[U-Boot] {Spam?} NetRxPackets
ether.c contains the following code :
req->buf = (u8 *) NetRxPackets[0]; req->length = size; req->complete = rx_complete;
retval = usb_ep_queue(dev->out_ep, req, gfp_flags);
My USB controller code that I'm writing responds that req->buf is NULL. So the OUT packets don't get processed. I know OUT data arrives in my controller code as I can read it, so my OUT endpoint is working. Also my status endpoint is working correctly and my guess is there's nothing wrong with my controller code.
Anyone have an idea how NetRxPackets is allocated ?
Best regards, Marcel
Nobody ?
This is returning an non existing buffer for some reason and I know not much about the ethernet layer to fix this. My guess is I miss some define (eth related) somewhere but I'm also about to give up on ether.c and just port a more simple driver to u-boot for testing USB device controller drivers.
Any ideas why this could happen or how I can find out why that is ?
Dear Marcel,
Nobody ?
Well,you're supposed to do some basic code reading yourself.
But you know how to use the search function in your favorite editor, and tools like for example ctags or grep?
Hint: have a look at "net/net.c".
And note: as NetRxPackets[] is a static array I can't see how NetRxPackets[0] should be a "non existing buffer".
Hi Wolfgang,
Nobody ?
Of course. It's always the idea to post a question after reading for some time. It either means I don't understand the code, the code really doesn't work or I did miss the most important part in the documents. I guess the answer will follow once the issue is solved. To be specific, I work with the u-boot-usb at91-cdc branch code. I'm not sure if that is all working code at this moment but sounded like the best starting point for my USB code.
I found that, but it doesn't make sense to me. I'll read it again and hopefully it makes sense to me than. Anyway, my knowledge of the ethernet part in u-boot is limited and I do not focus on ethernet. I will not use ether.c in the end anyway and I was just hoping it would work as a basis to test my new controller code.
Well, I guess the point where that's done doesn't show up nicely with grep. I probably missed it and will start to read the ethernet code. I know little of the ethernet code so I feel that as of tomorrow I will skip ether.c and move on to implementing another driver for testing my controller code.
My feeling is that I miss something very simple, but I can be looking for it for days. Perhaps I missed some define or whatever, but I'm almost certain that I missed something extremely simple that causes NetRxPackets to be empty somehow.
regards, Marcel
Dear Marcel,
Come on. You will find a static array declaration when you know the exact name of the file and the variable, right?
On Tuesday, January 18, 2011 11:53:38 pm Wolfgang Denk wrote:
Dear Marcel,
Well finding it is not the issue. I can't find a reason why it wouldn't work.
Regards, Marcel
Dear Marcel,
Not sure that branch is anything up to date....
*maybe* "req" itself is not allocated?
Best Regards, Reinhard
On Tuesday, January 18, 2011 11:54:22 pm Reinhard Meyer wrote:
Dear Marcel,
hmmm. What branch is best to work on for this code ?
Good question. My code that rejects the buffer is this :
static int usba_ep_queue(struct usb_ep *_ep, struct usb_request *_req, gfp_t gfp_flags) { struct usba_request *req = container_of(_req, struct usba_request, req); struct usba_ep *ep = container_of(_ep, struct usba_ep, ep); struct usba_udc *udc = ep->udc; int ret;
debug("%s: queue req %p, len %u\n", ep->ep.name, req, _req->length);
if (!_req || !_req->complete || !_req->buf || !list_empty(&req->queue)) {
DBG("invalid request\n"); if(!_req) debug("NO REQUEST\n"); if(!_req->complete) debug("NO REQUEST COMPLETE\n"); if(!_req->buf) debug("NO REQUEST BUF\n"); if(!list_empty(&req->queue)) debug("NO LIST EMPTY\n"); return -EINVAL; }
It just keeps failing with "NO REQUEST BUF". I feel like I'm staring at a typo for days and just don't see it.
regards, Marcel
Hi Marcel,
If someone sends USB-CDC patches they usually are applied into master branch of u-boot-usb.git repository: http://git.denx.de/cgi-bin/gitweb.cgi?p=u-boot/u-boot-usb.git;a=summary
AFAIK, master branch of u-boot main repository is also working well, but I haven't checked whether all recent patches are pulled into main repository. If you are using another version of u-boot (one of the previous releases) the driver in your version may be broken.
According to the log from "Usage of DMA" thread I think your gadget stack is up to date.
[...] if (!_req || !_req->complete || !_req->buf || !list_empty(&req->queue)) {
I suppose that usage of kzalloc in usba_ep_alloc_request (if you haven't changed it) may be not well. at91_udc driver (for example) uses static pool for requests allocation.
Anyway it's strange. I have a suspicion that buf was set to NULL somewhere inside atmel_usba_udc.
____ With best regards, Vitaly.
Marcel
Reinhard Meyer
Vitaly Kuzmichev
