[PATCH v2] gpio: rockchip: Add support for RK3568 and RK3588 banks
The GPIO V2 controller on RK3568 and RK3588 works very similar to prior generation, main difference is the use of a write mask in the upper 16 bits and register address offset have changed.
GPIO_VER_ID is a new register at 0x0078 that is used to determine when the driver should use new or old register offsets and values. Earlier generation return 0x0 from this offset.
Refactor code and add support for the GPIO V2 controller used in RK3568 and RK3588.
Signed-off-by: Jonas Karlman jonas@kwiboo.se --- Changes in v2: - Drop two patches related to gpio alias id
drivers/gpio/rk_gpio.c | 112 ++++++++++++++++++++++++++++------------- 1 file changed, 76 insertions(+), 36 deletions(-)
diff --git a/drivers/gpio/rk_gpio.c b/drivers/gpio/rk_gpio.c index f7ad4d68b452..d9bde8f4f034 100644 --- a/drivers/gpio/rk_gpio.c +++ b/drivers/gpio/rk_gpio.c @@ -13,83 +13,118 @@ #include <asm/gpio.h> #include <asm/io.h> #include <asm/arch-rockchip/clock.h> +#include <asm/arch-rockchip/hardware.h> #include <asm/arch-rockchip/gpio.h> #include <dm/pinctrl.h> -#include <dt-bindings/clock/rk3288-cru.h> +#include <dm/read.h> +#include <dt-bindings/pinctrl/rockchip.h> + +#define SWPORT_DR 0x0000 +#define SWPORT_DDR 0x0004 +#define EXT_PORT 0x0050 +#define SWPORT_DR_L 0x0000 +#define SWPORT_DR_H 0x0004 +#define SWPORT_DDR_L 0x0008 +#define SWPORT_DDR_H 0x000C +#define EXT_PORT_V2 0x0070 +#define VER_ID_V2 0x0078
enum { ROCKCHIP_GPIOS_PER_BANK = 32, };
-#define OFFSET_TO_BIT(bit) (1UL << (bit)) - struct rockchip_gpio_priv { - struct rockchip_gpio_regs *regs; + void __iomem *regs; struct udevice *pinctrl; int bank; char name[2]; + u32 version; };
-static int rockchip_gpio_direction_input(struct udevice *dev, unsigned offset) +static int rockchip_gpio_get_value(struct udevice *dev, unsigned offset) { struct rockchip_gpio_priv *priv = dev_get_priv(dev); - struct rockchip_gpio_regs *regs = priv->regs; + u32 mask = BIT(offset), data;
- clrbits_le32(®s->swport_ddr, OFFSET_TO_BIT(offset)); + if (priv->version) + data = readl(priv->regs + EXT_PORT_V2); + else + data = readl(priv->regs + EXT_PORT);
- return 0; + return (data & mask) ? 1 : 0; }
-static int rockchip_gpio_direction_output(struct udevice *dev, unsigned offset, - int value) +static int rockchip_gpio_set_value(struct udevice *dev, unsigned offset, + int value) { struct rockchip_gpio_priv *priv = dev_get_priv(dev); - struct rockchip_gpio_regs *regs = priv->regs; - int mask = OFFSET_TO_BIT(offset); + u32 mask = BIT(offset), data = value ? mask : 0;
- clrsetbits_le32(®s->swport_dr, mask, value ? mask : 0); - setbits_le32(®s->swport_ddr, mask); + if (priv->version && offset >= 16) + rk_clrsetreg(priv->regs + SWPORT_DR_H, mask >> 16, data >> 16); + else if (priv->version) + rk_clrsetreg(priv->regs + SWPORT_DR_L, mask, data); + else + clrsetbits_le32(priv->regs + SWPORT_DR, mask, data);
return 0; }
-static int rockchip_gpio_get_value(struct udevice *dev, unsigned offset) +static int rockchip_gpio_direction_input(struct udevice *dev, unsigned offset) { struct rockchip_gpio_priv *priv = dev_get_priv(dev); - struct rockchip_gpio_regs *regs = priv->regs; + u32 mask = BIT(offset); + + if (priv->version && offset >= 16) + rk_clrreg(priv->regs + SWPORT_DDR_H, mask >> 16); + else if (priv->version) + rk_clrreg(priv->regs + SWPORT_DDR_L, mask); + else + clrbits_le32(priv->regs + SWPORT_DDR, mask);
- return readl(®s->ext_port) & OFFSET_TO_BIT(offset) ? 1 : 0; + return 0; }
-static int rockchip_gpio_set_value(struct udevice *dev, unsigned offset, - int value) +static int rockchip_gpio_direction_output(struct udevice *dev, unsigned offset, + int value) { struct rockchip_gpio_priv *priv = dev_get_priv(dev); - struct rockchip_gpio_regs *regs = priv->regs; - int mask = OFFSET_TO_BIT(offset); + u32 mask = BIT(offset); + + rockchip_gpio_set_value(dev, offset, value);
- clrsetbits_le32(®s->swport_dr, mask, value ? mask : 0); + if (priv->version && offset >= 16) + rk_setreg(priv->regs + SWPORT_DDR_H, mask >> 16); + else if (priv->version) + rk_setreg(priv->regs + SWPORT_DDR_L, mask); + else + setbits_le32(priv->regs + SWPORT_DDR, mask);
return 0; }
static int rockchip_gpio_get_function(struct udevice *dev, unsigned offset) { -#ifdef CONFIG_SPL_BUILD - return -ENODATA; -#else struct rockchip_gpio_priv *priv = dev_get_priv(dev); - struct rockchip_gpio_regs *regs = priv->regs; - bool is_output; + u32 mask = BIT(offset), data; int ret;
- ret = pinctrl_get_gpio_mux(priv->pinctrl, priv->bank, offset); - if (ret) - return ret; - is_output = readl(®s->swport_ddr) & OFFSET_TO_BIT(offset); + if (CONFIG_IS_ENABLED(PINCTRL)) { + ret = pinctrl_get_gpio_mux(priv->pinctrl, priv->bank, offset); + if (ret < 0) + return ret; + else if (ret != RK_FUNC_GPIO) + return GPIOF_FUNC; + } + + if (priv->version && offset >= 16) + data = readl(priv->regs + SWPORT_DDR_H) << 16; + else if (priv->version) + data = readl(priv->regs + SWPORT_DDR_L); + else + data = readl(priv->regs + SWPORT_DDR);
- return is_output ? GPIOF_OUTPUT : GPIOF_INPUT; -#endif + return (data & mask) ? GPIOF_OUTPUT : GPIOF_INPUT; }
/* Simple SPL interface to GPIOs */ @@ -147,9 +182,12 @@ static int rockchip_gpio_probe(struct udevice *dev) int ret;
priv->regs = dev_read_addr_ptr(dev); - ret = uclass_first_device_err(UCLASS_PINCTRL, &priv->pinctrl); - if (ret) - return ret; + + if (CONFIG_IS_ENABLED(PINCTRL)) { + ret = uclass_first_device_err(UCLASS_PINCTRL, &priv->pinctrl); + if (ret) + return ret; + }
/* * If "gpio-ranges" is present in the devicetree use it to parse @@ -170,6 +208,8 @@ static int rockchip_gpio_probe(struct udevice *dev) priv->name[0] = 'A' + priv->bank; uc_priv->bank_name = priv->name;
+ priv->version = readl(priv->regs + VER_ID_V2); + return 0; }
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
Changes in v2:
- void __iomem *regs; struct udevice *pinctrl; int bank; char name[2];
- u32 version; };
- u32 mask = BIT(offset), data;
- if (priv->version)
- else
- return (data & mask) ? 1 : 0; }
int value)
{ struct rockchip_gpio_priv *priv = dev_get_priv(dev);int value)
- u32 mask = BIT(offset), data = value ? mask : 0;
else
return 0; }
- u32 mask = BIT(offset);
- if (priv->version && offset >= 16)
- else if (priv->version)
- else
- return 0; }
int value)
- rockchip_gpio_set_value(dev, offset, value);
else
return 0; }
- return -ENODATA;
- bool is_output;
- u32 mask = BIT(offset), data; int ret;
- if (ret)
return ret;
- if (CONFIG_IS_ENABLED(PINCTRL)) {
if (ret < 0)
return ret;
return GPIOF_FUNC;
- else
-#endif
- if (ret)
return ret;
if (ret)
return ret;
- If "gpio-ranges" is present in the devicetree use it to parse
- priv->version = readl(priv->regs + VER_ID_V2);
- return 0; }
Jonas Karlman
Kever Yang
