Re: [U-Boot] [PATCH 1/1] powerpc/lib: fix unsafe register handling in wait_ticks
On Tue, Apr 09, 2013 at 05:10:59PM +0200, Mats K??rrman wrote:
If watchdog is enabled, the arch/powerpc/lib/ticks.S::wait_ticks() function calls the function specified by the WATCHDOG_RESET macro. The wait_ticks function depends on the registers r0, r6 and r7 being preserved however that is not guaranteed, e.g. if the reset function is a C function this will probably overwrite r0 and cause an endless loop.
The following patch changes to using r14+r15 instead of r6+r7 (to resemble what would have been generated by a C compiler) and saves all necessary registers on the stack.
The patch has been tested on a custom MPC5125 based machine using the 512x powerpc architecture.
Signed-off-by: Mats Karrman mats.karrman@tritech.se Cc: Wolfgang Denk wd@denx.de Acked-by: Joakim Tjernlund joakim.tjernlund@transmode.se Tested-by: Stefan Roese sr@denx.de
