[U-Boot] Error Code "rm cannot remove directory 'asm/arch' : Is a directory"
Hello All, I am trying to learn u-boot in xp. *http://d1.amobbs.com/bbs_upload782111/files_41/ourdev_649777NIY8KG.pdf http://d1.amobbs.com/bbs_upload782111/files_41/ourdev_649777NIY8KG.pdf*
When I am trying to build u-boot I got an error. When I call command "*make am3517_evm_config*" then *Error* is "rm cannot remove directory 'asm/arch' : Is a directory make : ***[am3517_evm_config] Error 1
This time I don't know what to do. anyone can help me out
Any Kind of suggestion would be appreciated.
Hi Ambuj,
Why on Earth use XP? It's about the worst possible choice of MS OS for trying to build U-Boot, if only because it's going to stop being supported very soon (if not already?).
Plus, in general, U-Boot building requires GCC or LLVM, and generally Unix- or Linux-originating tools, which are fiddly to get working properly on an MS OS (disclaimer: I last tried this a decade ago and it was a /nightmare/. I guess it got better over time, but still, it's either MingW or Cygwin, right, and that probably still means a lot of "playing around" to get things working).
Which version of U-Boot are you building, and with which version of GCC?
Why not install some Linux-based OS? If you can't, why not at least run some Linux-based OS as a VM? You'd save a lot of trouble IMO.
Amicalement,
Albert ARIBAUD
Ambuj Saxena
