLK_BUS_I2C2 89 +#define CLK_BUS_I2C3 90 +#define CLK_BUS_CAN 91 +#define CLK_BUS_SCR 92 +#define CLK_BUS_PS20 93 +#define CLK_BUS_PS21 94 +#define CLK_BUS_I2C4 95 +#define CLK_BUS_UART0 96 +#define CLK_BUS_UART1 97 +#define CLK_BUS_UART2 98 +#define CLK_BUS_UART3 99 +#define CLK_BUS_UART4 100 +#define CLK_BUS_UART5 101 +#define CLK_BUS_UART6 102 +#define CLK_BUS_UART7 103 +#define CLK_BUS_DBG 104 + +#define CLK_THS 105 +#define CLK_NAND 106 +#define CLK_MMC0 107 +#define CLK_MMC1 108 +#define CLK_MMC2 109 +#define CLK_MMC3 110 +#define CLK_TS 111 +#define CLK_CE 112 +#define CLK_SPI0 113 +#define CLK_SPI1 114 +#define CLK_SPI2 115 +#define CLK_SPI3 116 +#define CLK_I2S0 117 +#define CLK_I2S1 118 +#define CLK_I2S2 119 +#define CLK_AC97 120 +#define CLK_SPDIF 121 +#define CLK_KEYPAD 122 +#define CLK_SATA 123 +#define CLK_USB_PHY0 124 +#define CLK_USB_PHY1 125 +#define CLK_USB_PHY2 126 +#define CLK_USB_OHCI0 127 +#define CLK_USB_OHCI1 128 +#define CLK_USB_OHCI2 129 +#define CLK_IR0 130 +#define CLK_IR1 131 + +#define CLK_DRAM_VE 133 +#define CLK_DRAM_CSI0 134 +#define CLK_DRAM_CSI1 135 +#define CLK_DRAM_TS 136 +#define CLK_DRAM_TVD 137 +#define CLK_DRAM_MP 138 +#define CLK_DRAM_DEINTERLACE 139 +#define CLK_DE 140 +#define CLK_MP 141 +#define CLK_TCON_LCD0 142 +#define CLK_TCON_LCD1 143 +#define CLK_TCON_TV0 144 +#define CLK_TCON_TV1 145 +#define CLK_DEINTERLACE 146 +#define CLK_CSI1_MCLK 147 +#define CLK_CSI_SCLK 148 +#define CLK_CSI0_MCLK 149 +#define CLK_VE 150 +#define CLK_CODEC 151 +#define CLK_AVS 152 +#define CLK_HDMI 153 +#define CLK_HDMI_SLOW 154 + +#define CLK_DSI_DPHY 156 +#define CLK_TVE0 157 +#define CLK_TVE1 158 +#define CLK_TVD0 159 +#define CLK_TVD1 160 +#define CLK_TVD2 161 +#define CLK_TVD3 162 +#define CLK_GPU 163 +#define CLK_OUTA 164 +#define CLK_OUTB 165 + +#endif /* _DT_BINDINGS_CLK_SUN8I_R40_H_ */ diff --git a/include/dt-bindings/reset/sun8i-r40-ccu.h b/include/dt-bindings/reset/sun8i-r40-ccu.h new file mode 100644 index 0000000000..c5ebcf6672 --- /dev/null +++ b/include/dt-bindings/reset/sun8i-r40-ccu.h @@ -0,0 +1,130 @@ +/* + * Copyright (C) 2017 Icenowy Zheng icenowy@aosc.io + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +#ifndef _DT_BINDINGS_RST_SUN8I_R40_H_ +#define _DT_BINDINGS_RST_SUN8I_R40_H_ + +#define RST_USB_PHY0 0 +#define RST_USB_PHY1 1 +#define RST_USB_PHY2 2 + +#define RST_DRAM 3 +#define RST_MBUS 4 + +#define RST_BUS_MIPI_DSI 5 +#define RST_BUS_CE 6 +#define RST_BUS_DMA 7 +#define RST_BUS_MMC0 8 +#define RST_BUS_MMC1 9 +#define RST_BUS_MMC2 10 +#define RST_BUS_MMC3 11 +#define RST_BUS_NAND 12 +#define RST_BUS_DRAM 13 +#define RST_BUS_EMAC 14 +#define RST_BUS_TS 15 +#define RST_BUS_HSTIMER 16 +#define RST_BUS_SPI0 17 +#define RST_BUS_SPI1 18 +#define RST_BUS_SPI2 19 +#define RST_BUS_SPI3 20 +#define RST_BUS_SATA 21 +#define RST_BUS_OTG 22 +#define RST_BUS_EHCI0 23 +#define RST_BUS_EHCI1 24 +#define RST_BUS_EHCI2 25 +#define RST_BUS_OHCI0 26 +#define RST_BUS_OHCI1 27 +#define RST_BUS_OHCI2 28 +#define RST_BUS_VE 29 +#define RST_BUS_MP 30 +#define RST_BUS_DEINTERLACE 31 +#define RST_BUS_CSI0 32 +#define RST_BUS_CSI1 33 +#define RST_BUS_HDMI0 34 +#define RST_BUS_HDMI1 35 +#define RST_BUS_DE 36 +#define RST_BUS_TVE0 37 +#define RST_BUS_TVE1 38 +#define RST_BUS_TVE_TOP 39 +#define RST_BUS_GMAC 40 +#define RST_BUS_GPU 41 +#define RST_BUS_TVD0 42 +#define RST_BUS_TVD1 43 +#define RST_BUS_TVD2 44 +#define RST_BUS_TVD3 45 +#define RST_BUS_TVD_TOP 46 +#define RST_BUS_TCON_LCD0 47 +#define RST_BUS_TCON_LCD1 48 +#define RST_BUS_TCON_TV0 49 +#define RST_BUS_TCON_TV1 50 +#define RST_BUS_TCON_TOP 51 +#define RST_BUS_DBG 52 +#define RST_BUS_LVDS 53 +#define RST_BUS_CODEC 54 +#define RST_BUS_SPDIF 55 +#define RST_BUS_AC97 56 +#define RST_BUS_IR0 57 +#define RST_BUS_IR1 58 +#define RST_BUS_THS 59 +#define RST_BUS_KEYPAD 60 +#define RST_BUS_I2S0 61 +#define RST_BUS_I2S1 62 +#define RST_BUS_I2S2 63 +#define RST_BUS_I2C0 64 +#define RST_BUS_I2C1 65 +#define RST_BUS_I2C2 66 +#define RST_BUS_I2C3 67 +#define RST_BUS_CAN 68 +#define RST_BUS_SCR 69 +#define RST_BUS_PS20 70 +#define RST_BUS_PS21 71 +#define RST_BUS_I2C4 72 +#define RST_BUS_UART0 73 +#define RST_BUS_UART1 74 +#define RST_BUS_UART2 75 +#define RST_BUS_UART3 76 +#define RST_BUS_UART4 77 +#define RST_BUS_UART5 78 +#define RST_BUS_UART6 79 +#define RST_BUS_UART7 80 + +#endif /* _DT_BINDINGS_RST_SUN8I_R40_H_ */
Allwinner V40 (sun8i) SoC features a Quad-Core Cortex-A7 ARM CPU, and a Mali400 MP2 GPU from ARM. It is the automotive version of R40.
This patch add support for V40 by reusing R40 configurations.
MACH_SUN8I_R40_V40 is the common config option for both.
Also fixed checkpatch warnings while making these changes.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/cpu/armv7/sunxi/psci.c | 10 ++++---- arch/arm/include/asm/arch-sunxi/clock_sun6i.h | 4 +-- arch/arm/include/asm/arch-sunxi/cpu_sun4i.h | 6 ++--- arch/arm/include/asm/arch-sunxi/timer.h | 2 +- arch/arm/include/asm/arch-sunxi/watchdog.h | 6 ++--- arch/arm/mach-sunxi/Kconfig | 36 ++++++++++++++++----------- arch/arm/mach-sunxi/board.c | 11 ++++---- arch/arm/mach-sunxi/clock_sun6i.c | 9 +++---- arch/arm/mach-sunxi/cpu_info.c | 2 ++ arch/arm/mach-sunxi/dram_sunxi_dw.c | 6 ++--- arch/arm/mach-sunxi/pmic_bus.c | 8 +++--- board/sunxi/board.c | 26 ++++++++----------- drivers/power/Kconfig | 18 +++++++------- 13 files changed, 74 insertions(+), 70 deletions(-)
diff --git a/arch/arm/cpu/armv7/sunxi/psci.c b/arch/arm/cpu/armv7/sunxi/psci.c index 18da9cb864..39195b6313 100644 --- a/arch/arm/cpu/armv7/sunxi/psci.c +++ b/arch/arm/cpu/armv7/sunxi/psci.c @@ -80,7 +80,7 @@ static void __secure clamp_release(u32 __maybe_unused *clamp) { #if defined(CONFIG_MACH_SUN6I) || defined(CONFIG_MACH_SUN7I) || \ defined(CONFIG_MACH_SUN8I_H3) || \ - defined(CONFIG_MACH_SUN8I_R40) + defined(CONFIG_MACH_SUN8I_R40_V40) u32 tmp = 0x1ff; do { tmp >>= 1; @@ -95,7 +95,7 @@ static void __secure clamp_set(u32 __maybe_unused *clamp) { #if defined(CONFIG_MACH_SUN6I) || defined(CONFIG_MACH_SUN7I) || \ defined(CONFIG_MACH_SUN8I_H3) || \ - defined(CONFIG_MACH_SUN8I_R40) + defined(CONFIG_MACH_SUN8I_R40_V40) writel(0xff, clamp); #endif } @@ -118,7 +118,7 @@ static void __secure sunxi_power_switch(u32 *clamp, u32 *pwroff, bool on, } }
-#ifdef CONFIG_MACH_SUN8I_R40 +#ifdef CONFIG_MACH_SUN8I_R40_V40 /* secondary core entry address is programmed differently on R40 */ static void __secure sunxi_set_entry_address(void *entry) { @@ -145,7 +145,7 @@ static void __secure sunxi_cpu_set_power(int __always_unused cpu, bool on) sunxi_power_switch(&cpucfg->cpu1_pwr_clamp, &cpucfg->cpu1_pwroff, on, 0); } -#elif defined CONFIG_MACH_SUN8I_R40 +#elif defined CONFIG_MACH_SUN8I_R40_V40 static void __secure sunxi_cpu_set_power(int cpu, bool on) { struct sunxi_cpucfg_reg *cpucfg = @@ -155,7 +155,7 @@ static void __secure sunxi_cpu_set_power(int cpu, bool on) (void *)cpucfg + SUN8I_R40_PWROFF, on, 0); } -#else /* ! CONFIG_MACH_SUN7I && ! CONFIG_MACH_SUN8I_R40 */ +#else /* ! CONFIG_MACH_SUN7I && ! CONFIG_MACH_SUN8I_R40_V40 */ static void __secure sunxi_cpu_set_power(int cpu, bool on) { struct sunxi_prcm_reg *prcm = diff --git a/arch/arm/include/asm/arch-sunxi/clock_sun6i.h b/arch/arm/include/asm/arch-sunxi/clock_sun6i.h index d35aa479f7..c4d8c58716 100644 --- a/arch/arm/include/asm/arch-sunxi/clock_sun6i.h +++ b/arch/arm/include/asm/arch-sunxi/clock_sun6i.h @@ -285,7 +285,7 @@ struct sunxi_ccm_reg { #define AHB_GATE_OFFSET_USB_EHCI1 27 #define AHB_GATE_OFFSET_USB_EHCI0 26 #endif -#ifndef CONFIG_MACH_SUN8I_R40 +#ifndef CONFIG_MACH_SUN8I_R40_V40 #define AHB_GATE_OFFSET_USB0 24 #else #define AHB_GATE_OFFSET_USB0 25 @@ -439,7 +439,7 @@ struct sunxi_ccm_reg { #define CCM_PLL11_PATTERN 0xf5860000
/* ahb_reset0 offsets */ -#ifdef CONFIG_MACH_SUN8I_R40 +#ifdef CONFIG_MACH_SUN8I_R40_V40 #define AHB_RESET_OFFSET_SATA 24 #endif #define AHB_RESET_OFFSET_GMAC 17 diff --git a/arch/arm/include/asm/arch-sunxi/cpu_sun4i.h b/arch/arm/include/asm/arch-sunxi/cpu_sun4i.h index 2419062d45..89300064e1 100644 --- a/arch/arm/include/asm/arch-sunxi/cpu_sun4i.h +++ b/arch/arm/include/asm/arch-sunxi/cpu_sun4i.h @@ -114,7 +114,7 @@ defined(CONFIG_MACH_SUN50I) #define SUNXI_TP_BASE 0x01c25000 #define SUNXI_PMU_BASE 0x01c25400
-#if defined CONFIG_MACH_SUN7I || defined CONFIG_MACH_SUN8I_R40 +#if defined CONFIG_MACH_SUN7I || defined CONFIG_MACH_SUN8I_R40_V40 #define SUNXI_CPUCFG_BASE 0x01c25c00 #endif
@@ -186,8 +186,8 @@ defined(CONFIG_MACH_SUN50I) #define SUNXI_PRCM_BASE 0x01f01400
#if defined CONFIG_SUNXI_GEN_SUN6I && \ - !defined CONFIG_MACH_SUN8I_A83T && \ - !defined CONFIG_MACH_SUN8I_R40 + !defined CONFIG_MACH_SUN8I_A83T && \ + !defined CONFIG_MACH_SUN8I_R40_V40 #define SUNXI_CPUCFG_BASE 0x01f01c00 #endif
diff --git a/arch/arm/include/asm/arch-sunxi/timer.h b/arch/arm/include/asm/arch-sunxi/timer.h index ccdf942534..de1a5c1e83 100644 --- a/arch/arm/include/asm/arch-sunxi/timer.h +++ b/arch/arm/include/asm/arch-sunxi/timer.h @@ -67,7 +67,7 @@ struct sunxi_timer_reg { struct sunxi_timer timer[6]; /* We have 6 timers */ u8 res2[16]; struct sunxi_avs avs; -#if defined(CONFIG_SUNXI_GEN_SUN4I) || defined(CONFIG_MACH_SUN8I_R40) +#if defined(CONFIG_SUNXI_GEN_SUN4I) || defined(CONFIG_MACH_SUN8I_R40_V40) struct sunxi_wdog wdog; /* 0x90 */ /* XXX the following is not accurate for sun5i/sun7i */ struct sunxi_64cnt cnt64; /* 0xa0 */ diff --git a/arch/arm/include/asm/arch-sunxi/watchdog.h b/arch/arm/include/asm/arch-sunxi/watchdog.h index ce6d664856..a1041c00c8 100644 --- a/arch/arm/include/asm/arch-sunxi/watchdog.h +++ b/arch/arm/include/asm/arch-sunxi/watchdog.h @@ -14,9 +14,9 @@ #define WDT_CTRL_KEY (0x0a57 << 1)
#if defined(CONFIG_MACH_SUN4I) || \ - defined(CONFIG_MACH_SUN5I) || \ - defined(CONFIG_MACH_SUN7I) || \ - defined(CONFIG_MACH_SUN8I_R40) + defined(CONFIG_MACH_SUN5I) || \ + defined(CONFIG_MACH_SUN7I) || \ + defined(CONFIG_MACH_SUN8I_R40_V40)
#define WDT_MODE_EN (0x1 << 0) #define WDT_MODE_RESET_EN (0x1 << 1) diff --git a/arch/arm/mach-sunxi/Kconfig b/arch/arm/mach-sunxi/Kconfig index b868f0e350..c50642e1b4 100644 --- a/arch/arm/mach-sunxi/Kconfig +++ b/arch/arm/mach-sunxi/Kconfig @@ -121,6 +121,17 @@ config SUNXI_DRAM_DW_32BIT 32-bit memory buswidth. endif
+config MACH_SUN8I_R40_V40 + bool + select CPU_V7 + select CPU_V7_HAS_NONSEC + select CPU_V7_HAS_VIRT + select ARCH_SUPPORT_PSCI + select SUNXI_GEN_SUN6I + select SUPPORT_SPL + select SUNXI_DRAM_DW + select SUNXI_DRAM_DW_32BIT + config MACH_SUNXI_H3_H5 bool select DM_I2C @@ -218,14 +229,7 @@ config MACH_SUN8I_H3
config MACH_SUN8I_R40 bool "sun8i (Allwinner R40)" - select CPU_V7 - select CPU_V7_HAS_NONSEC - select CPU_V7_HAS_VIRT - select ARCH_SUPPORT_PSCI - select SUNXI_GEN_SUN6I - select SUPPORT_SPL - select SUNXI_DRAM_DW - select SUNXI_DRAM_DW_32BIT + select MACH_SUN8I_R40_V40
config MACH_SUN8I_V3S bool "sun8i (Allwinner V3s)" @@ -239,6 +243,10 @@ config MACH_SUN8I_V3S select SUPPORT_SPL select ARMV7_BOOT_SEC_DEFAULT if OLD_SUNXI_KERNEL_COMPAT
+config MACH_SUN8I_V40 + bool "sun8i (Allwinner V40)" + select MACH_SUN8I_R40_V40 + config MACH_SUN9I bool "sun9i (Allwinner A80)" select CPU_V7 @@ -281,7 +289,7 @@ config MACH_SUN8I default y if MACH_SUN8I_A33 default y if MACH_SUN8I_A83T default y if MACH_SUNXI_H3_H5 - default y if MACH_SUN8I_R40 + default y if MACH_SUN8I_R40_V40 default y if MACH_SUN8I_V3S
config RESERVE_ALLWINNER_BOOT0_HEADER @@ -358,7 +366,7 @@ config DRAM_TYPE config DRAM_CLK int "sunxi dram clock speed" default 792 if MACH_SUN9I - default 648 if MACH_SUN8I_R40 + default 648 if MACH_SUN8I_R40_V40 default 312 if MACH_SUN6I || MACH_SUN8I default 360 if MACH_SUN4I || MACH_SUN5I || MACH_SUN7I || \ MACH_SUN8I_V3S @@ -382,7 +390,7 @@ config DRAM_ZQ default 123 if MACH_SUN4I || MACH_SUN5I || MACH_SUN6I || MACH_SUN8I default 127 if MACH_SUN7I default 14779 if MACH_SUN8I_V3S - default 3881979 if MACH_SUN8I_R40 + default 3881979 if MACH_SUN8I_R40_V40 default 4145117 if MACH_SUN9I default 3881915 if MACH_SUN50I ---help--- @@ -392,7 +400,7 @@ config DRAM_ODT_EN bool "sunxi dram odt enable" default n if !MACH_SUN8I_A23 default y if MACH_SUN8I_A23 - default y if MACH_SUN8I_R40 + default y if MACH_SUN8I_R40_V40 default y if MACH_SUN50I ---help--- Select this to enable dram odt (on die termination). @@ -633,7 +641,7 @@ config USB3_VBUS_PIN
config I2C0_ENABLE bool "Enable I2C/TWI controller 0" - default y if MACH_SUN4I || MACH_SUN5I || MACH_SUN7I || MACH_SUN8I_R40 + default y if MACH_SUN4I || MACH_SUN5I || MACH_SUN7I || MACH_SUN8I_R40_V40 default n if MACH_SUN6I || MACH_SUN8I select CMD_I2C ---help--- @@ -694,7 +702,7 @@ config VIDEO_SUNXI bool "Enable graphical uboot console on HDMI, LCD or VGA" depends on !MACH_SUN8I_A83T depends on !MACH_SUNXI_H3_H5 - depends on !MACH_SUN8I_R40 + depends on !MACH_SUN8I_R40_V40 depends on !MACH_SUN8I_V3S depends on !MACH_SUN9I depends on !MACH_SUN50I diff --git a/arch/arm/mach-sunxi/board.c b/arch/arm/mach-sunxi/board.c index 1753faec1d..8e097d67e6 100644 --- a/arch/arm/mach-sunxi/board.c +++ b/arch/arm/mach-sunxi/board.c @@ -67,14 +67,13 @@ struct mm_region *mem_map = sunxi_mem_map; static int gpio_init(void) { #if CONFIG_CONS_INDEX == 1 && defined(CONFIG_UART0_PORT_F) -#if defined(CONFIG_MACH_SUN4I) || \ - defined(CONFIG_MACH_SUN7I) || \ - defined(CONFIG_MACH_SUN8I_R40) +#if defined(CONFIG_MACH_SUN4I) || defined(CONFIG_MACH_SUN7I) || \ + defined(CONFIG_MACH_SUN8I_R40_V40) /* disable GPB22,23 as uart0 tx,rx to avoid conflict */ sunxi_gpio_set_cfgpin(SUNXI_GPB(22), SUNXI_GPIO_INPUT); sunxi_gpio_set_cfgpin(SUNXI_GPB(23), SUNXI_GPIO_INPUT); #endif -#if defined(CONFIG_MACH_SUN8I) && !defined(CONFIG_MACH_SUN8I_R40) +#if defined(CONFIG_MACH_SUN8I) && !defined(CONFIG_MACH_SUN8I_R40_V40) sunxi_gpio_set_cfgpin(SUNXI_GPF(2), SUN8I_GPF_UART0); sunxi_gpio_set_cfgpin(SUNXI_GPF(4), SUN8I_GPF_UART0); #else @@ -84,7 +83,7 @@ static int gpio_init(void) sunxi_gpio_set_pull(SUNXI_GPF(4), 1); #elif CONFIG_CONS_INDEX == 1 && (defined(CONFIG_MACH_SUN4I) || \ defined(CONFIG_MACH_SUN7I) || \ - defined(CONFIG_MACH_SUN8I_R40)) + defined(CONFIG_MACH_SUN8I_R40_V40)) sunxi_gpio_set_cfgpin(SUNXI_GPB(22), SUN4I_GPB_UART0); sunxi_gpio_set_cfgpin(SUNXI_GPB(23), SUN4I_GPB_UART0); sunxi_gpio_set_pull(SUNXI_GPB(23), SUNXI_GPIO_PULL_UP); @@ -275,7 +274,7 @@ void board_init_f(ulong dummy)
void reset_cpu(ulong addr) { -#if defined(CONFIG_SUNXI_GEN_SUN4I) || defined(CONFIG_MACH_SUN8I_R40) +#if defined(CONFIG_SUNXI_GEN_SUN4I) || defined(CONFIG_MACH_SUN8I_R40_V40) static const struct sunxi_wdog *wdog = &((struct sunxi_timer_reg *)SUNXI_TIMER_BASE)->wdog;
diff --git a/arch/arm/mach-sunxi/clock_sun6i.c b/arch/arm/mach-sunxi/clock_sun6i.c index 870ff5b1e0..6347085a76 100644 --- a/arch/arm/mach-sunxi/clock_sun6i.c +++ b/arch/arm/mach-sunxi/clock_sun6i.c @@ -35,7 +35,7 @@ void clock_init_safe(void) clrbits_le32(&prcm->pll_ctrl1, PRCM_PLL_CTRL_LDO_KEY_MASK); #endif
-#if defined(CONFIG_MACH_SUN8I_R40) || defined(CONFIG_MACH_SUN50I) +#if defined(CONFIG_MACH_SUN8I_R40_V40) || defined(CONFIG_MACH_SUN50I) /* Set PLL lock enable bits and switch to old lock mode */ writel(GENMASK(12, 0), &ccm->pll_lock_ctrl); #endif @@ -52,7 +52,7 @@ void clock_init_safe(void) if (IS_ENABLED(CONFIG_MACH_SUN6I)) writel(MBUS_CLK_DEFAULT, &ccm->mbus1_clk_cfg);
-#if defined(CONFIG_MACH_SUN8I_R40) && defined(CONFIG_SUNXI_AHCI) +#if defined(CONFIG_MACH_SUN8I_R40_V40) && defined(CONFIG_SUNXI_AHCI) setbits_le32(&ccm->sata_pll_cfg, CCM_SATA_PLL_DEFAULT); setbits_le32(&ccm->ahb_reset0_cfg, 0x1 << AHB_GATE_OFFSET_SATA); setbits_le32(&ccm->ahb_gate0, 0x1 << AHB_GATE_OFFSET_SATA); @@ -273,9 +273,8 @@ void clock_set_pll10(unsigned int clk) } #endif
-#if defined(CONFIG_MACH_SUN8I_A33) || \ - defined(CONFIG_MACH_SUN8I_R40) || \ - defined(CONFIG_MACH_SUN50I) +#if defined(CONFIG_MACH_SUN8I_A33) || defined(CONFIG_MACH_SUN8I_R40_V40) || \ + defined(CONFIG_MACH_SUN50I) void clock_set_pll11(unsigned int clk, bool sigma_delta_enable) { struct sunxi_ccm_reg * const ccm = diff --git a/arch/arm/mach-sunxi/cpu_info.c b/arch/arm/mach-sunxi/cpu_info.c index 25a5ec26a0..6f1386b2d0 100644 --- a/arch/arm/mach-sunxi/cpu_info.c +++ b/arch/arm/mach-sunxi/cpu_info.c @@ -89,6 +89,8 @@ int print_cpuinfo(void) printf("CPU: Allwinner H3 (SUN8I %04x)\n", sunxi_get_sram_id()); #elif defined CONFIG_MACH_SUN8I_R40 printf("CPU: Allwinner R40 (SUN8I %04x)\n", sunxi_get_sram_id()); +#elif defined CONFIG_MACH_SUN8I_V40 + printf("CPU: Allwinner V40 (SUN8I %04x)\n", sunxi_get_sram_id()); #elif defined CONFIG_MACH_SUN8I_V3S printf("CPU: Allwinner V3s (SUN8I %04x)\n", sunxi_get_sram_id()); #elif defined CONFIG_MACH_SUN9I diff --git a/arch/arm/mach-sunxi/dram_sunxi_dw.c b/arch/arm/mach-sunxi/dram_sunxi_dw.c index 78b4ffb9c3..ffe39216c7 100644 --- a/arch/arm/mach-sunxi/dram_sunxi_dw.c +++ b/arch/arm/mach-sunxi/dram_sunxi_dw.c @@ -43,7 +43,7 @@ static void mctl_set_bit_delays(struct dram_para *para) writel(ACBDLR_WRITE_DELAY(para->ac_delays[i]), &mctl_ctl->acbdlr[i]);
-#ifdef CONFIG_MACH_SUN8I_R40 +#ifdef CONFIG_MACH_SUN8I_R40_V40 /* DQSn, DMn, DQn output enable bit delay */ for (i = 0; i < 4; i++) writel(0x6 << 24, &mctl_ctl->dx[i].sdlr); @@ -700,7 +700,7 @@ unsigned long sunxi_dram_init(void) .dx_read_delays = SUN8I_H3_DX_READ_DELAYS, .dx_write_delays = SUN8I_H3_DX_WRITE_DELAYS, .ac_delays = SUN8I_H3_AC_DELAYS, -#elif defined(CONFIG_MACH_SUN8I_R40) +#elif defined(CONFIG_MACH_SUN8I_R40_V40) .dx_read_delays = SUN8I_R40_DX_READ_DELAYS, .dx_write_delays = SUN8I_R40_DX_WRITE_DELAYS, .ac_delays = SUN8I_R40_AC_DELAYS, @@ -721,7 +721,7 @@ unsigned long sunxi_dram_init(void) */ #if defined(CONFIG_MACH_SUN8I_H3) uint16_t socid = SOCID_H3; -#elif defined(CONFIG_MACH_SUN8I_R40) +#elif defined(CONFIG_MACH_SUN8I_R40_V40) uint16_t socid = SOCID_R40; /* Currently we cannot support R40 with dual rank memory */ para.dual_rank = 0; diff --git a/arch/arm/mach-sunxi/pmic_bus.c b/arch/arm/mach-sunxi/pmic_bus.c index f917c3e070..5f48bb1942 100644 --- a/arch/arm/mach-sunxi/pmic_bus.c +++ b/arch/arm/mach-sunxi/pmic_bus.c @@ -41,8 +41,8 @@ int pmic_bus_init(void) p2wi_init(); ret = p2wi_change_to_p2wi_mode(AXP221_CHIP_ADDR, AXP221_CTRL_ADDR, AXP221_INIT_DATA); -# elif defined CONFIG_MACH_SUN8I_R40 - /* Nothing. R40 uses the AXP221s in I2C mode */ +# elif defined CONFIG_MACH_SUN8I_R40_V40 + /* Nothing. R40_V40 uses the AXP221s in I2C mode */ ret = 0; # else ret = rsb_init(); @@ -68,7 +68,7 @@ int pmic_bus_read(u8 reg, u8 *data) #elif defined CONFIG_AXP221_POWER || defined CONFIG_AXP809_POWER || defined CONFIG_AXP818_POWER # ifdef CONFIG_MACH_SUN6I return p2wi_read(reg, data); -# elif defined CONFIG_MACH_SUN8I_R40 +# elif defined CONFIG_MACH_SUN8I_R40_V40 return i2c_read(AXP209_I2C_ADDR, reg, 1, data, 1); # else return rsb_read(AXP223_RUNTIME_ADDR, reg, data); @@ -85,7 +85,7 @@ int pmic_bus_write(u8 reg, u8 data) #elif defined CONFIG_AXP221_POWER || defined CONFIG_AXP809_POWER || defined CONFIG_AXP818_POWER # ifdef CONFIG_MACH_SUN6I return p2wi_write(reg, data); -# elif defined CONFIG_MACH_SUN8I_R40 +# elif defined CONFIG_MACH_SUN8I_R40_V40 return i2c_write(AXP209_I2C_ADDR, reg, 1, &data, 1); # else return rsb_write(AXP223_RUNTIME_ADDR, reg, data); diff --git a/board/sunxi/board.c b/board/sunxi/board.c index 322dd9e23a..13fedc29f5 100644 --- a/board/sunxi/board.c +++ b/board/sunxi/board.c @@ -82,10 +82,8 @@ DECLARE_GLOBAL_DATA_PTR; void i2c_init_board(void) { #ifdef CONFIG_I2C0_ENABLE -#if defined(CONFIG_MACH_SUN4I) || \ - defined(CONFIG_MACH_SUN5I) || \ - defined(CONFIG_MACH_SUN7I) || \ - defined(CONFIG_MACH_SUN8I_R40) +#if defined(CONFIG_MACH_SUN4I) || defined(CONFIG_MACH_SUN5I) || \ + defined(CONFIG_MACH_SUN7I) || defined(CONFIG_MACH_SUN8I_R40_V40) sunxi_gpio_set_cfgpin(SUNXI_GPB(0), SUN4I_GPB_TWI0); sunxi_gpio_set_cfgpin(SUNXI_GPB(1), SUN4I_GPB_TWI0); clock_twi_onoff(0, 1); @@ -101,9 +99,8 @@ void i2c_init_board(void) #endif
#ifdef CONFIG_I2C1_ENABLE -#if defined(CONFIG_MACH_SUN4I) || \ - defined(CONFIG_MACH_SUN7I) || \ - defined(CONFIG_MACH_SUN8I_R40) +#if defined(CONFIG_MACH_SUN4I) || defined(CONFIG_MACH_SUN7I) || \ + defined(CONFIG_MACH_SUN8I_R40_V40) sunxi_gpio_set_cfgpin(SUNXI_GPB(18), SUN4I_GPB_TWI1); sunxi_gpio_set_cfgpin(SUNXI_GPB(19), SUN4I_GPB_TWI1); clock_twi_onoff(1, 1); @@ -123,9 +120,8 @@ void i2c_init_board(void) #endif
#ifdef CONFIG_I2C2_ENABLE -#if defined(CONFIG_MACH_SUN4I) || \ - defined(CONFIG_MACH_SUN7I) || \ - defined(CONFIG_MACH_SUN8I_R40) +#if defined(CONFIG_MACH_SUN4I) || defined(CONFIG_MACH_SUN7I) || \ + defined(CONFIG_MACH_SUN8I_R40_V40) sunxi_gpio_set_cfgpin(SUNXI_GPB(20), SUN4I_GPB_TWI2); sunxi_gpio_set_cfgpin(SUNXI_GPB(21), SUN4I_GPB_TWI2); clock_twi_onoff(2, 1); @@ -150,7 +146,7 @@ void i2c_init_board(void) sunxi_gpio_set_cfgpin(SUNXI_GPG(11), SUN6I_GPG_TWI3); clock_twi_onoff(3, 1); #elif defined(CONFIG_MACH_SUN7I) || \ - defined(CONFIG_MACH_SUN8I_R40) + defined(CONFIG_MACH_SUN8I_R40_V40) sunxi_gpio_set_cfgpin(SUNXI_GPI(0), SUN7I_GPI_TWI3); sunxi_gpio_set_cfgpin(SUNXI_GPI(1), SUN7I_GPI_TWI3); clock_twi_onoff(3, 1); @@ -159,7 +155,7 @@ void i2c_init_board(void)
#ifdef CONFIG_I2C4_ENABLE #if defined(CONFIG_MACH_SUN7I) || \ - defined(CONFIG_MACH_SUN8I_R40) + defined(CONFIG_MACH_SUN8I_R40_V40) sunxi_gpio_set_cfgpin(SUNXI_GPI(2), SUN7I_GPI_TWI4); sunxi_gpio_set_cfgpin(SUNXI_GPI(3), SUN7I_GPI_TWI4); clock_twi_onoff(4, 1); @@ -323,7 +319,7 @@ static void mmc_pinmux_setup(int sdc) pins = sunxi_name_to_gpio_bank(CONFIG_MMC1_PINS);
#if defined(CONFIG_MACH_SUN4I) || defined(CONFIG_MACH_SUN7I) || \ - defined(CONFIG_MACH_SUN8I_R40) + defined(CONFIG_MACH_SUN8I_R40_V40) if (pins == SUNXI_GPIO_H) { /* SDC1: PH22-PH-27 */ for (pin = SUNXI_GPH(22); pin <= SUNXI_GPH(27); pin++) { @@ -418,7 +414,7 @@ static void mmc_pinmux_setup(int sdc) sunxi_gpio_set_pull(SUNXI_GPC(24), SUNXI_GPIO_PULL_UP); sunxi_gpio_set_drv(SUNXI_GPC(24), 2); } -#elif defined(CONFIG_MACH_SUN8I_R40) +#elif defined(CONFIG_MACH_SUN8I_R40_V40) /* SDC2: PC6-PC15, PC24 */ for (pin = SUNXI_GPC(6); pin <= SUNXI_GPC(15); pin++) { sunxi_gpio_set_cfgpin(pin, SUNXI_GPC_SDC2); @@ -456,7 +452,7 @@ static void mmc_pinmux_setup(int sdc) pins = sunxi_name_to_gpio_bank(CONFIG_MMC3_PINS);
#if defined(CONFIG_MACH_SUN4I) || defined(CONFIG_MACH_SUN7I) || \ - defined(CONFIG_MACH_SUN8I_R40) + defined(CONFIG_MACH_SUN8I_R40_V40) /* SDC3: PI4-PI9 */ for (pin = SUNXI_GPI(4); pin <= SUNXI_GPI(9); pin++) { sunxi_gpio_set_cfgpin(pin, SUNXI_GPI_SDC3); diff --git a/drivers/power/Kconfig b/drivers/power/Kconfig index 1a3852442a..4494075394 100644 --- a/drivers/power/Kconfig +++ b/drivers/power/Kconfig @@ -10,7 +10,7 @@ choice prompt "Select Sunxi PMIC Variant" depends on ARCH_SUNXI default AXP209_POWER if MACH_SUN4I || MACH_SUN5I || MACH_SUN7I - default AXP221_POWER if MACH_SUN6I || MACH_SUN8I_A23 || MACH_SUN8I_A33 || MACH_SUN8I_R40 + default AXP221_POWER if MACH_SUN6I || MACH_SUN8I_A23 || MACH_SUN8I_A33 || MACH_SUN8I_R40_V40 default AXP818_POWER if MACH_SUN8I_A83T default SUNXI_NO_PMIC if MACH_SUNXI_H3_H5 || MACH_SUN50I
@@ -39,7 +39,7 @@ config AXP209_POWER
config AXP221_POWER bool "axp221 / axp223 pmic support" - depends on MACH_SUN6I || MACH_SUN8I_A23 || MACH_SUN8I_A33 || MACH_SUN8I_R40 + depends on MACH_SUN6I || MACH_SUN8I_A23 || MACH_SUN8I_A33 || MACH_SUN8I_R40_V40 select AXP_PMIC_BUS select CMD_POWEROFF ---help--- @@ -75,7 +75,7 @@ endchoice config AXP_DCDC1_VOLT int "axp pmic dcdc1 voltage" depends on AXP221_POWER || AXP809_POWER || AXP818_POWER - default 3300 if AXP818_POWER || MACH_SUN8I_R40 + default 3300 if AXP818_POWER || MACH_SUN8I_R40_V40 default 3000 if MACH_SUN6I || MACH_SUN8I || MACH_SUN9I ---help--- Set the voltage (mV) to program the axp pmic dcdc1 at, set to 0 to @@ -102,7 +102,7 @@ config AXP_DCDC2_VOLT On A23/A33 boards dcdc2 is used for VDD-SYS and should be 1.1V. On A80 boards dcdc2 powers the GPU and can be left off. On A83T boards dcdc2 is used for VDD-CPUA(cluster 0) and should be 0.9V. - On R40 boards dcdc2 is VDD-CPU and should be 1.1V + On R40_V40 boards dcdc2 is VDD-CPU and should be 1.1V
config AXP_DCDC3_VOLT int "axp pmic dcdc3 voltage" @@ -110,7 +110,7 @@ config AXP_DCDC3_VOLT default 900 if AXP809_POWER || AXP818_POWER default 1500 if AXP152_POWER default 1250 if AXP209_POWER - default 1100 if MACH_SUN8I_R40 + default 1100 if MACH_SUN8I_R40_V40 default 1200 if MACH_SUN6I || MACH_SUN8I ---help--- Set the voltage (mV) to program the axp pmic dcdc3 at, set to 0 to @@ -121,7 +121,7 @@ config AXP_DCDC3_VOLT On A23 / A31 / A33 boards dcdc3 is VDD-CPU and should be 1.2V. On A80 boards dcdc3 is used for VDD-CPUA(cluster 0) and should be 0.9V. On A83T boards dcdc3 is used for VDD-CPUB(cluster 1) and should be 0.9V. - On R40 boards dcdc3 is VDD-SYS and VDD-GPU and should be 1.1V. + On R40_V40 boards dcdc3 is VDD-SYS and VDD-GPU and should be 1.1V.
config AXP_DCDC4_VOLT int "axp pmic dcdc4 voltage" @@ -146,13 +146,13 @@ config AXP_DCDC5_VOLT ---help--- Set the voltage (mV) to program the axp pmic dcdc5 at, set to 0 to disable dcdc5. - On A23 / A31 / A33 / A80 / A83T / R40 boards dcdc5 is VCC-DRAM and + On A23 / A31 / A33 / A80 / A83T / R40_V40 boards dcdc5 is VCC-DRAM and should be 1.5V, 1.35V if DDR3L is used.
config AXP_ALDO1_VOLT int "axp pmic (a)ldo1 voltage" depends on AXP221_POWER || AXP809_POWER || AXP818_POWER - default 0 if MACH_SUN6I || MACH_SUN8I_R40 + default 0 if MACH_SUN6I || MACH_SUN8I_R40_V40 default 1800 if MACH_SUN8I_A83T default 3000 if MACH_SUN8I || MACH_SUN9I ---help--- @@ -191,7 +191,7 @@ config AXP_ALDO3_VOLT Set the voltage (mV) to program the axp pmic aldo3 at, set to 0 to disable aldo3. On A10(s) / A13 / A20 boards aldo3 should be 2.8V. - On A23 / A31 / A33 / R40 boards aldo3 is VCC-PLL and AVCC and should + On A23 / A31 / A33 / R40_V40 boards aldo3 is VCC-PLL and AVCC and should be 3.0V. On A80 boards aldo3 is normally not used. On A83T / H8 boards aldo3 is AVCC, VCC-PL, and VCC-LED, and should be
Is there any difference between the R40 and V40?
If not, then there's no point in doing this. We already support the R8 and R16 that are exactly the same SoCs than the A13 and A33, respectively, without having to rewrite the whole thing.
And if there's some minor differences, you can just add a V40 option that selects the R40. In both cases, the diff is not necessary.
Maxime
On Wed, Apr 25, 2018 at 10:54 PM, Maxime Ripard maxime.ripard@bootlin.com wrote:
As of now I didn't see any diff.
What about cpu_info we can simply notify R40 for V40 SOC?
This I've tried and fired with Kbuild recursive definition issue.
Banana Pi BPI-M2 Berry is a quad-core mini single board computer built with Allwinner V40 SoC. It features - Quad Core ARM Cortex A7 CPU V40 - 1GB of RAM . - microSD/SATA port.. - onboard WiFi and BT - 4 USB A 2.0 ports - 1 USB OTG port - 1 HDMI port - 1 audio jack - DC power port
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/dts/Makefile | 2 + arch/arm/dts/sun8i-v40-bananapi-m2-berry.dts | 132 +++++++++++++++++++++++++++ board/sunxi/MAINTAINERS | 5 + configs/bananapi_m2_berry_defconfig | 14 +++ 4 files changed, 153 insertions(+) create mode 100644 arch/arm/dts/sun8i-v40-bananapi-m2-berry.dts create mode 100644 configs/bananapi_m2_berry_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index ac7667b1e8..de6103602c 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -369,6 +369,8 @@ dtb-$(CONFIG_MACH_SUN8I_R40) += \ sun8i-r40-bananapi-m2-ultra.dtb dtb-$(CONFIG_MACH_SUN8I_V3S) += \ sun8i-v3s-licheepi-zero.dtb +dtb-$(CONFIG_MACH_SUN8I_V40) += \ + sun8i-v40-bananapi-m2-berry.dtb dtb-$(CONFIG_MACH_SUN50I_H5) += \ sun50i-h5-nanopi-neo2.dtb \ sun50i-h5-nanopi-neo-plus2.dtb \ diff --git a/arch/arm/dts/sun8i-v40-bananapi-m2-berry.dts b/arch/arm/dts/sun8i-v40-bananapi-m2-berry.dts new file mode 100644 index 0000000000..193d9b29ec --- /dev/null +++ b/arch/arm/dts/sun8i-v40-bananapi-m2-berry.dts @@ -0,0 +1,132 @@ +/* + * Copyright (C) 2017 Icenowy Zheng icenowy@aosc.io + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +/dts-v1/; +#include "sun8i-r40.dtsi" + +#include <dt-bindings/gpio/gpio.h> + +/ { + model = "Banana Pi M2 Berry"; + compatible = "sinovoip,bpi-m2-berry", "allwinner,sun8i-r40"; + + aliases { + serial0 = &uart0; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; +}; + +&i2c0 { + status = "okay"; + + axp22x: pmic@68 { + compatible = "x-powers,axp221"; + reg = <0x34>; + interrupt-parent = <&nmi_intc>; + interrupts = <0 IRQ_TYPE_LEVEL_LOW>; + }; +}; + +#include "axp22x.dtsi" + +®_aldo3 { + regulator-always-on; + regulator-min-microvolt = <2700000>; + regulator-max-microvolt = <3300000>; + regulator-name = "avcc"; +}; + +®_dcdc1 { + regulator-always-on; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-name = "vcc-3v0"; +}; + +®_dcdc2 { + regulator-always-on; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1300000>; + regulator-name = "vdd-cpu"; +}; + +®_dcdc3 { + regulator-always-on; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1300000>; + regulator-name = "vdd-sys"; +}; + +®_dcdc5 { + regulator-always-on; + regulator-min-microvolt = <1500000>; + regulator-max-microvolt = <1500000>; + regulator-name = "vcc-dram"; +}; + +®_dldo1 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-wifi-io"; +}; + +®_dldo2 { + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-wifi"; +}; + +&mmc0 { + vmmc-supply = <®_dcdc1>; + bus-width = <4>; + cd-gpios = <&pio 7 13 GPIO_ACTIVE_LOW>; /* PH13 */ + status = "okay"; +}; + +&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart0_pb_pins>; + status = "okay"; +}; diff --git a/board/sunxi/MAINTAINERS b/board/sunxi/MAINTAINERS index 6dd48c0265..5d31bcbdcd 100644 --- a/board/sunxi/MAINTAINERS +++ b/board/sunxi/MAINTAINERS @@ -126,6 +126,11 @@ M: Jagan Teki jagan@amarulasolutions.com S: Maintained F: configs/bananapi_m1_plus_defconfig
+BANANAPI M2 BERRY +M: Jagan Teki jagan@amarulasolutions.com +S: Maintained +F: configs/bananapi_m2_berry_defconfig + BANANAPI M2 ULTRA BOARD M: Chen-Yu Tsai wens@csie.org S: Maintained diff --git a/configs/bananapi_m2_berry_defconfig b/configs/bananapi_m2_berry_defconfig new file mode 100644 index 0000000000..7dc9190d7f --- /dev/null +++ b/configs/bananapi_m2_berry_defconfig @@ -0,0 +1,14 @@ +CONFIG_ARM=y +CONFIG_ARCH_SUNXI=y +CONFIG_SPL=y +CONFIG_MACH_SUN8I_V40=y +CONFIG_DRAM_CLK=576 +CONFIG_DRAM_ZQ=3881979 +CONFIG_DRAM_ODT_EN=y +CONFIG_MMC0_CD_PIN="PH13" +CONFIG_DEFAULT_DEVICE_TREE="sun8i-v40-bananapi-m2-berry" +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_I2C_SUPPORT=y +# CONFIG_CMD_FLASH is not set +CONFIG_AXP_DLDO4_VOLT=2500 +CONFIG_AXP_ELDO3_VOLT=1200
Jagan Teki
Jagan Teki
Maxime Ripard
