[U-Boot] Please pull u-boot-video/master
Hi Tom,
The following changes since commit 22f3368e71321db1e0e15dfbf54b052367890ec7:
Merge branch 'master' of git://git.denx.de/u-boot-mips (2017-05-13 16:45:35 -0400)
git://git.denx.de/u-boot-video.git master
for you to fetch changes up to 940aed8f6bacfc8c0dbaf9da0008e0a6a76463a8:
sunxi: Add clock support for TV encoder (2017-05-15 21:22:57 +0200)
---------------------------------------------------------------- Jernej Skrabec (5): edid: Set timings flags according to edid edid: Add HDMI flag to timing info video: dw_hdmi: Select HDMI mode only if monitor supports it sunxi: video: Split out TVE code sunxi: Add clock support for TV encoder
Philipp Tomsich (2): rockchip: video: introduce VIDEO_DW_HDMI and select for Rockchip HDMI video: bmp: rename CONFIG_BMP_24BMP to CONFIG_BMP_24BPP
arch/arm/include/asm/arch-sunxi/clock_sun6i.h | 8 +- arch/arm/include/asm/arch-sunxi/display.h | 107 --------------------- arch/arm/include/asm/arch-sunxi/tve.h | 131 ++++++++++++++++++++++++++ common/edid.c | 56 +++++++++++ common/lcd.c | 4 +- drivers/video/Kconfig | 9 ++ drivers/video/Makefile | 1 + drivers/video/dw_hdmi.c | 31 +++--- drivers/video/rockchip/Kconfig | 1 + drivers/video/rockchip/Makefile | 2 +- drivers/video/sunxi/Makefile | 2 +- drivers/video/sunxi/sunxi_display.c | 73 +++----------- drivers/video/sunxi/tve.c | 86 +++++++++++++++++ drivers/video/video_bmp.c | 4 +- include/configs/brxre1.h | 2 +- include/edid.h | 14 +++ include/fdtdec.h | 1 + scripts/config_whitelist.txt | 1 - 18 files changed, 341 insertions(+), 192 deletions(-) create mode 100644 arch/arm/include/asm/arch-sunxi/tve.h create mode 100644 drivers/video/sunxi/tve.c
Please pull. Thanks!
Anatolij
On Tue, May 16, 2017 at 12:05:48AM +0200, Anatolij Gustschin wrote:
Hi Tom,
Anatolij Gustschin
