[U-Boot-Users] [PATCH 1/2] Update linux bootm to support ePAPR client interface
the ePAPR spec has some subtle differences from the current device tree based boot interface to the powerpc linux kernel. The powerpc linux kernel currently ignores the differences that ePAPR specifies.
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- lib_ppc/bootm.c | 33 +++++++++++++++++++++++---------- 1 files changed, 23 insertions(+), 10 deletions(-)
diff --git a/lib_ppc/bootm.c b/lib_ppc/bootm.c index 81803dd..d141fae 100644 --- a/lib_ppc/bootm.c +++ b/lib_ppc/bootm.c @@ -80,7 +80,8 @@ do_bootm_linux(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[], ulong cmd_start, cmd_end, bootmap_base; bd_t *kbd; ulong ep = 0; - void (*kernel)(bd_t *, ulong, ulong, ulong, ulong); + void (*kernel)(bd_t *, ulong r4, ulong r5, ulong r6, + ulong r7, ulong r8, ulong r9); int ret; ulong of_size = 0; struct lmb *lmb = images->lmb; @@ -166,8 +167,8 @@ do_bootm_linux(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[], puts ("Could not find kernel entry point!\n"); goto error; } - kernel = (void (*)(bd_t *, ulong, ulong, ulong, ulong))ep; - + kernel = (void (*)(bd_t *, ulong, ulong, ulong, + ulong, ulong, ulong))ep; /* find ramdisk */ ret = boot_get_ramdisk (argc, argv, images, IH_ARCH_PPC, &rd_data_start, &rd_data_end); @@ -284,14 +285,23 @@ do_bootm_linux(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[], if (of_flat_tree) { /* device tree; boot new style */ /* * Linux Kernel Parameters (passing device tree): - * r3: pointer to the fdt, followed by the board info data - * r4: physical pointer to the kernel itself - * r5: NULL - * r6: NULL - * r7: NULL + * r3: pointer to the fdt + * r4: 0 + * r5: 0 + * r6: epapr magic + * r7: size of IMA in bytes + * r8: 0 + * r9: 0 */ +#if defined(CONFIG_85xx) || defined(CONFIG_440) + #define EPAPR_MAGIC (0x45504150) +#else + #define EPAPR_MAGIC (0x65504150) +#endif + debug (" Booting using OF flat tree...\n"); - (*kernel) ((bd_t *)of_flat_tree, (ulong)kernel, 0, 0, 0); + (*kernel) ((bd_t *)of_flat_tree, 0, 0, EPAPR_MAGIC, + CFG_BOOTMAPSZ, 0, 0); /* does not return */ } else #endif @@ -303,9 +313,12 @@ do_bootm_linux(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[], * r5: initrd_end - unused if r4 is 0 * r6: Start of command line string * r7: End of command line string + * r8: 0 + * r9: 0 */ debug (" Booting using board info...\n"); - (*kernel) (kbd, initrd_start, initrd_end, cmd_start, cmd_end); + (*kernel) (kbd, initrd_start, initrd_end, + cmd_start, cmd_end, 0, 0); /* does not return */ } return ;
if the environment variable 'no_ft_board_setup' is set we skip doing the ft_board_setup().
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- lib_ppc/bootm.c | 3 ++- 1 files changed, 2 insertions(+), 1 deletions(-)
diff --git a/lib_ppc/bootm.c b/lib_ppc/bootm.c index d141fae..1fce037 100644 --- a/lib_ppc/bootm.c +++ b/lib_ppc/bootm.c @@ -193,7 +193,8 @@ do_bootm_linux(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[], } #ifdef CONFIG_OF_BOARD_SETUP /* Call the board-specific fixup routine */ - ft_board_setup(of_flat_tree, gd->bd); + if (!getenv("no_ft_board_setup")) + ft_board_setup(of_flat_tree, gd->bd); #endif }
Kumar Gala
