[U-Boot] [PATCH 01/19] s3c4510b: move specific code to soc directory
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com --- Makefile | 2 +- cpu/arm720t/cpu.c | 62 -------------- cpu/arm720t/s3c4510b/Makefile | 46 +++++++++++ cpu/arm720t/s3c4510b/cache.c | 86 ++++++++++++++++++++ include/asm-arm/arch-arm720t/hardware.h | 4 +- .../s3c4510b.h => arch-s3c4510b/hardware.h} | 0 6 files changed, 134 insertions(+), 66 deletions(-) create mode 100644 cpu/arm720t/s3c4510b/Makefile create mode 100644 cpu/arm720t/s3c4510b/cache.c rename include/asm-arm/{arch-arm720t/s3c4510b.h => arch-s3c4510b/hardware.h} (100%)
diff --git a/Makefile b/Makefile index 1cce381..a6dadf6 100644 --- a/Makefile +++ b/Makefile @@ -2943,7 +2943,7 @@ modnet50_config : unconfig @$(MKCONFIG) $(@:_config=) arm arm720t modnet50
evb4510_config : unconfig - @$(MKCONFIG) $(@:_config=) arm arm720t evb4510 + @$(MKCONFIG) $(@:_config=) arm arm720t evb4510 NULL s3c4510b
lpc2292sodimm_config: unconfig @$(MKCONFIG) $(@:_config=) arm arm720t lpc2292sodimm NULL lpc2292 diff --git a/cpu/arm720t/cpu.c b/cpu/arm720t/cpu.c index 5ac8f59..8166982 100644 --- a/cpu/arm720t/cpu.c +++ b/cpu/arm720t/cpu.c @@ -188,71 +188,9 @@ int dcache_status (void) { return (read_p15_c1 () & C1_IDC) != 0; } - -#elif defined(CONFIG_S3C4510B) - -void icache_enable (void) -{ - s32 i; - - /* disable all cache bits */ - CLR_REG( REG_SYSCFG, 0x3F); - - /* 8KB cache, write enable */ - SET_REG( REG_SYSCFG, CACHE_WRITE_BUFF | CACHE_MODE_01); - - /* clear TAG RAM bits */ - for ( i = 0; i < 256; i++) - PUT_REG( CACHE_TAG_RAM + 4*i, 0x00000000); - - /* clear SET0 RAM */ - for(i=0; i < 1024; i++) - PUT_REG( CACHE_SET0_RAM + 4*i, 0x00000000); - - /* clear SET1 RAM */ - for(i=0; i < 1024; i++) - PUT_REG( CACHE_SET1_RAM + 4*i, 0x00000000); - - /* enable cache */ - SET_REG( REG_SYSCFG, CACHE_ENABLE); - -} - -void icache_disable (void) -{ - /* disable all cache bits */ - CLR_REG( REG_SYSCFG, 0x3F); -} - -int icache_status (void) -{ - return GET_REG( REG_SYSCFG) & CACHE_ENABLE; -} - -void dcache_enable (void) -{ - /* we don't have seperate instruction/data caches */ - icache_enable(); -} - -void dcache_disable (void) -{ - /* we don't have seperate instruction/data caches */ - icache_disable(); -} - -int dcache_status (void) -{ - /* we don't have seperate instruction/data caches */ - return icache_status(); -} - #elif defined(CONFIG_INTEGRATOR) && defined(CONFIG_ARCH_INTEGRATOR) /* No specific cache setup for IntegratorAP/CM720T as yet */ void icache_enable (void) { } -#elif defined(CONFIG_LPC2292) /* just to satisfy the compiler */ -#else -#error No icache/dcache enable/disable functions defined for this CPU type #endif diff --git a/cpu/arm720t/s3c4510b/Makefile b/cpu/arm720t/s3c4510b/Makefile new file mode 100644 index 0000000..c9520b6 --- /dev/null +++ b/cpu/arm720t/s3c4510b/Makefile @@ -0,0 +1,46 @@ +# +# (C) Copyright 2000-2008 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(SOC).a + +COBJS-y += cache.o + +SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS-y)) + +all: $(obj).depend $(LIB) + +$(LIB): $(OBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### + diff --git a/cpu/arm720t/s3c4510b/cache.c b/cpu/arm720t/s3c4510b/cache.c new file mode 100644 index 0000000..104d287 --- /dev/null +++ b/cpu/arm720t/s3c4510b/cache.c @@ -0,0 +1,86 @@ +/* + * (C) Copyright 2002 + * Sysgo Real-Time Solutions, GmbH <www.elinos.com> + * Marius Groeger mgroeger@sysgo.de + * + * (C) Copyright 2002 + * Sysgo Real-Time Solutions, GmbH <www.elinos.com> + * Alex Zuepke azu@sysgo.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/hardware.h> + +void icache_enable (void) +{ + s32 i; + + /* disable all cache bits */ + CLR_REG( REG_SYSCFG, 0x3F); + + /* 8KB cache, write enable */ + SET_REG( REG_SYSCFG, CACHE_WRITE_BUFF | CACHE_MODE_01); + + /* clear TAG RAM bits */ + for ( i = 0; i < 256; i++) + PUT_REG( CACHE_TAG_RAM + 4*i, 0x00000000); + + /* clear SET0 RAM */ + for(i=0; i < 1024; i++) + PUT_REG( CACHE_SET0_RAM + 4*i, 0x00000000); + + /* clear SET1 RAM */ + for(i=0; i < 1024; i++) + PUT_REG( CACHE_SET1_RAM + 4*i, 0x00000000); + + /* enable cache */ + SET_REG( REG_SYSCFG, CACHE_ENABLE); + +} + +void icache_disable (void) +{ + /* disable all cache bits */ + CLR_REG( REG_SYSCFG, 0x3F); +} + +int icache_status (void) +{ + return GET_REG( REG_SYSCFG) & CACHE_ENABLE; +} + +void dcache_enable (void) +{ + /* we don't have seperate instruction/data caches */ + icache_enable(); +} + +void dcache_disable (void) +{ + /* we don't have seperate instruction/data caches */ + icache_disable(); +} + +int dcache_status (void) +{ + /* we don't have seperate instruction/data caches */ + return icache_status(); +} diff --git a/include/asm-arm/arch-arm720t/hardware.h b/include/asm-arm/arch-arm720t/hardware.h index 3056ca7..ec053c9 100644 --- a/include/asm-arm/arch-arm720t/hardware.h +++ b/include/asm-arm/arch-arm720t/hardware.h @@ -24,9 +24,7 @@ * MA 02111-1307 USA */
-#if defined(CONFIG_S3C4510B) -#include <asm-arm/arch-arm720t/s3c4510b.h> -#elif defined(CONFIG_NETARM) +#if defined(CONFIG_NETARM) #include <asm-arm/arch-arm720t/netarm_registers.h> #elif defined(CONFIG_IMPA7) /* include IMPA7 specific hardware file if there was one */ diff --git a/include/asm-arm/arch-arm720t/s3c4510b.h b/include/asm-arm/arch-s3c4510b/hardware.h similarity index 100% rename from include/asm-arm/arch-arm720t/s3c4510b.h rename to include/asm-arm/arch-s3c4510b/hardware.h
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com --- cpu/s3c44b0/cpu.c | 735 +++++++----------------- drivers/i2c/Makefile | 1 + cpu/s3c44b0/cpu.c => drivers/i2c/s3c44b0_i2c.c | 198 ------- include/configs/B2.h | 2 + 4 files changed, 225 insertions(+), 711 deletions(-) rewrite cpu/s3c44b0/cpu.c (60%) rename cpu/s3c44b0/cpu.c => drivers/i2c/s3c44b0_i2c.c (70%)
diff --git a/cpu/s3c44b0/cpu.c b/cpu/s3c44b0/cpu.c dissimilarity index 60% index 2960f2f..0c44691 100644 --- a/cpu/s3c44b0/cpu.c +++ b/cpu/s3c44b0/cpu.c @@ -1,513 +1,222 @@ -/* - * (C) Copyright 2004 - * DAVE Srl - * http://www.dave-tech.it - * http://www.wawnet.biz - * mailto:info@wawnet.biz - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -/* - * S3C44B0 CPU specific code - */ - -#include <common.h> -#include <command.h> -#include <asm/hardware.h> - -static void s3c44b0_flush_cache(void) -{ - volatile int i; - /* flush cycle */ - for(i=0x10002000;i<0x10004800;i+=16) - { - *((int *)i)=0x0; - } -} - - -int cpu_init (void) -{ - icache_enable(); - - return 0; -} - -int cleanup_before_linux (void) -{ - /* - cache memory should be enabled before calling - Linux to make the kernel uncompression faster - */ - icache_enable(); - - disable_interrupts (); - - return 0; -} - -void reset_cpu (ulong addr) -{ - /* - reset the cpu using watchdog - */ - - /* Disable the watchdog.*/ - WTCON&=~(1<<5); - - /* set the timeout value to a short time... */ - WTCNT = 0x1; - - /* Enable the watchdog. */ - WTCON|=1; - WTCON|=(1<<5); - - while(1) { - /*NOP*/ - } -} - -int do_reset (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) -{ - disable_interrupts (); - reset_cpu (0); - - /*NOTREACHED*/ - return (0); -} - -void icache_enable (void) -{ - ulong reg; - - s3c44b0_flush_cache(); - - /* - Init cache - Non-cacheable area (everything outside RAM) - 0x0000:0000 - 0x0C00:0000 - */ - NCACHBE0 = 0xC0000000; - NCACHBE1 = 0x00000000; - - /* - Enable chache - */ - reg = SYSCFG; - reg |= 0x00000006; /* 8kB */ - SYSCFG = reg; -} - -void icache_disable (void) -{ - ulong reg; - - reg = SYSCFG; - reg &= ~0x00000006; /* 8kB */ - SYSCFG = reg; -} - -int icache_status (void) -{ - return 0; -} - -void dcache_enable (void) -{ - icache_enable(); -} - -void dcache_disable (void) -{ - icache_disable(); -} - -int dcache_status (void) -{ - return dcache_status(); -} - -/* - RTC stuff -*/ -#include <rtc.h> -#ifndef BCD2HEX - #define BCD2HEX(n) ((n>>4)*10+(n&0x0f)) -#endif -#ifndef HEX2BCD - #define HEX2BCD(x) ((((x) / 10) << 4) + (x) % 10) -#endif - -int rtc_get (struct rtc_time* tm) -{ - RTCCON |= 1; - tm->tm_year = BCD2HEX(BCDYEAR); - tm->tm_mon = BCD2HEX(BCDMON); - tm->tm_wday = BCD2HEX(BCDDATE); - tm->tm_mday = BCD2HEX(BCDDAY); - tm->tm_hour = BCD2HEX(BCDHOUR); - tm->tm_min = BCD2HEX(BCDMIN); - tm->tm_sec = BCD2HEX(BCDSEC); - - if (tm->tm_sec==0) { - /* we have to re-read the rtc data because of the "one second deviation" problem */ - /* see RTC datasheet for more info about it */ - tm->tm_year = BCD2HEX(BCDYEAR); - tm->tm_mon = BCD2HEX(BCDMON); - tm->tm_mday = BCD2HEX(BCDDAY); - tm->tm_wday = BCD2HEX(BCDDATE); - tm->tm_hour = BCD2HEX(BCDHOUR); - tm->tm_min = BCD2HEX(BCDMIN); - tm->tm_sec = BCD2HEX(BCDSEC); - } - - RTCCON &= ~1; - - if(tm->tm_year >= 70) - tm->tm_year += 1900; - else - tm->tm_year += 2000; - - return 0; -} - -int rtc_set (struct rtc_time* tm) -{ - if(tm->tm_year < 2000) - tm->tm_year -= 1900; - else - tm->tm_year -= 2000; - - RTCCON |= 1; - BCDYEAR = HEX2BCD(tm->tm_year); - BCDMON = HEX2BCD(tm->tm_mon); - BCDDAY = HEX2BCD(tm->tm_mday); - BCDDATE = HEX2BCD(tm->tm_wday); - BCDHOUR = HEX2BCD(tm->tm_hour); - BCDMIN = HEX2BCD(tm->tm_min); - BCDSEC = HEX2BCD(tm->tm_sec); - RTCCON &= 1; - - return 0; -} - -void rtc_reset (void) -{ - RTCCON |= 1; - BCDYEAR = 0; - BCDMON = 0; - BCDDAY = 0; - BCDDATE = 0; - BCDHOUR = 0; - BCDMIN = 0; - BCDSEC = 0; - RTCCON &= 1; -} - - -/* - I2C stuff -*/ - -/* - * Initialization, must be called once on start up, may be called - * repeatedly to change the speed and slave addresses. - */ -void i2c_init(int speed, int slaveaddr) -{ - /* - setting up I2C support - */ - unsigned int save_F,save_PF,rIICCON,rPCONA,rPDATA,rPCONF,rPUPF; - - save_F = PCONF; - save_PF = PUPF; - - rPCONF = ((save_F & ~(0xF))| 0xa); - rPUPF = (save_PF | 0x3); - PCONF = rPCONF; /*PF0:IICSCL, PF1:IICSDA*/ - PUPF = rPUPF; /* Disable pull-up */ - - /* Configuring pin for WC pin of EEprom */ - rPCONA = PCONA; - rPCONA &= ~(1<<9); - PCONA = rPCONA; - - rPDATA = PDATA; - rPDATA &= ~(1<<9); - PDATA = rPDATA; - - /* - Enable ACK, IICCLK=MCLK/16, enable interrupt - 75MHz/16/(12+1) = 390625 Hz - */ - rIICCON=(1<<7)|(0<<6)|(1<<5)|(0xC); - IICCON = rIICCON; - - IICADD = slaveaddr; -} - -/* - * Probe the given I2C chip address. Returns 0 if a chip responded, - * not 0 on failure. - */ -int i2c_probe(uchar chip) -{ - /* - not implemented - */ - - printf("i2c_probe chip %d\n", (int) chip); - return -1; -} - -/* - * Read/Write interface: - * chip: I2C chip address, range 0..127 - * addr: Memory (register) address within the chip - * alen: Number of bytes to use for addr (typically 1, 2 for larger - * memories, 0 for register type devices with only one - * register) - * buffer: Where to read/write the data - * len: How many bytes to read/write - * - * Returns: 0 on success, not 0 on failure - */ - -#define S3C44B0X_rIIC_INTPEND (1<<4) -#define S3C44B0X_rIIC_LAST_RECEIV_BIT (1<<0) -#define S3C44B0X_rIIC_INTERRUPT_ENABLE (1<<5) -#define S3C44B0_IIC_TIMEOUT 100 - -int i2c_read(uchar chip, uint addr, int alen, uchar *buffer, int len) -{ - - int k, j, temp; - u32 rIICSTAT; - - /* - send the device offset - */ - - rIICSTAT = 0xD0; - IICSTAT = rIICSTAT; - - IICDS = chip; /* this is a write operation... */ - - rIICSTAT |= (1<<5); - IICSTAT = rIICSTAT; - - for(k=0; k<S3C44B0_IIC_TIMEOUT; k++) { - temp = IICCON; - if( (temp & S3C44B0X_rIIC_INTPEND) == S3C44B0X_rIIC_INTPEND) - break; - udelay(2000); - } - if (k==S3C44B0_IIC_TIMEOUT) - return -1; - - /* wait and check ACK */ - temp = IICSTAT; - if ((temp & S3C44B0X_rIIC_LAST_RECEIV_BIT) == S3C44B0X_rIIC_LAST_RECEIV_BIT ) - return -1; - - IICDS = addr; - IICCON = IICCON & ~(S3C44B0X_rIIC_INTPEND); - - /* wait and check ACK */ - for(k=0; k<S3C44B0_IIC_TIMEOUT; k++) { - temp = IICCON; - if( (temp & S3C44B0X_rIIC_INTPEND) == S3C44B0X_rIIC_INTPEND) - break; - udelay(2000); - } - if (k==S3C44B0_IIC_TIMEOUT) - return -1; - - temp = IICSTAT; - if ((temp & S3C44B0X_rIIC_LAST_RECEIV_BIT) == S3C44B0X_rIIC_LAST_RECEIV_BIT ) - return -1; - - /* - now we can start with the read operation... - */ - - IICDS = chip | 0x01; /* this is a read operation... */ - - rIICSTAT = 0x90; /*master recv*/ - rIICSTAT |= (1<<5); - IICSTAT = rIICSTAT; - - IICCON = IICCON & ~(S3C44B0X_rIIC_INTPEND); - - /* wait and check ACK */ - for(k=0; k<S3C44B0_IIC_TIMEOUT; k++) { - temp = IICCON; - if( (temp & S3C44B0X_rIIC_INTPEND) == S3C44B0X_rIIC_INTPEND) - break; - udelay(2000); - } - if (k==S3C44B0_IIC_TIMEOUT) - return -1; - - temp = IICSTAT; - if ((temp & S3C44B0X_rIIC_LAST_RECEIV_BIT) == S3C44B0X_rIIC_LAST_RECEIV_BIT ) - return -1; - - for (j=0; j<len-1; j++) { - - /*clear pending bit to resume */ - - temp = IICCON & ~(S3C44B0X_rIIC_INTPEND); - IICCON = temp; - - /* wait and check ACK */ - for(k=0; k<S3C44B0_IIC_TIMEOUT; k++) { - temp = IICCON; - if( (temp & S3C44B0X_rIIC_INTPEND) == S3C44B0X_rIIC_INTPEND) - break; - udelay(2000); - } - if (k==S3C44B0_IIC_TIMEOUT) - return -1; - - - buffer[j] = IICDS; /*save readed data*/ - - } /*end for(j)*/ - - /* - reading the last data - unset ACK generation - */ - temp = IICCON & ~(S3C44B0X_rIIC_INTPEND | (1<<7)); - IICCON = temp; - - /* wait but NOT check ACK */ - for(k=0; k<S3C44B0_IIC_TIMEOUT; k++) { - temp = IICCON; - if( (temp & S3C44B0X_rIIC_INTPEND) == S3C44B0X_rIIC_INTPEND) - break; - udelay(2000); - } - if (k==S3C44B0_IIC_TIMEOUT) - return -1; - - buffer[j] = IICDS; /*save readed data*/ - - rIICSTAT = 0x90; /*master recv*/ - - /* Write operation Terminate sending STOP */ - IICSTAT = rIICSTAT; - /*Clear Int Pending Bit to RESUME*/ - temp = IICCON; - IICCON = temp & (~S3C44B0X_rIIC_INTPEND); - - IICCON = IICCON | (1<<7); /*restore ACK generation*/ - - return 0; -} - -int i2c_write(uchar chip, uint addr, int alen, uchar *buffer, int len) -{ - int j, k; - u32 rIICSTAT, temp; - - - /* - send the device offset - */ - - rIICSTAT = 0xD0; - IICSTAT = rIICSTAT; - - IICDS = chip; /* this is a write operation... */ - - rIICSTAT |= (1<<5); - IICSTAT = rIICSTAT; - - IICCON = IICCON & ~(S3C44B0X_rIIC_INTPEND); - - /* wait and check ACK */ - for(k=0; k<S3C44B0_IIC_TIMEOUT; k++) { - temp = IICCON; - if( (temp & S3C44B0X_rIIC_INTPEND) == S3C44B0X_rIIC_INTPEND) - break; - udelay(2000); - } - if (k==S3C44B0_IIC_TIMEOUT) - return -1; - - temp = IICSTAT; - if ((temp & S3C44B0X_rIIC_LAST_RECEIV_BIT) == S3C44B0X_rIIC_LAST_RECEIV_BIT ) - return -1; - - IICDS = addr; - IICCON = IICCON & ~(S3C44B0X_rIIC_INTPEND); - - /* wait and check ACK */ - for(k=0; k<S3C44B0_IIC_TIMEOUT; k++) { - temp = IICCON; - if( (temp & S3C44B0X_rIIC_INTPEND) == S3C44B0X_rIIC_INTPEND) - break; - udelay(2000); - } - if (k==S3C44B0_IIC_TIMEOUT) - return -1; - - temp = IICSTAT; - if ((temp & S3C44B0X_rIIC_LAST_RECEIV_BIT) == S3C44B0X_rIIC_LAST_RECEIV_BIT ) - return -1; - - /* - now we can start with the read write operation - */ - for (j=0; j<len; j++) { - - IICDS = buffer[j]; /*prerare data to write*/ - - /*clear pending bit to resume*/ - - temp = IICCON & ~(S3C44B0X_rIIC_INTPEND); - IICCON = temp; - - /* wait but NOT check ACK */ - for(k=0; k<S3C44B0_IIC_TIMEOUT; k++) { - temp = IICCON; - if( (temp & S3C44B0X_rIIC_INTPEND) == S3C44B0X_rIIC_INTPEND) - break; - - udelay(2000); - } - - if (k==S3C44B0_IIC_TIMEOUT) - return -1; - - } /* end for(j) */ - - /* sending stop to terminate */ - rIICSTAT = 0xD0; /*master send*/ - IICSTAT = rIICSTAT; - /*Clear Int Pending Bit to RESUME*/ - temp = IICCON; - IICCON = temp & (~S3C44B0X_rIIC_INTPEND); - - return 0; -} +/* + * (C) Copyright 2004 + * DAVE Srl + * http://www.dave-tech.it + * http://www.wawnet.biz + * mailto:info@wawnet.biz + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* + * S3C44B0 CPU specific code + */ + +#include <common.h> +#include <command.h> +#include <asm/hardware.h> + +static void s3c44b0_flush_cache(void) +{ + volatile int i; + /* flush cycle */ + for(i=0x10002000;i<0x10004800;i+=16) + { + *((int *)i)=0x0; + } +} + + +int cpu_init (void) +{ + icache_enable(); + + return 0; +} + +int cleanup_before_linux (void) +{ + /* + cache memory should be enabled before calling + Linux to make the kernel uncompression faster + */ + icache_enable(); + + disable_interrupts (); + + return 0; +} + +void reset_cpu (ulong addr) +{ + /* + reset the cpu using watchdog + */ + + /* Disable the watchdog.*/ + WTCON&=~(1<<5); + + /* set the timeout value to a short time... */ + WTCNT = 0x1; + + /* Enable the watchdog. */ + WTCON|=1; + WTCON|=(1<<5); + + while(1) { + /*NOP*/ + } +} + +int do_reset (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +{ + disable_interrupts (); + reset_cpu (0); + + /*NOTREACHED*/ + return (0); +} + +void icache_enable (void) +{ + ulong reg; + + s3c44b0_flush_cache(); + + /* + Init cache + Non-cacheable area (everything outside RAM) + 0x0000:0000 - 0x0C00:0000 + */ + NCACHBE0 = 0xC0000000; + NCACHBE1 = 0x00000000; + + /* + Enable chache + */ + reg = SYSCFG; + reg |= 0x00000006; /* 8kB */ + SYSCFG = reg; +} + +void icache_disable (void) +{ + ulong reg; + + reg = SYSCFG; + reg &= ~0x00000006; /* 8kB */ + SYSCFG = reg; +} + +int icache_status (void) +{ + return 0; +} + +void dcache_enable (void) +{ + icache_enable(); +} + +void dcache_disable (void) +{ + icache_disable(); +} + +int dcache_status (void) +{ + return dcache_status(); +} + +/* + RTC stuff +*/ +#include <rtc.h> +#ifndef BCD2HEX + #define BCD2HEX(n) ((n>>4)*10+(n&0x0f)) +#endif +#ifndef HEX2BCD + #define HEX2BCD(x) ((((x) / 10) << 4) + (x) % 10) +#endif + +int rtc_get (struct rtc_time* tm) +{ + RTCCON |= 1; + tm->tm_year = BCD2HEX(BCDYEAR); + tm->tm_mon = BCD2HEX(BCDMON); + tm->tm_wday = BCD2HEX(BCDDATE); + tm->tm_mday = BCD2HEX(BCDDAY); + tm->tm_hour = BCD2HEX(BCDHOUR); + tm->tm_min = BCD2HEX(BCDMIN); + tm->tm_sec = BCD2HEX(BCDSEC); + + if (tm->tm_sec==0) { + /* we have to re-read the rtc data because of the "one second deviation" problem */ + /* see RTC datasheet for more info about it */ + tm->tm_year = BCD2HEX(BCDYEAR); + tm->tm_mon = BCD2HEX(BCDMON); + tm->tm_mday = BCD2HEX(BCDDAY); + tm->tm_wday = BCD2HEX(BCDDATE); + tm->tm_hour = BCD2HEX(BCDHOUR); + tm->tm_min = BCD2HEX(BCDMIN); + tm->tm_sec = BCD2HEX(BCDSEC); + } + + RTCCON &= ~1; + + if(tm->tm_year >= 70) + tm->tm_year += 1900; + else + tm->tm_year += 2000; + + return 0; +} + +int rtc_set (struct rtc_time* tm) +{ + if(tm->tm_year < 2000) + tm->tm_year -= 1900; + else + tm->tm_year -= 2000; + + RTCCON |= 1; + BCDYEAR = HEX2BCD(tm->tm_year); + BCDMON = HEX2BCD(tm->tm_mon); + BCDDAY = HEX2BCD(tm->tm_mday); + BCDDATE = HEX2BCD(tm->tm_wday); + BCDHOUR = HEX2BCD(tm->tm_hour); + BCDMIN = HEX2BCD(tm->tm_min); + BCDSEC = HEX2BCD(tm->tm_sec); + RTCCON &= 1; + + return 0; +} + +void rtc_reset (void) +{ + RTCCON |= 1; + BCDYEAR = 0; + BCDMON = 0; + BCDDAY = 0; + BCDDATE = 0; + BCDHOUR = 0; + BCDMIN = 0; + BCDSEC = 0; + RTCCON &= 1; +} diff --git a/drivers/i2c/Makefile b/drivers/i2c/Makefile index 9c74657..69cf9a6 100644 --- a/drivers/i2c/Makefile +++ b/drivers/i2c/Makefile @@ -31,6 +31,7 @@ COBJS-$(CONFIG_I2C_MXC) += mxc_i2c.o COBJS-$(CONFIG_DRIVER_OMAP1510_I2C) += omap1510_i2c.o COBJS-$(CONFIG_DRIVER_OMAP24XX_I2C) += omap24xx_i2c.o COBJS-$(CONFIG_DRIVER_OMAP34XX_I2C) += omap24xx_i2c.o +COBJS-$(CONFIG_S3C44B0_I2C) += s3c44b0_i2c.o COBJS-$(CONFIG_SOFT_I2C) += soft_i2c.o COBJS-$(CONFIG_TSI108_I2C) += tsi108_i2c.o
diff --git a/cpu/s3c44b0/cpu.c b/drivers/i2c/s3c44b0_i2c.c similarity index 70% rename from cpu/s3c44b0/cpu.c rename to drivers/i2c/s3c44b0_i2c.c index 2960f2f..b4d904b 100644 --- a/cpu/s3c44b0/cpu.c +++ b/drivers/i2c/s3c44b0_i2c.c @@ -24,208 +24,10 @@ * MA 02111-1307 USA */
-/* - * S3C44B0 CPU specific code - */ - #include <common.h> #include <command.h> #include <asm/hardware.h>
-static void s3c44b0_flush_cache(void) -{ - volatile int i; - /* flush cycle */ - for(i=0x10002000;i<0x10004800;i+=16) - { - *((int *)i)=0x0; - } -} - - -int cpu_init (void) -{ - icache_enable(); - - return 0; -} - -int cleanup_before_linux (void) -{ - /* - cache memory should be enabled before calling - Linux to make the kernel uncompression faster - */ - icache_enable(); - - disable_interrupts (); - - return 0; -} - -void reset_cpu (ulong addr) -{ - /* - reset the cpu using watchdog - */ - - /* Disable the watchdog.*/ - WTCON&=~(1<<5); - - /* set the timeout value to a short time... */ - WTCNT = 0x1; - - /* Enable the watchdog. */ - WTCON|=1; - WTCON|=(1<<5); - - while(1) { - /*NOP*/ - } -} - -int do_reset (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) -{ - disable_interrupts (); - reset_cpu (0); - - /*NOTREACHED*/ - return (0); -} - -void icache_enable (void) -{ - ulong reg; - - s3c44b0_flush_cache(); - - /* - Init cache - Non-cacheable area (everything outside RAM) - 0x0000:0000 - 0x0C00:0000 - */ - NCACHBE0 = 0xC0000000; - NCACHBE1 = 0x00000000; - - /* - Enable chache - */ - reg = SYSCFG; - reg |= 0x00000006; /* 8kB */ - SYSCFG = reg; -} - -void icache_disable (void) -{ - ulong reg; - - reg = SYSCFG; - reg &= ~0x00000006; /* 8kB */ - SYSCFG = reg; -} - -int icache_status (void) -{ - return 0; -} - -void dcache_enable (void) -{ - icache_enable(); -} - -void dcache_disable (void) -{ - icache_disable(); -} - -int dcache_status (void) -{ - return dcache_status(); -} - -/* - RTC stuff -*/ -#include <rtc.h> -#ifndef BCD2HEX - #define BCD2HEX(n) ((n>>4)*10+(n&0x0f)) -#endif -#ifndef HEX2BCD - #define HEX2BCD(x) ((((x) / 10) << 4) + (x) % 10) -#endif - -int rtc_get (struct rtc_time* tm) -{ - RTCCON |= 1; - tm->tm_year = BCD2HEX(BCDYEAR); - tm->tm_mon = BCD2HEX(BCDMON); - tm->tm_wday = BCD2HEX(BCDDATE); - tm->tm_mday = BCD2HEX(BCDDAY); - tm->tm_hour = BCD2HEX(BCDHOUR); - tm->tm_min = BCD2HEX(BCDMIN); - tm->tm_sec = BCD2HEX(BCDSEC); - - if (tm->tm_sec==0) { - /* we have to re-read the rtc data because of the "one second deviation" problem */ - /* see RTC datasheet for more info about it */ - tm->tm_year = BCD2HEX(BCDYEAR); - tm->tm_mon = BCD2HEX(BCDMON); - tm->tm_mday = BCD2HEX(BCDDAY); - tm->tm_wday = BCD2HEX(BCDDATE); - tm->tm_hour = BCD2HEX(BCDHOUR); - tm->tm_min = BCD2HEX(BCDMIN); - tm->tm_sec = BCD2HEX(BCDSEC); - } - - RTCCON &= ~1; - - if(tm->tm_year >= 70) - tm->tm_year += 1900; - else - tm->tm_year += 2000; - - return 0; -} - -int rtc_set (struct rtc_time* tm) -{ - if(tm->tm_year < 2000) - tm->tm_year -= 1900; - else - tm->tm_year -= 2000; - - RTCCON |= 1; - BCDYEAR = HEX2BCD(tm->tm_year); - BCDMON = HEX2BCD(tm->tm_mon); - BCDDAY = HEX2BCD(tm->tm_mday); - BCDDATE = HEX2BCD(tm->tm_wday); - BCDHOUR = HEX2BCD(tm->tm_hour); - BCDMIN = HEX2BCD(tm->tm_min); - BCDSEC = HEX2BCD(tm->tm_sec); - RTCCON &= 1; - - return 0; -} - -void rtc_reset (void) -{ - RTCCON |= 1; - BCDYEAR = 0; - BCDMON = 0; - BCDDAY = 0; - BCDDATE = 0; - BCDHOUR = 0; - BCDMIN = 0; - BCDSEC = 0; - RTCCON &= 1; -} - - -/* - I2C stuff -*/ - /* * Initialization, must be called once on start up, may be called * repeatedly to change the speed and slave addresses. diff --git a/include/configs/B2.h b/include/configs/B2.h index 340b847..d9f6e14 100644 --- a/include/configs/B2.h +++ b/include/configs/B2.h @@ -67,6 +67,8 @@ */ #define CONFIG_SERIAL1 1 /* we use Serial line 1 */
+#define CONFIG_S3C44B0_I2C + /* allow to overwrite serial and ethaddr */ #define CONFIG_ENV_OVERWRITE
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com --- cpu/s3c44b0/cpu.c | 77 ---------------------------------- drivers/rtc/Makefile | 1 + drivers/rtc/s3c44b0_rtc.c | 102 +++++++++++++++++++++++++++++++++++++++++++++ include/configs/B2.h | 1 + 4 files changed, 104 insertions(+), 77 deletions(-) create mode 100644 drivers/rtc/s3c44b0_rtc.c
diff --git a/cpu/s3c44b0/cpu.c b/cpu/s3c44b0/cpu.c index 0c44691..752191d 100644 --- a/cpu/s3c44b0/cpu.c +++ b/cpu/s3c44b0/cpu.c @@ -143,80 +143,3 @@ int dcache_status (void) { return dcache_status(); } - -/* - RTC stuff -*/ -#include <rtc.h> -#ifndef BCD2HEX - #define BCD2HEX(n) ((n>>4)*10+(n&0x0f)) -#endif -#ifndef HEX2BCD - #define HEX2BCD(x) ((((x) / 10) << 4) + (x) % 10) -#endif - -int rtc_get (struct rtc_time* tm) -{ - RTCCON |= 1; - tm->tm_year = BCD2HEX(BCDYEAR); - tm->tm_mon = BCD2HEX(BCDMON); - tm->tm_wday = BCD2HEX(BCDDATE); - tm->tm_mday = BCD2HEX(BCDDAY); - tm->tm_hour = BCD2HEX(BCDHOUR); - tm->tm_min = BCD2HEX(BCDMIN); - tm->tm_sec = BCD2HEX(BCDSEC); - - if (tm->tm_sec==0) { - /* we have to re-read the rtc data because of the "one second deviation" problem */ - /* see RTC datasheet for more info about it */ - tm->tm_year = BCD2HEX(BCDYEAR); - tm->tm_mon = BCD2HEX(BCDMON); - tm->tm_mday = BCD2HEX(BCDDAY); - tm->tm_wday = BCD2HEX(BCDDATE); - tm->tm_hour = BCD2HEX(BCDHOUR); - tm->tm_min = BCD2HEX(BCDMIN); - tm->tm_sec = BCD2HEX(BCDSEC); - } - - RTCCON &= ~1; - - if(tm->tm_year >= 70) - tm->tm_year += 1900; - else - tm->tm_year += 2000; - - return 0; -} - -int rtc_set (struct rtc_time* tm) -{ - if(tm->tm_year < 2000) - tm->tm_year -= 1900; - else - tm->tm_year -= 2000; - - RTCCON |= 1; - BCDYEAR = HEX2BCD(tm->tm_year); - BCDMON = HEX2BCD(tm->tm_mon); - BCDDAY = HEX2BCD(tm->tm_mday); - BCDDATE = HEX2BCD(tm->tm_wday); - BCDHOUR = HEX2BCD(tm->tm_hour); - BCDMIN = HEX2BCD(tm->tm_min); - BCDSEC = HEX2BCD(tm->tm_sec); - RTCCON &= 1; - - return 0; -} - -void rtc_reset (void) -{ - RTCCON |= 1; - BCDYEAR = 0; - BCDMON = 0; - BCDDAY = 0; - BCDDATE = 0; - BCDHOUR = 0; - BCDMIN = 0; - BCDSEC = 0; - RTCCON &= 1; -} diff --git a/drivers/rtc/Makefile b/drivers/rtc/Makefile index 94bc518..3831dd9 100644 --- a/drivers/rtc/Makefile +++ b/drivers/rtc/Makefile @@ -57,6 +57,7 @@ COBJS-$(CONFIG_RTC_PL031) += pl031.o COBJS-$(CONFIG_RTC_RS5C372A) += rs5c372.o COBJS-$(CONFIG_RTC_RX8025) += rx8025.o COBJS-$(CONFIG_RTC_S3C24X0) += s3c24x0_rtc.o +COBJS-$(CONFIG_RTC_S3C44B0) += s3c44b0_rtc.o COBJS-$(CONFIG_RTC_X1205) += x1205.o
COBJS := $(sort $(COBJS-y)) diff --git a/drivers/rtc/s3c44b0_rtc.c b/drivers/rtc/s3c44b0_rtc.c new file mode 100644 index 0000000..489536f --- /dev/null +++ b/drivers/rtc/s3c44b0_rtc.c @@ -0,0 +1,102 @@ +/* + * (C) Copyright 2004 + * DAVE Srl + * http://www.dave-tech.it + * http://www.wawnet.biz + * mailto:info@wawnet.biz + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* + * S3C44B0 CPU specific code + */ + +#include <common.h> +#include <command.h> +#include <asm/hardware.h> +#include <rtc.h> +#include <bcd.h> + +int rtc_get (struct rtc_time* tm) +{ + RTCCON |= 1; + tm->tm_year = BCD2BIN(BCDYEAR); + tm->tm_mon = BCD2BIN(BCDMON); + tm->tm_wday = BCD2BIN(BCDDATE); + tm->tm_mday = BCD2BIN(BCDDAY); + tm->tm_hour = BCD2BIN(BCDHOUR); + tm->tm_min = BCD2BIN(BCDMIN); + tm->tm_sec = BCD2BIN(BCDSEC); + + if (tm->tm_sec==0) { + /* we have to re-read the rtc data because of the "one second deviation" problem */ + /* see RTC datasheet for more info about it */ + tm->tm_year = BCD2BIN(BCDYEAR); + tm->tm_mon = BCD2BIN(BCDMON); + tm->tm_mday = BCD2BIN(BCDDAY); + tm->tm_wday = BCD2BIN(BCDDATE); + tm->tm_hour = BCD2BIN(BCDHOUR); + tm->tm_min = BCD2BIN(BCDMIN); + tm->tm_sec = BCD2BIN(BCDSEC); + } + + RTCCON &= ~1; + + if(tm->tm_year >= 70) + tm->tm_year += 1900; + else + tm->tm_year += 2000; + + return 0; +} + +int rtc_set (struct rtc_time* tm) +{ + if(tm->tm_year < 2000) + tm->tm_year -= 1900; + else + tm->tm_year -= 2000; + + RTCCON |= 1; + BCDYEAR = BIN2BCD(tm->tm_year); + BCDMON = BIN2BCD(tm->tm_mon); + BCDDAY = BIN2BCD(tm->tm_mday); + BCDDATE = BIN2BCD(tm->tm_wday); + BCDHOUR = BIN2BCD(tm->tm_hour); + BCDMIN = BIN2BCD(tm->tm_min); + BCDSEC = BIN2BCD(tm->tm_sec); + RTCCON &= 1; + + return 0; +} + +void rtc_reset (void) +{ + RTCCON |= 1; + BCDYEAR = 0; + BCDMON = 0; + BCDDAY = 0; + BCDDATE = 0; + BCDHOUR = 0; + BCDMIN = 0; + BCDSEC = 0; + RTCCON &= 1; +} + diff --git a/include/configs/B2.h b/include/configs/B2.h index d9f6e14..9340db6 100644 --- a/include/configs/B2.h +++ b/include/configs/B2.h @@ -68,6 +68,7 @@ #define CONFIG_SERIAL1 1 /* we use Serial line 1 */
#define CONFIG_S3C44B0_I2C +#define CONFIG_RTC_S3C44B0
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com --- cpu/s3c44b0/Makefile | 2 +- drivers/serial/Makefile | 1 + .../serial.c => drivers/serial/serial_s3c44b0.c | 0 include/configs/B2.h | 1 + 4 files changed, 3 insertions(+), 1 deletions(-) rename cpu/s3c44b0/serial.c => drivers/serial/serial_s3c44b0.c (100%)
diff --git a/cpu/s3c44b0/Makefile b/cpu/s3c44b0/Makefile index 790faeb..fd696f7 100644 --- a/cpu/s3c44b0/Makefile +++ b/cpu/s3c44b0/Makefile @@ -26,7 +26,7 @@ include $(TOPDIR)/config.mk LIB = $(obj)lib$(CPU).a
START = start.o -COBJS = serial.o interrupts.o cpu.o +COBJS = interrupts.o cpu.o
SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) diff --git a/drivers/serial/Makefile b/drivers/serial/Makefile index d0efd73..37cc5a0 100644 --- a/drivers/serial/Makefile +++ b/drivers/serial/Makefile @@ -37,6 +37,7 @@ COBJS-$(CONFIG_IXP_SERIAL) += serial_ixp.o COBJS-$(CONFIG_MAX3100_SERIAL) += serial_max3100.o COBJS-$(CONFIG_PL010_SERIAL) += serial_pl01x.o COBJS-$(CONFIG_PL011_SERIAL) += serial_pl01x.o +COBJS-$(CONFIG_S3C44B0_SERIAL) += serial_s3c44b0.o COBJS-$(CONFIG_XILINX_UARTLITE) += serial_xuartlite.o COBJS-$(CONFIG_SCIF_CONSOLE) += serial_sh.o COBJS-$(CONFIG_USB_TTY) += usbtty.o diff --git a/cpu/s3c44b0/serial.c b/drivers/serial/serial_s3c44b0.c similarity index 100% rename from cpu/s3c44b0/serial.c rename to drivers/serial/serial_s3c44b0.c diff --git a/include/configs/B2.h b/include/configs/B2.h index 9340db6..01b65c5 100644 --- a/include/configs/B2.h +++ b/include/configs/B2.h @@ -65,6 +65,7 @@ /* * select serial console configuration */ +#define CONFIG_S3C44B0_SERIAL #define CONFIG_SERIAL1 1 /* we use Serial line 1 */
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com --- cpu/s3c44b0/Makefile | 2 +- cpu/s3c44b0/{cpu.c => cache.c} | 56 +----------------------------------- cpu/s3c44b0/cpu.c | 62 ---------------------------------------- 3 files changed, 2 insertions(+), 118 deletions(-) copy cpu/s3c44b0/{cpu.c => cache.c} (71%)
diff --git a/cpu/s3c44b0/Makefile b/cpu/s3c44b0/Makefile index fd696f7..ae909a6 100644 --- a/cpu/s3c44b0/Makefile +++ b/cpu/s3c44b0/Makefile @@ -26,7 +26,7 @@ include $(TOPDIR)/config.mk LIB = $(obj)lib$(CPU).a
START = start.o -COBJS = interrupts.o cpu.o +COBJS = cache.o cpu.o interrupts.o
SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) diff --git a/cpu/s3c44b0/cpu.c b/cpu/s3c44b0/cache.c similarity index 71% copy from cpu/s3c44b0/cpu.c copy to cpu/s3c44b0/cache.c index 752191d..bc10171 100644 --- a/cpu/s3c44b0/cpu.c +++ b/cpu/s3c44b0/cache.c @@ -24,10 +24,6 @@ * MA 02111-1307 USA */
-/* - * S3C44B0 CPU specific code - */ - #include <common.h> #include <command.h> #include <asm/hardware.h> @@ -42,57 +38,6 @@ static void s3c44b0_flush_cache(void) } }
- -int cpu_init (void) -{ - icache_enable(); - - return 0; -} - -int cleanup_before_linux (void) -{ - /* - cache memory should be enabled before calling - Linux to make the kernel uncompression faster - */ - icache_enable(); - - disable_interrupts (); - - return 0; -} - -void reset_cpu (ulong addr) -{ - /* - reset the cpu using watchdog - */ - - /* Disable the watchdog.*/ - WTCON&=~(1<<5); - - /* set the timeout value to a short time... */ - WTCNT = 0x1; - - /* Enable the watchdog. */ - WTCON|=1; - WTCON|=(1<<5); - - while(1) { - /*NOP*/ - } -} - -int do_reset (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) -{ - disable_interrupts (); - reset_cpu (0); - - /*NOTREACHED*/ - return (0); -} - void icache_enable (void) { ulong reg; @@ -143,3 +88,4 @@ int dcache_status (void) { return dcache_status(); } + diff --git a/cpu/s3c44b0/cpu.c b/cpu/s3c44b0/cpu.c index 752191d..e4cdb82 100644 --- a/cpu/s3c44b0/cpu.c +++ b/cpu/s3c44b0/cpu.c @@ -32,17 +32,6 @@ #include <command.h> #include <asm/hardware.h>
-static void s3c44b0_flush_cache(void) -{ - volatile int i; - /* flush cycle */ - for(i=0x10002000;i<0x10004800;i+=16) - { - *((int *)i)=0x0; - } -} - - int cpu_init (void) { icache_enable(); @@ -92,54 +81,3 @@ int do_reset (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) /*NOTREACHED*/ return (0); } - -void icache_enable (void) -{ - ulong reg; - - s3c44b0_flush_cache(); - - /* - Init cache - Non-cacheable area (everything outside RAM) - 0x0000:0000 - 0x0C00:0000 - */ - NCACHBE0 = 0xC0000000; - NCACHBE1 = 0x00000000; - - /* - Enable chache - */ - reg = SYSCFG; - reg |= 0x00000006; /* 8kB */ - SYSCFG = reg; -} - -void icache_disable (void) -{ - ulong reg; - - reg = SYSCFG; - reg &= ~0x00000006; /* 8kB */ - SYSCFG = reg; -} - -int icache_status (void) -{ - return 0; -} - -void dcache_enable (void) -{ - icache_enable(); -} - -void dcache_disable (void) -{ - icache_disable(); -} - -int dcache_status (void) -{ - return dcache_status(); -}
add CONFIG_SA1100_SERIAL to activate the driver
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com --- cpu/sa1100/Makefile | 2 +- drivers/serial/Makefile | 1 + .../serial.c => drivers/serial/serial_sa1100.c | 0 include/configs/assabet.h | 1 + include/configs/dnp1110.h | 1 + include/configs/gcplus.h | 1 + include/configs/lart.h | 1 + include/configs/shannon.h | 1 + 8 files changed, 7 insertions(+), 1 deletions(-) rename cpu/sa1100/serial.c => drivers/serial/serial_sa1100.c (100%)
diff --git a/cpu/sa1100/Makefile b/cpu/sa1100/Makefile index 790faeb..fd696f7 100644 --- a/cpu/sa1100/Makefile +++ b/cpu/sa1100/Makefile @@ -26,7 +26,7 @@ include $(TOPDIR)/config.mk LIB = $(obj)lib$(CPU).a
SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) diff --git a/drivers/serial/Makefile b/drivers/serial/Makefile index 37cc5a0..8cac794 100644 --- a/drivers/serial/Makefile +++ b/drivers/serial/Makefile @@ -37,6 +37,7 @@ COBJS-$(CONFIG_IXP_SERIAL) += serial_ixp.o COBJS-$(CONFIG_MAX3100_SERIAL) += serial_max3100.o COBJS-$(CONFIG_PL010_SERIAL) += serial_pl01x.o COBJS-$(CONFIG_PL011_SERIAL) += serial_pl01x.o +COBJS-$(CONFIG_SA1100_SERIAL) += serial_sa1100.o COBJS-$(CONFIG_S3C44B0_SERIAL) += serial_s3c44b0.o COBJS-$(CONFIG_XILINX_UARTLITE) += serial_xuartlite.o COBJS-$(CONFIG_SCIF_CONSOLE) += serial_sh.o diff --git a/cpu/sa1100/serial.c b/drivers/serial/serial_sa1100.c similarity index 100% rename from cpu/sa1100/serial.c rename to drivers/serial/serial_sa1100.c diff --git a/include/configs/assabet.h b/include/configs/assabet.h index 4da68b3..a6c442b 100644 --- a/include/configs/assabet.h +++ b/include/configs/assabet.h @@ -57,6 +57,7 @@ /* * select serial console configuration */ +#define CONFIG_SA1100_SERIAL #define CONFIG_SERIAL1 1 /* we use SERIAL 1 on Intel Assabet */
/* allow to overwrite serial and ethaddr */ diff --git a/include/configs/dnp1110.h b/include/configs/dnp1110.h index 3f658a7..8f615bd 100644 --- a/include/configs/dnp1110.h +++ b/include/configs/dnp1110.h @@ -59,6 +59,7 @@ /* * select serial console configuration */ +#define CONFIG_SA1100_SERIAL #define CONFIG_SERIAL1 1 /* we use SERIAL 1 */
/* allow to overwrite serial and ethaddr */ diff --git a/include/configs/gcplus.h b/include/configs/gcplus.h index 81ee05f..77d4578 100644 --- a/include/configs/gcplus.h +++ b/include/configs/gcplus.h @@ -70,6 +70,7 @@ /* * select serial console configuration */ +#define CONFIG_SA1100_SERIAL #define CONFIG_SERIAL3 1 /* we use SERIAL 3 on ADS GCPlus */
/* allow to overwrite serial and ethaddr */ diff --git a/include/configs/lart.h b/include/configs/lart.h index 877d5c7..e34ec22 100644 --- a/include/configs/lart.h +++ b/include/configs/lart.h @@ -52,6 +52,7 @@ /* * select serial console configuration */ +#define CONFIG_SA1100_SERIAL #define CONFIG_SERIAL3 1 /* we use SERIAL 3 on LART */
/* allow to overwrite serial and ethaddr */ diff --git a/include/configs/shannon.h b/include/configs/shannon.h index 717036c..c8b0b16 100644 --- a/include/configs/shannon.h +++ b/include/configs/shannon.h @@ -59,6 +59,7 @@ /* * select serial console configuration */ +#define CONFIG_SA1100_SERIAL #define CONFIG_SERIAL3 1 /* we use SERIAL 3 */
add CONFIG_NETARM_SERIAL to activate the driver
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com --- cpu/arm720t/Makefile | 2 +- drivers/serial/Makefile | 1 + {cpu/arm720t => drivers/serial}/serial_netarm.c | 5 ----- include/configs/modnet50.h | 1 + 4 files changed, 3 insertions(+), 6 deletions(-) rename {cpu/arm720t => drivers/serial}/serial_netarm.c (99%)
diff --git a/cpu/arm720t/Makefile b/cpu/arm720t/Makefile index c97f329..a038042 100644 --- a/cpu/arm720t/Makefile +++ b/cpu/arm720t/Makefile @@ -26,7 +26,7 @@ include $(TOPDIR)/config.mk LIB = $(obj)lib$(CPU).a
START = start.o -COBJS = serial.o serial_netarm.o interrupts.o cpu.o +COBJS = serial.o interrupts.o cpu.o
SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) diff --git a/drivers/serial/Makefile b/drivers/serial/Makefile index 8cac794..e76a2ad 100644 --- a/drivers/serial/Makefile +++ b/drivers/serial/Makefile @@ -35,6 +35,7 @@ COBJS-$(CONFIG_S3C64XX) += s3c64xx.o COBJS-$(CONFIG_SYS_NS16550_SERIAL) += serial.o COBJS-$(CONFIG_IXP_SERIAL) += serial_ixp.o COBJS-$(CONFIG_MAX3100_SERIAL) += serial_max3100.o +COBJS-$(CONFIG_NETARM_SERIAL) += serial_netarm.o COBJS-$(CONFIG_PL010_SERIAL) += serial_pl01x.o COBJS-$(CONFIG_PL011_SERIAL) += serial_pl01x.o COBJS-$(CONFIG_SA1100_SERIAL) += serial_sa1100.o diff --git a/cpu/arm720t/serial_netarm.c b/drivers/serial/serial_netarm.c similarity index 99% rename from cpu/arm720t/serial_netarm.c rename to drivers/serial/serial_netarm.c index 1a1b2db..2eb5393 100644 --- a/cpu/arm720t/serial_netarm.c +++ b/drivers/serial/serial_netarm.c @@ -29,9 +29,6 @@ */
#include <common.h> - -#ifdef CONFIG_NETARM - #include <asm/hardware.h>
DECLARE_GLOBAL_DATA_PTR; @@ -196,5 +193,3 @@ void serial_puts (const char *s) serial_putc (*s++); } } - -#endif /* CONFIG_NETARM */ diff --git a/include/configs/modnet50.h b/include/configs/modnet50.h index b8ae018..74bab5f 100644 --- a/include/configs/modnet50.h +++ b/include/configs/modnet50.h @@ -56,6 +56,7 @@ /* * select serial console configuration */ +#define CONFIG_NETARM_SERIAL #define CONFIG_SERIAL1 1 /* we use Serial line 1 */
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com --- cpu/arm1136/mx31/Makefile | 2 +- drivers/serial/Makefile | 1 + .../mx31/serial.c => drivers/serial/serial_mx31.c | 6 ------ 3 files changed, 2 insertions(+), 7 deletions(-) rename cpu/arm1136/mx31/serial.c => drivers/serial/serial_mx31.c (99%)
diff --git a/cpu/arm1136/mx31/Makefile b/cpu/arm1136/mx31/Makefile index b648ffd..0e06f0a 100644 --- a/cpu/arm1136/mx31/Makefile +++ b/cpu/arm1136/mx31/Makefile @@ -25,7 +25,7 @@ include $(TOPDIR)/config.mk
-COBJS = interrupts.o serial.o generic.o +COBJS = interrupts.o generic.o
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) diff --git a/drivers/serial/Makefile b/drivers/serial/Makefile index e76a2ad..619d9da 100644 --- a/drivers/serial/Makefile +++ b/drivers/serial/Makefile @@ -35,6 +35,7 @@ COBJS-$(CONFIG_S3C64XX) += s3c64xx.o COBJS-$(CONFIG_SYS_NS16550_SERIAL) += serial.o COBJS-$(CONFIG_IXP_SERIAL) += serial_ixp.o COBJS-$(CONFIG_MAX3100_SERIAL) += serial_max3100.o +COBJS-$(CONFIG_MX31_UART) += serial_mx31.o COBJS-$(CONFIG_NETARM_SERIAL) += serial_netarm.o COBJS-$(CONFIG_PL010_SERIAL) += serial_pl01x.o COBJS-$(CONFIG_PL011_SERIAL) += serial_pl01x.o diff --git a/cpu/arm1136/mx31/serial.c b/drivers/serial/serial_mx31.c similarity index 99% rename from cpu/arm1136/mx31/serial.c rename to drivers/serial/serial_mx31.c index e025e94..7c0682a 100644 --- a/cpu/arm1136/mx31/serial.c +++ b/drivers/serial/serial_mx31.c @@ -18,9 +18,6 @@ */
#include <common.h> - -#if defined CONFIG_MX31_UART - #include <asm/arch/mx31.h>
#define __REG(x) (*((volatile u32 *)(x))) @@ -227,6 +224,3 @@ int serial_init (void)
return 0; } - - -#endif /* CONFIG_MX31 */
add CONFIG_USB_S3C64XX to activate the driver
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com --- cpu/arm1176/s3c64xx/Makefile | 1 - drivers/usb/Makefile | 1 + .../s3c64xx/usb.c => drivers/usb/s3c64xx_usb.c | 0 include/configs/smdk6400.h | 1 + 4 files changed, 2 insertions(+), 1 deletions(-) rename cpu/arm1176/s3c64xx/usb.c => drivers/usb/s3c64xx_usb.c (100%)
diff --git a/cpu/arm1176/s3c64xx/Makefile b/cpu/arm1176/s3c64xx/Makefile index 4ab1811..fa4ee3f 100644 --- a/cpu/arm1176/s3c64xx/Makefile +++ b/cpu/arm1176/s3c64xx/Makefile @@ -30,7 +30,6 @@ LIB = $(obj)lib$(SOC).a
COBJS-y = interrupts.o COBJS-$(CONFIG_S3C6400) += cpu_init.o speed.o -COBJS-$(CONFIG_USB_OHCI_NEW) += usb.o
diff --git a/drivers/usb/Makefile b/drivers/usb/Makefile index b306a65..7ddb72a 100644 --- a/drivers/usb/Makefile +++ b/drivers/usb/Makefile @@ -33,6 +33,7 @@ COBJS-$(CONFIG_USB_EHCI) += usb_ehci_core.o # host COBJS-$(CONFIG_USB_ISP116X_HCD) += isp116x-hcd.o COBJS-$(CONFIG_USB_R8A66597_HCD) += r8a66597-hcd.o +COBJS-$(CONFIG_USB_S3C64XX) += s3c64xx_usb.o COBJS-$(CONFIG_USB_SL811HS) += sl811_usb.o COBJS-$(CONFIG_USB_EHCI_FSL) += usb_ehci_fsl.o COBJS-$(CONFIG_USB_EHCI_PCI) += usb_ehci_pci.o diff --git a/cpu/arm1176/s3c64xx/usb.c b/drivers/usb/s3c64xx_usb.c similarity index 100% rename from cpu/arm1176/s3c64xx/usb.c rename to drivers/usb/s3c64xx_usb.c diff --git a/include/configs/smdk6400.h b/include/configs/smdk6400.h index 06d6a88..d3cf6e5 100644 --- a/include/configs/smdk6400.h +++ b/include/configs/smdk6400.h @@ -288,6 +288,7 @@
#if !defined(CONFIG_ENABLE_MMU) #define CONFIG_CMD_USB 1 +#define CONFIG_USB_S3C64XX #define CONFIG_USB_OHCI_NEW 1 #define CONFIG_SYS_USB_OHCI_REGS_BASE 0x74300000 #define CONFIG_SYS_USB_OHCI_SLOT_NAME "s3c6400"
add CONFIG_KS8695_SERIAL to activate the driver
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com --- cpu/arm920t/ks8695/Makefile | 2 +- drivers/serial/Makefile | 1 + .../serial.c => drivers/serial/serial_ks8695.c | 0 include/configs/cm4008.h | 1 + include/configs/cm41xx.h | 1 + 5 files changed, 4 insertions(+), 1 deletions(-) rename cpu/arm920t/ks8695/serial.c => drivers/serial/serial_ks8695.c (100%)
diff --git a/cpu/arm920t/ks8695/Makefile b/cpu/arm920t/ks8695/Makefile index 7db9473..f6b0063 100644 --- a/cpu/arm920t/ks8695/Makefile +++ b/cpu/arm920t/ks8695/Makefile @@ -25,7 +25,7 @@ include $(TOPDIR)/config.mk
-COBJS = interrupts.o serial.o +COBJS = interrupts.o SOBJS = lowlevel_init.o
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) diff --git a/drivers/serial/Makefile b/drivers/serial/Makefile index 619d9da..95255df 100644 --- a/drivers/serial/Makefile +++ b/drivers/serial/Makefile @@ -34,6 +34,7 @@ COBJS-$(CONFIG_DRIVER_S3C4510_UART) += s3c4510b_uart.o COBJS-$(CONFIG_S3C64XX) += s3c64xx.o COBJS-$(CONFIG_SYS_NS16550_SERIAL) += serial.o COBJS-$(CONFIG_IXP_SERIAL) += serial_ixp.o +COBJS-$(CONFIG_KS8695_SERIAL) += serial_ks8695.o COBJS-$(CONFIG_MAX3100_SERIAL) += serial_max3100.o COBJS-$(CONFIG_MX31_UART) += serial_mx31.o COBJS-$(CONFIG_NETARM_SERIAL) += serial_netarm.o diff --git a/cpu/arm920t/ks8695/serial.c b/drivers/serial/serial_ks8695.c similarity index 100% rename from cpu/arm920t/ks8695/serial.c rename to drivers/serial/serial_ks8695.c diff --git a/include/configs/cm4008.h b/include/configs/cm4008.h index 124fad7..7ea1a46 100644 --- a/include/configs/cm4008.h +++ b/include/configs/cm4008.h @@ -53,6 +53,7 @@ * select serial console configuration */ #define CONFIG_ENV_IS_NOWHERE +#define CONFIG_KS8695_SERIAL #define CONFIG_SERIAL1 #define CONFIG_CONS_INDEX 1 #define CONFIG_BAUDRATE 115200 diff --git a/include/configs/cm41xx.h b/include/configs/cm41xx.h index 5c255ce..ea374da 100644 --- a/include/configs/cm41xx.h +++ b/include/configs/cm41xx.h @@ -53,6 +53,7 @@ * select serial console configuration */ #define CONFIG_ENV_IS_NOWHERE +#define CONFIG_KS8695_SERIAL #define CONFIG_SERIAL1 #define CONFIG_CONS_INDEX 1 #define CONFIG_BAUDRATE 115200
add CONFIG_LPC2292_SERIAL to activate the driver
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com --- cpu/arm720t/serial.c | 77 ---------------------------- drivers/serial/Makefile | 1 + drivers/serial/serial_lpc2292.c | 105 +++++++++++++++++++++++++++++++++++++++ include/configs/SMN42.h | 1 + include/configs/lpc2292sodimm.h | 1 + 5 files changed, 108 insertions(+), 77 deletions(-) create mode 100644 drivers/serial/serial_lpc2292.c
diff --git a/cpu/arm720t/serial.c b/cpu/arm720t/serial.c index 54a9b31..b54d1cf 100644 --- a/cpu/arm720t/serial.c +++ b/cpu/arm720t/serial.c @@ -122,81 +122,4 @@ serial_puts (const char *s) serial_putc (*s++); } } - -#elif defined(CONFIG_LPC2292) - -DECLARE_GLOBAL_DATA_PTR; - -#include <asm/arch/hardware.h> - -void serial_setbrg (void) -{ - unsigned short divisor = 0; - - switch (gd->baudrate) { - case 1200: divisor = 3072; break; - case 9600: divisor = 384; break; - case 19200: divisor = 192; break; - case 38400: divisor = 96; break; - case 57600: divisor = 64; break; - case 115200: divisor = 32; break; - default: hang (); break; - } - - /* init serial UART0 */ - PUT8(U0LCR, 0); - PUT8(U0IER, 0); - PUT8(U0LCR, 0x80); /* DLAB=1 */ - PUT8(U0DLL, (unsigned char)(divisor & 0x00FF)); - PUT8(U0DLM, (unsigned char)(divisor >> 8)); - PUT8(U0LCR, 0x03); /* 8N1, DLAB=0 */ - PUT8(U0FCR, 1); /* Enable RX and TX FIFOs */ -} - -int serial_init (void) -{ - unsigned long pinsel0; - - serial_setbrg (); - - pinsel0 = GET32(PINSEL0); - pinsel0 &= ~(0x00000003); - pinsel0 |= 5; - PUT32(PINSEL0, pinsel0); - - return (0); -} - -void serial_putc (const char c) -{ - if (c == '\n') - { - while((GET8(U0LSR) & (1<<5)) == 0); /* Wait for empty U0THR */ - PUT8(U0THR, '\r'); - } - - while((GET8(U0LSR) & (1<<5)) == 0); /* Wait for empty U0THR */ - PUT8(U0THR, c); -} - -int serial_getc (void) -{ - while((GET8(U0LSR) & 1) == 0); - return GET8(U0RBR); -} - -void -serial_puts (const char *s) -{ - while (*s) { - serial_putc (*s++); - } -} - -/* Test if there is a byte to read */ -int serial_tstc (void) -{ - return (GET8(U0LSR) & 1); -} - #endif diff --git a/drivers/serial/Makefile b/drivers/serial/Makefile index 95255df..eaf4f8e 100644 --- a/drivers/serial/Makefile +++ b/drivers/serial/Makefile @@ -35,6 +35,7 @@ COBJS-$(CONFIG_S3C64XX) += s3c64xx.o COBJS-$(CONFIG_SYS_NS16550_SERIAL) += serial.o COBJS-$(CONFIG_IXP_SERIAL) += serial_ixp.o COBJS-$(CONFIG_KS8695_SERIAL) += serial_ks8695.o +COBJS-$(CONFIG_LPC2292_SERIAL) += serial_lpc2292.o COBJS-$(CONFIG_MAX3100_SERIAL) += serial_max3100.o COBJS-$(CONFIG_MX31_UART) += serial_mx31.o COBJS-$(CONFIG_NETARM_SERIAL) += serial_netarm.o diff --git a/drivers/serial/serial_lpc2292.c b/drivers/serial/serial_lpc2292.c new file mode 100644 index 0000000..87b7d5f --- /dev/null +++ b/drivers/serial/serial_lpc2292.c @@ -0,0 +1,105 @@ +/* + * (C) Copyright 2002-2004 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de + * + * (C) Copyright 2002 + * Sysgo Real-Time Solutions, GmbH <www.elinos.com> + * Marius Groeger mgroeger@sysgo.de + * + * (C) Copyright 2002 + * Sysgo Real-Time Solutions, GmbH <www.elinos.com> + * Alex Zuepke azu@sysgo.de + * + * Copyright (C) 1999 2000 2001 Erik Mouw (J.A.K.Mouw@its.tudelft.nl) + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + */ + +#include <common.h> +#include <asm/arch/hardware.h> + +DECLARE_GLOBAL_DATA_PTR; + +void serial_setbrg (void) +{ + unsigned short divisor = 0; + + switch (gd->baudrate) { + case 1200: divisor = 3072; break; + case 9600: divisor = 384; break; + case 19200: divisor = 192; break; + case 38400: divisor = 96; break; + case 57600: divisor = 64; break; + case 115200: divisor = 32; break; + default: hang (); break; + } + + /* init serial UART0 */ + PUT8(U0LCR, 0); + PUT8(U0IER, 0); + PUT8(U0LCR, 0x80); /* DLAB=1 */ + PUT8(U0DLL, (unsigned char)(divisor & 0x00FF)); + PUT8(U0DLM, (unsigned char)(divisor >> 8)); + PUT8(U0LCR, 0x03); /* 8N1, DLAB=0 */ + PUT8(U0FCR, 1); /* Enable RX and TX FIFOs */ +} + +int serial_init (void) +{ + unsigned long pinsel0; + + serial_setbrg (); + + pinsel0 = GET32(PINSEL0); + pinsel0 &= ~(0x00000003); + pinsel0 |= 5; + PUT32(PINSEL0, pinsel0); + + return (0); +} + +void serial_putc (const char c) +{ + if (c == '\n') + { + while((GET8(U0LSR) & (1<<5)) == 0); /* Wait for empty U0THR */ + PUT8(U0THR, '\r'); + } + + while((GET8(U0LSR) & (1<<5)) == 0); /* Wait for empty U0THR */ + PUT8(U0THR, c); +} + +int serial_getc (void) +{ + while((GET8(U0LSR) & 1) == 0); + return GET8(U0RBR); +} + +void +serial_puts (const char *s) +{ + while (*s) { + serial_putc (*s++); + } +} + +/* Test if there is a byte to read */ +int serial_tstc (void) +{ + return (GET8(U0LSR) & 1); +} + diff --git a/include/configs/SMN42.h b/include/configs/SMN42.h index d6f41f9..05f6d9f 100644 --- a/include/configs/SMN42.h +++ b/include/configs/SMN42.h @@ -59,6 +59,7 @@ /* * select serial console configuration */ +#define CONFIG_LPC2292_SERIAL #define CONFIG_SERIAL1 1 /* we use Serial line 1 */
/* allow to overwrite serial and ethaddr */ diff --git a/include/configs/lpc2292sodimm.h b/include/configs/lpc2292sodimm.h index fa2917e..1515038 100644 --- a/include/configs/lpc2292sodimm.h +++ b/include/configs/lpc2292sodimm.h @@ -59,6 +59,7 @@ /* * select serial console configuration */ +#define CONFIG_LPC2292_SERIAL #define CONFIG_SERIAL1 1 /* we use Serial line 1 */
add CONFIG_CLPS7111_SERIAL to activate the driver
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com --- cpu/arm720t/Makefile | 2 +- drivers/serial/Makefile | 1 + .../serial.c => drivers/serial/serial_clps7111.c | 4 ---- include/configs/armadillo.h | 1 + include/configs/ep7312.h | 1 + include/configs/impa7.h | 1 + 6 files changed, 5 insertions(+), 5 deletions(-) rename cpu/arm720t/serial.c => drivers/serial/serial_clps7111.c (96%)
diff --git a/cpu/arm720t/Makefile b/cpu/arm720t/Makefile index a038042..d5ac7d3 100644 --- a/cpu/arm720t/Makefile +++ b/cpu/arm720t/Makefile @@ -26,7 +26,7 @@ include $(TOPDIR)/config.mk LIB = $(obj)lib$(CPU).a
SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) diff --git a/drivers/serial/Makefile b/drivers/serial/Makefile index eaf4f8e..6ab847f 100644 --- a/drivers/serial/Makefile +++ b/drivers/serial/Makefile @@ -33,6 +33,7 @@ COBJS-$(CONFIG_SYS_NS16550) += ns16550.o COBJS-$(CONFIG_DRIVER_S3C4510_UART) += s3c4510b_uart.o COBJS-$(CONFIG_S3C64XX) += s3c64xx.o COBJS-$(CONFIG_SYS_NS16550_SERIAL) += serial.o +COBJS-$(CONFIG_CLPS7111_SERIAL) += serial_clps7111.o COBJS-$(CONFIG_IXP_SERIAL) += serial_ixp.o COBJS-$(CONFIG_KS8695_SERIAL) += serial_ks8695.o COBJS-$(CONFIG_LPC2292_SERIAL) += serial_lpc2292.o diff --git a/cpu/arm720t/serial.c b/drivers/serial/serial_clps7111.c similarity index 96% rename from cpu/arm720t/serial.c rename to drivers/serial/serial_clps7111.c index b54d1cf..a6aecad 100644 --- a/cpu/arm720t/serial.c +++ b/drivers/serial/serial_clps7111.c @@ -29,9 +29,6 @@ */
#include <common.h> - -#if defined(CONFIG_IMPA7) || defined(CONFIG_EP7312) || defined(CONFIG_ARMADILLO) - #include <clps7111.h>
DECLARE_GLOBAL_DATA_PTR; @@ -122,4 +119,3 @@ serial_puts (const char *s) serial_putc (*s++); } } -#endif diff --git a/include/configs/armadillo.h b/include/configs/armadillo.h index ef6ce22..7ba5e17 100644 --- a/include/configs/armadillo.h +++ b/include/configs/armadillo.h @@ -64,6 +64,7 @@ /* * select serial console configuration */ +#define CONFIG_CLPS7111_SERIAL #define CONFIG_SERIAL1 1 /* we use Serial line 1 */
/* allow to overwrite serial and ethaddr */ diff --git a/include/configs/ep7312.h b/include/configs/ep7312.h index d12b13f..630fff3 100644 --- a/include/configs/ep7312.h +++ b/include/configs/ep7312.h @@ -55,6 +55,7 @@ /* * select serial console configuration */ +#define CONFIG_CLPS7111_SERIAL #define CONFIG_SERIAL1 1 /* we use Serial line 1 */
/* allow to overwrite serial and ethaddr */ diff --git a/include/configs/impa7.h b/include/configs/impa7.h index efd4214..c7001cc 100644 --- a/include/configs/impa7.h +++ b/include/configs/impa7.h @@ -54,6 +54,7 @@ /* * select serial console configuration */ +#define CONFIG_CLPS7111_SERIAL #define CONFIG_SERIAL1 1 /* we use Serial line 1 */
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com --- cpu/arm_cortexa8/omap3/interrupts.c | 128 ----------------------------------- 1 files changed, 0 insertions(+), 128 deletions(-)
diff --git a/cpu/arm_cortexa8/omap3/interrupts.c b/cpu/arm_cortexa8/omap3/interrupts.c index 9e9817d..384ffdc 100644 --- a/cpu/arm_cortexa8/omap3/interrupts.c +++ b/cpu/arm_cortexa8/omap3/interrupts.c @@ -34,137 +34,9 @@
#include <common.h> #include <asm/io.h> -#include <asm/proc-armv/ptrace.h>
#define TIMER_LOAD_VAL 0
-#ifdef CONFIG_USE_IRQ -/* enable IRQ interrupts */ -void enable_interrupts(void) -{ - unsigned long temp; - __asm__ __volatile__("mrs %0, cpsr\n" - "bic %0, %0, #0x80\n" "msr cpsr_c, %0":"=r"(temp) - ::"memory"); -} - -/* - * disable IRQ/FIQ interrupts - * returns true if interrupts had been enabled before we disabled them - */ -int disable_interrupts(void) -{ - unsigned long old, temp; - __asm__ __volatile__("mrs %0, cpsr\n" - "orr %1, %0, #0xc0\n" - "msr cpsr_c, %1":"=r"(old), "=r"(temp) - ::"memory"); - return (old & 0x80) == 0; -} -#else -void enable_interrupts(void) -{ - return; -} -int disable_interrupts(void) -{ - return 0; -} -#endif - -void bad_mode(void) -{ - panic("Resetting CPU ...\n"); - reset_cpu(0); -} - -void show_regs(struct pt_regs *regs) -{ - unsigned long flags; - const char *processor_modes[] = { - "USER_26", "FIQ_26", "IRQ_26", "SVC_26", - "UK4_26", "UK5_26", "UK6_26", "UK7_26", - "UK8_26", "UK9_26", "UK10_26", "UK11_26", - "UK12_26", "UK13_26", "UK14_26", "UK15_26", - "USER_32", "FIQ_32", "IRQ_32", "SVC_32", - "UK4_32", "UK5_32", "UK6_32", "ABT_32", - "UK8_32", "UK9_32", "UK10_32", "UND_32", - "UK12_32", "UK13_32", "UK14_32", "SYS_32", - }; - - flags = condition_codes(regs); - - printf("pc : [<%08lx>] lr : [<%08lx>]\n" - "sp : %08lx ip : %08lx fp : %08lx\n", - instruction_pointer(regs), - regs->ARM_lr, regs->ARM_sp, regs->ARM_ip, regs->ARM_fp); - printf("r10: %08lx r9 : %08lx r8 : %08lx\n", - regs->ARM_r10, regs->ARM_r9, regs->ARM_r8); - printf("r7 : %08lx r6 : %08lx r5 : %08lx r4 : %08lx\n", - regs->ARM_r7, regs->ARM_r6, regs->ARM_r5, regs->ARM_r4); - printf("r3 : %08lx r2 : %08lx r1 : %08lx r0 : %08lx\n", - regs->ARM_r3, regs->ARM_r2, regs->ARM_r1, regs->ARM_r0); - printf("Flags: %c%c%c%c", - flags & CC_N_BIT ? 'N' : 'n', - flags & CC_Z_BIT ? 'Z' : 'z', - flags & CC_C_BIT ? 'C' : 'c', flags & CC_V_BIT ? 'V' : 'v'); - printf(" IRQs %s FIQs %s Mode %s%s\n", - interrupts_enabled(regs) ? "on" : "off", - fast_interrupts_enabled(regs) ? "on" : "off", - processor_modes[processor_mode(regs)], - thumb_mode(regs) ? " (T)" : ""); -} - -void do_undefined_instruction(struct pt_regs *pt_regs) -{ - printf("undefined instruction\n"); - show_regs(pt_regs); - bad_mode(); -} - -void do_software_interrupt(struct pt_regs *pt_regs) -{ - printf("software interrupt\n"); - show_regs(pt_regs); - bad_mode(); -} - -void do_prefetch_abort(struct pt_regs *pt_regs) -{ - printf("prefetch abort\n"); - show_regs(pt_regs); - bad_mode(); -} - -void do_data_abort(struct pt_regs *pt_regs) -{ - printf("data abort\n"); - show_regs(pt_regs); - bad_mode(); -} - -void do_not_used(struct pt_regs *pt_regs) -{ - printf("not used\n"); - show_regs(pt_regs); - bad_mode(); -} - -void do_fiq(struct pt_regs *pt_regs) -{ - printf("fast interrupt request\n"); - show_regs(pt_regs); - bad_mode(); -} - -void do_irq(struct pt_regs *pt_regs) -{ - printf("interrupt request\n"); - show_regs(pt_regs); - bad_mode(); -} - - static ulong timestamp; static ulong lastinc; static gptimer_t *timer_base = (gptimer_t *)CONFIG_SYS_TIMERBASE;
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com --- cpu/arm920t/imx/Makefile | 2 +- drivers/serial/Makefile | 1 + .../imx/serial.c => drivers/serial/serial_imx.c | 6 ------ include/configs/mx1ads.h | 1 + include/configs/mx1fs2.h | 3 ++- include/configs/scb9328.h | 1 + 6 files changed, 6 insertions(+), 8 deletions(-) rename cpu/arm920t/imx/serial.c => drivers/serial/serial_imx.c (97%)
diff --git a/cpu/arm920t/imx/Makefile b/cpu/arm920t/imx/Makefile index 9207ec1..d3352de 100644 --- a/cpu/arm920t/imx/Makefile +++ b/cpu/arm920t/imx/Makefile @@ -25,7 +25,7 @@ include $(TOPDIR)/config.mk
-COBJS = generic.o interrupts.o serial.o speed.o +COBJS = generic.o interrupts.o speed.o
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) diff --git a/drivers/serial/Makefile b/drivers/serial/Makefile index 6ab847f..705ae47 100644 --- a/drivers/serial/Makefile +++ b/drivers/serial/Makefile @@ -34,6 +34,7 @@ COBJS-$(CONFIG_DRIVER_S3C4510_UART) += s3c4510b_uart.o COBJS-$(CONFIG_S3C64XX) += s3c64xx.o COBJS-$(CONFIG_SYS_NS16550_SERIAL) += serial.o COBJS-$(CONFIG_CLPS7111_SERIAL) += serial_clps7111.o +COBJS-$(CONFIG_IMX_SERIAL) += serial_imx.o COBJS-$(CONFIG_IXP_SERIAL) += serial_ixp.o COBJS-$(CONFIG_KS8695_SERIAL) += serial_ks8695.o COBJS-$(CONFIG_LPC2292_SERIAL) += serial_lpc2292.o diff --git a/cpu/arm920t/imx/serial.c b/drivers/serial/serial_imx.c similarity index 97% rename from cpu/arm920t/imx/serial.c rename to drivers/serial/serial_imx.c index 85f1167..b9ca748 100644 --- a/cpu/arm920t/imx/serial.c +++ b/drivers/serial/serial_imx.c @@ -18,12 +18,8 @@ */
#include <common.h> -#if defined (CONFIG_IMX) - #include <asm/arch/imx-regs.h>
-#ifndef CONFIG_IMX_SERIAL_NONE - #if defined CONFIG_IMX_SERIAL1 #define UART_BASE IMX_UART1_BASE #elif defined CONFIG_IMX_SERIAL2 @@ -223,5 +219,3 @@ serial_puts (const char *s) serial_putc (*s++); } } -#endif /* CONFIG_IMX_SERIAL_NONE */ -#endif /* defined CONFIG_IMX */ diff --git a/include/configs/mx1ads.h b/include/configs/mx1ads.h index c3812e6..12e567b 100644 --- a/include/configs/mx1ads.h +++ b/include/configs/mx1ads.h @@ -40,6 +40,7 @@ /* * Select serial console configuration */ +#define CONFIG_IMX_SERIAL #define CONFIG_IMX_SERIAL1 /* internal uart 1 */ /* #define _CONFIG_UART2 */ /* internal uart 2 */ /* #define CONFIG_SILENT_CONSOLE */ /* use this to disable output */ diff --git a/include/configs/mx1fs2.h b/include/configs/mx1fs2.h index b174b5f..431e669 100644 --- a/include/configs/mx1fs2.h +++ b/include/configs/mx1fs2.h @@ -289,11 +289,12 @@ 0x000b00b ->3<- -> 64MHz/4=16MHz */
#ifdef _CONFIG_UART1 +#define CONFIG_IMX_SERIAL #define CONFIG_IMX_SERIAL1 #elif defined _CONFIG_UART2 +#define CONFIG_IMX_SERIAL #define CONFIG_IMX_SERIAL2 #elif defined _CONFIG_UART3 | defined _CONFIG_UART4 -#define CONFIG_IMX_SERIAL_NONE #define CONFIG_SYS_NS16550 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_CLK 3686400 diff --git a/include/configs/scb9328.h b/include/configs/scb9328.h index 10db535..2f166c9 100644 --- a/include/configs/scb9328.h +++ b/include/configs/scb9328.h @@ -29,6 +29,7 @@ #define CONFIG_SCB9328 1 /* on a scb9328tronix board */ #undef CONFIG_USE_IRQ /* don't need use IRQ/FIQ */
+#define CONFIG_IMX_SERIAL #define CONFIG_IMX_SERIAL1 /* * Select serial console configuration
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com --- cpu/arm926ejs/davinci/Makefile | 2 +- drivers/mtd/nand/Makefile | 1 + .../nand.c => drivers/mtd/nand/davinci_nand.c | 9 --------- include/configs/davinci_dvevm.h | 1 + include/configs/davinci_schmoogie.h | 1 + include/configs/davinci_sffsdr.h | 1 + include/configs/davinci_sonata.h | 1 + 7 files changed, 6 insertions(+), 10 deletions(-) rename cpu/arm926ejs/davinci/nand.c => drivers/mtd/nand/davinci_nand.c (98%)
diff --git a/cpu/arm926ejs/davinci/Makefile b/cpu/arm926ejs/davinci/Makefile index 0f77f40..53f7742 100644 --- a/cpu/arm926ejs/davinci/Makefile +++ b/cpu/arm926ejs/davinci/Makefile @@ -27,7 +27,7 @@ include $(TOPDIR)/config.mk
-COBJS = timer.o ether.o lxt972.o dp83848.o i2c.o nand.o +COBJS = timer.o ether.o lxt972.o dp83848.o i2c.o SOBJS = lowlevel_init.o reset.o
SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) diff --git a/drivers/mtd/nand/Makefile b/drivers/mtd/nand/Makefile index 03b0028..258ee25 100644 --- a/drivers/mtd/nand/Makefile +++ b/drivers/mtd/nand/Makefile @@ -37,6 +37,7 @@ endif
COBJS-$(CONFIG_NAND_ATMEL) += atmel_nand.o COBJS-$(CONFIG_DRIVER_NAND_BFIN) += bfin_nand.o +COBJS-$(CONFIG_NAND_DAVINCI) += davinci_nand.o COBJS-$(CONFIG_NAND_FSL_ELBC) += fsl_elbc_nand.o COBJS-$(CONFIG_NAND_FSL_UPM) += fsl_upm.o COBJS-$(CONFIG_NAND_NOMADIK) += nomadik.o diff --git a/cpu/arm926ejs/davinci/nand.c b/drivers/mtd/nand/davinci_nand.c similarity index 98% rename from cpu/arm926ejs/davinci/nand.c rename to drivers/mtd/nand/davinci_nand.c index 014e2b0..a974667 100644 --- a/cpu/arm926ejs/davinci/nand.c +++ b/drivers/mtd/nand/davinci_nand.c @@ -43,10 +43,6 @@
#include <common.h> #include <asm/io.h> - -#ifdef CONFIG_SYS_USE_NAND -#if !defined(CONFIG_NAND_LEGACY) - #include <nand.h> #include <asm/arch/nand_defs.h> #include <asm/arch/emif_defs.h> @@ -468,8 +464,3 @@ int board_nand_init(struct nand_chip *nand)
return(0); } - -#else -#error "U-Boot legacy NAND support not available for DaVinci chips" -#endif -#endif /* CONFIG_SYS_USE_NAND */ diff --git a/include/configs/davinci_dvevm.h b/include/configs/davinci_dvevm.h index 667c0d8..b43beaa 100644 --- a/include/configs/davinci_dvevm.h +++ b/include/configs/davinci_dvevm.h @@ -112,6 +112,7 @@ /* Flash & Environment */ /*=====================*/ #ifdef CONFIG_SYS_USE_NAND +#define CONFIG_NAND_DAVINCI #undef CONFIG_ENV_IS_IN_FLASH #define CONFIG_SYS_NO_FLASH #define CONFIG_ENV_IS_IN_NAND /* U-Boot env in NAND Flash */ diff --git a/include/configs/davinci_schmoogie.h b/include/configs/davinci_schmoogie.h index 22d3808..2c97a00 100644 --- a/include/configs/davinci_schmoogie.h +++ b/include/configs/davinci_schmoogie.h @@ -81,6 +81,7 @@ /*=====================*/ #undef CONFIG_ENV_IS_IN_FLASH #define CONFIG_SYS_NO_FLASH +#define CONFIG_NAND_DAVINCI #define CONFIG_ENV_IS_IN_NAND /* U-Boot env in NAND Flash */ #define CONFIG_ENV_SECT_SIZE 2048 /* Env sector Size */ #define CONFIG_ENV_SIZE SZ_128K diff --git a/include/configs/davinci_sffsdr.h b/include/configs/davinci_sffsdr.h index 875bab6..9354c2f 100644 --- a/include/configs/davinci_sffsdr.h +++ b/include/configs/davinci_sffsdr.h @@ -77,6 +77,7 @@ /* Flash & Environment */ #undef CONFIG_ENV_IS_IN_FLASH #define CONFIG_SYS_NO_FLASH +#define CONFIG_NAND_DAVINCI #define CONFIG_ENV_IS_IN_NAND /* U-Boot env in NAND Flash */ #define CONFIG_ENV_SECT_SIZE 2048 /* Env sector Size */ #define CONFIG_ENV_SIZE SZ_128K diff --git a/include/configs/davinci_sonata.h b/include/configs/davinci_sonata.h index 47ab27a..0865d0d 100644 --- a/include/configs/davinci_sonata.h +++ b/include/configs/davinci_sonata.h @@ -112,6 +112,7 @@ /* Flash & Environment */ /*=====================*/ #ifdef CONFIG_SYS_USE_NAND +#define CONFIG_NAND_DAVINCI #undef CONFIG_ENV_IS_IN_FLASH #define CONFIG_SYS_NO_FLASH #define CONFIG_ENV_IS_IN_NAND /* U-Boot env in NAND Flash */
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com --- cpu/arm926ejs/davinci/Makefile | 2 +- drivers/i2c/Makefile | 1 + .../davinci/i2c.c => drivers/i2c/davinci_i2c.c | 5 ----- 3 files changed, 2 insertions(+), 6 deletions(-) rename cpu/arm926ejs/davinci/i2c.c => drivers/i2c/davinci_i2c.c (98%)
diff --git a/cpu/arm926ejs/davinci/Makefile b/cpu/arm926ejs/davinci/Makefile index 53f7742..ed24e65 100644 --- a/cpu/arm926ejs/davinci/Makefile +++ b/cpu/arm926ejs/davinci/Makefile @@ -27,7 +27,7 @@ include $(TOPDIR)/config.mk
-COBJS = timer.o ether.o lxt972.o dp83848.o i2c.o +COBJS = timer.o ether.o lxt972.o dp83848.o SOBJS = lowlevel_init.o reset.o
SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) diff --git a/drivers/i2c/Makefile b/drivers/i2c/Makefile index 69cf9a6..4b4d9db 100644 --- a/drivers/i2c/Makefile +++ b/drivers/i2c/Makefile @@ -26,6 +26,7 @@ include $(TOPDIR)/config.mk LIB := $(obj)libi2c.a
COBJS-$(CONFIG_BFIN_TWI_I2C) += bfin-twi_i2c.o +COBJS-$(CONFIG_DRIVER_DAVINCI_I2C) += davinci_i2c.o COBJS-$(CONFIG_FSL_I2C) += fsl_i2c.o COBJS-$(CONFIG_I2C_MXC) += mxc_i2c.o COBJS-$(CONFIG_DRIVER_OMAP1510_I2C) += omap1510_i2c.o diff --git a/cpu/arm926ejs/davinci/i2c.c b/drivers/i2c/davinci_i2c.c similarity index 98% rename from cpu/arm926ejs/davinci/i2c.c rename to drivers/i2c/davinci_i2c.c index 3ba20ef..eee1cbd 100644 --- a/cpu/arm926ejs/davinci/i2c.c +++ b/drivers/i2c/davinci_i2c.c @@ -25,9 +25,6 @@ */
#include <common.h> - -#ifdef CONFIG_DRIVER_DAVINCI_I2C - #include <i2c.h> #include <asm/arch/hardware.h> #include <asm/arch/i2c_defs.h> @@ -330,5 +327,3 @@ int i2c_write(u_int8_t chip, u_int32_t addr, int alen, u_int8_t *buf, int len)
return(0); } - -#endif /* CONFIG_DRIVER_DAVINCI_I2C */
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com --- cpu/arm920t/s3c24x0/Makefile | 3 +-- drivers/serial/Makefile | 1 + .../serial.c => drivers/serial/serial_s3c24x0.c | 4 ---- include/configs/VCMA9.h | 1 + include/configs/sbc2410x.h | 1 + include/configs/smdk2400.h | 1 + include/configs/smdk2410.h | 1 + include/configs/trab.h | 1 + 8 files changed, 7 insertions(+), 6 deletions(-) rename cpu/arm920t/s3c24x0/serial.c => drivers/serial/serial_s3c24x0.c (97%)
diff --git a/cpu/arm920t/s3c24x0/Makefile b/cpu/arm920t/s3c24x0/Makefile index 6764920..8fd525e 100644 --- a/cpu/arm920t/s3c24x0/Makefile +++ b/cpu/arm920t/s3c24x0/Makefile @@ -25,8 +25,7 @@ include $(TOPDIR)/config.mk
-COBJS = i2c.o interrupts.o serial.o speed.o \ - usb.o usb_ohci.o nand.o +COBJS = i2c.o interrupts.o speed.o usb.o usb_ohci.o nand.o
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) diff --git a/drivers/serial/Makefile b/drivers/serial/Makefile index 705ae47..696d5fb 100644 --- a/drivers/serial/Makefile +++ b/drivers/serial/Makefile @@ -44,6 +44,7 @@ COBJS-$(CONFIG_NETARM_SERIAL) += serial_netarm.o COBJS-$(CONFIG_PL010_SERIAL) += serial_pl01x.o COBJS-$(CONFIG_PL011_SERIAL) += serial_pl01x.o COBJS-$(CONFIG_SA1100_SERIAL) += serial_sa1100.o +COBJS-$(CONFIG_S3C24X0_SERIAL) += serial_s3c24x0.o COBJS-$(CONFIG_S3C44B0_SERIAL) += serial_s3c44b0.o COBJS-$(CONFIG_XILINX_UARTLITE) += serial_xuartlite.o COBJS-$(CONFIG_SCIF_CONSOLE) += serial_sh.o diff --git a/cpu/arm920t/s3c24x0/serial.c b/drivers/serial/serial_s3c24x0.c similarity index 97% rename from cpu/arm920t/s3c24x0/serial.c rename to drivers/serial/serial_s3c24x0.c index 064b998..1b1b7a6 100644 --- a/cpu/arm920t/s3c24x0/serial.c +++ b/drivers/serial/serial_s3c24x0.c @@ -19,8 +19,6 @@ */
#include <common.h> -#if defined(CONFIG_S3C2400) || defined (CONFIG_S3C2410) || defined (CONFIG_TRAB) - #if defined(CONFIG_S3C2400) || defined(CONFIG_TRAB) #include <s3c2400.h> #elif defined(CONFIG_S3C2410) @@ -300,5 +298,3 @@ struct serial_device s3c24xx_serial2_device = INIT_S3C_SERIAL_STRUCTURE(2, "s3ser2", "S3UART3");
#endif /* CONFIG_SERIAL_MULTI */ - -#endif /* defined(CONFIG_S3C2400) || defined (CONFIG_S3C2410) || defined (CONFIG_TRAB) */ diff --git a/include/configs/VCMA9.h b/include/configs/VCMA9.h index 8550223..5e614fd 100644 --- a/include/configs/VCMA9.h +++ b/include/configs/VCMA9.h @@ -117,6 +117,7 @@ /* * select serial console configuration */ +#define CONFIG_S3C24X0_SERIAL #define CONFIG_SERIAL1 1 /* we use SERIAL 1 on VCMA9 */
/************************************************************ diff --git a/include/configs/sbc2410x.h b/include/configs/sbc2410x.h index 102c45a..2b659e3 100644 --- a/include/configs/sbc2410x.h +++ b/include/configs/sbc2410x.h @@ -70,6 +70,7 @@ /* * select serial console configuration */ +#define CONFIG_S3C24X0_SERIAL #define CONFIG_SERIAL1 1 /* we use SERIAL 1 on SBC2410X */
/************************************************************ diff --git a/include/configs/smdk2400.h b/include/configs/smdk2400.h index 856d1fb..ffdf217 100644 --- a/include/configs/smdk2400.h +++ b/include/configs/smdk2400.h @@ -63,6 +63,7 @@ /* * select serial console configuration */ +#define CONFIG_S3C24X0_SERIAL #define CONFIG_SERIAL1 1 /* we use SERIAL 1 on SAMSUNG */
#undef CONFIG_HWFLOW /* include RTS/CTS flow control support */ diff --git a/include/configs/smdk2410.h b/include/configs/smdk2410.h index 797a596..fb43706 100644 --- a/include/configs/smdk2410.h +++ b/include/configs/smdk2410.h @@ -60,6 +60,7 @@ /* * select serial console configuration */ +#define CONFIG_S3C24X0_SERIAL #define CONFIG_SERIAL1 1 /* we use SERIAL 1 on SMDK2410 */
/************************************************************ diff --git a/include/configs/trab.h b/include/configs/trab.h index 625d8ee..520fe36 100644 --- a/include/configs/trab.h +++ b/include/configs/trab.h @@ -111,6 +111,7 @@ /* * select serial console configuration */ +#define CONFIG_S3C24X0_SERIAL #define CONFIG_SERIAL1 1 /* we use SERIAL 1 on TRAB */
#define CONFIG_HWFLOW /* include RTS/CTS flow control support */
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com --- cpu/arm920t/s3c24x0/Makefile | 2 +- drivers/i2c/Makefile | 1 + .../s3c24x0/i2c.c => drivers/i2c/s3c24x0_i2c.c | 5 ----- 3 files changed, 2 insertions(+), 6 deletions(-) rename cpu/arm920t/s3c24x0/i2c.c => drivers/i2c/s3c24x0_i2c.c (99%)
diff --git a/cpu/arm920t/s3c24x0/Makefile b/cpu/arm920t/s3c24x0/Makefile index 8fd525e..fd13e53 100644 --- a/cpu/arm920t/s3c24x0/Makefile +++ b/cpu/arm920t/s3c24x0/Makefile @@ -25,7 +25,7 @@ include $(TOPDIR)/config.mk
-COBJS = i2c.o interrupts.o speed.o usb.o usb_ohci.o nand.o +COBJS = interrupts.o speed.o usb.o usb_ohci.o nand.o
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) diff --git a/drivers/i2c/Makefile b/drivers/i2c/Makefile index 4b4d9db..ef32f13 100644 --- a/drivers/i2c/Makefile +++ b/drivers/i2c/Makefile @@ -32,6 +32,7 @@ COBJS-$(CONFIG_I2C_MXC) += mxc_i2c.o COBJS-$(CONFIG_DRIVER_OMAP1510_I2C) += omap1510_i2c.o COBJS-$(CONFIG_DRIVER_OMAP24XX_I2C) += omap24xx_i2c.o COBJS-$(CONFIG_DRIVER_OMAP34XX_I2C) += omap24xx_i2c.o +COBJS-$(CONFIG_DRIVER_S3C24X0_I2C) += s3c24x0_i2c.o COBJS-$(CONFIG_S3C44B0_I2C) += s3c44b0_i2c.o COBJS-$(CONFIG_SOFT_I2C) += soft_i2c.o COBJS-$(CONFIG_TSI108_I2C) += tsi108_i2c.o diff --git a/cpu/arm920t/s3c24x0/i2c.c b/drivers/i2c/s3c24x0_i2c.c similarity index 99% rename from cpu/arm920t/s3c24x0/i2c.c rename to drivers/i2c/s3c24x0_i2c.c index fba5cd1..f0c1aa3 100644 --- a/cpu/arm920t/s3c24x0/i2c.c +++ b/drivers/i2c/s3c24x0_i2c.c @@ -27,9 +27,6 @@ */
#include <common.h> - -#ifdef CONFIG_DRIVER_S3C24X0_I2C - #if defined(CONFIG_S3C2400) #include <s3c2400.h> #elif defined(CONFIG_S3C2410) @@ -443,5 +440,3 @@ int i2c_write (uchar chip, uint addr, int alen, uchar * buffer, int len) len) != 0); } #endif /* CONFIG_HARD_I2C */ - -#endif /* CONFIG_DRIVER_S3C24X0_I2C */
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com --- cpu/arm920t/s3c24x0/Makefile | 2 +- drivers/mtd/nand/Makefile | 1 + .../nand.c => drivers/mtd/nand/s3c2410_nand.c | 8 -------- include/configs/sbc2410x.h | 1 + 4 files changed, 3 insertions(+), 9 deletions(-) rename cpu/arm920t/s3c24x0/nand.c => drivers/mtd/nand/s3c2410_nand.c (96%)
diff --git a/cpu/arm920t/s3c24x0/Makefile b/cpu/arm920t/s3c24x0/Makefile index fd13e53..3afe19c 100644 --- a/cpu/arm920t/s3c24x0/Makefile +++ b/cpu/arm920t/s3c24x0/Makefile @@ -25,7 +25,7 @@ include $(TOPDIR)/config.mk
-COBJS = interrupts.o speed.o usb.o usb_ohci.o nand.o +COBJS = interrupts.o speed.o usb.o usb_ohci.o
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) diff --git a/drivers/mtd/nand/Makefile b/drivers/mtd/nand/Makefile index 258ee25..471cd6b 100644 --- a/drivers/mtd/nand/Makefile +++ b/drivers/mtd/nand/Makefile @@ -41,6 +41,7 @@ COBJS-$(CONFIG_NAND_DAVINCI) += davinci_nand.o COBJS-$(CONFIG_NAND_FSL_ELBC) += fsl_elbc_nand.o COBJS-$(CONFIG_NAND_FSL_UPM) += fsl_upm.o COBJS-$(CONFIG_NAND_NOMADIK) += nomadik.o +COBJS-$(CONFIG_NAND_S3C2410) += s3c2410_nand.c COBJS-$(CONFIG_NAND_S3C64XX) += s3c64xx.o COBJS-$(CONFIG_NAND_OMAP_GPMC) += omap_gpmc.o endif diff --git a/cpu/arm920t/s3c24x0/nand.c b/drivers/mtd/nand/s3c2410_nand.c similarity index 96% rename from cpu/arm920t/s3c24x0/nand.c rename to drivers/mtd/nand/s3c2410_nand.c index 60174fb..d27a625 100644 --- a/cpu/arm920t/s3c24x0/nand.c +++ b/drivers/mtd/nand/s3c2410_nand.c @@ -26,9 +26,6 @@ #define DEBUGN(x, args ...) {} #endif
-#if defined(CONFIG_CMD_NAND) -#if !defined(CONFIG_NAND_LEGACY) - #include <nand.h> #include <s3c2410.h> #include <asm/io.h> @@ -172,8 +169,3 @@ int board_nand_init(struct nand_chip *nand)
return 0; } - -#else - #error "U-Boot legacy NAND support not available for S3C2410" -#endif -#endif diff --git a/include/configs/sbc2410x.h b/include/configs/sbc2410x.h index 2b659e3..af00187 100644 --- a/include/configs/sbc2410x.h +++ b/include/configs/sbc2410x.h @@ -199,6 +199,7 @@ * NAND flash settings */ #if defined(CONFIG_CMD_NAND) +#define CONFIG_NAND_S3C2410 #define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max number of NAND devices */ #define SECTORSIZE 512
Dear Jean-Christophe,
It seems to me that this patch is a re-post of
http://lists.denx.de/pipermail/u-boot/2009-March/049736.html
If this is the case, it would be helpful if you could mark re-send patches with 'v2' or something similar, explain what changed (or what's unchanged) and that the previous patch is obsolete with the re-post.
Dirk
Btw.: A description in the body of a patch (and not subject only) going into git would be nice, too. E.g.
"Remove interrupt code which is already in xxx and therefore not needed here"
::"memory");
- disable IRQ/FIQ interrupts
- returns true if interrupts had been enabled before we disabled them
::"memory");
- return;
-} -#endif
- reset_cpu(0);
- bad_mode();
- bad_mode();
- bad_mode();
- bad_mode();
- bad_mode();
- bad_mode();
- bad_mode();
Dirk Behme
