[U-Boot] [PATCH v2 0/2] ARC: HSDK: add platform-specific stuff
Add hsdk-specific commands. Enable spi flash support for hsdk board.
Changes v1->v2: * Mobe spi flash enable to separate patch.
Eugeniy Paltsev (2): ARC: HSDK: add platform-specific commands ARC: HSDK: enable spi flash support
arch/arc/dts/hsdk.dts | 56 +++ arch/arc/dts/hsdk.dts.back | 112 +++++ board/synopsys/hsdk/MAINTAINERS | 4 +- board/synopsys/hsdk/Makefile | 2 + board/synopsys/hsdk/clk-lib.c | 75 +++ board/synopsys/hsdk/clk-lib.h | 38 ++ board/synopsys/hsdk/env-lib.c | 302 +++++++++++ board/synopsys/hsdk/env-lib.h | 58 +++ board/synopsys/hsdk/hsdk.c | 1046 +++++++++++++++++++++++++++++++++++++-- configs/hsdk_defconfig | 14 + configs/hsdk_defconfig.back | 56 +++ include/configs/hsdk.h | 56 ++- 12 files changed, 1768 insertions(+), 51 deletions(-) create mode 100644 arch/arc/dts/hsdk.dts.back create mode 100644 board/synopsys/hsdk/clk-lib.c create mode 100644 board/synopsys/hsdk/clk-lib.h create mode 100644 board/synopsys/hsdk/env-lib.c create mode 100644 board/synopsys/hsdk/env-lib.h create mode 100644 configs/hsdk_defconfig.back
This patch add support of hsdk platform-specific commands:
hsdk_clock set - set clock from axi_freq, cpu_freq and tun_freq environment variables/command line arguments
hsdk_clock get - save clock frequencies to axi_freq, cpu_freq and tun_freq environment variables
hsdk_clock print - show CPU, AXI, DDR and TUNNEL current clock frequencies.
hsdk_clock print_all - show all currently used clock frequencies.
hsdk_init - setup board HW in one of pre-defined configuration (hsdk_hs34 / hsdk_hs36 / hsdk_hs36_ccm / hsdk_hs38 / hsdk_hs38_ccm / hsdk_hs38x2 / hsdk_hs38x3 / hsdk_hs38x4)
hsdk_go - run baremetal application on hsdk configured by hsdk_init command.
This patch changes default behaviour of 'bootm' command: now we are able to set number of CPUs to be kicked by setting 'core_mask' environment variable before 'bootm' command run.
Signed-off-by: Eugeniy Paltsev Eugeniy.Paltsev@synopsys.com --- arch/arc/dts/hsdk.dts | 30 ++ board/synopsys/hsdk/MAINTAINERS | 4 +- board/synopsys/hsdk/Makefile | 2 + board/synopsys/hsdk/clk-lib.c | 75 +++ board/synopsys/hsdk/clk-lib.h | 38 ++ board/synopsys/hsdk/env-lib.c | 302 +++++++++++ board/synopsys/hsdk/env-lib.h | 58 +++ board/synopsys/hsdk/hsdk.c | 1046 +++++++++++++++++++++++++++++++++++++-- configs/hsdk_defconfig | 4 + include/configs/hsdk.h | 56 ++- 10 files changed, 1564 insertions(+), 51 deletions(-) create mode 100644 board/synopsys/hsdk/clk-lib.c create mode 100644 board/synopsys/hsdk/clk-lib.h create mode 100644 board/synopsys/hsdk/env-lib.c create mode 100644 board/synopsys/hsdk/env-lib.h
diff --git a/arch/arc/dts/hsdk.dts b/arch/arc/dts/hsdk.dts index 67dfb93ca8..09f3fe9a37 100644 --- a/arch/arc/dts/hsdk.dts +++ b/arch/arc/dts/hsdk.dts @@ -6,6 +6,7 @@ /dts-v1/;
#include "skeleton.dtsi" +#include "dt-bindings/clock/snps,hsdk-cgu.h"
/ { #address-cells = <1>; @@ -24,6 +25,35 @@ }; };
+ clk-fmeas { + clocks = <&cgu_clk CLK_ARC_PLL>, <&cgu_clk CLK_SYS_PLL>, + <&cgu_clk CLK_TUN_PLL>, <&cgu_clk CLK_DDR_PLL>, + <&cgu_clk CLK_ARC>, <&cgu_clk CLK_HDMI_PLL>, + <&cgu_clk CLK_TUN_TUN>, <&cgu_clk CLK_HDMI>, + <&cgu_clk CLK_SYS_APB>, <&cgu_clk CLK_SYS_AXI>, + <&cgu_clk CLK_SYS_ETH>, <&cgu_clk CLK_SYS_USB>, + <&cgu_clk CLK_SYS_SDIO>, <&cgu_clk CLK_SYS_HDMI>, + <&cgu_clk CLK_SYS_GFX_CORE>, <&cgu_clk CLK_SYS_GFX_DMA>, + <&cgu_clk CLK_SYS_GFX_CFG>, <&cgu_clk CLK_SYS_DMAC_CORE>, + <&cgu_clk CLK_SYS_DMAC_CFG>, <&cgu_clk CLK_SYS_SDIO_REF>, + <&cgu_clk CLK_SYS_SPI_REF>, <&cgu_clk CLK_SYS_I2C_REF>, + <&cgu_clk CLK_SYS_UART_REF>, <&cgu_clk CLK_SYS_EBI_REF>, + <&cgu_clk CLK_TUN_ROM>, <&cgu_clk CLK_TUN_PWM>; + clock-names = "cpu-pll", "sys-pll", + "tun-pll", "ddr-clk", + "cpu-clk", "hdmi-pll", + "tun-clk", "hdmi-clk", + "apb-clk", "axi-clk", + "eth-clk", "usb-clk", + "sdio-clk", "hdmi-sys-clk", + "gfx-core-clk", "gfx-dma-clk", + "gfx-cfg-clk", "dmac-core-clk", + "dmac-cfg-clk", "sdio-ref-clk", + "spi-clk", "i2c-clk", + "uart-clk", "ebi-clk", + "rom-clk", "pwm-clk"; + }; + cgu_clk: cgu-clk@f0000000 { compatible = "snps,hsdk-cgu-clock"; reg = <0xf0000000 0x10>, <0xf00014B8 0x4>; diff --git a/board/synopsys/hsdk/MAINTAINERS b/board/synopsys/hsdk/MAINTAINERS index d034bc479d..e22bd1e40b 100644 --- a/board/synopsys/hsdk/MAINTAINERS +++ b/board/synopsys/hsdk/MAINTAINERS @@ -1,5 +1,5 @@ -AXS10X BOARD -M: Alexey Brodkin abrodkin@synopsys.com +HSDK BOARD +M: Eugeniy Paltsev paltsev@synopsys.com S: Maintained F: board/synopsys/hsdk/ F: configs/hsdk_defconfig diff --git a/board/synopsys/hsdk/Makefile b/board/synopsys/hsdk/Makefile index d84dd03265..7ecff3d740 100644 --- a/board/synopsys/hsdk/Makefile +++ b/board/synopsys/hsdk/Makefile @@ -5,3 +5,5 @@ #
obj-y += hsdk.o +obj-y += env-lib.o +obj-y += clk-lib.o diff --git a/board/synopsys/hsdk/clk-lib.c b/board/synopsys/hsdk/clk-lib.c new file mode 100644 index 0000000000..1ce54afffe --- /dev/null +++ b/board/synopsys/hsdk/clk-lib.c @@ -0,0 +1,75 @@ +/* + * Copyright (C) 2018 Synopsys, Inc. All rights reserved. + * Author: Eugeniy Paltsev Eugeniy.Paltsev@synopsys.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <clk.h> +#include <dm/device.h> + +#include "clk-lib.h" + +#define HZ_IN_MHZ 1000000 +#define ceil(x, y) ({ ulong __x = (x), __y = (y); (__x + __y - 1) / __y; }) + +int soc_clk_ctl(const char *name, ulong *rate, enum clk_ctl_ops ctl) +{ + int ret; + ulong mhz_rate, priv_rate; + struct clk clk; + + /* Dummy fmeas device, just to be able to use standard clk_* api */ + struct udevice fmeas = { + .name = "clk-fmeas", + .node = ofnode_path("/clk-fmeas"), + }; + + ret = clk_get_by_name(&fmeas, name, &clk); + if (ret) { + pr_err("clock '%s' not found, err=%d\n", name, ret); + return ret; + } + + if (ctl & CLK_ON) { + ret = clk_enable(&clk); + if (ret && ret != -ENOSYS && ret != -ENOTSUPP) + return ret; + } + + if ((ctl & CLK_SET) && rate) { + priv_rate = ctl & CLK_MHZ ? (*rate) * HZ_IN_MHZ : *rate; + ret = clk_set_rate(&clk, priv_rate); + if (ret) + return ret; + } + + if (ctl & CLK_OFF) { + ret = clk_disable(&clk); + if (ret) { + pr_err("clock '%s' can't be disabled, err=%d\n", name, ret); + return ret; + } + } + + priv_rate = clk_get_rate(&clk); + + clk_free(&clk); + + mhz_rate = ceil(priv_rate, HZ_IN_MHZ); + + if (ctl & CLK_MHZ) + priv_rate = mhz_rate; + + if ((ctl & CLK_GET) && rate) + *rate = priv_rate; + + if ((ctl & CLK_PRINT) && (ctl & CLK_MHZ)) + printf("HSDK: clock '%s' rate %lu MHz\n", name, priv_rate); + else if (ctl & CLK_PRINT) + printf("HSDK: clock '%s' rate %lu Hz\n", name, priv_rate); + else + debug("HSDK: clock '%s' rate %lu MHz\n", name, mhz_rate); + + return 0; +} diff --git a/board/synopsys/hsdk/clk-lib.h b/board/synopsys/hsdk/clk-lib.h new file mode 100644 index 0000000000..3b7dbc58ae --- /dev/null +++ b/board/synopsys/hsdk/clk-lib.h @@ -0,0 +1,38 @@ +/* + * Copyright (C) 2018 Synopsys, Inc. All rights reserved. + * Author: Eugeniy Paltsev Eugeniy.Paltsev@synopsys.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __BOARD_CLK_LIB_H +#define __BOARD_CLK_LIB_H + +#include <common.h> + +enum clk_ctl_ops { + CLK_SET = BIT(0), /* set frequency */ + CLK_GET = BIT(1), /* get frequency */ + CLK_ON = BIT(2), /* enable clock */ + CLK_OFF = BIT(3), /* disable clock */ + CLK_PRINT = BIT(4), /* print frequency */ + CLK_MHZ = BIT(5) /* all values in MHZ instead of HZ */ +}; + +/* + * Depending on the clk_ctl_ops enable / disable / + * set clock rate from 'rate' argument / read clock to 'rate' argument / + * print clock rate. If CLK_MHZ flag set in clk_ctl_ops 'rate' is in MHz, + * otherwise - in Hz. + * + * This function expects "clk-fmeas" node in device tree: + * / { + * clk-fmeas { + * clocks = <&cpu_pll>, <&sys_pll>; + * clock-names = "cpu-pll", "sys-pll"; + * }; + * }; + */ +int soc_clk_ctl(const char *name, ulong *rate, enum clk_ctl_ops ctl); + +#endif /* __BOARD_CLK_LIB_H */ diff --git a/board/synopsys/hsdk/env-lib.c b/board/synopsys/hsdk/env-lib.c new file mode 100644 index 0000000000..6b53d92c23 --- /dev/null +++ b/board/synopsys/hsdk/env-lib.c @@ -0,0 +1,302 @@ +/* + * Copyright (C) 2018 Synopsys, Inc. All rights reserved. + * Author: Eugeniy Paltsev Eugeniy.Paltsev@synopsys.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include "env-lib.h" + +#define MAX_CMD_LEN 25 + +static void env_clear_common(u32 index, const struct env_map_common *map) +{ + map[index].val->val = 0; + map[index].val->set = false; +} + +static int env_read_common(u32 index, const struct env_map_common *map) +{ + u32 val; + + if (!env_get_yesno(map[index].env_name)) { + if (map[index].type == ENV_HEX) { + val = (u32)env_get_hex(map[index].env_name, 0); + debug("ENV: %s: = %#x\n", map[index].env_name, val); + } else { + val = (u32)env_get_ulong(map[index].env_name, 10, 0); + debug("ENV: %s: = %d\n", map[index].env_name, val); + } + + map[index].val->val = val; + map[index].val->set = true; + } + + return 0; +} + +static void env_clear_core(u32 index, const struct env_map_percpu *map) +{ + for (u32 i = 0; i < NR_CPUS; i++) { + (*map[index].val)[i].val = 0; + (*map[index].val)[i].set = false; + } +} + +static int env_read_core(u32 index, const struct env_map_percpu *map) +{ + u32 val; + char command[MAX_CMD_LEN]; + + for (u32 i = 0; i < NR_CPUS; i++) { + sprintf(command, "%s_%u", map[index].env_name, i); + if (!env_get_yesno(command)) { + if (map[index].type == ENV_HEX) { + val = (u32)env_get_hex(command, 0); + debug("ENV: %s: = %#x\n", command, val); + } else { + val = (u32)env_get_ulong(command, 10, 0); + debug("ENV: %s: = %d\n", command, val); + } + + (*map[index].val)[i].val = val; + (*map[index].val)[i].set = true; + } + } + + return 0; +} + +static int env_validate_common(u32 index, const struct env_map_common *map) +{ + u32 value = map[index].val->val; + bool set = map[index].val->set; + u32 min = map[index].min; + u32 max = map[index].max; + + /* Check if environment is mandatory */ + if (map[index].mandatory && !set) { + pr_err("Variable '%s' is mandatory, but it is not defined\n", + map[index].env_name); + + return -EINVAL; + } + + /* Check environment boundary */ + if (set && (value < min || value > max)) { + if (map[index].type == ENV_HEX) + pr_err("Variable '%s' must be between %#x and %#x\n", + map[index].env_name, min, max); + else + pr_err("Variable '%s' must be between %u and %u\n", + map[index].env_name, min, max); + + return -EINVAL; + } + + return 0; +} + +static int env_validate_core(u32 index, const struct env_map_percpu *map, + bool (*cpu_used)(u32)) +{ + u32 value; + bool set; + bool mandatory = map[index].mandatory; + u32 min, max; + + for (u32 i = 0; i < NR_CPUS; i++) { + set = (*map[index].val)[i].set; + value = (*map[index].val)[i].val; + + /* Check if environment is mandatory */ + if (cpu_used(i) && mandatory && !set) { + pr_err("CPU %u is used, but '%s_%u' is not defined\n", + i, map[index].env_name, i); + + return -EINVAL; + } + + min = map[index].min[i]; + max = map[index].max[i]; + + /* Check environment boundary */ + if (set && (value < min || value > max)) { + if (map[index].type == ENV_HEX) + pr_err("Variable '%s_%u' must be between %#x and %#x\n", + map[index].env_name, i, min, max); + else + pr_err("Variable '%s_%u' must be between %d and %d\n", + map[index].env_name, i, min, max); + + return -EINVAL; + } + } + + return 0; +} + +void envs_cleanup_core(const struct env_map_percpu *map) +{ + /* Cleanup env struct first */ + for (u32 i = 0; map[i].env_name; i++) + env_clear_core(i, map); +} + +void envs_cleanup_common(const struct env_map_common *map) +{ + /* Cleanup env struct first */ + for (u32 i = 0; map[i].env_name; i++) + env_clear_common(i, map); +} + +int envs_read_common(const struct env_map_common *map) +{ + int ret; + + for (u32 i = 0; map[i].env_name; i++) { + ret = env_read_common(i, map); + if (ret) + return ret; + } + + return 0; +} + +int envs_validate_common(const struct env_map_common *map) +{ + int ret; + + for (u32 i = 0; map[i].env_name; i++) { + ret = env_validate_common(i, map); + if (ret) + return ret; + } + + return 0; +} + +int envs_read_validate_common(const struct env_map_common *map) +{ + int ret; + + envs_cleanup_common(map); + + ret = envs_read_common(map); + if (ret) + return ret; + + ret = envs_validate_common(map); + if (ret) + return ret; + + return 0; +} + +int envs_read_validate_core(const struct env_map_percpu *map, + bool (*cpu_used)(u32)) +{ + int ret; + + envs_cleanup_core(map); + + for (u32 i = 0; map[i].env_name; i++) { + ret = env_read_core(i, map); + if (ret) + return ret; + } + + for (u32 i = 0; map[i].env_name; i++) { + ret = env_validate_core(i, map, cpu_used); + if (ret) + return ret; + } + + return 0; +} + +int envs_process_and_validate(const struct env_map_common *common, + const struct env_map_percpu *core, + bool (*cpu_used)(u32)) +{ + int ret; + + ret = envs_read_validate_common(common); + if (ret) + return ret; + + ret = envs_read_validate_core(core, cpu_used); + if (ret) + return ret; + + return 0; +} + +static int args_envs_read_search(const struct env_map_common *map, + int argc, char *const argv[]) +{ + for (int i = 0; map[i].env_name; i++) { + if (!strcmp(argv[0], map[i].env_name)) + return i; + } + + pr_err("Unexpected argument '%s', can't parse\n", argv[0]); + + return -ENOENT; +} + +static int arg_read_set(const struct env_map_common *map, u32 i, int argc, + char *const argv[]) +{ + char *endp = argv[1]; + + if (map[i].type == ENV_HEX) + map[i].val->val = simple_strtoul(argv[1], &endp, 16); + else + map[i].val->val = simple_strtoul(argv[1], &endp, 10); + + map[i].val->set = true; + + if (*endp == '\0') + return 0; + + pr_err("Unexpected argument '%s', can't parse\n", argv[1]); + + map[i].val->set = false; + + return -EINVAL; +} + +int args_envs_enumerate(const struct env_map_common *map, int enum_by, + int argc, char *const argv[]) +{ + u32 i; + + if (argc % enum_by) { + pr_err("unexpected argument number: %d\n", argc); + return -EINVAL; + } + + while (argc > 0) { + i = args_envs_read_search(map, argc, argv); + if (i < 0) + return i; + + debug("ARG: found '%s' with index %d\n", map[i].env_name, i); + + if (i < 0) { + pr_err("unknown arg: %s\n", argv[0]); + return -EINVAL; + } + + if (arg_read_set(map, i, argc, argv)) + return -EINVAL; + + debug("ARG: value.s '%s' == %#x\n", argv[1], map[i].val->val); + + argc -= enum_by; + argv += enum_by; + } + + return 0; +} diff --git a/board/synopsys/hsdk/env-lib.h b/board/synopsys/hsdk/env-lib.h new file mode 100644 index 0000000000..606e802f0f --- /dev/null +++ b/board/synopsys/hsdk/env-lib.h @@ -0,0 +1,58 @@ +/* + * Copyright (C) 2018 Synopsys, Inc. All rights reserved. + * Author: Eugeniy Paltsev Eugeniy.Paltsev@synopsys.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __BOARD_ENV_LIB_H +#define __BOARD_ENV_LIB_H + +#include <common.h> +#include <config.h> +#include <linux/kernel.h> + +enum env_type { + ENV_DEC, + ENV_HEX +}; + +typedef struct { + u32 val; + bool set; +} u32_env; + +struct env_map_common { + const char *const env_name; + enum env_type type; + bool mandatory; + u32 min; + u32 max; + u32_env *val; +}; + +struct env_map_percpu { + const char *const env_name; + enum env_type type; + bool mandatory; + u32 min[NR_CPUS]; + u32 max[NR_CPUS]; + u32_env (*val)[NR_CPUS]; +}; + +void envs_cleanup_common(const struct env_map_common *map); +int envs_read_common(const struct env_map_common *map); +int envs_validate_common(const struct env_map_common *map); +int envs_read_validate_common(const struct env_map_common *map); + +void envs_cleanup_core(const struct env_map_percpu *map); +int envs_read_validate_core(const struct env_map_percpu *map, + bool (*cpu_used)(u32)); +int envs_process_and_validate(const struct env_map_common *common, + const struct env_map_percpu *core, + bool (*cpu_used)(u32)); + +int args_envs_enumerate(const struct env_map_common *map, + int enum_by, int argc, char *const argv[]); + +#endif /* __BOARD_ENV_LIB_H */ diff --git a/board/synopsys/hsdk/hsdk.c b/board/synopsys/hsdk/hsdk.c index 5b3a063b69..65f937fd0f 100644 --- a/board/synopsys/hsdk/hsdk.c +++ b/board/synopsys/hsdk/hsdk.c @@ -1,59 +1,713 @@ /* - * Copyright (C) 2017 Synopsys, Inc. All rights reserved. + * Copyright (C) 2018 Synopsys, Inc. All rights reserved. + * Author: Eugeniy Paltsev Eugeniy.Paltsev@synopsys.com * * SPDX-License-Identifier: GPL-2.0+ */
#include <common.h> +#include <config.h> +#include <linux/printk.h> +#include <linux/kernel.h> +#include <linux/io.h> +#include <asm/arcregs.h> +#include <fdt_support.h> #include <dwmmc.h> #include <malloc.h> +#include <usb.h> + +#include "clk-lib.h" +#include "env-lib.h"
DECLARE_GLOBAL_DATA_PTR;
-#define CREG_BASE (ARC_PERIPHERAL_BASE + 0x1000) -#define CREG_PAE (CREG_BASE + 0x180) -#define CREG_PAE_UPDATE (CREG_BASE + 0x194) -#define CREG_CPU_START (CREG_BASE + 0x400) +#define ALL_CPU_MASK GENMASK(NR_CPUS - 1, 0) +#define MASTER_CPU_ID 0 +#define APERTURE_SHIFT 28 +#define NO_CCM 0x10 +#define SLAVE_CPU_READY 0x12345678 +#define BOOTSTAGE_1 1 /* after SP, FP setup, before HW init */ +#define BOOTSTAGE_2 2 /* after HW init, before self halt */ +#define BOOTSTAGE_3 3 /* after self halt */ +#define BOOTSTAGE_4 4 /* before app launch */ +#define BOOTSTAGE_5 5 /* after app launch, unreachable */
-int board_early_init_f(void) +#define RESET_VECTOR_ADDR 0x0 + +#define CREG_BASE (ARC_PERIPHERAL_BASE + 0x1000) +#define CREG_CPU_START (CREG_BASE + 0x400) +#define CREG_CPU_START_MASK 0xF + +#define SDIO_BASE (ARC_PERIPHERAL_BASE + 0xA000) +#define SDIO_UHS_REG_EXT (SDIO_BASE + 0x108) +#define SDIO_UHS_REG_EXT_DIV_2 (2 << 30) + +/* Uncached access macros */ +#define arc_read_uncached_32(ptr) \ +({ \ + unsigned int __ret; \ + __asm__ __volatile__( \ + " ld.di %0, [%1] \n" \ + : "=r"(__ret) \ + : "r"(ptr)); \ + __ret; \ +}) + +#define arc_write_uncached_32(ptr, data)\ +({ \ + __asm__ __volatile__( \ + " st.di %0, [%1] \n" \ + : \ + : "r"(data), "r"(ptr)); \ +}) + +struct hsdk_env_core_ctl { + u32_env entry[NR_CPUS]; + u32_env iccm[NR_CPUS]; + u32_env dccm[NR_CPUS]; +}; + +struct hsdk_env_common_ctl { + bool halt_on_boot; + u32_env core_mask; + u32_env cpu_freq; + u32_env axi_freq; + u32_env tun_freq; + u32_env nvlim; + u32_env icache; + u32_env dcache; +}; + +/* + * Uncached cross-cpu structure. All CPUs must access to this structure fields + * only with arc_read_uncached_32() / arc_write_uncached_32() accessors (which + * implement ld.di / st.di instructions). Simultaneous cached and uncached + * access to this area will lead to data loss. + * We flush all data caches in board_early_init_r() as we don't want to have + * any dirty line in L1d$ or SL$ in this area. + */ +struct hsdk_cross_cpu { + /* slave CPU ready flag */ + u32 ready_flag; + /* address of the area, which can be used for stack by slave CPU */ + u32 stack_ptr; + /* slave CPU status - bootstage number */ + s32 status[NR_CPUS]; + + /* + * Slave CPU data - it is copy of corresponding fields in + * hsdk_env_core_ctl and hsdk_env_common_ctl structures which are + * required for slave CPUs initialization. + * This fields can be populated by copying from hsdk_env_core_ctl + * and hsdk_env_common_ctl structures with sync_cross_cpu_data() + * function. + */ + u32 entry[NR_CPUS]; + u32 iccm[NR_CPUS]; + u32 dccm[NR_CPUS]; + + u32 core_mask; + u32 icache; + u32 dcache; + + u8 cache_padding[ARCH_DMA_MINALIGN]; +} __aligned(ARCH_DMA_MINALIGN); + +/* Place for slave CPUs temporary stack */ +static u32 slave_stack[256 * NR_CPUS] __aligned(ARCH_DMA_MINALIGN); + +static struct hsdk_env_common_ctl env_common = {}; +static struct hsdk_env_core_ctl env_core = {}; +static struct hsdk_cross_cpu cross_cpu_data; + +static const struct env_map_common env_map_common[] = { + { "core_mask", ENV_HEX, true, 0x1, 0xF, &env_common.core_mask }, + { "non_volatile_limit", ENV_HEX, true, 0, 0xF, &env_common.nvlim }, + { "icache_ena", ENV_HEX, true, 0, 1, &env_common.icache }, + { "dcache_ena", ENV_HEX, true, 0, 1, &env_common.dcache }, + {} +}; + +static const struct env_map_common env_map_clock[] = { + { "cpu_freq", ENV_DEC, false, 100, 1000, &env_common.cpu_freq }, + { "axi_freq", ENV_DEC, false, 200, 800, &env_common.axi_freq }, + { "tun_freq", ENV_DEC, false, 0, 150, &env_common.tun_freq }, + {} +}; + +static const struct env_map_percpu env_map_core[] = { + { "core_iccm", ENV_HEX, true, {NO_CCM, 0, NO_CCM, 0}, {NO_CCM, 0xF, NO_CCM, 0xF}, &env_core.iccm }, + { "core_dccm", ENV_HEX, true, {NO_CCM, 0, NO_CCM, 0}, {NO_CCM, 0xF, NO_CCM, 0xF}, &env_core.dccm }, + {} +}; + +static const struct env_map_common env_map_mask[] = { + { "core_mask", ENV_HEX, false, 0x1, 0xF, &env_common.core_mask }, + {} +}; + +static const struct env_map_percpu env_map_go[] = { + { "core_entry", ENV_HEX, true, {0, 0, 0, 0}, {U32_MAX, U32_MAX, U32_MAX, U32_MAX}, &env_core.entry }, + {} +}; + +static void sync_cross_cpu_data(void) +{ + u32 value; + + for (u32 i = 0; i < NR_CPUS; i++) { + value = env_core.entry[i].val; + arc_write_uncached_32(&cross_cpu_data.entry[i], value); + } + + for (u32 i = 0; i < NR_CPUS; i++) { + value = env_core.iccm[i].val; + arc_write_uncached_32(&cross_cpu_data.iccm[i], value); + } + + for (u32 i = 0; i < NR_CPUS; i++) { + value = env_core.dccm[i].val; + arc_write_uncached_32(&cross_cpu_data.dccm[i], value); + } + + value = env_common.core_mask.val; + arc_write_uncached_32(&cross_cpu_data.core_mask, value); + + value = env_common.icache.val; + arc_write_uncached_32(&cross_cpu_data.icache, value); + + value = env_common.dcache.val; + arc_write_uncached_32(&cross_cpu_data.dcache, value); +} + +/* Can be used only on master CPU */ +static bool is_cpu_used(u32 cpu_id) { - /* In current chip PAE support for DMA is broken, disabling it. */ - writel(0, (void __iomem *) CREG_PAE); + return !!(env_common.core_mask.val & BIT(cpu_id)); +}
- /* Really apply settings made above */ - writel(1, (void __iomem *) CREG_PAE_UPDATE); +/* TODO: add ICCM BCR and DCCM BCR runtime check */ +static void init_slave_cpu_func(u32 core) +{ + u32 val; + + /* Remap ICCM to another memory region if it exists */ + val = arc_read_uncached_32(&cross_cpu_data.iccm[core]); + if (val != NO_CCM) + write_aux_reg(ARC_AUX_ICCM_BASE, val << APERTURE_SHIFT); + + /* Remap DCCM to another memory region if it exists */ + val = arc_read_uncached_32(&cross_cpu_data.dccm[core]); + if (val != NO_CCM) + write_aux_reg(ARC_AUX_DCCM_BASE, val << APERTURE_SHIFT); + + if (arc_read_uncached_32(&cross_cpu_data.icache)) + icache_enable(); + else + icache_disable(); + + if (arc_read_uncached_32(&cross_cpu_data.dcache)) + dcache_enable(); + else + dcache_disable(); +} + +static void init_cluster_nvlim(void) +{ + u32 val = env_common.nvlim.val << APERTURE_SHIFT; + + flush_dcache_all(); + write_aux_reg(ARC_AUX_NON_VOLATILE_LIMIT, val); + write_aux_reg(AUX_AUX_CACHE_LIMIT, val); + flush_n_invalidate_dcache_all(); +} + +static void init_master_icache(void) +{ + if (icache_status()) { + /* I$ is enabled - we need to disable it */ + if (!env_common.icache.val) + icache_disable(); + } else { + /* I$ is disabled - we need to enable it */ + if (env_common.icache.val) { + icache_enable(); + + /* invalidate I$ right after enable */ + invalidate_icache_all(); + } + } +} + +static void init_master_dcache(void) +{ + if (dcache_status()) { + /* D$ is enabled - we need to disable it */ + if (!env_common.dcache.val) + dcache_disable(); + } else { + /* D$ is disabled - we need to enable it */ + if (env_common.dcache.val) + dcache_enable(); + + /* TODO: probably we need ti invalidate D$ right after enable */ + } +} + +static int cleanup_before_go(void) +{ + disable_interrupts(); + sync_n_cleanup_cache_all();
return 0; }
-#define SDIO_BASE (ARC_PERIPHERAL_BASE + 0xA000) -#define SDIO_UHS_REG_EXT (SDIO_BASE + 0x108) -#define SDIO_UHS_REG_EXT_DIV_2 (2 << 30) +void slave_cpu_set_boot_addr(u32 addr) +{ + /* All cores have reset vector pointing to 0 */ + writel(addr, (void __iomem *)RESET_VECTOR_ADDR);
-int board_mmc_init(bd_t *bis) + /* Make sure other cores see written value in memory */ + sync_n_cleanup_cache_all(); +} + +static inline void halt_this_cpu(void) { - struct dwmci_host *host = NULL; + __builtin_arc_flag(1); +}
- host = malloc(sizeof(struct dwmci_host)); - if (!host) { - printf("dwmci_host malloc fail!\n"); - return 1; +static void smp_kick_cpu_x(u32 cpu_id) +{ + int cmd = readl((void __iomem *)CREG_CPU_START); + + if (cpu_id > NR_CPUS) + return; + + cmd &= ~CREG_CPU_START_MASK; + cmd |= (1 << cpu_id); + writel(cmd, (void __iomem *)CREG_CPU_START); +} + +static u32 prepare_cpu_ctart_reg(void) +{ + int cmd = readl((void __iomem *)CREG_CPU_START); + + cmd &= ~CREG_CPU_START_MASK; + + return cmd | env_common.core_mask.val; +} + +/* slave CPU entry for configuration */ +__attribute__((naked, noreturn, flatten)) noinline void hsdk_core_init_f(void) +{ + __asm__ __volatile__( + "ld.di r8, [%0]\n" + "mov %%sp, r8\n" + "mov %%fp, %%sp\n" + : /* no output */ + : "r" (&cross_cpu_data.stack_ptr)); + + invalidate_icache_all(); + + arc_write_uncached_32(&cross_cpu_data.status[CPU_ID_GET()], BOOTSTAGE_1); + init_slave_cpu_func(CPU_ID_GET()); + + arc_write_uncached_32(&cross_cpu_data.ready_flag, SLAVE_CPU_READY); + arc_write_uncached_32(&cross_cpu_data.status[CPU_ID_GET()], BOOTSTAGE_2); + + /* Halt the processor until the master kick us again */ + halt_this_cpu(); + + /* + * 3 NOPs after FLAG 1 instruction are no longer required for ARCv2 + * cores but we leave them for gebug purposes. + */ + __builtin_arc_nop(); + __builtin_arc_nop(); + __builtin_arc_nop(); + + arc_write_uncached_32(&cross_cpu_data.status[CPU_ID_GET()], BOOTSTAGE_3); + + /* get the updated entry - invalidate i$ */ + invalidate_icache_all(); + + arc_write_uncached_32(&cross_cpu_data.status[CPU_ID_GET()], BOOTSTAGE_4); + + /* Run our program */ + ((void (*)(void))(arc_read_uncached_32(&cross_cpu_data.entry[CPU_ID_GET()])))(); + + /* This bootstage is unreachable as we don't return from app we launch */ + arc_write_uncached_32(&cross_cpu_data.status[CPU_ID_GET()], BOOTSTAGE_5); + + /* Something went terribly wrong */ + while (true) + halt_this_cpu(); +} + +static void clear_cross_cpu_data(void) +{ + arc_write_uncached_32(&cross_cpu_data.ready_flag, 0); + arc_write_uncached_32(&cross_cpu_data.stack_ptr, 0); + + for (u32 i = 0; i < NR_CPUS; i++) + arc_write_uncached_32(&cross_cpu_data.status[i], 0); +} + +static noinline void do_init_slave_cpu(u32 cpu_id) +{ + /* attempts number for check clave CPU ready_flag */ + u32 attempts = 100; + u32 stack_ptr = (u32)(slave_stack + (64 * cpu_id)); + + if (cpu_id >= NR_CPUS) + return; + + arc_write_uncached_32(&cross_cpu_data.ready_flag, 0); + + /* Use global unique place for each slave cpu stack */ + arc_write_uncached_32(&cross_cpu_data.stack_ptr, stack_ptr); + + debug("CPU %u: stack pool base: %p\n", cpu_id, slave_stack); + debug("CPU %u: current slave stack base: %x\n", cpu_id, stack_ptr); + slave_cpu_set_boot_addr((u32)hsdk_core_init_f); + + smp_kick_cpu_x(cpu_id); + + debug("CPU %u: cross-cpu flag: %x [before timeout]\n", cpu_id, + arc_read_uncached_32(&cross_cpu_data.ready_flag)); + + while (!arc_read_uncached_32(&cross_cpu_data.ready_flag) && attempts--) + mdelay(10); + + /* Just to be sure that slave cpu is halted after it set ready_flag */ + mdelay(20); + + /* + * Only print error here if we reach timeout as there is no option to + * halt slave cpu (or check that slave cpu is halted) + */ + if (!attempts) + pr_err("CPU %u is not responding after init!\n", cpu_id); + + /* Check current stage of slave cpu */ + if (arc_read_uncached_32(&cross_cpu_data.status[cpu_id]) != BOOTSTAGE_2) + pr_err("CPU %u status is unexpected: %d\n", cpu_id, + arc_read_uncached_32(&cross_cpu_data.status[cpu_id])); + + debug("CPU %u: cross-cpu flag: %x [after timeout]\n", cpu_id, + arc_read_uncached_32(&cross_cpu_data.ready_flag)); + debug("CPU %u: status: %d [after timeout]\n", cpu_id, + arc_read_uncached_32(&cross_cpu_data.status[cpu_id])); +} + +static void do_init_slave_cpus(void) +{ + clear_cross_cpu_data(); + sync_cross_cpu_data(); + + debug("cross_cpu_data location: %#x\n", (u32)&cross_cpu_data); + + for (u32 i = MASTER_CPU_ID + 1; i < NR_CPUS; i++) + if (is_cpu_used(i)) + do_init_slave_cpu(i); +} + +static void do_init_master_cpu(void) +{ + /* + * Setup master caches even if master isn't used as we want to use + * same cache configuration on all running CPUs + */ + init_master_icache(); + init_master_dcache(); +} + +enum hsdk_axi_masters { + M_HS_CORE = 0, + M_HS_RTT, + M_AXI_TUN, + M_HDMI_VIDEO, + M_HDMI_AUDIO, + M_USB_HOST, + M_ETHERNET, + M_SDIO, + M_GPU, + M_DMAC_0, + M_DMAC_1, + M_DVFS +}; + +#define UPDATE_VAL 1 + +/* + * m master AXI_M_m_SLV0 AXI_M_m_SLV1 AXI_M_m_OFFSET0 AXI_M_m_OFFSET1 + * 0 HS (CBU) 0x11111111 0x63111111 0xFEDCBA98 0x0E543210 + * 1 HS (RTT) 0x77777777 0x77777777 0xFEDCBA98 0x76543210 + * 2 AXI Tunnel 0x88888888 0x88888888 0xFEDCBA98 0x76543210 + * 3 HDMI-VIDEO 0x77777777 0x77777777 0xFEDCBA98 0x76543210 + * 4 HDMI-ADUIO 0x77777777 0x77777777 0xFEDCBA98 0x76543210 + * 5 USB-HOST 0x77777777 0x77999999 0xFEDCBA98 0x76DCBA98 + * 6 ETHERNET 0x77777777 0x77999999 0xFEDCBA98 0x76DCBA98 + * 7 SDIO 0x77777777 0x77999999 0xFEDCBA98 0x76DCBA98 + * 8 GPU 0x77777777 0x77777777 0xFEDCBA98 0x76543210 + * 9 DMAC (port #1) 0x77777777 0x77777777 0xFEDCBA98 0x76543210 + * 10 DMAC (port #2) 0x77777777 0x77777777 0xFEDCBA98 0x76543210 + * 11 DVFS 0x00000000 0x60000000 0x00000000 0x00000000 + * + * Please read ARC HS Development IC Specification, section 17.2 for more + * information about apertures configuration. + * NOTE: we intentionally modify default settings in U-boot. Default settings + * are specified in "Table 111 CREG Address Decoder register reset values". + */ + +#define CREG_AXI_M_SLV0(m) ((void __iomem *)(CREG_BASE + 0x020 * (m))) +#define CREG_AXI_M_SLV1(m) ((void __iomem *)(CREG_BASE + 0x020 * (m) + 0x004)) +#define CREG_AXI_M_OFT0(m) ((void __iomem *)(CREG_BASE + 0x020 * (m) + 0x008)) +#define CREG_AXI_M_OFT1(m) ((void __iomem *)(CREG_BASE + 0x020 * (m) + 0x00C)) +#define CREG_AXI_M_UPDT(m) ((void __iomem *)(CREG_BASE + 0x020 * (m) + 0x014)) + +#define CREG_AXI_M_HS_CORE_BOOT ((void __iomem *)(CREG_BASE + 0x010)) + +#define CREG_PAE ((void __iomem *)(CREG_BASE + 0x180)) +#define CREG_PAE_UPDT ((void __iomem *)(CREG_BASE + 0x194)) + +void init_memory_bridge(void) +{ + u32 reg; + + /* + * M_HS_CORE has one unic register - BOOT. + * We need to clean boot mirror (BOOT[1:0]) bits in them. + */ + reg = readl(CREG_AXI_M_HS_CORE_BOOT) & (~0x3); + writel(reg, CREG_AXI_M_HS_CORE_BOOT); + writel(0x11111111, CREG_AXI_M_SLV0(M_HS_CORE)); + writel(0x63111111, CREG_AXI_M_SLV1(M_HS_CORE)); + writel(0xFEDCBA98, CREG_AXI_M_OFT0(M_HS_CORE)); + writel(0x0E543210, CREG_AXI_M_OFT1(M_HS_CORE)); + writel(UPDATE_VAL, CREG_AXI_M_UPDT(M_HS_CORE)); + + writel(0x77777777, CREG_AXI_M_SLV0(M_HS_RTT)); + writel(0x77777777, CREG_AXI_M_SLV1(M_HS_RTT)); + writel(0xFEDCBA98, CREG_AXI_M_OFT0(M_HS_RTT)); + writel(0x76543210, CREG_AXI_M_OFT1(M_HS_RTT)); + writel(UPDATE_VAL, CREG_AXI_M_UPDT(M_HS_RTT)); + + writel(0x88888888, CREG_AXI_M_SLV0(M_AXI_TUN)); + writel(0x88888888, CREG_AXI_M_SLV1(M_AXI_TUN)); + writel(0xFEDCBA98, CREG_AXI_M_OFT0(M_AXI_TUN)); + writel(0x76543210, CREG_AXI_M_OFT1(M_AXI_TUN)); + writel(UPDATE_VAL, CREG_AXI_M_UPDT(M_AXI_TUN)); + + writel(0x77777777, CREG_AXI_M_SLV0(M_HDMI_VIDEO)); + writel(0x77777777, CREG_AXI_M_SLV1(M_HDMI_VIDEO)); + writel(0xFEDCBA98, CREG_AXI_M_OFT0(M_HDMI_VIDEO)); + writel(0x76543210, CREG_AXI_M_OFT1(M_HDMI_VIDEO)); + writel(UPDATE_VAL, CREG_AXI_M_UPDT(M_HDMI_VIDEO)); + + writel(0x77777777, CREG_AXI_M_SLV0(M_HDMI_AUDIO)); + writel(0x77777777, CREG_AXI_M_SLV1(M_HDMI_AUDIO)); + writel(0xFEDCBA98, CREG_AXI_M_OFT0(M_HDMI_AUDIO)); + writel(0x76543210, CREG_AXI_M_OFT1(M_HDMI_AUDIO)); + writel(UPDATE_VAL, CREG_AXI_M_UPDT(M_HDMI_AUDIO)); + + writel(0x77777777, CREG_AXI_M_SLV0(M_USB_HOST)); + writel(0x77999999, CREG_AXI_M_SLV1(M_USB_HOST)); + writel(0xFEDCBA98, CREG_AXI_M_OFT0(M_USB_HOST)); + writel(0x76DCBA98, CREG_AXI_M_OFT1(M_USB_HOST)); + writel(UPDATE_VAL, CREG_AXI_M_UPDT(M_USB_HOST)); + + writel(0x77777777, CREG_AXI_M_SLV0(M_ETHERNET)); + writel(0x77999999, CREG_AXI_M_SLV1(M_ETHERNET)); + writel(0xFEDCBA98, CREG_AXI_M_OFT0(M_ETHERNET)); + writel(0x76DCBA98, CREG_AXI_M_OFT1(M_ETHERNET)); + writel(UPDATE_VAL, CREG_AXI_M_UPDT(M_ETHERNET)); + + writel(0x77777777, CREG_AXI_M_SLV0(M_SDIO)); + writel(0x77999999, CREG_AXI_M_SLV1(M_SDIO)); + writel(0xFEDCBA98, CREG_AXI_M_OFT0(M_SDIO)); + writel(0x76DCBA98, CREG_AXI_M_OFT1(M_SDIO)); + writel(UPDATE_VAL, CREG_AXI_M_UPDT(M_SDIO)); + + writel(0x77777777, CREG_AXI_M_SLV0(M_GPU)); + writel(0x77777777, CREG_AXI_M_SLV1(M_GPU)); + writel(0xFEDCBA98, CREG_AXI_M_OFT0(M_GPU)); + writel(0x76543210, CREG_AXI_M_OFT1(M_GPU)); + writel(UPDATE_VAL, CREG_AXI_M_UPDT(M_GPU)); + + writel(0x77777777, CREG_AXI_M_SLV0(M_DMAC_0)); + writel(0x77777777, CREG_AXI_M_SLV1(M_DMAC_0)); + writel(0xFEDCBA98, CREG_AXI_M_OFT0(M_DMAC_0)); + writel(0x76543210, CREG_AXI_M_OFT1(M_DMAC_0)); + writel(UPDATE_VAL, CREG_AXI_M_UPDT(M_DMAC_0)); + + writel(0x77777777, CREG_AXI_M_SLV0(M_DMAC_1)); + writel(0x77777777, CREG_AXI_M_SLV1(M_DMAC_1)); + writel(0xFEDCBA98, CREG_AXI_M_OFT0(M_DMAC_1)); + writel(0x76543210, CREG_AXI_M_OFT1(M_DMAC_1)); + writel(UPDATE_VAL, CREG_AXI_M_UPDT(M_DMAC_1)); + + writel(0x00000000, CREG_AXI_M_SLV0(M_DVFS)); + writel(0x60000000, CREG_AXI_M_SLV1(M_DVFS)); + writel(0x00000000, CREG_AXI_M_OFT0(M_DVFS)); + writel(0x00000000, CREG_AXI_M_OFT1(M_DVFS)); + writel(UPDATE_VAL, CREG_AXI_M_UPDT(M_DVFS)); + + writel(0x00000000, CREG_PAE); + writel(UPDATE_VAL, CREG_PAE_UPDT); +} + +static void setup_clocks(void) +{ + ulong rate; + + /* Setup CPU clock */ + if (env_common.cpu_freq.set) { + rate = env_common.cpu_freq.val; + soc_clk_ctl("cpu-clk", &rate, CLK_ON | CLK_SET | CLK_MHZ); }
+ /* Setup TUN clock */ + if (env_common.tun_freq.set) { + rate = env_common.tun_freq.val; + if (rate) + soc_clk_ctl("tun-clk", &rate, CLK_ON | CLK_SET | CLK_MHZ); + else + soc_clk_ctl("tun-clk", NULL, CLK_OFF); + } + + if (env_common.axi_freq.set) { + rate = env_common.axi_freq.val; + soc_clk_ctl("axi-clk", &rate, CLK_SET | CLK_ON | CLK_MHZ); + } +} + +static void do_init_cluster(void) +{ /* - * Switch SDIO external ciu clock divider from default div-by-8 to - * minimum possible div-by-2. + * A multi-core ARC HS configuration always includes only one + * ARC_AUX_NON_VOLATILE_LIMIT register, which is shared by all the + * cores. */ - writel(SDIO_UHS_REG_EXT_DIV_2, (void __iomem *) SDIO_UHS_REG_EXT); + init_cluster_nvlim(); +}
- memset(host, 0, sizeof(struct dwmci_host)); - host->name = "Synopsys Mobile storage"; - host->ioaddr = (void *)ARC_DWMMC_BASE; - host->buswidth = 4; - host->dev_index = 0; - host->bus_hz = 50000000; +static int check_master_cpu_id(void) +{ + if (CPU_ID_GET() == MASTER_CPU_ID) + return 0;
- add_dwmci(host, host->bus_hz / 2, 400000); + pr_err("u-boot runs on non-master cpu with id: %lu\n", CPU_ID_GET()); + + return -ENOENT; +} + +static noinline int prepare_cpus(void) +{ + int ret; + + ret = check_master_cpu_id(); + if (ret) + return ret; + + ret = envs_process_and_validate(env_map_common, env_map_core, is_cpu_used); + if (ret) + return ret; + + printf("CPU start mask is %#x\n", env_common.core_mask.val); + + do_init_slave_cpus(); + do_init_master_cpu(); + do_init_cluster(); + + return 0; +} + +static int hsdk_go_run(u32 cpu_start_reg) +{ + /* Cleanup caches, disable interrupts */ + cleanup_before_go(); + + if (env_common.halt_on_boot) + halt_this_cpu(); + + /* + * 3 NOPs after FLAG 1 instruction are no longer required for ARCv2 + * cores but we leave them for gebug purposes. + */ + __builtin_arc_nop(); + __builtin_arc_nop(); + __builtin_arc_nop(); + + /* Kick chosen slave CPUs */ + writel(cpu_start_reg, (void __iomem *)CREG_CPU_START); + + if (is_cpu_used(MASTER_CPU_ID)) + ((void (*)(void))(env_core.entry[MASTER_CPU_ID].val))(); + else + halt_this_cpu(); + + pr_err("u-boot still runs on cpu [%ld]\n", CPU_ID_GET()); + + /* + * We will never return after executing our program if master cpu used + * otherwise halt master cpu manually. + */ + while (true) + halt_this_cpu(); + + return 0; +} + +int board_prep_linux(bootm_headers_t *images) +{ + int ret, ofst; + char mask[15]; + + ret = envs_read_validate_common(env_map_mask); + if (ret) + return ret; + + /* Rollback to default values */ + if (!env_common.core_mask.set) { + env_common.core_mask.val = ALL_CPU_MASK; + env_common.core_mask.set = true; + } + + printf("CPU start mask is %#x\n", env_common.core_mask.val); + + if (!is_cpu_used(MASTER_CPU_ID)) + pr_err("ERR: try to launch linux with CPU[0] disabled! It doesn't work for ARC.\n"); + + /* + * If we want to launch linux on all CPUs we don't need to patch + * linux DTB as it is default configuration + */ + if (env_common.core_mask.val == ALL_CPU_MASK) + return 0; + + if (!IMAGE_ENABLE_OF_LIBFDT || !images->ft_len) { + pr_err("WARN: core_mask setup will work properly only with external DTB!\n"); + return 0; + } + + /* patch '/possible-cpus' property according to cpu mask */ + ofst = fdt_path_offset(images->ft_addr, "/"); + sprintf(mask, "%s%s%s%s", + is_cpu_used(0) ? "0," : "", + is_cpu_used(1) ? "1," : "", + is_cpu_used(2) ? "2," : "", + is_cpu_used(3) ? "3," : ""); + ret = fdt_setprop_string(images->ft_addr, ofst, "possible-cpus", mask); + /* + * If we failed to patch '/possible-cpus' property we don't need break + * linux loading process: kernel will handle it but linux will print + * warning like "Timeout: CPU1 FAILED to comeup !!!". + * So warn here about error, but return 0 like no error had occurred. + */ + if (ret) + pr_err("WARN: failed to patch '/possible-cpus' property, ret=%d\n", + ret);
return 0; } @@ -61,35 +715,335 @@ int board_mmc_init(bd_t *bis) void board_jump_and_run(ulong entry, int zero, int arch, uint params) { void (*kernel_entry)(int zero, int arch, uint params); + u32 cpu_start_reg;
kernel_entry = (void (*)(int, int, uint))entry;
- smp_set_core_boot_addr(entry, -1); - smp_kick_all_cpus(); - kernel_entry(zero, arch, params); + /* Prepare CREG_CPU_START for kicking chosen CPUs */ + cpu_start_reg = prepare_cpu_ctart_reg(); + + /* In case of run without hsdk_init */ + slave_cpu_set_boot_addr(entry); + + /* In case of run with hsdk_init */ + for (u32 i = 0; i < NR_CPUS; i++) { + env_core.entry[i].val = entry; + env_core.entry[i].set = true; + } + /* sync cross_cpu struct as we updated core-entry variables */ + sync_cross_cpu_data(); + + /* Kick chosen slave CPUs */ + writel(cpu_start_reg, (void __iomem *)CREG_CPU_START); + + if (is_cpu_used(0)) + kernel_entry(zero, arch, params); }
-#define RESET_VECTOR_ADDR 0x0 +static int hsdk_go_prepare_and_run(void) +{ + /* Prepare CREG_CPU_START for kicking chosen CPUs */ + u32 reg = prepare_cpu_ctart_reg(); + + if (env_common.halt_on_boot) + printf("CPU will halt before application start, start application with debugger.\n");
-void smp_set_core_boot_addr(unsigned long addr, int corenr) + return hsdk_go_run(reg); +} + +static int do_hsdk_go(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) { - /* All cores have reset vector pointing to 0 */ - writel(addr, (void __iomem *)RESET_VECTOR_ADDR); + int ret;
- /* Make sure other cores see written value in memory */ + /* + * Check for 'halt' parameter. 'halt' = enter halt-mode just before + * starting the application; can be used for debug. + */ + if (argc > 1) { + env_common.halt_on_boot = !strcmp(argv[1], "halt"); + if (!env_common.halt_on_boot) { + pr_err("Unrecognised parameter: '%s'\n", argv[1]); + return CMD_RET_FAILURE; + } + } + + ret = check_master_cpu_id(); + if (ret) + return ret; + + ret = envs_process_and_validate(env_map_mask, env_map_go, is_cpu_used); + if (ret) + return ret; + + /* sync cross_cpu struct as we updated core-entry variables */ + sync_cross_cpu_data(); + + ret = hsdk_go_prepare_and_run(); + + return ret ? CMD_RET_FAILURE : CMD_RET_SUCCESS; +} + +U_BOOT_CMD( + hsdk_go, 3, 0, do_hsdk_go, + "Synopsys HSDK specific command", + " - Boot stand-alone application on HSDK\n" + "hsdk_go halt - Boot stand-alone application on HSDK, halt CPU just before application run\n" +); + +static int do_hsdk_init(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) +{ + static bool done = false; + int ret; + + /* hsdk_init can be run only once */ + if (done) { + printf("HSDK HW is already initialized! Please reset the board if you want to change the configuration.\n"); + return CMD_RET_FAILURE; + } + + ret = prepare_cpus(); + if (!ret) + done = true; + + return ret ? CMD_RET_FAILURE : CMD_RET_SUCCESS; +} + +U_BOOT_CMD( + hsdk_init, 1, 0, do_hsdk_init, + "Synopsys HSDK specific command", + "- Init HSDK HW\n" +); + +static int do_hsdk_clock_set(cmd_tbl_t *cmdtp, int flag, int argc, + char *const argv[]) +{ + int ret = 0; + + /* Strip off leading subcommand argument */ + argc--; + argv++; + + envs_cleanup_common(env_map_clock); + + if (!argc) { + printf("Set clocks to values specified in environment\n"); + ret = envs_read_common(env_map_clock); + } else { + printf("Set clocks to values specified in args\n"); + ret = args_envs_enumerate(env_map_clock, 2, argc, argv); + } + + if (ret) + return CMD_RET_FAILURE; + + ret = envs_validate_common(env_map_clock); + if (ret) + return CMD_RET_FAILURE; + + /* Setup clock tree HW */ + setup_clocks(); + + return CMD_RET_SUCCESS; +} + +static int do_hsdk_clock_get(cmd_tbl_t *cmdtp, int flag, int argc, + char *const argv[]) +{ + ulong rate; + + if (soc_clk_ctl("cpu-clk", &rate, CLK_GET | CLK_MHZ)) + return CMD_RET_FAILURE; + + if (env_set_ulong("cpu_freq", rate)) + return CMD_RET_FAILURE; + + if (soc_clk_ctl("tun-clk", &rate, CLK_GET | CLK_MHZ)) + return CMD_RET_FAILURE; + + if (env_set_ulong("tun_freq", rate)) + return CMD_RET_FAILURE; + + if (soc_clk_ctl("axi-clk", &rate, CLK_GET | CLK_MHZ)) + return CMD_RET_FAILURE; + + if (env_set_ulong("axi_freq", rate)) + return CMD_RET_FAILURE; + + printf("Clock values are saved to environment\n"); + + return CMD_RET_SUCCESS; +} + +static int do_hsdk_clock_print(cmd_tbl_t *cmdtp, int flag, int argc, + char *const argv[]) +{ + /* Main clocks */ + soc_clk_ctl("cpu-clk", NULL, CLK_PRINT | CLK_MHZ); + soc_clk_ctl("tun-clk", NULL, CLK_PRINT | CLK_MHZ); + soc_clk_ctl("axi-clk", NULL, CLK_PRINT | CLK_MHZ); + soc_clk_ctl("ddr-clk", NULL, CLK_PRINT | CLK_MHZ); + + return CMD_RET_SUCCESS; +} + +static int do_hsdk_clock_print_all(cmd_tbl_t *cmdtp, int flag, int argc, + char *const argv[]) +{ + /* + * NOTE: as of today we don't use some peripherals like HDMI / EBI + * so we don't want to print their clocks ("hdmi-sys-clk", "hdmi-pll", + * "hdmi-clk", "ebi-clk"). Nevertheless their clock subsystems is fully + * functional and we can print their clocks if it is required + */ + + /* CPU clock domain */ + soc_clk_ctl("cpu-pll", NULL, CLK_PRINT | CLK_MHZ); + soc_clk_ctl("cpu-clk", NULL, CLK_PRINT | CLK_MHZ); + printf("\n"); + + /* SYS clock domain */ + soc_clk_ctl("sys-pll", NULL, CLK_PRINT | CLK_MHZ); + soc_clk_ctl("apb-clk", NULL, CLK_PRINT | CLK_MHZ); + soc_clk_ctl("axi-clk", NULL, CLK_PRINT | CLK_MHZ); + soc_clk_ctl("eth-clk", NULL, CLK_PRINT | CLK_MHZ); + soc_clk_ctl("usb-clk", NULL, CLK_PRINT | CLK_MHZ); + soc_clk_ctl("sdio-clk", NULL, CLK_PRINT | CLK_MHZ); +/* soc_clk_ctl("hdmi-sys-clk", NULL, CLK_PRINT | CLK_MHZ); */ + soc_clk_ctl("gfx-core-clk", NULL, CLK_PRINT | CLK_MHZ); + soc_clk_ctl("gfx-dma-clk", NULL, CLK_PRINT | CLK_MHZ); + soc_clk_ctl("gfx-cfg-clk", NULL, CLK_PRINT | CLK_MHZ); + soc_clk_ctl("dmac-core-clk", NULL, CLK_PRINT | CLK_MHZ); + soc_clk_ctl("dmac-cfg-clk", NULL, CLK_PRINT | CLK_MHZ); + soc_clk_ctl("sdio-ref-clk", NULL, CLK_PRINT | CLK_MHZ); + soc_clk_ctl("spi-clk", NULL, CLK_PRINT | CLK_MHZ); + soc_clk_ctl("i2c-clk", NULL, CLK_PRINT | CLK_MHZ); +/* soc_clk_ctl("ebi-clk", NULL, CLK_PRINT | CLK_MHZ); */ + soc_clk_ctl("uart-clk", NULL, CLK_PRINT | CLK_MHZ); + printf("\n"); + + /* DDR clock domain */ + soc_clk_ctl("ddr-clk", NULL, CLK_PRINT | CLK_MHZ); + printf("\n"); + + /* HDMI clock domain */ +/* soc_clk_ctl("hdmi-pll", NULL, CLK_PRINT | CLK_MHZ); */ +/* soc_clk_ctl("hdmi-clk", NULL, CLK_PRINT | CLK_MHZ); */ +/* printf("\n"); */ + + /* TUN clock domain */ + soc_clk_ctl("tun-pll", NULL, CLK_PRINT | CLK_MHZ); + soc_clk_ctl("tun-clk", NULL, CLK_PRINT | CLK_MHZ); + soc_clk_ctl("rom-clk", NULL, CLK_PRINT | CLK_MHZ); + soc_clk_ctl("pwm-clk", NULL, CLK_PRINT | CLK_MHZ); + printf("\n"); + + return CMD_RET_SUCCESS; +} + +cmd_tbl_t cmd_hsdk_clock[] = { + U_BOOT_CMD_MKENT(set, 3, 0, do_hsdk_clock_set, "", ""), + U_BOOT_CMD_MKENT(get, 3, 0, do_hsdk_clock_get, "", ""), + U_BOOT_CMD_MKENT(print, 4, 0, do_hsdk_clock_print, "", ""), + U_BOOT_CMD_MKENT(print_all, 4, 0, do_hsdk_clock_print_all, "", ""), +}; + +static int do_hsdk_clock(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) +{ + cmd_tbl_t *c; + + if (argc < 2) + return CMD_RET_USAGE; + + /* Strip off leading 'hsdk_clock' command argument */ + argc--; + argv++; + + c = find_cmd_tbl(argv[0], cmd_hsdk_clock, ARRAY_SIZE(cmd_hsdk_clock)); + if (!c) + return CMD_RET_USAGE; + + return c->cmd(cmdtp, flag, argc, argv); +} + +U_BOOT_CMD( + hsdk_clock, CONFIG_SYS_MAXARGS, 0, do_hsdk_clock, + "Synopsys HSDK specific clock command", + "set - Set clock to values specified in environment / command line arguments\n" + "hsdk_clock get - Save clock values to environment\n" + "hsdk_clock print - Print main clock values to console\n" + "hsdk_clock print_all - Print all clock values to console\n" +); + +/* init calls */ +int board_early_init_f(void) +{ + /* + * Setup AXI apertures unconditionally as we want to have DDR + * in 0x00000000 region when we are kicking slave cpus. + */ + init_memory_bridge(); + + return 0; +} + +int board_early_init_r(void) +{ + /* + * TODO: Init USB here to be able read environment from USB MSD. + * It can be done with usb_init() call. We can't do it right now + * due to brocken USB IP SW reset and lack of USB IP HW reset in + * linux kernel (if we init USB here we will break USB in linux) + */ + + /* + * Flush all d$ as we want to use uncached area with st.di / ld.di + * instructions and we don't want to have any dirty line in L1d$ or SL$ + * in this area. It is enough to flush all d$ once here as we access to + * uncached area with regular st (non .di) instruction only when we copy + * data during u-boot relocation. + */ flush_dcache_all(); + + printf("Relocation Offset is: %08lx\n", gd->reloc_off); + + return 0; }
-void smp_kick_all_cpus(void) +int board_late_init(void) { -#define BITS_START_CORE1 1 -#define BITS_START_CORE2 2 -#define BITS_START_CORE3 3 + /* + * Populate environment with clock frequency values - + * run hsdk_clock get callback without uboot command run. + */ + do_hsdk_clock_get(NULL, 0, 0, NULL);
- int cmd = readl((void __iomem *)CREG_CPU_START); + return 0; +}
- cmd |= (1 << BITS_START_CORE1) | - (1 << BITS_START_CORE2) | - (1 << BITS_START_CORE3); - writel(cmd, (void __iomem *)CREG_CPU_START); +int board_mmc_init(bd_t *bis) +{ + struct dwmci_host *host = NULL; + + host = malloc(sizeof(struct dwmci_host)); + if (!host) { + printf("dwmci_host malloc fail!\n"); + return 1; + } + + /* + * Switch SDIO external ciu clock divider from default div-by-8 to + * minimum possible div-by-2. + */ + writel(SDIO_UHS_REG_EXT_DIV_2, (void __iomem *)SDIO_UHS_REG_EXT); + + memset(host, 0, sizeof(struct dwmci_host)); + host->name = "Synopsys Mobile storage"; + host->ioaddr = (void *)ARC_DWMMC_BASE; + host->buswidth = 4; + host->dev_index = 0; + host->bus_hz = 50000000; + + add_dwmci(host, host->bus_hz / 2, 400000); + + return 0; } diff --git a/configs/hsdk_defconfig b/configs/hsdk_defconfig index 11cb7e03a6..c72ee2d0c1 100644 --- a/configs/hsdk_defconfig +++ b/configs/hsdk_defconfig @@ -7,13 +7,16 @@ CONFIG_DEFAULT_DEVICE_TREE="hsdk" CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200n8" CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="hsdk# " +CONFIG_CMD_ENV_FLAGS=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_MMC=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y @@ -25,6 +28,7 @@ CONFIG_ENV_FAT_INTERFACE="mmc" CONFIG_ENV_FAT_DEVICE_AND_PART="0:1" CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y +CONFIG_CLK_HSDK=y CONFIG_MMC=y CONFIG_MMC_DW=y CONFIG_DM_ETH=y diff --git a/include/configs/hsdk.h b/include/configs/hsdk.h index fb4829ab46..ac86f31142 100644 --- a/include/configs/hsdk.h +++ b/include/configs/hsdk.h @@ -12,6 +12,7 @@ /* * CPU configuration */ +#define NR_CPUS 4 #define ARC_PERIPHERAL_BASE 0xF0000000 #define ARC_DWMMC_BASE (ARC_PERIPHERAL_BASE + 0xA000) #define ARC_DWGMAC_BASE (ARC_PERIPHERAL_BASE + 0x18000) @@ -61,6 +62,50 @@ */ #define CONFIG_ENV_SIZE SZ_16K
+#define CONFIG_EXTRA_ENV_SETTINGS \ + "core_dccm_0=0x10\0" \ + "core_dccm_1=0x6\0" \ + "core_dccm_2=0x10\0" \ + "core_dccm_3=0x6\0" \ + "core_iccm_0=0x10\0" \ + "core_iccm_1=0x6\0" \ + "core_iccm_2=0x10\0" \ + "core_iccm_3=0x6\0" \ + "core_mask=0xF\0" \ + "dcache_ena=0x1\0" \ + "icache_ena=0x1\0" \ + "non_volatile_limit=0xE\0" \ + "hsdk_hs34=setenv core_mask 0x2; setenv icache_ena 0x0; \ +setenv dcache_ena 0x0; setenv core_iccm_1 0x7; \ +setenv core_dccm_1 0x8; setenv non_volatile_limit 0x0;\0" \ + "hsdk_hs36=setenv core_mask 0x1; setenv icache_ena 0x1; \ +setenv dcache_ena 0x1; setenv core_iccm_0 0x10; \ +setenv core_dccm_0 0x10; setenv non_volatile_limit 0xE;\0" \ + "hsdk_hs36_ccm=setenv core_mask 0x2; setenv icache_ena 0x1; \ +setenv dcache_ena 0x1; setenv core_iccm_1 0x7; \ +setenv core_dccm_1 0x8; setenv non_volatile_limit 0xE;\0" \ + "hsdk_hs38=setenv core_mask 0x1; setenv icache_ena 0x1; \ +setenv dcache_ena 0x1; setenv core_iccm_0 0x10; \ +setenv core_dccm_0 0x10; setenv non_volatile_limit 0xE;\0" \ + "hsdk_hs38_ccm=setenv core_mask 0x2; setenv icache_ena 0x1; \ +setenv dcache_ena 0x1; setenv core_iccm_1 0x7; \ +setenv core_dccm_1 0x8; setenv non_volatile_limit 0xE;\0" \ + "hsdk_hs38x2=setenv core_mask 0x3; setenv icache_ena 0x1; \ +setenv dcache_ena 0x1; setenv core_iccm_0 0x10; \ +setenv core_dccm_0 0x10; setenv non_volatile_limit 0xE; \ +setenv core_iccm_1 0x6; setenv core_dccm_1 0x6;\0" \ + "hsdk_hs38x3=setenv core_mask 0x7; setenv icache_ena 0x1; \ +setenv dcache_ena 0x1; setenv core_iccm_0 0x10; \ +setenv core_dccm_0 0x10; setenv non_volatile_limit 0xE; \ +setenv core_iccm_1 0x6; setenv core_dccm_1 0x6; \ +setenv core_iccm_2 0x10; setenv core_dccm_2 0x10;\0" \ + "hsdk_hs38x4=setenv core_mask 0xF; setenv icache_ena 0x1; \ +setenv dcache_ena 0x1; setenv core_iccm_0 0x10; \ +setenv core_dccm_0 0x10; setenv non_volatile_limit 0xE; \ +setenv core_iccm_1 0x6; setenv core_dccm_1 0x6; \ +setenv core_iccm_2 0x10; setenv core_dccm_2 0x10; \ +setenv core_iccm_3 0x6; setenv core_dccm_3 0x6;\0" + /* * Environment configuration */ @@ -68,12 +113,17 @@ #define CONFIG_LOADADDR CONFIG_SYS_LOAD_ADDR
/* - * Console configuration + * Misc utility configuration */ +#define CONFIG_BOUNCE_BUFFER + +/* Cli configuration */ +#define CONFIG_SYS_CBSIZE SZ_2K
/* - * Misc utility configuration + * Callback configuration */ -#define CONFIG_BOUNCE_BUFFER +#define CONFIG_BOARD_EARLY_INIT_R +#define CONFIG_BOARD_LATE_INIT
#endif /* _CONFIG_HSDK_H_ */
Hi Tom,
I was about to send you a pull-request containing this one but decided to give TravisCI a shot. And what I got was a warning due to not yet supported "naked" attribute in GCC 6.x for ARC, see https://travis-ci.org/abrodkin/u-boot/jobs/360259472
Ok I bumped ARC tools to the most recent arc-2017.09 based on GCC 7.1 where "naked" attr for ARC is already supported. But then I got another warning: --------------------->8----------------------- board/synopsys/hsdk/hsdk.c: In function "hsdk_core_init_f": board/synopsys/hsdk/hsdk.c:345:1: error: stack usage computation not supported for this target [-Werror] } ^ --------------------->8----------------------- see https://travis-ci.org/abrodkin/u-boot/jobs/360274604
That happens because GCC for ARC unconditionally tries to compute stack requirements for all functions even if they are "naked". And for "naked" computed value is negative thus the warning above.
So far I didn't manage to find a simple way to disable that warning.
And my question would be how to proceed with this [patch]? Given we're seeing a problem in GCC it most probably won't be fixed in U-Boot and we'll need to wait before new tools are available.
Or otherwise we'll start to see "failing" ARC jobs in TravisCI.
-Alexey
On Fri, Mar 30, 2018 at 08:08:19PM +0000, Alexey Brodkin wrote:
Hi Tom,
Ugh. (a) get the toolchain fixed to support this correctly and (b) kludge scripts/gcc-stack-usage.sh to have a 'naked' example too so that we'll just disable -fstack-usage on ARC for now.
HSDK board has sst26wf016 spi flash IC which we want to support.
Add SPI controller, CS-gpio and SPI flash nodes to hsdk device tree. Enable corresponding options in hsdk defconfig.
Signed-off-by: Eugeniy Paltsev Eugeniy.Paltsev@synopsys.com --- arch/arc/dts/hsdk.dts | 26 ++++++++++++++++++++++++++ configs/hsdk_defconfig | 9 +++++++++ 2 files changed, 35 insertions(+)
diff --git a/arch/arc/dts/hsdk.dts b/arch/arc/dts/hsdk.dts index 09f3fe9a37..4bb3035d53 100644 --- a/arch/arc/dts/hsdk.dts +++ b/arch/arc/dts/hsdk.dts @@ -14,6 +14,7 @@
aliases { console = &uart0; + spi0 = &spi0; };
cpu_card { @@ -83,4 +84,29 @@ compatible = "generic-ohci"; reg = <0xf0060000 0x100>; }; + + spi0: spi@f0020000 { + compatible = "snps,dw-apb-ssi"; + reg = <0xf0020000 0x1000>; + #address-cells = <1>; + #size-cells = <0>; + spi-max-frequency = <4000000>; + clocks = <&cgu_clk CLK_SYS_SPI_REF>; + clock-names = "spi_clk"; + cs-gpio = <&cs_gpio 0>; + spi_flash@0 { + compatible = "spi-flash"; + reg = <0>; + spi-max-frequency = <4000000>; + }; + }; + + cs_gpio: gpio@f00114B0 { + compatible = "snps,hsdk-creg-gpio"; + reg = <0xf00014B0 0x4>; + gpio-controller; + #gpio-cells = <1>; + gpio-bank-name = "hsdk-spi-cs"; + gpio-count = <1>; + }; }; diff --git a/configs/hsdk_defconfig b/configs/hsdk_defconfig index c72ee2d0c1..476ce6a974 100644 --- a/configs/hsdk_defconfig +++ b/configs/hsdk_defconfig @@ -12,6 +12,8 @@ CONFIG_SYS_PROMPT="hsdk# " CONFIG_CMD_ENV_FLAGS=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y @@ -29,12 +31,19 @@ CONFIG_ENV_FAT_DEVICE_AND_PART="0:1" CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_CLK_HSDK=y +CONFIG_DM_GPIO=y +CONFIG_HSDK_CREG_GPIO=y CONFIG_MMC=y CONFIG_MMC_DW=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_SST=y CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y CONFIG_DM_SERIAL=y CONFIG_SYS_NS16550=y +CONFIG_DM_SPI=y +CONFIG_DESIGNWARE_SPI=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y
Hi Eugeniy,
IMHO it worth adding a mention about dependency on SST flash patches. Also I'd add justification to GPIO addition in defconfig.
spi0 = &spi0;
cpu_card {
- spi0: spi@f0020000 {
#size-cells = <0>;
spi_flash@0 {
reg = <0>;
- cs_gpio: gpio@f00114B0 {
Hm "reg" value doesn't match node name: f00114B0 vs f00014B0. Which one is correct?
gpio-controller;
#gpio-cells = <1>;
gpio-count = <1>;
-Alexey
On Mon, 2018-03-26 at 13:45 +0000, Alexey Brodkin wrote:
Hi Eugeniy,
spi0 = &spi0;
cpu_card {
#size-cells = <0>;
spi_flash@0 {
reg = <0>;
"reg" value is correct. So node name should be: ------------->8-------------- cs_gpio: gpio@f00014b0 { ------------->8--------------
gpio-controller;
#gpio-cells = <1>;
gpio-count = <1>;
-Alexey
Alexey Brodkin
Eugeniy Paltsev
