[PATCH 0/6] Add HopeRun HiHope RZ/G2H board support
This patch series adds the required SoC/Board support to boot HopeRun HiHope RZ/G2H board.
This patch series depend on [1] and [2] [1]https://patchwork.ozlabs.org/project/uboot/list/?series=201842 [2]https://patchwork.ozlabs.org/project/uboot/list/?series=202025
Biju Das (6): arm: rmobile: Add RZ/G2H SoC arm: renesas: Add config option for R8A774E1 SoC arm: dts: r8a774e1: Import DTS from Linux 5.9-rc4 clk: renesas: Add R8A774E1 clock tables pinctrl: renesas: r8a77951: Add R8A774E1 PFC support arm: rmobile: Add HopeRun HiHope RZ/G2H board support
arch/arm/dts/Makefile | 1 + arch/arm/dts/r8a774e1-hihope-rzg2h-ex.dts | 15 + arch/arm/dts/r8a774e1-hihope-rzg2h-u-boot.dts | 9 + arch/arm/dts/r8a774e1-hihope-rzg2h.dts | 26 + arch/arm/dts/r8a774e1-u-boot.dtsi | 25 + arch/arm/dts/r8a774e1.dtsi | 1664 +++++++++++++++++ arch/arm/mach-rmobile/Kconfig.64 | 6 + arch/arm/mach-rmobile/cpu_info.c | 2 + arch/arm/mach-rmobile/include/mach/rmobile.h | 1 + board/hoperun/hihope-rzg2/hihope-rzg2.c | 6 +- configs/hihope_rzg2_defconfig | 2 +- drivers/clk/renesas/Kconfig | 6 + drivers/clk/renesas/Makefile | 1 + drivers/clk/renesas/r8a774e1-cpg-mssr.c | 358 ++++ drivers/pinctrl/renesas/Kconfig | 10 + drivers/pinctrl/renesas/Makefile | 1 + drivers/pinctrl/renesas/pfc-r8a7795.c | 905 +++++---- drivers/pinctrl/renesas/pfc.c | 11 + drivers/pinctrl/renesas/sh_pfc.h | 1 + include/dt-bindings/clock/r8a774e1-cpg-mssr.h | 59 + include/dt-bindings/power/r8a774e1-sysc.h | 36 + 21 files changed, 2734 insertions(+), 411 deletions(-) create mode 100644 arch/arm/dts/r8a774e1-hihope-rzg2h-ex.dts create mode 100644 arch/arm/dts/r8a774e1-hihope-rzg2h-u-boot.dts create mode 100644 arch/arm/dts/r8a774e1-hihope-rzg2h.dts create mode 100644 arch/arm/dts/r8a774e1-u-boot.dtsi create mode 100644 arch/arm/dts/r8a774e1.dtsi create mode 100644 drivers/clk/renesas/r8a774e1-cpg-mssr.c create mode 100644 include/dt-bindings/clock/r8a774e1-cpg-mssr.h create mode 100644 include/dt-bindings/power/r8a774e1-sysc.h
Add CPU and PRR IDs for R8A774E1(a.k.a RZ/G2H) SoC.
Signed-off-by: Biju Das biju.das.jz@bp.renesas.com Reviewed-by: Lad Prabhakar prabhakar.mahadev-lad.rj@bp.renesas.com --- arch/arm/mach-rmobile/cpu_info.c | 2 ++ arch/arm/mach-rmobile/include/mach/rmobile.h | 1 + 2 files changed, 3 insertions(+)
diff --git a/arch/arm/mach-rmobile/cpu_info.c b/arch/arm/mach-rmobile/cpu_info.c index 9b777cabee..752e89bee2 100644 --- a/arch/arm/mach-rmobile/cpu_info.c +++ b/arch/arm/mach-rmobile/cpu_info.c @@ -66,6 +66,7 @@ u32 rmobile_get_cpu_rev_fraction(void) static const struct udevice_id soc_ids[] = { { .compatible = "renesas,r8a774a1", .data = SOC_RZG2 }, { .compatible = "renesas,r8a774b1", .data = SOC_RZG2 }, + { .compatible = "renesas,r8a774e1", .data = SOC_RZG2 }, { }, };
@@ -79,6 +80,7 @@ static const struct { { RMOBILE_CPU_TYPE_R8A7740, "R8A7740", SOC_RMOBILE }, { RMOBILE_CPU_TYPE_R8A774A1, "R8A774A1", SOC_RZG2 }, { RMOBILE_CPU_TYPE_R8A774B1, "R8A774B1", SOC_RZG2 }, + { RMOBILE_CPU_TYPE_R8A774E1, "R8A774E1", SOC_RZG2 }, { RMOBILE_CPU_TYPE_R8A7790, "R8A7790", SOC_RCAR_GEN2 }, { RMOBILE_CPU_TYPE_R8A7791, "R8A7791", SOC_RCAR_GEN2 }, { RMOBILE_CPU_TYPE_R8A7792, "R8A7792", SOC_RCAR_GEN2 }, diff --git a/arch/arm/mach-rmobile/include/mach/rmobile.h b/arch/arm/mach-rmobile/include/mach/rmobile.h index 97853cda38..c54b0f1618 100644 --- a/arch/arm/mach-rmobile/include/mach/rmobile.h +++ b/arch/arm/mach-rmobile/include/mach/rmobile.h @@ -29,6 +29,7 @@ #define RMOBILE_CPU_TYPE_R8A7740 0x40 #define RMOBILE_CPU_TYPE_R8A774A1 0x52 #define RMOBILE_CPU_TYPE_R8A774B1 0x55 +#define RMOBILE_CPU_TYPE_R8A774E1 0x4F #define RMOBILE_CPU_TYPE_R8A7790 0x45 #define RMOBILE_CPU_TYPE_R8A7791 0x47 #define RMOBILE_CPU_TYPE_R8A7792 0x4A
Add config support for RZ/G2H(a.k.a R8A774E1) SoC.
Signed-off-by: Biju Das biju.das.jz@bp.renesas.com Reviewed-by: Lad Prabhakar prabhakar.mahadev-lad.rj@bp.renesas.com --- arch/arm/mach-rmobile/Kconfig.64 | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/arch/arm/mach-rmobile/Kconfig.64 b/arch/arm/mach-rmobile/Kconfig.64 index 46407ecf79..36c414f601 100644 --- a/arch/arm/mach-rmobile/Kconfig.64 +++ b/arch/arm/mach-rmobile/Kconfig.64 @@ -12,6 +12,9 @@ config R8A774B1 imply CLK_R8A774B1 imply PINCTRL_PFC_R8A774B1
+config R8A774E1 + bool "Renesas SoC R8A774E1" + config R8A7795 bool "Renesas SoC R8A7795" imply CLK_R8A7795
Import R8A774E1 (RZ/G2H) SoC DTSI and headers from upstream Linux kernel 5.9-rc4 commit f4d51dffc6c0 ("Linux 5.9-rc4")
Signed-off-by: Biju Das biju.das.jz@bp.renesas.com Reviewed-by: Lad Prabhakar prabhakar.mahadev-lad.rj@bp.renesas.com --- arch/arm/dts/r8a774e1.dtsi | 1664 +++++++++++++++++ include/dt-bindings/clock/r8a774e1-cpg-mssr.h | 59 + include/dt-bindings/power/r8a774e1-sysc.h | 36 + 3 files changed, 1759 insertions(+) create mode 100644 arch/arm/dts/r8a774e1.dtsi create mode 100644 include/dt-bindings/clock/r8a774e1-cpg-mssr.h create mode 100644 include/dt-bindings/power/r8a774e1-sysc.h
diff --git a/arch/arm/dts/r8a774e1.dtsi b/arch/arm/dts/r8a774e1.dtsi new file mode 100644 index 0000000000..0f86cfd524 --- /dev/null +++ b/arch/arm/dts/r8a774e1.dtsi @@ -0,0 +1,1664 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Device Tree Source for the r8a774e1 SoC + * + * Copyright (C) 2020 Renesas Electronics Corp. + */ + +#include <dt-bindings/interrupt-controller/irq.h> +#include <dt-bindings/interrupt-controller/arm-gic.h> +#include <dt-bindings/clock/r8a774e1-cpg-mssr.h> +#include <dt-bindings/power/r8a774e1-sysc.h> + +#define CPG_AUDIO_CLK_I R8A774E1_CLK_S0D4 + +/ { + compatible = "renesas,r8a774e1"; + #address-cells = <2>; + #size-cells = <2>; + + /* + * The external audio clocks are configured as 0 Hz fixed frequency + * clocks by default. + * Boards that provide audio clocks should override them. + */ + audio_clk_a: audio_clk_a { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <0>; + }; + + audio_clk_c: audio_clk_c { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <0>; + }; + + /* External CAN clock - to be overridden by boards that provide it */ + can_clk: can { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <0>; + }; + + cluster0_opp: opp_table0 { + compatible = "operating-points-v2"; + opp-shared; + + opp-500000000 { + opp-hz = /bits/ 64 <500000000>; + opp-microvolt = <820000>; + clock-latency-ns = <300000>; + }; + opp-1000000000 { + opp-hz = /bits/ 64 <1000000000>; + opp-microvolt = <820000>; + clock-latency-ns = <300000>; + }; + opp-1500000000 { + opp-hz = /bits/ 64 <1500000000>; + opp-microvolt = <820000>; + clock-latency-ns = <300000>; + opp-suspend; + }; + }; + + cluster1_opp: opp_table1 { + compatible = "operating-points-v2"; + opp-shared; + + opp-800000000 { + opp-hz = /bits/ 64 <800000000>; + opp-microvolt = <820000>; + clock-latency-ns = <300000>; + }; + opp-1000000000 { + opp-hz = /bits/ 64 <1000000000>; + opp-microvolt = <820000>; + clock-latency-ns = <300000>; + }; + opp-1200000000 { + opp-hz = /bits/ 64 <1200000000>; + opp-microvolt = <820000>; + clock-latency-ns = <300000>; + }; + }; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + + cpu-map { + cluster0 { + core0 { + cpu = <&a57_0>; + }; + core1 { + cpu = <&a57_1>; + }; + core2 { + cpu = <&a57_2>; + }; + core3 { + cpu = <&a57_3>; + }; + }; + + cluster1 { + core0 { + cpu = <&a53_0>; + }; + core1 { + cpu = <&a53_1>; + }; + core2 { + cpu = <&a53_2>; + }; + core3 { + cpu = <&a53_3>; + }; + }; + }; + + a57_0: cpu@0 { + compatible = "arm,cortex-a57"; + reg = <0x0>; + device_type = "cpu"; + power-domains = <&sysc R8A774E1_PD_CA57_CPU0>; + next-level-cache = <&L2_CA57>; + enable-method = "psci"; + dynamic-power-coefficient = <854>; + clocks = <&cpg CPG_CORE R8A774E1_CLK_Z>; + operating-points-v2 = <&cluster0_opp>; + capacity-dmips-mhz = <1024>; + #cooling-cells = <2>; + }; + + a57_1: cpu@1 { + compatible = "arm,cortex-a57"; + reg = <0x1>; + device_type = "cpu"; + power-domains = <&sysc R8A774E1_PD_CA57_CPU1>; + next-level-cache = <&L2_CA57>; + enable-method = "psci"; + clocks = <&cpg CPG_CORE R8A774E1_CLK_Z>; + operating-points-v2 = <&cluster0_opp>; + capacity-dmips-mhz = <1024>; + #cooling-cells = <2>; + }; + + a57_2: cpu@2 { + compatible = "arm,cortex-a57"; + reg = <0x2>; + device_type = "cpu"; + power-domains = <&sysc R8A774E1_PD_CA57_CPU2>; + next-level-cache = <&L2_CA57>; + enable-method = "psci"; + clocks = <&cpg CPG_CORE R8A774E1_CLK_Z>; + operating-points-v2 = <&cluster0_opp>; + capacity-dmips-mhz = <1024>; + #cooling-cells = <2>; + }; + + a57_3: cpu@3 { + compatible = "arm,cortex-a57"; + reg = <0x3>; + device_type = "cpu"; + power-domains = <&sysc R8A774E1_PD_CA57_CPU3>; + next-level-cache = <&L2_CA57>; + enable-method = "psci"; + clocks = <&cpg CPG_CORE R8A774E1_CLK_Z>; + operating-points-v2 = <&cluster0_opp>; + capacity-dmips-mhz = <1024>; + #cooling-cells = <2>; + }; + + a53_0: cpu@100 { + compatible = "arm,cortex-a53"; + reg = <0x100>; + device_type = "cpu"; + power-domains = <&sysc R8A774E1_PD_CA53_CPU0>; + next-level-cache = <&L2_CA53>; + enable-method = "psci"; + #cooling-cells = <2>; + dynamic-power-coefficient = <277>; + clocks = <&cpg CPG_CORE R8A774E1_CLK_Z2>; + operating-points-v2 = <&cluster1_opp>; + capacity-dmips-mhz = <535>; + }; + + a53_1: cpu@101 { + compatible = "arm,cortex-a53"; + reg = <0x101>; + device_type = "cpu"; + power-domains = <&sysc R8A774E1_PD_CA53_CPU1>; + next-level-cache = <&L2_CA53>; + enable-method = "psci"; + clocks = <&cpg CPG_CORE R8A774E1_CLK_Z2>; + operating-points-v2 = <&cluster1_opp>; + capacity-dmips-mhz = <535>; + }; + + a53_2: cpu@102 { + compatible = "arm,cortex-a53"; + reg = <0x102>; + device_type = "cpu"; + power-domains = <&sysc R8A774E1_PD_CA53_CPU2>; + next-level-cache = <&L2_CA53>; + enable-method = "psci"; + clocks = <&cpg CPG_CORE R8A774E1_CLK_Z2>; + operating-points-v2 = <&cluster1_opp>; + capacity-dmips-mhz = <535>; + }; + + a53_3: cpu@103 { + compatible = "arm,cortex-a53"; + reg = <0x103>; + device_type = "cpu"; + power-domains = <&sysc R8A774E1_PD_CA53_CPU3>; + next-level-cache = <&L2_CA53>; + enable-method = "psci"; + clocks = <&cpg CPG_CORE R8A774E1_CLK_Z2>; + operating-points-v2 = <&cluster1_opp>; + capacity-dmips-mhz = <535>; + }; + + L2_CA57: cache-controller-0 { + compatible = "cache"; + power-domains = <&sysc R8A774E1_PD_CA57_SCU>; + cache-unified; + cache-level = <2>; + }; + + L2_CA53: cache-controller-1 { + compatible = "cache"; + power-domains = <&sysc R8A774E1_PD_CA53_SCU>; + cache-unified; + cache-level = <2>; + }; + }; + + extal_clk: extal { + compatible = "fixed-clock"; + #clock-cells = <0>; + /* This value must be overridden by the board */ + clock-frequency = <0>; + }; + + extalr_clk: extalr { + compatible = "fixed-clock"; + #clock-cells = <0>; + /* This value must be overridden by the board */ + clock-frequency = <0>; + }; + + /* External PCIe clock - can be overridden by the board */ + pcie_bus_clk: pcie_bus { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <0>; + }; + + pmu_a53 { + compatible = "arm,cortex-a53-pmu"; + interrupts-extended = <&gic GIC_SPI 84 IRQ_TYPE_LEVEL_HIGH>, + <&gic GIC_SPI 85 IRQ_TYPE_LEVEL_HIGH>, + <&gic GIC_SPI 86 IRQ_TYPE_LEVEL_HIGH>, + <&gic GIC_SPI 87 IRQ_TYPE_LEVEL_HIGH>; + interrupt-affinity = <&a53_0>, <&a53_1>, <&a53_2>, <&a53_3>; + }; + + pmu_a57 { + compatible = "arm,cortex-a57-pmu"; + interrupts-extended = <&gic GIC_SPI 72 IRQ_TYPE_LEVEL_HIGH>, + <&gic GIC_SPI 73 IRQ_TYPE_LEVEL_HIGH>, + <&gic GIC_SPI 74 IRQ_TYPE_LEVEL_HIGH>, + <&gic GIC_SPI 75 IRQ_TYPE_LEVEL_HIGH>; + interrupt-affinity = <&a57_0>, <&a57_1>, <&a57_2>, <&a57_3>; + }; + + psci { + compatible = "arm,psci-1.0", "arm,psci-0.2"; + method = "smc"; + }; + + /* External SCIF clock - to be overridden by boards that provide it */ + scif_clk: scif { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <0>; + }; + + soc { + compatible = "simple-bus"; + interrupt-parent = <&gic>; + #address-cells = <2>; + #size-cells = <2>; + ranges; + + rwdt: watchdog@e6020000 { + compatible = "renesas,r8a774e1-wdt", + "renesas,rcar-gen3-wdt"; + reg = <0 0xe6020000 0 0x0c>; + interrupts = <GIC_SPI 140 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 402>; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 402>; + status = "disabled"; + }; + + gpio0: gpio@e6050000 { + compatible = "renesas,gpio-r8a774e1", + "renesas,rcar-gen3-gpio"; + reg = <0 0xe6050000 0 0x50>; + interrupts = <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>; + #gpio-cells = <2>; + gpio-controller; + gpio-ranges = <&pfc 0 0 16>; + #interrupt-cells = <2>; + interrupt-controller; + clocks = <&cpg CPG_MOD 912>; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 912>; + }; + + gpio1: gpio@e6051000 { + compatible = "renesas,gpio-r8a774e1", + "renesas,rcar-gen3-gpio"; + reg = <0 0xe6051000 0 0x50>; + interrupts = <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH>; + #gpio-cells = <2>; + gpio-controller; + gpio-ranges = <&pfc 0 32 29>; + #interrupt-cells = <2>; + interrupt-controller; + clocks = <&cpg CPG_MOD 911>; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 911>; + }; + + gpio2: gpio@e6052000 { + compatible = "renesas,gpio-r8a774e1", + "renesas,rcar-gen3-gpio"; + reg = <0 0xe6052000 0 0x50>; + interrupts = <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>; + #gpio-cells = <2>; + gpio-controller; + gpio-ranges = <&pfc 0 64 15>; + #interrupt-cells = <2>; + interrupt-controller; + clocks = <&cpg CPG_MOD 910>; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 910>; + }; + + gpio3: gpio@e6053000 { + compatible = "renesas,gpio-r8a774e1", + "renesas,rcar-gen3-gpio"; + reg = <0 0xe6053000 0 0x50>; + interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>; + #gpio-cells = <2>; + gpio-controller; + gpio-ranges = <&pfc 0 96 16>; + #interrupt-cells = <2>; + interrupt-controller; + clocks = <&cpg CPG_MOD 909>; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 909>; + }; + + gpio4: gpio@e6054000 { + compatible = "renesas,gpio-r8a774e1", + "renesas,rcar-gen3-gpio"; + reg = <0 0xe6054000 0 0x50>; + interrupts = <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>; + #gpio-cells = <2>; + gpio-controller; + gpio-ranges = <&pfc 0 128 18>; + #interrupt-cells = <2>; + interrupt-controller; + clocks = <&cpg CPG_MOD 908>; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 908>; + }; + + gpio5: gpio@e6055000 { + compatible = "renesas,gpio-r8a774e1", + "renesas,rcar-gen3-gpio"; + reg = <0 0xe6055000 0 0x50>; + interrupts = <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>; + #gpio-cells = <2>; + gpio-controller; + gpio-ranges = <&pfc 0 160 26>; + #interrupt-cells = <2>; + interrupt-controller; + clocks = <&cpg CPG_MOD 907>; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 907>; + }; + + gpio6: gpio@e6055400 { + compatible = "renesas,gpio-r8a774e1", + "renesas,rcar-gen3-gpio"; + reg = <0 0xe6055400 0 0x50>; + interrupts = <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>; + #gpio-cells = <2>; + gpio-controller; + gpio-ranges = <&pfc 0 192 32>; + #interrupt-cells = <2>; + interrupt-controller; + clocks = <&cpg CPG_MOD 906>; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 906>; + }; + + gpio7: gpio@e6055800 { + compatible = "renesas,gpio-r8a774e1", + "renesas,rcar-gen3-gpio"; + reg = <0 0xe6055800 0 0x50>; + interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>; + #gpio-cells = <2>; + gpio-controller; + gpio-ranges = <&pfc 0 224 4>; + #interrupt-cells = <2>; + interrupt-controller; + clocks = <&cpg CPG_MOD 905>; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 905>; + }; + + pfc: pin-controller@e6060000 { + compatible = "renesas,pfc-r8a774e1"; + reg = <0 0xe6060000 0 0x50c>; + }; + + cmt0: timer@e60f0000 { + compatible = "renesas,r8a774e1-cmt0", + "renesas,rcar-gen3-cmt0"; + reg = <0 0xe60f0000 0 0x1004>; + interrupts = <GIC_SPI 142 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 143 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 303>; + clock-names = "fck"; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 303>; + status = "disabled"; + }; + + cmt1: timer@e6130000 { + compatible = "renesas,r8a774e1-cmt1", + "renesas,rcar-gen3-cmt1"; + reg = <0 0xe6130000 0 0x1004>; + interrupts = <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 121 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 122 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 123 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 124 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 125 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 126 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 127 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 302>; + clock-names = "fck"; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 302>; + status = "disabled"; + }; + + cmt2: timer@e6140000 { + compatible = "renesas,r8a774e1-cmt1", + "renesas,rcar-gen3-cmt1"; + reg = <0 0xe6140000 0 0x1004>; + interrupts = <GIC_SPI 398 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 399 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 400 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 401 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 402 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 403 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 404 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 405 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 301>; + clock-names = "fck"; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 301>; + status = "disabled"; + }; + + cmt3: timer@e6148000 { + compatible = "renesas,r8a774e1-cmt1", + "renesas,rcar-gen3-cmt1"; + reg = <0 0xe6148000 0 0x1004>; + interrupts = <GIC_SPI 470 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 471 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 472 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 473 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 474 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 475 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 476 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 477 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 300>; + clock-names = "fck"; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 300>; + status = "disabled"; + }; + + cpg: clock-controller@e6150000 { + compatible = "renesas,r8a774e1-cpg-mssr"; + reg = <0 0xe6150000 0 0x1000>; + clocks = <&extal_clk>, <&extalr_clk>; + clock-names = "extal", "extalr"; + #clock-cells = <2>; + #power-domain-cells = <0>; + #reset-cells = <1>; + }; + + rst: reset-controller@e6160000 { + compatible = "renesas,r8a774e1-rst"; + reg = <0 0xe6160000 0 0x0200>; + }; + + sysc: system-controller@e6180000 { + compatible = "renesas,r8a774e1-sysc"; + reg = <0 0xe6180000 0 0x0400>; + #power-domain-cells = <1>; + }; + + tsc: thermal@e6198000 { + compatible = "renesas,r8a774e1-thermal"; + reg = <0 0xe6198000 0 0x100>, + <0 0xe61a0000 0 0x100>, + <0 0xe61a8000 0 0x100>; + interrupts = <GIC_SPI 67 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 68 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 69 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 522>; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 522>; + #thermal-sensor-cells = <1>; + }; + + intc_ex: interrupt-controller@e61c0000 { + compatible = "renesas,intc-ex-r8a774e1", "renesas,irqc"; + #interrupt-cells = <2>; + interrupt-controller; + reg = <0 0xe61c0000 0 0x200>; + interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 18 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 161 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 407>; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 407>; + }; + + tmu0: timer@e61e0000 { + compatible = "renesas,tmu-r8a774e1", "renesas,tmu"; + reg = <0 0xe61e0000 0 0x30>; + interrupts = <GIC_SPI 136 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 137 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 138 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 125>; + clock-names = "fck"; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 125>; + status = "disabled"; + }; + + tmu1: timer@e6fc0000 { + compatible = "renesas,tmu-r8a774e1", "renesas,tmu"; + reg = <0 0xe6fc0000 0 0x30>; + interrupts = <GIC_SPI 128 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 129 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 130 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 124>; + clock-names = "fck"; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 124>; + status = "disabled"; + }; + + tmu2: timer@e6fd0000 { + compatible = "renesas,tmu-r8a774e1", "renesas,tmu"; + reg = <0 0xe6fd0000 0 0x30>; + interrupts = <GIC_SPI 303 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 304 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 305 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 123>; + clock-names = "fck"; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 123>; + status = "disabled"; + }; + + tmu3: timer@e6fe0000 { + compatible = "renesas,tmu-r8a774e1", "renesas,tmu"; + reg = <0 0xe6fe0000 0 0x30>; + interrupts = <GIC_SPI 131 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 132 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 133 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 122>; + clock-names = "fck"; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 122>; + status = "disabled"; + }; + + tmu4: timer@ffc00000 { + compatible = "renesas,tmu-r8a774e1", "renesas,tmu"; + reg = <0 0xffc00000 0 0x30>; + interrupts = <GIC_SPI 406 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 407 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 408 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 121>; + clock-names = "fck"; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 121>; + status = "disabled"; + }; + + i2c0: i2c@e6500000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "renesas,i2c-r8a774e1", + "renesas,rcar-gen3-i2c"; + reg = <0 0xe6500000 0 0x40>; + interrupts = <GIC_SPI 287 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 931>; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 931>; + dmas = <&dmac1 0x91>, <&dmac1 0x90>, + <&dmac2 0x91>, <&dmac2 0x90>; + dma-names = "tx", "rx", "tx", "rx"; + i2c-scl-internal-delay-ns = <110>; + status = "disabled"; + }; + + i2c1: i2c@e6508000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "renesas,i2c-r8a774e1", + "renesas,rcar-gen3-i2c"; + reg = <0 0xe6508000 0 0x40>; + interrupts = <GIC_SPI 288 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 930>; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 930>; + dmas = <&dmac1 0x93>, <&dmac1 0x92>, + <&dmac2 0x93>, <&dmac2 0x92>; + dma-names = "tx", "rx", "tx", "rx"; + i2c-scl-internal-delay-ns = <6>; + status = "disabled"; + }; + + i2c2: i2c@e6510000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "renesas,i2c-r8a774e1", + "renesas,rcar-gen3-i2c"; + reg = <0 0xe6510000 0 0x40>; + interrupts = <GIC_SPI 286 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 929>; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 929>; + dmas = <&dmac1 0x95>, <&dmac1 0x94>, + <&dmac2 0x95>, <&dmac2 0x94>; + dma-names = "tx", "rx", "tx", "rx"; + i2c-scl-internal-delay-ns = <6>; + status = "disabled"; + }; + + i2c3: i2c@e66d0000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "renesas,i2c-r8a774e1", + "renesas,rcar-gen3-i2c"; + reg = <0 0xe66d0000 0 0x40>; + interrupts = <GIC_SPI 290 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 928>; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 928>; + dmas = <&dmac0 0x97>, <&dmac0 0x96>; + dma-names = "tx", "rx"; + i2c-scl-internal-delay-ns = <110>; + status = "disabled"; + }; + + i2c4: i2c@e66d8000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "renesas,i2c-r8a774e1", + "renesas,rcar-gen3-i2c"; + reg = <0 0xe66d8000 0 0x40>; + interrupts = <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 927>; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 927>; + dmas = <&dmac0 0x99>, <&dmac0 0x98>; + dma-names = "tx", "rx"; + i2c-scl-internal-delay-ns = <110>; + status = "disabled"; + }; + + i2c5: i2c@e66e0000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "renesas,i2c-r8a774e1", + "renesas,rcar-gen3-i2c"; + reg = <0 0xe66e0000 0 0x40>; + interrupts = <GIC_SPI 20 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 919>; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 919>; + dmas = <&dmac0 0x9b>, <&dmac0 0x9a>; + dma-names = "tx", "rx"; + i2c-scl-internal-delay-ns = <110>; + status = "disabled"; + }; + + i2c6: i2c@e66e8000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "renesas,i2c-r8a774e1", + "renesas,rcar-gen3-i2c"; + reg = <0 0xe66e8000 0 0x40>; + interrupts = <GIC_SPI 21 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 918>; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 918>; + dmas = <&dmac0 0x9d>, <&dmac0 0x9c>; + dma-names = "tx", "rx"; + i2c-scl-internal-delay-ns = <6>; + status = "disabled"; + }; + + i2c_dvfs: i2c@e60b0000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "renesas,iic-r8a774e1", + "renesas,rcar-gen3-iic", + "renesas,rmobile-iic"; + reg = <0 0xe60b0000 0 0x425>; + interrupts = <GIC_SPI 173 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 926>; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 926>; + dmas = <&dmac0 0x11>, <&dmac0 0x10>; + dma-names = "tx", "rx"; + status = "disabled"; + }; + + hscif0: serial@e6540000 { + compatible = "renesas,hscif-r8a774e1", + "renesas,rcar-gen3-hscif", + "renesas,hscif"; + reg = <0 0xe6540000 0 0x60>; + interrupts = <GIC_SPI 154 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 520>, + <&cpg CPG_CORE R8A774E1_CLK_S3D1>, + <&scif_clk>; + clock-names = "fck", "brg_int", "scif_clk"; + dmas = <&dmac1 0x31>, <&dmac1 0x30>, + <&dmac2 0x31>, <&dmac2 0x30>; + dma-names = "tx", "rx", "tx", "rx"; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 520>; + status = "disabled"; + }; + + hscif1: serial@e6550000 { + compatible = "renesas,hscif-r8a774e1", + "renesas,rcar-gen3-hscif", + "renesas,hscif"; + reg = <0 0xe6550000 0 0x60>; + interrupts = <GIC_SPI 155 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 519>, + <&cpg CPG_CORE R8A774E1_CLK_S3D1>, + <&scif_clk>; + clock-names = "fck", "brg_int", "scif_clk"; + dmas = <&dmac1 0x33>, <&dmac1 0x32>, + <&dmac2 0x33>, <&dmac2 0x32>; + dma-names = "tx", "rx", "tx", "rx"; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 519>; + status = "disabled"; + }; + + hscif2: serial@e6560000 { + compatible = "renesas,hscif-r8a774e1", + "renesas,rcar-gen3-hscif", + "renesas,hscif"; + reg = <0 0xe6560000 0 0x60>; + interrupts = <GIC_SPI 144 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 518>, + <&cpg CPG_CORE R8A774E1_CLK_S3D1>, + <&scif_clk>; + clock-names = "fck", "brg_int", "scif_clk"; + dmas = <&dmac1 0x35>, <&dmac1 0x34>, + <&dmac2 0x35>, <&dmac2 0x34>; + dma-names = "tx", "rx", "tx", "rx"; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 518>; + status = "disabled"; + }; + + hscif3: serial@e66a0000 { + compatible = "renesas,hscif-r8a774e1", + "renesas,rcar-gen3-hscif", + "renesas,hscif"; + reg = <0 0xe66a0000 0 0x60>; + interrupts = <GIC_SPI 145 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 517>, + <&cpg CPG_CORE R8A774E1_CLK_S3D1>, + <&scif_clk>; + clock-names = "fck", "brg_int", "scif_clk"; + dmas = <&dmac0 0x37>, <&dmac0 0x36>; + dma-names = "tx", "rx"; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 517>; + status = "disabled"; + }; + + hscif4: serial@e66b0000 { + compatible = "renesas,hscif-r8a774e1", + "renesas,rcar-gen3-hscif", + "renesas,hscif"; + reg = <0 0xe66b0000 0 0x60>; + interrupts = <GIC_SPI 146 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 516>, + <&cpg CPG_CORE R8A774E1_CLK_S3D1>, + <&scif_clk>; + clock-names = "fck", "brg_int", "scif_clk"; + dmas = <&dmac0 0x39>, <&dmac0 0x38>; + dma-names = "tx", "rx"; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 516>; + status = "disabled"; + }; + + hsusb: usb@e6590000 { + reg = <0 0xe6590000 0 0x200>; + status = "disabled"; + + /* placeholder */ + }; + + usb3_phy0: usb-phy@e65ee000 { + reg = <0 0xe65ee000 0 0x90>; + #phy-cells = <0>; + status = "disabled"; + + /* placeholder */ + }; + + dmac0: dma-controller@e6700000 { + compatible = "renesas,dmac-r8a774e1", + "renesas,rcar-dmac"; + reg = <0 0xe6700000 0 0x10000>; + interrupts = <GIC_SPI 199 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 200 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 201 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 202 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 203 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 204 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 205 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 206 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 207 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 208 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 209 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 210 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 211 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 212 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 213 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 214 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 215 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "error", + "ch0", "ch1", "ch2", "ch3", + "ch4", "ch5", "ch6", "ch7", + "ch8", "ch9", "ch10", "ch11", + "ch12", "ch13", "ch14", "ch15"; + clocks = <&cpg CPG_MOD 219>; + clock-names = "fck"; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 219>; + #dma-cells = <1>; + dma-channels = <16>; + iommus = <&ipmmu_ds0 0>, <&ipmmu_ds0 1>, + <&ipmmu_ds0 2>, <&ipmmu_ds0 3>, + <&ipmmu_ds0 4>, <&ipmmu_ds0 5>, + <&ipmmu_ds0 6>, <&ipmmu_ds0 7>, + <&ipmmu_ds0 8>, <&ipmmu_ds0 9>, + <&ipmmu_ds0 10>, <&ipmmu_ds0 11>, + <&ipmmu_ds0 12>, <&ipmmu_ds0 13>, + <&ipmmu_ds0 14>, <&ipmmu_ds0 15>; + }; + + dmac1: dma-controller@e7300000 { + compatible = "renesas,dmac-r8a774e1", + "renesas,rcar-dmac"; + reg = <0 0xe7300000 0 0x10000>; + interrupts = <GIC_SPI 220 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 216 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 217 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 218 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 219 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 308 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 309 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 310 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 311 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 312 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 313 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 314 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 315 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 316 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 317 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 318 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 319 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "error", + "ch0", "ch1", "ch2", "ch3", + "ch4", "ch5", "ch6", "ch7", + "ch8", "ch9", "ch10", "ch11", + "ch12", "ch13", "ch14", "ch15"; + clocks = <&cpg CPG_MOD 218>; + clock-names = "fck"; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 218>; + #dma-cells = <1>; + dma-channels = <16>; + iommus = <&ipmmu_ds1 0>, <&ipmmu_ds1 1>, + <&ipmmu_ds1 2>, <&ipmmu_ds1 3>, + <&ipmmu_ds1 4>, <&ipmmu_ds1 5>, + <&ipmmu_ds1 6>, <&ipmmu_ds1 7>, + <&ipmmu_ds1 8>, <&ipmmu_ds1 9>, + <&ipmmu_ds1 10>, <&ipmmu_ds1 11>, + <&ipmmu_ds1 12>, <&ipmmu_ds1 13>, + <&ipmmu_ds1 14>, <&ipmmu_ds1 15>; + }; + + dmac2: dma-controller@e7310000 { + compatible = "renesas,dmac-r8a774e1", + "renesas,rcar-dmac"; + reg = <0 0xe7310000 0 0x10000>; + interrupts = <GIC_SPI 416 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 417 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 418 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 419 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 420 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 421 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 422 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 423 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 424 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 425 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 426 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 427 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 428 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 429 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 430 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 431 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 397 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "error", + "ch0", "ch1", "ch2", "ch3", + "ch4", "ch5", "ch6", "ch7", + "ch8", "ch9", "ch10", "ch11", + "ch12", "ch13", "ch14", "ch15"; + clocks = <&cpg CPG_MOD 217>; + clock-names = "fck"; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 217>; + #dma-cells = <1>; + dma-channels = <16>; + iommus = <&ipmmu_ds1 16>, <&ipmmu_ds1 17>, + <&ipmmu_ds1 18>, <&ipmmu_ds1 19>, + <&ipmmu_ds1 20>, <&ipmmu_ds1 21>, + <&ipmmu_ds1 22>, <&ipmmu_ds1 23>, + <&ipmmu_ds1 24>, <&ipmmu_ds1 25>, + <&ipmmu_ds1 26>, <&ipmmu_ds1 27>, + <&ipmmu_ds1 28>, <&ipmmu_ds1 29>, + <&ipmmu_ds1 30>, <&ipmmu_ds1 31>; + }; + + ipmmu_ds0: iommu@e6740000 { + compatible = "renesas,ipmmu-r8a774e1"; + reg = <0 0xe6740000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 0>; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + #iommu-cells = <1>; + }; + + ipmmu_ds1: iommu@e7740000 { + compatible = "renesas,ipmmu-r8a774e1"; + reg = <0 0xe7740000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 1>; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + #iommu-cells = <1>; + }; + + ipmmu_hc: iommu@e6570000 { + compatible = "renesas,ipmmu-r8a774e1"; + reg = <0 0xe6570000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 2>; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + #iommu-cells = <1>; + }; + + ipmmu_mm: iommu@e67b0000 { + compatible = "renesas,ipmmu-r8a774e1"; + reg = <0 0xe67b0000 0 0x1000>; + interrupts = <GIC_SPI 196 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 197 IRQ_TYPE_LEVEL_HIGH>; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + #iommu-cells = <1>; + }; + + ipmmu_mp0: iommu@ec670000 { + compatible = "renesas,ipmmu-r8a774e1"; + reg = <0 0xec670000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 4>; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + #iommu-cells = <1>; + }; + + ipmmu_pv0: iommu@fd800000 { + compatible = "renesas,ipmmu-r8a774e1"; + reg = <0 0xfd800000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 6>; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + #iommu-cells = <1>; + }; + + ipmmu_pv1: iommu@fd950000 { + compatible = "renesas,ipmmu-r8a774e1"; + reg = <0 0xfd950000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 7>; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + #iommu-cells = <1>; + }; + + ipmmu_pv2: iommu@fd960000 { + compatible = "renesas,ipmmu-r8a774e1"; + reg = <0 0xfd960000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 8>; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + #iommu-cells = <1>; + }; + + ipmmu_pv3: iommu@fd970000 { + compatible = "renesas,ipmmu-r8a774e1"; + reg = <0 0xfd970000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 9>; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + #iommu-cells = <1>; + }; + + ipmmu_vc0: iommu@fe6b0000 { + compatible = "renesas,ipmmu-r8a774e1"; + reg = <0 0xfe6b0000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 12>; + power-domains = <&sysc R8A774E1_PD_A3VC>; + #iommu-cells = <1>; + }; + + ipmmu_vc1: iommu@fe6f0000 { + compatible = "renesas,ipmmu-r8a774e1"; + reg = <0 0xfe6f0000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 13>; + power-domains = <&sysc R8A774E1_PD_A3VC>; + #iommu-cells = <1>; + }; + + ipmmu_vi0: iommu@febd0000 { + compatible = "renesas,ipmmu-r8a774e1"; + reg = <0 0xfebd0000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 14>; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + #iommu-cells = <1>; + }; + + ipmmu_vi1: iommu@febe0000 { + compatible = "renesas,ipmmu-r8a774e1"; + reg = <0 0xfebe0000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 15>; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + #iommu-cells = <1>; + }; + + ipmmu_vp0: iommu@fe990000 { + compatible = "renesas,ipmmu-r8a774e1"; + reg = <0 0xfe990000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 16>; + power-domains = <&sysc R8A774E1_PD_A3VP>; + #iommu-cells = <1>; + }; + + ipmmu_vp1: iommu@fe980000 { + compatible = "renesas,ipmmu-r8a774e1"; + reg = <0 0xfe980000 0 0x1000>; + renesas,ipmmu-main = <&ipmmu_mm 17>; + power-domains = <&sysc R8A774E1_PD_A3VP>; + #iommu-cells = <1>; + }; + + avb: ethernet@e6800000 { + compatible = "renesas,etheravb-r8a774e1", + "renesas,etheravb-rcar-gen3"; + reg = <0 0xe6800000 0 0x800>; + interrupts = <GIC_SPI 39 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 42 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 43 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 44 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 45 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 46 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 47 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 48 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 49 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 50 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 51 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 52 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 53 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 54 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 55 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 56 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 57 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 58 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 59 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 60 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 61 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 62 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 63 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "ch0", "ch1", "ch2", "ch3", + "ch4", "ch5", "ch6", "ch7", + "ch8", "ch9", "ch10", "ch11", + "ch12", "ch13", "ch14", "ch15", + "ch16", "ch17", "ch18", "ch19", + "ch20", "ch21", "ch22", "ch23", + "ch24"; + clocks = <&cpg CPG_MOD 812>; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 812>; + phy-mode = "rgmii"; + iommus = <&ipmmu_ds0 16>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + can0: can@e6c30000 { + compatible = "renesas,can-r8a774e1", + "renesas,rcar-gen3-can"; + reg = <0 0xe6c30000 0 0x1000>; + interrupts = <GIC_SPI 186 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 916>, + <&cpg CPG_CORE R8A774E1_CLK_CANFD>, + <&can_clk>; + clock-names = "clkp1", "clkp2", "can_clk"; + assigned-clocks = <&cpg CPG_CORE R8A774E1_CLK_CANFD>; + assigned-clock-rates = <40000000>; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 916>; + status = "disabled"; + }; + + can1: can@e6c38000 { + compatible = "renesas,can-r8a774e1", + "renesas,rcar-gen3-can"; + reg = <0 0xe6c38000 0 0x1000>; + interrupts = <GIC_SPI 187 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 915>, + <&cpg CPG_CORE R8A774E1_CLK_CANFD>, + <&can_clk>; + clock-names = "clkp1", "clkp2", "can_clk"; + assigned-clocks = <&cpg CPG_CORE R8A774E1_CLK_CANFD>; + assigned-clock-rates = <40000000>; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 915>; + status = "disabled"; + }; + + canfd: can@e66c0000 { + compatible = "renesas,r8a774e1-canfd", + "renesas,rcar-gen3-canfd"; + reg = <0 0xe66c0000 0 0x8000>; + interrupts = <GIC_SPI 29 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 914>, + <&cpg CPG_CORE R8A774E1_CLK_CANFD>, + <&can_clk>; + clock-names = "fck", "canfd", "can_clk"; + assigned-clocks = <&cpg CPG_CORE R8A774E1_CLK_CANFD>; + assigned-clock-rates = <40000000>; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 914>; + status = "disabled"; + + channel0 { + status = "disabled"; + }; + + channel1 { + status = "disabled"; + }; + }; + + pwm0: pwm@e6e30000 { + reg = <0 0xe6e30000 0 0x8>; + #pwm-cells = <2>; + status = "disabled"; + + /* placeholder */ + }; + + scif0: serial@e6e60000 { + compatible = "renesas,scif-r8a774e1", + "renesas,rcar-gen3-scif", "renesas,scif"; + reg = <0 0xe6e60000 0 0x40>; + interrupts = <GIC_SPI 152 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 207>, + <&cpg CPG_CORE R8A774E1_CLK_S3D1>, + <&scif_clk>; + clock-names = "fck", "brg_int", "scif_clk"; + dmas = <&dmac1 0x51>, <&dmac1 0x50>, + <&dmac2 0x51>, <&dmac2 0x50>; + dma-names = "tx", "rx", "tx", "rx"; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 207>; + status = "disabled"; + }; + + scif1: serial@e6e68000 { + compatible = "renesas,scif-r8a774e1", + "renesas,rcar-gen3-scif", "renesas,scif"; + reg = <0 0xe6e68000 0 0x40>; + interrupts = <GIC_SPI 153 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 206>, + <&cpg CPG_CORE R8A774E1_CLK_S3D1>, + <&scif_clk>; + clock-names = "fck", "brg_int", "scif_clk"; + dmas = <&dmac1 0x53>, <&dmac1 0x52>, + <&dmac2 0x53>, <&dmac2 0x52>; + dma-names = "tx", "rx", "tx", "rx"; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 206>; + status = "disabled"; + }; + + scif2: serial@e6e88000 { + compatible = "renesas,scif-r8a774e1", + "renesas,rcar-gen3-scif", "renesas,scif"; + reg = <0 0xe6e88000 0 0x40>; + interrupts = <GIC_SPI 164 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 310>, + <&cpg CPG_CORE R8A774E1_CLK_S3D1>, + <&scif_clk>; + clock-names = "fck", "brg_int", "scif_clk"; + dmas = <&dmac1 0x13>, <&dmac1 0x12>, + <&dmac2 0x13>, <&dmac2 0x12>; + dma-names = "tx", "rx", "tx", "rx"; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 310>; + status = "disabled"; + }; + + scif3: serial@e6c50000 { + compatible = "renesas,scif-r8a774e1", + "renesas,rcar-gen3-scif", "renesas,scif"; + reg = <0 0xe6c50000 0 0x40>; + interrupts = <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 204>, + <&cpg CPG_CORE R8A774E1_CLK_S3D1>, + <&scif_clk>; + clock-names = "fck", "brg_int", "scif_clk"; + dmas = <&dmac0 0x57>, <&dmac0 0x56>; + dma-names = "tx", "rx"; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 204>; + status = "disabled"; + }; + + scif4: serial@e6c40000 { + compatible = "renesas,scif-r8a774e1", + "renesas,rcar-gen3-scif", "renesas,scif"; + reg = <0 0xe6c40000 0 0x40>; + interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 203>, + <&cpg CPG_CORE R8A774E1_CLK_S3D1>, + <&scif_clk>; + clock-names = "fck", "brg_int", "scif_clk"; + dmas = <&dmac0 0x59>, <&dmac0 0x58>; + dma-names = "tx", "rx"; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 203>; + status = "disabled"; + }; + + scif5: serial@e6f30000 { + compatible = "renesas,scif-r8a774e1", + "renesas,rcar-gen3-scif", "renesas,scif"; + reg = <0 0xe6f30000 0 0x40>; + interrupts = <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 202>, + <&cpg CPG_CORE R8A774E1_CLK_S3D1>, + <&scif_clk>; + clock-names = "fck", "brg_int", "scif_clk"; + dmas = <&dmac1 0x5b>, <&dmac1 0x5a>, + <&dmac2 0x5b>, <&dmac2 0x5a>; + dma-names = "tx", "rx", "tx", "rx"; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 202>; + status = "disabled"; + }; + + msiof0: spi@e6e90000 { + compatible = "renesas,msiof-r8a774e1", + "renesas,rcar-gen3-msiof"; + reg = <0 0xe6e90000 0 0x0064>; + interrupts = <GIC_SPI 156 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 211>; + dmas = <&dmac1 0x41>, <&dmac1 0x40>, + <&dmac2 0x41>, <&dmac2 0x40>; + dma-names = "tx", "rx", "tx", "rx"; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 211>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + msiof1: spi@e6ea0000 { + compatible = "renesas,msiof-r8a774e1", + "renesas,rcar-gen3-msiof"; + reg = <0 0xe6ea0000 0 0x0064>; + interrupts = <GIC_SPI 157 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 210>; + dmas = <&dmac1 0x43>, <&dmac1 0x42>, + <&dmac2 0x43>, <&dmac2 0x42>; + dma-names = "tx", "rx", "tx", "rx"; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 210>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + msiof2: spi@e6c00000 { + compatible = "renesas,msiof-r8a774e1", + "renesas,rcar-gen3-msiof"; + reg = <0 0xe6c00000 0 0x0064>; + interrupts = <GIC_SPI 158 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 209>; + dmas = <&dmac0 0x45>, <&dmac0 0x44>; + dma-names = "tx", "rx"; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 209>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + msiof3: spi@e6c10000 { + compatible = "renesas,msiof-r8a774e1", + "renesas,rcar-gen3-msiof"; + reg = <0 0xe6c10000 0 0x0064>; + interrupts = <GIC_SPI 159 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 208>; + dmas = <&dmac0 0x47>, <&dmac0 0x46>; + dma-names = "tx", "rx"; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 208>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + rcar_sound: sound@ec500000 { + reg = <0 0xec500000 0 0x1000>, /* SCU */ + <0 0xec5a0000 0 0x100>, /* ADG */ + <0 0xec540000 0 0x1000>, /* SSIU */ + <0 0xec541000 0 0x280>, /* SSI */ + <0 0xec760000 0 0x200>; /* Audio DMAC peri peri*/ + reg-names = "scu", "adg", "ssiu", "ssi", "audmapp"; + + status = "disabled"; + + /* placeholder */ + + rcar_sound,ssi { + ssi2: ssi-2 { + /* placeholder */ + }; + }; + }; + + xhci0: usb@ee000000 { + reg = <0 0xee000000 0 0xc00>; + status = "disabled"; + + /* placeholder */ + }; + + usb3_peri0: usb@ee020000 { + reg = <0 0xee020000 0 0x400>; + status = "disabled"; + + /* placeholder */ + }; + + ohci0: usb@ee080000 { + reg = <0 0xee080000 0 0x100>; + status = "disabled"; + + /* placeholder */ + }; + + ohci1: usb@ee0a0000 { + reg = <0 0xee0a0000 0 0x100>; + status = "disabled"; + + /* placeholder */ + }; + + ehci0: usb@ee080100 { + reg = <0 0xee080100 0 0x100>; + status = "disabled"; + + /* placeholder */ + }; + + ehci1: usb@ee0a0100 { + reg = <0 0xee0a0100 0 0x100>; + status = "disabled"; + + /* placeholder */ + }; + + usb2_phy0: usb-phy@ee080200 { + reg = <0 0xee080200 0 0x700>; + status = "disabled"; + + /* placeholder */ + }; + + usb2_phy1: usb-phy@ee0a0200 { + reg = <0 0xee0a0200 0 0x700>; + status = "disabled"; + + /* placeholder */ + }; + + sdhi0: mmc@ee100000 { + compatible = "renesas,sdhi-r8a774e1", + "renesas,rcar-gen3-sdhi"; + reg = <0 0xee100000 0 0x2000>; + interrupts = <GIC_SPI 165 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 314>; + max-frequency = <200000000>; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 314>; + iommus = <&ipmmu_ds1 32>; + status = "disabled"; + }; + + sdhi1: mmc@ee120000 { + compatible = "renesas,sdhi-r8a774e1", + "renesas,rcar-gen3-sdhi"; + reg = <0 0xee120000 0 0x2000>; + interrupts = <GIC_SPI 166 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 313>; + max-frequency = <200000000>; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 313>; + iommus = <&ipmmu_ds1 33>; + status = "disabled"; + }; + + sdhi2: mmc@ee140000 { + compatible = "renesas,sdhi-r8a774e1", + "renesas,rcar-gen3-sdhi"; + reg = <0 0xee140000 0 0x2000>; + interrupts = <GIC_SPI 167 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 312>; + max-frequency = <200000000>; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 312>; + iommus = <&ipmmu_ds1 34>; + status = "disabled"; + }; + + sdhi3: mmc@ee160000 { + compatible = "renesas,sdhi-r8a774e1", + "renesas,rcar-gen3-sdhi"; + reg = <0 0xee160000 0 0x2000>; + interrupts = <GIC_SPI 168 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cpg CPG_MOD 311>; + max-frequency = <200000000>; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 311>; + iommus = <&ipmmu_ds1 35>; + status = "disabled"; + }; + + gic: interrupt-controller@f1010000 { + compatible = "arm,gic-400"; + #interrupt-cells = <3>; + #address-cells = <0>; + interrupt-controller; + reg = <0x0 0xf1010000 0 0x1000>, + <0x0 0xf1020000 0 0x20000>, + <0x0 0xf1040000 0 0x20000>, + <0x0 0xf1060000 0 0x20000>; + interrupts = <GIC_PPI 9 + (GIC_CPU_MASK_SIMPLE(8) | IRQ_TYPE_LEVEL_HIGH)>; + clocks = <&cpg CPG_MOD 408>; + clock-names = "clk"; + power-domains = <&sysc R8A774E1_PD_ALWAYS_ON>; + resets = <&cpg 408>; + }; + + pciec0: pcie@fe000000 { + reg = <0 0xfe000000 0 0x80000>; + #address-cells = <3>; + #size-cells = <2>; + status = "disabled"; + + /* placeholder */ + }; + + hdmi0: hdmi@fead0000 { + reg = <0 0xfead0000 0 0x10000>; + status = "disabled"; + + /* placeholder */ + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + }; + port@1 { + reg = <1>; + }; + port@2 { + reg = <2>; + }; + }; + }; + + du: display@feb00000 { + reg = <0 0xfeb00000 0 0x80000>; + status = "disabled"; + + /* placeholder */ + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + }; + port@1 { + reg = <1>; + }; + port@2 { + reg = <2>; + }; + }; + }; + + prr: chipid@fff00044 { + compatible = "renesas,prr"; + reg = <0 0xfff00044 0 4>; + }; + }; + + thermal-zones { + sensor_thermal1: sensor-thermal1 { + polling-delay-passive = <250>; + polling-delay = <1000>; + thermal-sensors = <&tsc 0>; + sustainable-power = <6313>; + + trips { + sensor1_crit: sensor1-crit { + temperature = <120000>; + hysteresis = <1000>; + type = "critical"; + }; + }; + }; + + sensor_thermal2: sensor-thermal2 { + polling-delay-passive = <250>; + polling-delay = <1000>; + thermal-sensors = <&tsc 1>; + sustainable-power = <6313>; + + trips { + sensor2_crit: sensor2-crit { + temperature = <120000>; + hysteresis = <1000>; + type = "critical"; + }; + }; + }; + + sensor_thermal3: sensor-thermal3 { + polling-delay-passive = <250>; + polling-delay = <1000>; + thermal-sensors = <&tsc 2>; + sustainable-power = <6313>; + + trips { + target: trip-point1 { + temperature = <100000>; + hysteresis = <1000>; + type = "passive"; + }; + + sensor3_crit: sensor3-crit { + temperature = <120000>; + hysteresis = <1000>; + type = "critical"; + }; + }; + + cooling-maps { + map0 { + trip = <&target>; + cooling-device = <&a57_0 0 2>; + contribution = <1024>; + }; + + map1 { + trip = <&target>; + cooling-device = <&a53_0 0 2>; + contribution = <1024>; + }; + }; + }; + }; + + timer { + compatible = "arm,armv8-timer"; + interrupts-extended = <&gic GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(8) | IRQ_TYPE_LEVEL_LOW)>, + <&gic GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(8) | IRQ_TYPE_LEVEL_LOW)>, + <&gic GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(8) | IRQ_TYPE_LEVEL_LOW)>, + <&gic GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(8) | IRQ_TYPE_LEVEL_LOW)>; + }; + + /* External USB clocks - can be overridden by the board */ + usb3s0_clk: usb3s0 { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <0>; + }; + + usb_extal_clk: usb_extal { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <0>; + }; +}; diff --git a/include/dt-bindings/clock/r8a774e1-cpg-mssr.h b/include/dt-bindings/clock/r8a774e1-cpg-mssr.h new file mode 100644 index 0000000000..b2fc1d1c3c --- /dev/null +++ b/include/dt-bindings/clock/r8a774e1-cpg-mssr.h @@ -0,0 +1,59 @@ +/* SPDX-License-Identifier: GPL-2.0 + * + * Copyright (C) 2020 Renesas Electronics Corp. + */ +#ifndef __DT_BINDINGS_CLOCK_R8A774E1_CPG_MSSR_H__ +#define __DT_BINDINGS_CLOCK_R8A774E1_CPG_MSSR_H__ + +#include <dt-bindings/clock/renesas-cpg-mssr.h> + +/* R8A774E1 CPG Core Clocks */ +#define R8A774E1_CLK_Z 0 +#define R8A774E1_CLK_Z2 1 +#define R8A774E1_CLK_ZG 2 +#define R8A774E1_CLK_ZTR 3 +#define R8A774E1_CLK_ZTRD2 4 +#define R8A774E1_CLK_ZT 5 +#define R8A774E1_CLK_ZX 6 +#define R8A774E1_CLK_S0D1 7 +#define R8A774E1_CLK_S0D2 8 +#define R8A774E1_CLK_S0D3 9 +#define R8A774E1_CLK_S0D4 10 +#define R8A774E1_CLK_S0D6 11 +#define R8A774E1_CLK_S0D8 12 +#define R8A774E1_CLK_S0D12 13 +#define R8A774E1_CLK_S1D2 14 +#define R8A774E1_CLK_S1D4 15 +#define R8A774E1_CLK_S2D1 16 +#define R8A774E1_CLK_S2D2 17 +#define R8A774E1_CLK_S2D4 18 +#define R8A774E1_CLK_S3D1 19 +#define R8A774E1_CLK_S3D2 20 +#define R8A774E1_CLK_S3D4 21 +#define R8A774E1_CLK_LB 22 +#define R8A774E1_CLK_CL 23 +#define R8A774E1_CLK_ZB3 24 +#define R8A774E1_CLK_ZB3D2 25 +#define R8A774E1_CLK_ZB3D4 26 +#define R8A774E1_CLK_CR 27 +#define R8A774E1_CLK_CRD2 28 +#define R8A774E1_CLK_SD0H 29 +#define R8A774E1_CLK_SD0 30 +#define R8A774E1_CLK_SD1H 31 +#define R8A774E1_CLK_SD1 32 +#define R8A774E1_CLK_SD2H 33 +#define R8A774E1_CLK_SD2 34 +#define R8A774E1_CLK_SD3H 35 +#define R8A774E1_CLK_SD3 36 +#define R8A774E1_CLK_RPC 37 +#define R8A774E1_CLK_RPCD2 38 +#define R8A774E1_CLK_MSO 39 +#define R8A774E1_CLK_HDMI 40 +#define R8A774E1_CLK_CSI0 41 +#define R8A774E1_CLK_CP 42 +#define R8A774E1_CLK_CPEX 43 +#define R8A774E1_CLK_R 44 +#define R8A774E1_CLK_OSC 45 +#define R8A774E1_CLK_CANFD 46 + +#endif /* __DT_BINDINGS_CLOCK_R8A774E1_CPG_MSSR_H__ */ diff --git a/include/dt-bindings/power/r8a774e1-sysc.h b/include/dt-bindings/power/r8a774e1-sysc.h new file mode 100644 index 0000000000..7edb8161db --- /dev/null +++ b/include/dt-bindings/power/r8a774e1-sysc.h @@ -0,0 +1,36 @@ +/* SPDX-License-Identifier: GPL-2.0 + * + * Copyright (C) 2020 Renesas Electronics Corp. + */ +#ifndef __DT_BINDINGS_POWER_R8A774E1_SYSC_H__ +#define __DT_BINDINGS_POWER_R8A774E1_SYSC_H__ + +/* + * These power domain indices match the numbers of the interrupt bits + * representing the power areas in the various Interrupt Registers + * (e.g. SYSCISR, Interrupt Status Register) + */ + +#define R8A774E1_PD_CA57_CPU0 0 +#define R8A774E1_PD_CA57_CPU1 1 +#define R8A774E1_PD_CA57_CPU2 2 +#define R8A774E1_PD_CA57_CPU3 3 +#define R8A774E1_PD_CA53_CPU0 5 +#define R8A774E1_PD_CA53_CPU1 6 +#define R8A774E1_PD_CA53_CPU2 7 +#define R8A774E1_PD_CA53_CPU3 8 +#define R8A774E1_PD_A3VP 9 +#define R8A774E1_PD_CA57_SCU 12 +#define R8A774E1_PD_A3VC 14 +#define R8A774E1_PD_3DG_A 17 +#define R8A774E1_PD_3DG_B 18 +#define R8A774E1_PD_3DG_C 19 +#define R8A774E1_PD_3DG_D 20 +#define R8A774E1_PD_CA53_SCU 21 +#define R8A774E1_PD_3DG_E 22 +#define R8A774E1_PD_A2VC1 26 + +/* Always-on power area */ +#define R8A774E1_PD_ALWAYS_ON 32 + +#endif /* __DT_BINDINGS_POWER_R8A774E1_SYSC_H__ */
This sync's the RZ/G2H clock tables with mainline linux 5.9-rc4 commit f4d51dffc6c0 ("Linux 5.9-rc4")
Signed-off-by: Biju Das biju.das.jz@bp.renesas.com Reviewed-by: Lad Prabhakar prabhakar.mahadev-lad.rj@bp.renesas.com --- arch/arm/mach-rmobile/Kconfig.64 | 1 + drivers/clk/renesas/Kconfig | 6 + drivers/clk/renesas/Makefile | 1 + drivers/clk/renesas/r8a774e1-cpg-mssr.c | 358 ++++++++++++++++++++++++ 4 files changed, 366 insertions(+) create mode 100644 drivers/clk/renesas/r8a774e1-cpg-mssr.c
diff --git a/arch/arm/mach-rmobile/Kconfig.64 b/arch/arm/mach-rmobile/Kconfig.64 index 36c414f601..55e0a48e97 100644 --- a/arch/arm/mach-rmobile/Kconfig.64 +++ b/arch/arm/mach-rmobile/Kconfig.64 @@ -14,6 +14,7 @@ config R8A774B1
config R8A774E1 bool "Renesas SoC R8A774E1" + imply CLK_R8A774E1
config R8A7795 bool "Renesas SoC R8A7795" diff --git a/drivers/clk/renesas/Kconfig b/drivers/clk/renesas/Kconfig index 00a173b8c8..44afcecbfa 100644 --- a/drivers/clk/renesas/Kconfig +++ b/drivers/clk/renesas/Kconfig @@ -61,6 +61,12 @@ config CLK_R8A774B1 help Enable this to support the clocks on Renesas R8A774B1 SoC.
+config CLK_R8A774E1 + bool "Renesas R8A774E1 clock driver" + depends on CLK_RCAR_GEN3 + help + Enable this to support the clocks on Renesas R8A774E1 SoC. + config CLK_R8A7795 bool "Renesas R8A7795 clock driver" depends on CLK_RCAR_GEN3 diff --git a/drivers/clk/renesas/Makefile b/drivers/clk/renesas/Makefile index 2e8d796f89..da353e811d 100644 --- a/drivers/clk/renesas/Makefile +++ b/drivers/clk/renesas/Makefile @@ -2,6 +2,7 @@ obj-$(CONFIG_CLK_RENESAS) += renesas-cpg-mssr.o obj-$(CONFIG_CLK_RCAR_GEN2) += clk-rcar-gen2.o obj-$(CONFIG_CLK_R8A774A1) += r8a774a1-cpg-mssr.o obj-$(CONFIG_CLK_R8A774B1) += r8a774b1-cpg-mssr.o +obj-$(CONFIG_CLK_R8A774E1) += r8a774e1-cpg-mssr.o obj-$(CONFIG_CLK_R8A7790) += r8a7790-cpg-mssr.o obj-$(CONFIG_CLK_R8A7791) += r8a7791-cpg-mssr.o obj-$(CONFIG_CLK_R8A7792) += r8a7792-cpg-mssr.o diff --git a/drivers/clk/renesas/r8a774e1-cpg-mssr.c b/drivers/clk/renesas/r8a774e1-cpg-mssr.c new file mode 100644 index 0000000000..6cce007aa1 --- /dev/null +++ b/drivers/clk/renesas/r8a774e1-cpg-mssr.c @@ -0,0 +1,358 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * r8a774e1 Clock Pulse Generator / Module Standby and Software Reset + * + * Copyright (C) 2020 Renesas Electronics Corp. + * + * Based on r8a7795-cpg-mssr.c + * + * Copyright (C) 2015 Glider bvba + */ + +#include <common.h> +#include <clk-uclass.h> +#include <dm.h> +#include <linux/bitops.h> + +#include <dt-bindings/clock/r8a774e1-cpg-mssr.h> + +#include "renesas-cpg-mssr.h" +#include "rcar-gen3-cpg.h" + +enum clk_ids { + /* Core Clock Outputs exported to DT */ + LAST_DT_CORE_CLK = R8A774E1_CLK_CANFD, + + /* External Input Clocks */ + CLK_EXTAL, + CLK_EXTALR, + + /* Internal Core Clocks */ + CLK_MAIN, + CLK_PLL0, + CLK_PLL1, + CLK_PLL2, + CLK_PLL3, + CLK_PLL4, + CLK_PLL1_DIV2, + CLK_PLL1_DIV4, + CLK_S0, + CLK_S1, + CLK_S2, + CLK_S3, + CLK_SDSRC, + CLK_RPCSRC, + CLK_RINT, + + /* Module Clocks */ + MOD_CLK_BASE +}; + +static const struct cpg_core_clk r8a774e1_core_clks[] = { + /* External Clock Inputs */ + DEF_INPUT("extal", CLK_EXTAL), + DEF_INPUT("extalr", CLK_EXTALR), + + /* Internal Core Clocks */ + DEF_BASE(".main", CLK_MAIN, CLK_TYPE_GEN3_MAIN, CLK_EXTAL), + DEF_BASE(".pll0", CLK_PLL0, CLK_TYPE_GEN3_PLL0, CLK_MAIN), + DEF_BASE(".pll1", CLK_PLL1, CLK_TYPE_GEN3_PLL1, CLK_MAIN), + DEF_BASE(".pll2", CLK_PLL2, CLK_TYPE_GEN3_PLL2, CLK_MAIN), + DEF_BASE(".pll3", CLK_PLL3, CLK_TYPE_GEN3_PLL3, CLK_MAIN), + DEF_BASE(".pll4", CLK_PLL4, CLK_TYPE_GEN3_PLL4, CLK_MAIN), + + DEF_FIXED(".pll1_div2", CLK_PLL1_DIV2, CLK_PLL1, 2, 1), + DEF_FIXED(".pll1_div4", CLK_PLL1_DIV4, CLK_PLL1_DIV2, 2, 1), + DEF_FIXED(".s0", CLK_S0, CLK_PLL1_DIV2, 2, 1), + DEF_FIXED(".s1", CLK_S1, CLK_PLL1_DIV2, 3, 1), + DEF_FIXED(".s2", CLK_S2, CLK_PLL1_DIV2, 4, 1), + DEF_FIXED(".s3", CLK_S3, CLK_PLL1_DIV2, 6, 1), + DEF_FIXED(".sdsrc", CLK_SDSRC, CLK_PLL1_DIV2, 2, 1), + DEF_BASE(".rpcsrc", CLK_RPCSRC, CLK_TYPE_GEN3_RPCSRC, CLK_PLL1), + + DEF_BASE("rpc", R8A774E1_CLK_RPC, CLK_TYPE_GEN3_RPC, + CLK_RPCSRC), + DEF_BASE("rpcd2", R8A774E1_CLK_RPCD2, CLK_TYPE_GEN3_RPCD2, + R8A774E1_CLK_RPC), + + DEF_GEN3_OSC(".r", CLK_RINT, CLK_EXTAL, 32), + + /* Core Clock Outputs */ + DEF_GEN3_Z("z", R8A774E1_CLK_Z, CLK_TYPE_GEN3_Z, CLK_PLL0, 2, 8), + DEF_GEN3_Z("z2", R8A774E1_CLK_Z2, CLK_TYPE_GEN3_Z, CLK_PLL2, 2, 0), + DEF_FIXED("ztr", R8A774E1_CLK_ZTR, CLK_PLL1_DIV2, 6, 1), + DEF_FIXED("ztrd2", R8A774E1_CLK_ZTRD2, CLK_PLL1_DIV2, 12, 1), + DEF_FIXED("zt", R8A774E1_CLK_ZT, CLK_PLL1_DIV2, 4, 1), + DEF_FIXED("zx", R8A774E1_CLK_ZX, CLK_PLL1_DIV2, 2, 1), + DEF_FIXED("s0d1", R8A774E1_CLK_S0D1, CLK_S0, 1, 1), + DEF_FIXED("s0d2", R8A774E1_CLK_S0D2, CLK_S0, 2, 1), + DEF_FIXED("s0d3", R8A774E1_CLK_S0D3, CLK_S0, 3, 1), + DEF_FIXED("s0d4", R8A774E1_CLK_S0D4, CLK_S0, 4, 1), + DEF_FIXED("s0d6", R8A774E1_CLK_S0D6, CLK_S0, 6, 1), + DEF_FIXED("s0d8", R8A774E1_CLK_S0D8, CLK_S0, 8, 1), + DEF_FIXED("s0d12", R8A774E1_CLK_S0D12, CLK_S0, 12, 1), + DEF_FIXED("s1d2", R8A774E1_CLK_S1D2, CLK_S1, 2, 1), + DEF_FIXED("s1d4", R8A774E1_CLK_S1D4, CLK_S1, 4, 1), + DEF_FIXED("s2d1", R8A774E1_CLK_S2D1, CLK_S2, 1, 1), + DEF_FIXED("s2d2", R8A774E1_CLK_S2D2, CLK_S2, 2, 1), + DEF_FIXED("s2d4", R8A774E1_CLK_S2D4, CLK_S2, 4, 1), + DEF_FIXED("s3d1", R8A774E1_CLK_S3D1, CLK_S3, 1, 1), + DEF_FIXED("s3d2", R8A774E1_CLK_S3D2, CLK_S3, 2, 1), + DEF_FIXED("s3d4", R8A774E1_CLK_S3D4, CLK_S3, 4, 1), + + DEF_GEN3_SD("sd0", R8A774E1_CLK_SD0, CLK_SDSRC, 0x074), + DEF_GEN3_SD("sd1", R8A774E1_CLK_SD1, CLK_SDSRC, 0x078), + DEF_GEN3_SD("sd2", R8A774E1_CLK_SD2, CLK_SDSRC, 0x268), + DEF_GEN3_SD("sd3", R8A774E1_CLK_SD3, CLK_SDSRC, 0x26c), + + DEF_FIXED("cl", R8A774E1_CLK_CL, CLK_PLL1_DIV2, 48, 1), + DEF_FIXED("cr", R8A774E1_CLK_CR, CLK_PLL1_DIV4, 2, 1), + DEF_FIXED("cp", R8A774E1_CLK_CP, CLK_EXTAL, 2, 1), + DEF_FIXED("cpex", R8A774E1_CLK_CPEX, CLK_EXTAL, 2, 1), + + DEF_DIV6P1("canfd", R8A774E1_CLK_CANFD, CLK_PLL1_DIV4, 0x244), + DEF_DIV6P1("csi0", R8A774E1_CLK_CSI0, CLK_PLL1_DIV4, 0x00c), + DEF_DIV6P1("mso", R8A774E1_CLK_MSO, CLK_PLL1_DIV4, 0x014), + DEF_DIV6P1("hdmi", R8A774E1_CLK_HDMI, CLK_PLL1_DIV4, 0x250), + + DEF_GEN3_OSC("osc", R8A774E1_CLK_OSC, CLK_EXTAL, 8), + + DEF_BASE("r", R8A774E1_CLK_R, CLK_TYPE_GEN3_R, CLK_RINT), +}; + +static const struct mssr_mod_clk r8a774e1_mod_clks[] = { + DEF_MOD("fdp1-1", 118, R8A774E1_CLK_S0D1), + DEF_MOD("fdp1-0", 119, R8A774E1_CLK_S0D1), + DEF_MOD("tmu4", 121, R8A774E1_CLK_S0D6), + DEF_MOD("tmu3", 122, R8A774E1_CLK_S3D2), + DEF_MOD("tmu2", 123, R8A774E1_CLK_S3D2), + DEF_MOD("tmu1", 124, R8A774E1_CLK_S3D2), + DEF_MOD("tmu0", 125, R8A774E1_CLK_CP), + DEF_MOD("vcplf", 130, R8A774E1_CLK_S2D1), + DEF_MOD("vdpb", 131, R8A774E1_CLK_S2D1), + DEF_MOD("scif5", 202, R8A774E1_CLK_S3D4), + DEF_MOD("scif4", 203, R8A774E1_CLK_S3D4), + DEF_MOD("scif3", 204, R8A774E1_CLK_S3D4), + DEF_MOD("scif1", 206, R8A774E1_CLK_S3D4), + DEF_MOD("scif0", 207, R8A774E1_CLK_S3D4), + DEF_MOD("msiof3", 208, R8A774E1_CLK_MSO), + DEF_MOD("msiof2", 209, R8A774E1_CLK_MSO), + DEF_MOD("msiof1", 210, R8A774E1_CLK_MSO), + DEF_MOD("msiof0", 211, R8A774E1_CLK_MSO), + DEF_MOD("sys-dmac2", 217, R8A774E1_CLK_S3D1), + DEF_MOD("sys-dmac1", 218, R8A774E1_CLK_S3D1), + DEF_MOD("sys-dmac0", 219, R8A774E1_CLK_S0D3), + DEF_MOD("cmt3", 300, R8A774E1_CLK_R), + DEF_MOD("cmt2", 301, R8A774E1_CLK_R), + DEF_MOD("cmt1", 302, R8A774E1_CLK_R), + DEF_MOD("cmt0", 303, R8A774E1_CLK_R), + DEF_MOD("tpu0", 304, R8A774E1_CLK_S3D4), + DEF_MOD("scif2", 310, R8A774E1_CLK_S3D4), + DEF_MOD("sdif3", 311, R8A774E1_CLK_SD3), + DEF_MOD("sdif2", 312, R8A774E1_CLK_SD2), + DEF_MOD("sdif1", 313, R8A774E1_CLK_SD1), + DEF_MOD("sdif0", 314, R8A774E1_CLK_SD0), + DEF_MOD("pcie1", 318, R8A774E1_CLK_S3D1), + DEF_MOD("pcie0", 319, R8A774E1_CLK_S3D1), + DEF_MOD("usb3-if0", 328, R8A774E1_CLK_S3D1), + DEF_MOD("usb-dmac0", 330, R8A774E1_CLK_S3D1), + DEF_MOD("usb-dmac1", 331, R8A774E1_CLK_S3D1), + DEF_MOD("rwdt", 402, R8A774E1_CLK_R), + DEF_MOD("intc-ex", 407, R8A774E1_CLK_CP), + DEF_MOD("intc-ap", 408, R8A774E1_CLK_S0D3), + DEF_MOD("audmac1", 501, R8A774E1_CLK_S1D2), + DEF_MOD("audmac0", 502, R8A774E1_CLK_S1D2), + DEF_MOD("hscif4", 516, R8A774E1_CLK_S3D1), + DEF_MOD("hscif3", 517, R8A774E1_CLK_S3D1), + DEF_MOD("hscif2", 518, R8A774E1_CLK_S3D1), + DEF_MOD("hscif1", 519, R8A774E1_CLK_S3D1), + DEF_MOD("hscif0", 520, R8A774E1_CLK_S3D1), + DEF_MOD("thermal", 522, R8A774E1_CLK_CP), + DEF_MOD("pwm", 523, R8A774E1_CLK_S0D12), + DEF_MOD("fcpvd1", 602, R8A774E1_CLK_S0D2), + DEF_MOD("fcpvd0", 603, R8A774E1_CLK_S0D2), + DEF_MOD("fcpvb1", 606, R8A774E1_CLK_S0D1), + DEF_MOD("fcpvb0", 607, R8A774E1_CLK_S0D1), + DEF_MOD("fcpvi1", 610, R8A774E1_CLK_S0D1), + DEF_MOD("fcpvi0", 611, R8A774E1_CLK_S0D1), + DEF_MOD("fcpf1", 614, R8A774E1_CLK_S0D1), + DEF_MOD("fcpf0", 615, R8A774E1_CLK_S0D1), + DEF_MOD("fcpcs", 619, R8A774E1_CLK_S0D1), + DEF_MOD("vspd1", 622, R8A774E1_CLK_S0D2), + DEF_MOD("vspd0", 623, R8A774E1_CLK_S0D2), + DEF_MOD("vspbc", 624, R8A774E1_CLK_S0D1), + DEF_MOD("vspbd", 626, R8A774E1_CLK_S0D1), + DEF_MOD("vspi1", 630, R8A774E1_CLK_S0D1), + DEF_MOD("vspi0", 631, R8A774E1_CLK_S0D1), + DEF_MOD("ehci1", 702, R8A774E1_CLK_S3D2), + DEF_MOD("ehci0", 703, R8A774E1_CLK_S3D2), + DEF_MOD("hsusb", 704, R8A774E1_CLK_S3D2), + DEF_MOD("csi20", 714, R8A774E1_CLK_CSI0), + DEF_MOD("csi40", 716, R8A774E1_CLK_CSI0), + DEF_MOD("du3", 721, R8A774E1_CLK_S2D1), + DEF_MOD("du1", 723, R8A774E1_CLK_S2D1), + DEF_MOD("du0", 724, R8A774E1_CLK_S2D1), + DEF_MOD("lvds", 727, R8A774E1_CLK_S0D4), + DEF_MOD("hdmi0", 729, R8A774E1_CLK_HDMI), + DEF_MOD("vin7", 804, R8A774E1_CLK_S0D2), + DEF_MOD("vin6", 805, R8A774E1_CLK_S0D2), + DEF_MOD("vin5", 806, R8A774E1_CLK_S0D2), + DEF_MOD("vin4", 807, R8A774E1_CLK_S0D2), + DEF_MOD("vin3", 808, R8A774E1_CLK_S0D2), + DEF_MOD("vin2", 809, R8A774E1_CLK_S0D2), + DEF_MOD("vin1", 810, R8A774E1_CLK_S0D2), + DEF_MOD("vin0", 811, R8A774E1_CLK_S0D2), + DEF_MOD("etheravb", 812, R8A774E1_CLK_S0D6), + DEF_MOD("sata0", 815, R8A774E1_CLK_S3D2), + DEF_MOD("gpio7", 905, R8A774E1_CLK_S3D4), + DEF_MOD("gpio6", 906, R8A774E1_CLK_S3D4), + DEF_MOD("gpio5", 907, R8A774E1_CLK_S3D4), + DEF_MOD("gpio4", 908, R8A774E1_CLK_S3D4), + DEF_MOD("gpio3", 909, R8A774E1_CLK_S3D4), + DEF_MOD("gpio2", 910, R8A774E1_CLK_S3D4), + DEF_MOD("gpio1", 911, R8A774E1_CLK_S3D4), + DEF_MOD("gpio0", 912, R8A774E1_CLK_S3D4), + DEF_MOD("can-fd", 914, R8A774E1_CLK_S3D2), + DEF_MOD("can-if1", 915, R8A774E1_CLK_S3D4), + DEF_MOD("can-if0", 916, R8A774E1_CLK_S3D4), + DEF_MOD("rpc-if", 917, R8A774E1_CLK_RPCD2), + DEF_MOD("i2c6", 918, R8A774E1_CLK_S0D6), + DEF_MOD("i2c5", 919, R8A774E1_CLK_S0D6), + DEF_MOD("adg", 922, R8A774E1_CLK_S0D1), + DEF_MOD("i2c-dvfs", 926, R8A774E1_CLK_CP), + DEF_MOD("i2c4", 927, R8A774E1_CLK_S0D6), + DEF_MOD("i2c3", 928, R8A774E1_CLK_S0D6), + DEF_MOD("i2c2", 929, R8A774E1_CLK_S3D2), + DEF_MOD("i2c1", 930, R8A774E1_CLK_S3D2), + DEF_MOD("i2c0", 931, R8A774E1_CLK_S3D2), + DEF_MOD("ssi-all", 1005, R8A774E1_CLK_S3D4), + DEF_MOD("ssi9", 1006, MOD_CLK_ID(1005)), + DEF_MOD("ssi8", 1007, MOD_CLK_ID(1005)), + DEF_MOD("ssi7", 1008, MOD_CLK_ID(1005)), + DEF_MOD("ssi6", 1009, MOD_CLK_ID(1005)), + DEF_MOD("ssi5", 1010, MOD_CLK_ID(1005)), + DEF_MOD("ssi4", 1011, MOD_CLK_ID(1005)), + DEF_MOD("ssi3", 1012, MOD_CLK_ID(1005)), + DEF_MOD("ssi2", 1013, MOD_CLK_ID(1005)), + DEF_MOD("ssi1", 1014, MOD_CLK_ID(1005)), + DEF_MOD("ssi0", 1015, MOD_CLK_ID(1005)), + DEF_MOD("scu-all", 1017, R8A774E1_CLK_S3D4), + DEF_MOD("scu-dvc1", 1018, MOD_CLK_ID(1017)), + DEF_MOD("scu-dvc0", 1019, MOD_CLK_ID(1017)), + DEF_MOD("scu-ctu1-mix1", 1020, MOD_CLK_ID(1017)), + DEF_MOD("scu-ctu0-mix0", 1021, MOD_CLK_ID(1017)), + DEF_MOD("scu-src9", 1022, MOD_CLK_ID(1017)), + DEF_MOD("scu-src8", 1023, MOD_CLK_ID(1017)), + DEF_MOD("scu-src7", 1024, MOD_CLK_ID(1017)), + DEF_MOD("scu-src6", 1025, MOD_CLK_ID(1017)), + DEF_MOD("scu-src5", 1026, MOD_CLK_ID(1017)), + DEF_MOD("scu-src4", 1027, MOD_CLK_ID(1017)), + DEF_MOD("scu-src3", 1028, MOD_CLK_ID(1017)), + DEF_MOD("scu-src2", 1029, MOD_CLK_ID(1017)), + DEF_MOD("scu-src1", 1030, MOD_CLK_ID(1017)), + DEF_MOD("scu-src0", 1031, MOD_CLK_ID(1017)), +}; + +/* + * CPG Clock Data + */ + +/* + * MD EXTAL PLL0 PLL1 PLL2 PLL3 PLL4 OSC + * 14 13 19 17 (MHz) + *------------------------------------------------------------------------- + * 0 0 0 0 16.66 x 1 x180 x192 x144 x192 x144 /16 + * 0 0 0 1 16.66 x 1 x180 x192 x144 x128 x144 /16 + * 0 0 1 0 Prohibited setting + * 0 0 1 1 16.66 x 1 x180 x192 x144 x192 x144 /16 + * 0 1 0 0 20 x 1 x150 x160 x120 x160 x120 /19 + * 0 1 0 1 20 x 1 x150 x160 x120 x106 x120 /19 + * 0 1 1 0 Prohibited setting + * 0 1 1 1 20 x 1 x150 x160 x120 x160 x120 /19 + * 1 0 0 0 25 x 1 x120 x128 x96 x128 x96 /24 + * 1 0 0 1 25 x 1 x120 x128 x96 x84 x96 /24 + * 1 0 1 0 Prohibited setting + * 1 0 1 1 25 x 1 x120 x128 x96 x128 x96 /24 + * 1 1 0 0 33.33 / 2 x180 x192 x144 x192 x144 /32 + * 1 1 0 1 33.33 / 2 x180 x192 x144 x128 x144 /32 + * 1 1 1 0 Prohibited setting + * 1 1 1 1 33.33 / 2 x180 x192 x144 x192 x144 /32 + */ +#define CPG_PLL_CONFIG_INDEX(md) ((((md) & BIT(14)) >> 11) | \ + (((md) & BIT(13)) >> 11) | \ + (((md) & BIT(19)) >> 18) | \ + (((md) & BIT(17)) >> 17)) + +static const struct rcar_gen3_cpg_pll_config cpg_pll_configs[16] = { + /* EXTAL div PLL1 mult/div PLL3 mult/div OSC prediv */ + { 1, 192, 1, 192, 1, 16, }, + { 1, 192, 1, 128, 1, 16, }, + { 0, /* Prohibited setting */ }, + { 1, 192, 1, 192, 1, 16, }, + { 1, 160, 1, 160, 1, 19, }, + { 1, 160, 1, 106, 1, 19, }, + { 0, /* Prohibited setting */ }, + { 1, 160, 1, 160, 1, 19, }, + { 1, 128, 1, 128, 1, 24, }, + { 1, 128, 1, 84, 1, 24, }, + { 0, /* Prohibited setting */ }, + { 1, 128, 1, 128, 1, 24, }, + { 2, 192, 1, 192, 1, 32, }, + { 2, 192, 1, 128, 1, 32, }, + { 0, /* Prohibited setting */ }, + { 2, 192, 1, 192, 1, 32, }, +}; + +/* RMSTPCR[0-11] is not present on RZ/G2H */ +static const struct mstp_stop_table r8a774e1_mstp_table[] = { + { 0x00640800, 0x0, 0x0, 0 }, + { 0xF3EE9390, 0x0, 0x0, 0 }, + { 0x340FAFDC, 0x2040, 0x0, 0 }, + { 0xD80C7CDF, 0x400, 0x0, 0 }, + { 0x80000184, 0x180, 0x0, 0 }, + { 0x40BFFF46, 0x0, 0x0, 0 }, + { 0xE5FBEECF, 0x0, 0x0, 0 }, + { 0x39FFFF0E, 0x0, 0x0, 0 }, + { 0x01F19FF4, 0x0, 0x0, 0 }, + { 0xFFDFFFFF, 0x0, 0x0, 0 }, + { 0xFFFEFFE0, 0x0, 0x0, 0 }, + { 0x00000000, 0x0, 0x0, 0 }, +}; + +static const void *r8a774e1_get_pll_config(const u32 cpg_mode) +{ + return &cpg_pll_configs[CPG_PLL_CONFIG_INDEX(cpg_mode)]; +} + +static const struct cpg_mssr_info r8a774e1_cpg_mssr_info = { + .core_clk = r8a774e1_core_clks, + .core_clk_size = ARRAY_SIZE(r8a774e1_core_clks), + .mod_clk = r8a774e1_mod_clks, + .mod_clk_size = ARRAY_SIZE(r8a774e1_mod_clks), + .mstp_table = r8a774e1_mstp_table, + .mstp_table_size = ARRAY_SIZE(r8a774e1_mstp_table), + .reset_node = "renesas,r8a774e1-rst", + .extalr_node = "extalr", + .mod_clk_base = MOD_CLK_BASE, + .clk_extal_id = CLK_EXTAL, + .clk_extalr_id = CLK_EXTALR, + .get_pll_config = r8a774e1_get_pll_config, +}; + +static const struct udevice_id r8a774e1_clk_ids[] = { + { + .compatible = "renesas,r8a774e1-cpg-mssr", + .data = (ulong)&r8a774e1_cpg_mssr_info + }, + { } +}; + +U_BOOT_DRIVER(clk_r8a774e1) = { + .name = "clk_r8a774e1", + .id = UCLASS_CLK, + .of_match = r8a774e1_clk_ids, + .priv_auto_alloc_size = sizeof(struct gen3_clk_priv), + .ops = &gen3_clk_ops, + .probe = gen3_clk_probe, + .remove = gen3_clk_remove, +};
Renesas RZ/G2H (r8a774e1) is pin compatible with R-Car H3 (r8a77951), however it doesn't have several automotive specific peripherals. Add a r8a77951 specific pin groups/functions along with common pin groups/functions for supporting both r8a77951 and r8a774e1 SoC.
This patch is ported from mainline linux-5.9-rc4.
Signed-off-by: Biju Das biju.das.jz@bp.renesas.com Reviewed-by: Lad Prabhakar prabhakar.mahadev-lad.rj@bp.renesas.com --- arch/arm/mach-rmobile/Kconfig.64 | 1 + drivers/pinctrl/renesas/Kconfig | 10 + drivers/pinctrl/renesas/Makefile | 1 + drivers/pinctrl/renesas/pfc-r8a7795.c | 905 ++++++++++++++------------ drivers/pinctrl/renesas/pfc.c | 11 + drivers/pinctrl/renesas/sh_pfc.h | 1 + 6 files changed, 520 insertions(+), 409 deletions(-)
diff --git a/arch/arm/mach-rmobile/Kconfig.64 b/arch/arm/mach-rmobile/Kconfig.64 index 55e0a48e97..9e11732a09 100644 --- a/arch/arm/mach-rmobile/Kconfig.64 +++ b/arch/arm/mach-rmobile/Kconfig.64 @@ -15,6 +15,7 @@ config R8A774B1 config R8A774E1 bool "Renesas SoC R8A774E1" imply CLK_R8A774E1 + imply PINCTRL_PFC_R8A774E1
config R8A7795 bool "Renesas SoC R8A7795" diff --git a/drivers/pinctrl/renesas/Kconfig b/drivers/pinctrl/renesas/Kconfig index 0d839eecad..d2be4c84ba 100644 --- a/drivers/pinctrl/renesas/Kconfig +++ b/drivers/pinctrl/renesas/Kconfig @@ -77,6 +77,16 @@ config PINCTRL_PFC_R8A774B1 the GPIO definitions and pin control functions for each available multiplex function.
+config PINCTRL_PFC_R8A774E1 + bool "Renesas RZ/G2 R8A774E1 pin control driver" + depends on PINCTRL_PFC + help + Support pin multiplexing control on Renesas RZ/G2H R8A774E1 SoCs. + + The driver is controlled by a device tree node which contains both + the GPIO definitions and pin control functions for each available + multiplex function. + config PINCTRL_PFC_R8A7795 bool "Renesas RCar Gen3 R8A7795 pin control driver" depends on PINCTRL_PFC diff --git a/drivers/pinctrl/renesas/Makefile b/drivers/pinctrl/renesas/Makefile index 59dfd05b2c..1d00752051 100644 --- a/drivers/pinctrl/renesas/Makefile +++ b/drivers/pinctrl/renesas/Makefile @@ -1,6 +1,7 @@ obj-$(CONFIG_PINCTRL_PFC) += pfc.o obj-$(CONFIG_PINCTRL_PFC_R8A774A1) += pfc-r8a7796.o obj-$(CONFIG_PINCTRL_PFC_R8A774B1) += pfc-r8a77965.o +obj-$(CONFIG_PINCTRL_PFC_R8A774E1) += pfc-r8a7795.o obj-$(CONFIG_PINCTRL_PFC_R8A7790) += pfc-r8a7790.o obj-$(CONFIG_PINCTRL_PFC_R8A7791) += pfc-r8a7791.o obj-$(CONFIG_PINCTRL_PFC_R8A7792) += pfc-r8a7792.o diff --git a/drivers/pinctrl/renesas/pfc-r8a7795.c b/drivers/pinctrl/renesas/pfc-r8a7795.c index ba17a55775..b787c4883a 100644 --- a/drivers/pinctrl/renesas/pfc-r8a7795.c +++ b/drivers/pinctrl/renesas/pfc-r8a7795.c @@ -683,7 +683,7 @@ static const u16 pinmux_data[] = { PINMUX_IPSR_PHYS_MSEL(IP1_23_20, HRX3_D, I2C_SEL_3_0, SEL_HSCIF3_3), PINMUX_IPSR_PHYS_MSEL(IP1_23_20, VI4_DATA7_B, I2C_SEL_3_0, SEL_VIN4_1), PINMUX_IPSR_PHYS_MSEL(IP1_23_20, IERX_B, I2C_SEL_3_0, SEL_IEBUS_1), - PINMUX_IPSR_PHYS(IP0_23_20, SCL3, I2C_SEL_3_1), + PINMUX_IPSR_PHYS(IP1_23_20, SCL3, I2C_SEL_3_1),
PINMUX_IPSR_PHYS_MSEL(IP1_27_24, PWM2_A, I2C_SEL_3_0, SEL_PWM2_0), PINMUX_IPSR_PHYS_MSEL(IP1_27_24, HTX3_D, I2C_SEL_3_0, SEL_HSCIF3_3), @@ -3902,6 +3902,36 @@ static const unsigned int tmu_tclk2_b_mux[] = { TCLK2_B_MARK, };
+/* - TPU ------------------------------------------------------------------- */ +static const unsigned int tpu_to0_pins[] = { + /* TPU0TO0 */ + RCAR_GP_PIN(6, 28), +}; +static const unsigned int tpu_to0_mux[] = { + TPU0TO0_MARK, +}; +static const unsigned int tpu_to1_pins[] = { + /* TPU0TO1 */ + RCAR_GP_PIN(6, 29), +}; +static const unsigned int tpu_to1_mux[] = { + TPU0TO1_MARK, +}; +static const unsigned int tpu_to2_pins[] = { + /* TPU0TO2 */ + RCAR_GP_PIN(6, 30), +}; +static const unsigned int tpu_to2_mux[] = { + TPU0TO2_MARK, +}; +static const unsigned int tpu_to3_pins[] = { + /* TPU0TO3 */ + RCAR_GP_PIN(6, 31), +}; +static const unsigned int tpu_to3_mux[] = { + TPU0TO3_MARK, +}; + /* - USB0 ------------------------------------------------------------------- */ static const unsigned int usb0_pins[] = { /* PWEN, OVC */ @@ -4136,353 +4166,365 @@ static const unsigned int vin5_clk_mux[] = { VI5_CLK_MARK, };
-static const struct sh_pfc_pin_group pinmux_groups[] = { - SH_PFC_PIN_GROUP(audio_clk_a_a), - SH_PFC_PIN_GROUP(audio_clk_a_b), - SH_PFC_PIN_GROUP(audio_clk_a_c), - SH_PFC_PIN_GROUP(audio_clk_b_a), - SH_PFC_PIN_GROUP(audio_clk_b_b), - SH_PFC_PIN_GROUP(audio_clk_c_a), - SH_PFC_PIN_GROUP(audio_clk_c_b), - SH_PFC_PIN_GROUP(audio_clkout_a), - SH_PFC_PIN_GROUP(audio_clkout_b), - SH_PFC_PIN_GROUP(audio_clkout_c), - SH_PFC_PIN_GROUP(audio_clkout_d), - SH_PFC_PIN_GROUP(audio_clkout1_a), - SH_PFC_PIN_GROUP(audio_clkout1_b), - SH_PFC_PIN_GROUP(audio_clkout2_a), - SH_PFC_PIN_GROUP(audio_clkout2_b), - SH_PFC_PIN_GROUP(audio_clkout3_a), - SH_PFC_PIN_GROUP(audio_clkout3_b), - SH_PFC_PIN_GROUP(avb_link), - SH_PFC_PIN_GROUP(avb_magic), - SH_PFC_PIN_GROUP(avb_phy_int), - SH_PFC_PIN_GROUP_ALIAS(avb_mdc, avb_mdio), /* Deprecated */ - SH_PFC_PIN_GROUP(avb_mdio), - SH_PFC_PIN_GROUP(avb_mii), - SH_PFC_PIN_GROUP(avb_avtp_pps), - SH_PFC_PIN_GROUP(avb_avtp_match_a), - SH_PFC_PIN_GROUP(avb_avtp_capture_a), - SH_PFC_PIN_GROUP(avb_avtp_match_b), - SH_PFC_PIN_GROUP(avb_avtp_capture_b), - SH_PFC_PIN_GROUP(can0_data_a), - SH_PFC_PIN_GROUP(can0_data_b), - SH_PFC_PIN_GROUP(can1_data), - SH_PFC_PIN_GROUP(can_clk), - SH_PFC_PIN_GROUP(canfd0_data_a), - SH_PFC_PIN_GROUP(canfd0_data_b), - SH_PFC_PIN_GROUP(canfd1_data), - SH_PFC_PIN_GROUP(drif0_ctrl_a), - SH_PFC_PIN_GROUP(drif0_data0_a), - SH_PFC_PIN_GROUP(drif0_data1_a), - SH_PFC_PIN_GROUP(drif0_ctrl_b), - SH_PFC_PIN_GROUP(drif0_data0_b), - SH_PFC_PIN_GROUP(drif0_data1_b), - SH_PFC_PIN_GROUP(drif0_ctrl_c), - SH_PFC_PIN_GROUP(drif0_data0_c), - SH_PFC_PIN_GROUP(drif0_data1_c), - SH_PFC_PIN_GROUP(drif1_ctrl_a), - SH_PFC_PIN_GROUP(drif1_data0_a), - SH_PFC_PIN_GROUP(drif1_data1_a), - SH_PFC_PIN_GROUP(drif1_ctrl_b), - SH_PFC_PIN_GROUP(drif1_data0_b), - SH_PFC_PIN_GROUP(drif1_data1_b), - SH_PFC_PIN_GROUP(drif1_ctrl_c), - SH_PFC_PIN_GROUP(drif1_data0_c), - SH_PFC_PIN_GROUP(drif1_data1_c), - SH_PFC_PIN_GROUP(drif2_ctrl_a), - SH_PFC_PIN_GROUP(drif2_data0_a), - SH_PFC_PIN_GROUP(drif2_data1_a), - SH_PFC_PIN_GROUP(drif2_ctrl_b), - SH_PFC_PIN_GROUP(drif2_data0_b), - SH_PFC_PIN_GROUP(drif2_data1_b), - SH_PFC_PIN_GROUP(drif3_ctrl_a), - SH_PFC_PIN_GROUP(drif3_data0_a), - SH_PFC_PIN_GROUP(drif3_data1_a), - SH_PFC_PIN_GROUP(drif3_ctrl_b), - SH_PFC_PIN_GROUP(drif3_data0_b), - SH_PFC_PIN_GROUP(drif3_data1_b), - SH_PFC_PIN_GROUP(du_rgb666), - SH_PFC_PIN_GROUP(du_rgb888), - SH_PFC_PIN_GROUP(du_clk_out_0), - SH_PFC_PIN_GROUP(du_clk_out_1), - SH_PFC_PIN_GROUP(du_sync), - SH_PFC_PIN_GROUP(du_oddf), - SH_PFC_PIN_GROUP(du_cde), - SH_PFC_PIN_GROUP(du_disp), - SH_PFC_PIN_GROUP(hscif0_data), - SH_PFC_PIN_GROUP(hscif0_clk), - SH_PFC_PIN_GROUP(hscif0_ctrl), - SH_PFC_PIN_GROUP(hscif1_data_a), - SH_PFC_PIN_GROUP(hscif1_clk_a), - SH_PFC_PIN_GROUP(hscif1_ctrl_a), - SH_PFC_PIN_GROUP(hscif1_data_b), - SH_PFC_PIN_GROUP(hscif1_clk_b), - SH_PFC_PIN_GROUP(hscif1_ctrl_b), - SH_PFC_PIN_GROUP(hscif2_data_a), - SH_PFC_PIN_GROUP(hscif2_clk_a), - SH_PFC_PIN_GROUP(hscif2_ctrl_a), - SH_PFC_PIN_GROUP(hscif2_data_b), - SH_PFC_PIN_GROUP(hscif2_clk_b), - SH_PFC_PIN_GROUP(hscif2_ctrl_b), - SH_PFC_PIN_GROUP(hscif2_data_c), - SH_PFC_PIN_GROUP(hscif2_clk_c), - SH_PFC_PIN_GROUP(hscif2_ctrl_c), - SH_PFC_PIN_GROUP(hscif3_data_a), - SH_PFC_PIN_GROUP(hscif3_clk), - SH_PFC_PIN_GROUP(hscif3_ctrl), - SH_PFC_PIN_GROUP(hscif3_data_b), - SH_PFC_PIN_GROUP(hscif3_data_c), - SH_PFC_PIN_GROUP(hscif3_data_d), - SH_PFC_PIN_GROUP(hscif4_data_a), - SH_PFC_PIN_GROUP(hscif4_clk), - SH_PFC_PIN_GROUP(hscif4_ctrl), - SH_PFC_PIN_GROUP(hscif4_data_b), - SH_PFC_PIN_GROUP(i2c0), - SH_PFC_PIN_GROUP(i2c1_a), - SH_PFC_PIN_GROUP(i2c1_b), - SH_PFC_PIN_GROUP(i2c2_a), - SH_PFC_PIN_GROUP(i2c2_b), - SH_PFC_PIN_GROUP(i2c3), - SH_PFC_PIN_GROUP(i2c5), - SH_PFC_PIN_GROUP(i2c6_a), - SH_PFC_PIN_GROUP(i2c6_b), - SH_PFC_PIN_GROUP(i2c6_c), - SH_PFC_PIN_GROUP(intc_ex_irq0), - SH_PFC_PIN_GROUP(intc_ex_irq1), - SH_PFC_PIN_GROUP(intc_ex_irq2), - SH_PFC_PIN_GROUP(intc_ex_irq3), - SH_PFC_PIN_GROUP(intc_ex_irq4), - SH_PFC_PIN_GROUP(intc_ex_irq5), - SH_PFC_PIN_GROUP(msiof0_clk), - SH_PFC_PIN_GROUP(msiof0_sync), - SH_PFC_PIN_GROUP(msiof0_ss1), - SH_PFC_PIN_GROUP(msiof0_ss2), - SH_PFC_PIN_GROUP(msiof0_txd), - SH_PFC_PIN_GROUP(msiof0_rxd), - SH_PFC_PIN_GROUP(msiof1_clk_a), - SH_PFC_PIN_GROUP(msiof1_sync_a), - SH_PFC_PIN_GROUP(msiof1_ss1_a), - SH_PFC_PIN_GROUP(msiof1_ss2_a), - SH_PFC_PIN_GROUP(msiof1_txd_a), - SH_PFC_PIN_GROUP(msiof1_rxd_a), - SH_PFC_PIN_GROUP(msiof1_clk_b), - SH_PFC_PIN_GROUP(msiof1_sync_b), - SH_PFC_PIN_GROUP(msiof1_ss1_b), - SH_PFC_PIN_GROUP(msiof1_ss2_b), - SH_PFC_PIN_GROUP(msiof1_txd_b), - SH_PFC_PIN_GROUP(msiof1_rxd_b), - SH_PFC_PIN_GROUP(msiof1_clk_c), - SH_PFC_PIN_GROUP(msiof1_sync_c), - SH_PFC_PIN_GROUP(msiof1_ss1_c), - SH_PFC_PIN_GROUP(msiof1_ss2_c), - SH_PFC_PIN_GROUP(msiof1_txd_c), - SH_PFC_PIN_GROUP(msiof1_rxd_c), - SH_PFC_PIN_GROUP(msiof1_clk_d), - SH_PFC_PIN_GROUP(msiof1_sync_d), - SH_PFC_PIN_GROUP(msiof1_ss1_d), - SH_PFC_PIN_GROUP(msiof1_ss2_d), - SH_PFC_PIN_GROUP(msiof1_txd_d), - SH_PFC_PIN_GROUP(msiof1_rxd_d), - SH_PFC_PIN_GROUP(msiof1_clk_e), - SH_PFC_PIN_GROUP(msiof1_sync_e), - SH_PFC_PIN_GROUP(msiof1_ss1_e), - SH_PFC_PIN_GROUP(msiof1_ss2_e), - SH_PFC_PIN_GROUP(msiof1_txd_e), - SH_PFC_PIN_GROUP(msiof1_rxd_e), - SH_PFC_PIN_GROUP(msiof1_clk_f), - SH_PFC_PIN_GROUP(msiof1_sync_f), - SH_PFC_PIN_GROUP(msiof1_ss1_f), - SH_PFC_PIN_GROUP(msiof1_ss2_f), - SH_PFC_PIN_GROUP(msiof1_txd_f), - SH_PFC_PIN_GROUP(msiof1_rxd_f), - SH_PFC_PIN_GROUP(msiof1_clk_g), - SH_PFC_PIN_GROUP(msiof1_sync_g), - SH_PFC_PIN_GROUP(msiof1_ss1_g), - SH_PFC_PIN_GROUP(msiof1_ss2_g), - SH_PFC_PIN_GROUP(msiof1_txd_g), - SH_PFC_PIN_GROUP(msiof1_rxd_g), - SH_PFC_PIN_GROUP(msiof2_clk_a), - SH_PFC_PIN_GROUP(msiof2_sync_a), - SH_PFC_PIN_GROUP(msiof2_ss1_a), - SH_PFC_PIN_GROUP(msiof2_ss2_a), - SH_PFC_PIN_GROUP(msiof2_txd_a), - SH_PFC_PIN_GROUP(msiof2_rxd_a), - SH_PFC_PIN_GROUP(msiof2_clk_b), - SH_PFC_PIN_GROUP(msiof2_sync_b), - SH_PFC_PIN_GROUP(msiof2_ss1_b), - SH_PFC_PIN_GROUP(msiof2_ss2_b), - SH_PFC_PIN_GROUP(msiof2_txd_b), - SH_PFC_PIN_GROUP(msiof2_rxd_b), - SH_PFC_PIN_GROUP(msiof2_clk_c), - SH_PFC_PIN_GROUP(msiof2_sync_c), - SH_PFC_PIN_GROUP(msiof2_ss1_c), - SH_PFC_PIN_GROUP(msiof2_ss2_c), - SH_PFC_PIN_GROUP(msiof2_txd_c), - SH_PFC_PIN_GROUP(msiof2_rxd_c), - SH_PFC_PIN_GROUP(msiof2_clk_d), - SH_PFC_PIN_GROUP(msiof2_sync_d), - SH_PFC_PIN_GROUP(msiof2_ss1_d), - SH_PFC_PIN_GROUP(msiof2_ss2_d), - SH_PFC_PIN_GROUP(msiof2_txd_d), - SH_PFC_PIN_GROUP(msiof2_rxd_d), - SH_PFC_PIN_GROUP(msiof3_clk_a), - SH_PFC_PIN_GROUP(msiof3_sync_a), - SH_PFC_PIN_GROUP(msiof3_ss1_a), - SH_PFC_PIN_GROUP(msiof3_ss2_a), - SH_PFC_PIN_GROUP(msiof3_txd_a), - SH_PFC_PIN_GROUP(msiof3_rxd_a), - SH_PFC_PIN_GROUP(msiof3_clk_b), - SH_PFC_PIN_GROUP(msiof3_sync_b), - SH_PFC_PIN_GROUP(msiof3_ss1_b), - SH_PFC_PIN_GROUP(msiof3_ss2_b), - SH_PFC_PIN_GROUP(msiof3_txd_b), - SH_PFC_PIN_GROUP(msiof3_rxd_b), - SH_PFC_PIN_GROUP(msiof3_clk_c), - SH_PFC_PIN_GROUP(msiof3_sync_c), - SH_PFC_PIN_GROUP(msiof3_txd_c), - SH_PFC_PIN_GROUP(msiof3_rxd_c), - SH_PFC_PIN_GROUP(msiof3_clk_d), - SH_PFC_PIN_GROUP(msiof3_sync_d), - SH_PFC_PIN_GROUP(msiof3_ss1_d), - SH_PFC_PIN_GROUP(msiof3_txd_d), - SH_PFC_PIN_GROUP(msiof3_rxd_d), - SH_PFC_PIN_GROUP(msiof3_clk_e), - SH_PFC_PIN_GROUP(msiof3_sync_e), - SH_PFC_PIN_GROUP(msiof3_ss1_e), - SH_PFC_PIN_GROUP(msiof3_ss2_e), - SH_PFC_PIN_GROUP(msiof3_txd_e), - SH_PFC_PIN_GROUP(msiof3_rxd_e), - SH_PFC_PIN_GROUP(pwm0), - SH_PFC_PIN_GROUP(pwm1_a), - SH_PFC_PIN_GROUP(pwm1_b), - SH_PFC_PIN_GROUP(pwm2_a), - SH_PFC_PIN_GROUP(pwm2_b), - SH_PFC_PIN_GROUP(pwm3_a), - SH_PFC_PIN_GROUP(pwm3_b), - SH_PFC_PIN_GROUP(pwm4_a), - SH_PFC_PIN_GROUP(pwm4_b), - SH_PFC_PIN_GROUP(pwm5_a), - SH_PFC_PIN_GROUP(pwm5_b), - SH_PFC_PIN_GROUP(pwm6_a), - SH_PFC_PIN_GROUP(pwm6_b), - SH_PFC_PIN_GROUP(sata0_devslp_a), - SH_PFC_PIN_GROUP(sata0_devslp_b), - SH_PFC_PIN_GROUP(scif0_data), - SH_PFC_PIN_GROUP(scif0_clk), - SH_PFC_PIN_GROUP(scif0_ctrl), - SH_PFC_PIN_GROUP(scif1_data_a), - SH_PFC_PIN_GROUP(scif1_clk), - SH_PFC_PIN_GROUP(scif1_ctrl), - SH_PFC_PIN_GROUP(scif1_data_b), - SH_PFC_PIN_GROUP(scif2_data_a), - SH_PFC_PIN_GROUP(scif2_clk), - SH_PFC_PIN_GROUP(scif2_data_b), - SH_PFC_PIN_GROUP(scif3_data_a), - SH_PFC_PIN_GROUP(scif3_clk), - SH_PFC_PIN_GROUP(scif3_ctrl), - SH_PFC_PIN_GROUP(scif3_data_b), - SH_PFC_PIN_GROUP(scif4_data_a), - SH_PFC_PIN_GROUP(scif4_clk_a), - SH_PFC_PIN_GROUP(scif4_ctrl_a), - SH_PFC_PIN_GROUP(scif4_data_b), - SH_PFC_PIN_GROUP(scif4_clk_b), - SH_PFC_PIN_GROUP(scif4_ctrl_b), - SH_PFC_PIN_GROUP(scif4_data_c), - SH_PFC_PIN_GROUP(scif4_clk_c), - SH_PFC_PIN_GROUP(scif4_ctrl_c), - SH_PFC_PIN_GROUP(scif5_data_a), - SH_PFC_PIN_GROUP(scif5_clk_a), - SH_PFC_PIN_GROUP(scif5_data_b), - SH_PFC_PIN_GROUP(scif5_clk_b), - SH_PFC_PIN_GROUP(scif_clk_a), - SH_PFC_PIN_GROUP(scif_clk_b), - SH_PFC_PIN_GROUP(sdhi0_data1), - SH_PFC_PIN_GROUP(sdhi0_data4), - SH_PFC_PIN_GROUP(sdhi0_ctrl), - SH_PFC_PIN_GROUP(sdhi0_cd), - SH_PFC_PIN_GROUP(sdhi0_wp), - SH_PFC_PIN_GROUP(sdhi1_data1), - SH_PFC_PIN_GROUP(sdhi1_data4), - SH_PFC_PIN_GROUP(sdhi1_ctrl), - SH_PFC_PIN_GROUP(sdhi1_cd), - SH_PFC_PIN_GROUP(sdhi1_wp), - SH_PFC_PIN_GROUP(sdhi2_data1), - SH_PFC_PIN_GROUP(sdhi2_data4), - SH_PFC_PIN_GROUP(sdhi2_data8), - SH_PFC_PIN_GROUP(sdhi2_ctrl), - SH_PFC_PIN_GROUP(sdhi2_cd_a), - SH_PFC_PIN_GROUP(sdhi2_wp_a), - SH_PFC_PIN_GROUP(sdhi2_cd_b), - SH_PFC_PIN_GROUP(sdhi2_wp_b), - SH_PFC_PIN_GROUP(sdhi2_ds), - SH_PFC_PIN_GROUP(sdhi3_data1), - SH_PFC_PIN_GROUP(sdhi3_data4), - SH_PFC_PIN_GROUP(sdhi3_data8), - SH_PFC_PIN_GROUP(sdhi3_ctrl), - SH_PFC_PIN_GROUP(sdhi3_cd), - SH_PFC_PIN_GROUP(sdhi3_wp), - SH_PFC_PIN_GROUP(sdhi3_ds), - SH_PFC_PIN_GROUP(ssi0_data), - SH_PFC_PIN_GROUP(ssi01239_ctrl), - SH_PFC_PIN_GROUP(ssi1_data_a), - SH_PFC_PIN_GROUP(ssi1_data_b), - SH_PFC_PIN_GROUP(ssi1_ctrl_a), - SH_PFC_PIN_GROUP(ssi1_ctrl_b), - SH_PFC_PIN_GROUP(ssi2_data_a), - SH_PFC_PIN_GROUP(ssi2_data_b), - SH_PFC_PIN_GROUP(ssi2_ctrl_a), - SH_PFC_PIN_GROUP(ssi2_ctrl_b), - SH_PFC_PIN_GROUP(ssi3_data), - SH_PFC_PIN_GROUP(ssi349_ctrl), - SH_PFC_PIN_GROUP(ssi4_data), - SH_PFC_PIN_GROUP(ssi4_ctrl), - SH_PFC_PIN_GROUP(ssi5_data), - SH_PFC_PIN_GROUP(ssi5_ctrl), - SH_PFC_PIN_GROUP(ssi6_data), - SH_PFC_PIN_GROUP(ssi6_ctrl), - SH_PFC_PIN_GROUP(ssi7_data), - SH_PFC_PIN_GROUP(ssi78_ctrl), - SH_PFC_PIN_GROUP(ssi8_data), - SH_PFC_PIN_GROUP(ssi9_data_a), - SH_PFC_PIN_GROUP(ssi9_data_b), - SH_PFC_PIN_GROUP(ssi9_ctrl_a), - SH_PFC_PIN_GROUP(ssi9_ctrl_b), - SH_PFC_PIN_GROUP(tmu_tclk1_a), - SH_PFC_PIN_GROUP(tmu_tclk1_b), - SH_PFC_PIN_GROUP(tmu_tclk2_a), - SH_PFC_PIN_GROUP(tmu_tclk2_b), - SH_PFC_PIN_GROUP(usb0), - SH_PFC_PIN_GROUP(usb1), - SH_PFC_PIN_GROUP(usb2), - SH_PFC_PIN_GROUP(usb2_ch3), - SH_PFC_PIN_GROUP(usb30), - VIN_DATA_PIN_GROUP(vin4_data, 8, _a), - VIN_DATA_PIN_GROUP(vin4_data, 10, _a), - VIN_DATA_PIN_GROUP(vin4_data, 12, _a), - VIN_DATA_PIN_GROUP(vin4_data, 16, _a), - SH_PFC_PIN_GROUP(vin4_data18_a), - VIN_DATA_PIN_GROUP(vin4_data, 20, _a), - VIN_DATA_PIN_GROUP(vin4_data, 24, _a), - VIN_DATA_PIN_GROUP(vin4_data, 8, _b), - VIN_DATA_PIN_GROUP(vin4_data, 10, _b), - VIN_DATA_PIN_GROUP(vin4_data, 12, _b), - VIN_DATA_PIN_GROUP(vin4_data, 16, _b), - SH_PFC_PIN_GROUP(vin4_data18_b), - VIN_DATA_PIN_GROUP(vin4_data, 20, _b), - VIN_DATA_PIN_GROUP(vin4_data, 24, _b), - SH_PFC_PIN_GROUP(vin4_sync), - SH_PFC_PIN_GROUP(vin4_field), - SH_PFC_PIN_GROUP(vin4_clkenb), - SH_PFC_PIN_GROUP(vin4_clk), - VIN_DATA_PIN_GROUP(vin5_data, 8), - VIN_DATA_PIN_GROUP(vin5_data, 10), - VIN_DATA_PIN_GROUP(vin5_data, 12), - VIN_DATA_PIN_GROUP(vin5_data, 16), - SH_PFC_PIN_GROUP(vin5_sync), - SH_PFC_PIN_GROUP(vin5_field), - SH_PFC_PIN_GROUP(vin5_clkenb), - SH_PFC_PIN_GROUP(vin5_clk), +static const struct { + struct sh_pfc_pin_group common[320]; + struct sh_pfc_pin_group automotive[30]; +} pinmux_groups = { + .common = { + SH_PFC_PIN_GROUP(audio_clk_a_a), + SH_PFC_PIN_GROUP(audio_clk_a_b), + SH_PFC_PIN_GROUP(audio_clk_a_c), + SH_PFC_PIN_GROUP(audio_clk_b_a), + SH_PFC_PIN_GROUP(audio_clk_b_b), + SH_PFC_PIN_GROUP(audio_clk_c_a), + SH_PFC_PIN_GROUP(audio_clk_c_b), + SH_PFC_PIN_GROUP(audio_clkout_a), + SH_PFC_PIN_GROUP(audio_clkout_b), + SH_PFC_PIN_GROUP(audio_clkout_c), + SH_PFC_PIN_GROUP(audio_clkout_d), + SH_PFC_PIN_GROUP(audio_clkout1_a), + SH_PFC_PIN_GROUP(audio_clkout1_b), + SH_PFC_PIN_GROUP(audio_clkout2_a), + SH_PFC_PIN_GROUP(audio_clkout2_b), + SH_PFC_PIN_GROUP(audio_clkout3_a), + SH_PFC_PIN_GROUP(audio_clkout3_b), + SH_PFC_PIN_GROUP(avb_link), + SH_PFC_PIN_GROUP(avb_magic), + SH_PFC_PIN_GROUP(avb_phy_int), + SH_PFC_PIN_GROUP_ALIAS(avb_mdc, avb_mdio), /* Deprecated */ + SH_PFC_PIN_GROUP(avb_mdio), + SH_PFC_PIN_GROUP(avb_mii), + SH_PFC_PIN_GROUP(avb_avtp_pps), + SH_PFC_PIN_GROUP(avb_avtp_match_a), + SH_PFC_PIN_GROUP(avb_avtp_capture_a), + SH_PFC_PIN_GROUP(avb_avtp_match_b), + SH_PFC_PIN_GROUP(avb_avtp_capture_b), + SH_PFC_PIN_GROUP(can0_data_a), + SH_PFC_PIN_GROUP(can0_data_b), + SH_PFC_PIN_GROUP(can1_data), + SH_PFC_PIN_GROUP(can_clk), + SH_PFC_PIN_GROUP(canfd0_data_a), + SH_PFC_PIN_GROUP(canfd0_data_b), + SH_PFC_PIN_GROUP(canfd1_data), + SH_PFC_PIN_GROUP(du_rgb666), + SH_PFC_PIN_GROUP(du_rgb888), + SH_PFC_PIN_GROUP(du_clk_out_0), + SH_PFC_PIN_GROUP(du_clk_out_1), + SH_PFC_PIN_GROUP(du_sync), + SH_PFC_PIN_GROUP(du_oddf), + SH_PFC_PIN_GROUP(du_cde), + SH_PFC_PIN_GROUP(du_disp), + SH_PFC_PIN_GROUP(hscif0_data), + SH_PFC_PIN_GROUP(hscif0_clk), + SH_PFC_PIN_GROUP(hscif0_ctrl), + SH_PFC_PIN_GROUP(hscif1_data_a), + SH_PFC_PIN_GROUP(hscif1_clk_a), + SH_PFC_PIN_GROUP(hscif1_ctrl_a), + SH_PFC_PIN_GROUP(hscif1_data_b), + SH_PFC_PIN_GROUP(hscif1_clk_b), + SH_PFC_PIN_GROUP(hscif1_ctrl_b), + SH_PFC_PIN_GROUP(hscif2_data_a), + SH_PFC_PIN_GROUP(hscif2_clk_a), + SH_PFC_PIN_GROUP(hscif2_ctrl_a), + SH_PFC_PIN_GROUP(hscif2_data_b), + SH_PFC_PIN_GROUP(hscif2_clk_b), + SH_PFC_PIN_GROUP(hscif2_ctrl_b), + SH_PFC_PIN_GROUP(hscif2_data_c), + SH_PFC_PIN_GROUP(hscif2_clk_c), + SH_PFC_PIN_GROUP(hscif2_ctrl_c), + SH_PFC_PIN_GROUP(hscif3_data_a), + SH_PFC_PIN_GROUP(hscif3_clk), + SH_PFC_PIN_GROUP(hscif3_ctrl), + SH_PFC_PIN_GROUP(hscif3_data_b), + SH_PFC_PIN_GROUP(hscif3_data_c), + SH_PFC_PIN_GROUP(hscif3_data_d), + SH_PFC_PIN_GROUP(hscif4_data_a), + SH_PFC_PIN_GROUP(hscif4_clk), + SH_PFC_PIN_GROUP(hscif4_ctrl), + SH_PFC_PIN_GROUP(hscif4_data_b), + SH_PFC_PIN_GROUP(i2c0), + SH_PFC_PIN_GROUP(i2c1_a), + SH_PFC_PIN_GROUP(i2c1_b), + SH_PFC_PIN_GROUP(i2c2_a), + SH_PFC_PIN_GROUP(i2c2_b), + SH_PFC_PIN_GROUP(i2c3), + SH_PFC_PIN_GROUP(i2c5), + SH_PFC_PIN_GROUP(i2c6_a), + SH_PFC_PIN_GROUP(i2c6_b), + SH_PFC_PIN_GROUP(i2c6_c), + SH_PFC_PIN_GROUP(intc_ex_irq0), + SH_PFC_PIN_GROUP(intc_ex_irq1), + SH_PFC_PIN_GROUP(intc_ex_irq2), + SH_PFC_PIN_GROUP(intc_ex_irq3), + SH_PFC_PIN_GROUP(intc_ex_irq4), + SH_PFC_PIN_GROUP(intc_ex_irq5), + SH_PFC_PIN_GROUP(msiof0_clk), + SH_PFC_PIN_GROUP(msiof0_sync), + SH_PFC_PIN_GROUP(msiof0_ss1), + SH_PFC_PIN_GROUP(msiof0_ss2), + SH_PFC_PIN_GROUP(msiof0_txd), + SH_PFC_PIN_GROUP(msiof0_rxd), + SH_PFC_PIN_GROUP(msiof1_clk_a), + SH_PFC_PIN_GROUP(msiof1_sync_a), + SH_PFC_PIN_GROUP(msiof1_ss1_a), + SH_PFC_PIN_GROUP(msiof1_ss2_a), + SH_PFC_PIN_GROUP(msiof1_txd_a), + SH_PFC_PIN_GROUP(msiof1_rxd_a), + SH_PFC_PIN_GROUP(msiof1_clk_b), + SH_PFC_PIN_GROUP(msiof1_sync_b), + SH_PFC_PIN_GROUP(msiof1_ss1_b), + SH_PFC_PIN_GROUP(msiof1_ss2_b), + SH_PFC_PIN_GROUP(msiof1_txd_b), + SH_PFC_PIN_GROUP(msiof1_rxd_b), + SH_PFC_PIN_GROUP(msiof1_clk_c), + SH_PFC_PIN_GROUP(msiof1_sync_c), + SH_PFC_PIN_GROUP(msiof1_ss1_c), + SH_PFC_PIN_GROUP(msiof1_ss2_c), + SH_PFC_PIN_GROUP(msiof1_txd_c), + SH_PFC_PIN_GROUP(msiof1_rxd_c), + SH_PFC_PIN_GROUP(msiof1_clk_d), + SH_PFC_PIN_GROUP(msiof1_sync_d), + SH_PFC_PIN_GROUP(msiof1_ss1_d), + SH_PFC_PIN_GROUP(msiof1_ss2_d), + SH_PFC_PIN_GROUP(msiof1_txd_d), + SH_PFC_PIN_GROUP(msiof1_rxd_d), + SH_PFC_PIN_GROUP(msiof1_clk_e), + SH_PFC_PIN_GROUP(msiof1_sync_e), + SH_PFC_PIN_GROUP(msiof1_ss1_e), + SH_PFC_PIN_GROUP(msiof1_ss2_e), + SH_PFC_PIN_GROUP(msiof1_txd_e), + SH_PFC_PIN_GROUP(msiof1_rxd_e), + SH_PFC_PIN_GROUP(msiof1_clk_f), + SH_PFC_PIN_GROUP(msiof1_sync_f), + SH_PFC_PIN_GROUP(msiof1_ss1_f), + SH_PFC_PIN_GROUP(msiof1_ss2_f), + SH_PFC_PIN_GROUP(msiof1_txd_f), + SH_PFC_PIN_GROUP(msiof1_rxd_f), + SH_PFC_PIN_GROUP(msiof1_clk_g), + SH_PFC_PIN_GROUP(msiof1_sync_g), + SH_PFC_PIN_GROUP(msiof1_ss1_g), + SH_PFC_PIN_GROUP(msiof1_ss2_g), + SH_PFC_PIN_GROUP(msiof1_txd_g), + SH_PFC_PIN_GROUP(msiof1_rxd_g), + SH_PFC_PIN_GROUP(msiof2_clk_a), + SH_PFC_PIN_GROUP(msiof2_sync_a), + SH_PFC_PIN_GROUP(msiof2_ss1_a), + SH_PFC_PIN_GROUP(msiof2_ss2_a), + SH_PFC_PIN_GROUP(msiof2_txd_a), + SH_PFC_PIN_GROUP(msiof2_rxd_a), + SH_PFC_PIN_GROUP(msiof2_clk_b), + SH_PFC_PIN_GROUP(msiof2_sync_b), + SH_PFC_PIN_GROUP(msiof2_ss1_b), + SH_PFC_PIN_GROUP(msiof2_ss2_b), + SH_PFC_PIN_GROUP(msiof2_txd_b), + SH_PFC_PIN_GROUP(msiof2_rxd_b), + SH_PFC_PIN_GROUP(msiof2_clk_c), + SH_PFC_PIN_GROUP(msiof2_sync_c), + SH_PFC_PIN_GROUP(msiof2_ss1_c), + SH_PFC_PIN_GROUP(msiof2_ss2_c), + SH_PFC_PIN_GROUP(msiof2_txd_c), + SH_PFC_PIN_GROUP(msiof2_rxd_c), + SH_PFC_PIN_GROUP(msiof2_clk_d), + SH_PFC_PIN_GROUP(msiof2_sync_d), + SH_PFC_PIN_GROUP(msiof2_ss1_d), + SH_PFC_PIN_GROUP(msiof2_ss2_d), + SH_PFC_PIN_GROUP(msiof2_txd_d), + SH_PFC_PIN_GROUP(msiof2_rxd_d), + SH_PFC_PIN_GROUP(msiof3_clk_a), + SH_PFC_PIN_GROUP(msiof3_sync_a), + SH_PFC_PIN_GROUP(msiof3_ss1_a), + SH_PFC_PIN_GROUP(msiof3_ss2_a), + SH_PFC_PIN_GROUP(msiof3_txd_a), + SH_PFC_PIN_GROUP(msiof3_rxd_a), + SH_PFC_PIN_GROUP(msiof3_clk_b), + SH_PFC_PIN_GROUP(msiof3_sync_b), + SH_PFC_PIN_GROUP(msiof3_ss1_b), + SH_PFC_PIN_GROUP(msiof3_ss2_b), + SH_PFC_PIN_GROUP(msiof3_txd_b), + SH_PFC_PIN_GROUP(msiof3_rxd_b), + SH_PFC_PIN_GROUP(msiof3_clk_c), + SH_PFC_PIN_GROUP(msiof3_sync_c), + SH_PFC_PIN_GROUP(msiof3_txd_c), + SH_PFC_PIN_GROUP(msiof3_rxd_c), + SH_PFC_PIN_GROUP(msiof3_clk_d), + SH_PFC_PIN_GROUP(msiof3_sync_d), + SH_PFC_PIN_GROUP(msiof3_ss1_d), + SH_PFC_PIN_GROUP(msiof3_txd_d), + SH_PFC_PIN_GROUP(msiof3_rxd_d), + SH_PFC_PIN_GROUP(msiof3_clk_e), + SH_PFC_PIN_GROUP(msiof3_sync_e), + SH_PFC_PIN_GROUP(msiof3_ss1_e), + SH_PFC_PIN_GROUP(msiof3_ss2_e), + SH_PFC_PIN_GROUP(msiof3_txd_e), + SH_PFC_PIN_GROUP(msiof3_rxd_e), + SH_PFC_PIN_GROUP(pwm0), + SH_PFC_PIN_GROUP(pwm1_a), + SH_PFC_PIN_GROUP(pwm1_b), + SH_PFC_PIN_GROUP(pwm2_a), + SH_PFC_PIN_GROUP(pwm2_b), + SH_PFC_PIN_GROUP(pwm3_a), + SH_PFC_PIN_GROUP(pwm3_b), + SH_PFC_PIN_GROUP(pwm4_a), + SH_PFC_PIN_GROUP(pwm4_b), + SH_PFC_PIN_GROUP(pwm5_a), + SH_PFC_PIN_GROUP(pwm5_b), + SH_PFC_PIN_GROUP(pwm6_a), + SH_PFC_PIN_GROUP(pwm6_b), + SH_PFC_PIN_GROUP(sata0_devslp_a), + SH_PFC_PIN_GROUP(sata0_devslp_b), + SH_PFC_PIN_GROUP(scif0_data), + SH_PFC_PIN_GROUP(scif0_clk), + SH_PFC_PIN_GROUP(scif0_ctrl), + SH_PFC_PIN_GROUP(scif1_data_a), + SH_PFC_PIN_GROUP(scif1_clk), + SH_PFC_PIN_GROUP(scif1_ctrl), + SH_PFC_PIN_GROUP(scif1_data_b), + SH_PFC_PIN_GROUP(scif2_data_a), + SH_PFC_PIN_GROUP(scif2_clk), + SH_PFC_PIN_GROUP(scif2_data_b), + SH_PFC_PIN_GROUP(scif3_data_a), + SH_PFC_PIN_GROUP(scif3_clk), + SH_PFC_PIN_GROUP(scif3_ctrl), + SH_PFC_PIN_GROUP(scif3_data_b), + SH_PFC_PIN_GROUP(scif4_data_a), + SH_PFC_PIN_GROUP(scif4_clk_a), + SH_PFC_PIN_GROUP(scif4_ctrl_a), + SH_PFC_PIN_GROUP(scif4_data_b), + SH_PFC_PIN_GROUP(scif4_clk_b), + SH_PFC_PIN_GROUP(scif4_ctrl_b), + SH_PFC_PIN_GROUP(scif4_data_c), + SH_PFC_PIN_GROUP(scif4_clk_c), + SH_PFC_PIN_GROUP(scif4_ctrl_c), + SH_PFC_PIN_GROUP(scif5_data_a), + SH_PFC_PIN_GROUP(scif5_clk_a), + SH_PFC_PIN_GROUP(scif5_data_b), + SH_PFC_PIN_GROUP(scif5_clk_b), + SH_PFC_PIN_GROUP(scif_clk_a), + SH_PFC_PIN_GROUP(scif_clk_b), + SH_PFC_PIN_GROUP(sdhi0_data1), + SH_PFC_PIN_GROUP(sdhi0_data4), + SH_PFC_PIN_GROUP(sdhi0_ctrl), + SH_PFC_PIN_GROUP(sdhi0_cd), + SH_PFC_PIN_GROUP(sdhi0_wp), + SH_PFC_PIN_GROUP(sdhi1_data1), + SH_PFC_PIN_GROUP(sdhi1_data4), + SH_PFC_PIN_GROUP(sdhi1_ctrl), + SH_PFC_PIN_GROUP(sdhi1_cd), + SH_PFC_PIN_GROUP(sdhi1_wp), + SH_PFC_PIN_GROUP(sdhi2_data1), + SH_PFC_PIN_GROUP(sdhi2_data4), + SH_PFC_PIN_GROUP(sdhi2_data8), + SH_PFC_PIN_GROUP(sdhi2_ctrl), + SH_PFC_PIN_GROUP(sdhi2_cd_a), + SH_PFC_PIN_GROUP(sdhi2_wp_a), + SH_PFC_PIN_GROUP(sdhi2_cd_b), + SH_PFC_PIN_GROUP(sdhi2_wp_b), + SH_PFC_PIN_GROUP(sdhi2_ds), + SH_PFC_PIN_GROUP(sdhi3_data1), + SH_PFC_PIN_GROUP(sdhi3_data4), + SH_PFC_PIN_GROUP(sdhi3_data8), + SH_PFC_PIN_GROUP(sdhi3_ctrl), + SH_PFC_PIN_GROUP(sdhi3_cd), + SH_PFC_PIN_GROUP(sdhi3_wp), + SH_PFC_PIN_GROUP(sdhi3_ds), + SH_PFC_PIN_GROUP(ssi0_data), + SH_PFC_PIN_GROUP(ssi01239_ctrl), + SH_PFC_PIN_GROUP(ssi1_data_a), + SH_PFC_PIN_GROUP(ssi1_data_b), + SH_PFC_PIN_GROUP(ssi1_ctrl_a), + SH_PFC_PIN_GROUP(ssi1_ctrl_b), + SH_PFC_PIN_GROUP(ssi2_data_a), + SH_PFC_PIN_GROUP(ssi2_data_b), + SH_PFC_PIN_GROUP(ssi2_ctrl_a), + SH_PFC_PIN_GROUP(ssi2_ctrl_b), + SH_PFC_PIN_GROUP(ssi3_data), + SH_PFC_PIN_GROUP(ssi349_ctrl), + SH_PFC_PIN_GROUP(ssi4_data), + SH_PFC_PIN_GROUP(ssi4_ctrl), + SH_PFC_PIN_GROUP(ssi5_data), + SH_PFC_PIN_GROUP(ssi5_ctrl), + SH_PFC_PIN_GROUP(ssi6_data), + SH_PFC_PIN_GROUP(ssi6_ctrl), + SH_PFC_PIN_GROUP(ssi7_data), + SH_PFC_PIN_GROUP(ssi78_ctrl), + SH_PFC_PIN_GROUP(ssi8_data), + SH_PFC_PIN_GROUP(ssi9_data_a), + SH_PFC_PIN_GROUP(ssi9_data_b), + SH_PFC_PIN_GROUP(ssi9_ctrl_a), + SH_PFC_PIN_GROUP(ssi9_ctrl_b), + SH_PFC_PIN_GROUP(tmu_tclk1_a), + SH_PFC_PIN_GROUP(tmu_tclk1_b), + SH_PFC_PIN_GROUP(tmu_tclk2_a), + SH_PFC_PIN_GROUP(tmu_tclk2_b), + SH_PFC_PIN_GROUP(tpu_to0), + SH_PFC_PIN_GROUP(tpu_to1), + SH_PFC_PIN_GROUP(tpu_to2), + SH_PFC_PIN_GROUP(tpu_to3), + SH_PFC_PIN_GROUP(usb0), + SH_PFC_PIN_GROUP(usb1), + SH_PFC_PIN_GROUP(usb2), + SH_PFC_PIN_GROUP(usb2_ch3), + SH_PFC_PIN_GROUP(usb30), + VIN_DATA_PIN_GROUP(vin4_data, 8, _a), + VIN_DATA_PIN_GROUP(vin4_data, 10, _a), + VIN_DATA_PIN_GROUP(vin4_data, 12, _a), + VIN_DATA_PIN_GROUP(vin4_data, 16, _a), + SH_PFC_PIN_GROUP(vin4_data18_a), + VIN_DATA_PIN_GROUP(vin4_data, 20, _a), + VIN_DATA_PIN_GROUP(vin4_data, 24, _a), + VIN_DATA_PIN_GROUP(vin4_data, 8, _b), + VIN_DATA_PIN_GROUP(vin4_data, 10, _b), + VIN_DATA_PIN_GROUP(vin4_data, 12, _b), + VIN_DATA_PIN_GROUP(vin4_data, 16, _b), + SH_PFC_PIN_GROUP(vin4_data18_b), + VIN_DATA_PIN_GROUP(vin4_data, 20, _b), + VIN_DATA_PIN_GROUP(vin4_data, 24, _b), + SH_PFC_PIN_GROUP(vin4_sync), + SH_PFC_PIN_GROUP(vin4_field), + SH_PFC_PIN_GROUP(vin4_clkenb), + SH_PFC_PIN_GROUP(vin4_clk), + VIN_DATA_PIN_GROUP(vin5_data, 8), + VIN_DATA_PIN_GROUP(vin5_data, 10), + VIN_DATA_PIN_GROUP(vin5_data, 12), + VIN_DATA_PIN_GROUP(vin5_data, 16), + SH_PFC_PIN_GROUP(vin5_sync), + SH_PFC_PIN_GROUP(vin5_field), + SH_PFC_PIN_GROUP(vin5_clkenb), + SH_PFC_PIN_GROUP(vin5_clk), + }, + .automotive = { + SH_PFC_PIN_GROUP(drif0_ctrl_a), + SH_PFC_PIN_GROUP(drif0_data0_a), + SH_PFC_PIN_GROUP(drif0_data1_a), + SH_PFC_PIN_GROUP(drif0_ctrl_b), + SH_PFC_PIN_GROUP(drif0_data0_b), + SH_PFC_PIN_GROUP(drif0_data1_b), + SH_PFC_PIN_GROUP(drif0_ctrl_c), + SH_PFC_PIN_GROUP(drif0_data0_c), + SH_PFC_PIN_GROUP(drif0_data1_c), + SH_PFC_PIN_GROUP(drif1_ctrl_a), + SH_PFC_PIN_GROUP(drif1_data0_a), + SH_PFC_PIN_GROUP(drif1_data1_a), + SH_PFC_PIN_GROUP(drif1_ctrl_b), + SH_PFC_PIN_GROUP(drif1_data0_b), + SH_PFC_PIN_GROUP(drif1_data1_b), + SH_PFC_PIN_GROUP(drif1_ctrl_c), + SH_PFC_PIN_GROUP(drif1_data0_c), + SH_PFC_PIN_GROUP(drif1_data1_c), + SH_PFC_PIN_GROUP(drif2_ctrl_a), + SH_PFC_PIN_GROUP(drif2_data0_a), + SH_PFC_PIN_GROUP(drif2_data1_a), + SH_PFC_PIN_GROUP(drif2_ctrl_b), + SH_PFC_PIN_GROUP(drif2_data0_b), + SH_PFC_PIN_GROUP(drif2_data1_b), + SH_PFC_PIN_GROUP(drif3_ctrl_a), + SH_PFC_PIN_GROUP(drif3_data0_a), + SH_PFC_PIN_GROUP(drif3_data1_a), + SH_PFC_PIN_GROUP(drif3_ctrl_b), + SH_PFC_PIN_GROUP(drif3_data0_b), + SH_PFC_PIN_GROUP(drif3_data1_b), + } + };
static const char * const audio_clk_groups[] = { @@ -4947,6 +4989,13 @@ static const char * const tmu_groups[] = { "tmu_tclk2_b", };
+static const char * const tpu_groups[] = { + "tpu_to0", + "tpu_to1", + "tpu_to2", + "tpu_to3", +}; + static const char * const usb0_groups[] = { "usb0", }; @@ -4999,63 +5048,72 @@ static const char * const vin5_groups[] = { "vin5_clk", };
-static const struct sh_pfc_function pinmux_functions[] = { - SH_PFC_FUNCTION(audio_clk), - SH_PFC_FUNCTION(avb), - SH_PFC_FUNCTION(can0), - SH_PFC_FUNCTION(can1), - SH_PFC_FUNCTION(can_clk), - SH_PFC_FUNCTION(canfd0), - SH_PFC_FUNCTION(canfd1), - SH_PFC_FUNCTION(drif0), - SH_PFC_FUNCTION(drif1), - SH_PFC_FUNCTION(drif2), - SH_PFC_FUNCTION(drif3), - SH_PFC_FUNCTION(du), - SH_PFC_FUNCTION(hscif0), - SH_PFC_FUNCTION(hscif1), - SH_PFC_FUNCTION(hscif2), - SH_PFC_FUNCTION(hscif3), - SH_PFC_FUNCTION(hscif4), - SH_PFC_FUNCTION(i2c0), - SH_PFC_FUNCTION(i2c1), - SH_PFC_FUNCTION(i2c2), - SH_PFC_FUNCTION(i2c3), - SH_PFC_FUNCTION(i2c5), - SH_PFC_FUNCTION(i2c6), - SH_PFC_FUNCTION(intc_ex), - SH_PFC_FUNCTION(msiof0), - SH_PFC_FUNCTION(msiof1), - SH_PFC_FUNCTION(msiof2), - SH_PFC_FUNCTION(msiof3), - SH_PFC_FUNCTION(pwm0), - SH_PFC_FUNCTION(pwm1), - SH_PFC_FUNCTION(pwm2), - SH_PFC_FUNCTION(pwm3), - SH_PFC_FUNCTION(pwm4), - SH_PFC_FUNCTION(pwm5), - SH_PFC_FUNCTION(pwm6), - SH_PFC_FUNCTION(sata0), - SH_PFC_FUNCTION(scif0), - SH_PFC_FUNCTION(scif1), - SH_PFC_FUNCTION(scif2), - SH_PFC_FUNCTION(scif3), - SH_PFC_FUNCTION(scif4), - SH_PFC_FUNCTION(scif5), - SH_PFC_FUNCTION(scif_clk), - SH_PFC_FUNCTION(sdhi0), - SH_PFC_FUNCTION(sdhi1), - SH_PFC_FUNCTION(sdhi2), - SH_PFC_FUNCTION(sdhi3), - SH_PFC_FUNCTION(ssi), - SH_PFC_FUNCTION(tmu), - SH_PFC_FUNCTION(usb0), - SH_PFC_FUNCTION(usb1), - SH_PFC_FUNCTION(usb2), - SH_PFC_FUNCTION(usb2_ch3), - SH_PFC_FUNCTION(usb30), - SH_PFC_FUNCTION(vin4), - SH_PFC_FUNCTION(vin5), +static const struct { + struct sh_pfc_function common[53]; + struct sh_pfc_function automotive[4]; +} pinmux_functions = { + .common = { + SH_PFC_FUNCTION(audio_clk), + SH_PFC_FUNCTION(avb), + SH_PFC_FUNCTION(can0), + SH_PFC_FUNCTION(can1), + SH_PFC_FUNCTION(can_clk), + SH_PFC_FUNCTION(canfd0), + SH_PFC_FUNCTION(canfd1), + SH_PFC_FUNCTION(du), + SH_PFC_FUNCTION(hscif0), + SH_PFC_FUNCTION(hscif1), + SH_PFC_FUNCTION(hscif2), + SH_PFC_FUNCTION(hscif3), + SH_PFC_FUNCTION(hscif4), + SH_PFC_FUNCTION(i2c0), + SH_PFC_FUNCTION(i2c1), + SH_PFC_FUNCTION(i2c2), + SH_PFC_FUNCTION(i2c3), + SH_PFC_FUNCTION(i2c5), + SH_PFC_FUNCTION(i2c6), + SH_PFC_FUNCTION(intc_ex), + SH_PFC_FUNCTION(msiof0), + SH_PFC_FUNCTION(msiof1), + SH_PFC_FUNCTION(msiof2), + SH_PFC_FUNCTION(msiof3), + SH_PFC_FUNCTION(pwm0), + SH_PFC_FUNCTION(pwm1), + SH_PFC_FUNCTION(pwm2), + SH_PFC_FUNCTION(pwm3), + SH_PFC_FUNCTION(pwm4), + SH_PFC_FUNCTION(pwm5), + SH_PFC_FUNCTION(pwm6), + SH_PFC_FUNCTION(sata0), + SH_PFC_FUNCTION(scif0), + SH_PFC_FUNCTION(scif1), + SH_PFC_FUNCTION(scif2), + SH_PFC_FUNCTION(scif3), + SH_PFC_FUNCTION(scif4), + SH_PFC_FUNCTION(scif5), + SH_PFC_FUNCTION(scif_clk), + SH_PFC_FUNCTION(sdhi0), + SH_PFC_FUNCTION(sdhi1), + SH_PFC_FUNCTION(sdhi2), + SH_PFC_FUNCTION(sdhi3), + SH_PFC_FUNCTION(ssi), + SH_PFC_FUNCTION(tmu), + SH_PFC_FUNCTION(tpu), + SH_PFC_FUNCTION(usb0), + SH_PFC_FUNCTION(usb1), + SH_PFC_FUNCTION(usb2), + SH_PFC_FUNCTION(usb2_ch3), + SH_PFC_FUNCTION(usb30), + SH_PFC_FUNCTION(vin4), + SH_PFC_FUNCTION(vin5), + }, + .automotive = { + SH_PFC_FUNCTION(drif0), + SH_PFC_FUNCTION(drif1), + SH_PFC_FUNCTION(drif2), + SH_PFC_FUNCTION(drif3), + } + };
static const struct pinmux_cfg_reg pinmux_config_regs[] = { @@ -6186,6 +6244,32 @@ static const struct sh_pfc_soc_operations r8a7795_pinmux_ops = { .set_bias = r8a7795_pinmux_set_bias, };
+#ifdef CONFIG_PINCTRL_PFC_R8A774E1 +const struct sh_pfc_soc_info r8a774e1_pinmux_info = { + .name = "r8a774e1_pfc", + .ops = &r8a7795_pinmux_ops, + .unlock_reg = 0xe6060000, /* PMMR */ + + .function = { PINMUX_FUNCTION_BEGIN, PINMUX_FUNCTION_END }, + + .pins = pinmux_pins, + .nr_pins = ARRAY_SIZE(pinmux_pins), + .groups = pinmux_groups.common, + .nr_groups = ARRAY_SIZE(pinmux_groups.common), + .functions = pinmux_functions.common, + .nr_functions = ARRAY_SIZE(pinmux_functions.common), + + .cfg_regs = pinmux_config_regs, + .drive_regs = pinmux_drive_regs, + .bias_regs = pinmux_bias_regs, + .ioctrl_regs = pinmux_ioctrl_regs, + + .pinmux_data = pinmux_data, + .pinmux_data_size = ARRAY_SIZE(pinmux_data), +}; +#endif + +#ifdef CONFIG_PINCTRL_PFC_R8A7795 const struct sh_pfc_soc_info r8a7795_pinmux_info = { .name = "r8a77951_pfc", .ops = &r8a7795_pinmux_ops, @@ -6195,10 +6279,12 @@ const struct sh_pfc_soc_info r8a7795_pinmux_info = {
.pins = pinmux_pins, .nr_pins = ARRAY_SIZE(pinmux_pins), - .groups = pinmux_groups, - .nr_groups = ARRAY_SIZE(pinmux_groups), - .functions = pinmux_functions, - .nr_functions = ARRAY_SIZE(pinmux_functions), + .groups = pinmux_groups.common, + .nr_groups = ARRAY_SIZE(pinmux_groups.common) + + ARRAY_SIZE(pinmux_groups.automotive), + .functions = pinmux_functions.common, + .nr_functions = ARRAY_SIZE(pinmux_functions.common) + + ARRAY_SIZE(pinmux_functions.automotive),
.cfg_regs = pinmux_config_regs, .drive_regs = pinmux_drive_regs, @@ -6208,3 +6294,4 @@ const struct sh_pfc_soc_info r8a7795_pinmux_info = { .pinmux_data = pinmux_data, .pinmux_data_size = ARRAY_SIZE(pinmux_data), }; +#endif diff --git a/drivers/pinctrl/renesas/pfc.c b/drivers/pinctrl/renesas/pfc.c index 568ed3e7df..db0fa9b728 100644 --- a/drivers/pinctrl/renesas/pfc.c +++ b/drivers/pinctrl/renesas/pfc.c @@ -34,6 +34,7 @@ enum sh_pfc_model { SH_PFC_R8A7796, SH_PFC_R8A774A1, SH_PFC_R8A774B1, + SH_PFC_R8A774E1, SH_PFC_R8A77965, SH_PFC_R8A77970, SH_PFC_R8A77980, @@ -863,6 +864,10 @@ static int sh_pfc_pinctrl_probe(struct udevice *dev) if (model == SH_PFC_R8A774B1) priv->pfc.info = &r8a774b1_pinmux_info; #endif +#ifdef CONFIG_PINCTRL_PFC_R8A774E1 + if (model == SH_PFC_R8A774E1) + priv->pfc.info = &r8a774e1_pinmux_info; +#endif #ifdef CONFIG_PINCTRL_PFC_R8A77965 if (model == SH_PFC_R8A77965) priv->pfc.info = &r8a77965_pinmux_info; @@ -946,6 +951,12 @@ static const struct udevice_id sh_pfc_pinctrl_ids[] = { .data = SH_PFC_R8A774B1, }, #endif +#ifdef CONFIG_PINCTRL_PFC_R8A774E1 + { + .compatible = "renesas,pfc-r8a774e1", + .data = SH_PFC_R8A774E1, + }, +#endif #ifdef CONFIG_PINCTRL_PFC_R8A77965 { .compatible = "renesas,pfc-r8a77965", diff --git a/drivers/pinctrl/renesas/sh_pfc.h b/drivers/pinctrl/renesas/sh_pfc.h index f5cf31d26f..22cc860f29 100644 --- a/drivers/pinctrl/renesas/sh_pfc.h +++ b/drivers/pinctrl/renesas/sh_pfc.h @@ -295,6 +295,7 @@ sh_pfc_pin_to_bias_reg(const struct sh_pfc *pfc, unsigned int pin,
extern const struct sh_pfc_soc_info r8a774a1_pinmux_info; extern const struct sh_pfc_soc_info r8a774b1_pinmux_info; +extern const struct sh_pfc_soc_info r8a774e1_pinmux_info; extern const struct sh_pfc_soc_info r8a7790_pinmux_info; extern const struct sh_pfc_soc_info r8a7791_pinmux_info; extern const struct sh_pfc_soc_info r8a7792_pinmux_info;
The HiHope RZ/G2H board from HopeRun consists of main board (HopeRun HiHope RZ/G2H main board) and sub board(HopeRun HiHope RZ/G2H sub board). The HiHope RZ/G2H sub board sits below the HiHope RZ/G2H main board.
DTS files apart from r8a774e1-hihope-rzg2h-u-boot.dts and r8a774e1-u-boot.dtsi have been imported from Linux kernel 5.9-rc4 commit f4d51dffc6c0 ("Linux 5.9-rc4").
This patch adds the required board support to boot HopeRun HiHope RZ/G2H board.
Signed-off-by: Biju Das biju.das.jz@bp.renesas.com Reviewed-by: Lad Prabhakar prabhakar.mahadev-lad.rj@bp.renesas.com --- arch/arm/dts/Makefile | 1 + arch/arm/dts/r8a774e1-hihope-rzg2h-ex.dts | 15 +++++++++++ arch/arm/dts/r8a774e1-hihope-rzg2h-u-boot.dts | 9 +++++++ arch/arm/dts/r8a774e1-hihope-rzg2h.dts | 26 +++++++++++++++++++ arch/arm/dts/r8a774e1-u-boot.dtsi | 25 ++++++++++++++++++ arch/arm/mach-rmobile/Kconfig.64 | 1 + board/hoperun/hihope-rzg2/hihope-rzg2.c | 6 ++++- configs/hihope_rzg2_defconfig | 2 +- 8 files changed, 83 insertions(+), 2 deletions(-) create mode 100644 arch/arm/dts/r8a774e1-hihope-rzg2h-ex.dts create mode 100644 arch/arm/dts/r8a774e1-hihope-rzg2h-u-boot.dts create mode 100644 arch/arm/dts/r8a774e1-hihope-rzg2h.dts create mode 100644 arch/arm/dts/r8a774e1-u-boot.dtsi
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 75a23020ef..2f1b80f10c 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -786,6 +786,7 @@ dtb-$(CONFIG_RCAR_GEN3) += \ r8a774a1-beacon-rzg2m-kit.dtb \ r8a774a1-hihope-rzg2m-u-boot.dtb \ r8a774b1-hihope-rzg2n-u-boot.dtb \ + r8a774e1-hihope-rzg2h-u-boot.dtb \ r8a77950-ulcb-u-boot.dtb \ r8a77950-salvator-x-u-boot.dtb \ r8a77960-ulcb-u-boot.dtb \ diff --git a/arch/arm/dts/r8a774e1-hihope-rzg2h-ex.dts b/arch/arm/dts/r8a774e1-hihope-rzg2h-ex.dts new file mode 100644 index 0000000000..265355e0de --- /dev/null +++ b/arch/arm/dts/r8a774e1-hihope-rzg2h-ex.dts @@ -0,0 +1,15 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Device Tree Source for the HiHope RZ/G2H sub board + * + * Copyright (C) 2020 Renesas Electronics Corp. + */ + +#include "r8a774e1-hihope-rzg2h.dts" +#include "hihope-rzg2-ex.dtsi" + +/ { + model = "HopeRun HiHope RZ/G2H with sub board"; + compatible = "hoperun,hihope-rzg2-ex", "hoperun,hihope-rzg2h", + "renesas,r8a774e1"; +}; diff --git a/arch/arm/dts/r8a774e1-hihope-rzg2h-u-boot.dts b/arch/arm/dts/r8a774e1-hihope-rzg2h-u-boot.dts new file mode 100644 index 0000000000..2d2e5ec506 --- /dev/null +++ b/arch/arm/dts/r8a774e1-hihope-rzg2h-u-boot.dts @@ -0,0 +1,9 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Device Tree Source extras for U-Boot for the Hihope RZ/G2H board + * + * Copyright (C) 2020 Renesas Electronics Corp. + */ + +#include "r8a774e1-hihope-rzg2h-ex.dts" +#include "r8a774e1-u-boot.dtsi" diff --git a/arch/arm/dts/r8a774e1-hihope-rzg2h.dts b/arch/arm/dts/r8a774e1-hihope-rzg2h.dts new file mode 100644 index 0000000000..cdbe527e93 --- /dev/null +++ b/arch/arm/dts/r8a774e1-hihope-rzg2h.dts @@ -0,0 +1,26 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Device Tree Source for the HiHope RZ/G2H main board + * + * Copyright (C) 2020 Renesas Electronics Corp. + */ + +/dts-v1/; +#include "r8a774e1.dtsi" +#include "hihope-rev4.dtsi" + +/ { + model = "HopeRun HiHope RZ/G2H main board based on r8a774e1"; + compatible = "hoperun,hihope-rzg2h", "renesas,r8a774e1"; + + memory@48000000 { + device_type = "memory"; + /* first 128MB is reserved for secure area. */ + reg = <0x0 0x48000000 0x0 0x78000000>; + }; + + memory@500000000 { + device_type = "memory"; + reg = <0x5 0x00000000 0x0 0x80000000>; + }; +}; diff --git a/arch/arm/dts/r8a774e1-u-boot.dtsi b/arch/arm/dts/r8a774e1-u-boot.dtsi new file mode 100644 index 0000000000..30c38dcfba --- /dev/null +++ b/arch/arm/dts/r8a774e1-u-boot.dtsi @@ -0,0 +1,25 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Device Tree Source extras for U-Boot on RZ/G2 R8A774E1 SoC + * + * Copyright (C) 2020 Renesas Electronics Corp. + */ + +#include "r8a779x-u-boot.dtsi" + +&extalr_clk { + u-boot,dm-pre-reloc; +}; + +/delete-node/ &can0; +/delete-node/ &can1; +/delete-node/ &canfd; +/delete-node/ &du; +/delete-node/ &hdmi0; +/delete-node/ &rcar_sound; +/delete-node/ &sdhi2; +/delete-node/ &sound_card; + +/ { + /delete-node/ hdmi0-out; +}; diff --git a/arch/arm/mach-rmobile/Kconfig.64 b/arch/arm/mach-rmobile/Kconfig.64 index 9e11732a09..c716cd1954 100644 --- a/arch/arm/mach-rmobile/Kconfig.64 +++ b/arch/arm/mach-rmobile/Kconfig.64 @@ -67,6 +67,7 @@ config TARGET_HIHOPE_RZG2 bool "HiHope RZ/G2 board" imply R8A774A1 imply R8A774B1 + imply R8A774E1 imply SYS_MALLOC_F imply MULTI_DTB_FIT imply MULTI_DTB_FIT_USER_DEFINED_AREA diff --git a/board/hoperun/hihope-rzg2/hihope-rzg2.c b/board/hoperun/hihope-rzg2/hihope-rzg2.c index 31551d10ef..aadfbc1504 100644 --- a/board/hoperun/hihope-rzg2/hihope-rzg2.c +++ b/board/hoperun/hihope-rzg2/hihope-rzg2.c @@ -1,7 +1,7 @@ // SPDX-License-Identifier: GPL-2.0+ /* * board/hoperun/hihope-rzg2/hihope-rzg2.c - * This file is HiHope RZ/G2[MN] board support. + * This file is HiHope RZ/G2[HMN] board support. * * Copyright (C) 2020 Renesas Electronics Corporation */ @@ -188,6 +188,10 @@ int board_fit_config_name_match(const char *name) !strcmp(name, "r8a774b1-hihope-rzg2n-u-boot")) return 0;
+ if (cpu_type == RMOBILE_CPU_TYPE_R8A774E1 && + !strcmp(name, "r8a774e1-hihope-rzg2h-u-boot")) + return 0; + return -1; } #endif diff --git a/configs/hihope_rzg2_defconfig b/configs/hihope_rzg2_defconfig index 1c20206e1b..50ac0dea29 100644 --- a/configs/hihope_rzg2_defconfig +++ b/configs/hihope_rzg2_defconfig @@ -32,7 +32,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y -CONFIG_OF_LIST="r8a774a1-hihope-rzg2m-u-boot r8a774b1-hihope-rzg2n-u-boot" +CONFIG_OF_LIST="r8a774a1-hihope-rzg2m-u-boot r8a774b1-hihope-rzg2n-u-boot r8a774e1-hihope-rzg2h-u-boot" CONFIG_MULTI_DTB_FIT_LZO=y CONFIG_MULTI_DTB_FIT_USER_DEFINED_AREA=y CONFIG_ENV_OVERWRITE=y
Biju Das
