[U-Boot] [PATCH] post, memorytest: fix if vstart is not = 0x0
Signed-off-by: Heiko Schocher hs@denx.de --- post/drivers/memory.c | 5 +++-- 1 files changed, 3 insertions(+), 2 deletions(-)
diff --git a/post/drivers/memory.c b/post/drivers/memory.c index 3f47449..b7943ef 100644 --- a/post/drivers/memory.c +++ b/post/drivers/memory.c @@ -500,9 +500,10 @@ int memory_post_test(int flags) unsigned long i; for (i = 0; i < (memsize >> 20) && ret == 0; i++) { if (ret == 0) - ret = memory_post_tests(i << 20, 0x800); + ret = memory_post_tests(vstart + + (i << 20), 0x800); if (ret == 0) - ret = memory_post_tests( + ret = memory_post_tests(vstart + (i << 20) + 0xff800, 0x800); } }
Signed-off-by: Heiko Schocher hs@denx.de --- post/drivers/memory.c | 20 ++++++++++++++++++++ 1 files changed, 20 insertions(+), 0 deletions(-)
diff --git a/post/drivers/memory.c b/post/drivers/memory.c index b7943ef..47b312d 100644 --- a/post/drivers/memory.c +++ b/post/drivers/memory.c @@ -455,10 +455,30 @@ static int memory_post_tests (unsigned long start, unsigned long size) __attribute__((weak)) int arch_memory_test_prepare(u32 *vstart, u32 *size, phys_addr_t *phys_offset) { +#if defined(CONFIG_ARM) + bd_t *bd = gd->bd; + int i; + + *size = 0; + for (i = 0; i < CONFIG_NR_DRAM_BANKS; i++) { + if (i == 0) { + *vstart = bd->bi_dram[0].start; + *size += bd->bi_dram[i].size; + } else { + if (bd->bi_dram[i].start == + (bd->bi_dram[i - 1].start + bd->bi_dram[i - 1].size)) { + *size += bd->bi_dram[i].size; + } else { + break; + } + } + } +#else bd_t *bd = gd->bd; *vstart = CONFIG_SYS_SDRAM_BASE; *size = (bd->bi_memsize >= 256 << 20 ? 256 << 20 : bd->bi_memsize) - (1 << 20); +#endif
/* Limit area to be tested with the board info struct */ if ((*vstart) + (*size) > (ulong)bd)
Dear Heiko Schocher,
This is a weak function, so there should be no need to have #ifdef's in there.
Just define your own code as you need it.
- bd_t *bd = gd->bd;
- int i;
- *size = 0;
- for (i = 0; i < CONFIG_NR_DRAM_BANKS; i++) {
if (i == 0) {
This is a constant part and should be moved out of the loop. Then you can also get rid of th if...else clause.
} else {
} else {
break;
So how do you handle non-contiguous memory banks? It appears these are quite frequent on ARM these days.
Hello Wolfgang,
Yes (I did this for my case, as I use it in nand_spl code, and therefore I need a "own" function, because there I have no bd ) ... but, for arm there is no bd->bi_memsize! ... so this file fails compiling. Independent, if it gets replaced by another function.
- int i;
- *size = 0;
if (i == 0) {
Yep, you are right! Change this.
} else {
} else {
break;
Actually, I could not handle this. Ok, I add a comment, that this function is actually only valid for contiguous mem banks.
Thanks!
bye, Heiko
so add bi_memsize to arm ? it's the only arch that lacks it. -mike
Hello Mike,
Hmm.. I thought of that too, but wouldn;t it be better to use gd->ram_size in post/drivers/memory.c, as this is defined in global_data for all archs?
bye, Heiko
Indeed. Can you do this, please?
makes me wonder why we have bd->bi_memsize in the first place.
and how can this possibly work ? arch/arm/lib/board.c: sprintf ((char *)memsz, "%ldk", (bd->bi_memsize / 1024) - pram); -mike
Hello Mike,
Yep, good question ... maybe, no arm based board has defined
"#if defined(CONFIG_PRAM) || defined(CONFIG_LOGBUFFER)"
I can make a fix and change this to gd->ram_size?
bye, Heiko
That's actually very likely. ARM systems tended to be simple and not use any such fancy features.
Please do!
This include is needed, if this memory test is used "outside" from post code, for example booting with nand_spl, and using this memory test before copying u-boot code to RAM and jumping to it.
Signed-off-by: Heiko Schocher hs@denx.de --- include/post.h | 1 + 1 files changed, 1 insertions(+), 0 deletions(-)
diff --git a/include/post.h b/include/post.h index 519cef1..cda6e76 100644 --- a/include/post.h +++ b/include/post.h @@ -187,6 +187,7 @@ extern int post_hotkeys_pressed(void); #define CONFIG_SYS_POST_CODEC 0x00200000 #define CONFIG_SYS_POST_COPROC 0x00400000
+int memory_post_test(int flags); #endif /* CONFIG_POST */
#endif /* _POST_H */
Applied, thanks.
Dear Heiko,
This got applied as commit f18714d, but obviously this patch has not been tested before as it is breaking a ton of boards:
... Configuring for NETTA_ISDN - Board: NETTA, Options: NETTA_ISDN=1 include/post.h: Assembler messages: include/post.h:190: Error: Unrecognized opcode: `int' make[2]: *** [lib_powerpc/asm.o] Error 1 make[2]: *** Waiting for unfinished jobs.... include/post.h: Assembler messages: include/post.h:190: Error: Unrecognized opcode: `int' make[2]: *** [lib_powerpc/asm.o] Error 1 make[2]: *** Waiting for unfinished jobs.... make[1]: *** [lib_powerpc/libpostpowerpc.o] Error 2 make: *** [libpost.o] Error 2 ppc_6xx-size: 'u-boot': No such file Configuring for NETTA_ISDN_6412 - Board: NETTA, Options: NETTA_ISDN=1,NETTA_6412=1 include/post.h: Assembler messages: include/post.h:190: Error: Unrecognized opcode: `int' make[2]: *** [lib_powerpc/asm.o] Error 1 make[2]: *** Waiting for unfinished jobs.... include/post.h: Assembler messages: include/post.h:190: Error: Unrecognized opcode: `int' make[2]: *** [lib_powerpc/asm.o] Error 1 make[2]: *** Waiting for unfinished jobs.... make[1]: *** [lib_powerpc/libpostpowerpc.o] Error 2 make: *** [libpost.o] Error 2 ppc_6xx-size: 'u-boot': No such file Configuring for NETTA_ISDN_6412_SWAPHOOK - Board: NETTA, Options: NETTA_ISDN=1,NETTA_6412=1,NETTA_SWAPHOOK=1 include/post.h: Assembler messages: include/post.h:190: Error: Unrecognized opcode: `int' make[2]: *** [lib_powerpc/asm.o] Error 1 make[2]: *** Waiting for unfinished jobs.... include/post.h: Assembler messages: include/post.h:190: Error: Unrecognized opcode: `int' make[2]: *** [lib_powerpc/asm.o] Error 1 make[2]: *** Waiting for unfinished jobs.... make[1]: *** [lib_powerpc/libpostpowerpc.o] Error 2 make: *** [libpost.o] Error 2 ppc_6xx-size: 'u-boot': No such file Configuring for NETTA_ISDN_SWAPHOOK - Board: NETTA, Options: NETTA_ISDN=1,NETTA_SWAPHOOK=1 include/post.h: Assembler messages: include/post.h:190: Error: Unrecognized opcode: `int' make[2]: *** [lib_powerpc/asm.o] Error 1 make[2]: *** Waiting for unfinished jobs.... include/post.h: Assembler messages: include/post.h:190: Error: Unrecognized opcode: `int' make[2]: *** [lib_powerpc/asm.o] Error 1 make[2]: *** Waiting for unfinished jobs.... make[1]: *** [lib_powerpc/libpostpowerpc.o] Error 2 make: *** [libpost.o] Error 2 ppc_6xx-size: 'u-boot': No such file Configuring for NETTA_SWAPHOOK - Board: NETTA, Options: NETTA_SWAPHOOK=1 include/post.h: Assembler messages: include/post.h:190: Error: Unrecognized opcode: `int' make[2]: *** [lib_powerpc/asm.o] Error 1 make[2]: *** Waiting for unfinished jobs.... include/post.h: Assembler messages: include/post.h:190: Error: Unrecognized opcode: `int' make[2]: *** [lib_powerpc/asm.o] Error 1 make[2]: *** Waiting for unfinished jobs.... make[1]: *** [lib_powerpc/libpostpowerpc.o] Error 2 make: *** [libpost.o] Error 2 ppc_6xx-size: 'u-boot': No such file ... Configuring for KUP4X board... include/post.h: Assembler messages: include/post.h:190: Error: Unrecognized opcode: `int' make[2]: *** [lib_powerpc/asm.o] Error 1 make[2]: *** Waiting for unfinished jobs.... include/post.h: Assembler messages: include/post.h:190: Error: Unrecognized opcode: `int' ...
Please fix!!
Dear Heiko,
Please fix!!
To keep the number of non-compiling commits small and being able to apply more patches now I decided not to wait for your fix, but to revert the broken commit.
Please resubmit the (fixed) patch.
Hello Wolfgang,
Dear Heiko,
Please fix!!
Argh, did a "MAKEALL arm" only ... Sorry for the inconvinience! I look at this ASAP.
bye, Heiko
--- changes for v2: - make MAKEALL clean as Wolfgang Denk suggested - rebased against 7130a579fdba5dd1bf99508fb0b1d13317542109
diff --git a/include/post.h b/include/post.h index 3f259b7..3d23d22 100644 --- a/include/post.h +++ b/include/post.h @@ -147,6 +147,7 @@ unsigned long post_time_ms (unsigned long base); extern struct post_test post_list[]; extern unsigned int post_list_size; extern int post_hotkeys_pressed(void); +extern int memory_post_test(int flags);
/* * If GCC is configured to use a version of GAS that supports
changes for v2:
Applied, thanks.
Applied, thanks.
Heiko Schocher
Mike Frysinger
