[U-Boot] [PATCH] Move the preprocessor test for building flash.c to the Makefile.
Move the preprocessor test of CONFIG_SYS_NO_FLASH out of flash.c and back to the Makefile, for readability.
Signed-off-by: Robert P. J. Day rpjday@crashcourse.ca
this one is a little uglier since it adds an "#ifndef" check to the Makefile, but i still consider this to be more readable since it's potentially misleading to have a hard-coded build of a file in the Makefile, only to have to go that file to notice that a subsequent preprocessor check takes the file out of play. except in weird circumstances, tests like that should be in the Makefile.
i don't think there's a lot of this left.
diff --git a/common/Makefile b/common/Makefile index 3781738..69629f5 100644 --- a/common/Makefile +++ b/common/Makefile @@ -152,7 +152,9 @@ COBJS-$(CONFIG_VFD) += cmd_vfd.o COBJS-$(CONFIG_DDR_SPD) += ddr_spd.o COBJS-$(CONFIG_HWCONFIG) += hwconfig.o COBJS-$(CONFIG_CONSOLE_MUX) += iomux.o +#ifndef CONFIG_SYS_NO_FLASH COBJS-y += flash.o +#endif COBJS-$(CONFIG_CMD_KGDB) += kgdb.o COBJS-$(CONFIG_KALLSYMS) += kallsyms.o COBJS-$(CONFIG_LCD) += lcd.o diff --git a/common/flash.c b/common/flash.c index eb4b2f5..f5da566 100644 --- a/common/flash.c +++ b/common/flash.c @@ -26,8 +26,6 @@ #include <common.h> #include <flash.h>
-#if !defined(CONFIG_SYS_NO_FLASH) - extern flash_info_t flash_info[]; /* info for FLASH chips */
/*----------------------------------------------------------------------- @@ -222,7 +220,3 @@ void flash_perror (int err) break; } } - -/*----------------------------------------------------------------------- - */ -#endif /* !CONFIG_SYS_NO_FLASH */
======================================================================== Robert P. J. Day Waterloo, Ontario, CANADA
Linux Consulting, Training and Kernel Pedantry.
Web page: http://crashcourse.ca Twitter: http://twitter.com/rpjday ========================================================================
me thinks you did not test this and/or you dont know how Makefile's work and/or you forgot to remove debug comments.
regardless, obvious NACK -mike
oh, crap, that's what i get for getting lazy and not paying attention. sorry.
rday --
Mike Frysinger
Robert P. J. Day
