[U-Boot] [PATCH] MIPS: fix types u64 and __u64 to unsigned long long
Linux MIPS uses asm-generic/int-ll64.h in asm/types.h. Thus u64 and __u64 are defined as unsigned long long. Port this over to U-Boot.
Signed-off-by: Daniel Schwierzeck daniel.schwierzeck@gmail.com --- This fixes all warnings on qemu_mips64 introduced by patch http://patchwork.ozlabs.org/patch/324673/. --- arch/mips/include/asm/types.h | 23 +++-------------------- 1 file changed, 3 insertions(+), 20 deletions(-)
diff --git a/arch/mips/include/asm/types.h b/arch/mips/include/asm/types.h index d4bb859..aebafdb 100644 --- a/arch/mips/include/asm/types.h +++ b/arch/mips/include/asm/types.h @@ -27,18 +27,12 @@ typedef unsigned short __u16; typedef __signed__ int __s32; typedef unsigned int __u32;
-#if (_MIPS_SZLONG == 64) - -typedef __signed__ long __s64; -typedef unsigned long __u64; - -#else - #if defined(__GNUC__) __extension__ typedef __signed__ long long __s64; __extension__ typedef unsigned long long __u64; -#endif - +#else +typedef __signed__ long long __s64; +typedef unsigned long long __u64; #endif
#endif /* __ASSEMBLY__ */ @@ -61,19 +55,8 @@ typedef unsigned short u16; typedef __signed int s32; typedef unsigned int u32;
-#if (_MIPS_SZLONG == 64) - -typedef __signed__ long s64; -typedef unsigned long u64; - -#else - -#if defined(__GNUC__) && !defined(__STRICT_ANSI__) typedef __signed__ long long s64; typedef unsigned long long u64; -#endif - -#endif
#if (defined(CONFIG_HIGHMEM) && defined(CONFIG_64BIT_PHYS_ADDR)) \ || defined(CONFIG_64BIT)
-----BEGIN PGP SIGNED MESSAGE----- Hash: SHA1
I hoped this would be the fix, thanks!
Acked-by: Tom Rini trini@ti.com
And if you want to get me a u-boot-mips PR soon I'll take it along.
- -- Tom
Daniel Schwierzeck
