[U-Boot] Pull request u-boot-arm
The following changes since commit 201532a69cf7e7a84bff354fdab45947425d22b4:
Merge branch 'master' of ../master (2010-08-10 22:20:27 +0200)
git://git.denx.de/u-boot-arm.git master
Albert Aribaud (6): ide: add configuration ide: reorder object files alphabetically ide: add mvsata_ide driver cmd_ide: add support for orion5x edminiv2: add mvsata_ide and cmd_ide support orion5x: allow overriding default mappings windows
Li Haibo (1): MX51EVK: fix return value of get_timer_masked
Prafulla Wadaskar (2): cmd_ide: add support for Kirkwood Kirkwood: openrd_base: Added SATA support
Reinhard Meyer (1): fix cmd_mmc.c, line 136 missing "
Steve Sakoman (8): ARMV7: Add pad mux support for OMAP4 ARMV7: Fix udelay for OMAP4 ARMV7: Modify i2c driver for more reliable operation on OMAP4 ARMV7: Add support for the TWL6030 I2C power chip used in OMAP4 systems ARMV7: Restructure omap3 musb driver to allow code sharing between OMAP3 and OMAP4 ARMV7: Enable musb driver and usbtty on OMAP4430 SDP ARMV7: Enable musb driver and usbtty on OMAP4 Panda ARMV7: Update default environment for OMAP4 boards
arch/arm/cpu/arm926ejs/orion5x/cpu.c | 40 ++-- arch/arm/cpu/armv7/mx51/timer.c | 2 +- arch/arm/cpu/armv7/omap-common/timer.c | 9 - arch/arm/cpu/armv7/omap4/board.c | 11 + arch/arm/include/asm/arch-kirkwood/kirkwood.h | 5 + arch/arm/include/asm/arch-omap3/cpu.h | 3 + arch/arm/include/asm/arch-omap3/i2c.h | 4 +- arch/arm/include/asm/arch-omap4/cpu.h | 3 + arch/arm/include/asm/arch-omap4/mux_omap4.h | 344 +++++++++++++++++++++++++ arch/arm/include/asm/arch-omap4/omap4.h | 2 + arch/arm/include/asm/arch-omap4/sys_proto.h | 1 + arch/arm/include/asm/arch-orion5x/cpu.h | 98 ++++++-- arch/arm/include/asm/arch-orion5x/orion5x.h | 3 + arch/powerpc/include/asm/config.h | 3 + board/ti/panda/panda.c | 26 ++ board/ti/panda/panda.h | 265 +++++++++++++++++++ board/ti/sdp4430/sdp.c | 26 ++ board/ti/sdp4430/sdp.h | 265 +++++++++++++++++++ common/cmd_ide.c | 25 ++- common/cmd_mmc.c | 2 +- doc/README.PXA_CF | 8 + drivers/block/Makefile | 7 +- drivers/block/mvsata_ide.c | 140 ++++++++++ drivers/i2c/omap24xx_i2c.c | 31 ++- drivers/i2c/omap24xx_i2c.h | 4 + drivers/power/Makefile | 1 + drivers/power/twl6030.c | 78 ++++++ drivers/usb/musb/omap3.c | 16 ++ drivers/usb/musb/omap3.h | 3 +- include/configs/ap325rxa.h | 1 + include/configs/edminiv2.h | 34 +++- include/configs/ms7720se.h | 1 + include/configs/omap4_panda.h | 26 ++- include/configs/omap4_sdp4430.h | 26 ++- include/configs/openrd_base.h | 31 +++ include/configs/r2dplus.h | 1 + include/configs/r7780mp.h | 1 + include/twl6030.h | 91 +++++++ 38 files changed, 1556 insertions(+), 81 deletions(-) create mode 100644 arch/arm/include/asm/arch-omap4/mux_omap4.h create mode 100644 board/ti/panda/panda.h create mode 100644 board/ti/sdp4430/sdp.h create mode 100644 drivers/block/mvsata_ide.c create mode 100644 drivers/power/twl6030.c create mode 100644 include/twl6030.h
