[U-Boot] [PATCH v7 0/2] add command env erase
sometimes it is needed to erase the non-volatile environment e.g. for boot-up with builtin-environment or after resizing env
this series add basic functionality for erasing environment from storage as a first storage-driver mmc is introduced, other needs to be added later
changes since v6: - fix whitespace around errmsg
changes since v5: - don't use the CMD_RET_ macros in erase_env - remove mmc-checks (!mmc + mmc_getwp) and add init_mmc_for_env
changes since v4: - rebased to 2019.07-rc4 - changed handling with CONFIG_ENV_OFFSET_REDUND (more similar to saveenv) - quashed last 2 commits to get 2-parts patchset
Frank Wunderlich (2): env: register erase command env: mmc: add erase-function
cmd/Kconfig | 8 +++++++ cmd/nvedit.c | 20 +++++++++++++++++ env/env.c | 30 +++++++++++++++++++++++++ env/mmc.c | 51 +++++++++++++++++++++++++++++++++++++++++++ include/environment.h | 17 +++++++++++++++ 5 files changed, 126 insertions(+)
-- 2.17.1
this patch adds basic changes for adding a erase-subcommand to env
with this command the environment stored on non-volatile storage written by saveenv can be cleared.
Signed-off-by: Frank Wunderlich frank-w@public-files.de
squashed fixes - start message with "Erasing" - mark erase-function as optional - env: separate eraseenv from saveenv
Suggested-by: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com --- cmd/Kconfig | 8 ++++++++ cmd/nvedit.c | 20 ++++++++++++++++++++ env/env.c | 30 ++++++++++++++++++++++++++++++ include/environment.h | 17 +++++++++++++++++ 4 files changed, 75 insertions(+)
diff --git a/cmd/Kconfig b/cmd/Kconfig index 0badcb3fe0..77e8a542d9 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -408,6 +408,14 @@ config CMD_SAVEENV Save all environment variables into the compiled-in persistent storage.
+config CMD_ERASEENV + bool "eraseenv" + default n + depends on CMD_SAVEENV + help + Erase environment variables from the compiled-in persistent + storage. + config CMD_ENV_EXISTS bool "env exists" default y diff --git a/cmd/nvedit.c b/cmd/nvedit.c index 52c242b4f6..63de758534 100644 --- a/cmd/nvedit.c +++ b/cmd/nvedit.c @@ -761,6 +761,20 @@ U_BOOT_CMD( "save environment variables to persistent storage", "" ); + +#if defined(CONFIG_CMD_ERASEENV) +static int do_env_erase(cmd_tbl_t *cmdtp, int flag, int argc, + char * const argv[]) +{ + return env_erase() ? 1 : 0; +} + +U_BOOT_CMD( + eraseenv, 1, 0, do_env_erase, + "erase environment variables from persistent storage", + "" +); +#endif #endif #endif /* CONFIG_SPL_BUILD */
@@ -1207,6 +1221,9 @@ static cmd_tbl_t cmd_env_sub[] = { #endif #if defined(CONFIG_CMD_SAVEENV) && !defined(CONFIG_ENV_IS_NOWHERE) U_BOOT_CMD_MKENT(save, 1, 0, do_env_save, "", ""), +#if defined(CONFIG_CMD_ERASEENV) + U_BOOT_CMD_MKENT(erase, 1, 0, do_env_erase, "", ""), +#endif #endif U_BOOT_CMD_MKENT(set, CONFIG_SYS_MAXARGS, 0, do_env_set, "", ""), #if defined(CONFIG_CMD_ENV_EXISTS) @@ -1282,6 +1299,9 @@ static char env_help_text[] = #endif #if defined(CONFIG_CMD_SAVEENV) && !defined(CONFIG_ENV_IS_NOWHERE) "env save - save environment\n" +#if defined(CONFIG_CMD_ERASEENV) + "env erase - erase environment\n" +#endif #endif #if defined(CONFIG_CMD_NVEDIT_EFI) "env set -e name [arg ...] - set UEFI variable; unset if 'arg' not specified\n" diff --git a/env/env.c b/env/env.c index 4b417b90a2..d3cbe2f915 100644 --- a/env/env.c +++ b/env/env.c @@ -24,6 +24,8 @@ void env_fix_drivers(void) entry->load += gd->reloc_off; if (entry->save) entry->save += gd->reloc_off; + if (entry->erase) + entry->erase += gd->reloc_off; if (entry->init) entry->init += gd->reloc_off; } @@ -254,6 +256,34 @@ int env_save(void) return -ENODEV; }
+int env_erase(void) +{ + struct env_driver *drv; + + drv = env_driver_lookup(ENVOP_ERASE, gd->env_load_prio); + if (drv) { + int ret; + + if (!drv->erase) + return -ENODEV; + + if (!env_has_inited(drv->location)) + return -ENODEV; + + printf("Erasing Environment on %s... ", drv->name); + ret = drv->erase(); + if (ret) + printf("Failed (%d)\n", ret); + else + printf("OK\n"); + + if (!ret) + return 0; + } + + return -ENODEV; +} + int env_init(void) { struct env_driver *drv; diff --git a/include/environment.h b/include/environment.h index cd96676141..de67cf4f0e 100644 --- a/include/environment.h +++ b/include/environment.h @@ -200,6 +200,7 @@ enum env_operation { ENVOP_INIT, /* we want to call the init function */ ENVOP_LOAD, /* we want to call the load function */ ENVOP_SAVE, /* we want to call the save function */ + ENVOP_ERASE, /* we want to call the erase function */ };
struct env_driver { @@ -225,6 +226,15 @@ struct env_driver { */ int (*save)(void);
+ /** + * erase() - Erase the environment on storage + * + * This method is optional and required for 'eraseenv' to work. + * + * @return 0 if OK, -ve on error + */ + int (*erase)(void); + /** * init() - Set up the initial pre-relocation environment * @@ -303,6 +313,13 @@ int env_load(void); */ int env_save(void);
+/** + * env_erase() - Erase the environment on storage + * + * @return 0 if OK, -ve on error + */ +int env_erase(void); + /** * env_fix_drivers() - Updates envdriver as per relocation */ -- 2.17.1
Am 29.06.2019 um 11:36 schrieb Frank Wunderlich:
squashed fixes
Reviewed-by: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com
=2D-- cmd/Kconfig | 8 ++++++++ cmd/nvedit.c | 20 ++++++++++++++++++++ env/env.c | 30 ++++++++++++++++++++++++++++++ include/environment.h | 17 +++++++++++++++++ 4 files changed, 75 insertions(+)
diff --git a/cmd/Kconfig b/cmd/Kconfig index 0badcb3fe0..77e8a542d9 100644 =2D-- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -408,6 +408,14 @@ config CMD_SAVEENV Save all environment variables into the compiled-in persistent storage.
- bool "eraseenv"
- default n
- depends on CMD_SAVEENV
- help
storage.
- config CMD_ENV_EXISTS bool "env exists" default y
diff --git a/cmd/nvedit.c b/cmd/nvedit.c index 52c242b4f6..63de758534 100644 =2D-- a/cmd/nvedit.c +++ b/cmd/nvedit.c @@ -761,6 +761,20 @@ U_BOOT_CMD( "save environment variables to persistent storage", "" );
- return env_erase() ? 1 : 0;
+U_BOOT_CMD(
- eraseenv, 1, 0, do_env_erase,
- "erase environment variables from persistent storage",
@@ -1207,6 +1221,9 @@ static cmd_tbl_t cmd_env_sub[] =3D { #endif #if defined(CONFIG_CMD_SAVEENV) && !defined(CONFIG_ENV_IS_NOWHERE) U_BOOT_CMD_MKENT(save, 1, 0, do_env_save, "", ""), +#if defined(CONFIG_CMD_ERASEENV)
- U_BOOT_CMD_MKENT(erase, 1, 0, do_env_erase, "", ""),
+#endif #endif U_BOOT_CMD_MKENT(set, CONFIG_SYS_MAXARGS, 0, do_env_set, "", ""), #if defined(CONFIG_CMD_ENV_EXISTS) @@ -1282,6 +1299,9 @@ static char env_help_text[] =3D #endif #if defined(CONFIG_CMD_SAVEENV) && !defined(CONFIG_ENV_IS_NOWHERE) "env save - save environment\n" +#if defined(CONFIG_CMD_ERASEENV)
- "env erase - erase environment\n"
+#endif #endif #if defined(CONFIG_CMD_NVEDIT_EFI) "env set -e name [arg ...] - set UEFI variable; unset if 'arg' not speci= fied\n" diff --git a/env/env.c b/env/env.c index 4b417b90a2..d3cbe2f915 100644 =2D-- a/env/env.c +++ b/env/env.c @@ -24,6 +24,8 @@ void env_fix_drivers(void) entry->load +=3D gd->reloc_off; if (entry->save) entry->save +=3D gd->reloc_off;
if (entry->erase)
if (entry->init) entry->init +=3D gd->reloc_off; }entry->erase +=3D gd->reloc_off;
- struct env_driver *drv;
- drv =3D env_driver_lookup(ENVOP_ERASE, gd->env_load_prio);
- if (drv) {
int ret;
if (!drv->erase)
return -ENODEV;
return -ENODEV;
ret =3D drv->erase();
if (ret)
else
printf("OK\n");
if (!ret)
- return -ENODEV;
- int env_init(void) { struct env_driver *drv;
diff --git a/include/environment.h b/include/environment.h index cd96676141..de67cf4f0e 100644 =2D-- a/include/environment.h +++ b/include/environment.h @@ -200,6 +200,7 @@ enum env_operation { ENVOP_INIT, /* we want to call the init function */ ENVOP_LOAD, /* we want to call the load function */ ENVOP_SAVE, /* we want to call the save function */
struct env_driver {
- int (*erase)(void);
- init() - Set up the initial pre-relocation environment
- env_erase() - Erase the environment on storage
- @return 0 if OK, -ve on error
- env_fix_drivers() - Updates envdriver as per relocation
=2D- 2.17.1
squashed fixes
Suggested-by: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com Reviewed-by: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com
this adds erase environment for mmc storage
squashed fixes: - add CONFIG_CMD_ERASEENV - env: erase redundant offset if defined - changes mentioned by Simon - fix whitespaces around errmsg
Suggested-by: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com Signed-off-by: Frank Wunderlich frank-w@public-files.de --- env/mmc.c | 51 +++++++++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 51 insertions(+)
diff --git a/env/mmc.c b/env/mmc.c index c3cf35d01b..b7b833f423 100644 --- a/env/mmc.c +++ b/env/mmc.c @@ -242,6 +242,54 @@ fini: fini_mmc_for_env(mmc); return ret; } + +#if defined(CONFIG_CMD_ERASEENV) +static inline int erase_env(struct mmc *mmc, unsigned long size, + unsigned long offset) +{ + uint blk_start, blk_cnt, n; + struct blk_desc *desc = mmc_get_blk_desc(mmc); + + blk_start = ALIGN(offset, mmc->write_bl_len) / mmc->write_bl_len; + blk_cnt = ALIGN(size, mmc->write_bl_len) / mmc->write_bl_len; + + n = blk_derase(desc, blk_start, blk_cnt); + printf("%d blocks erased: %s\n", n, (n == blk_cnt) ? "OK" : "ERROR"); + + return (n == blk_cnt) ? 0 : 1; +} + +static int env_mmc_erase(void) +{ + int dev = mmc_get_env_dev(); + struct mmc *mmc = find_mmc_device(dev); + int ret, copy = 0; + u32 offset; + const char *errmsg; + + errmsg = init_mmc_for_env(mmc); + if (errmsg) { + printf("%s\n", errmsg); + return 1; + } + + if (mmc_get_env_addr(mmc, copy, &offset)) + return CMD_RET_FAILURE; + + ret = erase_env(mmc, CONFIG_ENV_SIZE, offset); + +#ifdef CONFIG_ENV_OFFSET_REDUND + copy = 1; + + if (mmc_get_env_addr(mmc, copy, &offset)) + return CMD_RET_FAILURE; + + ret |= erase_env(mmc, CONFIG_ENV_SIZE, offset); +#endif + + return ret; +} +#endif /* CONFIG_CMD_ERASEENV */ #endif /* CONFIG_CMD_SAVEENV && !CONFIG_SPL_BUILD */
static inline int read_env(struct mmc *mmc, unsigned long size, @@ -351,5 +399,8 @@ U_BOOT_ENV_LOCATION(mmc) = { .load = env_mmc_load, #ifndef CONFIG_SPL_BUILD .save = env_save_ptr(env_mmc_save), +#if defined(CONFIG_CMD_ERASEENV) + .erase = env_mmc_erase, +#endif #endif }; -- 2.17.1
squashed fixes:
=2D-- env/mmc.c | 51 +++++++++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 51 insertions(+)
diff --git a/env/mmc.c b/env/mmc.c index c3cf35d01b..b7b833f423 100644 =2D-- a/env/mmc.c +++ b/env/mmc.c @@ -242,6 +242,54 @@ fini: fini_mmc_for_env(mmc); return ret; }
- uint blk_start, blk_cnt, n;
- struct blk_desc *desc =3D mmc_get_blk_desc(mmc);
- blk_start =3D ALIGN(offset, mmc->write_bl_len) / mmc->write_bl_len;
- blk_cnt =3D ALIGN(size, mmc->write_bl_len) / mmc->write_bl_len;
- n =3D blk_derase(desc, blk_start, blk_cnt);
- printf("%d blocks erased: %s\n", n, (n =3D=3D blk_cnt) ? "OK" : "ERROR")=
- return (n =3D=3D blk_cnt) ? 0 : 1;
- int dev =3D mmc_get_env_dev();
- struct mmc *mmc =3D find_mmc_device(dev);
- int ret, copy =3D 0;
- u32 offset;
- const char *errmsg;
- errmsg =3D init_mmc_for_env(mmc);
- if (errmsg) {
return 1;
- if (mmc_get_env_addr(mmc, copy, &offset))
- ret =3D erase_env(mmc, CONFIG_ENV_SIZE, offset);
- copy =3D 1;
- ret |=3D erase_env(mmc, CONFIG_ENV_SIZE, offset);
- return ret;
static inline int read_env(struct mmc *mmc, unsigned long size, @@ -351,5 +399,8 @@ U_BOOT_ENV_LOCATION(mmc) =3D { .load =3D env_mmc_load, #ifndef CONFIG_SPL_BUILD .save =3D env_save_ptr(env_mmc_save), +#if defined(CONFIG_CMD_ERASEENV)
- .erase =3D env_mmc_erase,
+#endif #endif }; =2D- 2.17.1
squashed fixes:
Suggested-by: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com Signed-off-by: Frank Wunderlich frank-w@public-files.de Reviewed-by: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com
any new opinions about last version? can it be merged to next u-boot version?
regards Frank
Gesendet: Samstag, 29. Juni 2019 um 11:36 Uhr Von: "Frank Wunderlich" frank-w@public-files.de An: "Simon Goldschmidt" simon.k.r.goldschmidt@gmail.com, u-boot@lists.denx.de Cc: "Frank Wunderlich" frank-w@public-files.de Betreff: [PATCH v7 0/2] add command env erase
changes since v6:
changes since v5:
changes since v4:
-- 2.17.1
Am 07.07.2019 um 20:40 schrieb Frank Wunderlich:
I remember having answered to v5, then you sent v6 and without further responses sent v7. I fail to read from the patches what actually changed between the versions. You have written a changelog in the cover letter, please do so for the different patches as well.
Further, you have not integrated by Reviewed-by tag to 1/2 I sent for v5...
I'll no go and manually diff v6 and v6, and then reply sigh...
But even then, keep in mind I'm not the one mergin this!
regards Frank
changes since v6:
changes since v5:
changes since v4:
-- 2.17.1
Hi Simon
Am 9. Juli 2019 21:23:45 MESZ schrieb Simon Goldschmidt simon.k.r.goldschmidt@gmail.com:
Only change between v6 and v7 is in 2/2 (mentioned in cover letter and 2/2 but there not as version history):
There are spaces instead of tabs i've seen after send v6. So i fixed that without waiting for responses.
V6 has changed to be closer to saveenv like you suggested.
Sorry i missed that,1/2 afair has not changed since v5
Regards Frank
Am 09.07.2019 um 21:48 schrieb Frank Wunderlich:
Hi Simon
That's not the point. The point is it should be in the patch so I can jsut see it when finding the time to look at it.
I encourage you to rely on patman creating the cover letter and changelog for you (see 'tools/patman/README').
That wouldn't have been a problem if the patches contained a changelog. And for patches without changes from one version to the next, include "-no changes" or something like that to let everyone know you did not forget the changelog (or just use patman :)
Yes, I've just sent by rb.
No problem, I keep forgetting that too, just wanted to let you know.
Regards Frank
Frank Wunderlich
Simon Goldschmidt
