[U-Boot] [PATCHv4 0/9] ARM: socfpga: Add minimal support for Arria10
This is v4 of the patch series that adds minimal support for Altera's Arria10 platform.
v4: - s/CONFIG_SOCFPGA_GEN5/CONFIG_TARGET_SOCFPGA_GEN5 - rename mod_reset(s) in the gen5 reset manager to match a10 - clean up of #if-else throughout misc.c - reorder CONFIG_TARGET_SOCFPGA_ARRIA10 - add SYSMGR_SDMMC_DRVSEL_SHIFT - s/SYSMGR_SDMMC_SMPSEL_SHIFT/SYSMGR_SDMMC_SMPLSEL_SHIFT
v3: - Add CONFIG_SOCFPGA_GEN5 for building for Arria5 and Cyclone5 - Clean up socfpga_arria10_socdk - Add patch to remove the macro SYSMGR_SDMMC_CTRL_SET - Move system_manager_a10.h into system_manager.h - Rebase to u-boot-socfpga/master
v2: - Removes the need for a separate /mach-socfpga/arria10 directory - Tries to re-use alot of the Arria5/Cyclone5 code - Removes the usage of unions bitfields in the SDRAM defines
v1: The series builds for the Altera Arria10 SoCDK, but is not entirely functional on the hardware yet. This series really just add the defines, build and Kconfig layout for Arria10.
There are few TODO after this series: - Add DTS file for the devkit - Add clock manager - The Arria10 Pin Mux requires the FPGA to get programmed before the SDRAM controller can be usable. So another patch is needed to make use of the fpga manager to program the FPGA within the limited size of the OCRAM.
Thanks,
Dinh Nguyen (9): arm: socfpga: introduce TARGET_SOCFPGA_GEN5 config property arm: socfpga: arria10: add system manager defines arm: socfpga: arria10: add reset manager for Arria10 arm: socfpga: arria10: add misc functions for Arria10 arm: socfpga: arria10: add socfpga_arria10_socdk config arm: socfpga: arria10: add socfpga_arria10_defconfig arm: socfpga: arria10: add config option build for arria10 arm: socfpga: remove building scan manager arm: socfpga: fix up a questionable macro for SDMMC
arch/arm/Kconfig | 4 +- arch/arm/mach-socfpga/Kconfig | 15 +++ arch/arm/mach-socfpga/Makefile | 5 +- arch/arm/mach-socfpga/include/mach/reset_manager.h | 71 ++++++++++- .../arm/mach-socfpga/include/mach/system_manager.h | 132 ++++++++++++++++++++- arch/arm/mach-socfpga/misc.c | 51 ++++++++ arch/arm/mach-socfpga/reset_manager.c | 36 ++++-- configs/socfpga_arria10_defconfig | 16 +++ drivers/mmc/socfpga_dw_mmc.c | 5 +- include/configs/socfpga_arria10_socdk.h | 94 +++++++++++++++ 10 files changed, 410 insertions(+), 19 deletions(-) create mode 100644 configs/socfpga_arria10_defconfig create mode 100644 include/configs/socfpga_arria10_socdk.h
In order to re-use as much Cyclone5 and Arria5 code as possible to support the Arria10 platform, we need to wrap some of the code with #ifdef's. By adding CONFIG_TARGET_SOCFPGA_GEN5, we can shorten the check by not having to check for both AV || AV.
Signed-off-by: Dinh Nguyen dinguyen@opensource.altera.com --- v2: s/CONFIG_SOCFPGA_GEN5/CONFIG_TARGET_SOCFPGA_GEN5 --- arch/arm/mach-socfpga/Kconfig | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/arch/arm/mach-socfpga/Kconfig b/arch/arm/mach-socfpga/Kconfig index 0cb9f9e..dea4ce5 100644 --- a/arch/arm/mach-socfpga/Kconfig +++ b/arch/arm/mach-socfpga/Kconfig @@ -2,9 +2,14 @@ if ARCH_SOCFPGA
config TARGET_SOCFPGA_ARRIA5 bool + select TARGET_SOCFPGA_GEN5
config TARGET_SOCFPGA_CYCLONE5 bool + select TARGET_SOCFPGA_GEN5 + +config TARGET_SOCFPGA_GEN5 + bool
choice prompt "Altera SOCFPGA board select"
On Wednesday, December 02, 2015 at 08:31:25 PM, dinguyen@opensource.altera.com wrote:
Applied, thanks.
Best regards, Marek Vasut
Add system manager defines for Arria10.
Signed-off-by: Dinh Nguyen dinguyen@opensource.altera.com --- v4: none v3: combine system_manager_a10.h into system_manager.h v2: clean up parenthesis --- .../arm/mach-socfpga/include/mach/system_manager.h | 122 +++++++++++++++++++++ 1 file changed, 122 insertions(+)
diff --git a/arch/arm/mach-socfpga/include/mach/system_manager.h b/arch/arm/mach-socfpga/include/mach/system_manager.h index 8712f8e..f8d9e98 100644 --- a/arch/arm/mach-socfpga/include/mach/system_manager.h +++ b/arch/arm/mach-socfpga/include/mach/system_manager.h @@ -15,6 +15,7 @@ void sysmgr_config_warmrstcfgio(int enable); void sysmgr_get_pinmux_table(const u8 **table, unsigned int *table_len); #endif
+#if defined(CONFIG_TARGET_SOCFPGA_GEN5) struct socfpga_system_manager { /* System Manager Module */ u32 siliconid1; /* 0x00 */ @@ -115,6 +116,77 @@ struct socfpga_system_manager { u32 _pad_0x734; u32 spim0usefpga; /* 0x738 */ }; +#else /* Arria10 System Manager */ +struct socfpga_system_manager { + u32 siliconid1; + u32 siliconid2; + u32 wddbg; + u32 bootinfo; + u32 mpu_ctrl_l2_ecc; + u32 _pad_0x14_0x1f[3]; + u32 dma; + u32 dma_periph; + u32 sdmmcgrp_ctrl; + u32 sdmmc_l3master; + u32 nand_bootstrap; + u32 nand_l3master; + u32 usb0_l3master; + u32 usb1_l3master; + u32 emac_global; + u32 emac0; + u32 emac1; + u32 emac2; + u32 _pad_0x50_0x5f[4]; + u32 fpgaintf_en_global; + u32 fpgaintf_en_0; + u32 fpgaintf_en_1; + u32 fpgaintf_en_2; + u32 fpgaintf_en_3; + u32 _pad_0x74_0x7f[3]; + u32 noc_addr_remap_value; + u32 noc_addr_remap_set; + u32 noc_addr_remap_clear; + u32 _pad_0x8c_0x8f; + u32 ecc_intmask_value; + u32 ecc_intmask_set; + u32 ecc_intmask_clr; + u32 ecc_intstatus_serr; + u32 ecc_intstatus_derr; + u32 mpu_status_l2_ecc; + u32 mpu_clear_l2_ecc; + u32 mpu_status_l1_parity; + u32 mpu_clear_l1_parity; + u32 mpu_set_l1_parity; + u32 _pad_0xb8_0xbf[2]; + u32 noc_timeout; + u32 noc_idlereq_set; + u32 noc_idlereq_clr; + u32 noc_idlereq_value; + u32 noc_idleack; + u32 noc_idlestatus; + u32 fpga2soc_ctrl; + u32 _pad_0xdc_0xff[9]; + u32 tsmc_tsel_0; + u32 tsmc_tsel_1; + u32 tsmc_tsel_2; + u32 tsmc_tsel_3; + u32 _pad_0x110_0x200[60]; + u32 romhw_ctrl; + u32 romcode_ctrl; + u32 romcode_cpu1startaddr; + u32 romcode_initswstate; + u32 romcode_initswlastld; + u32 _pad_0x214_0x217; + u32 warmram_enable; + u32 warmram_datastart; + u32 warmram_length; + u32 warmram_execution; + u32 warmram_crc; + u32 _pad_0x22c_0x22f; + u32 isw_handoff[8]; + u32 romcode_bootromswstate[8]; +}; +#endif
#define SYSMGR_ROMCODEGRP_CTRL_WARMRSTCFGPINMUX (1 << 0) #define SYSMGR_ROMCODEGRP_CTRL_WARMRSTCFGIO (1 << 1) @@ -142,4 +214,54 @@ struct socfpga_system_manager { #define SYSMGR_EMACGRP_CTRL_PHYSEL1_LSB 2 #define SYSMGR_EMACGRP_CTRL_PHYSEL_MASK 0x3
+/* For dedicated IO configuration */ +/* Voltage select enums */ +#define VOLTAGE_SEL_3V 0x0 +#define VOLTAGE_SEL_1P8V 0x1 +#define VOLTAGE_SEL_2P5V 0x2 + +/* Input buffer enable */ +#define INPUT_BUF_DISABLE 0 +#define INPUT_BUF_1P8V 1 +#define INPUT_BUF_2P5V3V 2 + +/* Weak pull up enable */ +#define WK_PU_DISABLE 0 +#define WK_PU_ENABLE 1 + +/* Pull up slew rate control */ +#define PU_SLW_RT_SLOW 0 +#define PU_SLW_RT_FAST 1 +#define PU_SLW_RT_DEFAULT PU_SLW_RT_SLOW + +/* Pull down slew rate control */ +#define PD_SLW_RT_SLOW 0 +#define PD_SLW_RT_FAST 1 +#define PD_SLW_RT_DEFAULT PD_SLW_RT_SLOW + +/* Drive strength control */ +#define PU_DRV_STRG_DEFAULT 0x10 +#define PD_DRV_STRG_DEFAULT 0x10 + +/* bit position */ +#define PD_DRV_STRG_LSB 0 +#define PD_SLW_RT_LSB 5 +#define PU_DRV_STRG_LSB 8 +#define PU_SLW_RT_LSB 13 +#define WK_PU_LSB 16 +#define INPUT_BUF_LSB 17 +#define BIAS_TRIM_LSB 19 +#define VOLTAGE_SEL_LSB 0 + +#define ALT_SYSMGR_NOC_H2F_SET_MSK 0x00000001 +#define ALT_SYSMGR_NOC_LWH2F_SET_MSK 0x00000010 +#define ALT_SYSMGR_NOC_F2H_SET_MSK 0x00000100 +#define ALT_SYSMGR_NOC_F2SDR0_SET_MSK 0x00010000 +#define ALT_SYSMGR_NOC_F2SDR1_SET_MSK 0x00100000 +#define ALT_SYSMGR_NOC_F2SDR2_SET_MSK 0x01000000 +#define ALT_SYSMGR_NOC_TMO_EN_SET_MSK 0x00000001 + +#define ALT_SYSMGR_ECC_INTSTAT_SERR_OCRAM_SET_MSK 0x00000002 +#define ALT_SYSMGR_ECC_INTSTAT_DERR_OCRAM_SET_MSK 0x00000002 + #endif /* _SYSTEM_MANAGER_H_ */
On Wednesday, December 02, 2015 at 08:31:26 PM, dinguyen@opensource.altera.com wrote:
V4 has no changes other than this change, right ? ;-)
Applied, thanks.
Yes, this is the only change in V4 from V3.
Dinh
So it should've been listed in the changelog ;-)
Add the defines for the reset manager and some basic reset functionality.
Signed-off-by: Dinh Nguyen dinguyen@opensource.altera.com --- v4: rename mod_reset names to be used by both gen5 and a10 v3: remove duplicate reset function use CONFIG_SOCFPGA_GEN5 v2: integrate into a5/c5 reset manager --- arch/arm/mach-socfpga/include/mach/reset_manager.h | 71 +++++++++++++++++++++- arch/arm/mach-socfpga/reset_manager.c | 36 ++++++++--- 2 files changed, 97 insertions(+), 10 deletions(-)
diff --git a/arch/arm/mach-socfpga/include/mach/reset_manager.h b/arch/arm/mach-socfpga/include/mach/reset_manager.h index e50fbd8..b34c7c6 100644 --- a/arch/arm/mach-socfpga/include/mach/reset_manager.h +++ b/arch/arm/mach-socfpga/include/mach/reset_manager.h @@ -15,19 +15,56 @@ void socfpga_bridges_reset(int enable); void socfpga_per_reset(u32 reset, int set); void socfpga_per_reset_all(void);
+#if defined(CONFIG_TARGET_SOCFPGA_GEN5) struct socfpga_reset_manager { u32 status; u32 ctrl; u32 counts; u32 padding1; u32 mpu_mod_reset; - u32 per_mod_reset; - u32 per2_mod_reset; + u32 per0_mod_reset; /* per_mod_reset */ + u32 per1_mod_reset; /* per2_mod_reset */ u32 brg_mod_reset; - u32 misc_mod_reset; + u32 sys_mod_reset; /* misc_mod_reset */ u32 padding2[12]; u32 tstscratch; }; +#else +struct socfpga_reset_manager { + u32 stat; + u32 ramstat; + u32 miscstat; + u32 ctrl; + u32 hdsken; + u32 hdskreq; + u32 hdskack; + u32 counts; + u32 mpu_mod_reset; + u32 per0_mod_reset; + u32 per1_mod_reset; + u32 brg_mod_reset; + u32 sys_mod_reset; + u32 coldmodrst; + u32 nrstmodrst; + u32 dbgmodrst; + u32 mpuwarmmask; + u32 per0warmmask; + u32 per1warmmask; + u32 brgwarmmask; + u32 syswarmmask; + u32 nrstwarmmask; + u32 l3warmmask; + u32 tststa; + u32 tstscratch; + u32 hdsktimeout; + u32 hmcintr; + u32 hmcintren; + u32 hmcintrens; + u32 hmcintrenr; + u32 hmcgpout; + u32 hmcgpin; +}; +#endif
#if defined(CONFIG_SOCFPGA_VIRTUAL_TARGET) #define RSTMGR_CTRL_SWWARMRSTREQ_LSB 2 @@ -55,6 +92,7 @@ struct socfpga_reset_manager { #define RSTMGR_BANK(_reset) \ (((_reset) >> RSTMGR_BANK_OFFSET) & RSTMGR_BANK_MASK)
+#if defined(CONFIG_TARGET_SOCFPGA_GEN5) /* * SocFPGA Cyclone V/Arria V reset IDs, bank mapping is as follows: * 0 ... mpumodrst @@ -74,6 +112,33 @@ struct socfpga_reset_manager { #define RSTMGR_SDMMC RSTMGR_DEFINE(1, 22) #define RSTMGR_DMA RSTMGR_DEFINE(1, 28) #define RSTMGR_SDR RSTMGR_DEFINE(1, 29) +#else +/* + * SocFPGA Arria10 reset IDs, bank mapping is as follows: + * 0 ... mpumodrst + * 1 ... per0modrst + * 2 ... per1modrst + * 3 ... brgmodrst + * 4 ... sysmodrst + */ +#define RSTMGR_EMAC0 RSTMGR_DEFINE(1, 0) +#define RSTMGR_EMAC1 RSTMGR_DEFINE(1, 1) +#define RSTMGR_EMAC2 RSTMGR_DEFINE(1, 2) +#define RSTMGR_L4WD0 RSTMGR_DEFINE(2, 0) +#define RSTMGR_L4WD1 RSTMGR_DEFINE(2, 1) +#define RSTMGR_L4SYSTIMER0 RSTMGR_DEFINE(2, 2) +#define RSTMGR_L4SYSTIMER1 RSTMGR_DEFINE(2, 3) +#define RSTMGR_SPTIMER0 RSTMGR_DEFINE(2, 4) +#define RSTMGR_SPTIMER1 RSTMGR_DEFINE(2, 5) +#define RSTMGR_UART0 RSTMGR_DEFINE(2, 16) +#define RSTMGR_UART1 RSTMGR_DEFINE(2, 17) +#define RSTMGR_SPIM0 RSTMGR_DEFINE(1, 17) +#define RSTMGR_SPIM1 RSTMGR_DEFINE(1, 18) +#define RSTMGR_QSPI RSTMGR_DEFINE(1, 6) +#define RSTMGR_SDMMC RSTMGR_DEFINE(1, 7) +#define RSTMGR_DMA RSTMGR_DEFINE(1, 16) +#define RSTMGR_DDRSCH RSTMGR_DEFINE(3, 6) +#endif
/* Create a human-readable reference to SoCFPGA reset. */ #define SOCFPGA_RESET(_name) RSTMGR_##_name diff --git a/arch/arm/mach-socfpga/reset_manager.c b/arch/arm/mach-socfpga/reset_manager.c index b6beaa2..1154f60 100644 --- a/arch/arm/mach-socfpga/reset_manager.c +++ b/arch/arm/mach-socfpga/reset_manager.c @@ -18,7 +18,9 @@ static const struct socfpga_reset_manager *reset_manager_base = static struct socfpga_system_manager *sysmgr_regs = (struct socfpga_system_manager *)SOCFPGA_SYSMGR_ADDRESS;
-/* Assert or de-assert SoCFPGA reset manager reset. */ +/* + * Assert or de-assert SoCFPGA reset manager reset. + */ void socfpga_per_reset(u32 reset, int set) { const void *reg; @@ -26,13 +28,13 @@ void socfpga_per_reset(u32 reset, int set) if (RSTMGR_BANK(reset) == 0) reg = &reset_manager_base->mpu_mod_reset; else if (RSTMGR_BANK(reset) == 1) - reg = &reset_manager_base->per_mod_reset; + reg = &reset_manager_base->per0_mod_reset; else if (RSTMGR_BANK(reset) == 2) - reg = &reset_manager_base->per2_mod_reset; + reg = &reset_manager_base->per1_mod_reset; else if (RSTMGR_BANK(reset) == 3) reg = &reset_manager_base->brg_mod_reset; else if (RSTMGR_BANK(reset) == 4) - reg = &reset_manager_base->misc_mod_reset; + reg = &reset_manager_base->sys_mod_reset; else /* Invalid reset register, do nothing */ return;
@@ -46,13 +48,29 @@ void socfpga_per_reset(u32 reset, int set) * Assert reset on every peripheral but L4WD0. * Watchdog must be kept intact to prevent glitches * and/or hangs. + * For the Arria10, we disable all the peripherals except L4 watchdog0, + * L4 Timer 0, and ECC. */ void socfpga_per_reset_all(void) { +#if defined(CONFIG_TARGET_SOCFPGA_GEN5) const u32 l4wd0 = 1 << RSTMGR_RESET(SOCFPGA_RESET(L4WD0));
- writel(~l4wd0, &reset_manager_base->per_mod_reset); - writel(0xffffffff, &reset_manager_base->per2_mod_reset); + writel(~l4wd0, &reset_manager_base->per0_mod_reset); + writel(0xffffffff, &reset_manager_base->per1_mod_reset); +#else + const u32 l4wd0 = (1 << RSTMGR_RESET(SOCFPGA_RESET(L4WD0)) | + (1 << RSTMGR_RESET(SOCFPGA_RESET(L4SYSTIMER0)))); + + unsigned mask_ecc_ocp = 0x0000FF00; + + /* disable all components except ECC_OCP, L4 Timer0 and L4 WD0 */ + writel(~l4wd0, &reset_manager_base->per1_mod_reset); + setbits_le32(&reset_manager_base->per0_mod_reset, ~mask_ecc_ocp); + + /* Finally disable the ECC_OCP */ + setbits_le32(&reset_manager_base->per0_mod_reset, mask_ecc_ocp); +#endif }
/* @@ -71,13 +89,15 @@ void reset_cpu(ulong addr) ; }
+#if defined(CONFIG_TARGET_SOCFPGA_GEN5) /* * Release peripherals from reset based on handoff */ void reset_deassert_peripherals_handoff(void) { - writel(0, &reset_manager_base->per_mod_reset); + writel(0, &reset_manager_base->per0_mod_reset); } +#endif
#if defined(CONFIG_SOCFPGA_VIRTUAL_TARGET) void socfpga_bridges_reset(int enable) @@ -92,6 +112,7 @@ void socfpga_bridges_reset(int enable)
void socfpga_bridges_reset(int enable) { +#if defined(CONFIG_TARGET_SOCFPGA_GEN5) const uint32_t l3mask = L3REGS_REMAP_LWHPS2FPGA_MASK | L3REGS_REMAP_HPS2FPGA_MASK | L3REGS_REMAP_OCRAM_MASK; @@ -116,5 +137,6 @@ void socfpga_bridges_reset(int enable) /* Remap the bridges into memory map */ writel(l3mask, SOCFPGA_L3REGS_ADDRESS); } +#endif } #endif
On Wednesday, December 02, 2015 at 08:31:27 PM, dinguyen@opensource.altera.com wrote:
- u32 per0_mod_reset; /* per_mod_reset */
- u32 per1_mod_reset; /* per2_mod_reset */ u32 brg_mod_reset;
- u32 sys_mod_reset; /* misc_mod_reset */
OK, so why do you rename it for gen5 and not gen10 ?
else if (RSTMGR_BANK(reset) == 2)reg = &reset_manager_base->per0_mod_reset;
else if (RSTMGR_BANK(reset) == 3) reg = &reset_manager_base->brg_mod_reset; else if (RSTMGR_BANK(reset) == 4)reg = &reset_manager_base->per1_mod_reset;
This change would not be necessary than.
- Assert reset on every peripheral but L4WD0.
- Watchdog must be kept intact to prevent glitches
- and/or hangs.
- For the Arria10, we disable all the peripherals except L4 watchdog0,
- L4 Timer 0, and ECC.
- writel(~l4wd0, &reset_manager_base->per0_mod_reset);
- writel(0xffffffff, &reset_manager_base->per1_mod_reset);
+#else
- const u32 l4wd0 = (1 << RSTMGR_RESET(SOCFPGA_RESET(L4WD0)) |
- unsigned mask_ecc_ocp = 0x0000FF00;
- /* disable all components except ECC_OCP, L4 Timer0 and L4 WD0 */
- writel(~l4wd0, &reset_manager_base->per1_mod_reset);
- setbits_le32(&reset_manager_base->per0_mod_reset, ~mask_ecc_ocp);
- /* Finally disable the ECC_OCP */
- setbits_le32(&reset_manager_base->per0_mod_reset, mask_ecc_ocp);
+#endif }
- Release peripherals from reset based on handoff
- writel(0, &reset_manager_base->per0_mod_reset);
And this change.
} +#endif
It looks OK otherwise of course.
Umm. Those comments are really hard to understand. Add "in the datasheet" at the end so that poor reader has chance to see what is going on?
Thanks, Pavel
Add arch_early_init_r function. The Arria10 has a firewall protection around the SDRAM and OCRAM. These firewalls are to be disabled in order for U-Boot to function.
Signed-off-by: Dinh Nguyen dinguyen@opensource.altera.com --- v4: be consistent and use #if->else throughout v3: s/reset_assert_all_peripherals_except_l4wd0_l4timer0/socfpga_per_reset_all use CONFIG_SOCFPGA_GEN5 v2: reuse misc functions from a5/c5 --- arch/arm/mach-socfpga/misc.c | 51 ++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 51 insertions(+)
diff --git a/arch/arm/mach-socfpga/misc.c b/arch/arm/mach-socfpga/misc.c index b110f5b..78774d5 100644 --- a/arch/arm/mach-socfpga/misc.c +++ b/arch/arm/mach-socfpga/misc.c @@ -15,6 +15,7 @@ #include <watchdog.h> #include <asm/arch/reset_manager.h> #include <asm/arch/scan_manager.h> +#include <asm/arch/sdram_a10.h> #include <asm/arch/system_manager.h> #include <asm/arch/dwmmc.h> #include <asm/arch/nic301.h> @@ -31,8 +32,15 @@ static struct socfpga_system_manager *sysmgr_regs = (struct socfpga_system_manager *)SOCFPGA_SYSMGR_ADDRESS; static struct socfpga_reset_manager *reset_manager_base = (struct socfpga_reset_manager *)SOCFPGA_RSTMGR_ADDRESS; +#if defined(CONFIG_TARGET_SOCFPGA_GEN5) static struct nic301_registers *nic301_regs = (struct nic301_registers *)SOCFPGA_L3REGS_ADDRESS; +#else +static const struct socfpga_noc_fw_ocram *noc_fw_ocram_base = + (void *)SOCFPGA_SDR_FIREWALL_OCRAM_ADDRESS; +static const struct socfpga_noc_fw_ddr_l3 *noc_fw_ddr_l3_base = + (void *)SOCFPGA_SDR_FIREWALL_L3_ADDRESS; +#endif static struct scu_registers *scu_regs = (struct scu_registers *)SOCFPGA_MPUSCU_ADDRESS;
@@ -207,9 +215,14 @@ static int socfpga_fpga_id(const bool print_id) #if defined(CONFIG_DISPLAY_CPUINFO) int print_cpuinfo(void) { +#if defined(CONFIG_TARGET_SOCFPGA_GEN5) const u32 bsel = readl(&sysmgr_regs->bootinfo) & 0x7; puts("CPU: Altera SoCFPGA Platform\n"); socfpga_fpga_id(1); +#else + const u32 bsel = (readl(&sysmgr_regs->bootinfo) >> 12) & 0x7; + puts("CPU: Altera SoCFPGA Arria 10\n"); +#endif printf("BOOT: %s\n", bsel_str[bsel].name); return 0; } @@ -292,6 +305,7 @@ int arch_cpu_init(void) return 0; }
+#if defined(CONFIG_TARGET_SOCFPGA_GEN5) /* * Convert all NIC-301 AMBA slaves from secure to non-secure */ @@ -411,6 +425,43 @@ int do_bridge(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
return 0; } +#else +/* ++ * This function initializes security policies to be consistent across ++ * all logic units in the Arria 10. ++ * ++ * The idea is to set all security policies to be normal, nonsecure ++ * for all units. ++ */ +static void initialize_security_policies(void) +{ + /* Put OCRAM in non-secure */ + writel(0x003f0000, &noc_fw_ocram_base->region0); + writel(0x1, &noc_fw_ocram_base->enable); + + /* Put DDR in non-secure */ + writel(0xffff0000, &noc_fw_ddr_l3_base->hpsregion0addr); + writel(0x1, &noc_fw_ddr_l3_base->enable); +} + +int arch_early_init_r(void) +{ + initialize_security_policies(); + + /* Configure the L2 controller to make SDRAM start at 0 */ + writel(0x1, &pl310->pl310_addr_filter_start); + + /* assert reset to all except L4WD0 and L4TIMER0 */ + socfpga_per_reset_all(); + + /* configuring the clock based on handoff */ + /* TODO: Add call to cm_basic_init() */ + + /* Add device descriptor to FPGA device table */ + socfpga_fpga_add(); + return 0; +} +#endif
U_BOOT_CMD( bridge, 2, 1, do_bridge,
On Wednesday, December 02, 2015 at 08:31:28 PM, dinguyen@opensource.altera.com wrote:
- (void *)SOCFPGA_SDR_FIREWALL_OCRAM_ADDRESS;
- (void *)SOCFPGA_SDR_FIREWALL_L3_ADDRESS;
- const u32 bsel = (readl(&sysmgr_regs->bootinfo) >> 12) & 0x7;
Is the bsel meaning the same for both Gen5 and Gen10 ? If so, that's fine. You can improve this code here by defining some bootinfo offset, 0 for gen5 and 12 for gen10 and then you'd only need to ifdef the puts() and the invocation of socfpga_fpga_id();
Can you send a subsequent patch for this ?
- puts("CPU: Altera SoCFPGA Arria 10\n");
Anyway, let me just apply this.
Yes, the bsel meaning is the same for Gen5 and Gen10. I'll send a follow up patch with Pavel's comment taken into consideration.
Dinh
Add config for the Arria10 SoC Development Kit.
Signed-off-by: Dinh Nguyen dinguyen@opensource.altera.com Acked-by: Marek Vasut marex@denx.de --- v4: none v3: further clean up, remove extra defines, keep bare mininum options v2: clean up socfpga_arria10_socdk.h to use socfpga_common.h --- include/configs/socfpga_arria10_socdk.h | 94 +++++++++++++++++++++++++++++++++ 1 file changed, 94 insertions(+) create mode 100644 include/configs/socfpga_arria10_socdk.h
diff --git a/include/configs/socfpga_arria10_socdk.h b/include/configs/socfpga_arria10_socdk.h new file mode 100644 index 0000000..577f60f --- /dev/null +++ b/include/configs/socfpga_arria10_socdk.h @@ -0,0 +1,94 @@ +/* + * Copyright (C) 2015 Altera Corporation <www.altera.com> + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#ifndef __CONFIG_SOCFGPA_ARRIA10_H__ +#define __CONFIG_SOCFGPA_ARRIA10_H__ + +#include <asm/arch/base_addr_a10.h> +/* U-Boot Commands */ +#define CONFIG_SYS_NO_FLASH +#define CONFIG_DOS_PARTITION +#define CONFIG_FAT_WRITE +#define CONFIG_HW_WATCHDOG + +#define CONFIG_CMD_ASKENV +#define CONFIG_CMD_BOOTZ +#define CONFIG_CMD_CACHE +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_EXT4 +#define CONFIG_CMD_EXT4_WRITE +#define CONFIG_CMD_FAT +#define CONFIG_CMD_FS_GENERIC +#define CONFIG_CMD_GREPENV +#define CONFIG_CMD_MMC +#define CONFIG_CMD_PING + +/* + * Memory configurations + */ +#define PHYS_SDRAM_1_SIZE 0x2000000 + +/* Booting Linux */ +#define CONFIG_BOOTDELAY 3 +#define CONFIG_BOOTFILE "zImage" +#define CONFIG_BOOTARGS "console=ttyS0," __stringify(CONFIG_BAUDRATE) +#define CONFIG_BOOTCOMMAND "run mmcload; run mmcboot" +#define CONFIG_LOADADDR 0x01000000 +#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR + +/* + * Display CPU and Board Info + */ +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DISPLAY_BOARDINFO +#define CONFIG_DISPLAY_BOARDINFO_LATE + +/* Ethernet on SoC (EMAC) */ +#if defined(CONFIG_CMD_NET) + +/* PHY */ +#define CONFIG_PHY_MICREL +#define CONFIG_PHY_MICREL_KSZ9031 + +#endif + +#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_SYS_MMC_ENV_DEV 0/* device 0 */ +#define CONFIG_ENV_OFFSET 512/* just after the MBR */ + +/* + * arguments passed to the bootz command. The value of + * CONFIG_BOOTARGS goes into the environment value "bootargs". + * Do note the value will overide also the chosen node in FDT blob. + */ +#define CONFIG_BOOTARGS "console=ttyS0," __stringify(CONFIG_BAUDRATE) + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "verify=n\0" \ + "loadaddr= " __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \ + "ramboot=setenv bootargs " CONFIG_BOOTARGS ";" \ + "bootm ${loadaddr} - ${fdt_addr}\0" \ + "bootimage=zImage\0" \ + "fdt_addr=100\0" \ + "fdtimage=socfpga.dtb\0" \ + "fsloadcmd=ext2load\0" \ + "bootm ${loadaddr} - ${fdt_addr}\0" \ + "mmcroot=/dev/mmcblk0p2\0" \ + "mmcboot=setenv bootargs " CONFIG_BOOTARGS \ + " root=${mmcroot} rw rootwait;" \ + "bootz ${loadaddr} - ${fdt_addr}\0" \ + "mmcload=mmc rescan;" \ + "load mmc 0:1 ${loadaddr} ${bootimage};" \ + "load mmc 0:1 ${fdt_addr} ${fdtimage}\0" \ + "qspiroot=/dev/mtdblock0\0" \ + "qspirootfstype=jffs2\0" \ + "qspiboot=setenv bootargs " CONFIG_BOOTARGS \ + " root=${qspiroot} rw rootfstype=${qspirootfstype};"\ + "bootm ${loadaddr} - ${fdt_addr}\0" + +/* The rest of the configuration is shared */ +#include <configs/socfpga_common.h> +#endif /* __CONFIG_H */
On Wednesday, December 02, 2015 at 08:31:29 PM, dinguyen@opensource.altera.com wrote:
Applied, thanks.
Add a defconfig file for Arria10, which does not include enabling SPL.
Signed-off-by: Dinh Nguyen dinguyen@opensource.altera.com Acked-by: Marek Vasut marex@denx.de --- v4: none v3: align with u-boot-socfpga/master v2: none --- configs/socfpga_arria10_defconfig | 16 ++++++++++++++++ 1 file changed, 16 insertions(+) create mode 100644 configs/socfpga_arria10_defconfig
diff --git a/configs/socfpga_arria10_defconfig b/configs/socfpga_arria10_defconfig new file mode 100644 index 0000000..422261b --- /dev/null +++ b/configs/socfpga_arria10_defconfig @@ -0,0 +1,16 @@ +CONFIG_ARM=y +CONFIG_ARCH_SOCFPGA=y +CONFIG_TARGET_SOCFPGA_ARRIA10=y +CONFIG_DM_GPIO=y +CONFIG_TARGET_SOCFPGA_ARRIA10_SOCDK=y +CONFIG_DEFAULT_DEVICE_TREE="socfpga_arria10_socdk" +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_GPIO=y +CONFIG_DWAPB_GPIO=y +CONFIG_DM_ETH=y +CONFIG_ETH_DESIGNWARE=y +CONFIG_SYS_NS16550=y +CONFIG_CADENCE_QSPI=y +CONFIG_DESIGNWARE_SPI=y +CONFIG_DM_MMC=y
On Wednesday, December 02, 2015 at 08:31:30 PM, dinguyen@opensource.altera.com wrote:
Applied, thanks.
Signed-off-by: Dinh Nguyen dinguyen@opensource.altera.com --- v4: reorder ARRIA10 below ARRIA5 v3: none v2: none --- arch/arm/Kconfig | 4 ++-- arch/arm/mach-socfpga/Kconfig | 10 ++++++++++ 2 files changed, 12 insertions(+), 2 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 408e4ff..c43c8b4 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -500,9 +500,9 @@ config RMOBILE config ARCH_SOCFPGA bool "Altera SOCFPGA family" select CPU_V7 - select SUPPORT_SPL + select SUPPORT_SPL if !TARGET_SOCFPGA_ARRIA10 select OF_CONTROL - select SPL_OF_CONTROL + select SPL_OF_CONTROL if !TARGET_SOCFPGA_ARRIA10 select DM select DM_SPI_FLASH select DM_SPI diff --git a/arch/arm/mach-socfpga/Kconfig b/arch/arm/mach-socfpga/Kconfig index dea4ce5..f0b1be0 100644 --- a/arch/arm/mach-socfpga/Kconfig +++ b/arch/arm/mach-socfpga/Kconfig @@ -4,6 +4,9 @@ config TARGET_SOCFPGA_ARRIA5 bool select TARGET_SOCFPGA_GEN5
+config TARGET_SOCFPGA_ARRIA10 + bool + config TARGET_SOCFPGA_CYCLONE5 bool select TARGET_SOCFPGA_GEN5 @@ -23,6 +26,10 @@ config TARGET_SOCFPGA_CYCLONE5_SOCDK bool "Altera SOCFPGA SoCDK (Cyclone V)" select TARGET_SOCFPGA_CYCLONE5
+config TARGET_SOCFPGA_ARRIA10_SOCDK + bool "Altera SOCFPGA SoCDK (Arria 10)" + select TARGET_SOCFPGA_ARRIA10 + config TARGET_SOCFPGA_DENX_MCVEVK bool "DENX MCVEVK (Cyclone V)" select TARGET_SOCFPGA_CYCLONE5 @@ -47,6 +54,7 @@ endchoice
config SYS_BOARD default "arria5-socdk" if TARGET_SOCFPGA_ARRIA5_SOCDK + default "arria10-socdk" if TARGET_SOCFPGA_ARRIA10_SOCDK default "cyclone5-socdk" if TARGET_SOCFPGA_CYCLONE5_SOCDK default "de0-nano-soc" if TARGET_SOCFPGA_TERASIC_DE0_NANO default "mcvevk" if TARGET_SOCFPGA_DENX_MCVEVK @@ -56,6 +64,7 @@ config SYS_BOARD
config SYS_VENDOR default "altera" if TARGET_SOCFPGA_ARRIA5_SOCDK + default "altera" if TARGET_SOCFPGA_ARRIA10_SOCDK default "altera" if TARGET_SOCFPGA_CYCLONE5_SOCDK default "denx" if TARGET_SOCFPGA_DENX_MCVEVK default "ebv" if TARGET_SOCFPGA_EBV_SOCRATES @@ -67,6 +76,7 @@ config SYS_SOC
config SYS_CONFIG_NAME default "socfpga_arria5_socdk" if TARGET_SOCFPGA_ARRIA5_SOCDK + default "socfpga_arria10_socdk" if TARGET_SOCFPGA_ARRIA10_SOCDK default "socfpga_cyclone5_socdk" if TARGET_SOCFPGA_CYCLONE5_SOCDK default "socfpga_de0_nano_soc" if TARGET_SOCFPGA_TERASIC_DE0_NANO default "socfpga_mcvevk" if TARGET_SOCFPGA_DENX_MCVEVK
The scan manager is not needed for the Arria10. Edit the makefile to build the scan manager for arria5 and cyclone5 only.
Signed-off-by: Dinh Nguyen dinguyen@opensource.altera.com Acked-by: Marek Vasut marex@denx.de --- v4: use CONFIG_TARGET_SOCFPGA_GEN5 option for build v3: use CONFIG_SOCFPGA_GEN5 option for build --- arch/arm/mach-socfpga/Makefile | 5 +++-- 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/arch/arm/mach-socfpga/Makefile b/arch/arm/mach-socfpga/Makefile index 316b326..ac57d03 100644 --- a/arch/arm/mach-socfpga/Makefile +++ b/arch/arm/mach-socfpga/Makefile @@ -8,11 +8,12 @@ #
obj-y += misc.o timer.o reset_manager.o system_manager.o clock_manager.o \ - fpga_manager.o scan_manager.o + fpga_manager.o + obj-$(CONFIG_SPL_BUILD) += spl.o freeze_controller.o
# QTS-generated config file wrappers -obj-y += wrap_pll_config.o +obj-$(CONFIG_TARGET_SOCFPGA_GEN5) += scan_manager.o wrap_pll_config.o obj-$(CONFIG_SPL_BUILD) += wrap_iocsr_config.o wrap_pinmux_config.o \ wrap_sdram_config.o CFLAGS_wrap_iocsr_config.o += -I$(srctree)/board/$(BOARDDIR)
On Wednesday, December 02, 2015 at 08:31:32 PM, dinguyen@opensource.altera.com wrote:
Applied, thanks.
Move the macro into the socfpga_dwmci_clksel().
Signed-off-by: Dinh Nguyen dinguyen@opensource.altera.com --- v2: add SYSMGR_SDMMC_DRVSEL_SHIFT s/SYSMGR_SDMMC_SMPSEL_SHIFT/SYSMGR_SDMMC_SMPLSEL_SHIFT --- arch/arm/mach-socfpga/include/mach/system_manager.h | 10 +++++++--- drivers/mmc/socfpga_dw_mmc.c | 5 +++-- 2 files changed, 10 insertions(+), 5 deletions(-)
diff --git a/arch/arm/mach-socfpga/include/mach/system_manager.h b/arch/arm/mach-socfpga/include/mach/system_manager.h index f8d9e98..e688c50 100644 --- a/arch/arm/mach-socfpga/include/mach/system_manager.h +++ b/arch/arm/mach-socfpga/include/mach/system_manager.h @@ -201,9 +201,13 @@ struct socfpga_system_manager { #define SYSMGR_FPGAINTF_NAND (1 << 4) #define SYSMGR_FPGAINTF_SDMMC (1 << 5)
-/* FIXME: This is questionable macro. */ -#define SYSMGR_SDMMC_CTRL_SET(smplsel, drvsel) \ - ((((drvsel) << 0) & 0x7) | (((smplsel) << 3) & 0x38)) +#if defined(CONFIG_TARGET_SOCFPGA_GEN5) +#define SYSMGR_SDMMC_SMPLSEL_SHIFT 3 +#else +#define SYSMGR_SDMMC_SMPLSEL_SHIFT 4 +#endif + +#define SYSMGR_SDMMC_DRVSEL_SHIFT 0
/* EMAC Group Bit definitions */ #define SYSMGR_EMACGRP_CTRL_PHYSEL_ENUM_GMII_MII 0x0 diff --git a/drivers/mmc/socfpga_dw_mmc.c b/drivers/mmc/socfpga_dw_mmc.c index 5b0c3a8..d7edec7 100644 --- a/drivers/mmc/socfpga_dw_mmc.c +++ b/drivers/mmc/socfpga_dw_mmc.c @@ -33,6 +33,8 @@ struct dwmci_socfpga_priv_data { static void socfpga_dwmci_clksel(struct dwmci_host *host) { struct dwmci_socfpga_priv_data *priv = host->priv; + u32 sdmmc_mask = ((((priv->smplsel) & 0x7) << SYSMGR_SDMMC_SMPLSEL_SHIFT) | + ((priv->drvsel) & 0x7) << SYSMGR_SDMMC_DRVSEL_SHIFT);
/* Disable SDMMC clock. */ clrbits_le32(&clock_manager_base->per_pll.en, @@ -40,8 +42,7 @@ static void socfpga_dwmci_clksel(struct dwmci_host *host)
debug("%s: drvsel %d smplsel %d\n", __func__, priv->drvsel, priv->smplsel); - writel(SYSMGR_SDMMC_CTRL_SET(priv->smplsel, priv->drvsel), - &system_manager_base->sdmmcgrp_ctrl); + writel(sdmmc_mask, &system_manager_base->sdmmcgrp_ctrl);
debug("%s: SYSMGR_SDMMCGRP_CTRL_REG = 0x%x\n", __func__, readl(&system_manager_base->sdmmcgrp_ctrl));
On Wednesday, December 02, 2015 at 08:31:33 PM, dinguyen@opensource.altera.com wrote:
- u32 sdmmc_mask = ((((priv->smplsel) & 0x7) <<
After correcting the parenthesis mayhem here, applied.
On Wednesday, December 02, 2015 at 08:31:24 PM, dinguyen@opensource.altera.com wrote:
I pushed all the stuff which was applicable to u-boot-socfpga/a10 . The reset manager needs some clarification and there are a few other suggestions, please address them so we can close this series.
Dinh Nguyen
Pavel Machek
