[U-Boot] [PATCH v2 1/1] ARM: DRA72x: fix io delay calibration for ethernet
we currently use in-development IODelay values for DRA72x which are proposed in the data sheet, however, DRA72x EVM uses DP83865 ethernet Phy over RGMII. The PHY characteristics and routing choices made on the EVM, make the current iodelay values fail ethernet communication.
Instead, we need to choose custom values for DRA72x-evm specifically designed for the PHY and routing on the platform for ethernet to function.
Cc: Nishanth Menon nm@ti.com Cc: Lokesh Vutla lokeshvutla@ti.com Tested-by: Lokesh Vutla lokeshvutla@ti.com Reviewed-by: Nishanth Menon nm@ti.com Signed-off-by: Mugunthan V N mugunthanvnm@ti.com --- board/ti/dra7xx/mux_data.h | 49 +++++++++++++++++++++++----------------------- 1 file changed, 25 insertions(+), 24 deletions(-)
diff --git a/board/ti/dra7xx/mux_data.h b/board/ti/dra7xx/mux_data.h index c9301a5..5145301 100644 --- a/board/ti/dra7xx/mux_data.h +++ b/board/ti/dra7xx/mux_data.h @@ -156,30 +156,31 @@ const struct pad_conf_entry early_padconf[] = {
#ifdef CONFIG_IODELAY_RECALIBRATION const struct iodelay_cfg_entry iodelay_cfg_array[] = { - {0x6F0, 480, 0}, /* RGMMI0_RXC_IN */ - {0x6FC, 111, 1641}, /* RGMMI0_RXCTL_IN */ - {0x708, 272, 1116}, /* RGMMI0_RXD0_IN */ - {0x714, 243, 1260}, /* RGMMI0_RXD1_IN */ - {0x720, 0, 1614}, /* RGMMI0_RXD2_IN */ - {0x72C, 105, 1673}, /* RGMMI0_RXD3_IN */ - {0x740, 531, 120}, /* RGMMI0_TXC_OUT */ - {0x74C, 11, 60}, /* RGMMI0_TXCTL_OUT */ - {0x758, 7, 120}, /* RGMMI0_TXD0_OUT */ - {0x764, 0, 0}, /* RGMMI0_TXD1_OUT */ - {0x770, 276, 120}, /* RGMMI0_TXD2_OUT */ - {0x77C, 440, 120}, /* RGMMI0_TXD3_OUT */ - {0xAB0, 702, 0}, /* CFG_VIN2A_D18_IN */ - {0xABC, 136, 976}, /* CFG_VIN2A_D19_IN */ - {0xAD4, 210, 1357}, /* CFG_VIN2A_D20_IN */ - {0xAE0, 189, 1462}, /* CFG_VIN2A_D21_IN */ - {0xAEC, 232, 1278}, /* CFG_VIN2A_D22_IN */ - {0xAF8, 0, 1397}, /* CFG_VIN2A_D23_IN */ - {0xA70, 1551, 115}, /* CFG_VIN2A_D12_OUT */ - {0xA7C, 816, 0}, /* CFG_VIN2A_D13_OUT */ - {0xA88, 876, 0}, /* CFG_VIN2A_D14_OUT */ - {0xA94, 312, 0}, /* CFG_VIN2A_D15_OUT */ - {0xAA0, 58, 0}, /* CFG_VIN2A_D16_OUT */ - {0xAAC, 0, 0}, /* CFG_VIN2A_D17_OUT */ + {0x6F0, 359, 0}, /* RGMMI0_RXC_IN */ + {0x6FC, 129, 1896}, /* RGMMI0_RXCTL_IN */ + {0x708, 80, 1391}, /* RGMMI0_RXD0_IN */ + {0x714, 196, 1522}, /* RGMMI0_RXD1_IN */ + {0x720, 40, 1860}, /* RGMMI0_RXD2_IN */ + {0x72C, 0, 1956}, /* RGMMI0_RXD3_IN */ + {0x740, 0, 220}, /* RGMMI0_TXC_OUT */ + {0x74C, 1820, 180}, /* RGMMI0_TXCTL_OUT */ + {0x758, 1740, 440}, /* RGMMI0_TXD0_OUT */ + {0x764, 1740, 240}, /* RGMMI0_TXD1_OUT */ + {0x770, 1680, 380}, /* RGMMI0_TXD2_OUT */ + {0x77C, 1740, 440}, /* RGMMI0_TXD3_OUT */ + /* These values are for using RGMII1 configuration on VIN2a_x pins. */ + {0xAB0, 596, 0}, /* CFG_VIN2A_D18_IN */ + {0xABC, 314, 980}, /* CFG_VIN2A_D19_IN */ + {0xAD4, 241, 1536}, /* CFG_VIN2A_D20_IN */ + {0xAE0, 103, 1689}, /* CFG_VIN2A_D21_IN */ + {0xAEC, 161, 1563}, /* CFG_VIN2A_D22_IN */ + {0xAF8, 0, 1613}, /* CFG_VIN2A_D23_IN */ + {0xA70, 0, 200}, /* CFG_VIN2A_D12_OUT */ + {0xA7C, 1560, 140}, /* CFG_VIN2A_D13_OUT */ + {0xA88, 1700, 0}, /* CFG_VIN2A_D14_OUT */ + {0xA94, 1260, 0}, /* CFG_VIN2A_D15_OUT */ + {0xAA0, 1400, 0}, /* CFG_VIN2A_D16_OUT */ + {0xAAC, 1290, 0}, /* CFG_VIN2A_D17_OUT */ }; #endif
Tom,
Do you have any comments on this patch?
Regards Mugunthan V N
Tom,
Oh sorry, this slipped my mind.
Mugunthan V N
