[U-Boot] [PATCH 20/22] ARM sunxi: SPL support for Rikomagic MK802II board
From: j j@mailb.org Signed-off-by: Henrik Nordstrom henrik@henriknordstrom.net --- board/sunxi/Makefile | 1 + board/sunxi/dram_mk802ii.c | 31 +++++++++++++++++++++++++++++++ boards.cfg | 1 + 3 files changed, 33 insertions(+), 0 deletions(-) create mode 100644 board/sunxi/dram_mk802ii.c
diff --git a/board/sunxi/Makefile b/board/sunxi/Makefile index b3a40f4..95826f2 100644 --- a/board/sunxi/Makefile +++ b/board/sunxi/Makefile @@ -35,6 +35,7 @@ COBJS-$(CONFIG_MELE_A1000) += dram_mele_a1000.o COBJS-$(CONFIG_MINI_X) += dram_mini_x.o COBJS-$(CONFIG_A7HD) += dram_hyundai_a7hd.o COBJS-$(CONFIG_MK802) += dram_mk802.o +COBJS-$(CONFIG_MK802II) += dram_mk802ii.o
COBJS := $(COBJS-y) SRCS := $(COBJS:.o=.c) diff --git a/board/sunxi/dram_mk802ii.c b/board/sunxi/dram_mk802ii.c new file mode 100644 index 0000000..4fc1398 --- /dev/null +++ b/board/sunxi/dram_mk802ii.c @@ -0,0 +1,31 @@ +/* this file is generated, don't edit it yourself */ + +#include <common.h> +#include <asm/arch/dram.h> + +static struct dram_para dram_para = { + .clock = 408, + .type = 3, + .rank_num = 1, + .density = 4096, + .io_width = 16, + .bus_width = 32, + .cas = 6, + .zq = 123, + .odt_en = 0, + .size = 1024, + .tpr0 = 0x30926692, + .tpr1 = 0x1090, + .tpr2 = 0x1a0c8, + .tpr3 = 0, + .tpr4 = 0, + .tpr5 = 0, + .emr1 = 0x4, + .emr2 = 0, + .emr3 = 0, +}; + +int sunxi_dram_init(void) +{ + return dramc_init(&dram_para); +} diff --git a/boards.cfg b/boards.cfg index 12fbcc9..14d6c67 100644 --- a/boards.cfg +++ b/boards.cfg @@ -301,6 +301,7 @@ sun4i_sdcon arm armv7 sunxi - sun5i arm armv7 sunxi - sunxi sun5i sun5i_sdcon arm armv7 sunxi - sunxi sun5i:UART0_PORT_F mk802 arm armv7 sunxi - sunxi sun4i:MK802,SPL +mk802ii arm armv7 sunxi - sunxi sun4i:MK802II,SPL kzm9g arm armv7 kzm9g kmc rmobile armadillo-800eva arm armv7 armadillo-800eva atmark-techno rmobile zynq arm armv7 zynq xilinx zynq
Henrik Nordström
