[U-Boot] Please pull u-boot-marvell/master
Hi Tom,
please pull the first Marvell patches in this merge window with the following changes:
---------------------------------------------------------------- - Various improvements to Keymile boards - mostly DT conversation (Pascal & Holger) - Removal of now unsupported Keymile boards (Pascal & Holger) - Small MVEBU PCI fix (Marek) - Turris Omnia defconfig update (Marek) - Misc Allied Telesis defconfig updates (Chris) ----------------------------------------------------------------
Thanks, Stefan
The following changes since commit feb5a02f869d5678190dfc915ef6c2781b4f7a6c:
Merge branch 'master' of git://git.denx.de/u-boot-sh (2019-08-10 17:57:58 -0400)
git@gitlab.denx.de:u-boot/custodians/u-boot-marvell.git
for you to fetch changes up to 193a1e9f196b7fb7e913a70936c8a49060a1859c:
pci: pci_mvebu: set BAR0 after memory space is set (2019-08-12 13:59:31 +0200)
---------------------------------------------------------------- Chris Packham (1): ARM: configs: Enable DM_ETH for SBx81LIFKW and SBx81LIFXCAT
Holger Brunck (2): powerpc/km: remove unmaintained target KMVECT1 powerpc/km: remove unmaintained board KMLION1
Marek Behún (2): arm: mvebu: turris_omnia: update defconfig pci: pci_mvebu: set BAR0 after memory space is set
Pascal Linder (7): km: add Kconfig menus for KM boards km: remove obsolete definitions in KM header files km: clean up header files for KM Kirkwood boards km: fixed typo in KM Kirkwood header file km/uart: port UART interface of KM Kirkwood boards to driver model km/rgmii: port Ethernet interface of KM Kirkwood boards to driver model km/arm: remove unmaintained target PORTL2
arch/arm/dts/kirkwood-km_common.dtsi | 1 + arch/powerpc/cpu/mpc83xx/Kconfig | 4 - board/keymile/Kconfig | 101 +++++++++ board/keymile/common/common.h | 4 - board/keymile/common/ivm.c | 5 - board/keymile/km83xx/Kconfig | 19 -- board/keymile/km83xx/MAINTAINERS | 1 - board/keymile/km83xx/km83xx.c | 81 ------- board/keymile/km_arm/Kconfig | 31 +++ board/keymile/km_arm/MAINTAINERS | 1 - board/keymile/kmp204x/MAINTAINERS | 1 - configs/SBx81LIFKW_defconfig | 3 + configs/SBx81LIFXCAT_defconfig | 3 + configs/km_kirkwood_pci_defconfig | 1 + configs/kmcoge5un_defconfig | 3 + configs/kmlion1_defconfig | 57 ----- configs/kmnusa_defconfig | 4 + configs/kmsugp1_defconfig | 4 + configs/kmsuv31_defconfig | 2 + configs/kmvect1_defconfig | 180 --------------- configs/mgcoge3un_defconfig | 2 + configs/portl2_defconfig | 46 ---- configs/turris_omnia_defconfig | 3 + drivers/pci/pci_mvebu.c | 8 +- include/configs/km/keymile-common.h | 8 - include/configs/km/km-mpc83xx.h | 4 - include/configs/km/km-powerpc.h | 13 -- include/configs/km/km_arm.h | 54 +---- include/configs/km/kmp204x-common.h | 409 ---------------------------------- include/configs/km_kirkwood.h | 28 +-- include/configs/kmp204x.h | 410 +++++++++++++++++++++++++++++++++-- include/configs/kmvect1.h | 61 ------ scripts/config_whitelist.txt | 22 -- 33 files changed, 554 insertions(+), 1020 deletions(-) delete mode 100644 configs/kmlion1_defconfig delete mode 100644 configs/kmvect1_defconfig delete mode 100644 configs/portl2_defconfig delete mode 100644 include/configs/km/kmp204x-common.h delete mode 100644 include/configs/kmvect1.h
Stefan Roese
