Fix typos in the 'test/dm' directory.
Yuepeng Xing (1): test:dm:fix typo
test/dm/blk.c | 2 +- test/dm/button.c | 4 ++-- test/dm/gpio.c | 4 ++-- test/dm/host.c | 2 +- test/dm/remoteproc.c | 2 +- test/dm/scmi.c | 2 +- test/dm/spmi.c | 2 +- test/dm/test-fdt.c | 2 +- 8 files changed, 10 insertions(+), 10 deletions(-)
Signed-off-by: Yuepeng Xing xingyuepeng@eswincomputing.com --- test/dm/blk.c | 2 +- test/dm/button.c | 4 ++-- test/dm/gpio.c | 4 ++-- test/dm/host.c | 2 +- test/dm/remoteproc.c | 2 +- test/dm/scmi.c | 2 +- test/dm/spmi.c | 2 +- test/dm/test-fdt.c | 2 +- 8 files changed, 10 insertions(+), 10 deletions(-)
diff --git a/test/dm/blk.c b/test/dm/blk.c index 612f3ffb32..0aa04c64ef 100644 --- a/test/dm/blk.c +++ b/test/dm/blk.c @@ -127,7 +127,7 @@ static int dm_test_blk_devnum(struct unit_test_state *uts)
/* * Probe the devices, with the first one being probed last. This is the - * one with no alias / sequence numnber. + * one with no alias / sequence number. */ ut_assertok(uclass_get_device(UCLASS_MMC, 1, &dev)); ut_assertok(uclass_get_device(UCLASS_MMC, 2, &dev)); diff --git a/test/dm/button.c b/test/dm/button.c index f8a7fab61d..e76c1ad030 100644 --- a/test/dm/button.c +++ b/test/dm/button.c @@ -46,7 +46,7 @@ static int dm_test_button_gpio(struct unit_test_state *uts) struct udevice *dev, *gpio;
/* - * Check that we can manipulate an BUTTON. BUTTON 1 is connected to GPIO + * Check that we can manipulate a BUTTON. BUTTON 1 is connected to GPIO * bank gpio_a, offset 3. */ ut_assertok(uclass_get_device(UCLASS_BUTTON, 1, &dev)); @@ -64,7 +64,7 @@ static int dm_test_button_gpio(struct unit_test_state *uts) } DM_TEST(dm_test_button_gpio, UT_TESTF_SCAN_PDATA | UT_TESTF_SCAN_FDT);
-/* Test obtaining an BUTTON by label */ +/* Test obtaining a BUTTON by label */ static int dm_test_button_label(struct unit_test_state *uts) { struct udevice *dev, *cmp; diff --git a/test/dm/gpio.c b/test/dm/gpio.c index a8c35d4370..0d88ec24bd 100644 --- a/test/dm/gpio.c +++ b/test/dm/gpio.c @@ -348,7 +348,7 @@ static int dm_test_gpio_phandles(struct unit_test_state *uts) ut_asserteq(-ENOENT, gpio_request_by_name(dev, "test-gpios", 5, &desc, 0));
- /* Last GPIO is ignord as it comes after <0> */ + /* Last GPIO is ignored as it comes after <0> */ ut_asserteq(3, gpio_request_list_by_name(dev, "test-gpios", desc_list, ARRAY_SIZE(desc_list), 0)); ut_asserteq(-EBUSY, gpio_request_list_by_name(dev, "test-gpios", @@ -377,7 +377,7 @@ static int dm_test_gpio_phandles(struct unit_test_state *uts) ut_asserteq(6, gpio_request_list_by_name(dev, "test2-gpios", desc_list, ARRAY_SIZE(desc_list), 0));
- /* This was set to output previously but flags resetted to 0 = INPUT */ + /* This was set to output previously but flags reset to 0 = INPUT */ ut_asserteq(0, sandbox_gpio_get_flags(gpio_a, 1)); ut_asserteq(GPIOF_INPUT, gpio_get_function(gpio_a, 1, NULL));
diff --git a/test/dm/host.c b/test/dm/host.c index 4dafc24abb..355ba7770a 100644 --- a/test/dm/host.c +++ b/test/dm/host.c @@ -132,7 +132,7 @@ static int dm_test_cmd_host(struct unit_test_state *uts)
ut_assertok(run_commandf("host bind fat %s", filename2));
- /* Check it is not removeable (no '-r') */ + /* Check it is not removable (no '-r') */ ut_assertok(uclass_next_device_err(&dev)); ut_assertok(blk_get_from_parent(dev, &blk)); desc = dev_get_uclass_plat(blk); diff --git a/test/dm/remoteproc.c b/test/dm/remoteproc.c index 1cc07bc808..915c1f67ca 100644 --- a/test/dm/remoteproc.c +++ b/test/dm/remoteproc.c @@ -139,7 +139,7 @@ static int dm_test_remoteproc_elf(struct unit_test_state *uts) 0x20, 0x00, 0x00, 0x00, /* memsz = filesz */ 0x20, 0x00, 0x00, 0x00, - /* flags : readable and exectuable */ + /* flags : readable and executable */ 0x05, 0x00, 0x00, 0x00, /* padding */ 0x00, 0x00, 0x00, 0x00, diff --git a/test/dm/scmi.c b/test/dm/scmi.c index 795f207304..93c7d08f43 100644 --- a/test/dm/scmi.c +++ b/test/dm/scmi.c @@ -6,7 +6,7 @@ * uclass devices probe when a SCMI server exposes resources. * * Note in test.dts the protocol@10 node in scmi node. Protocol 0x10 is not - * implemented in U-Boot SCMI components but the implementation is exepected + * implemented in U-Boot SCMI components but the implementation is expected * to not complain on unknown protocol IDs, as long as it is not used. Note * in test.dts tests that SCMI drivers probing does not fail for such an * unknown SCMI protocol ID. diff --git a/test/dm/spmi.c b/test/dm/spmi.c index 114fd2d22e..9cc284b98c 100644 --- a/test/dm/spmi.c +++ b/test/dm/spmi.c @@ -17,7 +17,7 @@ #include <test/test.h> #include <test/ut.h>
-/* Test if bus childs got probed propperly*/ +/* Test if bus children got probed properly*/ static int dm_test_spmi_probe(struct unit_test_state *uts) { const char *name = "spmi@0"; diff --git a/test/dm/test-fdt.c b/test/dm/test-fdt.c index 8bb868b678..7cd2d04612 100644 --- a/test/dm/test-fdt.c +++ b/test/dm/test-fdt.c @@ -592,7 +592,7 @@ static int dm_test_fdt_translation(struct unit_test_state *uts) ut_asserteq_str("dev@2,200", dev->name); ut_asserteq(0xA000, dev_read_addr(dev));
- /* No translation for busses with #size-cells == 0 */ + /* No translation for buses with #size-cells == 0 */ ut_assertok(uclass_find_device_by_seq(UCLASS_TEST_DUMMY, 3, &dev)); ut_asserteq_str("dev@42", dev->name); ut_asserteq(0x42, dev_read_addr(dev));
On Sat, 3 Dec 2022 at 01:26, Yuepeng Xing xingyuepeng@eswincomputing.com wrote:
Applied to u-boot-dm/next, thanks!
Yuepeng Xing
