[U-Boot] [PATCH] sunxi: fix the default value of CONS_INDEX on non-A23/A33 SUN8I
Only A23/A33 in SUN8I want a default value of CONS_INDEX of 5, for other chips the default value is 1 like other Allwinner SoCs.
Fix this default value.
The original wrong value has lead to wrong console on H3 Orange Pi boards.
Fixes: 7095f8641863 ("sunxi: Convert CONS_INDEX to Kconfig")
Signed-off-by: Icenowy Zheng icenowy@aosc.io --- drivers/serial/Kconfig | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/serial/Kconfig b/drivers/serial/Kconfig index a753367ee1..58320666b7 100644 --- a/drivers/serial/Kconfig +++ b/drivers/serial/Kconfig @@ -48,11 +48,11 @@ config CONS_INDEX int "UART used for console" depends on ARCH_SUNXI default 2 if MACH_SUN5I - default 5 if MACH_SUN8I + default 5 if MACH_SUN8I_A23 || MACH_SUN8I_A33 default 1 help Configures the console index. - For Allwinner SoC., default values are 2 for SUN5I and 5 for SUN8I. + For Allwinner SoC., default values are 2 for SUN5I and 5 for A23/A33. Otherwise, the index equals 1.
config DM_SERIAL
Applied, thanks! Maxime
Icenowy Zheng
Maxime Ripard
