[PATCH] arm: at91: gardena-smart-gateway-at91sam: Adjust to production values
From: Reto Schneider reto.schneider@husqvarnagroup.com
This commit updates the default config with the values that will be used soon on the Atmel / Microchip AT91SAM9G25 based GARDENA smart gateway.
Signed-off-by: Reto Schneider reto.schneider@husqvarnagroup.com --- This patch applies to current u-boot-atmel/next
configs/gardena-smart-gateway-at91sam_defconfig | 15 ++++++++++++++- 1 file changed, 14 insertions(+), 1 deletion(-)
diff --git a/configs/gardena-smart-gateway-at91sam_defconfig b/configs/gardena-smart-gateway-at91sam_defconfig index 40fe0f150e..c626cd699a 100644 --- a/configs/gardena-smart-gateway-at91sam_defconfig +++ b/configs/gardena-smart-gateway-at91sam_defconfig @@ -8,6 +8,7 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_SYS_MEMTEST_START=0x0 CONFIG_ENV_SIZE=0x10000 CONFIG_DM_GPIO=y CONFIG_SPL_TEXT_BASE=0x300000 @@ -22,6 +23,8 @@ CONFIG_DEBUG_UART=y CONFIG_FIT=y CONFIG_NAND_BOOT=y CONFIG_BOOTDELAY=0 +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_STOP_STR="x" CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk mtdparts=atmel_nand:256k(bootstrap)ro,768k(uboot)ro,256k(env_redundant),256k(env),512k(dtb),6M(kernel)ro,-(rootfs) rootfstype=ubifs ubi.mtd=6 root=ubi0:rootfs rw" CONFIG_SYS_CONSOLE_IS_IN_ENV=y @@ -32,20 +35,26 @@ CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_NAND_DRIVERS=y CONFIG_SPL_NAND_BASE=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_LICENSE=y CONFIG_CMD_BOOTZ=y +CONFIG_CMD_MEMINFO=y +CONFIG_CMD_MEMTEST=y +CONFIG_SYS_ALT_MEMTEST=y CONFIG_CMD_DM=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y CONFIG_CMD_MTD=y CONFIG_CMD_NAND=y CONFIG_CMD_WDT=y -# CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y +CONFIG_CMD_GETTIME=y +CONFIG_CMD_UUID=y CONFIG_CMD_FAT=y CONFIG_CMD_MTDPARTS=y +CONFIG_CMD_MTDPARTS_SHOW_NET_SIZES=y CONFIG_MTDIDS_DEFAULT="nand0=atmel_nand" CONFIG_MTDPARTS_DEFAULT="atmel_nand:1536k(uboot),10752k(unused),-(ubi)" CONFIG_CMD_UBI=y @@ -58,6 +67,8 @@ CONFIG_ENV_UBI_PART="ubi" CONFIG_ENV_UBI_VOLUME="uboot_env0" CONFIG_ENV_UBI_VOLUME_REDUND="uboot_env1" CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_VERSION_VARIABLE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_SPL_DM=y @@ -71,6 +82,7 @@ CONFIG_LED_GPIO=y CONFIG_MTD=y CONFIG_NAND_ATMEL=y CONFIG_SPL_GENERATE_ATMEL_PMECC_HEADER=y +CONFIG_MTD_UBI_FASTMAP=y CONFIG_DM_ETH=y CONFIG_MACB=y CONFIG_PINCTRL=y @@ -84,3 +96,4 @@ CONFIG_ATMEL_PIT_TIMER=y CONFIG_WDT=y CONFIG_WDT_AT91=y # CONFIG_UBIFS_SILENCE_MSG is not set +CONFIG_LZMA=y
Thanks, Stefan
Viele Grüße, Stefan
Applied to u-boot-atmel/next
Sorry for taking so long, somehow I missed this patch as it had identical subject with a previous patch which I already applied, but this patch does something different. Anyway, I applied it to next, but will be queued for the next merge window.
Eugen
+CONFIG_LZMA=y
2.30.2
Eugen.Hristev@microchip.com
Reto Schneider
Stefan Roese
