[PATCH v3 0/2] gpio: add possibility to search for gpio label name
search for gpio label if gpio name from bankname is not found.
This makes sense on boards with different hardware verions. You can now search for the gpio label name, and can give the gpio a unique name. The real gpio pin number is not needed in board code anymore.
while at it add basic gpio hog test functions in seperate patch.
Travis build: https://travis-ci.org/hsdenx/u-boot-test/builds/645826819
Changes in v3: - add comment from Simon Glass make this new function configurable through Kconfig option DM_GPIO_LOOKUP_LABEL
Changes in v2: - add basic gpio hog test functions - add comment from Simon Glass move code into seperate function dm_gpio_lookup_label() add test if dm_gpio_lookup_label() works
Heiko Schocher (2): sandbox, test: add test for GPIO_HOG function gpio: search for gpio label if gpio is not found through bank name
arch/sandbox/dts/test.dts | 24 +++++++++++++++ configs/sandbox64_defconfig | 1 + configs/sandbox_defconfig | 1 + configs/sandbox_flattree_defconfig | 1 + configs/sandbox_spl_defconfig | 1 + drivers/gpio/Kconfig | 22 ++++++++++++++ drivers/gpio/gpio-uclass.c | 47 ++++++++++++++++++++++++++++++ test/dm/gpio.c | 30 +++++++++++++++++++ 8 files changed, 127 insertions(+)
currently gpio hog function is not tested with "ut dm gpio" so add some basic tests for gpio hog functionality.
For this enable GPIO_HOG in sandbox_defconfig, add in DTS some gpio hog entries, and add testcase in "ut dm gpio" command.
Signed-off-by: Heiko Schocher hs@denx.de
Changes in v3: None Changes in v2: - add basic gpio hog test functions
arch/sandbox/dts/test.dts | 24 ++++++++++++++++++++++++ configs/sandbox64_defconfig | 1 + configs/sandbox_defconfig | 1 + configs/sandbox_flattree_defconfig | 1 + configs/sandbox_spl_defconfig | 1 + test/dm/gpio.c | 23 +++++++++++++++++++++++ 6 files changed, 51 insertions(+)
diff --git a/arch/sandbox/dts/test.dts b/arch/sandbox/dts/test.dts index e529c54d8d..cff05dcf7c 100644 --- a/arch/sandbox/dts/test.dts +++ b/arch/sandbox/dts/test.dts @@ -1,5 +1,7 @@ /dts-v1/;
+#include <dt-bindings/gpio/gpio.h> + / { model = "sandbox"; compatible = "sandbox"; @@ -284,6 +286,28 @@ #gpio-cells = <1>; gpio-bank-name = "a"; sandbox,gpio-count = <20>; + + hog_input_active_low { + gpio-hog; + input; + gpios = <0 GPIO_ACTIVE_LOW>; + }; + hog_input_active_high { + gpio-hog; + input; + gpios = <1 GPIO_ACTIVE_HIGH>; + }; + hog_output_low { + gpio-hog; + output-low; + gpios = <2 GPIO_ACTIVE_HIGH>; + }; + hog_output_high { + gpio-hog; + output-high; + gpios = <3 GPIO_ACTIVE_HIGH>; + }; + };
gpio_b: extra-gpios { diff --git a/configs/sandbox64_defconfig b/configs/sandbox64_defconfig index 7b80033c3b..f614b23666 100644 --- a/configs/sandbox64_defconfig +++ b/configs/sandbox64_defconfig @@ -92,6 +92,7 @@ CONFIG_DM_DEMO_SIMPLE=y CONFIG_DM_DEMO_SHAPE=y CONFIG_BOARD=y CONFIG_BOARD_SANDBOX=y +CONFIG_GPIO_HOG=y CONFIG_PM8916_GPIO=y CONFIG_SANDBOX_GPIO=y CONFIG_I2C_CROS_EC_TUNNEL=y diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index fc018bdd2c..afce8050b4 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -108,6 +108,7 @@ CONFIG_BOARD_SANDBOX=y CONFIG_DMA=y CONFIG_DMA_CHANNELS=y CONFIG_SANDBOX_DMA=y +CONFIG_GPIO_HOG=y CONFIG_PM8916_GPIO=y CONFIG_SANDBOX_GPIO=y CONFIG_DM_HWSPINLOCK=y diff --git a/configs/sandbox_flattree_defconfig b/configs/sandbox_flattree_defconfig index 2c90639ecb..0518b56fd9 100644 --- a/configs/sandbox_flattree_defconfig +++ b/configs/sandbox_flattree_defconfig @@ -78,6 +78,7 @@ CONFIG_DM_DEMO_SIMPLE=y CONFIG_DM_DEMO_SHAPE=y CONFIG_BOARD=y CONFIG_BOARD_SANDBOX=y +CONFIG_GPIO_HOG=y CONFIG_PM8916_GPIO=y CONFIG_SANDBOX_GPIO=y CONFIG_I2C_CROS_EC_TUNNEL=y diff --git a/configs/sandbox_spl_defconfig b/configs/sandbox_spl_defconfig index b78115af61..e70f2b4aa8 100644 --- a/configs/sandbox_spl_defconfig +++ b/configs/sandbox_spl_defconfig @@ -98,6 +98,7 @@ CONFIG_DM_DEMO_SHAPE=y CONFIG_BOARD=y CONFIG_BOARD_SANDBOX=y CONFIG_SPL_FIRMWARE=y +CONFIG_GPIO_HOG=y CONFIG_PM8916_GPIO=y CONFIG_SANDBOX_GPIO=y CONFIG_I2C_CROS_EC_TUNNEL=y diff --git a/test/dm/gpio.c b/test/dm/gpio.c index bb4b20cea9..9003ea82c7 100644 --- a/test/dm/gpio.c +++ b/test/dm/gpio.c @@ -18,6 +18,7 @@ static int dm_test_gpio(struct unit_test_state *uts) unsigned int offset, gpio; struct dm_gpio_ops *ops; struct udevice *dev; + struct gpio_desc *desc; const char *name; int offset_count; char buf[80]; @@ -102,6 +103,28 @@ static int dm_test_gpio(struct unit_test_state *uts) ut_asserteq_str("a", name); ut_asserteq(20, offset_count);
+ /* add gpio hog tests */ + ut_assertok(gpio_hog_lookup_name("hog_input_active_low", &desc)); + ut_asserteq(GPIOD_IS_IN | GPIOD_ACTIVE_LOW, desc->flags); + ut_asserteq(0, desc->offset); + ut_asserteq(1, dm_gpio_get_value(desc)); + ut_assertok(gpio_hog_lookup_name("hog_input_active_high", &desc)); + ut_asserteq(GPIOD_IS_IN, desc->flags); + ut_asserteq(1, desc->offset); + ut_asserteq(0, dm_gpio_get_value(desc)); + ut_assertok(gpio_hog_lookup_name("hog_output_low", &desc)); + ut_asserteq(GPIOD_IS_OUT, desc->flags); + ut_asserteq(2, desc->offset); + ut_asserteq(0, dm_gpio_get_value(desc)); + ut_assertok(dm_gpio_set_value(desc, 1)); + ut_asserteq(1, dm_gpio_get_value(desc)); + ut_assertok(gpio_hog_lookup_name("hog_output_high", &desc)); + ut_asserteq(GPIOD_IS_OUT, desc->flags); + ut_asserteq(3, desc->offset); + ut_asserteq(1, dm_gpio_get_value(desc)); + ut_assertok(dm_gpio_set_value(desc, 0)); + ut_asserteq(0, dm_gpio_get_value(desc)); + return 0; } DM_TEST(dm_test_gpio, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT);
Signed-off-by: Heiko Schocher hs@denx.de Reviewed-by: Simon Glass sjg@chromium.org
This no longer applies cleanly/obviously, please rebase, thanks!
Hello Tom,
Am 24.04.2020 um 19:45 schrieb Tom Rini:
Done, unfortunately, aristainetos2 does not boot anymore... got:
├─UBOOT (ari-ub) │ │ <> ### Connect to "aristainetos" using command: /usr/bin/telnet ts2 7015 │ │ <> Trying 192.168.1.202... │ │ <> Connected to ts2. │ │ <> Escape character is '^]'. │ │ <> <debug_uart> unrecognized JEDEC id bytes: 00, 00, 00 │ │ <> *** Warning - spi_flash_probe_bus_cs() failed, using default environment │ │ <> │ │ <> alloc space exhausted │ │ <> alloc space exhausted │ │ <> alloc space exhausted │ │ <> himport_r: can't insert "loadbootscriptUSB=ext4load usb 0 ${loadaddr} ${script};" into hash table │ │ <> alloc space exhausted │ │ <> alloc space exhausted
Seems early SPI NOR detection fails ...
Have to start bisect, try to find some time...
bye, Heiko
Hello Tom, Patrick,
Am 27.04.2020 um 07:16 schrieb Heiko Schocher:
Hello Tom,
Ok, commit:
commit 788ea834124bd6169ea10b2d37d5de48a2dd28a0 (bisect-788ea83412) Author: Patrick Delaunay patrick.delaunay@st.com Date: Mon Jan 13 11:35:03 2020 +0100
gpio: add function _dm_gpio_set_dir_flags
Introduce the function _dm_gpio_set_dir_flags to set dir flags without check if the GPIO is reserved.
Separate the reserved check for "set_dir" and "set_dir_flags".
This patch is a preliminary step to add new ops.
Signed-off-by: Patrick Delaunay patrick.delaunay@st.com Reviewed-by: Simon Glass sjg@chromium.org
breaks the aristainetos2 board ... reverting this patch (and therefore I needed some more patches to revert as it was a patchseries):
* dbf06f0e6c - (HEAD -> aristainetos-denx) Revert "gpio: add function _gpio_get_value" (vor 5 Minuten) <Heiko Schocher> * 5c85a7cc26 - Revert "gpio: add function _dm_gpio_set_dir_flags" (vor 5 Minuten) <Heiko Schocher> * c226d65d88 - Revert "gpio: add function check_dir_flags" (vor 5 Minuten) <Heiko Schocher> * 1423a40c69 - Revert "gpio: add helper GPIOD_FLAGS_OUTPUT" (vor 5 Minuten) <Heiko Schocher> * fb0176450f - Revert "gpio: update dir_flags management" (vor 5 Minuten) <Heiko Schocher> * 9d74cc5ecb - Revert "gpio: add support of new GPIO direction flag" (vor 5 Minuten) <Heiko Schocher> * 3bf361c206 - Revert "gpio: add ops to get dir flags" (vor 5 Minuten) <Heiko Schocher> * beb6d3c2d9 - Revert "gpio: add ops to set dir flags" (vor 5 Minuten) <Heiko Schocher>
And board boots again fine ...
I do not see, why commit 788ea834124bd6169ea10b2d37d5de48a2dd28a0 makes SPI not working anymore ...
Any ideas?
bye, Heiko
Hello Tom, Patrick,
Am 27.04.2020 um 08:47 schrieb Heiko Schocher:
Hello Tom, Patrick,
Hello Tom,
Ok, commit:
- dbf06f0e6c - (HEAD -> aristainetos-denx) Revert "gpio: add function _gpio_get_value" (vor 5
- 5c85a7cc26 - Revert "gpio: add function _dm_gpio_set_dir_flags" (vor 5 Minuten) <Heiko Schocher>
- c226d65d88 - Revert "gpio: add function check_dir_flags" (vor 5 Minuten) <Heiko Schocher>
- 1423a40c69 - Revert "gpio: add helper GPIOD_FLAGS_OUTPUT" (vor 5 Minuten) <Heiko Schocher>
- fb0176450f - Revert "gpio: update dir_flags management" (vor 5 Minuten) <Heiko Schocher>
- 9d74cc5ecb - Revert "gpio: add support of new GPIO direction flag" (vor 5 Minuten) <Heiko Schocher>
- 3bf361c206 - Revert "gpio: add ops to get dir flags" (vor 5 Minuten) <Heiko Schocher>
- beb6d3c2d9 - Revert "gpio: add ops to set dir flags" (vor 5 Minuten) <Heiko Schocher>
Any ideas?
Just looking with sandbox into it ... added debug patch:
diff --git a/drivers/gpio/gpio-uclass.c b/drivers/gpio/gpio-uclass.c index 3fb6b6e69c..2e68f558bd 100644 --- a/drivers/gpio/gpio-uclass.c +++ b/drivers/gpio/gpio-uclass.c @@ -273,9 +273,11 @@ static int gpio_hog_probe(struct udevice *dev) struct gpio_hog_priv *priv = dev_get_priv(dev); int ret;
+ printf("%s: --------- dev->name: %s nr: %d flag: %d platflags: %d\n", __func__, dev->name, plat->val[0], plat->val[1], plat->gpiod_flags); ret = gpio_dev_request_index(dev->parent, dev->name, "gpio-hog", plat->val[0], plat->gpiod_flags, plat->val[1], &priv->gpiod); + printf("%s: --------- gpiod: %p\n", __func__, &priv->gpiod); if (ret < 0) { debug("%s: node %s could not get gpio.\n", __func__, dev->name); @@ -291,6 +293,10 @@ static int gpio_hog_probe(struct udevice *dev) } }
+ if (1) { + struct gpio_desc *gpiod = &priv->gpiod; + printf("%s: gpiod_flags: %x\n", __func__, gpiod->flags); + } return 0; }
and see:
=> ut dm gpio Test: dm_test_gpio: gpio.c gpio_hog_probe_all: --------- gpio_hog_probe: --------- dev->name: hog_input_active_low nr: 0 flag: 1 platflags: 4 gpio_hog_probe: --------- gpiod: 0000000015901050 gpio_hog_probe: gpiod_flags: 8 gpio_hog_probe: --------- dev->name: hog_input_active_high nr: 1 flag: 0 platflags: 4 gpio_hog_probe: --------- gpiod: 00000000159010a0 gpio_hog_probe: gpiod_flags: 0 gpio_hog_probe: --------- dev->name: hog_output_low nr: 2 flag: 0 platflags: 2 gpio_hog_probe: --------- gpiod: 00000000159010f0 gpio_hog_probe: gpiod_flags: 0 gpio_hog_probe: --------- dev->name: hog_output_high nr: 3 flag: 0 platflags: 2 gpio_hog_probe: --------- gpiod: 0000000015901130 gpio_hog_probe: gpiod_flags: 0 gpio_hog_lookup_name: name: hog_input_active_low gpio_hog_lookup_name: --------- gpiod: 15901050 test/dm/gpio.c:115, dm_test_gpio(): GPIOD_IS_IN | GPIOD_ACTIVE_LOW == desc->flags: Expected 0xc (12), got 0x8 (8)
It looks like the plat->gpiod_flags are not written anymore into gpiod through the gpio_dev_request_index() function ...
bye, Heiko
Hello tom, Patrick,
Am 12.05.2020 um 08:26 schrieb Heiko Schocher:
Hello Tom, Patrick,
Hello Tom, Patrick,
Hello Tom,
Ok, commit:
Any ideas?
and see:
Ok, I did now the following change:
https://github.com/hsdenx/u-boot-test/commits/aristainetos-gpio-v4
$ git show c4a3295fa6 commit c4a3295fa67f23408ba3ff5552532222f48142f6 Author: Heiko Schocher hs@denx.de Date: Tue May 12 08:56:40 2020 +0200
gpio-uclass.c: save the GPIOD flags also in the gpio descriptor
save the GPIOD_ flags also in the gpio descriptor.
Patch-cc: Patrick Delaunay patrick.delaunay@st.com
Series-changes: 4 - new in version 4
diff --git a/drivers/gpio/gpio-uclass.c b/drivers/gpio/gpio-uclass.c index 757ab7106e..fc94334160 100644 --- a/drivers/gpio/gpio-uclass.c +++ b/drivers/gpio/gpio-uclass.c @@ -572,6 +572,9 @@ static int _dm_gpio_set_dir_flags(struct gpio_desc *desc, ulong flags) return ret; }
+ /* save the flags also in descriptor */ + desc->flags = flags; + /* GPIOD_ are directly managed by driver in set_dir_flags*/ if (ops->set_dir_flags) { ret = ops->set_dir_flags(dev, desc->offset, flags);
and with it, the sandbox tests and the aristainetos2 board works fine again. I have just started a travis build for it:
https://travis-ci.org/github/hsdenx/u-boot-test/builds/685995112
If no errors pop up, I send v4 version of my patchseries.
bye, Heiko
Hi Heiko
From: Heiko Schocher hs@denx.de Sent: mardi 12 mai 2020 09:32
Hello tom, Patrick,
Hello Tom, Patrick,
Hello Tom, Patrick,
Hello Tom,
${script};"
Ok, commit:
Any ideas?
+ printf("%s: --------- dev->name: %s nr: %d flag: %d platflags: +%d\n", __func__, dev->name, plat->val[0], plat->val[1], plat->gpiod_flags); ret = gpio_dev_request_index(dev->parent, dev->name, "gpio-hog", plat->val[0], plat->gpiod_flags, plat->val[1], &priv->gpiod); + printf("%s: --------- gpiod: %p\n", __func__, &priv->gpiod); if (ret < 0) { debug("%s: node %s could not get gpio.\n", __func__, dev->name); @@ -291,6 +293,10 @@ static int gpio_hog_probe(struct udevice *dev) } }
+ if (1) { + struct gpio_desc *gpiod = &priv->gpiod; + printf("%s: gpiod_flags: %x\n", __func__, +gpiod->flags); + } return 0; }
and see:
gpio-uclass.c: save the GPIOD flags also in the gpio descriptor save the GPIOD_ flags also in the gpio descriptor. Signed-off-by: Heiko Schocher <hs@denx.de> Patch-cc: Patrick Delaunay <patrick.delaunay@st.com> Series-changes: 4 - new in version 4
In my serie, normally the update of the desc->flags was done in dm_gpio_set_dir_flags()
with the line
/* update the descriptor flags */ if (ret) desc->flags = flags;
not needed in dm_gpio_set_dir (as requested with desc->flags)
At first lok, I don't understood the execution path to have desc->flags not updated...
But in fact I inverse the test (again :-<)
/* update the descriptor flags */ + if (!ret) - if (ret) desc->flags = flags;
but this test could move in _ dm_gpio_set_deit to be more clear, but I think we need continue to test ret value before to update descriptor
Sorry for the issue.
Do you prefer that send a sperate patch to correct this error ?
Regards
Patrick
Hello Patrick,
Am 14.05.2020 um 15:47 schrieb Patrick DELAUNAY:
Hi Heiko
Hello tom, Patrick,
Hello Tom, Patrick,
Hello Tom, Patrick,
Hello Tom,
> currently gpio hog function is not tested with "ut dm gpio" > so add some basic tests for gpio hog functionality. > > For this enable GPIO_HOG in sandbox_defconfig, add in DTS some > gpio hog entries, and add testcase in "ut dm gpio" command. > > Signed-off-by: Heiko Schocher hs@denx.de > Reviewed-by: Simon Glass sjg@chromium.org
${script};"
Ok, commit:
Any ideas?
and see:
with the line
- if (!ret)
Ok, this fix works also, thanks!
Moved this into _dm_gpio_set_dir_flags()
No problem, more problematic was, that I missed to add sandbox tests before and patch which adds them is pending for a while!
I would see this in this patchseries, travis build runs, and I post v5 if all is fine, thanks!
https://travis-ci.org/github/hsdenx/u-boot-test/builds/687305014
bye, Heiko
Hi Heiko,
From: Heiko Schocher hs@denx.de Sent: vendredi 15 mai 2020 08:01
Hello Patrick,
Hi Heiko
Hello tom, Patrick,
with the line
updated...
- if (!ret)
Ok, your patch is good for me.
Thanks Patrick
dm_gpio_lookup_name() searches for a gpio through the bank name. But we have also gpio labels, and it makes sense to search for a gpio also in the labels we have defined, if no gpio is found through the bank name definition.
This is useful for example if you have a wp pin on different gpios on different board versions.
If dm_gpio_lookup_name() searches also for the gpio labels, you can give the gpio an unique label name and search for this label, and do not need to differ between board revisions.
Signed-off-by: Heiko Schocher hs@denx.de ---
Example on the aristainetos board:
=> gpio clear wp_spi_nor.gpio-hog gpio: pin wp_spi_nor.gpio-hog (gpio 47) value is 0 =>
before this patch, you need to know where your pin is:
=> gpio clear GPIO2_15 gpio: pin GPIO2_15 (gpio 47) value is 0 =>
travis build:
Changes in v2: - add comment from Simon Glass move code into seperate function dm_gpio_lookup_label() add test if dm_gpio_lookup_label() works
drivers/gpio/Kconfig | 22 ++++++++++++++++++ drivers/gpio/gpio-uclass.c | 47 ++++++++++++++++++++++++++++++++++++++ test/dm/gpio.c | 7 ++++++ 3 files changed, 76 insertions(+)
diff --git a/drivers/gpio/Kconfig b/drivers/gpio/Kconfig index 4e5a70780a..5614f3f828 100644 --- a/drivers/gpio/Kconfig +++ b/drivers/gpio/Kconfig @@ -46,6 +46,28 @@ config GPIO_HOG is a mechanism providing automatic GPIO request and config- uration as part of the gpio-controller's driver probe function.
+config DM_GPIO_LOOKUP_LABEL + bool "Enable searching for gpio labelnames" + depends on DM_GPIO + default y + help + This option enables searching for gpio names in + the defined gpio labels, if the search for the + gpio bank name failed. This makes sense if you use + different gpios on different hardware versions + for the same functionality in board code. + +config SPL_DM_GPIO_LOOKUP_LABEL + bool "Enable searching for gpio labelnames" + depends on DM_GPIO && SPL_DM && SPL_GPIO_SUPPORT + default n + help + This option enables searching for gpio names in + the defined gpio labels, if the search for the + gpio bank name failed. This makes sense if you use + different gpios on different hardware versions + for the same functionality in board code. + config ALTERA_PIO bool "Altera PIO driver" depends on DM_GPIO diff --git a/drivers/gpio/gpio-uclass.c b/drivers/gpio/gpio-uclass.c index 90fbed455b..e5c1d0d7a3 100644 --- a/drivers/gpio/gpio-uclass.c +++ b/drivers/gpio/gpio-uclass.c @@ -52,6 +52,46 @@ static int gpio_to_device(unsigned int gpio, struct gpio_desc *desc) return ret ? ret : -ENOENT; }
+#if CONFIG_IS_ENABLED(DM_GPIO_LOOKUP_LABEL) +/** + * dm_gpio_lookup_label() - look for name in gpio device + * + * search in uc_priv, if there is a gpio with labelname same + * as name. + * + * @name: name which is searched + * @uc_priv: gpio_dev_priv pointer. + * @offset: gpio offset within the device + * @return: 0 if found, -ENOENT if not. + */ +static int +dm_gpio_lookup_label(const char *name, struct gpio_dev_priv *uc_priv, + ulong *offset) +{ + int len; + int i; + + *offset = -1; + len = strlen(name); + for (i = 0; i < uc_priv->gpio_count; i++) { + if (!uc_priv->name[i]) + continue; + if (!strncmp(name, uc_priv->name[i], len)) { + *offset = i; + return 0; + } + } + return -ENOENT; +} +#else +static int +dm_gpio_lookup_label(const char *name, struct gpio_dev_priv *uc_priv, + ulong *offset) +{ + return -ENOENT; +} +#endif + int dm_gpio_lookup_name(const char *name, struct gpio_desc *desc) { struct gpio_dev_priv *uc_priv = NULL; @@ -80,6 +120,13 @@ int dm_gpio_lookup_name(const char *name, struct gpio_desc *desc) if (!strict_strtoul(name + len, 10, &offset)) break; } + + /* + * if we did not found a gpio through its bank + * name, we search for a valid gpio label. + */ + if (!dm_gpio_lookup_label(name, uc_priv, &offset)) + break; }
if (!dev) diff --git a/test/dm/gpio.c b/test/dm/gpio.c index 9003ea82c7..1f1bf680c5 100644 --- a/test/dm/gpio.c +++ b/test/dm/gpio.c @@ -125,6 +125,13 @@ static int dm_test_gpio(struct unit_test_state *uts) ut_assertok(dm_gpio_set_value(desc, 0)); ut_asserteq(0, dm_gpio_get_value(desc));
+ /* Check if lookup for labels work */ + ut_assertok(gpio_lookup_name("hog_input_active_low", &dev, &offset, + &gpio)); + ut_asserteq_str(dev->name, "base-gpios"); + ut_asserteq(0, offset); + ut_asserteq(CONFIG_SANDBOX_GPIO_COUNT + 0, gpio); + return 0; } DM_TEST(dm_test_gpio, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT);
travis build:
Changes in v3:
Changes in v2:
Heiko Schocher
Patrick DELAUNAY
