[U-Boot] [PATCH v5 0/3] TI: tnetv107x patch series
TNETV107X is a Texas Instruments SoC based on an ARM1176 core, and with a bunch on on-chip integrated peripherals. This patch series generalizes current ARM1176 code to allow for the addition of new ARM1176 SOCs. The remaining patches in this series add arch and board support.
Cyril Chemparathy (3): ARM1176: Coexist with other ARM1176 platforms ARM1176: TI: TNETV107X soc initial support TI: TNETV107X EVM initial support
MAINTAINERS | 4 + MAKEALL | 1 + Makefile | 3 + arch/arm/cpu/arm1176/cpu.c | 3 - arch/arm/cpu/arm1176/start.S | 62 +++- arch/arm/cpu/arm1176/tnetv107x/Makefile | 44 ++ arch/arm/cpu/arm1176/tnetv107x/aemif.c | 151 +++++++ arch/arm/cpu/arm1176/tnetv107x/clock.c | 542 +++++++++++++++++++++++ arch/arm/cpu/arm1176/tnetv107x/init.c | 41 ++ arch/arm/cpu/arm1176/tnetv107x/lowlevel_init.S | 25 + arch/arm/cpu/arm1176/tnetv107x/mux.c | 463 +++++++++++++++++++ arch/arm/cpu/arm1176/tnetv107x/timer.c | 125 ++++++ arch/arm/cpu/arm1176/tnetv107x/wdt.c | 172 +++++++ arch/arm/include/asm/arch-tnetv107x/clock.h | 50 ++ arch/arm/include/asm/arch-tnetv107x/emif_defs.h | 1 + arch/arm/include/asm/arch-tnetv107x/hardware.h | 184 ++++++++ arch/arm/include/asm/arch-tnetv107x/mux.h | 307 +++++++++++++ arch/arm/include/asm/arch-tnetv107x/nand_defs.h | 38 ++ board/ti/tnetv107xevm/Makefile | 49 ++ board/ti/tnetv107xevm/config.mk | 20 + board/ti/tnetv107xevm/sdb_board.c | 66 +++ include/configs/smdk6400.h | 6 + include/configs/tnetv107x_evm.h | 214 +++++++++ 23 files changed, 2557 insertions(+), 14 deletions(-) create mode 100644 arch/arm/cpu/arm1176/tnetv107x/Makefile create mode 100644 arch/arm/cpu/arm1176/tnetv107x/aemif.c create mode 100644 arch/arm/cpu/arm1176/tnetv107x/clock.c create mode 100644 arch/arm/cpu/arm1176/tnetv107x/init.c create mode 100644 arch/arm/cpu/arm1176/tnetv107x/lowlevel_init.S create mode 100644 arch/arm/cpu/arm1176/tnetv107x/mux.c create mode 100644 arch/arm/cpu/arm1176/tnetv107x/timer.c create mode 100644 arch/arm/cpu/arm1176/tnetv107x/wdt.c create mode 100644 arch/arm/include/asm/arch-tnetv107x/clock.h create mode 100644 arch/arm/include/asm/arch-tnetv107x/emif_defs.h create mode 100644 arch/arm/include/asm/arch-tnetv107x/hardware.h create mode 100644 arch/arm/include/asm/arch-tnetv107x/mux.h create mode 100644 arch/arm/include/asm/arch-tnetv107x/nand_defs.h create mode 100644 board/ti/tnetv107xevm/Makefile create mode 100644 board/ti/tnetv107xevm/config.mk create mode 100644 board/ti/tnetv107xevm/sdb_board.c create mode 100644 include/configs/tnetv107x_evm.h
The current ARM1176 CPU specific code is too specific to the SMDK6400 architecture. The following changes were necessary prerequisites for the addition of other SoCs based on ARM1176.
Existing board's (SMDK6400) configuration has been modified to keep behavior unchanged despite these changes.
1. Peripheral port remap configurability The earlier code had hardcoded remap values specific to s3c64xx in start.S. This change makes the peripheral port remap addresses and sizes configurable.
2. Skip low level initialization Ability to skip low level initialization if necessary. Many other platforms have a similar capability, and this is quite useful during debug/bring-up.
3. U-Boot code relocation support Most architectures allow u-boot code to run initially at a different address (possibly in NOR) and then get relocated to its final resting place in RAM. Added support for this capability in ARM1176 architecture.
4. Disable TCM if necessary If a ROM based bootloader happened to have initialized TCM, we disable it here to keep things sane.
5. Remove unnecessary SoC specific includes ARM1176 code does not really need this SoC specific include. The presence of this include prevents builds on other ARM1176 archs.
6. ARM926 style MMU disable when !CONFIG_ENABLE_MMU The original MMU disable code masks out too many bits from the load address when it tries to figure out the physical address of the jump target label. Consequently, it ends up branching to the wrong address after disabling the MMU.
Signed-off-by: Cyril Chemparathy cyril@ti.com --- v5: rebased on master in u-boot-arm.git v4: rebased on next in u-boot-arm.git v3: unchanged from v2 v2: unchanged from v1
arch/arm/cpu/arm1176/cpu.c | 3 -- arch/arm/cpu/arm1176/start.S | 62 ++++++++++++++++++++++++++++++++++------- include/configs/smdk6400.h | 6 ++++ 3 files changed, 57 insertions(+), 14 deletions(-)
diff --git a/arch/arm/cpu/arm1176/cpu.c b/arch/arm/cpu/arm1176/cpu.c index befa0cd..c0fd114 100644 --- a/arch/arm/cpu/arm1176/cpu.c +++ b/arch/arm/cpu/arm1176/cpu.c @@ -33,9 +33,6 @@
#include <common.h> #include <command.h> -#ifdef CONFIG_S3C64XX -#include <asm/arch/s3c6400.h> -#endif #include <asm/system.h>
static void cache_flush (void); diff --git a/arch/arm/cpu/arm1176/start.S b/arch/arm/cpu/arm1176/start.S index e2b6c9b..beec574 100644 --- a/arch/arm/cpu/arm1176/start.S +++ b/arch/arm/cpu/arm1176/start.S @@ -1,5 +1,5 @@ /* - * armboot - Startup Code for S3C6400/ARM1176 CPU-core + * armboot - Startup Code for ARM1176 CPU-core * * Copyright (c) 2007 Samsung Electronics * @@ -35,9 +35,6 @@ #ifdef CONFIG_ENABLE_MMU #include <asm/proc/domain.h> #endif -#ifdef CONFIG_S3C64XX -#include <asm/arch/s3c6400.h> -#endif
#if !defined(CONFIG_ENABLE_MMU) && !defined(CONFIG_SYS_PHY_UBOOT_BASE) #define CONFIG_SYS_PHY_UBOOT_BASE CONFIG_SYS_UBOOT_BASE @@ -147,6 +144,7 @@ reset: * ************************************************************************* */ +#ifndef CONFIG_SKIP_LOWLEVEL_INIT /* * we do sys-critical inits only at reboot, * not when booting from ram! @@ -172,6 +170,8 @@ cpu_init_crit: bic r0, r0, #0x00000087 @ clear bits 7, 2:0 (B--- -CAM) orr r0, r0, #0x00000002 @ set bit 2 (A) Align orr r0, r0, #0x00001000 @ set bit 12 (I) I-Cache + +#ifdef CONFIG_ENABLE_MMU /* Prepare to disable the MMU */ adr r1, mmu_disable_phys /* We presume we're within the first 1024 bytes */ @@ -189,13 +189,32 @@ mmu_disable: nop nop mov pc, r2 +mmu_disable_phys: +#else + mcr p15, 0, r0, c1, c0, 0 #endif
-mmu_disable_phys: -#ifdef CONFIG_S3C64XX +#ifdef CONFIG_DISABLE_TCM + /* + * Disable the TCMs + */ + mrc p15, 0, r0, c0, c0, 2 /* Return TCM details */ + cmp r0, #0 + beq skip_tcmdisable + mov r1, #0 + mov r2, #1 + tst r0, r2 + mcrne p15, 0, r1, c9, c1, 1 /* Disable Instruction TCM if present*/ + tst r0, r2, LSL #16 + mcrne p15, 0, r1, c9, c1, 0 /* Disable Data TCM if present*/ +skip_tcmdisable: +#endif +#endif + +#ifdef CONFIG_PERIPORT_REMAP /* Peri port setup */ - ldr r0, =0x70000000 - orr r0, r0, #0x13 + ldr r0, =CONFIG_PERIPORT_BASE + orr r0, r0, #CONFIG_PERIPORT_SIZE mcr p15,0,r0,c15,c2,4 @ 256M (0x70000000 - 0x7fffffff) #endif
@@ -203,8 +222,27 @@ mmu_disable_phys: * Go setup Memory and board specific bits prior to relocation. */ bl lowlevel_init /* go setup pll,mux,memory */ +#endif /* CONFIG_SKIP_LOWLEVEL_INIT */ + +#ifndef CONFIG_SKIP_RELOCATE_UBOOT +relocate: /* relocate U-Boot to RAM */ + adr r0, _start /* r0 <- current position of code */ + ldr r1, _TEXT_BASE /* test if we run from flash or RAM */ + cmp r0, r1 /* don't reloc during debug */ + beq stack_setup + + ldr r2, _armboot_start + ldr r3, _bss_start + sub r2, r3, r2 /* r2 <- size of armboot */ + add r2, r0, r2 /* r2 <- source end address */ + +copy_loop: + ldmia r0!, {r3-r10} /* copy from source address [r0] */ + stmia r1!, {r3-r10} /* copy to target address [r1] */ + cmp r0, r2 /* until source end addreee [r2] */ + ble copy_loop +#endif /* CONFIG_SKIP_RELOCATE_UBOOT */
-after_copy: #ifdef CONFIG_ENABLE_MMU enable_mmu: /* enable domain access */ @@ -240,9 +278,9 @@ mmu_enable: nop nop mov pc, r2 +skip_hw_init: #endif
-skip_hw_init: /* Set up the stack */ stack_setup: ldr r0, =CONFIG_SYS_UBOOT_BASE /* base of copy in DRAM */ @@ -310,6 +348,8 @@ phy_last_jump: mov r0, #0 mov pc, r9 #endif + + /* ************************************************************************* * @@ -377,7 +417,7 @@ phy_last_jump: ldr r13, _armboot_start /* move past malloc pool */ sub r13, r13, #(CONFIG_SYS_MALLOC_LEN) - /* move to reserved a couple spots for abort stack */ + /* reserved a couple spots for abort stack */ sub r13, r13, #(CONFIG_SYS_GBL_DATA_SIZE + 8)
/* save caller lr in position 0 of saved stack */ diff --git a/include/configs/smdk6400.h b/include/configs/smdk6400.h index f04feae..7b4501d 100644 --- a/include/configs/smdk6400.h +++ b/include/configs/smdk6400.h @@ -40,6 +40,12 @@ #define CONFIG_S3C64XX 1 /* in a SAMSUNG S3C64XX Family */ #define CONFIG_SMDK6400 1 /* on a SAMSUNG SMDK6400 Board */
+#define CONFIG_SKIP_RELOCATE_UBOOT + +#define CONFIG_PERIPORT_REMAP +#define CONFIG_PERIPORT_BASE 0x70000000 +#define CONFIG_PERIPORT_SIZE 0x13 + #define CONFIG_SYS_SDRAM_BASE 0x50000000
/* input clock of PLL: SMDK6400 has 12MHz input clock */
TNETV107X is a Texas Instruments SoC based on an ARM1176 core, and with a bunch on on-chip integrated peripherals. This is an initial commit with basic functionality, more commits with drivers, etc. to follow.
Signed-off-by: Cyril Chemparathy cyril@ti.com --- v5: rebased on master in u-boot-arm.git v4: rebased on next in u-boot-arm.git (unchanged) v3: unchanged from v2 v2: macroized aemif configuration to reduce verbosity v2: consolidated lpsc utilities, inlined clock enable/disable
arch/arm/cpu/arm1176/tnetv107x/Makefile | 44 ++ arch/arm/cpu/arm1176/tnetv107x/aemif.c | 151 +++++++ arch/arm/cpu/arm1176/tnetv107x/clock.c | 542 +++++++++++++++++++++++ arch/arm/cpu/arm1176/tnetv107x/init.c | 41 ++ arch/arm/cpu/arm1176/tnetv107x/lowlevel_init.S | 25 + arch/arm/cpu/arm1176/tnetv107x/mux.c | 463 +++++++++++++++++++ arch/arm/cpu/arm1176/tnetv107x/timer.c | 125 ++++++ arch/arm/cpu/arm1176/tnetv107x/wdt.c | 172 +++++++ arch/arm/include/asm/arch-tnetv107x/clock.h | 50 ++ arch/arm/include/asm/arch-tnetv107x/emif_defs.h | 1 + arch/arm/include/asm/arch-tnetv107x/hardware.h | 184 ++++++++ arch/arm/include/asm/arch-tnetv107x/mux.h | 307 +++++++++++++ arch/arm/include/asm/arch-tnetv107x/nand_defs.h | 38 ++ 13 files changed, 2143 insertions(+), 0 deletions(-) create mode 100644 arch/arm/cpu/arm1176/tnetv107x/Makefile create mode 100644 arch/arm/cpu/arm1176/tnetv107x/aemif.c create mode 100644 arch/arm/cpu/arm1176/tnetv107x/clock.c create mode 100644 arch/arm/cpu/arm1176/tnetv107x/init.c create mode 100644 arch/arm/cpu/arm1176/tnetv107x/lowlevel_init.S create mode 100644 arch/arm/cpu/arm1176/tnetv107x/mux.c create mode 100644 arch/arm/cpu/arm1176/tnetv107x/timer.c create mode 100644 arch/arm/cpu/arm1176/tnetv107x/wdt.c create mode 100644 arch/arm/include/asm/arch-tnetv107x/clock.h create mode 100644 arch/arm/include/asm/arch-tnetv107x/emif_defs.h create mode 100644 arch/arm/include/asm/arch-tnetv107x/hardware.h create mode 100644 arch/arm/include/asm/arch-tnetv107x/mux.h create mode 100644 arch/arm/include/asm/arch-tnetv107x/nand_defs.h
diff --git a/arch/arm/cpu/arm1176/tnetv107x/Makefile b/arch/arm/cpu/arm1176/tnetv107x/Makefile new file mode 100644 index 0000000..fe9d8a0 --- /dev/null +++ b/arch/arm/cpu/arm1176/tnetv107x/Makefile @@ -0,0 +1,44 @@ +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or modify +# it under the terms of the GNU General Public License as published by +# the Free Software Foundation; either version 2 of the License, or +# (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(SOC).a + +COBJS += aemif.o clock.o init.o mux.o timer.o wdt.o +SOBJS += lowlevel_init.o + +SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) + +OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) +START := $(addprefix $(obj),$(START)) + +all: $(obj).depend $(LIB) + +$(LIB): $(OBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/arch/arm/cpu/arm1176/tnetv107x/aemif.c b/arch/arm/cpu/arm1176/tnetv107x/aemif.c new file mode 100644 index 0000000..ae512b0 --- /dev/null +++ b/arch/arm/cpu/arm1176/tnetv107x/aemif.c @@ -0,0 +1,151 @@ +/* + * TNETV107X: Asynchronous EMIF Configuration + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/clock.h> +#include <asm/arch/mux.h> + +#define ASYNC_EMIF_BASE TNETV107X_ASYNC_EMIF_CNTRL_BASE +#define ASYNC_EMIF_CONFIG(cs) (ASYNC_EMIF_BASE+0x10+(cs)*4) +#define ASYNC_EMIF_ONENAND_CONTROL (ASYNC_EMIF_BASE+0x5c) +#define ASYNC_EMIF_NAND_CONTROL (ASYNC_EMIF_BASE+0x60) +#define ASYNC_EMIF_WAITCYCLE_CONFIG (ASYNC_EMIF_BASE+0x4) + +#define CONFIG_SELECT_STROBE(v) ((v) ? 1 << 31 : 0) +#define CONFIG_EXTEND_WAIT(v) ((v) ? 1 << 30 : 0) +#define CONFIG_WR_SETUP(v) (((v) & 0x0f) << 26) +#define CONFIG_WR_STROBE(v) (((v) & 0x3f) << 20) +#define CONFIG_WR_HOLD(v) (((v) & 0x07) << 17) +#define CONFIG_RD_SETUP(v) (((v) & 0x0f) << 13) +#define CONFIG_RD_STROBE(v) (((v) & 0x3f) << 7) +#define CONFIG_RD_HOLD(v) (((v) & 0x07) << 4) +#define CONFIG_TURN_AROUND(v) (((v) & 0x03) << 2) +#define CONFIG_WIDTH(v) (((v) & 0x03) << 0) + +#define NUM_CS 4 +#define MASK 0xffffffff + +#define set_config_field(reg, field, val) \ + do { \ + if (val != -1) { \ + reg &= ~CONFIG_##field(MASK); \ + reg |= CONFIG_##field(val); \ + } \ + } while (0) + +static struct async_emif_config default_async_emif_config[NUM_CS] = { + { /* CS0 */ + .mode = ASYNC_EMIF_MODE_NAND, + .select_strobe = ASYNC_EMIF_CS0_SELECT_STROBE, + .extend_wait = ASYNC_EMIF_CS0_EXTEND_WAIT, + .wr_setup = ASYNC_EMIF_CS0_WR_SETUP, + .wr_strobe = ASYNC_EMIF_CS0_WR_STROBE, + .wr_hold = ASYNC_EMIF_CS0_WR_HOLD, + .rd_setup = ASYNC_EMIF_CS0_RD_SETUP, + .rd_strobe = ASYNC_EMIF_CS0_RD_STROBE, + .rd_hold = ASYNC_EMIF_CS0_RD_HOLD, + .turn_around = ASYNC_EMIF_CS0_TURN_AROUND, + .width = ASYNC_EMIF_CS0_WIDTH, + }, + { /* CS1 */ + .mode = ASYNC_EMIF_MODE_NOR, + .select_strobe = ASYNC_EMIF_CS1_SELECT_STROBE, + .extend_wait = ASYNC_EMIF_CS1_EXTEND_WAIT, + .wr_setup = ASYNC_EMIF_CS1_WR_SETUP, + .wr_strobe = ASYNC_EMIF_CS1_WR_STROBE, + .wr_hold = ASYNC_EMIF_CS1_WR_HOLD, + .rd_setup = ASYNC_EMIF_CS1_RD_SETUP, + .rd_strobe = ASYNC_EMIF_CS1_RD_STROBE, + .rd_hold = ASYNC_EMIF_CS1_RD_HOLD, + .turn_around = ASYNC_EMIF_CS1_TURN_AROUND, + .width = ASYNC_EMIF_CS1_WIDTH, + }, + { /* CS2 */ + .mode = ASYNC_EMIF_MODE_NOR, + .select_strobe = ASYNC_EMIF_CS2_SELECT_STROBE, + .extend_wait = ASYNC_EMIF_CS2_EXTEND_WAIT, + .wr_setup = ASYNC_EMIF_CS2_WR_SETUP, + .wr_strobe = ASYNC_EMIF_CS2_WR_STROBE, + .wr_hold = ASYNC_EMIF_CS2_WR_HOLD, + .rd_setup = ASYNC_EMIF_CS2_RD_SETUP, + .rd_strobe = ASYNC_EMIF_CS2_RD_STROBE, + .rd_hold = ASYNC_EMIF_CS2_RD_HOLD, + .turn_around = ASYNC_EMIF_CS2_TURN_AROUND, + .width = ASYNC_EMIF_CS2_WIDTH, + }, + { /* CS3 */ + .mode = ASYNC_EMIF_MODE_NOR, + .select_strobe = ASYNC_EMIF_CS3_SELECT_STROBE, + .extend_wait = ASYNC_EMIF_CS3_EXTEND_WAIT, + .wr_setup = ASYNC_EMIF_CS3_WR_SETUP, + .wr_strobe = ASYNC_EMIF_CS3_WR_STROBE, + .wr_hold = ASYNC_EMIF_CS3_WR_HOLD, + .rd_setup = ASYNC_EMIF_CS3_RD_SETUP, + .rd_strobe = ASYNC_EMIF_CS3_RD_STROBE, + .rd_hold = ASYNC_EMIF_CS3_RD_HOLD, + .turn_around = ASYNC_EMIF_CS3_TURN_AROUND, + .width = ASYNC_EMIF_CS3_WIDTH, + }, +}; + +void configure_async_emif(int cs, struct async_emif_config *cfg) +{ + unsigned long tmp; + + if (cfg->mode == ASYNC_EMIF_MODE_NAND) { + tmp = __raw_readl(ASYNC_EMIF_NAND_CONTROL); + tmp |= (1 << cs); + __raw_writel(tmp, ASYNC_EMIF_NAND_CONTROL); + + } else if (cfg->mode == ASYNC_EMIF_MODE_ONENAND) { + tmp = __raw_readl(ASYNC_EMIF_ONENAND_CONTROL); + tmp |= (1 << cs); + __raw_writel(tmp, ASYNC_EMIF_ONENAND_CONTROL); + } + + tmp = __raw_readl(ASYNC_EMIF_CONFIG(cs)); + + set_config_field(tmp, SELECT_STROBE, cfg->select_strobe); + set_config_field(tmp, EXTEND_WAIT, cfg->extend_wait); + set_config_field(tmp, WR_SETUP, cfg->wr_setup); + set_config_field(tmp, WR_STROBE, cfg->wr_strobe); + set_config_field(tmp, WR_HOLD, cfg->wr_hold); + set_config_field(tmp, RD_SETUP, cfg->rd_setup); + set_config_field(tmp, RD_STROBE, cfg->rd_strobe); + set_config_field(tmp, RD_HOLD, cfg->rd_hold); + set_config_field(tmp, TURN_AROUND, cfg->turn_around); + set_config_field(tmp, WIDTH, cfg->width); + + __raw_writel(tmp, ASYNC_EMIF_CONFIG(cs)); +} + +void init_async_emif(void) +{ + int cs; + + mux_select_pin(TNETV107X_PIN_ASR_CS3); + + clk_enable(TNETV107X_LPSC_AEMIF); + + for (cs = 0; cs < NUM_CS; cs++) + configure_async_emif(cs, &default_async_emif_config[cs]); +} diff --git a/arch/arm/cpu/arm1176/tnetv107x/clock.c b/arch/arm/cpu/arm1176/tnetv107x/clock.c new file mode 100644 index 0000000..861cea1 --- /dev/null +++ b/arch/arm/cpu/arm1176/tnetv107x/clock.c @@ -0,0 +1,542 @@ +/* + * TNETV107X: Clock management APIs + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/clock.h> + +#define CLOCK_BASE TNETV107X_CLOCK_CONTROL_BASE +#define PSC_BASE TNETV107X_PSC_BASE + +#define MAX_PREDIV 64 +#define MAX_POSTDIV 8 +#define MAX_MULT 512 +#define MAX_DIV (MAX_PREDIV * MAX_POSTDIV) + +/* LPSC registers */ +#define PSC_PTCMD 0x120 +#define PSC_PTSTAT 0x128 +#define PSC_MDSTAT(n) (0x800 + (n) * 4) +#define PSC_MDCTL(n) (0xA00 + (n) * 4) + +#define psc_reg_read(reg) __raw_readl((u32 *)(PSC_BASE + (reg))) +#define psc_reg_write(reg, val) __raw_writel(val, (u32 *)(PSC_BASE + (reg))) + +/* PLL identifiers */ +enum pll_type_e { + SYS_PLL, + TDM_PLL, + ETH_PLL +}; + +/* PLL configuration data */ +struct pll_init_data { + int config_enable; + int pll; + int internal_osc; + unsigned long external_freq; + unsigned long pll_freq; + unsigned long div_freq[10]; +}; + +/* SSPLL registers */ +struct sspll_regs { + u32 modes; + u32 postdiv; + u32 prediv; + u32 mult_factor; + u32 divider_range; + u32 bw_divider; + u32 spr_amount; + u32 spr_rate_div; + u32 diag; +}; + +/* SSPLL base addresses */ +static struct sspll_regs *sspll_regs[] = { + (struct sspll_regs *)(CLOCK_BASE + 0x040), + (struct sspll_regs *)(CLOCK_BASE + 0x080), + (struct sspll_regs *)(CLOCK_BASE + 0x0c0), +}; + +#define sspll_reg(pll, reg) (&(sspll_regs[pll]->reg)) +#define sspll_reg_read(pll, reg) __raw_readl(sspll_reg(pll, reg)) +#define sspll_reg_write(pll, reg, val) __raw_writel(val, sspll_reg(pll, reg)) + + +/* PLL Control Registers */ +struct pllctl_regs { + u32 ctl; /* 00 */ + u32 ocsel; /* 04 */ + u32 secctl; /* 08 */ + u32 __pad0; + u32 mult; /* 10 */ + u32 prediv; /* 14 */ + u32 div1; /* 18 */ + u32 div2; /* 1c */ + u32 div3; /* 20 */ + u32 oscdiv1; /* 24 */ + u32 postdiv; /* 28 */ + u32 bpdiv; /* 2c */ + u32 wakeup; /* 30 */ + u32 __pad1; + u32 cmd; /* 38 */ + u32 stat; /* 3c */ + u32 alnctl; /* 40 */ + u32 dchange; /* 44 */ + u32 cken; /* 48 */ + u32 ckstat; /* 4c */ + u32 systat; /* 50 */ + u32 ckctl; /* 54 */ + u32 __pad2[2]; + u32 div4; /* 60 */ + u32 div5; /* 64 */ + u32 div6; /* 68 */ + u32 div7; /* 6c */ + u32 div8; /* 70 */ +}; + +struct lpsc_map { + int pll, div; +}; + +static struct pllctl_regs *pllctl_regs[] = { + (struct pllctl_regs *)(CLOCK_BASE + 0x700), + (struct pllctl_regs *)(CLOCK_BASE + 0x300), + (struct pllctl_regs *)(CLOCK_BASE + 0x500), +}; + +#define pllctl_reg(pll, reg) (&(pllctl_regs[pll]->reg)) +#define pllctl_reg_read(pll, reg) __raw_readl(pllctl_reg(pll, reg)) +#define pllctl_reg_write(pll, reg, val) __raw_writel(val, pllctl_reg(pll, reg)) + +#define pllctl_reg_rmw(pll, reg, mask, val) \ + pllctl_reg_write(pll, reg, \ + (pllctl_reg_read(pll, reg) & ~(mask)) | val) + +#define pllctl_reg_setbits(pll, reg, mask) \ + pllctl_reg_rmw(pll, reg, 0, mask) + +#define pllctl_reg_clrbits(pll, reg, mask) \ + pllctl_reg_rmw(pll, reg, mask, 0) + +/* PLLCTL Bits */ +#define PLLCTL_CLKMODE (0x1 << 8) +#define PLLCTL_PLLSELB (0x1 << 7) +#define PLLCTL_PLLENSRC (0x1 << 5) +#define PLLCTL_PLLDIS (0x1 << 4) +#define PLLCTL_PLLRST (0x1 << 3) +#define PLLCTL_PLLPWRDN (0x1 << 1) +#define PLLCTL_PLLEN (0x1 << 0) + +static int pll_div_offset[] = { +#define div_offset(reg) offsetof(struct pllctl_regs, reg) + div_offset(div1), div_offset(div2), div_offset(div3), + div_offset(div4), div_offset(div5), div_offset(div6), + div_offset(div7), div_offset(div8), +}; + +static unsigned long pll_bypass_mask[] = { 1, 4, 2 }; +static unsigned long pll_div_mask[] = { 0x01ff, 0x00ff, 0x00ff }; + +/* Mappings from PLL+DIV to subsystem clocks */ +#define sys_arm1176_clk {SYS_PLL, 0} +#define sys_dsp_clk {SYS_PLL, 1} +#define sys_ddr_clk {SYS_PLL, 2} +#define sys_full_clk {SYS_PLL, 3} +#define sys_lcd_clk {SYS_PLL, 4} +#define sys_vlynq_ref_clk {SYS_PLL, 5} +#define sys_tsc_clk {SYS_PLL, 6} +#define sys_half_clk {SYS_PLL, 7} + +#define eth_clk_5 {ETH_PLL, 0} +#define eth_clk_50 {ETH_PLL, 1} +#define eth_clk_125 {ETH_PLL, 2} +#define eth_clk_250 {ETH_PLL, 3} +#define eth_clk_25 {ETH_PLL, 4} + +#define tdm_clk {TDM_PLL, 0} +#define tdm_extra_clk {TDM_PLL, 1} +#define tdm1_clk {TDM_PLL, 2} + +static const struct lpsc_map lpsc_clk_map[] = { + [TNETV107X_LPSC_ARM] = sys_arm1176_clk, + [TNETV107X_LPSC_GEM] = sys_dsp_clk, + [TNETV107X_LPSC_DDR2_PHY] = sys_ddr_clk, + [TNETV107X_LPSC_TPCC] = sys_full_clk, + [TNETV107X_LPSC_TPTC0] = sys_full_clk, + [TNETV107X_LPSC_TPTC1] = sys_full_clk, + [TNETV107X_LPSC_RAM] = sys_full_clk, + [TNETV107X_LPSC_MBX_LITE] = sys_arm1176_clk, + [TNETV107X_LPSC_LCD] = sys_lcd_clk, + [TNETV107X_LPSC_ETHSS] = eth_clk_125, + [TNETV107X_LPSC_AEMIF] = sys_full_clk, + [TNETV107X_LPSC_CHIP_CFG] = sys_half_clk, + [TNETV107X_LPSC_TSC] = sys_tsc_clk, + [TNETV107X_LPSC_ROM] = sys_half_clk, + [TNETV107X_LPSC_UART2] = sys_half_clk, + [TNETV107X_LPSC_PKTSEC] = sys_half_clk, + [TNETV107X_LPSC_SECCTL] = sys_half_clk, + [TNETV107X_LPSC_KEYMGR] = sys_half_clk, + [TNETV107X_LPSC_KEYPAD] = sys_half_clk, + [TNETV107X_LPSC_GPIO] = sys_half_clk, + [TNETV107X_LPSC_MDIO] = sys_half_clk, + [TNETV107X_LPSC_SDIO0] = sys_half_clk, + [TNETV107X_LPSC_UART0] = sys_half_clk, + [TNETV107X_LPSC_UART1] = sys_half_clk, + [TNETV107X_LPSC_TIMER0] = sys_half_clk, + [TNETV107X_LPSC_TIMER1] = sys_half_clk, + [TNETV107X_LPSC_WDT_ARM] = sys_half_clk, + [TNETV107X_LPSC_WDT_DSP] = sys_half_clk, + [TNETV107X_LPSC_SSP] = sys_half_clk, + [TNETV107X_LPSC_TDM0] = tdm_clk, + [TNETV107X_LPSC_VLYNQ] = sys_vlynq_ref_clk, + [TNETV107X_LPSC_MCDMA] = sys_half_clk, + [TNETV107X_LPSC_USB0] = sys_half_clk, + [TNETV107X_LPSC_TDM1] = tdm1_clk, + [TNETV107X_LPSC_DEBUGSS] = sys_half_clk, + [TNETV107X_LPSC_ETHSS_RGMII] = eth_clk_250, + [TNETV107X_LPSC_SYSTEM] = sys_half_clk, + [TNETV107X_LPSC_IMCOP] = sys_dsp_clk, + [TNETV107X_LPSC_SPARE] = sys_half_clk, + [TNETV107X_LPSC_SDIO1] = sys_half_clk, + [TNETV107X_LPSC_USB1] = sys_half_clk, + [TNETV107X_LPSC_USBSS] = sys_half_clk, + [TNETV107X_LPSC_DDR2_EMIF1_VRST] = sys_ddr_clk, + [TNETV107X_LPSC_DDR2_EMIF2_VCTL_RST] = sys_ddr_clk, +}; + +static const struct pll_init_data plls[] = { + [SYS_PLL] = { + .config_enable = CONFIG_PLL_SYS_CONFIG, + .pll = SYS_PLL, + .internal_osc = CONFIG_PLL_SYS_INT_OSC, + .external_freq = CONFIG_PLL_SYS_EXT_FREQ, +#if (CONFIG_PLL_SYS_CONFIG) + .pll_freq = CONFIG_PLL_SYS_PLL_FREQ, + .div_freq = { + CONFIG_PLL_SYS_ARM1176_CLK, + CONFIG_PLL_SYS_DSP_CLK, + CONFIG_PLL_SYS_DDR_CLK, + CONFIG_PLL_SYS_FULL_CLK, + CONFIG_PLL_SYS_LCD_CLK, + CONFIG_PLL_SYS_VLYNQ_REF_CLK, + CONFIG_PLL_SYS_TSC_CLK, + CONFIG_PLL_SYS_HALF_CLK, + }, +#endif + }, + [TDM_PLL] = { + .config_enable = CONFIG_PLL_TDM_CONFIG, + .pll = TDM_PLL, + .internal_osc = CONFIG_PLL_TDM_INT_OSC, + .external_freq = CONFIG_PLL_TDM_EXT_FREQ, +#if (CONFIG_PLL_TDM_CONFIG) + .pll_freq = CONFIG_PLL_TDM_PLL_FREQ, + .div_freq = { + CONFIG_PLL_TDM_TDM0_CLK, + CONFIG_PLL_TDM_TIMER_CLK, + CONFIG_PLL_TDM_TDM1_CLK, + }, +#endif + }, + [ETH_PLL] = { + .config_enable = CONFIG_PLL_ETH_CONFIG, + .pll = ETH_PLL, + .internal_osc = CONFIG_PLL_ETH_INT_OSC, + .external_freq = CONFIG_PLL_ETH_EXT_FREQ, +#if (CONFIG_PLL_ETH_CONFIG) + .pll_freq = CONFIG_PLL_ETH_PLL_FREQ, + .div_freq = { + CONFIG_PLL_ETH_5_CLK, + CONFIG_PLL_ETH_50_CLK, + CONFIG_PLL_ETH_125_CLK, + CONFIG_PLL_ETH_250_CLK, + CONFIG_PLL_ETH_25_CLK, + }, +#endif + }, +}; + +void clk_delay(void) +{ + int i; + + for (i = 0; i < 1000; i++) + __asm__ __volatile__("mov r0, r0\n" : : : "memory"); +} + +static unsigned long pll_freq_get(int pll) +{ + unsigned long mult = 1, prediv = 1, postdiv = 1; + unsigned long ref = CONFIG_SYS_INT_OSC_FREQ; + unsigned long ret; + u32 bypass; + + bypass = __raw_readl((u32 *)(CLOCK_BASE)); + if (!(bypass & pll_bypass_mask[pll])) { + mult = sspll_reg_read(pll, mult_factor); + prediv = sspll_reg_read(pll, prediv) + 1; + postdiv = sspll_reg_read(pll, postdiv) + 1; + } + + if (pllctl_reg_read(pll, ctl) & PLLCTL_CLKMODE) + ref = plls[pll].external_freq; + + if (!(pllctl_reg_read(pll, ctl) & PLLCTL_PLLEN)) + return ref; + + ret = (unsigned long)(ref + ((unsigned long long)ref * mult) / 256); + ret /= (prediv * postdiv); + + return ret; +} + +static unsigned long __pll_div_freq_get(int pll, unsigned int fpll, + int div) +{ + int divider = 1; + unsigned long divreg; + + divreg = __raw_readl((void *)pllctl_regs[pll] + pll_div_offset[div]); + + if (divreg & (0x01 << 15)) + divider = (divreg & pll_div_mask[pll]) + 1; + + return fpll / divider; +} + +static unsigned long pll_div_freq_get(int pll, int div) +{ + unsigned int fpll = pll_freq_get(pll); + + return __pll_div_freq_get(pll, fpll, div); +} + +static void __pll_div_freq_set(int pll, unsigned int fpll, int div, + unsigned long hz) +{ + int divider = (fpll / hz - 1); + + divider &= pll_div_mask[pll]; + divider |= (0x01 << 15); /* enable */ + + __raw_writel(divider, (void *)pllctl_regs[pll] + pll_div_offset[div]); + pllctl_reg_setbits(pll, alnctl, (1 << div)); + pllctl_reg_setbits(pll, dchange, (1 << div)); +} + +static unsigned long pll_div_freq_set(int pll, int div, unsigned long hz) +{ + unsigned int fpll = pll_freq_get(pll); + + __pll_div_freq_set(pll, fpll, div, hz); + + pllctl_reg_write(pll, cmd, 1); + + while (pllctl_reg_read(pll, stat) & 0x01) + ; + + clk_delay(); + + return __pll_div_freq_get(pll, fpll, div); +} + +unsigned long clk_get_rate(unsigned int clk) +{ + return pll_div_freq_get(lpsc_clk_map[clk].pll, lpsc_clk_map[clk].div); +} + +long clk_round_rate(unsigned int clk, unsigned long hz) +{ + int fpll, divider, pll; + + pll = lpsc_clk_map[clk].pll; + fpll = pll_freq_get(pll); + divider = (fpll / hz - 1); + divider &= pll_div_mask[pll]; + + return fpll / (divider + 1); +} + +int clk_set_rate(unsigned int clk, unsigned long _hz) +{ + unsigned long hz; + + hz = clk_round_rate(clk, _hz); + if (hz != _hz) + return -1; /* Cannot set to target freq */ + + return pll_div_freq_set(lpsc_clk_map[clk].pll, + lpsc_clk_map[clk].div, hz); +} + +static void __lpsc_set_state(int nmod, int lrstz, va_list args) +{ + int i; + u32 mdctl, state; + unsigned int id; + + for (i = 0; i < nmod; i++) { + id = va_arg(args, unsigned int); + state = va_arg(args, u32); + mdctl = psc_reg_read(PSC_MDCTL(id)); + mdctl &= ~0x1f; + mdctl |= state; + if (lrstz == 0 || lrstz == 1) { + mdctl &= ~(1 << 8); + mdctl |= (lrstz << 8); + } + psc_reg_write(PSC_MDCTL(id), mdctl); + } +} + +static void __lpsc_wait_state(int nmod, va_list args) +{ + int i; + u32 state; + unsigned int id; + + for (i = 0; i < nmod; i++) { + id = va_arg(args, unsigned int); + state = va_arg(args, u32); + while ((psc_reg_read(PSC_MDSTAT(id)) & 0x1f) != state) + ; + } +} + +void lpsc_control(int nmod, int lrstz, ...) +{ + va_list args; + + va_start(args, lrstz); + __lpsc_set_state(nmod, lrstz, args); + va_end(args); + + psc_reg_write(PSC_PTCMD, 1); + while (psc_reg_read(PSC_PTSTAT) & 1) + ; + + va_start(args, lrstz); + __lpsc_wait_state(nmod, args); + va_end(args); +} + +int lpsc_status(unsigned int id) +{ + return psc_reg_read(PSC_MDSTAT(id)) & 0x1f; +} + +static void init_pll(const struct pll_init_data *data) +{ + unsigned long fpll; + unsigned long best_pre = 0, best_post = 0, best_mult = 0; + unsigned long div, prediv, postdiv, mult; + unsigned long delta, actual; + long best_delta = -1; + int i; + u32 tmp; + + if (!data->config_enable) + return; + + tmp = pllctl_reg_read(data->pll, ctl); + if (data->internal_osc) { + tmp &= ~PLLCTL_CLKMODE; + fpll = CONFIG_SYS_INT_OSC_FREQ; + } else { + tmp |= PLLCTL_CLKMODE; + fpll = data->external_freq; + } + pllctl_reg_write(data->pll, ctl, tmp); + + mult = data->pll_freq / fpll; + for (mult = MAX(mult, 1); mult <= MAX_MULT; mult++) { + div = (fpll * mult) / data->pll_freq; + if (div < 1 || div > MAX_DIV) + continue; + + for (postdiv = 1; postdiv <= min(div, MAX_POSTDIV); postdiv++) { + prediv = div / postdiv; + if (prediv < 1 || prediv > MAX_PREDIV) + continue; + + actual = (fpll / prediv) * (mult / postdiv); + delta = (actual - data->pll_freq); + delta = ABS(delta); + if ((delta < best_delta) || (best_delta == -1)) { + best_delta = delta; + best_mult = mult; + best_pre = prediv; + best_post = postdiv; + if (delta == 0) + goto done; + } + } + } +done: + + fpll = fpll * best_mult; + fpll /= best_pre * best_post; + + pllctl_reg_clrbits(data->pll, ctl, PLLCTL_PLLENSRC); + pllctl_reg_clrbits(data->pll, ctl, PLLCTL_PLLEN); + + clk_delay(); + + pllctl_reg_setbits(data->pll, ctl, PLLCTL_PLLRST); + clk_delay(); + + pllctl_reg_clrbits(data->pll, ctl, PLLCTL_PLLPWRDN); + pllctl_reg_clrbits(data->pll, ctl, PLLCTL_PLLDIS); + clk_delay(); + + sspll_reg_write(data->pll, mult_factor, (best_mult - 1) << 8); + sspll_reg_write(data->pll, prediv, best_pre - 1); + sspll_reg_write(data->pll, postdiv, best_post - 1); + + for (i = 0; i < 10; i++) + if (data->div_freq[i]) + __pll_div_freq_set(data->pll, fpll, i, + data->div_freq[i]); + + pllctl_reg_write(data->pll, cmd, 1); + + /* Wait for completion */ + while (pllctl_reg_read(data->pll, stat) & 0x01) + ; + + clk_delay(); + + pllctl_reg_clrbits(data->pll, ctl, PLLCTL_PLLRST); + clk_delay(); + + pllctl_reg_setbits(data->pll, ctl, PLLCTL_PLLEN); + clk_delay(); +} + +void init_plls(void) +{ + int i; + + for (i = 0; i < ARRAY_SIZE(plls); i++) + init_pll(&plls[i]); +} diff --git a/arch/arm/cpu/arm1176/tnetv107x/init.c b/arch/arm/cpu/arm1176/tnetv107x/init.c new file mode 100644 index 0000000..d906c72 --- /dev/null +++ b/arch/arm/cpu/arm1176/tnetv107x/init.c @@ -0,0 +1,41 @@ +/* + * TNETV107X: Architecture initialization + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +#include <common.h> +#include <asm/io.h> + +void chip_configuration_unlock(void) +{ + __raw_writel(TNETV107X_KICK0_MAGIC, TNETV107X_KICK0); + __raw_writel(TNETV107X_KICK1_MAGIC, TNETV107X_KICK1); +} + +int arch_cpu_init(void) +{ + icache_enable(); + chip_configuration_unlock(); + init_plls(); + init_timer(); + init_async_emif(); + init_wdt(); + + return 0; +} diff --git a/arch/arm/cpu/arm1176/tnetv107x/lowlevel_init.S b/arch/arm/cpu/arm1176/tnetv107x/lowlevel_init.S new file mode 100644 index 0000000..3ee32ef --- /dev/null +++ b/arch/arm/cpu/arm1176/tnetv107x/lowlevel_init.S @@ -0,0 +1,25 @@ +/* + * TNETV107X: Low-level pre-relocation initialization + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +.globl lowlevel_init +lowlevel_init: + /* nothing for now, maybe needed for more exotic boot modes */ + mov pc, lr diff --git a/arch/arm/cpu/arm1176/tnetv107x/mux.c b/arch/arm/cpu/arm1176/tnetv107x/mux.c new file mode 100644 index 0000000..7b58133 --- /dev/null +++ b/arch/arm/cpu/arm1176/tnetv107x/mux.c @@ -0,0 +1,463 @@ +/* + * TNETV107X: Pinmux configuration + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/clock.h> +#include <asm/arch/mux.h> + +#define MUX_MODE_1 0x00 +#define MUX_MODE_2 0x04 +#define MUX_MODE_3 0x0c +#define MUX_MODE_4 0x1c + +#define MUX_DEBUG 0 + +static const struct pin_config pin_table[] = { + TNETV107X_MUX_CFG(0, 0, MUX_MODE_1), + TNETV107X_MUX_CFG(0, 0, MUX_MODE_2), + TNETV107X_MUX_CFG(0, 5, MUX_MODE_1), + TNETV107X_MUX_CFG(0, 5, MUX_MODE_2), + TNETV107X_MUX_CFG(0, 10, MUX_MODE_1), + TNETV107X_MUX_CFG(0, 10, MUX_MODE_2), + TNETV107X_MUX_CFG(0, 15, MUX_MODE_1), + TNETV107X_MUX_CFG(0, 15, MUX_MODE_2), + TNETV107X_MUX_CFG(0, 20, MUX_MODE_1), + TNETV107X_MUX_CFG(0, 20, MUX_MODE_2), + TNETV107X_MUX_CFG(0, 25, MUX_MODE_1), + TNETV107X_MUX_CFG(0, 25, MUX_MODE_2), + TNETV107X_MUX_CFG(1, 0, MUX_MODE_1), + TNETV107X_MUX_CFG(1, 0, MUX_MODE_2), + TNETV107X_MUX_CFG(1, 5, MUX_MODE_1), + TNETV107X_MUX_CFG(1, 5, MUX_MODE_2), + TNETV107X_MUX_CFG(1, 10, MUX_MODE_1), + TNETV107X_MUX_CFG(1, 10, MUX_MODE_2), + TNETV107X_MUX_CFG(1, 15, MUX_MODE_1), + TNETV107X_MUX_CFG(1, 15, MUX_MODE_2), + TNETV107X_MUX_CFG(1, 20, MUX_MODE_1), + TNETV107X_MUX_CFG(1, 20, MUX_MODE_2), + TNETV107X_MUX_CFG(1, 25, MUX_MODE_1), + TNETV107X_MUX_CFG(1, 25, MUX_MODE_2), + TNETV107X_MUX_CFG(2, 0, MUX_MODE_1), + TNETV107X_MUX_CFG(2, 0, MUX_MODE_2), + TNETV107X_MUX_CFG(2, 5, MUX_MODE_1), + TNETV107X_MUX_CFG(2, 5, MUX_MODE_2), + TNETV107X_MUX_CFG(2, 10, MUX_MODE_1), + TNETV107X_MUX_CFG(2, 10, MUX_MODE_2), + TNETV107X_MUX_CFG(2, 15, MUX_MODE_1), + TNETV107X_MUX_CFG(2, 15, MUX_MODE_2), + TNETV107X_MUX_CFG(2, 20, MUX_MODE_1), + TNETV107X_MUX_CFG(2, 20, MUX_MODE_2), + TNETV107X_MUX_CFG(2, 25, MUX_MODE_1), + TNETV107X_MUX_CFG(2, 25, MUX_MODE_2), + TNETV107X_MUX_CFG(3, 0, MUX_MODE_1), + TNETV107X_MUX_CFG(3, 0, MUX_MODE_2), + TNETV107X_MUX_CFG(3, 0, MUX_MODE_4), + TNETV107X_MUX_CFG(3, 5, MUX_MODE_1), + TNETV107X_MUX_CFG(3, 5, MUX_MODE_2), + TNETV107X_MUX_CFG(3, 5, MUX_MODE_4), + TNETV107X_MUX_CFG(3, 10, MUX_MODE_1), + TNETV107X_MUX_CFG(3, 10, MUX_MODE_2), + TNETV107X_MUX_CFG(3, 10, MUX_MODE_4), + TNETV107X_MUX_CFG(3, 15, MUX_MODE_1), + TNETV107X_MUX_CFG(3, 15, MUX_MODE_2), + TNETV107X_MUX_CFG(3, 15, MUX_MODE_4), + TNETV107X_MUX_CFG(3, 20, MUX_MODE_1), + TNETV107X_MUX_CFG(3, 20, MUX_MODE_2), + TNETV107X_MUX_CFG(3, 20, MUX_MODE_4), + TNETV107X_MUX_CFG(3, 25, MUX_MODE_1), + TNETV107X_MUX_CFG(3, 25, MUX_MODE_2), + TNETV107X_MUX_CFG(3, 25, MUX_MODE_4), + TNETV107X_MUX_CFG(4, 0, MUX_MODE_1), + TNETV107X_MUX_CFG(4, 0, MUX_MODE_2), + TNETV107X_MUX_CFG(4, 0, MUX_MODE_4), + TNETV107X_MUX_CFG(4, 5, MUX_MODE_1), + TNETV107X_MUX_CFG(4, 10, MUX_MODE_1), + TNETV107X_MUX_CFG(4, 15, MUX_MODE_1), + TNETV107X_MUX_CFG(4, 15, MUX_MODE_4), + TNETV107X_MUX_CFG(4, 20, MUX_MODE_1), + TNETV107X_MUX_CFG(4, 20, MUX_MODE_3), + TNETV107X_MUX_CFG(4, 25, MUX_MODE_1), + TNETV107X_MUX_CFG(4, 25, MUX_MODE_4), + TNETV107X_MUX_CFG(5, 0, MUX_MODE_1), + TNETV107X_MUX_CFG(5, 0, MUX_MODE_4), + TNETV107X_MUX_CFG(5, 5, MUX_MODE_1), + TNETV107X_MUX_CFG(5, 5, MUX_MODE_4), + TNETV107X_MUX_CFG(5, 10, MUX_MODE_1), + TNETV107X_MUX_CFG(5, 10, MUX_MODE_4), + TNETV107X_MUX_CFG(5, 15, MUX_MODE_1), + TNETV107X_MUX_CFG(5, 15, MUX_MODE_4), + TNETV107X_MUX_CFG(5, 20, MUX_MODE_1), + TNETV107X_MUX_CFG(5, 20, MUX_MODE_4), + TNETV107X_MUX_CFG(5, 25, MUX_MODE_1), + TNETV107X_MUX_CFG(5, 25, MUX_MODE_4), + TNETV107X_MUX_CFG(6, 0, MUX_MODE_1), + TNETV107X_MUX_CFG(6, 0, MUX_MODE_4), + TNETV107X_MUX_CFG(6, 5, MUX_MODE_1), + TNETV107X_MUX_CFG(6, 5, MUX_MODE_4), + TNETV107X_MUX_CFG(6, 10, MUX_MODE_1), + TNETV107X_MUX_CFG(6, 10, MUX_MODE_4), + TNETV107X_MUX_CFG(6, 15, MUX_MODE_1), + TNETV107X_MUX_CFG(6, 15, MUX_MODE_4), + TNETV107X_MUX_CFG(6, 20, MUX_MODE_1), + TNETV107X_MUX_CFG(6, 20, MUX_MODE_4), + TNETV107X_MUX_CFG(6, 25, MUX_MODE_1), + TNETV107X_MUX_CFG(6, 25, MUX_MODE_4), + TNETV107X_MUX_CFG(7, 0, MUX_MODE_1), + TNETV107X_MUX_CFG(7, 0, MUX_MODE_4), + TNETV107X_MUX_CFG(7, 5, MUX_MODE_1), + TNETV107X_MUX_CFG(7, 5, MUX_MODE_4), + TNETV107X_MUX_CFG(7, 10, MUX_MODE_1), + TNETV107X_MUX_CFG(7, 10, MUX_MODE_4), + TNETV107X_MUX_CFG(7, 15, MUX_MODE_1), + TNETV107X_MUX_CFG(7, 15, MUX_MODE_2), + TNETV107X_MUX_CFG(7, 20, MUX_MODE_1), + TNETV107X_MUX_CFG(7, 20, MUX_MODE_2), + TNETV107X_MUX_CFG(7, 25, MUX_MODE_1), + TNETV107X_MUX_CFG(7, 25, MUX_MODE_2), + TNETV107X_MUX_CFG(8, 0, MUX_MODE_1), + TNETV107X_MUX_CFG(8, 0, MUX_MODE_2), + TNETV107X_MUX_CFG(8, 5, MUX_MODE_1), + TNETV107X_MUX_CFG(8, 5, MUX_MODE_2), + TNETV107X_MUX_CFG(8, 5, MUX_MODE_4), + TNETV107X_MUX_CFG(8, 10, MUX_MODE_1), + TNETV107X_MUX_CFG(8, 10, MUX_MODE_2), + TNETV107X_MUX_CFG(9, 0, MUX_MODE_1), + TNETV107X_MUX_CFG(9, 0, MUX_MODE_2), + TNETV107X_MUX_CFG(9, 0, MUX_MODE_4), + TNETV107X_MUX_CFG(9, 5, MUX_MODE_1), + TNETV107X_MUX_CFG(9, 5, MUX_MODE_2), + TNETV107X_MUX_CFG(9, 5, MUX_MODE_4), + TNETV107X_MUX_CFG(9, 10, MUX_MODE_1), + TNETV107X_MUX_CFG(9, 10, MUX_MODE_2), + TNETV107X_MUX_CFG(9, 10, MUX_MODE_4), + TNETV107X_MUX_CFG(9, 15, MUX_MODE_1), + TNETV107X_MUX_CFG(9, 15, MUX_MODE_2), + TNETV107X_MUX_CFG(9, 15, MUX_MODE_4), + TNETV107X_MUX_CFG(9, 20, MUX_MODE_1), + TNETV107X_MUX_CFG(9, 20, MUX_MODE_2), + TNETV107X_MUX_CFG(9, 20, MUX_MODE_4), + TNETV107X_MUX_CFG(10, 0, MUX_MODE_1), + TNETV107X_MUX_CFG(10, 0, MUX_MODE_2), + TNETV107X_MUX_CFG(10, 5, MUX_MODE_1), + TNETV107X_MUX_CFG(10, 5, MUX_MODE_2), + TNETV107X_MUX_CFG(10, 10, MUX_MODE_1), + TNETV107X_MUX_CFG(10, 10, MUX_MODE_2), + TNETV107X_MUX_CFG(10, 15, MUX_MODE_1), + TNETV107X_MUX_CFG(10, 15, MUX_MODE_2), + TNETV107X_MUX_CFG(10, 20, MUX_MODE_1), + TNETV107X_MUX_CFG(10, 20, MUX_MODE_2), + TNETV107X_MUX_CFG(10, 25, MUX_MODE_1), + TNETV107X_MUX_CFG(10, 25, MUX_MODE_2), + TNETV107X_MUX_CFG(11, 0, MUX_MODE_1), + TNETV107X_MUX_CFG(11, 5, MUX_MODE_1), + TNETV107X_MUX_CFG(12, 0, MUX_MODE_1), + TNETV107X_MUX_CFG(12, 5, MUX_MODE_1), + TNETV107X_MUX_CFG(12, 10, MUX_MODE_1), + TNETV107X_MUX_CFG(12, 15, MUX_MODE_1), + TNETV107X_MUX_CFG(12, 20, MUX_MODE_1), + TNETV107X_MUX_CFG(12, 25, MUX_MODE_1), + TNETV107X_MUX_CFG(13, 0, MUX_MODE_1), + TNETV107X_MUX_CFG(13, 5, MUX_MODE_1), + TNETV107X_MUX_CFG(13, 10, MUX_MODE_1), + TNETV107X_MUX_CFG(13, 15, MUX_MODE_1), + TNETV107X_MUX_CFG(14, 0, MUX_MODE_1), + TNETV107X_MUX_CFG(14, 5, MUX_MODE_1), + TNETV107X_MUX_CFG(14, 10, MUX_MODE_1), + TNETV107X_MUX_CFG(14, 15, MUX_MODE_1), + TNETV107X_MUX_CFG(14, 20, MUX_MODE_1), + TNETV107X_MUX_CFG(14, 25, MUX_MODE_1), + TNETV107X_MUX_CFG(15, 0, MUX_MODE_1), + TNETV107X_MUX_CFG(15, 0, MUX_MODE_2), + TNETV107X_MUX_CFG(15, 5, MUX_MODE_1), + TNETV107X_MUX_CFG(15, 5, MUX_MODE_2), + TNETV107X_MUX_CFG(15, 10, MUX_MODE_1), + TNETV107X_MUX_CFG(15, 15, MUX_MODE_1), + TNETV107X_MUX_CFG(15, 20, MUX_MODE_1), + TNETV107X_MUX_CFG(15, 25, MUX_MODE_1), + TNETV107X_MUX_CFG(16, 0, MUX_MODE_1), + TNETV107X_MUX_CFG(16, 5, MUX_MODE_1), + TNETV107X_MUX_CFG(16, 10, MUX_MODE_1), + TNETV107X_MUX_CFG(16, 10, MUX_MODE_2), + TNETV107X_MUX_CFG(16, 10, MUX_MODE_3), + TNETV107X_MUX_CFG(16, 15, MUX_MODE_1), + TNETV107X_MUX_CFG(16, 15, MUX_MODE_2), + TNETV107X_MUX_CFG(17, 0, MUX_MODE_1), + TNETV107X_MUX_CFG(17, 0, MUX_MODE_2), + TNETV107X_MUX_CFG(17, 0, MUX_MODE_3), + TNETV107X_MUX_CFG(17, 5, MUX_MODE_1), + TNETV107X_MUX_CFG(17, 5, MUX_MODE_2), + TNETV107X_MUX_CFG(17, 5, MUX_MODE_3), + TNETV107X_MUX_CFG(17, 10, MUX_MODE_1), + TNETV107X_MUX_CFG(17, 10, MUX_MODE_2), + TNETV107X_MUX_CFG(17, 10, MUX_MODE_3), + TNETV107X_MUX_CFG(17, 15, MUX_MODE_1), + TNETV107X_MUX_CFG(17, 15, MUX_MODE_2), + TNETV107X_MUX_CFG(17, 15, MUX_MODE_3), + TNETV107X_MUX_CFG(18, 0, MUX_MODE_1), + TNETV107X_MUX_CFG(18, 0, MUX_MODE_2), + TNETV107X_MUX_CFG(18, 0, MUX_MODE_3), + TNETV107X_MUX_CFG(18, 5, MUX_MODE_1), + TNETV107X_MUX_CFG(18, 5, MUX_MODE_2), + TNETV107X_MUX_CFG(18, 5, MUX_MODE_3), + TNETV107X_MUX_CFG(18, 10, MUX_MODE_1), + TNETV107X_MUX_CFG(18, 10, MUX_MODE_2), + TNETV107X_MUX_CFG(18, 10, MUX_MODE_3), + TNETV107X_MUX_CFG(18, 15, MUX_MODE_1), + TNETV107X_MUX_CFG(18, 15, MUX_MODE_2), + TNETV107X_MUX_CFG(18, 15, MUX_MODE_3), + TNETV107X_MUX_CFG(19, 0, MUX_MODE_1), + TNETV107X_MUX_CFG(19, 5, MUX_MODE_1), + TNETV107X_MUX_CFG(19, 10, MUX_MODE_1), + TNETV107X_MUX_CFG(19, 15, MUX_MODE_1), + TNETV107X_MUX_CFG(19, 20, MUX_MODE_1), + TNETV107X_MUX_CFG(19, 25, MUX_MODE_1), + TNETV107X_MUX_CFG(20, 0, MUX_MODE_1), + TNETV107X_MUX_CFG(20, 5, MUX_MODE_1), + TNETV107X_MUX_CFG(20, 10, MUX_MODE_1), + TNETV107X_MUX_CFG(20, 15, MUX_MODE_1), + TNETV107X_MUX_CFG(20, 15, MUX_MODE_3), + TNETV107X_MUX_CFG(20, 20, MUX_MODE_1), + TNETV107X_MUX_CFG(20, 25, MUX_MODE_1), + TNETV107X_MUX_CFG(21, 0, MUX_MODE_1), + TNETV107X_MUX_CFG(21, 5, MUX_MODE_1), + TNETV107X_MUX_CFG(21, 10, MUX_MODE_1), + TNETV107X_MUX_CFG(21, 15, MUX_MODE_1), + TNETV107X_MUX_CFG(21, 20, MUX_MODE_1), + TNETV107X_MUX_CFG(21, 25, MUX_MODE_1), + TNETV107X_MUX_CFG(22, 0, MUX_MODE_1), + TNETV107X_MUX_CFG(22, 5, MUX_MODE_1), + TNETV107X_MUX_CFG(22, 5, MUX_MODE_3), + TNETV107X_MUX_CFG(22, 10, MUX_MODE_1), + TNETV107X_MUX_CFG(22, 10, MUX_MODE_3), + TNETV107X_MUX_CFG(22, 15, MUX_MODE_1), + TNETV107X_MUX_CFG(22, 15, MUX_MODE_2), + TNETV107X_MUX_CFG(22, 15, MUX_MODE_3), + TNETV107X_MUX_CFG(22, 20, MUX_MODE_1), + TNETV107X_MUX_CFG(22, 20, MUX_MODE_3), + TNETV107X_MUX_CFG(22, 25, MUX_MODE_1), + TNETV107X_MUX_CFG(22, 25, MUX_MODE_3), + TNETV107X_MUX_CFG(23, 0, MUX_MODE_1), + TNETV107X_MUX_CFG(23, 0, MUX_MODE_3), + TNETV107X_MUX_CFG(23, 5, MUX_MODE_1), + TNETV107X_MUX_CFG(23, 5, MUX_MODE_3), + TNETV107X_MUX_CFG(23, 10, MUX_MODE_1), + TNETV107X_MUX_CFG(23, 10, MUX_MODE_3), + TNETV107X_MUX_CFG(24, 0, MUX_MODE_1), + TNETV107X_MUX_CFG(24, 0, MUX_MODE_2), + TNETV107X_MUX_CFG(24, 5, MUX_MODE_1), + TNETV107X_MUX_CFG(24, 5, MUX_MODE_2), + TNETV107X_MUX_CFG(24, 10, MUX_MODE_1), + TNETV107X_MUX_CFG(24, 10, MUX_MODE_2), + TNETV107X_MUX_CFG(24, 10, MUX_MODE_3), + TNETV107X_MUX_CFG(24, 15, MUX_MODE_1), + TNETV107X_MUX_CFG(24, 15, MUX_MODE_2), + TNETV107X_MUX_CFG(24, 15, MUX_MODE_3), + TNETV107X_MUX_CFG(24, 20, MUX_MODE_1), + TNETV107X_MUX_CFG(24, 20, MUX_MODE_2), + TNETV107X_MUX_CFG(24, 25, MUX_MODE_1), + TNETV107X_MUX_CFG(24, 25, MUX_MODE_2), + TNETV107X_MUX_CFG(25, 0, MUX_MODE_1), + TNETV107X_MUX_CFG(25, 0, MUX_MODE_2), + TNETV107X_MUX_CFG(25, 0, MUX_MODE_3), + TNETV107X_MUX_CFG(25, 5, MUX_MODE_1), + TNETV107X_MUX_CFG(25, 5, MUX_MODE_2), + TNETV107X_MUX_CFG(25, 5, MUX_MODE_3), + TNETV107X_MUX_CFG(25, 10, MUX_MODE_1), + TNETV107X_MUX_CFG(25, 10, MUX_MODE_2), + TNETV107X_MUX_CFG(25, 10, MUX_MODE_3), + TNETV107X_MUX_CFG(25, 15, MUX_MODE_1), + TNETV107X_MUX_CFG(25, 15, MUX_MODE_2), + TNETV107X_MUX_CFG(25, 15, MUX_MODE_3), + TNETV107X_MUX_CFG(25, 15, MUX_MODE_4), + TNETV107X_MUX_CFG(26, 0, MUX_MODE_1), + TNETV107X_MUX_CFG(26, 5, MUX_MODE_1), + TNETV107X_MUX_CFG(26, 10, MUX_MODE_1), + TNETV107X_MUX_CFG(26, 10, MUX_MODE_2), + TNETV107X_MUX_CFG(26, 15, MUX_MODE_1), + TNETV107X_MUX_CFG(26, 15, MUX_MODE_2), + TNETV107X_MUX_CFG(26, 20, MUX_MODE_1), + TNETV107X_MUX_CFG(26, 20, MUX_MODE_2), + TNETV107X_MUX_CFG(26, 25, MUX_MODE_1), + TNETV107X_MUX_CFG(26, 25, MUX_MODE_2), +}; + +const int pin_table_size = sizeof(pin_table) / sizeof(pin_table[0]); + +static const short sdio0_pins[] = { + TNETV107X_PIN_SDIO0_CLK, TNETV107X_PIN_SDIO0_CMD, + TNETV107X_PIN_SDIO0_DATA0, + TNETV107X_PIN_SDIO0_DATA1, TNETV107X_PIN_SDIO0_DATA2, + TNETV107X_PIN_SDIO0_DATA3, + -1 +}; + +static const short sdio1_pins[] = { + TNETV107X_PIN_SDIO1_CLK_0, TNETV107X_PIN_SDIO1_CMD_0, + TNETV107X_PIN_SDIO1_DATA0_0, TNETV107X_PIN_SDIO1_DATA1_0, + TNETV107X_PIN_SDIO1_DATA2_0, TNETV107X_PIN_SDIO1_DATA3_0, + -1 +}; + +static const short uart0_pins[] = { + TNETV107X_PIN_UART0_CTS, TNETV107X_PIN_UART0_RD, + TNETV107X_PIN_UART0_RTS, + TNETV107X_PIN_UART0_TD, -1 +}; + +static const short uart1_pins[] = { + TNETV107X_PIN_UART1_RD, TNETV107X_PIN_UART1_TD, -1 +}; + +static const short uart2_pins[] = { + TNETV107X_PIN_UART2_CTS, TNETV107X_PIN_UART2_RD, + TNETV107X_PIN_UART2_RTS, + TNETV107X_PIN_UART2_TD, -1 +}; + +static const short keypad_pins[] = { + TNETV107X_PIN_KEYPAD_R0, TNETV107X_PIN_KEYPAD_R1, + TNETV107X_PIN_KEYPAD_R2, + TNETV107X_PIN_KEYPAD_R3, TNETV107X_PIN_KEYPAD_R4, + TNETV107X_PIN_KEYPAD_R5, + TNETV107X_PIN_KEYPAD_R6, TNETV107X_PIN_KEYPAD_C0, + TNETV107X_PIN_KEYPAD_C1, + TNETV107X_PIN_KEYPAD_C2, TNETV107X_PIN_KEYPAD_C3, + TNETV107X_PIN_KEYPAD_C4, + TNETV107X_PIN_KEYPAD_C5, TNETV107X_PIN_KEYPAD_C6, -1 +}; + +static const short vlynq_pins[] = { + TNETV107X_PIN_VLYNQ_CLK, TNETV107X_PIN_VLYNQ_RXD0, + TNETV107X_PIN_VLYNQ_RXD1, + TNETV107X_PIN_VLYNQ_TXD0, TNETV107X_PIN_VLYNQ_TXD1, -1 +}; + +static const short lcd_pins[] = { + TNETV107X_PIN_LCD_AC_NCS, TNETV107X_PIN_LCD_HSYNC_RNW, + TNETV107X_PIN_LCD_VSYNC_A0, TNETV107X_PIN_LCD_PCLK_E, + TNETV107X_PIN_LCD_PD00, + TNETV107X_PIN_LCD_PD01, TNETV107X_PIN_LCD_PD02, TNETV107X_PIN_LCD_PD03, + TNETV107X_PIN_LCD_PD04, TNETV107X_PIN_LCD_PD05, TNETV107X_PIN_LCD_PD06, + TNETV107X_PIN_LCD_PD07, TNETV107X_PIN_LCD_PD08, TNETV107X_PIN_LCD_PD09, + TNETV107X_PIN_LCD_PD10, TNETV107X_PIN_LCD_PD11, TNETV107X_PIN_LCD_PD12, + TNETV107X_PIN_LCD_PD13, TNETV107X_PIN_LCD_PD14, TNETV107X_PIN_LCD_PD15, + TNETV107X_PIN_LCD_PD16_0, TNETV107X_PIN_LCD_PD17_0, + TNETV107X_PIN_LCD_PD18, + TNETV107X_PIN_LCD_PD19_1, TNETV107X_PIN_LCD_PD20_0, + TNETV107X_PIN_LCD_PD21_0, + TNETV107X_PIN_LCD_PD22_0, TNETV107X_PIN_LCD_PD23_0, -1 +}; + +static const short ssp_pins[] = { + TNETV107X_PIN_SSP0_0, TNETV107X_PIN_SSP0_1, TNETV107X_PIN_SSP0_2, + TNETV107X_PIN_SSP1_0, TNETV107X_PIN_SSP1_1, TNETV107X_PIN_SSP1_2, + TNETV107X_PIN_SSP1_3, -1 +}; + +static const short dummy[] = { -1 }; + +static const short *psc_pins[] = { + [TNETV107X_LPSC_ARM] = dummy, + [TNETV107X_LPSC_GEM] = dummy, + [TNETV107X_LPSC_DDR2_PHY] = dummy, + [TNETV107X_LPSC_TPCC] = dummy, + [TNETV107X_LPSC_TPTC0] = dummy, + [TNETV107X_LPSC_TPTC1] = dummy, + [TNETV107X_LPSC_RAM] = dummy, + [TNETV107X_LPSC_MBX_LITE] = dummy, + [TNETV107X_LPSC_LCD] = lcd_pins, + [TNETV107X_LPSC_ETHSS] = dummy, + [TNETV107X_LPSC_AEMIF] = dummy, + [TNETV107X_LPSC_CHIP_CFG] = dummy, + [TNETV107X_LPSC_TSC] = dummy, + [TNETV107X_LPSC_ROM] = dummy, + [TNETV107X_LPSC_UART2] = uart2_pins, + [TNETV107X_LPSC_PKTSEC] = dummy, + [TNETV107X_LPSC_SECCTL] = dummy, + [TNETV107X_LPSC_KEYMGR] = dummy, + [TNETV107X_LPSC_KEYPAD] = keypad_pins, + [TNETV107X_LPSC_GPIO] = dummy, + [TNETV107X_LPSC_MDIO] = dummy, + [TNETV107X_LPSC_SDIO0] = sdio0_pins, + [TNETV107X_LPSC_UART0] = uart0_pins, + [TNETV107X_LPSC_UART1] = uart1_pins, + [TNETV107X_LPSC_TIMER0] = dummy, + [TNETV107X_LPSC_TIMER1] = dummy, + [TNETV107X_LPSC_WDT_ARM] = dummy, + [TNETV107X_LPSC_WDT_DSP] = dummy, + [TNETV107X_LPSC_SSP] = ssp_pins, + [TNETV107X_LPSC_TDM0] = dummy, + [TNETV107X_LPSC_VLYNQ] = vlynq_pins, + [TNETV107X_LPSC_MCDMA] = dummy, + [TNETV107X_LPSC_USB0] = dummy, + [TNETV107X_LPSC_TDM1] = dummy, + [TNETV107X_LPSC_DEBUGSS] = dummy, + [TNETV107X_LPSC_ETHSS_RGMII] = dummy, + [TNETV107X_LPSC_SYSTEM] = dummy, + [TNETV107X_LPSC_IMCOP] = dummy, + [TNETV107X_LPSC_SPARE] = dummy, + [TNETV107X_LPSC_SDIO1] = sdio1_pins, + [TNETV107X_LPSC_USB1] = dummy, + [TNETV107X_LPSC_USBSS] = dummy, + [TNETV107X_LPSC_DDR2_EMIF1_VRST] = dummy, + [TNETV107X_LPSC_DDR2_EMIF2_VCTL_RST] = dummy, +}; + +const int psc_pins_size = sizeof(psc_pins) / sizeof(psc_pins[0]); + +int mux_select_pin(unsigned index) +{ + const struct pin_config *cfg; + unsigned long mask, mode, reg; + + if (index >= pin_table_size) + return 0; + + cfg = &pin_table[index]; + + mask = 0x1f << cfg->mask_offset; + mode = cfg->mode << cfg->mask_offset; + + reg = __raw_readl(TNETV107X_PINMUX(cfg->reg_index)); + reg = (reg & ~mask) | mode; + __raw_writel(reg, TNETV107X_PINMUX(cfg->reg_index)); + + return 1; +} + +int mux_select_pins(const short *pins) +{ + int i, ret = 1; + + for (i = 0; pins[i] >= 0; i++) + ret &= mux_select_pin(pins[i]); + + return ret; +} + +int mux_select_module(int lpsc) +{ + if (lpsc >= psc_pins_size) + return 0; + + return mux_select_pins(psc_pins[lpsc]); +} diff --git a/arch/arm/cpu/arm1176/tnetv107x/timer.c b/arch/arm/cpu/arm1176/tnetv107x/timer.c new file mode 100644 index 0000000..2ba3f54 --- /dev/null +++ b/arch/arm/cpu/arm1176/tnetv107x/timer.c @@ -0,0 +1,125 @@ +/* + * TNETV107X: Timer implementation + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/clock.h> + +struct timer_regs { + u_int32_t pid12; + u_int32_t pad[3]; + u_int32_t tim12; + u_int32_t tim34; + u_int32_t prd12; + u_int32_t prd34; + u_int32_t tcr; + u_int32_t tgcr; + u_int32_t wdtcr; +}; + +#define regs ((struct timer_regs *)CONFIG_SYS_TIMERBASE) + +#define TIMER_LOAD_VAL (CONFIG_SYS_HZ_CLOCK / CONFIG_SYS_HZ) +#define TIM_CLK_DIV 16 + +static ulong timestamp; +static ulong lastinc; + +void init_timer(void) +{ + clk_enable(TNETV107X_LPSC_TIMER0); + + lastinc = timestamp = 0; + + /* We are using timer34 in unchained 32-bit mode, full speed */ + __raw_writel(0x0, ®s->tcr); + __raw_writel(0x0, ®s->tgcr); + __raw_writel(0x06 | ((TIM_CLK_DIV - 1) << 8), ®s->tgcr); + __raw_writel(0x0, ®s->tim34); + __raw_writel(TIMER_LOAD_VAL, ®s->prd34); + __raw_writel(2 << 22, ®s->tcr); +} + +int timer_init(void) +{ + return 0; +} + +void reset_timer(void) +{ + lastinc = timestamp = 0; + + __raw_writel(0, ®s->tcr); + __raw_writel(0, ®s->tim34); + __raw_writel(2 << 22, ®s->tcr); +} + +static ulong get_timer_raw(void) +{ + ulong now = __raw_readl(®s->tim34); + + if (now >= lastinc) + timestamp += now - lastinc; + else + timestamp += now + TIMER_LOAD_VAL - lastinc; + + lastinc = now; + + return timestamp; +} + +ulong get_timer(ulong base) +{ + return (get_timer_raw() / (TIMER_LOAD_VAL / TIM_CLK_DIV)) - base; +} + +void set_timer(ulong t) +{ + timestamp = t; +} + +unsigned long long get_ticks(void) +{ + return get_timer(0); +} + +void __udelay(unsigned long usec) +{ + ulong tmo; + ulong endtime; + signed long diff; + + tmo = CONFIG_SYS_HZ_CLOCK / 1000; + tmo *= usec; + tmo /= (1000 * TIM_CLK_DIV); + + endtime = get_timer_raw() + tmo; + + do { + ulong now = get_timer_raw(); + diff = endtime - now; + } while (diff >= 0); +} + +ulong get_tbclk(void) +{ + return CONFIG_SYS_HZ; +} diff --git a/arch/arm/cpu/arm1176/tnetv107x/wdt.c b/arch/arm/cpu/arm1176/tnetv107x/wdt.c new file mode 100644 index 0000000..eeed136 --- /dev/null +++ b/arch/arm/cpu/arm1176/tnetv107x/wdt.c @@ -0,0 +1,172 @@ +/* + * TNETV107X: Watchdog timer implementation (for reset) + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/clock.h> + +#define MAX_DIV 0xFFFE0001 + +struct wdt_regs { + u32 kick_lock; + u32 kick; + u32 change_lock; + u32 change; + u32 disable_lock; + u32 disable; + u32 prescale_lock; + u32 prescale; +}; + +static struct wdt_regs* regs = (struct wdt_regs *)TNETV107X_WDT0_ARM_BASE; + +#define wdt_reg_read(reg) __raw_readl(®s->reg) +#define wdt_reg_write(reg, val) __raw_writel((val), ®s->reg) + +static int write_prescale_reg(unsigned long prescale_value) +{ + wdt_reg_write(prescale_lock, 0x5a5a); + if ((wdt_reg_read(prescale_lock) & 0x3) != 0x1) + return -1; + + wdt_reg_write(prescale_lock, 0xa5a5); + if ((wdt_reg_read(prescale_lock) & 0x3) != 0x3) + return -1; + + wdt_reg_write(prescale, prescale_value); + + return 0; +} + +static int write_change_reg(unsigned long initial_timer_value) +{ + wdt_reg_write(change_lock, 0x6666); + if ((wdt_reg_read(change_lock) & 0x3) != 0x1) + return -1; + + wdt_reg_write(change_lock, 0xbbbb); + if ((wdt_reg_read(change_lock) & 0x3) != 0x3) + return -1; + + wdt_reg_write(change, initial_timer_value); + + return 0; +} + +static int wdt_control(unsigned long disable_value) +{ + wdt_reg_write(disable_lock, 0x7777); + if ((wdt_reg_read(disable_lock) & 0x3) != 0x1) + return -1; + + wdt_reg_write(disable_lock, 0xcccc); + if ((wdt_reg_read(disable_lock) & 0x3) != 0x2) + return -1; + + wdt_reg_write(disable_lock, 0xdddd); + if ((wdt_reg_read(disable_lock) & 0x3) != 0x3) + return -1; + + wdt_reg_write(disable, disable_value); + return 0; +} + +static int wdt_set_period(unsigned long msec) +{ + unsigned long change_value, count_value; + unsigned long prescale_value = 1; + unsigned long refclk_khz, maxdiv; + int ret; + + refclk_khz = clk_get_rate(TNETV107X_LPSC_WDT_ARM); + maxdiv = (MAX_DIV / refclk_khz); + + if ((!msec) || (msec > maxdiv)) + return -1; + + count_value = refclk_khz * msec; + if (count_value > 0xffff) { + change_value = count_value / 0xffff + 1; + prescale_value = count_value / change_value; + } else { + change_value = count_value; + } + + ret = write_prescale_reg(prescale_value - 1); + if (ret) + return ret; + + ret = write_change_reg(change_value); + if (ret) + return ret; + + return 0; +} + +unsigned long last_wdt = -1; + +int wdt_start(unsigned long msecs) +{ + int ret; + ret = wdt_control(0); + if (ret) + return ret; + ret = wdt_set_period(msecs); + if (ret) + return ret; + ret = wdt_control(1); + if (ret) + return ret; + ret = wdt_kick(); + last_wdt = msecs; + return ret; +} + +int wdt_stop(void) +{ + last_wdt = -1; + return wdt_control(0); +} + +int wdt_kick(void) +{ + wdt_reg_write(kick_lock, 0x5555); + if ((wdt_reg_read(kick_lock) & 0x3) != 0x1) + return -1; + + wdt_reg_write(kick_lock, 0xaaaa); + if ((wdt_reg_read(kick_lock) & 0x3) != 0x3) + return -1; + + wdt_reg_write(kick, 1); + return 0; +} + +void reset_cpu(ulong addr) +{ + wdt_start(1); + wdt_kick(); +} + +void init_wdt(void) +{ + clk_enable(TNETV107X_LPSC_WDT_ARM); +} diff --git a/arch/arm/include/asm/arch-tnetv107x/clock.h b/arch/arm/include/asm/arch-tnetv107x/clock.h new file mode 100644 index 0000000..369e11b --- /dev/null +++ b/arch/arm/include/asm/arch-tnetv107x/clock.h @@ -0,0 +1,50 @@ +/* + * TNETV107X: Clock APIs + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +#ifndef __ASM_ARCH_CLOCK_H +#define __ASM_ARCH_CLOCK_H + +#define PSC_MDCTL_NEXT_SWRSTDISABLE 0x0 +#define PSC_MDCTL_NEXT_SYNCRST 0x1 +#define PSC_MDCTL_NEXT_DISABLE 0x2 +#define PSC_MDCTL_NEXT_ENABLE 0x3 + +#ifndef __ASSEMBLY__ +int lpsc_status(unsigned int id); +void lpsc_control(int nmod, int lrstz, ...); +void pinmux_enable(unsigned int id, int enable); +unsigned long clk_get_rate(unsigned int clk); +long clk_round_rate(unsigned int clk, unsigned long hz); +int clk_set_rate(unsigned int clk, unsigned long hz); + +static inline void clk_enable(unsigned int id) +{ + lpsc_control(1, -1, id, PSC_MDCTL_NEXT_ENABLE); +} + +static inline void clk_disable(unsigned int id) +{ + lpsc_control(1, -1, id, PSC_MDCTL_NEXT_DISABLE); +} + +#endif + +#endif diff --git a/arch/arm/include/asm/arch-tnetv107x/emif_defs.h b/arch/arm/include/asm/arch-tnetv107x/emif_defs.h new file mode 100644 index 0000000..9969a01 --- /dev/null +++ b/arch/arm/include/asm/arch-tnetv107x/emif_defs.h @@ -0,0 +1 @@ +#include <asm/arch-davinci/emif_defs.h> diff --git a/arch/arm/include/asm/arch-tnetv107x/hardware.h b/arch/arm/include/asm/arch-tnetv107x/hardware.h new file mode 100644 index 0000000..824555c --- /dev/null +++ b/arch/arm/include/asm/arch-tnetv107x/hardware.h @@ -0,0 +1,184 @@ +/* + * TNETV107X: Hardware information + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +#ifndef __ASM_ARCH_HARDWARE_H +#define __ASM_ARCH_HARDWARE_H + +#ifndef __ASSEMBLY__ + +#include <asm/sizes.h> + +#define DIV_CEILING(num, den) ((((num)+(den)-1)/(den))-1) +#define DIV_FLOOR(num, den) (((num)/(den))-1) +#define ABS(x) (((x) < 0) ? -(x) : (x)) + +#define ASYNC_EMIF_PRESERVE -1 +struct async_emif_config { + unsigned mode; + unsigned select_strobe; + unsigned extend_wait; + unsigned wr_setup; + unsigned wr_strobe; + unsigned wr_hold; + unsigned rd_setup; + unsigned rd_strobe; + unsigned rd_hold; + unsigned turn_around; + enum { + ASYNC_EMIF_8 = 0, + ASYNC_EMIF_16 = 1, + ASYNC_EMIF_32 = 2, + } width; +}; + +void init_plls(void); +void clk_delay(void); + +void init_async_emif(void); +void suspend_async_emif(void); +void restore_async_emif(void); + +void init_timer(void); +void suspend_timer(void); +void restore_timer(void); + +void init_wdt(void); +void suspend_wdt(void); +void restore_wdt(void); +int wdt_start(unsigned long msecs); +int wdt_stop(void); +int wdt_kick(void); + +#endif + +/* Chip configuration unlock codes and registers */ +#define TNETV107X_KICK0 (TNETV107X_CHIP_CONFIG_SYS_BASE+0x38) +#define TNETV107X_KICK1 (TNETV107X_CHIP_CONFIG_SYS_BASE+0x3c) +#define TNETV107X_PINMUX(n) (TNETV107X_CHIP_CONFIG_SYS_BASE+0x150+(n)*4) +#define TNETV107X_KICK0_MAGIC 0x83e70b13 +#define TNETV107X_KICK1_MAGIC 0x95a4f1e0 + +/* Module base addresses */ +#define TNETV107X_TPCC_BASE 0x01C00000 +#define TNETV107X_TPTC0_BASE 0x01C10000 +#define TNETV107X_TPTC1_BASE 0x01C10400 +#define TNETV107X_INTC_BASE 0x03000000 +#define TNETV107X_LCD_CONTROLLER_BASE 0x08030000 +#define TNETV107X_INTD_BASE 0x08038000 +#define TNETV107X_INTD_IPC_BASE 0x08038000 +#define TNETV107X_INTD_FAST_BASE 0x08039000 +#define TNETV107X_INTD_ASYNC_BASE 0x0803A000 +#define TNETV107X_INTD_SLOW_BASE 0x0803B000 +#define TNETV107X_PKA_BASE 0x08040000 +#define TNETV107X_RNG_BASE 0x08044000 +#define TNETV107X_TIMER0_BASE 0x08086500 +#define TNETV107X_TIMER1_BASE 0x08086600 +#define TNETV107X_WDT0_ARM_BASE 0x08086700 +#define TNETV107X_WDT1_DSP_BASE 0x08086800 +#define TNETV107X_CHIP_CONFIG_SYS_BASE 0x08087000 +#define TNETV107X_GPIO_BASE 0x08088000 +#define TNETV107X_UART1_BASE 0x08088400 +#define TNETV107X_TOUCHSCREEN_BASE 0x08088500 +#define TNETV107X_SDIO0_BASE 0x08088700 +#define TNETV107X_SDIO1_BASE 0x08088800 +#define TNETV107X_MDIO_BASE 0x08088900 +#define TNETV107X_KEYPAD_BASE 0x08088A00 +#define TNETV107X_SSP_BASE 0x08088C00 +#define TNETV107X_CLOCK_CONTROL_BASE 0x0808A000 +#define TNETV107X_PSC_BASE 0x0808B000 +#define TNETV107X_TDM0_BASE 0x08100000 +#define TNETV107X_TDM1_BASE 0x08100100 +#define TNETV107X_MCDMA_BASE 0x08108000 +#define TNETV107X_UART0_DMA_BASE 0x08108200 +#define TNETV107X_USBSS_BASE 0x08120000 +#define TNETV107X_VLYNQ_CONTROL_BASE 0x0810D000 +#define TNETV107X_ASYNC_EMIF_CNTRL_BASE 0x08200000 +#define TNETV107X_VLYNQ_MEM_MAP_BASE 0x0C000000 +#define TNETV107X_IMCOP_BASE 0x01CC0000 +#define TNETV107X_MBX_LITE_BASE 0x07000000 +#define TNETV107X_ETHSS_BASE 0x0803C000 +#define TNETV107X_CPSW_BASE 0x0803C000 +#define TNETV107X_SPF_BASE 0x0803C800 +#define TNETV107X_IOPU_ETHSS_BASE 0x0803D000 +#define TNETV107X_VTP_CNTRL_0 0x0803D800 +#define TNETV107X_VTP_CNTRL_1 0x0803D900 +#define TNETV107X_UART2_DMA_BASE 0x08108400 +#define TNETV107X_INTERNAL_MEMORY 0x20000000 +#define TNETV107X_ASYNC_EMIF_DATA_CE0_BASE 0x30000000 +#define TNETV107X_ASYNC_EMIF_DATA_CE1_BASE 0x40000000 +#define TNETV107X_ASYNC_EMIF_DATA_CE2_BASE 0x44000000 +#define TNETV107X_ASYNC_EMIF_DATA_CE3_BASE 0x48000000 +#define TNETV107X_DDR_EMIF_DATA_BASE 0x80000000 +#define TNETV107X_DDR_EMIF_CONTROL_BASE 0x90000000 + +/* LPSC module definitions */ +#define TNETV107X_LPSC_ARM 0 +#define TNETV107X_LPSC_GEM 1 +#define TNETV107X_LPSC_DDR2_PHY 2 +#define TNETV107X_LPSC_TPCC 3 +#define TNETV107X_LPSC_TPTC0 4 +#define TNETV107X_LPSC_TPTC1 5 +#define TNETV107X_LPSC_RAM 6 +#define TNETV107X_LPSC_MBX_LITE 7 +#define TNETV107X_LPSC_LCD 8 +#define TNETV107X_LPSC_ETHSS 9 +#define TNETV107X_LPSC_AEMIF 10 +#define TNETV107X_LPSC_CHIP_CFG 11 +#define TNETV107X_LPSC_TSC 12 +#define TNETV107X_LPSC_ROM 13 +#define TNETV107X_LPSC_UART2 14 +#define TNETV107X_LPSC_PKTSEC 15 +#define TNETV107X_LPSC_SECCTL 16 +#define TNETV107X_LPSC_KEYMGR 17 +#define TNETV107X_LPSC_KEYPAD 18 +#define TNETV107X_LPSC_GPIO 19 +#define TNETV107X_LPSC_MDIO 20 +#define TNETV107X_LPSC_SDIO0 21 +#define TNETV107X_LPSC_UART0 22 +#define TNETV107X_LPSC_UART1 23 +#define TNETV107X_LPSC_TIMER0 24 +#define TNETV107X_LPSC_TIMER1 25 +#define TNETV107X_LPSC_WDT_ARM 26 +#define TNETV107X_LPSC_WDT_DSP 27 +#define TNETV107X_LPSC_SSP 28 +#define TNETV107X_LPSC_TDM0 29 +#define TNETV107X_LPSC_VLYNQ 30 +#define TNETV107X_LPSC_MCDMA 31 +#define TNETV107X_LPSC_USB0 32 +#define TNETV107X_LPSC_TDM1 33 +#define TNETV107X_LPSC_DEBUGSS 34 +#define TNETV107X_LPSC_ETHSS_RGMII 35 +#define TNETV107X_LPSC_SYSTEM 36 +#define TNETV107X_LPSC_IMCOP 37 +#define TNETV107X_LPSC_SPARE 38 +#define TNETV107X_LPSC_SDIO1 39 +#define TNETV107X_LPSC_USB1 40 +#define TNETV107X_LPSC_USBSS 41 +#define TNETV107X_LPSC_DDR2_EMIF1_VRST 42 +#define TNETV107X_LPSC_DDR2_EMIF2_VCTL_RST 43 +#define TNETV107X_LPSC_MAX 44 + +/* Interrupt controller */ +#define INTC_GLB_EN (TNETV107X_INTC_BASE + 0x10) +#define INTC_HINT_EN (TNETV107X_INTC_BASE + 0x1500) +#define INTC_EN_CLR0 (TNETV107X_INTC_BASE + 0x380) + +#endif /* __ASM_ARCH_HARDWARE_H */ diff --git a/arch/arm/include/asm/arch-tnetv107x/mux.h b/arch/arm/include/asm/arch-tnetv107x/mux.h new file mode 100644 index 0000000..274c037 --- /dev/null +++ b/arch/arm/include/asm/arch-tnetv107x/mux.h @@ -0,0 +1,307 @@ +/* + * TNETV107X: Pinmux APIs + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +#ifndef __ASM_ARCH_MUX_H +#define __ASM_ARCH_MUX_H + +struct pin_config { + unsigned char reg_index; + unsigned char mask_offset; + unsigned char mode; +}; + +#define TNETV107X_MUX_CFG(reg, offset, mux_mode) \ + { reg, offset, mux_mode } + +int mux_select_pin(unsigned index); +int mux_select_pins(const short *pins); +int mux_select_module(int lpsc); + +enum tnetv107x_pin_mux_index { + TNETV107X_PIN_ASR_A00, + TNETV107X_PIN_GPIO32, + TNETV107X_PIN_ASR_A01, + TNETV107X_PIN_GPIO33, + TNETV107X_PIN_ASR_A02, + TNETV107X_PIN_GPIO34, + TNETV107X_PIN_ASR_A03, + TNETV107X_PIN_GPIO35, + TNETV107X_PIN_ASR_A04, + TNETV107X_PIN_GPIO36, + TNETV107X_PIN_ASR_A05, + TNETV107X_PIN_GPIO37, + TNETV107X_PIN_ASR_A06, + TNETV107X_PIN_GPIO38, + TNETV107X_PIN_ASR_A07, + TNETV107X_PIN_GPIO39, + TNETV107X_PIN_ASR_A08, + TNETV107X_PIN_GPIO40, + TNETV107X_PIN_ASR_A09, + TNETV107X_PIN_GPIO41, + TNETV107X_PIN_ASR_A10, + TNETV107X_PIN_GPIO42, + TNETV107X_PIN_ASR_A11, + TNETV107X_PIN_BOOT_STRP_0, + TNETV107X_PIN_ASR_A12, + TNETV107X_PIN_BOOT_STRP_1, + TNETV107X_PIN_ASR_A13, + TNETV107X_PIN_GPIO43, + TNETV107X_PIN_ASR_A14, + TNETV107X_PIN_GPIO44, + TNETV107X_PIN_ASR_A15, + TNETV107X_PIN_GPIO45, + TNETV107X_PIN_ASR_A16, + TNETV107X_PIN_GPIO46, + TNETV107X_PIN_ASR_A17, + TNETV107X_PIN_GPIO47, + TNETV107X_PIN_ASR_A18, + TNETV107X_PIN_GPIO48, + TNETV107X_PIN_SDIO1_DATA3_0, + TNETV107X_PIN_ASR_A19, + TNETV107X_PIN_GPIO49, + TNETV107X_PIN_SDIO1_DATA2_0, + TNETV107X_PIN_ASR_A20, + TNETV107X_PIN_GPIO50, + TNETV107X_PIN_SDIO1_DATA1_0, + TNETV107X_PIN_ASR_A21, + TNETV107X_PIN_GPIO51, + TNETV107X_PIN_SDIO1_DATA0_0, + TNETV107X_PIN_ASR_A22, + TNETV107X_PIN_GPIO52, + TNETV107X_PIN_SDIO1_CMD_0, + TNETV107X_PIN_ASR_A23, + TNETV107X_PIN_GPIO53, + TNETV107X_PIN_SDIO1_CLK_0, + TNETV107X_PIN_ASR_BA_1, + TNETV107X_PIN_GPIO54, + TNETV107X_PIN_SYS_PLL_CLK, + TNETV107X_PIN_ASR_CS0, + TNETV107X_PIN_ASR_CS1, + TNETV107X_PIN_ASR_CS2, + TNETV107X_PIN_TDM_PLL_CLK, + TNETV107X_PIN_ASR_CS3, + TNETV107X_PIN_ETH_PHY_CLK, + TNETV107X_PIN_ASR_D00, + TNETV107X_PIN_GPIO55, + TNETV107X_PIN_ASR_D01, + TNETV107X_PIN_GPIO56, + TNETV107X_PIN_ASR_D02, + TNETV107X_PIN_GPIO57, + TNETV107X_PIN_ASR_D03, + TNETV107X_PIN_GPIO58, + TNETV107X_PIN_ASR_D04, + TNETV107X_PIN_GPIO59_0, + TNETV107X_PIN_ASR_D05, + TNETV107X_PIN_GPIO60_0, + TNETV107X_PIN_ASR_D06, + TNETV107X_PIN_GPIO61_0, + TNETV107X_PIN_ASR_D07, + TNETV107X_PIN_GPIO62_0, + TNETV107X_PIN_ASR_D08, + TNETV107X_PIN_GPIO63_0, + TNETV107X_PIN_ASR_D09, + TNETV107X_PIN_GPIO64_0, + TNETV107X_PIN_ASR_D10, + TNETV107X_PIN_SDIO1_DATA3_1, + TNETV107X_PIN_ASR_D11, + TNETV107X_PIN_SDIO1_DATA2_1, + TNETV107X_PIN_ASR_D12, + TNETV107X_PIN_SDIO1_DATA1_1, + TNETV107X_PIN_ASR_D13, + TNETV107X_PIN_SDIO1_DATA0_1, + TNETV107X_PIN_ASR_D14, + TNETV107X_PIN_SDIO1_CMD_1, + TNETV107X_PIN_ASR_D15, + TNETV107X_PIN_SDIO1_CLK_1, + TNETV107X_PIN_ASR_OE, + TNETV107X_PIN_BOOT_STRP_2, + TNETV107X_PIN_ASR_RNW, + TNETV107X_PIN_GPIO29_0, + TNETV107X_PIN_ASR_WAIT, + TNETV107X_PIN_GPIO30_0, + TNETV107X_PIN_ASR_WE, + TNETV107X_PIN_BOOT_STRP_3, + TNETV107X_PIN_ASR_WE_DQM0, + TNETV107X_PIN_GPIO31, + TNETV107X_PIN_LCD_PD17_0, + TNETV107X_PIN_ASR_WE_DQM1, + TNETV107X_PIN_ASR_BA0_0, + TNETV107X_PIN_VLYNQ_CLK, + TNETV107X_PIN_GPIO14, + TNETV107X_PIN_LCD_PD19_0, + TNETV107X_PIN_VLYNQ_RXD0, + TNETV107X_PIN_GPIO15, + TNETV107X_PIN_LCD_PD20_0, + TNETV107X_PIN_VLYNQ_RXD1, + TNETV107X_PIN_GPIO16, + TNETV107X_PIN_LCD_PD21_0, + TNETV107X_PIN_VLYNQ_TXD0, + TNETV107X_PIN_GPIO17, + TNETV107X_PIN_LCD_PD22_0, + TNETV107X_PIN_VLYNQ_TXD1, + TNETV107X_PIN_GPIO18, + TNETV107X_PIN_LCD_PD23_0, + TNETV107X_PIN_SDIO0_CLK, + TNETV107X_PIN_GPIO19, + TNETV107X_PIN_SDIO0_CMD, + TNETV107X_PIN_GPIO20, + TNETV107X_PIN_SDIO0_DATA0, + TNETV107X_PIN_GPIO21, + TNETV107X_PIN_SDIO0_DATA1, + TNETV107X_PIN_GPIO22, + TNETV107X_PIN_SDIO0_DATA2, + TNETV107X_PIN_GPIO23, + TNETV107X_PIN_SDIO0_DATA3, + TNETV107X_PIN_GPIO24, + TNETV107X_PIN_EMU0, + TNETV107X_PIN_EMU1, + TNETV107X_PIN_RTCK, + TNETV107X_PIN_TRST_N, + TNETV107X_PIN_TCK, + TNETV107X_PIN_TDI, + TNETV107X_PIN_TDO, + TNETV107X_PIN_TMS, + TNETV107X_PIN_TDM1_CLK, + TNETV107X_PIN_TDM1_RX, + TNETV107X_PIN_TDM1_TX, + TNETV107X_PIN_TDM1_FS, + TNETV107X_PIN_KEYPAD_R0, + TNETV107X_PIN_KEYPAD_R1, + TNETV107X_PIN_KEYPAD_R2, + TNETV107X_PIN_KEYPAD_R3, + TNETV107X_PIN_KEYPAD_R4, + TNETV107X_PIN_KEYPAD_R5, + TNETV107X_PIN_KEYPAD_R6, + TNETV107X_PIN_GPIO12, + TNETV107X_PIN_KEYPAD_R7, + TNETV107X_PIN_GPIO10, + TNETV107X_PIN_KEYPAD_C0, + TNETV107X_PIN_KEYPAD_C1, + TNETV107X_PIN_KEYPAD_C2, + TNETV107X_PIN_KEYPAD_C3, + TNETV107X_PIN_KEYPAD_C4, + TNETV107X_PIN_KEYPAD_C5, + TNETV107X_PIN_KEYPAD_C6, + TNETV107X_PIN_GPIO13, + TNETV107X_PIN_TEST_CLK_IN, + TNETV107X_PIN_KEYPAD_C7, + TNETV107X_PIN_GPIO11, + TNETV107X_PIN_SSP0_0, + TNETV107X_PIN_SCC_DCLK, + TNETV107X_PIN_LCD_PD20_1, + TNETV107X_PIN_SSP0_1, + TNETV107X_PIN_SCC_CS_N, + TNETV107X_PIN_LCD_PD21_1, + TNETV107X_PIN_SSP0_2, + TNETV107X_PIN_SCC_D, + TNETV107X_PIN_LCD_PD22_1, + TNETV107X_PIN_SSP0_3, + TNETV107X_PIN_SCC_RESETN, + TNETV107X_PIN_LCD_PD23_1, + TNETV107X_PIN_SSP1_0, + TNETV107X_PIN_GPIO25, + TNETV107X_PIN_UART2_CTS, + TNETV107X_PIN_SSP1_1, + TNETV107X_PIN_GPIO26, + TNETV107X_PIN_UART2_RD, + TNETV107X_PIN_SSP1_2, + TNETV107X_PIN_GPIO27, + TNETV107X_PIN_UART2_RTS, + TNETV107X_PIN_SSP1_3, + TNETV107X_PIN_GPIO28, + TNETV107X_PIN_UART2_TD, + TNETV107X_PIN_UART0_CTS, + TNETV107X_PIN_UART0_RD, + TNETV107X_PIN_UART0_RTS, + TNETV107X_PIN_UART0_TD, + TNETV107X_PIN_UART1_RD, + TNETV107X_PIN_UART1_TD, + TNETV107X_PIN_LCD_AC_NCS, + TNETV107X_PIN_LCD_HSYNC_RNW, + TNETV107X_PIN_LCD_VSYNC_A0, + TNETV107X_PIN_LCD_MCLK, + TNETV107X_PIN_LCD_PD16_0, + TNETV107X_PIN_LCD_PCLK_E, + TNETV107X_PIN_LCD_PD00, + TNETV107X_PIN_LCD_PD01, + TNETV107X_PIN_LCD_PD02, + TNETV107X_PIN_LCD_PD03, + TNETV107X_PIN_LCD_PD04, + TNETV107X_PIN_LCD_PD05, + TNETV107X_PIN_LCD_PD06, + TNETV107X_PIN_LCD_PD07, + TNETV107X_PIN_LCD_PD08, + TNETV107X_PIN_GPIO59_1, + TNETV107X_PIN_LCD_PD09, + TNETV107X_PIN_GPIO60_1, + TNETV107X_PIN_LCD_PD10, + TNETV107X_PIN_ASR_BA0_1, + TNETV107X_PIN_GPIO61_1, + TNETV107X_PIN_LCD_PD11, + TNETV107X_PIN_GPIO62_1, + TNETV107X_PIN_LCD_PD12, + TNETV107X_PIN_GPIO63_1, + TNETV107X_PIN_LCD_PD13, + TNETV107X_PIN_GPIO64_1, + TNETV107X_PIN_LCD_PD14, + TNETV107X_PIN_GPIO29_1, + TNETV107X_PIN_LCD_PD15, + TNETV107X_PIN_GPIO30_1, + TNETV107X_PIN_EINT0, + TNETV107X_PIN_GPIO08, + TNETV107X_PIN_EINT1, + TNETV107X_PIN_GPIO09, + TNETV107X_PIN_GPIO00, + TNETV107X_PIN_LCD_PD20_2, + TNETV107X_PIN_TDM_CLK_IN_2, + TNETV107X_PIN_GPIO01, + TNETV107X_PIN_LCD_PD21_2, + TNETV107X_PIN_24M_CLK_OUT_1, + TNETV107X_PIN_GPIO02, + TNETV107X_PIN_LCD_PD22_2, + TNETV107X_PIN_GPIO03, + TNETV107X_PIN_LCD_PD23_2, + TNETV107X_PIN_GPIO04, + TNETV107X_PIN_LCD_PD16_1, + TNETV107X_PIN_USB0_RXERR, + TNETV107X_PIN_GPIO05, + TNETV107X_PIN_LCD_PD17_1, + TNETV107X_PIN_TDM_CLK_IN_1, + TNETV107X_PIN_GPIO06, + TNETV107X_PIN_LCD_PD18, + TNETV107X_PIN_24M_CLK_OUT_2, + TNETV107X_PIN_GPIO07, + TNETV107X_PIN_LCD_PD19_1, + TNETV107X_PIN_USB1_RXERR, + TNETV107X_PIN_ETH_PLL_CLK, + TNETV107X_PIN_MDIO, + TNETV107X_PIN_MDC, + TNETV107X_PIN_AIC_MUTE_STAT_N, + TNETV107X_PIN_TDM0_CLK, + TNETV107X_PIN_AIC_HNS_EN_N, + TNETV107X_PIN_TDM0_FS, + TNETV107X_PIN_AIC_HDS_EN_STAT_N, + TNETV107X_PIN_TDM0_TX, + TNETV107X_PIN_AIC_HNF_EN_STAT_N, + TNETV107X_PIN_TDM0_RX, +}; + +#endif diff --git a/arch/arm/include/asm/arch-tnetv107x/nand_defs.h b/arch/arm/include/asm/arch-tnetv107x/nand_defs.h new file mode 100644 index 0000000..961b710 --- /dev/null +++ b/arch/arm/include/asm/arch-tnetv107x/nand_defs.h @@ -0,0 +1,38 @@ +/* + * TNETV107X: NAND definitions + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ +#ifndef _NAND_DEFS_H_ +#define _NAND_DEFS_H_ + +#include <asm/arch/hardware.h> +#include <asm/arch/emif_defs.h> + +#define DAVINCI_ASYNC_EMIF_CNTRL_BASE TNETV107X_ASYNC_EMIF_CNTRL_BASE + +#define MASK_CLE 0x4000 +#define MASK_ALE 0x2000 + +#define NAND_READ_START 0x00 +#define NAND_READ_END 0x30 +#define NAND_STATUS 0x70 + +extern void davinci_nand_init(struct nand_chip *nand); + +#endif
TNETV107X is a Texas Instruments SoC based on an ARM1176 core, and with a bunch on on-chip integrated peripherals. This patch adds support for the TNETV107X EVM board.
Signed-off-by: Cyril Chemparathy cyril@ti.com --- v5: rebased on master in u-boot-arm.git (unchanged) v4: rebased on next in u-boot-arm.git (unchanged) v3: Added NAND MTDID comment in board config v2: Added maintainers entry v2: Fixed sort order in main makefile v2: Remove board specific linker script v2: Style fixes - multiline comments v2: Replaced clk_get() with clk_get_rate()
MAINTAINERS | 4 + MAKEALL | 1 + Makefile | 3 + board/ti/tnetv107xevm/Makefile | 49 +++++++++ board/ti/tnetv107xevm/config.mk | 20 ++++ board/ti/tnetv107xevm/sdb_board.c | 66 +++++++++++ include/configs/tnetv107x_evm.h | 214 +++++++++++++++++++++++++++++++++++++ 7 files changed, 357 insertions(+), 0 deletions(-) create mode 100644 board/ti/tnetv107xevm/Makefile create mode 100644 board/ti/tnetv107xevm/config.mk create mode 100644 board/ti/tnetv107xevm/sdb_board.c create mode 100644 include/configs/tnetv107x_evm.h
diff --git a/MAINTAINERS b/MAINTAINERS index 0e759c9..44369fe 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -62,6 +62,10 @@ Oliver Brown obrown@adventnetworks.com
gw8260 MPC8260
+Cyril Chemparathy cyril@ti.com + + tnetv107x_evm tnetv107x + Conn Clark clark@esteem.com
ESTEEM192E MPC8xx diff --git a/MAKEALL b/MAKEALL index b15d407..e10fead 100755 --- a/MAKEALL +++ b/MAKEALL @@ -625,6 +625,7 @@ LIST_ARM11=" \ mx31pdk_nand \ qong \ smdk6400 \ + tnetv107x_evm \ "
######################################################################### diff --git a/Makefile b/Makefile index 8b4e0b9..92aa3be 100644 --- a/Makefile +++ b/Makefile @@ -3319,6 +3319,9 @@ smdk6400_config : unconfig fi @echo "CONFIG_NAND_U_BOOT = y" >> $(obj)include/config.mk
+tnetv107x_evm_config: unconfig + @$(MKCONFIG) $(@:_config=) arm arm1176 tnetv107xevm ti tnetv107x + #======================================================================== # i386 #======================================================================== diff --git a/board/ti/tnetv107xevm/Makefile b/board/ti/tnetv107xevm/Makefile new file mode 100644 index 0000000..2446c2a --- /dev/null +++ b/board/ti/tnetv107xevm/Makefile @@ -0,0 +1,49 @@ +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or modify +# it under the terms of the GNU General Public License as published by +# the Free Software Foundation; either version 2 of the License, or +# (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS += sdb_board.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +.PHONY: all + +all: $(LIB) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) $(SOBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak *~ .depend + +######################################################################### +# This is for $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/ti/tnetv107xevm/config.mk b/board/ti/tnetv107xevm/config.mk new file mode 100644 index 0000000..d24d49a --- /dev/null +++ b/board/ti/tnetv107xevm/config.mk @@ -0,0 +1,20 @@ +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or modify +# it under the terms of the GNU General Public License as published by +# the Free Software Foundation; either version 2 of the License, or +# (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. +# + +TEXT_BASE = 0x83FC0000 diff --git a/board/ti/tnetv107xevm/sdb_board.c b/board/ti/tnetv107xevm/sdb_board.c new file mode 100644 index 0000000..fa7b49c --- /dev/null +++ b/board/ti/tnetv107xevm/sdb_board.c @@ -0,0 +1,66 @@ +/* + * TNETV107X-EVM: Board initialization + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +#include <common.h> +#include <miiphy.h> +#include <linux/mtd/nand.h> +#include <asm/arch/hardware.h> +#include <asm/arch/clock.h> +#include <asm/io.h> +#include <asm/mach-types.h> +#include <asm/arch/nand_defs.h> + +DECLARE_GLOBAL_DATA_PTR; + +int board_init(void) +{ +#ifndef CONFIG_USE_IRQ + __raw_writel(0, INTC_GLB_EN); /* Global disable */ + __raw_writel(0, INTC_HINT_EN); /* Disable host ints */ + __raw_writel(0, INTC_EN_CLR0 + 0); /* Clear enable */ + __raw_writel(0, INTC_EN_CLR0 + 4); /* Clear enable */ + __raw_writel(0, INTC_EN_CLR0 + 8); /* Clear enable */ +#endif + + gd->bd->bi_arch_number = MACH_TYPE_TNETV107X; + gd->bd->bi_boot_params = LINUX_BOOT_PARAM_ADDR; + + clk_enable(TNETV107X_LPSC_WDT_ARM); + + return 0; +} + +int dram_init(void) +{ + gd->bd->bi_dram[0].start = PHYS_SDRAM_1; + gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; + + return 0; +} + +#ifdef CONFIG_NAND_DAVINCI +int board_nand_init(struct nand_chip *nand) +{ + davinci_nand_init(nand); + + return 0; +} +#endif diff --git a/include/configs/tnetv107x_evm.h b/include/configs/tnetv107x_evm.h new file mode 100644 index 0000000..812ffb7 --- /dev/null +++ b/include/configs/tnetv107x_evm.h @@ -0,0 +1,214 @@ +/* + * Copyright (C) 2008 Texas Instruments, Inc <www.ti.com> + * + * Based on davinci_dvevm.h. Original Copyrights follow: + * + * Copyright (C) 2007 Sergey Kubushyn ksi@koi8.net + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#include <asm/sizes.h> +#include <asm/arch/hardware.h> +#include <asm/arch/clock.h> + +/* Architecture, CPU, etc */ +#define CONFIG_ARM1176 +#define CONFIG_TNETV107X +#define CONFIG_TNETV107X_EVM +#define CONFIG_ARCH_CPU_INIT +#define CONFIG_SYS_UBOOT_BASE TEXT_BASE +#define CONFIG_DISABLE_TCM +#define CONFIG_PERIPORT_REMAP +#define CONFIG_PERIPORT_BASE 0x2000000 +#define CONFIG_PERIPORT_SIZE 0x10 +#define CONFIG_SYS_MON_DEBUG +#define CONFIG_SYS_INT_OSC_FREQ 24000000 +#define CONFIG_SYS_CLK_FREQ clk_get_rate(TNETV107X_LPSC_ARM) + +/* PLL Configuration */ +#define CONFIG_PLL_SYS_CONFIG 0 +#define CONFIG_PLL_SYS_INT_OSC 1 +#define CONFIG_PLL_SYS_EXT_FREQ 25000000 +#define CONFIG_PLL_TDM_CONFIG 0 +#define CONFIG_PLL_TDM_INT_OSC 1 +#define CONFIG_PLL_TDM_EXT_FREQ 19200000 +#define CONFIG_PLL_ETH_CONFIG 1 +#define CONFIG_PLL_ETH_INT_OSC 1 +#define CONFIG_PLL_ETH_EXT_FREQ 25000000 +#define CONFIG_PLL_ETH_PLL_FREQ 500000000 +#define CONFIG_PLL_ETH_5_CLK 5000000 +#define CONFIG_PLL_ETH_50_CLK 50000000 +#define CONFIG_PLL_ETH_125_CLK 125000000 +#define CONFIG_PLL_ETH_250_CLK 250000000 +#define CONFIG_PLL_ETH_25_CLK 25000000 + +/* Async EMIF Configuration */ +#define ASYNC_EMIF_MODE_NOR 0 +#define ASYNC_EMIF_MODE_NAND 1 +#define ASYNC_EMIF_MODE_ONENAND 2 + +#define ASYNC_EMIF_CS0_SELECT_STROBE 0 +#define ASYNC_EMIF_CS0_EXTEND_WAIT 0 +#define ASYNC_EMIF_CS0_WR_SETUP 5 /* cycles */ +#define ASYNC_EMIF_CS0_WR_STROBE 5 /* cycles */ +#define ASYNC_EMIF_CS0_WR_HOLD 2 /* cycles */ +#define ASYNC_EMIF_CS0_RD_SETUP 5 /* cycles */ +#define ASYNC_EMIF_CS0_RD_STROBE 5 /* cycles */ +#define ASYNC_EMIF_CS0_RD_HOLD 2 /* cycles */ +#define ASYNC_EMIF_CS0_TURN_AROUND 5 /* cycles */ +#define ASYNC_EMIF_CS0_WIDTH ASYNC_EMIF_8 + +#define ASYNC_EMIF_CS1_SELECT_STROBE 0 +#define ASYNC_EMIF_CS1_EXTEND_WAIT 0 +#define ASYNC_EMIF_CS1_WR_SETUP 2 /* cycles */ +#define ASYNC_EMIF_CS1_WR_STROBE 27 /* cycles */ +#define ASYNC_EMIF_CS1_WR_HOLD 4 /* cycles */ +#define ASYNC_EMIF_CS1_RD_SETUP 2 /* cycles */ +#define ASYNC_EMIF_CS1_RD_STROBE 27 /* cycles */ +#define ASYNC_EMIF_CS1_RD_HOLD 4 /* cycles */ +#define ASYNC_EMIF_CS1_TURN_AROUND 2 /* cycles */ +#define ASYNC_EMIF_CS1_WIDTH ASYNC_EMIF_PRESERVE + +#define ASYNC_EMIF_CS2_SELECT_STROBE 0 +#define ASYNC_EMIF_CS2_EXTEND_WAIT 0 +#define ASYNC_EMIF_CS2_WR_SETUP 2 /* cycles */ +#define ASYNC_EMIF_CS2_WR_STROBE 27 /* cycles */ +#define ASYNC_EMIF_CS2_WR_HOLD 4 /* cycles */ +#define ASYNC_EMIF_CS2_RD_SETUP 2 /* cycles */ +#define ASYNC_EMIF_CS2_RD_STROBE 27 /* cycles */ +#define ASYNC_EMIF_CS2_RD_HOLD 4 /* cycles */ +#define ASYNC_EMIF_CS2_TURN_AROUND 2 /* cycles */ +#define ASYNC_EMIF_CS2_WIDTH ASYNC_EMIF_PRESERVE + +#define ASYNC_EMIF_CS3_SELECT_STROBE 0 +#define ASYNC_EMIF_CS3_EXTEND_WAIT 0 +#define ASYNC_EMIF_CS3_WR_SETUP 1 /* cycles */ +#define ASYNC_EMIF_CS3_WR_STROBE 90 /* cycles */ +#define ASYNC_EMIF_CS3_WR_HOLD 3 /* cycles */ +#define ASYNC_EMIF_CS3_RD_SETUP 1 /* cycles */ +#define ASYNC_EMIF_CS3_RD_STROBE 26 /* cycles */ +#define ASYNC_EMIF_CS3_RD_HOLD 3 /* cycles */ +#define ASYNC_EMIF_CS3_TURN_AROUND 1 /* cycles */ +#define ASYNC_EMIF_CS3_WIDTH ASYNC_EMIF_8 + +#define CONFIG_SYS_TIMERBASE TNETV107X_TIMER0_BASE +#define CONFIG_SYS_HZ_CLOCK clk_get_rate(TNETV107X_LPSC_TIMER0) +#define CONFIG_SYS_HZ 1000 + +/* Memory Info */ +#define CONFIG_SYS_MALLOC_LEN (0x10000 + 1*1024*1024) +#define CONFIG_SYS_GBL_DATA_SIZE 128 +#define PHYS_SDRAM_1 TNETV107X_DDR_EMIF_DATA_BASE +#define PHYS_SDRAM_1_SIZE 0x04000000 +#define CONFIG_SYS_MEMTEST_START PHYS_SDRAM_1 +#define CONFIG_SYS_MEMTEST_END (PHYS_SDRAM_1 + 16*1024*1024) +#define CONFIG_NR_DRAM_BANKS 1 +#define CONFIG_STACKSIZE (256*1024) + +/* Serial Driver Info */ +#define CONFIG_SYS_NS16550 +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_SYS_NS16550_REG_SIZE -4 +#define CONFIG_SYS_NS16550_COM1 TNETV107X_UART1_BASE +#define CONFIG_SYS_NS16550_CLK clk_get_rate(TNETV107X_LPSC_UART1) +#define CONFIG_CONS_INDEX 1 +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } + +/* Flash and environment info */ +#define CONFIG_SYS_NO_FLASH +#define CONFIG_ENV_IS_IN_NAND +#define CONFIG_NAND_DAVINCI +#define CONFIG_ENV_SIZE (SZ_128K) +#define CONFIG_SYS_NAND_HW_ECC +#define CONFIG_SYS_NAND_1BIT_ECC +#define CONFIG_SYS_NAND_CS 2 +#define CONFIG_SYS_NAND_BASE TNETV107X_ASYNC_EMIF_DATA_CE0_BASE +#define CONFIG_SYS_CLE_MASK 0x10 +#define CONFIG_SYS_ALE_MASK 0x8 +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_MTD_PARTITIONS +#define CONFIG_CMD_MTDPARTS +#define CONFIG_MTD_DEVICE +#define NAND_MAX_CHIPS 1 +#define CONFIG_ENV_OFFSET 0x180000 +#define DEF_BOOTM "" + +/* + * davinci_nand is a bit of a misnomer since this particular EMIF block is + * commonly used across multiple TI devices. Unfortunately, this misnomer + * (amongst others) carries forward into the kernel too. Consequently, if we + * use a different device name here, the mtdparts variable won't be usable as + * a kernel command-line argument. + */ +#define MTDIDS_DEFAULT "nand0=davinci_nand.0" +#define MTDPARTS_DEFAULT "mtdparts=davinci_nand.0:" \ + "1536k(uboot)ro," \ + "128k(params)ro," \ + "4m(kernel)," \ + "-(filesystem)" + +/* General U-Boot configuration */ +#define CONFIG_BOOTFILE "uImage" +#define CONFIG_SYS_PROMPT "U-Boot > " +#define CONFIG_SYS_CBSIZE 1024 +#define CONFIG_SYS_MAXARGS 64 +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE +#define CONFIG_VERSION_VARIABLE +#define CONFIG_AUTO_COMPLETE +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " +#define CONFIG_CMDLINE_EDITING +#define CONFIG_SYS_LONGHELP +#define CONFIG_CRC32_VERIFY +#define CONFIG_MX_CYCLIC +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_MEMTEST_START + \ + 0x700000) +#define LINUX_BOOT_PARAM_ADDR (CONFIG_SYS_MEMTEST_START + 0x100) +#define CONFIG_CMDLINE_TAG +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_BOOTARGS "mem=32M console=ttyS1,115200n8 " \ + "root=/dev/mmcblk0p1 rw noinitrd" +#define CONFIG_BOOTCOMMAND "" +#define CONFIG_BOOTDELAY 1 + +#define CONFIG_CMD_BDI +#define CONFIG_CMD_BOOTD +#define CONFIG_CMD_CONSOLE +#define CONFIG_CMD_ECHO +#define CONFIG_CMD_EDITENV +#define CONFIG_CMD_IMI +#define CONFIG_CMD_ITEST +#define CONFIG_CMD_LOADB +#define CONFIG_CMD_LOADS +#define CONFIG_CMD_MEMORY +#define CONFIG_CMD_MISC +#define CONFIG_CMD_RUN +#define CONFIG_CMD_SAVEENV +#define CONFIG_CMD_SOURCE +#define CONFIG_CMD_ENV +#define CONFIG_CMD_ASKENV +#define CONFIG_CMD_SAVES +#define CONFIG_CMD_MEMORY +#define CONFIG_CMD_NAND + +#endif /* __CONFIG_H */
gw8260 MPC8260
- tnetv107x_evm tnetv107x
- tnetv107x_evm \
- @$(MKCONFIG) $(@:_config=) arm arm1176 tnetv107xevm ti tnetv107x
+.PHONY: all
+all: $(LIB)
- $(AR) $(ARFLAGS) $@ $(OBJS) $(SOBJS)
+clean:
- rm -f $(SOBJS) $(OBJS)
+distclean: clean
- rm -f $(LIB) core *.bak *~ .depend
- TNETV107X-EVM: Board initialization
- project.
- This program is free software; you can redistribute it and/or modify
- it under the terms of the GNU General Public License as published by
- the Free Software Foundation; either version 2 of the License, or
- (at your option) any later version.
- Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA.
- __raw_writel(0, INTC_GLB_EN); /* Global disable */
- __raw_writel(0, INTC_HINT_EN); /* Disable host ints */
- __raw_writel(0, INTC_EN_CLR0 + 0); /* Clear enable */
- __raw_writel(0, INTC_EN_CLR0 + 4); /* Clear enable */
- __raw_writel(0, INTC_EN_CLR0 + 8); /* Clear enable */
- gd->bd->bi_arch_number = MACH_TYPE_TNETV107X;
- gd->bd->bi_boot_params = LINUX_BOOT_PARAM_ADDR;
- clk_enable(TNETV107X_LPSC_WDT_ARM);
- gd->bd->bi_dram[0].start = PHYS_SDRAM_1;
- gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE;
- davinci_nand_init(nand);
- Copyright (C) 2008 Texas Instruments, Inc <www.ti.com>
- Based on davinci_dvevm.h. Original Copyrights follow:
- Copyright (C) 2007 Sergey Kubushyn ksi@koi8.net
- MA 02111-1307 USA
Is there a better place to put these #defines? Maybe the board initialization *.c file ?
Fine otherwise Tom
TNETV107X is a Texas Instruments SoC based on an ARM1176 core, and with a bunch on on-chip integrated peripherals. This is an initial commit with basic functionality, more commits with drivers, etc. to follow.
v5: rebased on master in u-boot-arm.git v4: rebased on next in u-boot-arm.git (unchanged) v3: unchanged from v2 v2: macroized aemif configuration to reduce verbosity v2: consolidated lpsc utilities, inlined clock enable/disable
arch/arm/cpu/arm1176/tnetv107x/Makefile | 44 ++ arch/arm/cpu/arm1176/tnetv107x/aemif.c | 151 +++++++ arch/arm/cpu/arm1176/tnetv107x/clock.c | 542 +++++++++++++++++++++++ arch/arm/cpu/arm1176/tnetv107x/init.c | 41 ++ arch/arm/cpu/arm1176/tnetv107x/lowlevel_init.S | 25 + arch/arm/cpu/arm1176/tnetv107x/mux.c | 463 +++++++++++++++++++ arch/arm/cpu/arm1176/tnetv107x/timer.c | 125 ++++++ arch/arm/cpu/arm1176/tnetv107x/wdt.c | 172 +++++++ arch/arm/include/asm/arch-tnetv107x/clock.h | 50 ++ arch/arm/include/asm/arch-tnetv107x/emif_defs.h | 1 + arch/arm/include/asm/arch-tnetv107x/hardware.h | 184 ++++++++ arch/arm/include/asm/arch-tnetv107x/mux.h | 307 +++++++++++++ arch/arm/include/asm/arch-tnetv107x/nand_defs.h | 38 ++ 13 files changed, 2143 insertions(+), 0 deletions(-) create mode 100644 arch/arm/cpu/arm1176/tnetv107x/Makefile create mode 100644 arch/arm/cpu/arm1176/tnetv107x/aemif.c create mode 100644 arch/arm/cpu/arm1176/tnetv107x/clock.c create mode 100644 arch/arm/cpu/arm1176/tnetv107x/init.c create mode 100644 arch/arm/cpu/arm1176/tnetv107x/lowlevel_init.S create mode 100644 arch/arm/cpu/arm1176/tnetv107x/mux.c create mode 100644 arch/arm/cpu/arm1176/tnetv107x/timer.c create mode 100644 arch/arm/cpu/arm1176/tnetv107x/wdt.c create mode 100644 arch/arm/include/asm/arch-tnetv107x/clock.h create mode 100644 arch/arm/include/asm/arch-tnetv107x/emif_defs.h create mode 100644 arch/arm/include/asm/arch-tnetv107x/hardware.h create mode 100644 arch/arm/include/asm/arch-tnetv107x/mux.h create mode 100644 arch/arm/include/asm/arch-tnetv107x/nand_defs.h
diff --git a/arch/arm/cpu/arm1176/tnetv107x/Makefile b/arch/arm/cpu/arm1176/tnetv107x/Makefile new file mode 100644 index 0000000..fe9d8a0 --- /dev/null +++ b/arch/arm/cpu/arm1176/tnetv107x/Makefile @@ -0,0 +1,44 @@ +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or modify +# it under the terms of the GNU General Public License as published by +# the Free Software Foundation; either version 2 of the License, or +# (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. +#
+LIB = $(obj)lib$(SOC).a
+COBJS += aemif.o clock.o init.o mux.o timer.o wdt.o +SOBJS += lowlevel_init.o
+SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c)
+OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) +START := $(addprefix $(obj),$(START))
+all: $(obj).depend $(LIB)
+$(LIB): $(OBJS)
+# defines $(obj).depend target +include $(SRCTREE)/rules.mk
+######################################################################### diff --git a/arch/arm/cpu/arm1176/tnetv107x/aemif.c b/arch/arm/cpu/arm1176/tnetv107x/aemif.c new file mode 100644 index 0000000..ae512b0 --- /dev/null +++ b/arch/arm/cpu/arm1176/tnetv107x/aemif.c @@ -0,0 +1,151 @@ +/*
- TNETV107X: Asynchronous EMIF Configuration
- project.
+#include <common.h> +#include <asm/io.h> +#include <asm/arch/clock.h> +#include <asm/arch/mux.h>
+#define ASYNC_EMIF_BASE TNETV107X_ASYNC_EMIF_CNTRL_BASE +#define ASYNC_EMIF_CONFIG(cs) (ASYNC_EMIF_BASE+0x10+(cs)*4) +#define ASYNC_EMIF_ONENAND_CONTROL (ASYNC_EMIF_BASE+0x5c) +#define ASYNC_EMIF_NAND_CONTROL (ASYNC_EMIF_BASE+0x60) +#define ASYNC_EMIF_WAITCYCLE_CONFIG (ASYNC_EMIF_BASE+0x4)
+#define CONFIG_SELECT_STROBE(v) ((v) ? 1 << 31 : 0) +#define CONFIG_EXTEND_WAIT(v) ((v) ? 1 << 30 : 0) +#define CONFIG_WR_SETUP(v) (((v) & 0x0f) << 26) +#define CONFIG_WR_STROBE(v) (((v) & 0x3f) << 20) +#define CONFIG_WR_HOLD(v) (((v) & 0x07) << 17) +#define CONFIG_RD_SETUP(v) (((v) & 0x0f) << 13) +#define CONFIG_RD_STROBE(v) (((v) & 0x3f) << 7) +#define CONFIG_RD_HOLD(v) (((v) & 0x07) << 4) +#define CONFIG_TURN_AROUND(v) (((v) & 0x03) << 2) +#define CONFIG_WIDTH(v) (((v) & 0x03) << 0)
+#define NUM_CS 4 +#define MASK 0xffffffff
MASK is only used once. It would be ok to just use 0xffffffff here.
+#define set_config_field(reg, field, val) \
- do { \
if (val != -1) { \
reg &= ~CONFIG_##field(MASK); \
reg |= CONFIG_##field(val); \
- } while (0)
+static struct async_emif_config default_async_emif_config[NUM_CS] = {
- { /* CS0 */
.mode = ASYNC_EMIF_MODE_NAND,
.select_strobe = ASYNC_EMIF_CS0_SELECT_STROBE,
.extend_wait = ASYNC_EMIF_CS0_EXTEND_WAIT,
.wr_setup = ASYNC_EMIF_CS0_WR_SETUP,
.wr_strobe = ASYNC_EMIF_CS0_WR_STROBE,
.wr_hold = ASYNC_EMIF_CS0_WR_HOLD,
.rd_setup = ASYNC_EMIF_CS0_RD_SETUP,
.rd_strobe = ASYNC_EMIF_CS0_RD_STROBE,
.rd_hold = ASYNC_EMIF_CS0_RD_HOLD,
.turn_around = ASYNC_EMIF_CS0_TURN_AROUND,
.width = ASYNC_EMIF_CS0_WIDTH,
- { /* CS1 */
.mode = ASYNC_EMIF_MODE_NOR,
.select_strobe = ASYNC_EMIF_CS1_SELECT_STROBE,
.extend_wait = ASYNC_EMIF_CS1_EXTEND_WAIT,
.wr_setup = ASYNC_EMIF_CS1_WR_SETUP,
.wr_strobe = ASYNC_EMIF_CS1_WR_STROBE,
.wr_hold = ASYNC_EMIF_CS1_WR_HOLD,
.rd_setup = ASYNC_EMIF_CS1_RD_SETUP,
.rd_strobe = ASYNC_EMIF_CS1_RD_STROBE,
.rd_hold = ASYNC_EMIF_CS1_RD_HOLD,
.turn_around = ASYNC_EMIF_CS1_TURN_AROUND,
.width = ASYNC_EMIF_CS1_WIDTH,
- { /* CS2 */
.select_strobe = ASYNC_EMIF_CS2_SELECT_STROBE,
.extend_wait = ASYNC_EMIF_CS2_EXTEND_WAIT,
.wr_setup = ASYNC_EMIF_CS2_WR_SETUP,
.wr_strobe = ASYNC_EMIF_CS2_WR_STROBE,
.wr_hold = ASYNC_EMIF_CS2_WR_HOLD,
.rd_setup = ASYNC_EMIF_CS2_RD_SETUP,
.rd_strobe = ASYNC_EMIF_CS2_RD_STROBE,
.rd_hold = ASYNC_EMIF_CS2_RD_HOLD,
.turn_around = ASYNC_EMIF_CS2_TURN_AROUND,
.width = ASYNC_EMIF_CS2_WIDTH,
- { /* CS3 */
.select_strobe = ASYNC_EMIF_CS3_SELECT_STROBE,
.extend_wait = ASYNC_EMIF_CS3_EXTEND_WAIT,
.wr_setup = ASYNC_EMIF_CS3_WR_SETUP,
.wr_strobe = ASYNC_EMIF_CS3_WR_STROBE,
.wr_hold = ASYNC_EMIF_CS3_WR_HOLD,
.rd_setup = ASYNC_EMIF_CS3_RD_SETUP,
.rd_strobe = ASYNC_EMIF_CS3_RD_STROBE,
.rd_hold = ASYNC_EMIF_CS3_RD_HOLD,
.turn_around = ASYNC_EMIF_CS3_TURN_AROUND,
.width = ASYNC_EMIF_CS3_WIDTH,
A better place for all the preceding code would be in an arch *.h The NUM_CS should likely be a CONFIG_ paramter.
+void configure_async_emif(int cs, struct async_emif_config *cfg) +{
- unsigned long tmp;
- if (cfg->mode == ASYNC_EMIF_MODE_NAND) {
tmp = __raw_readl(ASYNC_EMIF_NAND_CONTROL);
tmp |= (1 << cs);
__raw_writel(tmp, ASYNC_EMIF_NAND_CONTROL);
- } else if (cfg->mode == ASYNC_EMIF_MODE_ONENAND) {
tmp = __raw_readl(ASYNC_EMIF_ONENAND_CONTROL);
tmp |= (1 << cs);
__raw_writel(tmp, ASYNC_EMIF_ONENAND_CONTROL);
- tmp = __raw_readl(ASYNC_EMIF_CONFIG(cs));
- set_config_field(tmp, SELECT_STROBE, cfg->select_strobe);
- set_config_field(tmp, EXTEND_WAIT, cfg->extend_wait);
- set_config_field(tmp, WR_SETUP, cfg->wr_setup);
- set_config_field(tmp, WR_STROBE, cfg->wr_strobe);
- set_config_field(tmp, WR_HOLD, cfg->wr_hold);
- set_config_field(tmp, RD_SETUP, cfg->rd_setup);
- set_config_field(tmp, RD_STROBE, cfg->rd_strobe);
- set_config_field(tmp, RD_HOLD, cfg->rd_hold);
- set_config_field(tmp, TURN_AROUND, cfg->turn_around);
- set_config_field(tmp, WIDTH, cfg->width);
- __raw_writel(tmp, ASYNC_EMIF_CONFIG(cs));
+void init_async_emif(void) +{
- int cs;
- mux_select_pin(TNETV107X_PIN_ASR_CS3);
- clk_enable(TNETV107X_LPSC_AEMIF);
- for (cs = 0; cs < NUM_CS; cs++)
configure_async_emif(cs, &default_async_emif_config[cs]);
+} diff --git a/arch/arm/cpu/arm1176/tnetv107x/clock.c b/arch/arm/cpu/arm1176/tnetv107x/clock.c new file mode 100644 index 0000000..861cea1 --- /dev/null +++ b/arch/arm/cpu/arm1176/tnetv107x/clock.c @@ -0,0 +1,542 @@ +/*
- TNETV107X: Clock management APIs
- project.
+#define CLOCK_BASE TNETV107X_CLOCK_CONTROL_BASE +#define PSC_BASE TNETV107X_PSC_BASE
+#define MAX_PREDIV 64 +#define MAX_POSTDIV 8 +#define MAX_MULT 512 +#define MAX_DIV (MAX_PREDIV * MAX_POSTDIV)
+/* LPSC registers */ +#define PSC_PTCMD 0x120 +#define PSC_PTSTAT 0x128 +#define PSC_MDSTAT(n) (0x800 + (n) * 4) +#define PSC_MDCTL(n) (0xA00 + (n) * 4)
+#define psc_reg_read(reg) __raw_readl((u32 *)(PSC_BASE + (reg))) +#define psc_reg_write(reg, val) __raw_writel(val, (u32 *)(PSC_BASE + (reg)))
+/* PLL identifiers */ +enum pll_type_e {
- SYS_PLL,
- TDM_PLL,
- ETH_PLL
+/* PLL configuration data */ +struct pll_init_data {
- int config_enable;
- int pll;
- int internal_osc;
- unsigned long external_freq;
- unsigned long pll_freq;
- unsigned long div_freq[10];
+/* SSPLL registers */ +struct sspll_regs {
- u32 modes;
- u32 postdiv;
- u32 prediv;
- u32 mult_factor;
- u32 divider_range;
- u32 bw_divider;
- u32 spr_amount;
- u32 spr_rate_div;
- u32 diag;
+/* SSPLL base addresses */ +static struct sspll_regs *sspll_regs[] = {
- (struct sspll_regs *)(CLOCK_BASE + 0x040),
- (struct sspll_regs *)(CLOCK_BASE + 0x080),
- (struct sspll_regs *)(CLOCK_BASE + 0x0c0),
+#define sspll_reg(pll, reg) (&(sspll_regs[pll]->reg)) +#define sspll_reg_read(pll, reg) __raw_readl(sspll_reg(pll, reg)) +#define sspll_reg_write(pll, reg, val) __raw_writel(val, sspll_reg(pll, reg))
+/* PLL Control Registers */ +struct pllctl_regs {
- u32 ctl; /* 00 */
- u32 ocsel; /* 04 */
- u32 secctl; /* 08 */
- u32 __pad0;
- u32 mult; /* 10 */
- u32 prediv; /* 14 */
- u32 div1; /* 18 */
- u32 div2; /* 1c */
- u32 div3; /* 20 */
- u32 oscdiv1; /* 24 */
- u32 postdiv; /* 28 */
- u32 bpdiv; /* 2c */
- u32 wakeup; /* 30 */
- u32 __pad1;
- u32 cmd; /* 38 */
- u32 stat; /* 3c */
- u32 alnctl; /* 40 */
- u32 dchange; /* 44 */
- u32 cken; /* 48 */
- u32 ckstat; /* 4c */
- u32 systat; /* 50 */
- u32 ckctl; /* 54 */
- u32 __pad2[2];
- u32 div4; /* 60 */
- u32 div5; /* 64 */
- u32 div6; /* 68 */
- u32 div7; /* 6c */
- u32 div8; /* 70 */
+struct lpsc_map {
- int pll, div;
+static struct pllctl_regs *pllctl_regs[] = {
- (struct pllctl_regs *)(CLOCK_BASE + 0x700),
- (struct pllctl_regs *)(CLOCK_BASE + 0x300),
- (struct pllctl_regs *)(CLOCK_BASE + 0x500),
+#define pllctl_reg(pll, reg) (&(pllctl_regs[pll]->reg)) +#define pllctl_reg_read(pll, reg) __raw_readl(pllctl_reg(pll, reg)) +#define pllctl_reg_write(pll, reg, val) __raw_writel(val, pllctl_reg(pll, reg))
+#define pllctl_reg_rmw(pll, reg, mask, val) \
- pllctl_reg_write(pll, reg, \
(pllctl_reg_read(pll, reg) & ~(mask)) | val)
+#define pllctl_reg_setbits(pll, reg, mask) \
- pllctl_reg_rmw(pll, reg, 0, mask)
+#define pllctl_reg_clrbits(pll, reg, mask) \
- pllctl_reg_rmw(pll, reg, mask, 0)
+/* PLLCTL Bits */ +#define PLLCTL_CLKMODE (0x1 << 8) +#define PLLCTL_PLLSELB (0x1 << 7) +#define PLLCTL_PLLENSRC (0x1 << 5) +#define PLLCTL_PLLDIS (0x1 << 4) +#define PLLCTL_PLLRST (0x1 << 3) +#define PLLCTL_PLLPWRDN (0x1 << 1) +#define PLLCTL_PLLEN (0x1 << 0)
+static int pll_div_offset[] = { +#define div_offset(reg) offsetof(struct pllctl_regs, reg)
- div_offset(div1), div_offset(div2), div_offset(div3),
- div_offset(div4), div_offset(div5), div_offset(div6),
- div_offset(div7), div_offset(div8),
+static unsigned long pll_bypass_mask[] = { 1, 4, 2 }; +static unsigned long pll_div_mask[] = { 0x01ff, 0x00ff, 0x00ff };
+/* Mappings from PLL+DIV to subsystem clocks */ +#define sys_arm1176_clk {SYS_PLL, 0} +#define sys_dsp_clk {SYS_PLL, 1} +#define sys_ddr_clk {SYS_PLL, 2} +#define sys_full_clk {SYS_PLL, 3} +#define sys_lcd_clk {SYS_PLL, 4} +#define sys_vlynq_ref_clk {SYS_PLL, 5} +#define sys_tsc_clk {SYS_PLL, 6} +#define sys_half_clk {SYS_PLL, 7}
+#define eth_clk_5 {ETH_PLL, 0} +#define eth_clk_50 {ETH_PLL, 1} +#define eth_clk_125 {ETH_PLL, 2} +#define eth_clk_250 {ETH_PLL, 3} +#define eth_clk_25 {ETH_PLL, 4}
+#define tdm_clk {TDM_PLL, 0} +#define tdm_extra_clk {TDM_PLL, 1} +#define tdm1_clk {TDM_PLL, 2}
+static const struct lpsc_map lpsc_clk_map[] = {
- [TNETV107X_LPSC_ARM] = sys_arm1176_clk,
- [TNETV107X_LPSC_GEM] = sys_dsp_clk,
- [TNETV107X_LPSC_DDR2_PHY] = sys_ddr_clk,
- [TNETV107X_LPSC_TPCC] = sys_full_clk,
- [TNETV107X_LPSC_TPTC0] = sys_full_clk,
- [TNETV107X_LPSC_TPTC1] = sys_full_clk,
- [TNETV107X_LPSC_RAM] = sys_full_clk,
- [TNETV107X_LPSC_MBX_LITE] = sys_arm1176_clk,
- [TNETV107X_LPSC_LCD] = sys_lcd_clk,
- [TNETV107X_LPSC_ETHSS] = eth_clk_125,
- [TNETV107X_LPSC_AEMIF] = sys_full_clk,
- [TNETV107X_LPSC_CHIP_CFG] = sys_half_clk,
- [TNETV107X_LPSC_TSC] = sys_tsc_clk,
- [TNETV107X_LPSC_ROM] = sys_half_clk,
- [TNETV107X_LPSC_UART2] = sys_half_clk,
- [TNETV107X_LPSC_PKTSEC] = sys_half_clk,
- [TNETV107X_LPSC_SECCTL] = sys_half_clk,
- [TNETV107X_LPSC_KEYMGR] = sys_half_clk,
- [TNETV107X_LPSC_KEYPAD] = sys_half_clk,
- [TNETV107X_LPSC_GPIO] = sys_half_clk,
- [TNETV107X_LPSC_MDIO] = sys_half_clk,
- [TNETV107X_LPSC_SDIO0] = sys_half_clk,
- [TNETV107X_LPSC_UART0] = sys_half_clk,
- [TNETV107X_LPSC_UART1] = sys_half_clk,
- [TNETV107X_LPSC_TIMER0] = sys_half_clk,
- [TNETV107X_LPSC_TIMER1] = sys_half_clk,
- [TNETV107X_LPSC_WDT_ARM] = sys_half_clk,
- [TNETV107X_LPSC_WDT_DSP] = sys_half_clk,
- [TNETV107X_LPSC_SSP] = sys_half_clk,
- [TNETV107X_LPSC_TDM0] = tdm_clk,
- [TNETV107X_LPSC_VLYNQ] = sys_vlynq_ref_clk,
- [TNETV107X_LPSC_MCDMA] = sys_half_clk,
- [TNETV107X_LPSC_USB0] = sys_half_clk,
- [TNETV107X_LPSC_TDM1] = tdm1_clk,
- [TNETV107X_LPSC_DEBUGSS] = sys_half_clk,
- [TNETV107X_LPSC_ETHSS_RGMII] = eth_clk_250,
- [TNETV107X_LPSC_SYSTEM] = sys_half_clk,
- [TNETV107X_LPSC_IMCOP] = sys_dsp_clk,
- [TNETV107X_LPSC_SPARE] = sys_half_clk,
- [TNETV107X_LPSC_SDIO1] = sys_half_clk,
- [TNETV107X_LPSC_USB1] = sys_half_clk,
- [TNETV107X_LPSC_USBSS] = sys_half_clk,
- [TNETV107X_LPSC_DDR2_EMIF1_VRST] = sys_ddr_clk,
- [TNETV107X_LPSC_DDR2_EMIF2_VCTL_RST] = sys_ddr_clk,
+static const struct pll_init_data plls[] = {
- [SYS_PLL] = {
.config_enable = CONFIG_PLL_SYS_CONFIG,
.pll = SYS_PLL,
.internal_osc = CONFIG_PLL_SYS_INT_OSC,
.external_freq = CONFIG_PLL_SYS_EXT_FREQ,
+#if (CONFIG_PLL_SYS_CONFIG)
.pll_freq = CONFIG_PLL_SYS_PLL_FREQ,
.div_freq = {
CONFIG_PLL_SYS_ARM1176_CLK,
CONFIG_PLL_SYS_DSP_CLK,
CONFIG_PLL_SYS_DDR_CLK,
CONFIG_PLL_SYS_FULL_CLK,
CONFIG_PLL_SYS_LCD_CLK,
CONFIG_PLL_SYS_VLYNQ_REF_CLK,
CONFIG_PLL_SYS_TSC_CLK,
CONFIG_PLL_SYS_HALF_CLK,
- [TDM_PLL] = {
.config_enable = CONFIG_PLL_TDM_CONFIG,
.pll = TDM_PLL,
.internal_osc = CONFIG_PLL_TDM_INT_OSC,
.external_freq = CONFIG_PLL_TDM_EXT_FREQ,
+#if (CONFIG_PLL_TDM_CONFIG)
.pll_freq = CONFIG_PLL_TDM_PLL_FREQ,
.div_freq = {
CONFIG_PLL_TDM_TDM0_CLK,
CONFIG_PLL_TDM_TIMER_CLK,
CONFIG_PLL_TDM_TDM1_CLK,
- [ETH_PLL] = {
.config_enable = CONFIG_PLL_ETH_CONFIG,
.pll = ETH_PLL,
.internal_osc = CONFIG_PLL_ETH_INT_OSC,
.external_freq = CONFIG_PLL_ETH_EXT_FREQ,
+#if (CONFIG_PLL_ETH_CONFIG)
.pll_freq = CONFIG_PLL_ETH_PLL_FREQ,
.div_freq = {
CONFIG_PLL_ETH_5_CLK,
CONFIG_PLL_ETH_50_CLK,
CONFIG_PLL_ETH_125_CLK,
CONFIG_PLL_ETH_250_CLK,
CONFIG_PLL_ETH_25_CLK,
Similar to above, the preceeding code is better placed in an arch *.h Please move.
+void clk_delay(void) +{
- int i;
- for (i = 0; i < 1000; i++)
__asm__ __volatile__("mov r0, r0\n" : : : "memory");
This delay is dependent on the clock frequency. Either generalize to use the clock frequency or add a detailed comment on the minimal expected delay time.
+static unsigned long pll_freq_get(int pll) +{
- unsigned long mult = 1, prediv = 1, postdiv = 1;
- unsigned long ref = CONFIG_SYS_INT_OSC_FREQ;
- unsigned long ret;
- u32 bypass;
- bypass = __raw_readl((u32 *)(CLOCK_BASE));
- if (!(bypass & pll_bypass_mask[pll])) {
mult = sspll_reg_read(pll, mult_factor);
prediv = sspll_reg_read(pll, prediv) + 1;
postdiv = sspll_reg_read(pll, postdiv) + 1;
- if (pllctl_reg_read(pll, ctl) & PLLCTL_CLKMODE)
ref = plls[pll].external_freq;
- if (!(pllctl_reg_read(pll, ctl) & PLLCTL_PLLEN))
return ref;
- ret = (unsigned long)(ref + ((unsigned long long)ref * mult) / 256);
- ret /= (prediv * postdiv);
- return ret;
+static unsigned long __pll_div_freq_get(int pll, unsigned int fpll,
int div)
- int divider = 1;
- unsigned long divreg;
- divreg = __raw_readl((void *)pllctl_regs[pll] + pll_div_offset[div]);
- if (divreg & (0x01 << 15))
divider = (divreg & pll_div_mask[pll]) + 1;
This bit 0x01 << 15 should be a #define Add this to the appropriate arch *.h
- return fpll / divider;
+static unsigned long pll_div_freq_get(int pll, int div) +{
- unsigned int fpll = pll_freq_get(pll);
- return __pll_div_freq_get(pll, fpll, div);
+static void __pll_div_freq_set(int pll, unsigned int fpll, int div,
unsigned long hz)
- int divider = (fpll / hz - 1);
- divider &= pll_div_mask[pll];
- divider |= (0x01 << 15); /* enable */
Similar, this bit operation should be a #define. For other similar uses, fix globally
- __raw_writel(divider, (void *)pllctl_regs[pll] + pll_div_offset[div]);
- pllctl_reg_setbits(pll, alnctl, (1 << div));
- pllctl_reg_setbits(pll, dchange, (1 << div));
+static unsigned long pll_div_freq_set(int pll, int div, unsigned long hz) +{
- __pll_div_freq_set(pll, fpll, div, hz);
- pllctl_reg_write(pll, cmd, 1);
- while (pllctl_reg_read(pll, stat) & 0x01)
- clk_delay();
+unsigned long clk_get_rate(unsigned int clk) +{
- return pll_div_freq_get(lpsc_clk_map[clk].pll, lpsc_clk_map[clk].div);
+long clk_round_rate(unsigned int clk, unsigned long hz) +{
- int fpll, divider, pll;
May want to change type from int to long
- pll = lpsc_clk_map[clk].pll;
- fpll = pll_freq_get(pll);
- divider = (fpll / hz - 1);
- return fpll / (divider + 1);
+int clk_set_rate(unsigned int clk, unsigned long _hz) +{
- unsigned long hz;
- hz = clk_round_rate(clk, _hz);
- if (hz != _hz)
return -1; /* Cannot set to target freq */
- return pll_div_freq_set(lpsc_clk_map[clk].pll,
lpsc_clk_map[clk].div, hz);
+static void __lpsc_set_state(int nmod, int lrstz, va_list args) +{
va_list is not needed. Convert to normal parameter passing Other functions have similar calling. Apply this fix globally
- int i;
- u32 mdctl, state;
- unsigned int id;
- for (i = 0; i < nmod; i++) {
id = va_arg(args, unsigned int);
state = va_arg(args, u32);
mdctl = psc_reg_read(PSC_MDCTL(id));
mdctl &= ~0x1f;
mdctl |= state;
if (lrstz == 0 || lrstz == 1) {
mdctl &= ~(1 << 8);
mdctl |= (lrstz << 8);
Another example of bit operations Use #define
psc_reg_write(PSC_MDCTL(id), mdctl);
+static void __lpsc_wait_state(int nmod, va_list args) +{
- int i;
- u32 state;
- unsigned int id;
while ((psc_reg_read(PSC_MDSTAT(id)) & 0x1f) != state)
Add a comment about a busy wait. Apply this fix globally
+void lpsc_control(int nmod, int lrstz, ...) +{
- va_list args;
No vargs
- va_start(args, lrstz);
- __lpsc_set_state(nmod, lrstz, args);
- va_end(args);
- psc_reg_write(PSC_PTCMD, 1);
- while (psc_reg_read(PSC_PTSTAT) & 1)
- __lpsc_wait_state(nmod, args);
- va_end(args);
+int lpsc_status(unsigned int id) +{
- return psc_reg_read(PSC_MDSTAT(id)) & 0x1f;
+static void init_pll(const struct pll_init_data *data) +{
- unsigned long fpll;
- unsigned long best_pre = 0, best_post = 0, best_mult = 0;
- unsigned long div, prediv, postdiv, mult;
- unsigned long delta, actual;
- long best_delta = -1;
- int i;
- u32 tmp;
- if (!data->config_enable)
return;
- tmp = pllctl_reg_read(data->pll, ctl);
- if (data->internal_osc) {
tmp &= ~PLLCTL_CLKMODE;
fpll = CONFIG_SYS_INT_OSC_FREQ;
- } else {
tmp |= PLLCTL_CLKMODE;
fpll = data->external_freq;
- pllctl_reg_write(data->pll, ctl, tmp);
- mult = data->pll_freq / fpll;
- for (mult = MAX(mult, 1); mult <= MAX_MULT; mult++) {
div = (fpll * mult) / data->pll_freq;
if (div < 1 || div > MAX_DIV)
continue;
for (postdiv = 1; postdiv <= min(div, MAX_POSTDIV); postdiv++) {
prediv = div / postdiv;
if (prediv < 1 || prediv > MAX_PREDIV)
continue;
actual = (fpll / prediv) * (mult / postdiv);
delta = (actual - data->pll_freq);
delta = ABS(delta);
if ((delta < best_delta) || (best_delta == -1)) {
best_delta = delta;
best_mult = mult;
best_pre = prediv;
best_post = postdiv;
if (delta == 0)
goto done;
Add a check that hursitics here produced a reasonable clock. If the best_* are not set, the last interation will likely be an error
+done:
- fpll = fpll * best_mult;
- fpll /= best_pre * best_post;
- pllctl_reg_clrbits(data->pll, ctl, PLLCTL_PLLENSRC);
- pllctl_reg_clrbits(data->pll, ctl, PLLCTL_PLLEN);
- clk_delay();
- pllctl_reg_setbits(data->pll, ctl, PLLCTL_PLLRST);
- clk_delay();
- pllctl_reg_clrbits(data->pll, ctl, PLLCTL_PLLPWRDN);
- pllctl_reg_clrbits(data->pll, ctl, PLLCTL_PLLDIS);
- clk_delay();
- sspll_reg_write(data->pll, mult_factor, (best_mult - 1) << 8);
- sspll_reg_write(data->pll, prediv, best_pre - 1);
- sspll_reg_write(data->pll, postdiv, best_post - 1);
- for (i = 0; i < 10; i++)
if (data->div_freq[i])
__pll_div_freq_set(data->pll, fpll, i,
data->div_freq[i]);
- pllctl_reg_write(data->pll, cmd, 1);
- /* Wait for completion */
- while (pllctl_reg_read(data->pll, stat) & 0x01)
- clk_delay();
- pllctl_reg_clrbits(data->pll, ctl, PLLCTL_PLLRST);
- clk_delay();
- pllctl_reg_setbits(data->pll, ctl, PLLCTL_PLLEN);
- clk_delay();
+void init_plls(void) +{
- int i;
- for (i = 0; i < ARRAY_SIZE(plls); i++)
init_pll(&plls[i]);
+} diff --git a/arch/arm/cpu/arm1176/tnetv107x/init.c b/arch/arm/cpu/arm1176/tnetv107x/init.c new file mode 100644 index 0000000..d906c72 --- /dev/null +++ b/arch/arm/cpu/arm1176/tnetv107x/init.c @@ -0,0 +1,41 @@ +/*
- TNETV107X: Architecture initialization
- project.
+void chip_configuration_unlock(void) +{
__raw_writel(TNETV107X_KICK0_MAGIC, TNETV107X_KICK0);
__raw_writel(TNETV107X_KICK1_MAGIC, TNETV107X_KICK1);
+int arch_cpu_init(void) +{
icache_enable();
chip_configuration_unlock();
init_plls();
init_timer();
init_async_emif();
init_wdt();
+} diff --git a/arch/arm/cpu/arm1176/tnetv107x/lowlevel_init.S b/arch/arm/cpu/arm1176/tnetv107x/lowlevel_init.S new file mode 100644 index 0000000..3ee32ef --- /dev/null +++ b/arch/arm/cpu/arm1176/tnetv107x/lowlevel_init.S @@ -0,0 +1,25 @@ +/*
- TNETV107X: Low-level pre-relocation initialization
- project.
+.globl lowlevel_init +lowlevel_init:
- /* nothing for now, maybe needed for more exotic boot modes */
- mov pc, lr
diff --git a/arch/arm/cpu/arm1176/tnetv107x/mux.c b/arch/arm/cpu/arm1176/tnetv107x/mux.c new file mode 100644 index 0000000..7b58133 --- /dev/null +++ b/arch/arm/cpu/arm1176/tnetv107x/mux.c @@ -0,0 +1,463 @@ +/*
- TNETV107X: Pinmux configuration
- project.
+#define MUX_MODE_1 0x00 +#define MUX_MODE_2 0x04 +#define MUX_MODE_3 0x0c +#define MUX_MODE_4 0x1c
+#define MUX_DEBUG 0
+static const struct pin_config pin_table[] = {
- TNETV107X_MUX_CFG(0, 0, MUX_MODE_1),
- TNETV107X_MUX_CFG(0, 0, MUX_MODE_2),
Change these immedates '0, 0' into #defines Apply globally
- TNETV107X_MUX_CFG(0, 5, MUX_MODE_1),
- TNETV107X_MUX_CFG(0, 5, MUX_MODE_2),
- TNETV107X_MUX_CFG(0, 10, MUX_MODE_1),
- TNETV107X_MUX_CFG(0, 10, MUX_MODE_2),
- TNETV107X_MUX_CFG(0, 15, MUX_MODE_1),
- TNETV107X_MUX_CFG(0, 15, MUX_MODE_2),
- TNETV107X_MUX_CFG(0, 20, MUX_MODE_1),
- TNETV107X_MUX_CFG(0, 20, MUX_MODE_2),
- TNETV107X_MUX_CFG(0, 25, MUX_MODE_1),
- TNETV107X_MUX_CFG(0, 25, MUX_MODE_2),
- TNETV107X_MUX_CFG(1, 0, MUX_MODE_1),
- TNETV107X_MUX_CFG(1, 0, MUX_MODE_2),
- TNETV107X_MUX_CFG(1, 5, MUX_MODE_1),
- TNETV107X_MUX_CFG(1, 5, MUX_MODE_2),
- TNETV107X_MUX_CFG(1, 10, MUX_MODE_1),
- TNETV107X_MUX_CFG(1, 10, MUX_MODE_2),
- TNETV107X_MUX_CFG(1, 15, MUX_MODE_1),
- TNETV107X_MUX_CFG(1, 15, MUX_MODE_2),
- TNETV107X_MUX_CFG(1, 20, MUX_MODE_1),
- TNETV107X_MUX_CFG(1, 20, MUX_MODE_2),
- TNETV107X_MUX_CFG(1, 25, MUX_MODE_1),
- TNETV107X_MUX_CFG(1, 25, MUX_MODE_2),
- TNETV107X_MUX_CFG(2, 0, MUX_MODE_1),
- TNETV107X_MUX_CFG(2, 0, MUX_MODE_2),
- TNETV107X_MUX_CFG(2, 5, MUX_MODE_1),
- TNETV107X_MUX_CFG(2, 5, MUX_MODE_2),
- TNETV107X_MUX_CFG(2, 10, MUX_MODE_1),
- TNETV107X_MUX_CFG(2, 10, MUX_MODE_2),
- TNETV107X_MUX_CFG(2, 15, MUX_MODE_1),
- TNETV107X_MUX_CFG(2, 15, MUX_MODE_2),
- TNETV107X_MUX_CFG(2, 20, MUX_MODE_1),
- TNETV107X_MUX_CFG(2, 20, MUX_MODE_2),
- TNETV107X_MUX_CFG(2, 25, MUX_MODE_1),
- TNETV107X_MUX_CFG(2, 25, MUX_MODE_2),
- TNETV107X_MUX_CFG(3, 0, MUX_MODE_1),
- TNETV107X_MUX_CFG(3, 0, MUX_MODE_2),
- TNETV107X_MUX_CFG(3, 0, MUX_MODE_4),
- TNETV107X_MUX_CFG(3, 5, MUX_MODE_1),
- TNETV107X_MUX_CFG(3, 5, MUX_MODE_2),
- TNETV107X_MUX_CFG(3, 5, MUX_MODE_4),
- TNETV107X_MUX_CFG(3, 10, MUX_MODE_1),
- TNETV107X_MUX_CFG(3, 10, MUX_MODE_2),
- TNETV107X_MUX_CFG(3, 10, MUX_MODE_4),
- TNETV107X_MUX_CFG(3, 15, MUX_MODE_1),
- TNETV107X_MUX_CFG(3, 15, MUX_MODE_2),
- TNETV107X_MUX_CFG(3, 15, MUX_MODE_4),
- TNETV107X_MUX_CFG(3, 20, MUX_MODE_1),
- TNETV107X_MUX_CFG(3, 20, MUX_MODE_2),
- TNETV107X_MUX_CFG(3, 20, MUX_MODE_4),
- TNETV107X_MUX_CFG(3, 25, MUX_MODE_1),
- TNETV107X_MUX_CFG(3, 25, MUX_MODE_2),
- TNETV107X_MUX_CFG(3, 25, MUX_MODE_4),
- TNETV107X_MUX_CFG(4, 0, MUX_MODE_1),
- TNETV107X_MUX_CFG(4, 0, MUX_MODE_2),
- TNETV107X_MUX_CFG(4, 0, MUX_MODE_4),
- TNETV107X_MUX_CFG(4, 5, MUX_MODE_1),
- TNETV107X_MUX_CFG(4, 10, MUX_MODE_1),
- TNETV107X_MUX_CFG(4, 15, MUX_MODE_1),
- TNETV107X_MUX_CFG(4, 15, MUX_MODE_4),
- TNETV107X_MUX_CFG(4, 20, MUX_MODE_1),
- TNETV107X_MUX_CFG(4, 20, MUX_MODE_3),
- TNETV107X_MUX_CFG(4, 25, MUX_MODE_1),
- TNETV107X_MUX_CFG(4, 25, MUX_MODE_4),
- TNETV107X_MUX_CFG(5, 0, MUX_MODE_1),
- TNETV107X_MUX_CFG(5, 0, MUX_MODE_4),
- TNETV107X_MUX_CFG(5, 5, MUX_MODE_1),
- TNETV107X_MUX_CFG(5, 5, MUX_MODE_4),
- TNETV107X_MUX_CFG(5, 10, MUX_MODE_1),
- TNETV107X_MUX_CFG(5, 10, MUX_MODE_4),
- TNETV107X_MUX_CFG(5, 15, MUX_MODE_1),
- TNETV107X_MUX_CFG(5, 15, MUX_MODE_4),
- TNETV107X_MUX_CFG(5, 20, MUX_MODE_1),
- TNETV107X_MUX_CFG(5, 20, MUX_MODE_4),
- TNETV107X_MUX_CFG(5, 25, MUX_MODE_1),
- TNETV107X_MUX_CFG(5, 25, MUX_MODE_4),
- TNETV107X_MUX_CFG(6, 0, MUX_MODE_1),
- TNETV107X_MUX_CFG(6, 0, MUX_MODE_4),
- TNETV107X_MUX_CFG(6, 5, MUX_MODE_1),
- TNETV107X_MUX_CFG(6, 5, MUX_MODE_4),
- TNETV107X_MUX_CFG(6, 10, MUX_MODE_1),
- TNETV107X_MUX_CFG(6, 10, MUX_MODE_4),
- TNETV107X_MUX_CFG(6, 15, MUX_MODE_1),
- TNETV107X_MUX_CFG(6, 15, MUX_MODE_4),
- TNETV107X_MUX_CFG(6, 20, MUX_MODE_1),
- TNETV107X_MUX_CFG(6, 20, MUX_MODE_4),
- TNETV107X_MUX_CFG(6, 25, MUX_MODE_1),
- TNETV107X_MUX_CFG(6, 25, MUX_MODE_4),
- TNETV107X_MUX_CFG(7, 0, MUX_MODE_1),
- TNETV107X_MUX_CFG(7, 0, MUX_MODE_4),
- TNETV107X_MUX_CFG(7, 5, MUX_MODE_1),
- TNETV107X_MUX_CFG(7, 5, MUX_MODE_4),
- TNETV107X_MUX_CFG(7, 10, MUX_MODE_1),
- TNETV107X_MUX_CFG(7, 10, MUX_MODE_4),
- TNETV107X_MUX_CFG(7, 15, MUX_MODE_1),
- TNETV107X_MUX_CFG(7, 15, MUX_MODE_2),
- TNETV107X_MUX_CFG(7, 20, MUX_MODE_1),
- TNETV107X_MUX_CFG(7, 20, MUX_MODE_2),
- TNETV107X_MUX_CFG(7, 25, MUX_MODE_1),
- TNETV107X_MUX_CFG(7, 25, MUX_MODE_2),
- TNETV107X_MUX_CFG(8, 0, MUX_MODE_1),
- TNETV107X_MUX_CFG(8, 0, MUX_MODE_2),
- TNETV107X_MUX_CFG(8, 5, MUX_MODE_1),
- TNETV107X_MUX_CFG(8, 5, MUX_MODE_2),
- TNETV107X_MUX_CFG(8, 5, MUX_MODE_4),
- TNETV107X_MUX_CFG(8, 10, MUX_MODE_1),
- TNETV107X_MUX_CFG(8, 10, MUX_MODE_2),
- TNETV107X_MUX_CFG(9, 0, MUX_MODE_1),
- TNETV107X_MUX_CFG(9, 0, MUX_MODE_2),
- TNETV107X_MUX_CFG(9, 0, MUX_MODE_4),
- TNETV107X_MUX_CFG(9, 5, MUX_MODE_1),
- TNETV107X_MUX_CFG(9, 5, MUX_MODE_2),
- TNETV107X_MUX_CFG(9, 5, MUX_MODE_4),
- TNETV107X_MUX_CFG(9, 10, MUX_MODE_1),
- TNETV107X_MUX_CFG(9, 10, MUX_MODE_2),
- TNETV107X_MUX_CFG(9, 10, MUX_MODE_4),
- TNETV107X_MUX_CFG(9, 15, MUX_MODE_1),
- TNETV107X_MUX_CFG(9, 15, MUX_MODE_2),
- TNETV107X_MUX_CFG(9, 15, MUX_MODE_4),
- TNETV107X_MUX_CFG(9, 20, MUX_MODE_1),
- TNETV107X_MUX_CFG(9, 20, MUX_MODE_2),
- TNETV107X_MUX_CFG(9, 20, MUX_MODE_4),
- TNETV107X_MUX_CFG(10, 0, MUX_MODE_1),
- TNETV107X_MUX_CFG(10, 0, MUX_MODE_2),
- TNETV107X_MUX_CFG(10, 5, MUX_MODE_1),
- TNETV107X_MUX_CFG(10, 5, MUX_MODE_2),
- TNETV107X_MUX_CFG(10, 10, MUX_MODE_1),
- TNETV107X_MUX_CFG(10, 10, MUX_MODE_2),
- TNETV107X_MUX_CFG(10, 15, MUX_MODE_1),
- TNETV107X_MUX_CFG(10, 15, MUX_MODE_2),
- TNETV107X_MUX_CFG(10, 20, MUX_MODE_1),
- TNETV107X_MUX_CFG(10, 20, MUX_MODE_2),
- TNETV107X_MUX_CFG(10, 25, MUX_MODE_1),
- TNETV107X_MUX_CFG(10, 25, MUX_MODE_2),
- TNETV107X_MUX_CFG(11, 0, MUX_MODE_1),
- TNETV107X_MUX_CFG(11, 5, MUX_MODE_1),
- TNETV107X_MUX_CFG(12, 0, MUX_MODE_1),
- TNETV107X_MUX_CFG(12, 5, MUX_MODE_1),
- TNETV107X_MUX_CFG(12, 10, MUX_MODE_1),
- TNETV107X_MUX_CFG(12, 15, MUX_MODE_1),
- TNETV107X_MUX_CFG(12, 20, MUX_MODE_1),
- TNETV107X_MUX_CFG(12, 25, MUX_MODE_1),
- TNETV107X_MUX_CFG(13, 0, MUX_MODE_1),
- TNETV107X_MUX_CFG(13, 5, MUX_MODE_1),
- TNETV107X_MUX_CFG(13, 10, MUX_MODE_1),
- TNETV107X_MUX_CFG(13, 15, MUX_MODE_1),
- TNETV107X_MUX_CFG(14, 0, MUX_MODE_1),
- TNETV107X_MUX_CFG(14, 5, MUX_MODE_1),
- TNETV107X_MUX_CFG(14, 10, MUX_MODE_1),
- TNETV107X_MUX_CFG(14, 15, MUX_MODE_1),
- TNETV107X_MUX_CFG(14, 20, MUX_MODE_1),
- TNETV107X_MUX_CFG(14, 25, MUX_MODE_1),
- TNETV107X_MUX_CFG(15, 0, MUX_MODE_1),
- TNETV107X_MUX_CFG(15, 0, MUX_MODE_2),
- TNETV107X_MUX_CFG(15, 5, MUX_MODE_1),
- TNETV107X_MUX_CFG(15, 5, MUX_MODE_2),
- TNETV107X_MUX_CFG(15, 10, MUX_MODE_1),
- TNETV107X_MUX_CFG(15, 15, MUX_MODE_1),
- TNETV107X_MUX_CFG(15, 20, MUX_MODE_1),
- TNETV107X_MUX_CFG(15, 25, MUX_MODE_1),
- TNETV107X_MUX_CFG(16, 0, MUX_MODE_1),
- TNETV107X_MUX_CFG(16, 5, MUX_MODE_1),
- TNETV107X_MUX_CFG(16, 10, MUX_MODE_1),
- TNETV107X_MUX_CFG(16, 10, MUX_MODE_2),
- TNETV107X_MUX_CFG(16, 10, MUX_MODE_3),
- TNETV107X_MUX_CFG(16, 15, MUX_MODE_1),
- TNETV107X_MUX_CFG(16, 15, MUX_MODE_2),
- TNETV107X_MUX_CFG(17, 0, MUX_MODE_1),
- TNETV107X_MUX_CFG(17, 0, MUX_MODE_2),
- TNETV107X_MUX_CFG(17, 0, MUX_MODE_3),
- TNETV107X_MUX_CFG(17, 5, MUX_MODE_1),
- TNETV107X_MUX_CFG(17, 5, MUX_MODE_2),
- TNETV107X_MUX_CFG(17, 5, MUX_MODE_3),
- TNETV107X_MUX_CFG(17, 10, MUX_MODE_1),
- TNETV107X_MUX_CFG(17, 10, MUX_MODE_2),
- TNETV107X_MUX_CFG(17, 10, MUX_MODE_3),
- TNETV107X_MUX_CFG(17, 15, MUX_MODE_1),
- TNETV107X_MUX_CFG(17, 15, MUX_MODE_2),
- TNETV107X_MUX_CFG(17, 15, MUX_MODE_3),
- TNETV107X_MUX_CFG(18, 0, MUX_MODE_1),
- TNETV107X_MUX_CFG(18, 0, MUX_MODE_2),
- TNETV107X_MUX_CFG(18, 0, MUX_MODE_3),
- TNETV107X_MUX_CFG(18, 5, MUX_MODE_1),
- TNETV107X_MUX_CFG(18, 5, MUX_MODE_2),
- TNETV107X_MUX_CFG(18, 5, MUX_MODE_3),
- TNETV107X_MUX_CFG(18, 10, MUX_MODE_1),
- TNETV107X_MUX_CFG(18, 10, MUX_MODE_2),
- TNETV107X_MUX_CFG(18, 10, MUX_MODE_3),
- TNETV107X_MUX_CFG(18, 15, MUX_MODE_1),
- TNETV107X_MUX_CFG(18, 15, MUX_MODE_2),
- TNETV107X_MUX_CFG(18, 15, MUX_MODE_3),
- TNETV107X_MUX_CFG(19, 0, MUX_MODE_1),
- TNETV107X_MUX_CFG(19, 5, MUX_MODE_1),
- TNETV107X_MUX_CFG(19, 10, MUX_MODE_1),
- TNETV107X_MUX_CFG(19, 15, MUX_MODE_1),
- TNETV107X_MUX_CFG(19, 20, MUX_MODE_1),
- TNETV107X_MUX_CFG(19, 25, MUX_MODE_1),
- TNETV107X_MUX_CFG(20, 0, MUX_MODE_1),
- TNETV107X_MUX_CFG(20, 5, MUX_MODE_1),
- TNETV107X_MUX_CFG(20, 10, MUX_MODE_1),
- TNETV107X_MUX_CFG(20, 15, MUX_MODE_1),
- TNETV107X_MUX_CFG(20, 15, MUX_MODE_3),
- TNETV107X_MUX_CFG(20, 20, MUX_MODE_1),
- TNETV107X_MUX_CFG(20, 25, MUX_MODE_1),
- TNETV107X_MUX_CFG(21, 0, MUX_MODE_1),
- TNETV107X_MUX_CFG(21, 5, MUX_MODE_1),
- TNETV107X_MUX_CFG(21, 10, MUX_MODE_1),
- TNETV107X_MUX_CFG(21, 15, MUX_MODE_1),
- TNETV107X_MUX_CFG(21, 20, MUX_MODE_1),
- TNETV107X_MUX_CFG(21, 25, MUX_MODE_1),
- TNETV107X_MUX_CFG(22, 0, MUX_MODE_1),
- TNETV107X_MUX_CFG(22, 5, MUX_MODE_1),
- TNETV107X_MUX_CFG(22, 5, MUX_MODE_3),
- TNETV107X_MUX_CFG(22, 10, MUX_MODE_1),
- TNETV107X_MUX_CFG(22, 10, MUX_MODE_3),
- TNETV107X_MUX_CFG(22, 15, MUX_MODE_1),
- TNETV107X_MUX_CFG(22, 15, MUX_MODE_2),
- TNETV107X_MUX_CFG(22, 15, MUX_MODE_3),
- TNETV107X_MUX_CFG(22, 20, MUX_MODE_1),
- TNETV107X_MUX_CFG(22, 20, MUX_MODE_3),
- TNETV107X_MUX_CFG(22, 25, MUX_MODE_1),
- TNETV107X_MUX_CFG(22, 25, MUX_MODE_3),
- TNETV107X_MUX_CFG(23, 0, MUX_MODE_1),
- TNETV107X_MUX_CFG(23, 0, MUX_MODE_3),
- TNETV107X_MUX_CFG(23, 5, MUX_MODE_1),
- TNETV107X_MUX_CFG(23, 5, MUX_MODE_3),
- TNETV107X_MUX_CFG(23, 10, MUX_MODE_1),
- TNETV107X_MUX_CFG(23, 10, MUX_MODE_3),
- TNETV107X_MUX_CFG(24, 0, MUX_MODE_1),
- TNETV107X_MUX_CFG(24, 0, MUX_MODE_2),
- TNETV107X_MUX_CFG(24, 5, MUX_MODE_1),
- TNETV107X_MUX_CFG(24, 5, MUX_MODE_2),
- TNETV107X_MUX_CFG(24, 10, MUX_MODE_1),
- TNETV107X_MUX_CFG(24, 10, MUX_MODE_2),
- TNETV107X_MUX_CFG(24, 10, MUX_MODE_3),
- TNETV107X_MUX_CFG(24, 15, MUX_MODE_1),
- TNETV107X_MUX_CFG(24, 15, MUX_MODE_2),
- TNETV107X_MUX_CFG(24, 15, MUX_MODE_3),
- TNETV107X_MUX_CFG(24, 20, MUX_MODE_1),
- TNETV107X_MUX_CFG(24, 20, MUX_MODE_2),
- TNETV107X_MUX_CFG(24, 25, MUX_MODE_1),
- TNETV107X_MUX_CFG(24, 25, MUX_MODE_2),
- TNETV107X_MUX_CFG(25, 0, MUX_MODE_1),
- TNETV107X_MUX_CFG(25, 0, MUX_MODE_2),
- TNETV107X_MUX_CFG(25, 0, MUX_MODE_3),
- TNETV107X_MUX_CFG(25, 5, MUX_MODE_1),
- TNETV107X_MUX_CFG(25, 5, MUX_MODE_2),
- TNETV107X_MUX_CFG(25, 5, MUX_MODE_3),
- TNETV107X_MUX_CFG(25, 10, MUX_MODE_1),
- TNETV107X_MUX_CFG(25, 10, MUX_MODE_2),
- TNETV107X_MUX_CFG(25, 10, MUX_MODE_3),
- TNETV107X_MUX_CFG(25, 15, MUX_MODE_1),
- TNETV107X_MUX_CFG(25, 15, MUX_MODE_2),
- TNETV107X_MUX_CFG(25, 15, MUX_MODE_3),
- TNETV107X_MUX_CFG(25, 15, MUX_MODE_4),
- TNETV107X_MUX_CFG(26, 0, MUX_MODE_1),
- TNETV107X_MUX_CFG(26, 5, MUX_MODE_1),
- TNETV107X_MUX_CFG(26, 10, MUX_MODE_1),
- TNETV107X_MUX_CFG(26, 10, MUX_MODE_2),
- TNETV107X_MUX_CFG(26, 15, MUX_MODE_1),
- TNETV107X_MUX_CFG(26, 15, MUX_MODE_2),
- TNETV107X_MUX_CFG(26, 20, MUX_MODE_1),
- TNETV107X_MUX_CFG(26, 20, MUX_MODE_2),
- TNETV107X_MUX_CFG(26, 25, MUX_MODE_1),
- TNETV107X_MUX_CFG(26, 25, MUX_MODE_2),
+const int pin_table_size = sizeof(pin_table) / sizeof(pin_table[0]);
+static const short sdio0_pins[] = {
- TNETV107X_PIN_SDIO0_CLK, TNETV107X_PIN_SDIO0_CMD,
- TNETV107X_PIN_SDIO0_DATA0,
- TNETV107X_PIN_SDIO0_DATA1, TNETV107X_PIN_SDIO0_DATA2,
- TNETV107X_PIN_SDIO0_DATA3,
- -1
+static const short sdio1_pins[] = {
- TNETV107X_PIN_SDIO1_CLK_0, TNETV107X_PIN_SDIO1_CMD_0,
- TNETV107X_PIN_SDIO1_DATA0_0, TNETV107X_PIN_SDIO1_DATA1_0,
- TNETV107X_PIN_SDIO1_DATA2_0, TNETV107X_PIN_SDIO1_DATA3_0,
- -1
+static const short uart0_pins[] = {
- TNETV107X_PIN_UART0_CTS, TNETV107X_PIN_UART0_RD,
- TNETV107X_PIN_UART0_RTS,
- TNETV107X_PIN_UART0_TD, -1
+static const short uart1_pins[] = {
- TNETV107X_PIN_UART1_RD, TNETV107X_PIN_UART1_TD, -1
+static const short uart2_pins[] = {
- TNETV107X_PIN_UART2_CTS, TNETV107X_PIN_UART2_RD,
- TNETV107X_PIN_UART2_RTS,
- TNETV107X_PIN_UART2_TD, -1
+static const short keypad_pins[] = {
- TNETV107X_PIN_KEYPAD_R0, TNETV107X_PIN_KEYPAD_R1,
- TNETV107X_PIN_KEYPAD_R2,
- TNETV107X_PIN_KEYPAD_R3, TNETV107X_PIN_KEYPAD_R4,
- TNETV107X_PIN_KEYPAD_R5,
- TNETV107X_PIN_KEYPAD_R6, TNETV107X_PIN_KEYPAD_C0,
- TNETV107X_PIN_KEYPAD_C1,
- TNETV107X_PIN_KEYPAD_C2, TNETV107X_PIN_KEYPAD_C3,
- TNETV107X_PIN_KEYPAD_C4,
- TNETV107X_PIN_KEYPAD_C5, TNETV107X_PIN_KEYPAD_C6, -1
+static const short vlynq_pins[] = {
- TNETV107X_PIN_VLYNQ_CLK, TNETV107X_PIN_VLYNQ_RXD0,
- TNETV107X_PIN_VLYNQ_RXD1,
- TNETV107X_PIN_VLYNQ_TXD0, TNETV107X_PIN_VLYNQ_TXD1, -1
+static const short lcd_pins[] = {
- TNETV107X_PIN_LCD_AC_NCS, TNETV107X_PIN_LCD_HSYNC_RNW,
- TNETV107X_PIN_LCD_VSYNC_A0, TNETV107X_PIN_LCD_PCLK_E,
- TNETV107X_PIN_LCD_PD00,
- TNETV107X_PIN_LCD_PD01, TNETV107X_PIN_LCD_PD02, TNETV107X_PIN_LCD_PD03,
- TNETV107X_PIN_LCD_PD04, TNETV107X_PIN_LCD_PD05, TNETV107X_PIN_LCD_PD06,
- TNETV107X_PIN_LCD_PD07, TNETV107X_PIN_LCD_PD08, TNETV107X_PIN_LCD_PD09,
- TNETV107X_PIN_LCD_PD10, TNETV107X_PIN_LCD_PD11, TNETV107X_PIN_LCD_PD12,
- TNETV107X_PIN_LCD_PD13, TNETV107X_PIN_LCD_PD14, TNETV107X_PIN_LCD_PD15,
- TNETV107X_PIN_LCD_PD16_0, TNETV107X_PIN_LCD_PD17_0,
- TNETV107X_PIN_LCD_PD18,
- TNETV107X_PIN_LCD_PD19_1, TNETV107X_PIN_LCD_PD20_0,
- TNETV107X_PIN_LCD_PD21_0,
- TNETV107X_PIN_LCD_PD22_0, TNETV107X_PIN_LCD_PD23_0, -1
+static const short ssp_pins[] = {
- TNETV107X_PIN_SSP0_0, TNETV107X_PIN_SSP0_1, TNETV107X_PIN_SSP0_2,
- TNETV107X_PIN_SSP1_0, TNETV107X_PIN_SSP1_1, TNETV107X_PIN_SSP1_2,
- TNETV107X_PIN_SSP1_3, -1
+static const short dummy[] = { -1 };
+static const short *psc_pins[] = {
- [TNETV107X_LPSC_ARM] = dummy,
Simplify Initialize with a #define
- [TNETV107X_LPSC_GEM] = dummy,
- [TNETV107X_LPSC_DDR2_PHY] = dummy,
- [TNETV107X_LPSC_TPCC] = dummy,
- [TNETV107X_LPSC_TPTC0] = dummy,
- [TNETV107X_LPSC_TPTC1] = dummy,
- [TNETV107X_LPSC_RAM] = dummy,
- [TNETV107X_LPSC_MBX_LITE] = dummy,
- [TNETV107X_LPSC_LCD] = lcd_pins,
- [TNETV107X_LPSC_ETHSS] = dummy,
- [TNETV107X_LPSC_AEMIF] = dummy,
- [TNETV107X_LPSC_CHIP_CFG] = dummy,
- [TNETV107X_LPSC_TSC] = dummy,
- [TNETV107X_LPSC_ROM] = dummy,
- [TNETV107X_LPSC_UART2] = uart2_pins,
- [TNETV107X_LPSC_PKTSEC] = dummy,
- [TNETV107X_LPSC_SECCTL] = dummy,
- [TNETV107X_LPSC_KEYMGR] = dummy,
- [TNETV107X_LPSC_KEYPAD] = keypad_pins,
- [TNETV107X_LPSC_GPIO] = dummy,
- [TNETV107X_LPSC_MDIO] = dummy,
- [TNETV107X_LPSC_SDIO0] = sdio0_pins,
- [TNETV107X_LPSC_UART0] = uart0_pins,
- [TNETV107X_LPSC_UART1] = uart1_pins,
- [TNETV107X_LPSC_TIMER0] = dummy,
- [TNETV107X_LPSC_TIMER1] = dummy,
- [TNETV107X_LPSC_WDT_ARM] = dummy,
- [TNETV107X_LPSC_WDT_DSP] = dummy,
- [TNETV107X_LPSC_SSP] = ssp_pins,
- [TNETV107X_LPSC_TDM0] = dummy,
- [TNETV107X_LPSC_VLYNQ] = vlynq_pins,
- [TNETV107X_LPSC_MCDMA] = dummy,
- [TNETV107X_LPSC_USB0] = dummy,
- [TNETV107X_LPSC_TDM1] = dummy,
- [TNETV107X_LPSC_DEBUGSS] = dummy,
- [TNETV107X_LPSC_ETHSS_RGMII] = dummy,
- [TNETV107X_LPSC_SYSTEM] = dummy,
- [TNETV107X_LPSC_IMCOP] = dummy,
- [TNETV107X_LPSC_SPARE] = dummy,
- [TNETV107X_LPSC_SDIO1] = sdio1_pins,
- [TNETV107X_LPSC_USB1] = dummy,
- [TNETV107X_LPSC_USBSS] = dummy,
- [TNETV107X_LPSC_DDR2_EMIF1_VRST] = dummy,
- [TNETV107X_LPSC_DDR2_EMIF2_VCTL_RST] = dummy,
The preceding tables look like they could be used generally. If this is the case, move them to an arch *.h file.
+const int psc_pins_size = sizeof(psc_pins) / sizeof(psc_pins[0]);
+int mux_select_pin(unsigned index) +{
- const struct pin_config *cfg;
- unsigned long mask, mode, reg;
- if (index >= pin_table_size)
- cfg = &pin_table[index];
- mask = 0x1f << cfg->mask_offset;
- mode = cfg->mode << cfg->mask_offset;
- reg = __raw_readl(TNETV107X_PINMUX(cfg->reg_index));
- reg = (reg & ~mask) | mode;
- __raw_writel(reg, TNETV107X_PINMUX(cfg->reg_index));
- return 1;
+int mux_select_pins(const short *pins) +{
- int i, ret = 1;
- for (i = 0; pins[i] >= 0; i++)
ret &= mux_select_pin(pins[i]);
- return ret;
+int mux_select_module(int lpsc) +{
- if (lpsc >= psc_pins_size)
- return mux_select_pins(psc_pins[lpsc]);
+} diff --git a/arch/arm/cpu/arm1176/tnetv107x/timer.c b/arch/arm/cpu/arm1176/tnetv107x/timer.c new file mode 100644 index 0000000..2ba3f54 --- /dev/null +++ b/arch/arm/cpu/arm1176/tnetv107x/timer.c @@ -0,0 +1,125 @@ +/*
- TNETV107X: Timer implementation
- project.
+struct timer_regs {
- u_int32_t pid12;
- u_int32_t pad[3];
- u_int32_t tim12;
- u_int32_t tim34;
- u_int32_t prd12;
- u_int32_t prd34;
- u_int32_t tcr;
- u_int32_t tgcr;
- u_int32_t wdtcr;
+#define regs ((struct timer_regs *)CONFIG_SYS_TIMERBASE)
+#define TIMER_LOAD_VAL (CONFIG_SYS_HZ_CLOCK / CONFIG_SYS_HZ) +#define TIM_CLK_DIV 16
+static ulong timestamp; +static ulong lastinc;
+void init_timer(void) +{
- clk_enable(TNETV107X_LPSC_TIMER0);
- lastinc = timestamp = 0;
- /* We are using timer34 in unchained 32-bit mode, full speed */
- __raw_writel(0x0, ®s->tcr);
- __raw_writel(0x0, ®s->tgcr);
- __raw_writel(0x06 | ((TIM_CLK_DIV - 1) << 8), ®s->tgcr);
- __raw_writel(0x0, ®s->tim34);
- __raw_writel(TIMER_LOAD_VAL, ®s->prd34);
- __raw_writel(2 << 22, ®s->tcr);
+int timer_init(void) +{
+void reset_timer(void) +{
- __raw_writel(0, ®s->tcr);
- __raw_writel(0, ®s->tim34);
+static ulong get_timer_raw(void) +{
- ulong now = __raw_readl(®s->tim34);
- if (now >= lastinc)
timestamp += now - lastinc;
- else
timestamp += now + TIMER_LOAD_VAL - lastinc;
- lastinc = now;
- return timestamp;
+ulong get_timer(ulong base) +{
- return (get_timer_raw() / (TIMER_LOAD_VAL / TIM_CLK_DIV)) - base;
+void set_timer(ulong t) +{
- timestamp = t;
+unsigned long long get_ticks(void) +{
- return get_timer(0);
+void __udelay(unsigned long usec) +{
- ulong tmo;
- ulong endtime;
- signed long diff;
- tmo = CONFIG_SYS_HZ_CLOCK / 1000;
- tmo *= usec;
- tmo /= (1000 * TIM_CLK_DIV);
- endtime = get_timer_raw() + tmo;
- do {
ulong now = get_timer_raw();
diff = endtime - now;
- } while (diff >= 0);
+ulong get_tbclk(void) +{
- return CONFIG_SYS_HZ;
+} diff --git a/arch/arm/cpu/arm1176/tnetv107x/wdt.c b/arch/arm/cpu/arm1176/tnetv107x/wdt.c new file mode 100644 index 0000000..eeed136 --- /dev/null +++ b/arch/arm/cpu/arm1176/tnetv107x/wdt.c @@ -0,0 +1,172 @@ +/*
- TNETV107X: Watchdog timer implementation (for reset)
- project.
+#define MAX_DIV 0xFFFE0001
+struct wdt_regs {
- u32 kick_lock;
- u32 kick;
- u32 change_lock;
- u32 change;
- u32 disable_lock;
- u32 disable;
- u32 prescale_lock;
- u32 prescale;
+static struct wdt_regs* regs = (struct wdt_regs *)TNETV107X_WDT0_ARM_BASE;
+#define wdt_reg_read(reg) __raw_readl(®s->reg) +#define wdt_reg_write(reg, val) __raw_writel((val), ®s->reg)
+static int write_prescale_reg(unsigned long prescale_value) +{
- wdt_reg_write(prescale_lock, 0x5a5a);
- if ((wdt_reg_read(prescale_lock) & 0x3) != 0x1)
return -1;
Move 0x5a5a to a #define Similar for others
- wdt_reg_write(prescale_lock, 0xa5a5);
- if ((wdt_reg_read(prescale_lock) & 0x3) != 0x3)
return -1;
- wdt_reg_write(prescale, prescale_value);
+static int write_change_reg(unsigned long initial_timer_value) +{
- wdt_reg_write(change_lock, 0x6666);
- if ((wdt_reg_read(change_lock) & 0x3) != 0x1)
return -1;
- wdt_reg_write(change_lock, 0xbbbb);
- if ((wdt_reg_read(change_lock) & 0x3) != 0x3)
return -1;
- wdt_reg_write(change, initial_timer_value);
+static int wdt_control(unsigned long disable_value) +{
- wdt_reg_write(disable_lock, 0x7777);
- if ((wdt_reg_read(disable_lock) & 0x3) != 0x1)
return -1;
- wdt_reg_write(disable_lock, 0xcccc);
- if ((wdt_reg_read(disable_lock) & 0x3) != 0x2)
return -1;
- wdt_reg_write(disable_lock, 0xdddd);
- if ((wdt_reg_read(disable_lock) & 0x3) != 0x3)
return -1;
- wdt_reg_write(disable, disable_value);
+static int wdt_set_period(unsigned long msec) +{
- unsigned long change_value, count_value;
- unsigned long prescale_value = 1;
- unsigned long refclk_khz, maxdiv;
- int ret;
- refclk_khz = clk_get_rate(TNETV107X_LPSC_WDT_ARM);
- maxdiv = (MAX_DIV / refclk_khz);
- if ((!msec) || (msec > maxdiv))
return -1;
- count_value = refclk_khz * msec;
- if (count_value > 0xffff) {
change_value = count_value / 0xffff + 1;
prescale_value = count_value / change_value;
- } else {
change_value = count_value;
- ret = write_prescale_reg(prescale_value - 1);
- if (ret)
return ret;
- ret = write_change_reg(change_value);
- if (ret)
return ret;
+unsigned long last_wdt = -1;
+int wdt_start(unsigned long msecs) +{
- int ret;
- ret = wdt_control(0);
- if (ret)
return ret;
- ret = wdt_set_period(msecs);
- if (ret)
return ret;
- ret = wdt_control(1);
- if (ret)
return ret;
- ret = wdt_kick();
- last_wdt = msecs;
- return ret;
+int wdt_stop(void) +{
- last_wdt = -1;
- return wdt_control(0);
+int wdt_kick(void) +{
- wdt_reg_write(kick_lock, 0x5555);
- if ((wdt_reg_read(kick_lock) & 0x3) != 0x1)
return -1;
- wdt_reg_write(kick_lock, 0xaaaa);
- if ((wdt_reg_read(kick_lock) & 0x3) != 0x3)
return -1;
- wdt_reg_write(kick, 1);
+void reset_cpu(ulong addr) +{
- wdt_start(1);
- wdt_kick();
+void init_wdt(void) +{
+} diff --git a/arch/arm/include/asm/arch-tnetv107x/clock.h b/arch/arm/include/asm/arch-tnetv107x/clock.h new file mode 100644 index 0000000..369e11b --- /dev/null +++ b/arch/arm/include/asm/arch-tnetv107x/clock.h @@ -0,0 +1,50 @@ +/*
- TNETV107X: Clock APIs
- project.
+#ifndef __ASM_ARCH_CLOCK_H +#define __ASM_ARCH_CLOCK_H
+#define PSC_MDCTL_NEXT_SWRSTDISABLE 0x0 +#define PSC_MDCTL_NEXT_SYNCRST 0x1 +#define PSC_MDCTL_NEXT_DISABLE 0x2 +#define PSC_MDCTL_NEXT_ENABLE 0x3
+#ifndef __ASSEMBLY__ +int lpsc_status(unsigned int id); +void lpsc_control(int nmod, int lrstz, ...);
This this only called with 1 arg. vargs is not needed. Convert to a normal calling Convert other functions called from this function.
+void pinmux_enable(unsigned int id, int enable); +unsigned long clk_get_rate(unsigned int clk); +long clk_round_rate(unsigned int clk, unsigned long hz); +int clk_set_rate(unsigned int clk, unsigned long hz);
+static inline void clk_enable(unsigned int id) +{
- lpsc_control(1, -1, id, PSC_MDCTL_NEXT_ENABLE);
+static inline void clk_disable(unsigned int id) +{
- lpsc_control(1, -1, id, PSC_MDCTL_NEXT_DISABLE);
+#endif diff --git a/arch/arm/include/asm/arch-tnetv107x/emif_defs.h b/arch/arm/include/asm/arch-tnetv107x/emif_defs.h new file mode 100644 index 0000000..9969a01 --- /dev/null +++ b/arch/arm/include/asm/arch-tnetv107x/emif_defs.h @@ -0,0 +1 @@ +#include <asm/arch-davinci/emif_defs.h> diff --git a/arch/arm/include/asm/arch-tnetv107x/hardware.h b/arch/arm/include/asm/arch-tnetv107x/hardware.h new file mode 100644 index 0000000..824555c --- /dev/null +++ b/arch/arm/include/asm/arch-tnetv107x/hardware.h @@ -0,0 +1,184 @@ +/*
- TNETV107X: Hardware information
- project.
+#ifndef __ASM_ARCH_HARDWARE_H +#define __ASM_ARCH_HARDWARE_H
+#define DIV_CEILING(num, den) ((((num)+(den)-1)/(den))-1) +#define DIV_FLOOR(num, den) (((num)/(den))-1)
These two are not used anywhere and should be removed.
+#define ABS(x) (((x) < 0) ? -(x) : (x))
This is only used once. A macro is overkill This could be removed.
+#define ASYNC_EMIF_PRESERVE -1 +struct async_emif_config {
- unsigned mode;
- unsigned select_strobe;
- unsigned extend_wait;
- unsigned wr_setup;
- unsigned wr_strobe;
- unsigned wr_hold;
- unsigned rd_setup;
- unsigned rd_strobe;
- unsigned rd_hold;
- unsigned turn_around;
- enum {
ASYNC_EMIF_8 = 0,
ASYNC_EMIF_16 = 1,
ASYNC_EMIF_32 = 2,
- } width;
+void init_plls(void); +void clk_delay(void);
+void init_async_emif(void); +void suspend_async_emif(void); +void restore_async_emif(void);
+void init_timer(void); +void suspend_timer(void); +void restore_timer(void);
+void init_wdt(void); +void suspend_wdt(void); +void restore_wdt(void); +int wdt_start(unsigned long msecs); +int wdt_stop(void); +int wdt_kick(void);
+/* Chip configuration unlock codes and registers */ +#define TNETV107X_KICK0 (TNETV107X_CHIP_CONFIG_SYS_BASE+0x38) +#define TNETV107X_KICK1 (TNETV107X_CHIP_CONFIG_SYS_BASE+0x3c) +#define TNETV107X_PINMUX(n) (TNETV107X_CHIP_CONFIG_SYS_BASE+0x150+(n)*4) +#define TNETV107X_KICK0_MAGIC 0x83e70b13 +#define TNETV107X_KICK1_MAGIC 0x95a4f1e0
+/* Module base addresses */ +#define TNETV107X_TPCC_BASE 0x01C00000 +#define TNETV107X_TPTC0_BASE 0x01C10000 +#define TNETV107X_TPTC1_BASE 0x01C10400 +#define TNETV107X_INTC_BASE 0x03000000 +#define TNETV107X_LCD_CONTROLLER_BASE 0x08030000 +#define TNETV107X_INTD_BASE 0x08038000 +#define TNETV107X_INTD_IPC_BASE 0x08038000 +#define TNETV107X_INTD_FAST_BASE 0x08039000 +#define TNETV107X_INTD_ASYNC_BASE 0x0803A000 +#define TNETV107X_INTD_SLOW_BASE 0x0803B000 +#define TNETV107X_PKA_BASE 0x08040000 +#define TNETV107X_RNG_BASE 0x08044000 +#define TNETV107X_TIMER0_BASE 0x08086500 +#define TNETV107X_TIMER1_BASE 0x08086600 +#define TNETV107X_WDT0_ARM_BASE 0x08086700 +#define TNETV107X_WDT1_DSP_BASE 0x08086800 +#define TNETV107X_CHIP_CONFIG_SYS_BASE 0x08087000 +#define TNETV107X_GPIO_BASE 0x08088000 +#define TNETV107X_UART1_BASE 0x08088400 +#define TNETV107X_TOUCHSCREEN_BASE 0x08088500 +#define TNETV107X_SDIO0_BASE 0x08088700 +#define TNETV107X_SDIO1_BASE 0x08088800 +#define TNETV107X_MDIO_BASE 0x08088900 +#define TNETV107X_KEYPAD_BASE 0x08088A00 +#define TNETV107X_SSP_BASE 0x08088C00 +#define TNETV107X_CLOCK_CONTROL_BASE 0x0808A000 +#define TNETV107X_PSC_BASE 0x0808B000 +#define TNETV107X_TDM0_BASE 0x08100000 +#define TNETV107X_TDM1_BASE 0x08100100 +#define TNETV107X_MCDMA_BASE 0x08108000 +#define TNETV107X_UART0_DMA_BASE 0x08108200 +#define TNETV107X_USBSS_BASE 0x08120000 +#define TNETV107X_VLYNQ_CONTROL_BASE 0x0810D000 +#define TNETV107X_ASYNC_EMIF_CNTRL_BASE 0x08200000 +#define TNETV107X_VLYNQ_MEM_MAP_BASE 0x0C000000 +#define TNETV107X_IMCOP_BASE 0x01CC0000 +#define TNETV107X_MBX_LITE_BASE 0x07000000 +#define TNETV107X_ETHSS_BASE 0x0803C000 +#define TNETV107X_CPSW_BASE 0x0803C000 +#define TNETV107X_SPF_BASE 0x0803C800 +#define TNETV107X_IOPU_ETHSS_BASE 0x0803D000 +#define TNETV107X_VTP_CNTRL_0 0x0803D800 +#define TNETV107X_VTP_CNTRL_1 0x0803D900 +#define TNETV107X_UART2_DMA_BASE 0x08108400 +#define TNETV107X_INTERNAL_MEMORY 0x20000000 +#define TNETV107X_ASYNC_EMIF_DATA_CE0_BASE 0x30000000 +#define TNETV107X_ASYNC_EMIF_DATA_CE1_BASE 0x40000000 +#define TNETV107X_ASYNC_EMIF_DATA_CE2_BASE 0x44000000 +#define TNETV107X_ASYNC_EMIF_DATA_CE3_BASE 0x48000000 +#define TNETV107X_DDR_EMIF_DATA_BASE 0x80000000 +#define TNETV107X_DDR_EMIF_CONTROL_BASE 0x90000000
+/* LPSC module definitions */ +#define TNETV107X_LPSC_ARM 0 +#define TNETV107X_LPSC_GEM 1 +#define TNETV107X_LPSC_DDR2_PHY 2 +#define TNETV107X_LPSC_TPCC 3 +#define TNETV107X_LPSC_TPTC0 4 +#define TNETV107X_LPSC_TPTC1 5 +#define TNETV107X_LPSC_RAM 6 +#define TNETV107X_LPSC_MBX_LITE 7 +#define TNETV107X_LPSC_LCD 8 +#define TNETV107X_LPSC_ETHSS 9 +#define TNETV107X_LPSC_AEMIF 10 +#define TNETV107X_LPSC_CHIP_CFG 11 +#define TNETV107X_LPSC_TSC 12 +#define TNETV107X_LPSC_ROM 13 +#define TNETV107X_LPSC_UART2 14 +#define TNETV107X_LPSC_PKTSEC 15 +#define TNETV107X_LPSC_SECCTL 16 +#define TNETV107X_LPSC_KEYMGR 17 +#define TNETV107X_LPSC_KEYPAD 18 +#define TNETV107X_LPSC_GPIO 19 +#define TNETV107X_LPSC_MDIO 20 +#define TNETV107X_LPSC_SDIO0 21 +#define TNETV107X_LPSC_UART0 22 +#define TNETV107X_LPSC_UART1 23 +#define TNETV107X_LPSC_TIMER0 24 +#define TNETV107X_LPSC_TIMER1 25 +#define TNETV107X_LPSC_WDT_ARM 26 +#define TNETV107X_LPSC_WDT_DSP 27 +#define TNETV107X_LPSC_SSP 28 +#define TNETV107X_LPSC_TDM0 29 +#define TNETV107X_LPSC_VLYNQ 30 +#define TNETV107X_LPSC_MCDMA 31 +#define TNETV107X_LPSC_USB0 32 +#define TNETV107X_LPSC_TDM1 33 +#define TNETV107X_LPSC_DEBUGSS 34 +#define TNETV107X_LPSC_ETHSS_RGMII 35 +#define TNETV107X_LPSC_SYSTEM 36 +#define TNETV107X_LPSC_IMCOP 37 +#define TNETV107X_LPSC_SPARE 38 +#define TNETV107X_LPSC_SDIO1 39 +#define TNETV107X_LPSC_USB1 40 +#define TNETV107X_LPSC_USBSS 41 +#define TNETV107X_LPSC_DDR2_EMIF1_VRST 42 +#define TNETV107X_LPSC_DDR2_EMIF2_VCTL_RST 43 +#define TNETV107X_LPSC_MAX 44
+/* Interrupt controller */ +#define INTC_GLB_EN (TNETV107X_INTC_BASE + 0x10) +#define INTC_HINT_EN (TNETV107X_INTC_BASE + 0x1500) +#define INTC_EN_CLR0 (TNETV107X_INTC_BASE + 0x380)
+#endif /* __ASM_ARCH_HARDWARE_H */ diff --git a/arch/arm/include/asm/arch-tnetv107x/mux.h b/arch/arm/include/asm/arch-tnetv107x/mux.h new file mode 100644 index 0000000..274c037 --- /dev/null +++ b/arch/arm/include/asm/arch-tnetv107x/mux.h @@ -0,0 +1,307 @@ +/*
- TNETV107X: Pinmux APIs
- project.
+#ifndef __ASM_ARCH_MUX_H +#define __ASM_ARCH_MUX_H
+struct pin_config {
- unsigned char reg_index;
- unsigned char mask_offset;
- unsigned char mode;
+#define TNETV107X_MUX_CFG(reg, offset, mux_mode) \
{ reg, offset, mux_mode }
+int mux_select_pin(unsigned index);
These are already defined in asm/arch-tnetv107x/mux.h Remove this version
+int mux_select_pins(const short *pins); +int mux_select_module(int lpsc);
These are only used in mux.c Convert these to static
+enum tnetv107x_pin_mux_index {
- TNETV107X_PIN_ASR_A00,
- TNETV107X_PIN_GPIO32,
- TNETV107X_PIN_ASR_A01,
- TNETV107X_PIN_GPIO33,
- TNETV107X_PIN_ASR_A02,
- TNETV107X_PIN_GPIO34,
- TNETV107X_PIN_ASR_A03,
- TNETV107X_PIN_GPIO35,
- TNETV107X_PIN_ASR_A04,
- TNETV107X_PIN_GPIO36,
- TNETV107X_PIN_ASR_A05,
- TNETV107X_PIN_GPIO37,
- TNETV107X_PIN_ASR_A06,
- TNETV107X_PIN_GPIO38,
- TNETV107X_PIN_ASR_A07,
- TNETV107X_PIN_GPIO39,
- TNETV107X_PIN_ASR_A08,
- TNETV107X_PIN_GPIO40,
- TNETV107X_PIN_ASR_A09,
- TNETV107X_PIN_GPIO41,
- TNETV107X_PIN_ASR_A10,
- TNETV107X_PIN_GPIO42,
- TNETV107X_PIN_ASR_A11,
- TNETV107X_PIN_BOOT_STRP_0,
- TNETV107X_PIN_ASR_A12,
- TNETV107X_PIN_BOOT_STRP_1,
- TNETV107X_PIN_ASR_A13,
- TNETV107X_PIN_GPIO43,
- TNETV107X_PIN_ASR_A14,
- TNETV107X_PIN_GPIO44,
- TNETV107X_PIN_ASR_A15,
- TNETV107X_PIN_GPIO45,
- TNETV107X_PIN_ASR_A16,
- TNETV107X_PIN_GPIO46,
- TNETV107X_PIN_ASR_A17,
- TNETV107X_PIN_GPIO47,
- TNETV107X_PIN_ASR_A18,
- TNETV107X_PIN_GPIO48,
- TNETV107X_PIN_SDIO1_DATA3_0,
- TNETV107X_PIN_ASR_A19,
- TNETV107X_PIN_GPIO49,
- TNETV107X_PIN_ASR_A20,
- TNETV107X_PIN_GPIO50,
- TNETV107X_PIN_SDIO1_DATA1_0,
- TNETV107X_PIN_ASR_A21,
- TNETV107X_PIN_GPIO51,
- TNETV107X_PIN_ASR_A22,
- TNETV107X_PIN_GPIO52,
- TNETV107X_PIN_SDIO1_CMD_0,
- TNETV107X_PIN_ASR_A23,
- TNETV107X_PIN_GPIO53,
- TNETV107X_PIN_ASR_BA_1,
- TNETV107X_PIN_GPIO54,
- TNETV107X_PIN_SYS_PLL_CLK,
- TNETV107X_PIN_ASR_CS0,
- TNETV107X_PIN_ASR_CS1,
- TNETV107X_PIN_ASR_CS2,
- TNETV107X_PIN_TDM_PLL_CLK,
- TNETV107X_PIN_ASR_CS3,
- TNETV107X_PIN_ETH_PHY_CLK,
- TNETV107X_PIN_ASR_D00,
- TNETV107X_PIN_GPIO55,
- TNETV107X_PIN_ASR_D01,
- TNETV107X_PIN_GPIO56,
- TNETV107X_PIN_ASR_D02,
- TNETV107X_PIN_GPIO57,
- TNETV107X_PIN_ASR_D03,
- TNETV107X_PIN_GPIO58,
- TNETV107X_PIN_ASR_D04,
- TNETV107X_PIN_GPIO59_0,
- TNETV107X_PIN_ASR_D05,
- TNETV107X_PIN_GPIO60_0,
- TNETV107X_PIN_ASR_D06,
- TNETV107X_PIN_GPIO61_0,
- TNETV107X_PIN_ASR_D07,
- TNETV107X_PIN_GPIO62_0,
- TNETV107X_PIN_ASR_D08,
- TNETV107X_PIN_GPIO63_0,
- TNETV107X_PIN_ASR_D09,
- TNETV107X_PIN_GPIO64_0,
- TNETV107X_PIN_ASR_D10,
- TNETV107X_PIN_SDIO1_DATA3_1,
- TNETV107X_PIN_ASR_D11,
- TNETV107X_PIN_SDIO1_DATA2_1,
- TNETV107X_PIN_ASR_D12,
- TNETV107X_PIN_SDIO1_DATA1_1,
- TNETV107X_PIN_ASR_D13,
- TNETV107X_PIN_SDIO1_DATA0_1,
- TNETV107X_PIN_ASR_D14,
- TNETV107X_PIN_SDIO1_CMD_1,
- TNETV107X_PIN_ASR_D15,
- TNETV107X_PIN_SDIO1_CLK_1,
- TNETV107X_PIN_ASR_OE,
- TNETV107X_PIN_BOOT_STRP_2,
- TNETV107X_PIN_ASR_RNW,
- TNETV107X_PIN_GPIO29_0,
- TNETV107X_PIN_ASR_WAIT,
- TNETV107X_PIN_GPIO30_0,
- TNETV107X_PIN_ASR_WE,
- TNETV107X_PIN_BOOT_STRP_3,
- TNETV107X_PIN_ASR_WE_DQM0,
- TNETV107X_PIN_GPIO31,
- TNETV107X_PIN_LCD_PD17_0,
- TNETV107X_PIN_ASR_WE_DQM1,
- TNETV107X_PIN_ASR_BA0_0,
- TNETV107X_PIN_GPIO14,
- TNETV107X_PIN_LCD_PD19_0,
- TNETV107X_PIN_VLYNQ_RXD0,
- TNETV107X_PIN_GPIO15,
- TNETV107X_PIN_LCD_PD20_0,
- TNETV107X_PIN_GPIO16,
- TNETV107X_PIN_GPIO17,
- TNETV107X_PIN_VLYNQ_TXD1,
- TNETV107X_PIN_GPIO18,
- TNETV107X_PIN_LCD_PD23_0,
- TNETV107X_PIN_GPIO19,
- TNETV107X_PIN_SDIO0_CMD,
- TNETV107X_PIN_GPIO20,
- TNETV107X_PIN_GPIO21,
- TNETV107X_PIN_GPIO22,
- TNETV107X_PIN_SDIO0_DATA2,
- TNETV107X_PIN_GPIO23,
- TNETV107X_PIN_GPIO24,
- TNETV107X_PIN_EMU0,
- TNETV107X_PIN_EMU1,
- TNETV107X_PIN_RTCK,
- TNETV107X_PIN_TRST_N,
- TNETV107X_PIN_TCK,
- TNETV107X_PIN_TDI,
- TNETV107X_PIN_TDO,
- TNETV107X_PIN_TMS,
- TNETV107X_PIN_TDM1_CLK,
- TNETV107X_PIN_TDM1_RX,
- TNETV107X_PIN_TDM1_TX,
- TNETV107X_PIN_TDM1_FS,
- TNETV107X_PIN_KEYPAD_R1,
- TNETV107X_PIN_KEYPAD_R4,
- TNETV107X_PIN_GPIO12,
- TNETV107X_PIN_KEYPAD_R7,
- TNETV107X_PIN_GPIO10,
- TNETV107X_PIN_KEYPAD_C0,
- TNETV107X_PIN_KEYPAD_C3,
- TNETV107X_PIN_KEYPAD_C6,
- TNETV107X_PIN_GPIO13,
- TNETV107X_PIN_TEST_CLK_IN,
- TNETV107X_PIN_KEYPAD_C7,
- TNETV107X_PIN_GPIO11,
- TNETV107X_PIN_SCC_DCLK,
- TNETV107X_PIN_LCD_PD20_1,
- TNETV107X_PIN_SSP0_1,
- TNETV107X_PIN_SCC_CS_N,
- TNETV107X_PIN_LCD_PD21_1,
- TNETV107X_PIN_SSP0_2,
- TNETV107X_PIN_SCC_D,
- TNETV107X_PIN_LCD_PD22_1,
- TNETV107X_PIN_SSP0_3,
- TNETV107X_PIN_SCC_RESETN,
- TNETV107X_PIN_LCD_PD23_1,
- TNETV107X_PIN_GPIO25,
- TNETV107X_PIN_SSP1_1,
- TNETV107X_PIN_GPIO26,
- TNETV107X_PIN_UART2_RD,
- TNETV107X_PIN_SSP1_2,
- TNETV107X_PIN_GPIO27,
- TNETV107X_PIN_GPIO28,
- TNETV107X_PIN_UART0_RD,
- TNETV107X_PIN_UART1_TD,
- TNETV107X_PIN_LCD_HSYNC_RNW,
- TNETV107X_PIN_LCD_MCLK,
- TNETV107X_PIN_LCD_PCLK_E,
- TNETV107X_PIN_LCD_PD02,
- TNETV107X_PIN_LCD_PD03,
- TNETV107X_PIN_LCD_PD05,
- TNETV107X_PIN_LCD_PD06,
- TNETV107X_PIN_LCD_PD08,
- TNETV107X_PIN_GPIO59_1,
- TNETV107X_PIN_LCD_PD09,
- TNETV107X_PIN_GPIO60_1,
- TNETV107X_PIN_ASR_BA0_1,
- TNETV107X_PIN_GPIO61_1,
- TNETV107X_PIN_LCD_PD11,
- TNETV107X_PIN_GPIO62_1,
- TNETV107X_PIN_LCD_PD12,
- TNETV107X_PIN_GPIO63_1,
- TNETV107X_PIN_GPIO64_1,
- TNETV107X_PIN_LCD_PD14,
- TNETV107X_PIN_GPIO29_1,
- TNETV107X_PIN_LCD_PD15,
- TNETV107X_PIN_GPIO30_1,
- TNETV107X_PIN_EINT0,
- TNETV107X_PIN_GPIO08,
- TNETV107X_PIN_EINT1,
- TNETV107X_PIN_GPIO09,
- TNETV107X_PIN_GPIO00,
- TNETV107X_PIN_LCD_PD20_2,
- TNETV107X_PIN_TDM_CLK_IN_2,
- TNETV107X_PIN_GPIO01,
- TNETV107X_PIN_LCD_PD21_2,
- TNETV107X_PIN_24M_CLK_OUT_1,
- TNETV107X_PIN_GPIO02,
- TNETV107X_PIN_LCD_PD22_2,
- TNETV107X_PIN_GPIO03,
- TNETV107X_PIN_LCD_PD23_2,
- TNETV107X_PIN_GPIO04,
- TNETV107X_PIN_LCD_PD16_1,
- TNETV107X_PIN_USB0_RXERR,
- TNETV107X_PIN_GPIO05,
- TNETV107X_PIN_LCD_PD17_1,
- TNETV107X_PIN_TDM_CLK_IN_1,
- TNETV107X_PIN_GPIO06,
- TNETV107X_PIN_24M_CLK_OUT_2,
- TNETV107X_PIN_GPIO07,
- TNETV107X_PIN_USB1_RXERR,
- TNETV107X_PIN_ETH_PLL_CLK,
- TNETV107X_PIN_MDIO,
- TNETV107X_PIN_MDC,
- TNETV107X_PIN_AIC_MUTE_STAT_N,
- TNETV107X_PIN_TDM0_CLK,
- TNETV107X_PIN_AIC_HNS_EN_N,
- TNETV107X_PIN_TDM0_FS,
- TNETV107X_PIN_AIC_HDS_EN_STAT_N,
- TNETV107X_PIN_TDM0_TX,
- TNETV107X_PIN_AIC_HNF_EN_STAT_N,
- TNETV107X_PIN_TDM0_RX,
+#endif diff --git a/arch/arm/include/asm/arch-tnetv107x/nand_defs.h b/arch/arm/include/asm/arch-tnetv107x/nand_defs.h new file mode 100644 index 0000000..961b710 --- /dev/null +++ b/arch/arm/include/asm/arch-tnetv107x/nand_defs.h @@ -0,0 +1,38 @@ +/*
- TNETV107X: NAND definitions
- project.
+#ifndef _NAND_DEFS_H_ +#define _NAND_DEFS_H_
+#include <asm/arch/hardware.h> +#include <asm/arch/emif_defs.h>
+#define DAVINCI_ASYNC_EMIF_CNTRL_BASE TNETV107X_ASYNC_EMIF_CNTRL_BASE
+#define MASK_CLE 0x4000 +#define MASK_ALE 0x2000
+#define NAND_READ_START 0x00 +#define NAND_READ_END 0x30 +#define NAND_STATUS 0x70
+extern void davinci_nand_init(struct nand_chip *nand);
Tom
Hi Tom,
Thanks for the excellent review.
{ /* CS0 */
I have moved this over to board code instead, since the board should determine these based on the connected device's timings.
[SYS_PLL] = {
.pll = SYS_PLL,
.div_freq = {
Again, moved these initializations to board code instead. Some boards may opt to run at different rates.
These are register indices and bit shifts, not really amenable to macro definition. I have put in a comment for the column contents.
Regards Cyril.
Cyril Chemparathy
Tom Rix
