[U-Boot] [PATCH v2] rockchip: add basic support for evb-rk3288 board
evb-3288 board RK3288-based development board with 2 USB ports, HDMI, VGA, micro-SD card, audio, WiFi and Gigabit Ethernet. It also includes on-board 8G eMMC and 2GB of SDRAM. Expansion connector provide access to display pins, I2C, SPI, UART and GPIOs. This add some basic files required to allow the board to output serial messaged and can run command(mmc info etc).
evb-rk3288 also supports booting from eMMC or SD card, the default is eMMC.
Signed-off-by: Ziyuan Xu xzy.xu@rock-chips.com Reviewed-by: Simon Glass sjg@chromium.org ---
Changes in v2: - Fix a comment nit - Add reviewed flag from Simon
arch/arm/dts/Makefile | 1 + arch/arm/dts/rk3288-evb.dts | 59 +++++ arch/arm/dts/rk3288-evb.dtsi | 379 ++++++++++++++++++++++++++++++ arch/arm/mach-rockchip/rk3288-board-spl.c | 4 +- arch/arm/mach-rockchip/rk3288/Kconfig | 10 + board/evb-rk3288/evb-rk3288/Kconfig | 15 ++ board/evb-rk3288/evb-rk3288/MAINTAINERS | 6 + board/evb-rk3288/evb-rk3288/Makefile | 7 + board/evb-rk3288/evb-rk3288/evb-rk3288.c | 15 ++ configs/evb-rk3288_defconfig | 67 ++++++ doc/README.rockchip | 3 +- include/configs/evb-rk3288.h | 26 ++ 12 files changed, 590 insertions(+), 2 deletions(-) create mode 100644 arch/arm/dts/rk3288-evb.dts create mode 100644 arch/arm/dts/rk3288-evb.dtsi create mode 100644 board/evb-rk3288/evb-rk3288/Kconfig create mode 100644 board/evb-rk3288/evb-rk3288/MAINTAINERS create mode 100644 board/evb-rk3288/evb-rk3288/Makefile create mode 100644 board/evb-rk3288/evb-rk3288/evb-rk3288.c create mode 100644 configs/evb-rk3288_defconfig create mode 100644 include/configs/evb-rk3288.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 5d463ce..493b9da 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -31,6 +31,7 @@ dtb-$(CONFIG_ARCH_ROCKCHIP) += \ rk3288-firefly.dtb \ rk3288-jerry.dtb \ rk3288-rock2-square.dtb \ + rk3288-evb.dtb \ rk3036-sdk.dtb dtb-$(CONFIG_ARCH_MESON) += \ meson-gxbb-odroidc2.dtb diff --git a/arch/arm/dts/rk3288-evb.dts b/arch/arm/dts/rk3288-evb.dts new file mode 100644 index 0000000..caf24ee --- /dev/null +++ b/arch/arm/dts/rk3288-evb.dts @@ -0,0 +1,59 @@ +/* + * (C) Copyright 2016 Rockchip Electronics Co., Ltd + * + * SPDX-License-Identifier: GPL-2.0+ X11 + */ + +/dts-v1/; +#include "rk3288-evb.dtsi" + +/ { + model = "Evb-RK3288"; + compatible = "evb-rk3288,evb-rk3288", "rockchip,rk3288"; + + chosen { + stdout-path = &uart2; + }; +}; + +&dmc { + rockchip,num-channels = <2>; + rockchip,pctl-timing = <0x215 0xc8 0x0 0x35 0x26 0x2 0x70 0x2000d + 0x6 0x0 0x8 0x4 0x17 0x24 0xd 0x6 + 0x4 0x8 0x4 0x76 0x4 0x0 0x30 0x0 + 0x1 0x2 0x2 0x4 0x0 0x0 0xc0 0x4 + 0x8 0x1f4>; + rockchip,phy-timing = <0x48d7dd93 0x187008d8 0x121076 + 0x0 0xc3 0x6 0x2>; + rockchip,sdram-channel = /bits/ 8 <0x2 0xa 0x3 0x2 0x2 0x0 0xe 0xe>; + rockchip,sdram-params = <0x20d266a4 0x5b6 2 533000000 6 9 0>; +}; + +&pinctrl { + u-boot,dm-pre-reloc; +}; + +&pwm1 { + status = "okay"; +}; + +&uart2 { + u-boot,dm-pre-reloc; + reg-shift = <2>; +}; + +&sdmmc { + u-boot,dm-pre-reloc; +}; + +&emmc { + u-boot,dm-pre-reloc; +}; + +&gpio3 { + u-boot,dm-pre-reloc; +}; + +&gpio8 { + u-boot,dm-pre-reloc; +}; diff --git a/arch/arm/dts/rk3288-evb.dtsi b/arch/arm/dts/rk3288-evb.dtsi new file mode 100644 index 0000000..cb7d03e --- /dev/null +++ b/arch/arm/dts/rk3288-evb.dtsi @@ -0,0 +1,379 @@ +/* + * (C) Copyright 2016 Rockchip Electronics Co., Ltd + * + * SPDX-License-Identifier: GPL-2.0+ X11 + */ + +#include "rk3288.dtsi" + +/ { + memory { + reg = <0 0x80000000>; + }; + + keys: gpio-keys { + compatible = "gpio-keys"; + #address-cells = <1>; + #size-cells = <0>; + + button@0 { + gpio-key,wakeup = <1>; + gpios = <&gpio0 5 GPIO_ACTIVE_LOW>; + label = "GPIO Power"; + linux,code = <116>; + pinctrl-names = "default"; + pinctrl-0 = <&pwr_key>; + }; + }; + + vcc_sys: vsys-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc_sys"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-always-on; + regulator-boot-on; + }; + + vcc_flash: flash-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc_flash"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + vin-supply = <&vcc_io>; + }; + + vcc_5v: usb-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc_5v"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-always-on; + regulator-boot-on; + vin-supply = <&vcc_sys>; + }; + + vcc_host_5v: usb-host-regulator { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio0 14 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&host_vbus_drv>; + regulator-name = "vcc_host_5v"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-always-on; + vin-supply = <&vcc_5v>; + }; + + vcc_otg_5v: usb-otg-regulator { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio0 12 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&otg_vbus_drv>; + regulator-name = "vcc_otg_5v"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-always-on; + vin-supply = <&vcc_5v>; + }; +}; + +&cpu0 { + cpu0-supply = <&vdd_cpu>; +}; + +&emmc { + broken-cd; + bus-width = <8>; + cap-mmc-highspeed; + disable-wp; + non-removable; + num-slots = <1>; + pinctrl-names = "default"; + pinctrl-0 = <&emmc_clk>, <&emmc_cmd>, <&emmc_pwr>, <&emmc_bus8>; + vmmc-supply = <&vcc_io>; + vqmmc-supply = <&vcc_flash>; + status = "okay"; +}; + +&hdmi { + ddc-i2c-bus = <&i2c5>; + status = "okay"; +}; + +&i2c0 { + clock-frequency = <400000>; + status = "okay"; + + vdd_cpu: syr827@40 { + compatible = "silergy,syr827"; + fcs,suspend-voltage-selector = <1>; + reg = <0x40>; + regulator-name = "vdd_cpu"; + regulator-min-microvolt = <850000>; + regulator-max-microvolt = <1350000>; + regulator-always-on; + regulator-boot-on; + vin-supply = <&vcc_sys>; + }; + + vdd_gpu: syr828@41 { + compatible = "silergy,syr828"; + fcs,suspend-voltage-selector = <1>; + reg = <0x41>; + regulator-name = "vdd_gpu"; + regulator-min-microvolt = <850000>; + regulator-max-microvolt = <1350000>; + regulator-always-on; + vin-supply = <&vcc_sys>; + }; + + hym8563: hym8563@51 { + compatible = "haoyu,hym8563"; + reg = <0x51>; + #clock-cells = <0>; + clock-frequency = <32768>; + clock-output-names = "xin32k"; + interrupt-parent = <&gpio7>; + interrupts = <4 IRQ_TYPE_EDGE_FALLING>; + pinctrl-names = "default"; + pinctrl-0 = <&rtc_int>; + }; + + act8846: act8846@5a { + compatible = "active-semi,act8846"; + reg = <0x5a>; + pinctrl-names = "default"; + pinctrl-0 = <&pwr_hold>; + system-power-controller; + + regulators { + vcc_ddr: REG1 { + regulator-name = "vcc_ddr"; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-always-on; + }; + + vcc_io: REG2 { + regulator-name = "vcc_io"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + + vdd_log: REG3 { + regulator-name = "vdd_log"; + regulator-min-microvolt = <1100000>; + regulator-max-microvolt = <1100000>; + regulator-always-on; + }; + + vcc_20: REG4 { + regulator-name = "vcc_20"; + regulator-min-microvolt = <2000000>; + regulator-max-microvolt = <2000000>; + regulator-always-on; + }; + + vccio_sd: REG5 { + regulator-name = "vccio_sd"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + + vdd10_lcd: REG6 { + regulator-name = "vdd10_lcd"; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1000000>; + regulator-always-on; + }; + + vcca_codec: REG7 { + regulator-name = "vcca_codec"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; + + vcc_tp: REG8 { + regulator-name = "vcca_33"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; + + vccio_pmu: REG9 { + regulator-name = "vccio_pmu"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; + + vdd_10: REG10 { + regulator-name = "vdd_10"; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1000000>; + regulator-always-on; + }; + + vcc_18: REG11 { + regulator-name = "vcc_18"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + }; + + vcc18_lcd: REG12 { + regulator-name = "vcc18_lcd"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + }; + }; + }; +}; + +&i2c1 { + status = "okay"; +}; + +&i2c2 { + status = "okay"; +}; + +&i2c4 { + status = "okay"; +}; + +&i2c5 { + status = "okay"; +}; + +&pinctrl { + pcfg_output_high: pcfg-output-high { + output-high; + }; + + pcfg_output_low: pcfg-output-low { + output-low; + }; + + act8846 { + pwr_hold: pwr-hold { + rockchip,pins = <0 9 RK_FUNC_GPIO &pcfg_output_high>; + }; + }; + + hym8563 { + rtc_int: rtc-int { + rockchip,pins = <0 4 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + keys { + pwr_key: pwr-key { + rockchip,pins = <0 5 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + sdmmc { + sdmmc_pwr: sdmmc-pwr { + rockchip,pins = <7 11 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + usb_host { + host_vbus_drv: host-vbus-drv { + rockchip,pins = <0 14 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + usb_otg { + otg_vbus_drv: otg-vbus-drv { + rockchip,pins = <0 12 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; +}; + +&saradc { + vref-supply = <&vcc_18>; + status = "okay"; +}; + +&sdio0 { + broken-cd; + bus-width = <4>; + disable-wp; + non-removable; + num-slots = <1>; + pinctrl-names = "default"; + pinctrl-0 = <&sdio0_bus4>, <&sdio0_cmd>, <&sdio0_clk>; + vmmc-supply = <&vcc_18>; + status = "disabled"; +}; + +&sdmmc { + bus-width = <4>; + cap-mmc-highspeed; + cap-sd-highspeed; + card-detect-delay = <200>; + disable-wp; + num-slots = <1>; + pinctrl-names = "default"; + pinctrl-0 = <&sdmmc_clk>, <&sdmmc_cmd>, <&sdmmc_cd>, <&sdmmc_bus4>; + vmmc-supply = <&vccio_sd>; + status = "okay"; +}; + +&spi0 { + pinctrl-names = "default"; + pinctrl-0 = <&spi0_clk>, <&spi0_cs0>, <&spi0_tx>, <&spi0_rx>, <&spi0_cs1>; + status = "okay"; +}; + +&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart0_xfer>, <&uart0_cts>, <&uart0_rts>; + status = "okay"; +}; + +&uart1 { + status = "okay"; +}; + +&uart2 { + status = "okay"; +}; + +&uart3 { + status = "okay"; +}; + +&usb_host1 { + status = "okay"; +}; + +&usb_otg { + status = "okay"; +}; + +&vopb { + status = "okay"; +}; + +&vopb_mmu { + status = "okay"; +}; + +&vopl { + status = "okay"; +}; + +&vopl_mmu { + status = "okay"; +}; + +&wdt { + status = "okay"; +}; diff --git a/arch/arm/mach-rockchip/rk3288-board-spl.c b/arch/arm/mach-rockchip/rk3288-board-spl.c index 15f1266..773ea42 100644 --- a/arch/arm/mach-rockchip/rk3288-board-spl.c +++ b/arch/arm/mach-rockchip/rk3288-board-spl.c @@ -114,7 +114,9 @@ static void configure_l2ctlr(void) #ifdef CONFIG_SPL_MMC_SUPPORT static int configure_emmc(struct udevice *pinctrl) { -#if !defined(CONFIG_TARGET_ROCK2) && !defined(CONFIG_TARGET_FIREFLY_RK3288) +#if !defined(CONFIG_TARGET_ROCK2) && !defined(CONFIG_TARGET_FIREFLY_RK3288) && \ + !defined(CONFIG_TARGET_EVB_RK3288) + struct gpio_desc desc; int ret;
diff --git a/arch/arm/mach-rockchip/rk3288/Kconfig b/arch/arm/mach-rockchip/rk3288/Kconfig index 7215624..031dbfc 100644 --- a/arch/arm/mach-rockchip/rk3288/Kconfig +++ b/arch/arm/mach-rockchip/rk3288/Kconfig @@ -8,6 +8,14 @@ config TARGET_FIREFLY_RK3288 also includes on-board eMMC and 1GB of SDRAM. Expansion connectors provide access to display pins, I2C, SPI, UART and GPIOs.
+config TARGET_EVB_RK3288 + bool "Evb-RK3288" + help + EVB-RK3288 is a RK3288-based development board with 2 USB ports, + HDMI, VGA, micro-SD card, audio, WiFi and Gigabit Ethernet, It + also includes on-board eMMC and 2GB of SDRAM. Expansion connectors + provide access to display pins, I2C, SPI, UART and GPIOs. + config TARGET_CHROMEBOOK_JERRY bool "Google/Rockchip Veyron-Jerry Chromebook" help @@ -45,4 +53,6 @@ source "board/firefly/firefly-rk3288/Kconfig"
source "board/radxa/rock2/Kconfig"
+source "board/evb-rk3288/evb-rk3288/Kconfig" + endif diff --git a/board/evb-rk3288/evb-rk3288/Kconfig b/board/evb-rk3288/evb-rk3288/Kconfig new file mode 100644 index 0000000..b201acb --- /dev/null +++ b/board/evb-rk3288/evb-rk3288/Kconfig @@ -0,0 +1,15 @@ +if TARGET_EVB_RK3288 + +config SYS_BOARD + default "evb-rk3288" + +config SYS_VENDOR + default "evb-rk3288" + +config SYS_CONFIG_NAME + default "evb-rk3288" + +config BOARD_SPECIFIC_OPTIONS # dummy + def_bool y + +endif diff --git a/board/evb-rk3288/evb-rk3288/MAINTAINERS b/board/evb-rk3288/evb-rk3288/MAINTAINERS new file mode 100644 index 0000000..222c254 --- /dev/null +++ b/board/evb-rk3288/evb-rk3288/MAINTAINERS @@ -0,0 +1,6 @@ +EVB-RK3288 +M: Lin Huang hl@rock-chips.com +S: Maintained +F: board/evb-rk3288/evb-rk3288 +F: include/configs/evb-rk3288.h +F: configs/evb-rk3288_defconfig diff --git a/board/evb-rk3288/evb-rk3288/Makefile b/board/evb-rk3288/evb-rk3288/Makefile new file mode 100644 index 0000000..c11b657 --- /dev/null +++ b/board/evb-rk3288/evb-rk3288/Makefile @@ -0,0 +1,7 @@ +# +# (C) Copyright 2016 Rockchip Electronics Co., Ltd +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += evb-rk3288.o diff --git a/board/evb-rk3288/evb-rk3288/evb-rk3288.c b/board/evb-rk3288/evb-rk3288/evb-rk3288.c new file mode 100644 index 0000000..aad74ef --- /dev/null +++ b/board/evb-rk3288/evb-rk3288/evb-rk3288.c @@ -0,0 +1,15 @@ +/* + * (C) Copyright 2016 Rockchip Electronics Co., Ltd + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <spl.h> + +void board_boot_order(u32 *spl_boot_list) +{ + /* eMMC prior to sdcard */ + spl_boot_list[0] = BOOT_DEVICE_MMC2; + spl_boot_list[1] = BOOT_DEVICE_MMC1; +} diff --git a/configs/evb-rk3288_defconfig b/configs/evb-rk3288_defconfig new file mode 100644 index 0000000..41cfedd --- /dev/null +++ b/configs/evb-rk3288_defconfig @@ -0,0 +1,67 @@ +CONFIG_ARM=y +CONFIG_ARCH_ROCKCHIP=y +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_ROCKCHIP_RK3288=y +CONFIG_TARGET_EVB_RK3288=y +CONFIG_SPL_STACK_R_ADDR=0x80000 +CONFIG_DEFAULT_DEVICE_TREE="rk3288-evb" +CONFIG_SPL_STACK_R=y +CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 +CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y +# CONFIG_CMD_IMLS is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_GPIO=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_TIME=y +CONFIG_CMD_PMIC=y +CONFIG_CMD_REGULATOR=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_REGMAP=y +CONFIG_SPL_REGMAP=y +CONFIG_SYSCON=y +CONFIG_SPL_SYSCON=y +CONFIG_CLK=y +CONFIG_SPL_CLK=y +CONFIG_ROCKCHIP_GPIO=y +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_LED=y +CONFIG_LED_GPIO=y +CONFIG_SYSRESET=y +CONFIG_DM_MMC=y +CONFIG_ROCKCHIP_DWMMC=y +CONFIG_PINCTRL=y +# CONFIG_PINCTRL_FULL is not set +CONFIG_SPL_PINCTRL=y +# CONFIG_SPL_PINCTRL_FULL is not set +CONFIG_ROCKCHIP_PINCTRL=y +CONFIG_DM_PMIC=y +CONFIG_PMIC_ACT8846=y +CONFIG_DM_REGULATOR=y +CONFIG_REGULATOR_ACT8846=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_PWM=y +CONFIG_PWM_ROCKCHIP=y +CONFIG_RAM=y +CONFIG_SPL_RAM=y +CONFIG_DEBUG_UART=y +CONFIG_DEBUG_UART_BASE=0xff690000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SYS_NS16550=y +CONFIG_USE_PRIVATE_LIBGCC=y +CONFIG_USE_TINY_PRINTF=y +CONFIG_CMD_DHRYSTONE=y +CONFIG_ERRNO_STR=y diff --git a/doc/README.rockchip b/doc/README.rockchip index e0572c8..f4e8348 100644 --- a/doc/README.rockchip +++ b/doc/README.rockchip @@ -36,11 +36,12 @@ You will need: Building ========
-At present three RK3288 boards are supported: +At present four RK3288 boards are supported:
- Firefly RK3288 - use firefly-rk3288 configuration - Radxa Rock 2 - use rock2 configuration - Hisense Chromebook - use chromebook_jerry configuration + - EVB RK3288 - use evb-rk3288 configuration
Two RK3036 board are supported:
diff --git a/include/configs/evb-rk3288.h b/include/configs/evb-rk3288.h new file mode 100644 index 0000000..342557f --- /dev/null +++ b/include/configs/evb-rk3288.h @@ -0,0 +1,26 @@ +/* + * (C) Copyright 2016 Rockchip Electronics Co., Ltd + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#define ROCKCHIP_DEVICE_SETTINGS +#include <configs/rk3288_common.h> + +#define CONFIG_SPL_MMC_SUPPORT + +#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_SYS_MMC_ENV_DEV 1 +/* SPL @ 32k for ~36k + * ENV @ 96k + * u-boot @ 128K + */ +#define CONFIG_ENV_OFFSET (96 * 1024) + +#define CONFIG_SYS_WHITE_ON_BLACK +#define CONFIG_CONSOLE_SCROLL_LINES 10 + +#endif
Changes in v2:
- Fix a comment nit
Applied to u-boot-rockchip, thanks!
Ziyuan Xu
