[U-Boot] [PATCH] qoriq/p1_p2_rdb: USB device-tree fixups for P1020
Resolve P1020 second USB controller multiplexing with eLBC - mandatory to mention USB2 in hwconfig string to select it over eLBC, otherwise USB2 node is removed - works only for SPI and SD boot
Signed-off-by: Ramneek Mehresh ramneek.mehresh@freescale.com --- Applies on git://git.am.freescale.net/mirrors/u-boot.git (branch master)
board/freescale/p1_p2_rdb/p1_p2_rdb.c | 54 +++++++++++++++++++++++++++++++++ 1 files changed, 54 insertions(+), 0 deletions(-)
diff --git a/board/freescale/p1_p2_rdb/p1_p2_rdb.c b/board/freescale/p1_p2_rdb/p1_p2_rdb.c index d66b130..14ad895 100644 --- a/board/freescale/p1_p2_rdb/p1_p2_rdb.c +++ b/board/freescale/p1_p2_rdb/p1_p2_rdb.c @@ -37,6 +37,7 @@ #include <netdev.h> #include <rtc.h> #include <i2c.h> +#include <hwconfig.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -247,6 +248,11 @@ extern void ft_pci_board_setup(void *blob);
void ft_board_setup(void *blob, bd_t *bd) { +#if defined(CONFIG_SDCARD) || defined(CONFIG_SPIFLASH) + const char *soc_elbc_compat = "fsl,p1020-elbc"; +#endif + const char *soc_usb_compat = "fsl-usb2-dr"; + int off, err, usb1_off, usb2_off; phys_addr_t base; phys_size_t size;
@@ -260,5 +266,53 @@ void ft_board_setup(void *blob, bd_t *bd) #endif /* #if defined(CONFIG_PCI) */
fdt_fixup_memory(blob, (u64)base, (u64)size); + + fdt_fixup_dr_usb(blob, bd); + +#if defined(CONFIG_SDCARD) || defined(CONFIG_SPIFLASH) + /* Delete eLBC node as it is muxed with USB2 controller */ + if (hwconfig("usb2")) { + off = fdt_node_offset_by_compatible(blob, -1, + soc_elbc_compat); + if (off < 0) { + printf("WARNING: could not find compatible node" + " %s: %s.\n", soc_elbc_compat, + fdt_strerror(off)); + return; + } + err = fdt_del_node(blob, off); + if (err < 0) { + printf("WARNING: could not remove %s: %s.\n", + soc_elbc_compat, fdt_strerror(err)); + return; + } + } else { +#endif + /* Delete USB2 node as it is muxed with eLBC */ + usb1_off = fdt_node_offset_by_compatible(blob, -1, + soc_usb_compat); + if (usb1_off < 0) { + printf("WARNING: could not find compatible node" + " %s: %s.\n", soc_usb_compat, + fdt_strerror(usb1_off)); + return; + } + usb2_off = fdt_node_offset_by_compatible(blob, usb1_off, + soc_usb_compat); + if (usb2_off < 0) { + printf("WARNING: could not find compatible node" + " %s: %s.\n", soc_usb_compat, + fdt_strerror(usb2_off)); + return; + } + err = fdt_del_node(blob, usb2_off); + if (err < 0) { + printf("WARNING: could not remove %s: %s.\n", + soc_usb_compat, fdt_strerror(err)); + return; + } +#if defined(CONFIG_SDCARD) || defined(CONFIG_SPIFLASH) + } +#endif } #endif
Dear Ramneek Mehresh,
In message 1305032211-7732-1-git-send-email-ramneek.mehresh@freescale.com you wrote:
Forget it. It is a mandatory requirement that patches are submitted against the master branch of the master repository.
NAK, without even looking further.
- const char *soc_elbc_compat = "fsl,p1020-elbc";
- const char *soc_usb_compat = "fsl-usb2-dr";
- int off, err, usb1_off, usb2_off; phys_addr_t base; phys_size_t size;
- fdt_fixup_dr_usb(blob, bd);
- /* Delete eLBC node as it is muxed with USB2 controller */
- if (hwconfig("usb2")) {
soc_elbc_compat);
if (off < 0) {
fdt_strerror(off));
return;
if (err < 0) {
return;
Move the return; from oneline above here.
- } else {
Then you can get rid of this "else {" part, and indentation will become correct. As is, it's ugly at best.
soc_usb_compat);
if (usb1_off < 0) {
return;
soc_usb_compat);
if (usb2_off < 0) {
return;
if (err < 0) {
return;
This #if will then disappear, too.
Ramneek Mehresh
