[U-Boot] [PATCH 0/9 V4] EXYNOS5: Add Audio support
This patchset adds the audio support for EXYNOS5. This patchset plays a predefined beep sound.
Rajeshwari Shinde (9): SOUND: SAMSUNG: Add I2S driver SOUND: Add WM8994 codec Sound: Add command for audio playback EXYNOS: Add I2S registers EXYNOS: Add parameters required by I2S EXYNOS: Add pinmux for I2S EXYNOS: Add I2S base address EXYNOS: Add clock for I2S SMDK5250: Enable Sound
Changes in V2: - renamed i2s.c to samsung-i2s.c. - made exynos_i2s_config pinmux function static. - corrected the commit message for "Enable sound" patch. Changes in V3: - Incorporated comments from Simon Glass and Minkyu Kang. Changes in V4: - Corrected the coding style issues suggested by Simon Glass. Makefile | 1 + arch/arm/cpu/armv7/exynos/clock.c | 120 ++++ arch/arm/cpu/armv7/exynos/pinmux.c | 13 + arch/arm/include/asm/arch-exynos/clk.h | 3 + arch/arm/include/asm/arch-exynos/clock.h | 29 + arch/arm/include/asm/arch-exynos/cpu.h | 3 + arch/arm/include/asm/arch-exynos/i2s-regs.h | 66 +++ arch/arm/include/asm/arch-exynos/periph.h | 1 + arch/arm/include/asm/arch-exynos/sound.h | 44 ++ common/Makefile | 1 + common/cmd_sound.c | 96 ++++ drivers/sound/Makefile | 48 ++ drivers/sound/samsung-i2s.c | 358 ++++++++++++ drivers/sound/sound.c | 228 ++++++++ drivers/sound/wm8994.c | 792 +++++++++++++++++++++++++++ drivers/sound/wm8994.h | 87 +++ drivers/sound/wm8994_registers.h | 299 ++++++++++ include/configs/smdk5250.h | 8 + include/i2s.h | 127 +++++ include/sound.h | 62 +++ 20 files changed, 2386 insertions(+), 0 deletions(-) create mode 100644 arch/arm/include/asm/arch-exynos/i2s-regs.h create mode 100644 arch/arm/include/asm/arch-exynos/sound.h create mode 100644 common/cmd_sound.c create mode 100644 drivers/sound/Makefile create mode 100644 drivers/sound/samsung-i2s.c create mode 100644 drivers/sound/sound.c create mode 100644 drivers/sound/wm8994.c create mode 100644 drivers/sound/wm8994.h create mode 100644 drivers/sound/wm8994_registers.h create mode 100644 include/i2s.h create mode 100644 include/sound.h
This patch adds driver for I2S interface specific to samsung.
Signed-off-by: R. Chandrasekar rcsekar@samsung.com Signed-off-by: Rajeshwari Shinde rajeshwari.s@samsung.com Acked-by: Simon Glass sjg@chromium.org --- Changes in V2: - renamed i2s.c to samsung-i2s.c. Changes in V3: - wave sine table removed and the same in calculated in a function. Changes in V4: - Corrected the coding style issues suggested by Simon Glass. - Global variables in sound.c were made static. Makefile | 1 + drivers/sound/Makefile | 47 ++++++ drivers/sound/samsung-i2s.c | 358 +++++++++++++++++++++++++++++++++++++++++++ drivers/sound/sound.c | 228 +++++++++++++++++++++++++++ include/i2s.h | 127 +++++++++++++++ include/sound.h | 62 ++++++++ 6 files changed, 823 insertions(+), 0 deletions(-) create mode 100644 drivers/sound/Makefile create mode 100644 drivers/sound/samsung-i2s.c create mode 100644 drivers/sound/sound.c create mode 100644 include/i2s.h create mode 100644 include/sound.h
diff --git a/Makefile b/Makefile index 08eecbb..ee4fb7f 100644 --- a/Makefile +++ b/Makefile @@ -311,6 +311,7 @@ LIBS-y += arch/powerpc/cpu/mpc8xxx/lib8xxx.o endif LIBS-y += drivers/rtc/librtc.o LIBS-y += drivers/serial/libserial.o +LIBS-y += drivers/sound/libsound.o LIBS-$(CONFIG_GENERIC_LPC_TPM) += drivers/tpm/libtpm.o LIBS-y += drivers/twserial/libtws.o LIBS-y += drivers/usb/eth/libusb_eth.o diff --git a/drivers/sound/Makefile b/drivers/sound/Makefile new file mode 100644 index 0000000..18ad2c9 --- /dev/null +++ b/drivers/sound/Makefile @@ -0,0 +1,47 @@ +# +# Copyright (C) 2012 Samsung Electronics +# R. Chandrasekar rcsekar@samsung.com +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB := $(obj)libsound.o + +COBJS-$(CONFIG_SOUND) += sound.o +COBJS-$(CONFIG_I2S) += samsung-i2s.o + +COBJS := $(COBJS-y) +SRCS := $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) + +all: $(LIB) + +$(LIB): $(obj).depend $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +# diff --git a/drivers/sound/samsung-i2s.c b/drivers/sound/samsung-i2s.c new file mode 100644 index 0000000..9f3117d --- /dev/null +++ b/drivers/sound/samsung-i2s.c @@ -0,0 +1,358 @@ +/* + * Copyright (C) 2012 Samsung Electronics + * R. Chandrasekar rcsekar@samsung.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <asm/arch/clk.h> +#include <asm/arch/pinmux.h> +#include <asm/arch/i2s-regs.h> +#include <asm/io.h> +#include <common.h> +#include <sound.h> +#include <i2s.h> + +#define FIC_TX2COUNT(x) (((x) >> 24) & 0xf) +#define FIC_TX1COUNT(x) (((x) >> 16) & 0xf) +#define FIC_TXCOUNT(x) (((x) >> 8) & 0xf) +#define FIC_RXCOUNT(x) (((x) >> 0) & 0xf) +#define FICS_TXCOUNT(x) (((x) >> 8) & 0x7f) + +#define TIMEOUT_I2S_TX 100 /* i2s transfer timeout */ + +/* + * Sets the frame size for I2S LR clock + * + * @param i2s_reg i2s regiter address + * @param rfs Frame Size + */ +static void i2s_set_lr_framesize(struct i2s_reg *i2s_reg, unsigned int rfs) +{ + unsigned int mod = readl(&i2s_reg->mod); + + mod &= ~MOD_RCLK_MASK; + + switch (rfs) { + case 768: + mod |= MOD_RCLK_768FS; + break; + case 512: + mod |= MOD_RCLK_512FS; + break; + case 384: + mod |= MOD_RCLK_384FS; + break; + default: + mod |= MOD_RCLK_256FS; + break; + } + + writel(mod, &i2s_reg->mod); +} + +/* + * Sets the i2s transfer control + * + * @param i2s_reg i2s regiter address + * @param on 1 enable tx , 0 disable tx transfer + */ +static void i2s_txctrl(struct i2s_reg *i2s_reg, int on) +{ + unsigned int con = readl(&i2s_reg->con); + unsigned int mod = readl(&i2s_reg->mod) & ~MOD_MASK; + + if (on) { + con |= CON_ACTIVE; + con &= ~CON_TXCH_PAUSE; + + } else { + + con |= CON_TXCH_PAUSE; + con &= ~CON_ACTIVE; + } + + writel(mod, &i2s_reg->mod); + writel(con, &i2s_reg->con); +} + +/* + * set the bit clock frame size (in multiples of LRCLK) + * + * @param i2s_reg i2s regiter address + * @param bfs bit Frame Size + */ +static void i2s_set_bitclk_framesize(struct i2s_reg *i2s_reg, unsigned bfs) +{ + unsigned int mod = readl(&i2s_reg->mod); + + mod &= ~MOD_BCLK_MASK; + + switch (bfs) { + case 48: + mod |= MOD_BCLK_48FS; + break; + case 32: + mod |= MOD_BCLK_32FS; + break; + case 24: + mod |= MOD_BCLK_24FS; + break; + case 16: + mod |= MOD_BCLK_16FS; + break; + default: + return; + } + writel(mod, &i2s_reg->mod); +} + +/* + * flushes the i2stx fifo + * + * @param i2s_reg i2s regiter address + * @param flush Tx fifo flush command (0x00 - do not flush + * 0x80 - flush tx fifo) + */ +void i2s_fifo(struct i2s_reg *i2s_reg, unsigned int flush) +{ + /* Flush the FIFO */ + setbits_le32(&i2s_reg->fic, flush); + clrbits_le32(&i2s_reg->fic, flush); +} + +/* + * Set System Clock direction + * + * @param i2s_reg i2s regiter address + * @param dir Clock direction + * + * @return int value 0 for success, -1 in case of error + */ +int i2s_set_sysclk_dir(struct i2s_reg *i2s_reg, int dir) +{ + unsigned int mod = readl(&i2s_reg->mod); + + if (dir == SND_SOC_CLOCK_IN) + mod |= MOD_CDCLKCON; + else + mod &= ~MOD_CDCLKCON; + + writel(mod, &i2s_reg->mod); + + return 0; +} + +/* + * Sets I2S Clcok format + * + * @param fmt i2s clock properties + * @param i2s_reg i2s regiter address + * + * @return int value 0 for success, -1 in case of error + */ +int i2s_set_fmt(struct i2s_reg *i2s_reg, unsigned int fmt) +{ + unsigned int mod = readl(&i2s_reg->mod); + unsigned int tmp = 0; + unsigned int ret = 0; + + /* Format is priority */ + switch (fmt & SND_SOC_DAIFMT_FORMAT_MASK) { + case SND_SOC_DAIFMT_RIGHT_J: + tmp |= MOD_LR_RLOW; + tmp |= MOD_SDF_MSB; + break; + case SND_SOC_DAIFMT_LEFT_J: + tmp |= MOD_LR_RLOW; + tmp |= MOD_SDF_LSB; + break; + case SND_SOC_DAIFMT_I2S: + tmp |= MOD_SDF_IIS; + break; + default: + debug("%s: Invalid format priority [0x%x]\n", __func__, + (fmt & SND_SOC_DAIFMT_FORMAT_MASK)); + return -1; + } + + /* + * INV flag is relative to the FORMAT flag - if set it simply + * flips the polarity specified by the Standard + */ + switch (fmt & SND_SOC_DAIFMT_INV_MASK) { + case SND_SOC_DAIFMT_NB_NF: + break; + case SND_SOC_DAIFMT_NB_IF: + if (tmp & MOD_LR_RLOW) + tmp &= ~MOD_LR_RLOW; + else + tmp |= MOD_LR_RLOW; + break; + default: + debug("%s: Invalid clock ploarity input [0x%x]\n", __func__, + (fmt & SND_SOC_DAIFMT_INV_MASK)); + return -1; + } + + switch (fmt & SND_SOC_DAIFMT_MASTER_MASK) { + case SND_SOC_DAIFMT_CBS_CFS: + tmp |= MOD_SLAVE; + break; + case SND_SOC_DAIFMT_CBM_CFM: + /* Set default source clock in Master mode */ + ret = i2s_set_sysclk_dir(i2s_reg, SND_SOC_CLOCK_OUT); + if (ret != 0) { + debug("%s:set i2s clock direction failed\n", __func__); + return -1; + } + break; + default: + debug("%s: Invalid master selection [0x%x]\n", __func__, + (fmt & SND_SOC_DAIFMT_MASTER_MASK)); + return -1; + } + + mod &= ~(MOD_SDF_MASK | MOD_LR_RLOW | MOD_SLAVE); + mod |= tmp; + writel(mod, &i2s_reg->mod); + + return 0; +} + +/* + * Sets the sample width in bits + * + * @param blc samplewidth (size of sample in bits) + * @param i2s_reg i2s regiter address + * + * @return int value 0 for success, -1 in case of error + */ +int i2s_set_samplesize(struct i2s_reg *i2s_reg, unsigned int blc) +{ + unsigned int mod = readl(&i2s_reg->mod); + + mod &= ~MOD_BLCP_MASK; + mod &= ~MOD_BLC_MASK; + + switch (blc) { + case 8: + mod |= MOD_BLCP_8BIT; + mod |= MOD_BLC_8BIT; + break; + case 16: + mod |= MOD_BLCP_16BIT; + mod |= MOD_BLC_16BIT; + break; + case 24: + mod |= MOD_BLCP_24BIT; + mod |= MOD_BLC_24BIT; + break; + default: + debug("%s: Invalid sample size input [0x%x]\n", + __func__, blc); + return -1; + } + writel(mod, &i2s_reg->mod); + + return 0; +} + +int i2s_transfer_tx_data(struct i2stx_info *pi2s_tx, unsigned int *data, + unsigned long data_size) +{ + int i; + int start; + struct i2s_reg *i2s_reg = + (struct i2s_reg *)pi2s_tx->base_address; + + if (data_size < FIFO_LENGTH) { + debug("%s : Invalid data size\n", __func__); + return -1; /* invalid pcm data size */ + } + + /* fill the tx buffer before stating the tx transmit */ + for (i = 0; i < FIFO_LENGTH; i++) + writel(*data++, &i2s_reg->txd); + + data_size -= FIFO_LENGTH; + i2s_txctrl(i2s_reg, I2S_TX_ON); + + while (data_size > 0) { + start = get_timer(0); + if (!(CON_TXFIFO_FULL & (readl(&i2s_reg->con)))) { + writel(*data++, &i2s_reg->txd); + data_size--; + } else { + if (get_timer(start) > TIMEOUT_I2S_TX) { + i2s_txctrl(i2s_reg, I2S_TX_OFF); + debug("%s: I2S Transfer Timeout\n", __func__); + return -1; + } + } + } + i2s_txctrl(i2s_reg, I2S_TX_OFF); + + return 0; +} + +int i2s_tx_init(struct i2stx_info *pi2s_tx) +{ + int ret; + struct i2s_reg *i2s_reg = + (struct i2s_reg *)pi2s_tx->base_address; + + /* Initialize GPIO for I2s */ + exynos_pinmux_config(PERIPH_ID_I2S1, 0); + + /* Set EPLL Clock */ + ret = set_epll_clk(pi2s_tx->audio_pll_clk); + if (ret != 0) { + debug("%s: epll clock set rate falied\n", __func__); + return -1; + } + + /* Select Clk Source for Audio1 */ + set_i2s_clk_source(); + + /* Set Prescaler to get MCLK */ + set_i2s_clk_prescaler(pi2s_tx->audio_pll_clk, + (pi2s_tx->samplingrate * (pi2s_tx->rfs))); + + /* Configure I2s format */ + ret = i2s_set_fmt(i2s_reg, (SND_SOC_DAIFMT_I2S | SND_SOC_DAIFMT_NB_NF | + SND_SOC_DAIFMT_CBM_CFM)); + if (ret == 0) { + i2s_set_lr_framesize(i2s_reg, pi2s_tx->rfs); + ret = i2s_set_samplesize(i2s_reg, pi2s_tx->bitspersample); + if (ret != 0) { + debug("%s:set sample rate failed\n", __func__); + return -1; + } + + i2s_set_bitclk_framesize(i2s_reg, pi2s_tx->bfs); + /* disable i2s transfer flag and flush the fifo */ + i2s_txctrl(i2s_reg, I2S_TX_OFF); + i2s_fifo(i2s_reg, FIC_TXFLUSH); + } else { + debug("%s: failed\n", __func__); + } + + return ret; +} diff --git a/drivers/sound/sound.c b/drivers/sound/sound.c new file mode 100644 index 0000000..4c74534 --- /dev/null +++ b/drivers/sound/sound.c @@ -0,0 +1,228 @@ +/* + * Copyright (C) 2012 Samsung Electronics + * R. Chandrasekar rcsekar@samsung.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <malloc.h> +#include <common.h> +#include <asm/io.h> +#include <i2c.h> +#include <i2s.h> +#include <sound.h> +#include "wm8994.h" +#include <asm/arch/sound.h> + +/* defines */ +#define SOUND_400_HZ 400 +#define SOUND_BITS_IN_BYTE 8 + +static struct i2stx_info g_i2stx_pri; +static struct sound_codec_info g_codec_info; + +/* + * get_sound_fdt_values gets fdt values for i2s parameters + * + * @param i2stx_info i2s transmitter transfer param structure + * @param blob FDT blob + */ +static void get_sound_i2s_values(struct i2stx_info *i2s) +{ + i2s->base_address = samsung_get_base_i2s(); + i2s->audio_pll_clk = I2S_PLL_CLK; + i2s->samplingrate = I2S_SAMPLING_RATE; + i2s->bitspersample = I2S_BITS_PER_SAMPLE; + i2s->channels = I2S_CHANNELS; + i2s->rfs = I2S_RFS; + i2s->bfs = I2S_BFS; +} + +/* + * Gets fdt values for wm8994 config parameters + * + * @param pcodec_info codec information structure + * @param blob FDT blob + * @return int value, 0 for success + */ +static int get_sound_wm8994_values(struct sound_codec_info *pcodec_info) +{ + int error = 0; + + switch (AUDIO_COMPAT) { + case AUDIO_COMPAT_SPI: + debug("%s: Support not added for SPI interface\n", __func__); + return -1; + break; + case AUDIO_COMPAT_I2C: + pcodec_info->i2c_bus = AUDIO_I2C_BUS; + pcodec_info->i2c_dev_addr = AUDIO_I2C_REG; + debug("i2c dev addr = %d\n", pcodec_info->i2c_dev_addr); + break; + default: + debug("%s: Unknown compat id %d\n", __func__, AUDIO_COMPAT); + return -1; + } + + if (error == -1) { + debug("fail to get wm8994 codec node properties\n"); + return -1; + } + + return 0; +} + +/* + * Gets fdt values for codec config parameters + * + * @param pcodec_info codec information structure + * @param blob FDT blob + * @return int value, 0 for success + */ +static int get_sound_codec_values(struct sound_codec_info *pcodec_info) +{ + int error = 0; + const char *codectype; + + codectype = AUDIO_CODEC; + + if (!strcmp(codectype, "wm8994")) { + pcodec_info->codec_type = CODEC_WM_8994; + error = get_sound_wm8994_values(pcodec_info); + } else { + error = -1; + } + + if (error == -1) { + debug("fail to get sound codec node properties\n"); + return -1; + } + + return 0; +} + +int sound_init(void) +{ + int ret; + struct i2stx_info *pi2s_tx = &g_i2stx_pri; + struct sound_codec_info *pcodec_info = &g_codec_info; + + /* Get the I2S Values */ + get_sound_i2s_values(pi2s_tx); + + /* Get the codec Values */ + if (get_sound_codec_values(pcodec_info) < 0) + return -1; + + ret = i2s_tx_init(pi2s_tx); + if (ret) { + debug("%s: Failed to init i2c transmit: ret=%d\n", __func__, + ret); + return ret; + } + + /* Check the codec type and initialise the same */ + if (pcodec_info->codec_type == CODEC_WM_8994) { + ret = wm8994_init(pcodec_info, WM8994_AIF2, + pi2s_tx->samplingrate, + (pi2s_tx->samplingrate * (pi2s_tx->rfs)), + pi2s_tx->bitspersample, pi2s_tx->channels); + } else { + debug("%s: Unknown code type %d\n", __func__, + pcodec_info->codec_type); + return -1; + } + if (ret) { + debug("%s: Codec init failed\n", __func__); + return -1; + } + + return ret; +} + +/* + * Generates square wave sound data for 1 second + * + * @param data data buffer pointer + * @param size size of the buffer + * @param freq frequency of the wave + */ +static void sound_prepare_buffer(unsigned short *data, int size, uint32_t freq) +{ + const int sample = 48000; + const unsigned short amplitude = 16000; /* between 1 and 32767 */ + const int period = freq ? sample / freq : 0; + const int half = period / 2; + + assert(freq); + + /* Make sure we don't overflow our buffer */ + if (size % 2) + size--; + + while (size) { + int i; + for (i = 0; size && i < half; i++) { + size -= 2; + *data++ = amplitude; + *data++ = amplitude; + } + for (i = 0; size && i < period - half; i++) { + size -= 2; + *data++ = -amplitude; + *data++ = -amplitude; + } + } +} + +int sound_play(uint32_t msec, uint32_t frequency) +{ + unsigned int *data; + unsigned long data_size; + unsigned int ret = 0; + + /*Buffer length computation */ + data_size = g_i2stx_pri.samplingrate * g_i2stx_pri.channels; + data_size *= (g_i2stx_pri.bitspersample / SOUND_BITS_IN_BYTE); + data = malloc(data_size); + + if (data == NULL) { + debug("%s: malloc failed\n", __func__); + return -1; + } + + sound_prepare_buffer((unsigned short *)data, + data_size / sizeof(unsigned short), frequency); + + while (msec >= 1000) { + ret = i2s_transfer_tx_data(&g_i2stx_pri, data, + (data_size / sizeof(int))); + msec -= 1000; + } + if (msec) { + unsigned long size = + (data_size * msec) / (sizeof(int) * 1000); + + ret = i2s_transfer_tx_data(&g_i2stx_pri, data, size); + } + + free(data); + + return ret; +} diff --git a/include/i2s.h b/include/i2s.h new file mode 100644 index 0000000..75ae75c --- /dev/null +++ b/include/i2s.h @@ -0,0 +1,127 @@ +/* + * Copyright (C) 2012 Samsung Electronics + * R. Chandrasekar rcsekar@samsung.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __I2S_H__ +#define __I2S_H__ + +/* + * DAI hardware audio formats. + * + * Describes the physical PCM data formating and clocking. Add new formats + * to the end. + */ +#define SND_SOC_DAIFMT_I2S 1 /* I2S mode */ +#define SND_SOC_DAIFMT_RIGHT_J 2 /* Right Justified mode */ +#define SND_SOC_DAIFMT_LEFT_J 3 /* Left Justified mode */ +#define SND_SOC_DAIFMT_DSP_A 4 /* L data MSB after FRM LRC */ +#define SND_SOC_DAIFMT_DSP_B 5 /* L data MSB during FRM LRC */ +#define SND_SOC_DAIFMT_AC97 6 /* AC97 */ +#define SND_SOC_DAIFMT_PDM 7 /* Pulse density modulation */ + +/* left and right justified also known as MSB and LSB respectively */ +#define SND_SOC_DAIFMT_MSB SND_SOC_DAIFMT_LEFT_J +#define SND_SOC_DAIFMT_LSB SND_SOC_DAIFMT_RIGHT_J + +/* + * DAI hardware signal inversions. + * + * Specifies whether the DAI can also support inverted clocks for the specified + * format. + */ +#define SND_SOC_DAIFMT_NB_NF (1 << 8) /* normal bit clock + frame */ +#define SND_SOC_DAIFMT_NB_IF (2 << 8) /* normal BCLK + inv FRM */ +#define SND_SOC_DAIFMT_IB_NF (3 << 8) /* invert BCLK + nor FRM */ +#define SND_SOC_DAIFMT_IB_IF (4 << 8) /* invert BCLK + FRM */ + +/* + * DAI hardware clock masters. + * + * This is wrt the codec, the inverse is true for the interface + * i.e. if the codec is clk and FRM master then the interface is + * clk and frame slave. + */ +#define SND_SOC_DAIFMT_CBM_CFM (1 << 12) /* codec clk & FRM master */ +#define SND_SOC_DAIFMT_CBS_CFM (2 << 12) /* codec clk slave & FRM master */ +#define SND_SOC_DAIFMT_CBM_CFS (3 << 12) /* codec clk master & frame slave */ +#define SND_SOC_DAIFMT_CBS_CFS (4 << 12) /* codec clk & FRM slave */ + +#define SND_SOC_DAIFMT_FORMAT_MASK 0x000f +#define SND_SOC_DAIFMT_CLOCK_MASK 0x00f0 +#define SND_SOC_DAIFMT_INV_MASK 0x0f00 +#define SND_SOC_DAIFMT_MASTER_MASK 0xf000 + +/* + * Master Clock Directions + */ +#define SND_SOC_CLOCK_IN 0 +#define SND_SOC_CLOCK_OUT 1 + +/* I2S Tx Control */ +#define I2S_TX_ON 1 +#define I2S_TX_OFF 0 + +#define FIFO_LENGTH 64 + +/* I2s Registers */ +struct i2s_reg { + unsigned int con; /* base + 0 , Control register */ + unsigned int mod; /* Mode register */ + unsigned int fic; /* FIFO control register */ + unsigned int psr; /* Reserved */ + unsigned int txd; /* Transmit data register */ + unsigned int rxd; /* Receive Data Register */ +}; + +/* This structure stores the i2s related information */ +struct i2stx_info { + unsigned int rfs; /* LR clock frame size */ + unsigned int bfs; /* Bit slock frame size */ + unsigned int audio_pll_clk; /* Audio pll frequency in Hz */ + unsigned int samplingrate; /* sampling rate */ + unsigned int bitspersample; /* bits per sample */ + unsigned int channels; /* audio channels */ + unsigned int base_address; /* I2S Register Base */ +}; + +/* + * Sends the given data through i2s tx + * + * @param pi2s_tx pointer of i2s transmitter parameter structure. + * @param data address of the data buffer + * @param data_size array size of the int buffer (total size / size of int) + * + * @return int value 0 for success, -1 in case of error + */ +int i2s_transfer_tx_data(struct i2stx_info *pi2s_tx, unsigned *data, + unsigned long data_size); + +/* + * Initialise i2s transmiter + * + * @param pi2s_tx pointer of i2s transmitter parameter structure. + * + * @return int value 0 for success, -1 in case of error + */ +int i2s_tx_init(struct i2stx_info *pi2s_tx); + +#endif /* __I2S_H__ */ diff --git a/include/sound.h b/include/sound.h new file mode 100644 index 0000000..ea0b115 --- /dev/null +++ b/include/sound.h @@ -0,0 +1,62 @@ +/* + * Copyright (C) 2012 Samsung Electronics + * R. Chandrasekar < rcsekar@samsung.com> + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __SOUND_H__ +#define __SOUND_H__ + +/* sound codec enum */ +enum en_sound_codec { + CODEC_WM_8994, + CODEC_WM_8995, + CODEC_MAX +}; + +/* sound codec enum */ +enum sound_compat { + AUDIO_COMPAT_SPI, + AUDIO_COMPAT_I2C, +}; + +/* Codec information structure to store the info from device tree */ +struct sound_codec_info { + int i2c_bus; + int i2c_dev_addr; + enum en_sound_codec codec_type; +}; + +/* + * Initialises audio sub system + * + * @return int value 0 for success, -1 for error + */ +int sound_init(void); + +/* + * plays the pcm data buffer in pcm_data.h through i2s1 to make the + * sine wave sound + * + * @return int 0 for success, -1 for error + */ +int sound_play(uint32_t msec, uint32_t frequency); + +#endif /* __SOUND__H__ */
This patch adds driver for audio codec WM8994
Signed-off-by: R. Chandrasekar rcsekar@samsung.com Signed-off-by: Rajeshwari Shinde rajeshwari.s@samsung.com Acked-by: Simon Glass sjg@chromium.org --- Changes in V2: - None Changes in V3: - Incorporated comments from Simon Glass. Changes in V4: - None drivers/sound/Makefile | 1 + drivers/sound/wm8994.c | 792 ++++++++++++++++++++++++++++++++++++++ drivers/sound/wm8994.h | 87 +++++ drivers/sound/wm8994_registers.h | 299 ++++++++++++++ 4 files changed, 1179 insertions(+), 0 deletions(-) create mode 100644 drivers/sound/wm8994.c create mode 100644 drivers/sound/wm8994.h create mode 100644 drivers/sound/wm8994_registers.h
diff --git a/drivers/sound/Makefile b/drivers/sound/Makefile index 18ad2c9..8fdffb1 100644 --- a/drivers/sound/Makefile +++ b/drivers/sound/Makefile @@ -27,6 +27,7 @@ LIB := $(obj)libsound.o
COBJS-$(CONFIG_SOUND) += sound.o COBJS-$(CONFIG_I2S) += samsung-i2s.o +COBJS-$(CONFIG_SOUND_WM8994) += wm8994.o
COBJS := $(COBJS-y) SRCS := $(COBJS:.o=.c) diff --git a/drivers/sound/wm8994.c b/drivers/sound/wm8994.c new file mode 100644 index 0000000..293903a --- /dev/null +++ b/drivers/sound/wm8994.c @@ -0,0 +1,792 @@ +/* + * Copyright (C) 2012 Samsung Electronics + * R. Chandrasekar rcsekar@samsung.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#include <asm/arch/clk.h> +#include <asm/arch/cpu.h> +#include <asm/gpio.h> +#include <asm/io.h> +#include <common.h> +#include <div64.h> +#include <i2c.h> +#include <i2s.h> +#include <sound.h> +#include "wm8994.h" +#include "wm8994_registers.h" + +/* defines for wm8994 system clock selection */ +#define SEL_MCLK1 0x00 +#define SEL_MCLK2 0x08 +#define SEL_FLL1 0x10 +#define SEL_FLL2 0x18 + +/* fll config to configure fll */ +struct wm8994_fll_config { + int src; /* Source */ + int in; /* Input frequency in Hz */ + int out; /* output frequency in Hz */ +}; + +/* codec private data */ +struct wm8994_priv { + enum wm8994_type type; /* codec type of wolfson */ + int revision; /* Revision */ + int sysclk[WM8994_MAX_AIF]; /* System clock frequency in Hz */ + int mclk[WM8994_MAX_AIF]; /* master clock frequency in Hz */ + int aifclk[WM8994_MAX_AIF]; /* audio interface clock in Hz */ + struct wm8994_fll_config fll[2]; /* fll config to configure fll */ +}; + +/* wm 8994 supported sampling rate values */ +static unsigned int src_rate[] = { + 8000, 11025, 12000, 16000, 22050, 24000, + 32000, 44100, 48000, 88200, 96000 +}; + +/* op clock divisions */ +static int opclk_divs[] = { 10, 20, 30, 40, 55, 60, 80, 120, 160 }; + +/* lr clock frame size ratio */ +static int fs_ratios[] = { + 64, 128, 192, 256, 348, 512, 768, 1024, 1408, 1536 +}; + +/* bit clock divisors */ +static int bclk_divs[] = { + 10, 15, 20, 30, 40, 50, 60, 80, 110, 120, 160, 220, 240, 320, 440, 480, + 640, 880, 960, 1280, 1760, 1920 +}; + +static struct wm8994_priv g_wm8994_info; +static unsigned char g_wm8994_i2c_dev_addr; + +/* + * Initialise I2C for wm 8994 + * + * @param bus no i2c bus number in which wm8994 is connected + */ +static void wm8994_i2c_init(int bus_no) +{ + i2c_set_bus_num(bus_no); +} + +/* + * Writes value to a device register through i2c + * + * @param reg reg number to be write + * @param data data to be writen to the above registor + * + * @return int value 1 for change, 0 for no change or negative error code. + */ +static int wm8994_i2c_write(unsigned int reg, unsigned short data) +{ + unsigned char val[2]; + + val[0] = (unsigned char)((data >> 8) & 0xff); + val[1] = (unsigned char)(data & 0xff); + debug("Write Addr : 0x%04X, Data : 0x%04X\n", reg, data); + + return i2c_write(g_wm8994_i2c_dev_addr, reg, 2, val, 2); +} + +/* + * Read a value from a device register through i2c + * + * @param reg reg number to be read + * @param data address of read data to be stored + * + * @return int value 0 for success, -1 in case of error. + */ +static unsigned int wm8994_i2c_read(unsigned int reg , unsigned short *data) +{ + unsigned char val[2]; + int ret; + + ret = i2c_read(g_wm8994_i2c_dev_addr, reg, 2, val, 2); + if (ret != 0) { + debug("%s: Error while reading register %#04x\n", + __func__, reg); + return -1; + } + + *data = val[0]; + *data <<= 8; + *data |= val[1]; + + return 0; +} + +/* + * update device register bits through i2c + * + * @param reg codec register + * @param mask register mask + * @param value new value + * + * @return int value 1 if change in the register value, + * 0 for no change or negative error code. + */ +static int wm8994_update_bits(unsigned int reg, unsigned short mask, + unsigned short value) +{ + int change , ret = 0; + unsigned short old, new; + + if (wm8994_i2c_read(reg, &old) != 0) + return -1; + new = (old & ~mask) | (value & mask); + change = (old != new) ? 1 : 0; + if (change) + ret = wm8994_i2c_write(reg, new); + if (ret < 0) + return ret; + + return change; +} + +/* + * Sets i2s set format + * + * @param aif_id Interface ID + * @param fmt i2S format + * + * @return -1 for error and 0 Success. + */ +int wm8994_set_fmt(int aif_id, unsigned int fmt) +{ + int ms_reg; + int aif_reg; + int ms = 0; + int aif = 0; + int aif_clk = 0; + int error = 0; + + switch (aif_id) { + case 1: + ms_reg = WM8994_AIF1_MASTER_SLAVE; + aif_reg = WM8994_AIF1_CONTROL_1; + aif_clk = WM8994_AIF1_CLOCKING_1; + break; + case 2: + ms_reg = WM8994_AIF2_MASTER_SLAVE; + aif_reg = WM8994_AIF2_CONTROL_1; + aif_clk = WM8994_AIF2_CLOCKING_1; + break; + default: + debug("%s: Invalid audio interface selection\n", __func__); + return -1; + } + + switch (fmt & SND_SOC_DAIFMT_MASTER_MASK) { + case SND_SOC_DAIFMT_CBS_CFS: + break; + case SND_SOC_DAIFMT_CBM_CFM: + ms = WM8994_AIF1_MSTR; + break; + default: + debug("%s: Invalid i2s master selection\n", __func__); + return -1; + } + + switch (fmt & SND_SOC_DAIFMT_FORMAT_MASK) { + case SND_SOC_DAIFMT_DSP_B: + aif |= WM8994_AIF1_LRCLK_INV; + case SND_SOC_DAIFMT_DSP_A: + aif |= 0x18; + break; + case SND_SOC_DAIFMT_I2S: + aif |= 0x10; + break; + case SND_SOC_DAIFMT_RIGHT_J: + break; + case SND_SOC_DAIFMT_LEFT_J: + aif |= 0x8; + break; + default: + debug("%s: Invalid i2s format selection\n", __func__); + return -1; + } + + switch (fmt & SND_SOC_DAIFMT_FORMAT_MASK) { + case SND_SOC_DAIFMT_DSP_A: + case SND_SOC_DAIFMT_DSP_B: + /* frame inversion not valid for DSP modes */ + switch (fmt & SND_SOC_DAIFMT_INV_MASK) { + case SND_SOC_DAIFMT_NB_NF: + break; + case SND_SOC_DAIFMT_IB_NF: + aif |= WM8994_AIF1_BCLK_INV; + break; + default: + debug("%s: Invalid i2s frame inverse selection\n", + __func__); + return -1; + } + break; + + case SND_SOC_DAIFMT_I2S: + case SND_SOC_DAIFMT_RIGHT_J: + case SND_SOC_DAIFMT_LEFT_J: + switch (fmt & SND_SOC_DAIFMT_INV_MASK) { + case SND_SOC_DAIFMT_NB_NF: + break; + case SND_SOC_DAIFMT_IB_IF: + aif |= WM8994_AIF1_BCLK_INV | WM8994_AIF1_LRCLK_INV; + break; + case SND_SOC_DAIFMT_IB_NF: + aif |= WM8994_AIF1_BCLK_INV; + break; + case SND_SOC_DAIFMT_NB_IF: + aif |= WM8994_AIF1_LRCLK_INV; + break; + default: + debug("%s: Invalid i2s clock polarity selection\n", + __func__); + return -1; + } + break; + default: + debug("%s: Invalid i2s format selection\n", __func__); + return -1; + } + + error = wm8994_update_bits(aif_reg, WM8994_AIF1_BCLK_INV | + WM8994_AIF1_LRCLK_INV_MASK | WM8994_AIF1_FMT_MASK, aif); + + error |= wm8994_update_bits(ms_reg, WM8994_AIF1_MSTR_MASK, ms); + error |= wm8994_update_bits(aif_clk, WM8994_AIF1CLK_ENA_MASK, + WM8994_AIF1CLK_ENA); + if (error < 0) { + debug("%s: codec register access error\n", __func__); + return -1; + } + + return 0; +} + +/* + * Sets hw params FOR WM8994 + * + * @param wm8994 wm8994 information pointer + * @param aif_id Audio interface ID + * @param sampling_rate Sampling rate + * @param bits_per_sample Bits per sample + * @param Channels Channels in the given audio input + * + * @return -1 for error and 0 Success. + */ +static int wm8994_hw_params(struct wm8994_priv *wm8994, int aif_id, + unsigned int sampling_rate, unsigned int bits_per_sample, + unsigned int channels) +{ + int aif1_reg; + int aif2_reg; + int bclk_reg; + int bclk = 0; + int rate_reg; + int aif1 = 0; + int aif2 = 0; + int rate_val = 0; + int id = aif_id - 1; + int i, cur_val, best_val, bclk_rate, best; + unsigned short reg_data; + int ret = 0; + + switch (aif_id) { + case 1: + aif1_reg = WM8994_AIF1_CONTROL_1; + aif2_reg = WM8994_AIF1_CONTROL_2; + bclk_reg = WM8994_AIF1_BCLK; + rate_reg = WM8994_AIF1_RATE; + break; + case 2: + aif1_reg = WM8994_AIF2_CONTROL_1; + aif2_reg = WM8994_AIF2_CONTROL_2; + bclk_reg = WM8994_AIF2_BCLK; + rate_reg = WM8994_AIF2_RATE; + break; + default: + return -1; + } + + bclk_rate = sampling_rate * 32; + switch (bits_per_sample) { + case 16: + bclk_rate *= 16; + break; + case 20: + bclk_rate *= 20; + aif1 |= 0x20; + break; + case 24: + bclk_rate *= 24; + aif1 |= 0x40; + break; + case 32: + bclk_rate *= 32; + aif1 |= 0x60; + break; + default: + return -1; + } + + /* Try to find an appropriate sample rate; look for an exact match. */ + for (i = 0; i < ARRAY_SIZE(src_rate); i++) + if (src_rate[i] == sampling_rate) + break; + + if (i == ARRAY_SIZE(src_rate)) { + debug("%s: Could not get the best matching samplingrate\n", + __func__); + return -1; + } + + rate_val |= i << WM8994_AIF1_SR_SHIFT; + + /* AIFCLK/fs ratio; look for a close match in either direction */ + best = 0; + best_val = abs((fs_ratios[0] * sampling_rate) + - wm8994->aifclk[id]); + + for (i = 1; i < ARRAY_SIZE(fs_ratios); i++) { + cur_val = abs((fs_ratios[i] * sampling_rate) + - wm8994->aifclk[id]); + if (cur_val >= best_val) + continue; + best = i; + best_val = cur_val; + } + + rate_val |= best; + + /* + * We may not get quite the right frequency if using + * approximate clocks so look for the closest match that is + * higher than the target (we need to ensure that there enough + * BCLKs to clock out the samples). + */ + best = 0; + for (i = 0; i < ARRAY_SIZE(bclk_divs); i++) { + cur_val = (wm8994->aifclk[id] * 10 / bclk_divs[i]) - bclk_rate; + if (cur_val < 0) /* BCLK table is sorted */ + break; + best = i; + } + + if (i == ARRAY_SIZE(bclk_divs)) { + debug("%s: Could not get the best matching bclk division\n", + __func__); + return -1; + } + + bclk_rate = wm8994->aifclk[id] * 10 / bclk_divs[best]; + bclk |= best << WM8994_AIF1_BCLK_DIV_SHIFT; + + if (wm8994_i2c_read(aif1_reg, ®_data) != 0) { + debug("%s: AIF1 register read Failed\n", __func__); + return -1; + } + + if ((channels == 1) && ((reg_data & 0x18) == 0x18)) + aif2 |= WM8994_AIF1_MONO; + + if (wm8994->aifclk[id] == 0) { + debug("%s:Audio interface clock not set\n", __func__); + return -1; + } + + ret = wm8994_update_bits(aif1_reg, WM8994_AIF1_WL_MASK, aif1); + ret |= wm8994_update_bits(aif2_reg, WM8994_AIF1_MONO, aif2); + ret |= wm8994_update_bits(bclk_reg, WM8994_AIF1_BCLK_DIV_MASK, bclk); + ret |= wm8994_update_bits(rate_reg, WM8994_AIF1_SR_MASK | + WM8994_AIF1CLK_RATE_MASK, rate_val); + + debug("rate vale = %x , bclk val= %x\n", rate_val, bclk); + + if (ret < 0) { + debug("%s: codec register access error\n", __func__); + return -1; + } + + return 0; +} + +/* + * Configures Audio interface Clock + * + * @param wm8994 wm8994 information pointer + * @param aif Audio Interface ID + * + * @return -1 for error and 0 Success. + */ +static int configure_aif_clock(struct wm8994_priv *wm8994, int aif) +{ + int rate; + int reg1 = 0; + int offset; + int ret; + + /* AIF(1/0) register adress offset calculated */ + if (aif) + offset = 4; + else + offset = 0; + + switch (wm8994->sysclk[aif]) { + case WM8994_SYSCLK_MCLK1: + reg1 |= SEL_MCLK1; + rate = wm8994->mclk[0]; + break; + + case WM8994_SYSCLK_MCLK2: + reg1 |= SEL_MCLK2; + rate = wm8994->mclk[1]; + break; + + case WM8994_SYSCLK_FLL1: + reg1 |= SEL_FLL1; + rate = wm8994->fll[0].out; + break; + + case WM8994_SYSCLK_FLL2: + reg1 |= SEL_FLL2; + rate = wm8994->fll[1].out; + break; + + default: + debug("%s: Invalid input clock selection [%d]\n", + __func__, wm8994->sysclk[aif]); + return -1; + } + + /* if input clock frequenct is more than 135Mhz then divide */ + if (rate >= WM8994_MAX_INPUT_CLK_FREQ) { + rate /= 2; + reg1 |= WM8994_AIF1CLK_DIV; + } + + wm8994->aifclk[aif] = rate; + + ret = wm8994_update_bits(WM8994_AIF1_CLOCKING_1 + offset, + WM8994_AIF1CLK_SRC_MASK | WM8994_AIF1CLK_DIV, + reg1); + + ret |= wm8994_update_bits(WM8994_CLOCKING_1, + WM8994_SYSCLK_SRC | WM8994_AIF2DSPCLK_ENA_MASK | + WM8994_SYSDSPCLK_ENA_MASK, WM8994_SYSCLK_SRC | + WM8994_AIF2DSPCLK_ENA | WM8994_SYSDSPCLK_ENA); + + if (ret < 0) { + debug("%s: codec register access error\n", __func__); + return -1; + } + + return 0; +} + +/* + * Configures Audio interface for the given frequency + * + * @param wm8994 wm8994 information + * @param aif_id Audio Interface + * @param clk_id Input Clock ID + * @param freq Sampling frequency in Hz + * + * @return -1 for error and 0 success. + */ +static int wm8994_set_sysclk(struct wm8994_priv *wm8994, int aif_id, + int clk_id, unsigned int freq) +{ + int i; + int ret = 0; + + wm8994->sysclk[aif_id - 1] = clk_id; + + switch (clk_id) { + case WM8994_SYSCLK_MCLK1: + wm8994->mclk[0] = freq; + if (aif_id == 2) { + ret = wm8994_update_bits(WM8994_AIF1_CLOCKING_2 , + WM8994_AIF2DAC_DIV_MASK , 0); + } + break; + + case WM8994_SYSCLK_MCLK2: + /* TODO: Set GPIO AF */ + wm8994->mclk[1] = freq; + break; + + case WM8994_SYSCLK_FLL1: + case WM8994_SYSCLK_FLL2: + break; + + case WM8994_SYSCLK_OPCLK: + /* + * Special case - a division (times 10) is given and + * no effect on main clocking. + */ + if (freq) { + for (i = 0; i < ARRAY_SIZE(opclk_divs); i++) + if (opclk_divs[i] == freq) + break; + if (i == ARRAY_SIZE(opclk_divs)) { + debug("%s frequency divisor not found\n", + __func__); + return -1; + } + ret = wm8994_update_bits(WM8994_CLOCKING_2, + WM8994_OPCLK_DIV_MASK, i); + ret |= wm8994_update_bits(WM8994_POWER_MANAGEMENT_2, + WM8994_OPCLK_ENA, WM8994_OPCLK_ENA); + } else { + ret |= wm8994_update_bits(WM8994_POWER_MANAGEMENT_2, + WM8994_OPCLK_ENA, 0); + } + + default: + debug("%s Invalid input clock selection [%d]\n", + __func__, clk_id); + return -1; + } + + ret |= configure_aif_clock(wm8994, aif_id - 1); + + if (ret < 0) { + debug("%s: codec register access error\n", __func__); + return -1; + } + + return 0; +} + +/* + * Initializes Volume for AIF2 to HP path + * + * @returns -1 for error and 0 Success. + * + */ +static int wm8994_init_volume_aif2_dac1(void) +{ + int ret; + + /* Unmute AIF2DAC */ + ret = wm8994_update_bits(WM8994_AIF2_DAC_FILTERS_1, + WM8994_AIF2DAC_MUTE_MASK, 0); + + + ret |= wm8994_update_bits(WM8994_AIF2_DAC_LEFT_VOLUME, + WM8994_AIF2DAC_VU_MASK | WM8994_AIF2DACL_VOL_MASK, + WM8994_AIF2DAC_VU | 0xff); + + ret |= wm8994_update_bits(WM8994_AIF2_DAC_RIGHT_VOLUME, + WM8994_AIF2DAC_VU_MASK | WM8994_AIF2DACR_VOL_MASK, + WM8994_AIF2DAC_VU | 0xff); + + + ret |= wm8994_update_bits(WM8994_DAC1_LEFT_VOLUME, + WM8994_DAC1_VU_MASK | WM8994_DAC1L_VOL_MASK | + WM8994_DAC1L_MUTE_MASK, WM8994_DAC1_VU | 0xc0); + + ret |= wm8994_update_bits(WM8994_DAC1_RIGHT_VOLUME, + WM8994_DAC1_VU_MASK | WM8994_DAC1R_VOL_MASK | + WM8994_DAC1R_MUTE_MASK, WM8994_DAC1_VU | 0xc0); + /* Head Phone Volume */ + ret |= wm8994_i2c_write(WM8994_LEFT_OUTPUT_VOLUME, 0x12D); + ret |= wm8994_i2c_write(WM8994_RIGHT_OUTPUT_VOLUME, 0x12D); + + if (ret < 0) { + debug("%s: codec register access error\n", __func__); + return -1; + } + + return 0; +} + +/* + * Intialise wm8994 codec device + * + * @param wm8994 wm8994 information + * + * @returns -1 for error and 0 Success. + */ +static int wm8994_device_init(struct wm8994_priv *wm8994) +{ + const char *devname; + unsigned short reg_data; + int ret; + + wm8994_i2c_write(WM8994_SOFTWARE_RESET, WM8994_SW_RESET);/* Reset */ + + ret = wm8994_i2c_read(WM8994_SOFTWARE_RESET, ®_data); + if (ret < 0) { + debug("Failed to read ID register\n"); + goto err; + } + + if (reg_data == WM8994_ID) { + devname = "WM8994"; + debug("Device registered as type %d\n", wm8994->type); + wm8994->type = WM8994; + } else { + debug("Device is not a WM8994, ID is %x\n", ret); + ret = -1; + goto err; + } + + ret = wm8994_i2c_read(WM8994_CHIP_REVISION, ®_data); + if (ret < 0) { + debug("Failed to read revision register: %d\n", ret); + goto err; + } + wm8994->revision = reg_data; + debug("%s revision %c\n", devname, 'A' + wm8994->revision); + + /* VMID Selection */ + ret |= wm8994_update_bits(WM8994_POWER_MANAGEMENT_1, + WM8994_VMID_SEL_MASK | WM8994_BIAS_ENA_MASK, 0x3); + + /* Charge Pump Enable */ + ret |= wm8994_update_bits(WM8994_CHARGE_PUMP_1, WM8994_CP_ENA_MASK, + WM8994_CP_ENA); + + /* Head Phone Power Enable */ + ret |= wm8994_update_bits(WM8994_POWER_MANAGEMENT_1, + WM8994_HPOUT1L_ENA_MASK, WM8994_HPOUT1L_ENA); + + ret |= wm8994_update_bits(WM8994_POWER_MANAGEMENT_1, + WM8994_HPOUT1R_ENA_MASK, WM8994_HPOUT1R_ENA); + + /* Power enable for AIF2 and DAC1 */ + ret |= wm8994_update_bits(WM8994_POWER_MANAGEMENT_5, + WM8994_AIF2DACL_ENA_MASK | WM8994_AIF2DACR_ENA_MASK | + WM8994_DAC1L_ENA_MASK | WM8994_DAC1R_ENA_MASK, + WM8994_AIF2DACL_ENA | WM8994_AIF2DACR_ENA | WM8994_DAC1L_ENA | + WM8994_DAC1R_ENA); + + /* Head Phone Initialisation */ + ret |= wm8994_update_bits(WM8994_ANALOGUE_HP_1, + WM8994_HPOUT1L_DLY_MASK | WM8994_HPOUT1R_DLY_MASK, + WM8994_HPOUT1L_DLY | WM8994_HPOUT1R_DLY); + + ret |= wm8994_update_bits(WM8994_DC_SERVO_1, + WM8994_DCS_ENA_CHAN_0_MASK | + WM8994_DCS_ENA_CHAN_1_MASK , WM8994_DCS_ENA_CHAN_0 | + WM8994_DCS_ENA_CHAN_1); + + ret |= wm8994_update_bits(WM8994_ANALOGUE_HP_1, + WM8994_HPOUT1L_DLY_MASK | + WM8994_HPOUT1R_DLY_MASK | WM8994_HPOUT1L_OUTP_MASK | + WM8994_HPOUT1R_OUTP_MASK | + WM8994_HPOUT1L_RMV_SHORT_MASK | + WM8994_HPOUT1R_RMV_SHORT_MASK, WM8994_HPOUT1L_DLY | + WM8994_HPOUT1R_DLY | WM8994_HPOUT1L_OUTP | + WM8994_HPOUT1R_OUTP | WM8994_HPOUT1L_RMV_SHORT | + WM8994_HPOUT1R_RMV_SHORT); + + /* MIXER Config DAC1 to HP */ + ret |= wm8994_update_bits(WM8994_OUTPUT_MIXER_1, + WM8994_DAC1L_TO_HPOUT1L_MASK, WM8994_DAC1L_TO_HPOUT1L); + + ret |= wm8994_update_bits(WM8994_OUTPUT_MIXER_2, + WM8994_DAC1R_TO_HPOUT1R_MASK, WM8994_DAC1R_TO_HPOUT1R); + + /* Routing AIF2 to DAC1 */ + ret |= wm8994_update_bits(WM8994_DAC1_LEFT_MIXER_ROUTING, + WM8994_AIF2DACL_TO_DAC1L_MASK, + WM8994_AIF2DACL_TO_DAC1L); + + ret |= wm8994_update_bits(WM8994_DAC1_RIGHT_MIXER_ROUTING, + WM8994_AIF2DACR_TO_DAC1R_MASK, + WM8994_AIF2DACR_TO_DAC1R); + + /* GPIO Settings for AIF2 */ + /* B CLK */ + ret |= wm8994_update_bits(WM8994_GPIO_3, WM8994_GPIO_DIR_MASK | + WM8994_GPIO_FUNCTION_MASK , + WM8994_GPIO_DIR_OUTPUT | + WM8994_GPIO_FUNCTION_I2S_CLK); + + /* LR CLK */ + ret |= wm8994_update_bits(WM8994_GPIO_4, WM8994_GPIO_DIR_MASK | + WM8994_GPIO_FUNCTION_MASK, + WM8994_GPIO_DIR_OUTPUT | + WM8994_GPIO_FUNCTION_I2S_CLK); + + /* DATA */ + ret |= wm8994_update_bits(WM8994_GPIO_5, WM8994_GPIO_DIR_MASK | + WM8994_GPIO_FUNCTION_MASK, + WM8994_GPIO_DIR_OUTPUT | + WM8994_GPIO_FUNCTION_I2S_CLK); + + ret |= wm8994_init_volume_aif2_dac1(); + if (ret < 0) + goto err; + + debug("%s: Codec chip init ok\n", __func__); + return 0; +err: + debug("%s: Codec chip init error\n", __func__); + return -1; +} + +/*wm8994 Device Initialisation */ +int wm8994_init(struct sound_codec_info *pcodec_info, + enum en_audio_interface aif_id, + int sampling_rate, int mclk_freq, + int bits_per_sample, unsigned int channels) +{ + int ret = 0; + + /* shift the device address by 1 for 7 bit addressing */ + g_wm8994_i2c_dev_addr = pcodec_info->i2c_dev_addr; + wm8994_i2c_init(pcodec_info->i2c_bus); + + if (pcodec_info->codec_type == CODEC_WM_8994) + g_wm8994_info.type = WM8994; + else { + debug("%s: Codec id [%d] not defined\n", __func__, + pcodec_info->codec_type); + return -1; + } + + ret = wm8994_device_init(&g_wm8994_info); + if (ret < 0) { + debug("%s: wm8994 codec chip init failed\n", __func__); + return ret; + } + + ret = wm8994_set_sysclk(&g_wm8994_info, aif_id, WM8994_SYSCLK_MCLK1, + mclk_freq); + if (ret < 0) { + debug("%s: wm8994 codec set sys clock failed\n", __func__); + return ret; + } + + ret = wm8994_hw_params(&g_wm8994_info, aif_id, sampling_rate, + bits_per_sample, channels); + + if (ret == 0) { + ret = wm8994_set_fmt(aif_id, SND_SOC_DAIFMT_I2S | + SND_SOC_DAIFMT_NB_NF | + SND_SOC_DAIFMT_CBS_CFS); + } + return ret; +} diff --git a/drivers/sound/wm8994.h b/drivers/sound/wm8994.h new file mode 100644 index 0000000..a8f0de1 --- /dev/null +++ b/drivers/sound/wm8994.h @@ -0,0 +1,87 @@ +/* + * Copyright (C) 2012 Samsung Electronics + * R. Chadrasekar rcsekar@samsung.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __WM8994_H__ +#define __WM8994_H__ + +/* Sources for AIF1/2 SYSCLK - use with set_dai_sysclk() */ +#define WM8994_SYSCLK_MCLK1 1 +#define WM8994_SYSCLK_MCLK2 2 +#define WM8994_SYSCLK_FLL1 3 +#define WM8994_SYSCLK_FLL2 4 + +/* Avilable audi interface ports in wm8994 codec */ +enum en_audio_interface { + WM8994_AIF1 = 1, + WM8994_AIF2, + WM8994_AIF3 +}; + +/* OPCLK is also configured with set_dai_sysclk, specify division*10 as rate. */ +#define WM8994_SYSCLK_OPCLK 5 + +#define WM8994_FLL1 1 +#define WM8994_FLL2 2 + +#define WM8994_FLL_SRC_MCLK1 1 +#define WM8994_FLL_SRC_MCLK2 2 +#define WM8994_FLL_SRC_LRCLK 3 +#define WM8994_FLL_SRC_BCLK 4 + +/* maximum available digital interfac in the dac to configure */ +#define WM8994_MAX_AIF 2 + +#define WM8994_MAX_INPUT_CLK_FREQ 13500000 +#define WM8994_ID 0x8994 + +enum wm8994_vmid_mode { + WM8994_VMID_NORMAL, + WM8994_VMID_FORCE, +}; + +/* wm 8994 family devices */ +enum wm8994_type { + WM8994 = 0, + WM8958 = 1, + WM1811 = 2, +}; + +/* + * intialise wm8994 sound codec device for the given configuration + * + * @param pcodec_info pointer value of the sound codec info structure + * parsed from device tree + * @param aif_id enum value of codec interface port in which + * soc i2s is connected + * @param sampling_rate Sampling rate ranges between from 8khz to 96khz + * @param mclk_freq Master clock frequency. + * @param bits_per_sample bits per Sample can be 16 or 24 + * @param channels Number of channnels, maximum 2 + * + * @returns -1 for error and 0 Success. + */ +int wm8994_init(struct sound_codec_info *pcodec_info, + enum en_audio_interface aif_id, + int sampling_rate, int mclk_freq, + int bits_per_sample, unsigned int channels); +#endif /*__WM8994_H__ */ diff --git a/drivers/sound/wm8994_registers.h b/drivers/sound/wm8994_registers.h new file mode 100644 index 0000000..f455b11 --- /dev/null +++ b/drivers/sound/wm8994_registers.h @@ -0,0 +1,299 @@ +/* + * (C) Copyright 2012 Samsung Electronics + * + * This program is free software; you can redistribute it and/or modify it + * under the terms of the GNU General Public License as published by the + * Free Software Foundation; either version 2 of the License, or (at your + * option) any later version. + * + */ + +#ifndef __WM8994_REGISTERS_H__ +#define __WM8994_REGISTERS_H__ + +/* + * Register values. + */ +#define WM8994_SOFTWARE_RESET 0x00 +#define WM8994_POWER_MANAGEMENT_1 0x01 +#define WM8994_POWER_MANAGEMENT_2 0x02 +#define WM8994_POWER_MANAGEMENT_5 0x05 +#define WM8994_LEFT_OUTPUT_VOLUME 0x1C +#define WM8994_RIGHT_OUTPUT_VOLUME 0x1D +#define WM8994_OUTPUT_MIXER_1 0x2D +#define WM8994_OUTPUT_MIXER_2 0x2E +#define WM8994_CHARGE_PUMP_1 0x4C +#define WM8994_DC_SERVO_1 0x54 +#define WM8994_ANALOGUE_HP_1 0x60 +#define WM8994_CHIP_REVISION 0x100 +#define WM8994_AIF1_CLOCKING_1 0x200 +#define WM8994_AIF1_CLOCKING_2 0x201 +#define WM8994_AIF2_CLOCKING_1 0x204 +#define WM8994_CLOCKING_1 0x208 +#define WM8994_CLOCKING_2 0x209 +#define WM8994_AIF1_RATE 0x210 +#define WM8994_AIF2_RATE 0x211 +#define WM8994_RATE_STATUS 0x212 +#define WM8994_AIF1_CONTROL_1 0x300 +#define WM8994_AIF1_CONTROL_2 0x301 +#define WM8994_AIF1_MASTER_SLAVE 0x302 +#define WM8994_AIF1_BCLK 0x303 +#define WM8994_AIF2_CONTROL_1 0x310 +#define WM8994_AIF2_CONTROL_2 0x311 +#define WM8994_AIF2_MASTER_SLAVE 0x312 +#define WM8994_AIF2_BCLK 0x313 +#define WM8994_AIF2_DAC_LEFT_VOLUME 0x502 +#define WM8994_AIF2_DAC_RIGHT_VOLUME 0x503 +#define WM8994_AIF2_DAC_FILTERS_1 0x520 +#define WM8994_DAC1_LEFT_MIXER_ROUTING 0x601 +#define WM8994_DAC1_RIGHT_MIXER_ROUTING 0x602 +#define WM8994_DAC1_LEFT_VOLUME 0x610 +#define WM8994_DAC1_RIGHT_VOLUME 0x611 +#define WM8994_GPIO_3 0x702 +#define WM8994_GPIO_4 0x703 +#define WM8994_GPIO_5 0x704 + +/* + * Field Definitions. + */ + +/* + * R0 (0x00) - Software Reset + */ +/* SW_RESET */ +#define WM8994_SW_RESET 1 +/* + * R1 (0x01) - Power Management (1) + */ +/* HPOUT1L_ENA */ +#define WM8994_HPOUT1L_ENA 0x0200 +/* HPOUT1L_ENA */ +#define WM8994_HPOUT1L_ENA_MASK 0x0200 +/* HPOUT1R_ENA */ +#define WM8994_HPOUT1R_ENA 0x0100 +/* HPOUT1R_ENA */ +#define WM8994_HPOUT1R_ENA_MASK 0x0100 +/* VMID_SEL - [2:1] */ +#define WM8994_VMID_SEL_MASK 0x0006 +/* BIAS_ENA */ +#define WM8994_BIAS_ENA 0x0001 +/* BIAS_ENA */ +#define WM8994_BIAS_ENA_MASK 0x0001 + +/* + * R2 (0x02) - Power Management (2) + */ +/* OPCLK_ENA */ +#define WM8994_OPCLK_ENA 0x0800 + +/* + * R5 (0x05) - Power Management (5) + */ +/* AIF2DACL_ENA */ +#define WM8994_AIF2DACL_ENA 0x2000 +#define WM8994_AIF2DACL_ENA_MASK 0x2000 +/* AIF2DACR_ENA */ +#define WM8994_AIF2DACR_ENA 0x1000 +#define WM8994_AIF2DACR_ENA_MASK 0x1000 +/* DAC1L_ENA */ +#define WM8994_DAC1L_ENA 0x0002 +#define WM8994_DAC1L_ENA_MASK 0x0002 +/* DAC1R_ENA */ +#define WM8994_DAC1R_ENA 0x0001 +#define WM8994_DAC1R_ENA_MASK 0x0001 + +/* + * R45 (0x2D) - Output Mixer (1) + */ +/* DAC1L_TO_HPOUT1L */ +#define WM8994_DAC1L_TO_HPOUT1L 0x0100 +#define WM8994_DAC1L_TO_HPOUT1L_MASK 0x0100 + +/* + * R46 (0x2E) - Output Mixer (2) + */ +/* DAC1R_TO_HPOUT1R */ +#define WM8994_DAC1R_TO_HPOUT1R 0x0100 +#define WM8994_DAC1R_TO_HPOUT1R_MASK 0x0100 + +/* + * R76 (0x4C) - Charge Pump (1) + */ +/* CP_ENA */ +#define WM8994_CP_ENA 0x8000 +#define WM8994_CP_ENA_MASK 0x8000 +/* + * R84 (0x54) - DC Servo (1) + */ +/* DCS_ENA_CHAN_1 */ +#define WM8994_DCS_ENA_CHAN_1 0x0002 +#define WM8994_DCS_ENA_CHAN_1_MASK 0x0002 +/* DCS_ENA_CHAN_0 */ +#define WM8994_DCS_ENA_CHAN_0 0x0001 +#define WM8994_DCS_ENA_CHAN_0_MASK 0x0001 + +/* + * R96 (0x60) - Analogue HP (1) + */ +/* HPOUT1L_RMV_SHORT */ +#define WM8994_HPOUT1L_RMV_SHORT 0x0080 +#define WM8994_HPOUT1L_RMV_SHORT_MASK 0x0080 +/* HPOUT1L_OUTP */ +#define WM8994_HPOUT1L_OUTP 0x0040 +#define WM8994_HPOUT1L_OUTP_MASK 0x0040 +/* HPOUT1L_DLY */ +#define WM8994_HPOUT1L_DLY 0x0020 +#define WM8994_HPOUT1L_DLY_MASK 0x0020 +/* HPOUT1R_RMV_SHORT */ +#define WM8994_HPOUT1R_RMV_SHORT 0x0008 +#define WM8994_HPOUT1R_RMV_SHORT_MASK 0x0008 +/* HPOUT1R_OUTP */ +#define WM8994_HPOUT1R_OUTP 0x0004 +#define WM8994_HPOUT1R_OUTP_MASK 0x0004 +/* HPOUT1R_DLY */ +#define WM8994_HPOUT1R_DLY 0x0002 +#define WM8994_HPOUT1R_DLY_MASK 0x0002 + +/* + * R512 (0x200) - AIF1 Clocking (1) + */ +/* AIF1CLK_SRC - [4:3] */ +#define WM8994_AIF1CLK_SRC_MASK 0x0018 +/* AIF1CLK_DIV */ +#define WM8994_AIF1CLK_DIV 0x0002 +/* AIF1CLK_ENA */ +#define WM8994_AIF1CLK_ENA 0x0001 +#define WM8994_AIF1CLK_ENA_MASK 0x0001 + +/* + * R517 (0x205) - AIF2 Clocking (2) + */ +/* AIF2DAC_DIV - [5:3] */ +#define WM8994_AIF2DAC_DIV_MASK 0x0038 + +/* + * R520 (0x208) - Clocking (1) + */ +/* AIF2DSPCLK_ENA */ +#define WM8994_AIF2DSPCLK_ENA 0x0004 +#define WM8994_AIF2DSPCLK_ENA_MASK 0x0004 +/* SYSDSPCLK_ENA */ +#define WM8994_SYSDSPCLK_ENA 0x0002 +#define WM8994_SYSDSPCLK_ENA_MASK 0x0002 +/* SYSCLK_SRC */ +#define WM8994_SYSCLK_SRC 0x0001 + +/* + * R521 (0x209) - Clocking (2) + */ +/* OPCLK_DIV - [2:0] */ +#define WM8994_OPCLK_DIV_MASK 0x0007 + +/* + * R528 (0x210) - AIF1 Rate + */ +/* AIF1_SR - [7:4] */ +#define WM8994_AIF1_SR_MASK 0x00F0 +#define WM8994_AIF1_SR_SHIFT 4 +/* AIF1CLK_RATE - [3:0] */ +#define WM8994_AIF1CLK_RATE_MASK 0x000F + +/* + * R768 (0x300) - AIF1 Control (1) + */ +/* AIF1_BCLK_INV */ +#define WM8994_AIF1_BCLK_INV 0x0100 +/* AIF1_LRCLK_INV */ +#define WM8994_AIF1_LRCLK_INV 0x0080 +#define WM8994_AIF1_LRCLK_INV_MASK 0x0080 +/* AIF1_WL - [6:5] */ +#define WM8994_AIF1_WL_MASK 0x0060 +/* AIF1_FMT - [4:3] */ +#define WM8994_AIF1_FMT_MASK 0x0018 + +/* + * R769 (0x301) - AIF1 Control (2) + */ +/* AIF1_MONO */ +#define WM8994_AIF1_MONO 0x0100 + +/* + * R770 (0x302) - AIF1 Master/Slave + */ +/* AIF1_MSTR */ +#define WM8994_AIF1_MSTR 0x4000 +#define WM8994_AIF1_MSTR_MASK 0x4000 + +/* + * R771 (0x303) - AIF1 BCLK + */ +/* AIF1_BCLK_DIV - [8:4] */ +#define WM8994_AIF1_BCLK_DIV_MASK 0x01F0 +#define WM8994_AIF1_BCLK_DIV_SHIFT 4 + +/* + * R1282 (0x502) - AIF2 DAC Left Volume + */ +/* AIF2DAC_VU */ +#define WM8994_AIF2DAC_VU 0x0100 +#define WM8994_AIF2DAC_VU_MASK 0x0100 +/* AIF2DACL_VOL - [7:0] */ +#define WM8994_AIF2DACL_VOL_MASK 0x00FF + +/* + * R1283 (0x503) - AIF2 DAC Right Volume + */ +/* AIF2DACR_VOL - [7:0] */ +#define WM8994_AIF2DACR_VOL_MASK 0x00FF + +/* + * R1312 (0x520) - AIF2 DAC Filters (1) + */ +/* AIF2DAC_MUTE */ +#define WM8994_AIF2DAC_MUTE_MASK 0x0200 + +/* + * R1537 (0x601) - DAC1 Left Mixer Routing + */ +/* AIF2DACL_TO_DAC1L */ +#define WM8994_AIF2DACL_TO_DAC1L 0x0004 +#define WM8994_AIF2DACL_TO_DAC1L_MASK 0x0004 + +/* + * R1538 (0x602) - DAC1 Right Mixer Routing + */ +/* AIF2DACR_TO_DAC1R */ +#define WM8994_AIF2DACR_TO_DAC1R 0x0004 +#define WM8994_AIF2DACR_TO_DAC1R_MASK 0x0004 + +/* + * R1552 (0x610) - DAC1 Left Volume + */ +/* DAC1L_MUTE */ +#define WM8994_DAC1L_MUTE_MASK 0x0200 +/* DAC1_VU */ +#define WM8994_DAC1_VU 0x0100 +#define WM8994_DAC1_VU_MASK 0x0100 +/* DAC1L_VOL - [7:0] */ +#define WM8994_DAC1L_VOL_MASK 0x00FF + +/* + * R1553 (0x611) - DAC1 Right Volume + */ +/* DAC1R_MUTE */ +#define WM8994_DAC1R_MUTE_MASK 0x0200 +/* DAC1R_VOL - [7:0] */ +#define WM8994_DAC1R_VOL_MASK 0x00FF + +/* + * GPIO + */ +/* OUTPUT PIN */ +#define WM8994_GPIO_DIR_OUTPUT 0x8000 +/* GPIO PIN MASK */ +#define WM8994_GPIO_DIR_MASK 0xFFE0 +/* I2S CLK */ +#define WM8994_GPIO_FUNCTION_I2S_CLK 0x0000 +/* GPn FN */ +#define WM8994_GPIO_FUNCTION_MASK 0x001F +#endif
This patch adds command to test audio playback. sound init - Initialises the audio subsystem (i2s and wm8994 codec) sound play - Plays predefined the audio data when specified length and frequency.
Signed-off-by: Rajeshwari Shinde rajeshwari.s@samsung.com Acked-by: Simon Glass sjg@chromium.org --- Changes in V2: - None Changes in V3: - Incorporated comments from Simon Glass. Changes in V4: - None common/Makefile | 1 + common/cmd_sound.c | 96 ++++++++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 97 insertions(+), 0 deletions(-) create mode 100644 common/cmd_sound.c
diff --git a/common/Makefile b/common/Makefile index fdfead7..3f9f001 100644 --- a/common/Makefile +++ b/common/Makefile @@ -74,6 +74,7 @@ COBJS-$(CONFIG_CMD_CONSOLE) += cmd_console.o COBJS-$(CONFIG_CMD_CPLBINFO) += cmd_cplbinfo.o COBJS-$(CONFIG_DATAFLASH_MMC_SELECT) += cmd_dataflash_mmc_mux.o COBJS-$(CONFIG_CMD_DATE) += cmd_date.o +COBJS-$(CONFIG_CMD_SOUND) += cmd_sound.o ifdef CONFIG_4xx COBJS-$(CONFIG_CMD_SETGETDCR) += cmd_dcr.o endif diff --git a/common/cmd_sound.c b/common/cmd_sound.c new file mode 100644 index 0000000..459d1eb --- /dev/null +++ b/common/cmd_sound.c @@ -0,0 +1,96 @@ +/* + * Copyright (C) 2012 Samsung Electronics + * Rajeshwari Shinde rajeshwari.s@samsung.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <command.h> +#include <fdtdec.h> +#include <sound.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* Initilaise sound subsystem */ +static int do_init(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) +{ + int ret; + + ret = sound_init(); + if (ret) { + printf("Initialise Audio driver failed\n"); + return CMD_RET_FAILURE; + } + + return 0; +} + +/* play sound from buffer */ +static int do_play(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) +{ + int ret = 0; + int msec = 1000; + int freq = 400; + + if (argc > 1) + msec = simple_strtoul(argv[1], NULL, 10); + if (argc > 2) + freq = simple_strtoul(argv[2], NULL, 10); + + ret = sound_play(msec, freq); + if (ret) { + printf("play failed"); + return CMD_RET_FAILURE; + } + + return 0; +} + +static cmd_tbl_t cmd_sound_sub[] = { + U_BOOT_CMD_MKENT(init, 0, 1, do_init, "", ""), + U_BOOT_CMD_MKENT(play, 2, 1, do_play, "", ""), +}; + +/* process sound command */ +static int do_sound(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) +{ + cmd_tbl_t *c; + + if (argc < 1) + return CMD_RET_USAGE; + + /* Strip off leading 'sound' command argument */ + argc--; + argv++; + + c = find_cmd_tbl(argv[0], &cmd_sound_sub[0], ARRAY_SIZE(cmd_sound_sub)); + + if (c) + return c->cmd(cmdtp, flag, argc, argv); + else + return CMD_RET_USAGE; +} + +U_BOOT_CMD( + sound, 4, 1, do_sound, + "sound sub-system", + "init - initialise the sound driver\n" + "sound play [len] [freq] - play a sound for len ms at freq hz\n" +);
This patch add I2S registers
Signed-off-by: R. Chandrasekar rcsekar@samsung.com Signed-off-by: Rajeshwari Shinde rajeshwari.s@samsung.com Acked-by: Simon Glass sjg@chromium.org --- Changes in V2: - None Changes in V3: - None Changes in V4: - None arch/arm/include/asm/arch-exynos/i2s-regs.h | 66 +++++++++++++++++++++++++++ 1 files changed, 66 insertions(+), 0 deletions(-) create mode 100644 arch/arm/include/asm/arch-exynos/i2s-regs.h
diff --git a/arch/arm/include/asm/arch-exynos/i2s-regs.h b/arch/arm/include/asm/arch-exynos/i2s-regs.h new file mode 100644 index 0000000..2326ca0 --- /dev/null +++ b/arch/arm/include/asm/arch-exynos/i2s-regs.h @@ -0,0 +1,66 @@ +/* + * Copyright (C) 2012 Samsung Electronics + * R. Chandrasekar rcsekar@samsung.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __I2S_REGS_H__ +#define __I2S_REGS_H__ + +#define CON_TXFIFO_FULL (1 << 8) +#define CON_TXCH_PAUSE (1 << 4) +#define CON_ACTIVE (1 << 0) + +#define MOD_BLCP_SHIFT 24 +#define MOD_BLCP_16BIT (0 << MOD_BLCP_SHIFT) +#define MOD_BLCP_8BIT (1 << MOD_BLCP_SHIFT) +#define MOD_BLCP_24BIT (2 << MOD_BLCP_SHIFT) +#define MOD_BLCP_MASK (3 << MOD_BLCP_SHIFT) + +#define MOD_BLC_16BIT (0 << 13) +#define MOD_BLC_8BIT (1 << 13) +#define MOD_BLC_24BIT (2 << 13) +#define MOD_BLC_MASK (3 << 13) + +#define MOD_SLAVE (1 << 11) +#define MOD_MASK (3 << 8) +#define MOD_LR_LLOW (0 << 7) +#define MOD_LR_RLOW (1 << 7) +#define MOD_SDF_IIS (0 << 5) +#define MOD_SDF_MSB (1 << 5) +#define MOD_SDF_LSB (2 << 5) +#define MOD_SDF_MASK (3 << 5) +#define MOD_RCLK_256FS (0 << 3) +#define MOD_RCLK_512FS (1 << 3) +#define MOD_RCLK_384FS (2 << 3) +#define MOD_RCLK_768FS (3 << 3) +#define MOD_RCLK_MASK (3 << 3) +#define MOD_BCLK_32FS (0 << 1) +#define MOD_BCLK_48FS (1 << 1) +#define MOD_BCLK_16FS (2 << 1) +#define MOD_BCLK_24FS (3 << 1) +#define MOD_BCLK_MASK (3 << 1) + +#define MOD_CDCLKCON (1 << 12) + +#define FIC_TXFLUSH (1 << 15) +#define FIC_RXFLUSH (1 << 7) + +#endif /* __I2S_REGS_H__ */
This patch adds the audio parameters required by the I2S to play the predefined audio data.
Signed-off-by: Rajeshwari Shinde rajeshwari.s@samsung.com Acked-by: Simon Glass sjg@chromium.org --- Changes in V2: - None Changes in V3: - Changed codec I2C address to 0x1a. Changes in V4: - None arch/arm/include/asm/arch-exynos/sound.h | 44 ++++++++++++++++++++++++++++++ 1 files changed, 44 insertions(+), 0 deletions(-) create mode 100644 arch/arm/include/asm/arch-exynos/sound.h
diff --git a/arch/arm/include/asm/arch-exynos/sound.h b/arch/arm/include/asm/arch-exynos/sound.h new file mode 100644 index 0000000..d1bd2f6 --- /dev/null +++ b/arch/arm/include/asm/arch-exynos/sound.h @@ -0,0 +1,44 @@ +/* + * Copyright (C) 2012 Samsung Electronics + * Rajeshwari Shinde rajeshwari.s@samsung.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + + +#ifndef __SOUND_ARCH_H__ +#define __SOUND_ARCH_H__ + +/* I2S values */ +#define I2S_PLL_CLK 192000000 +#define I2S_SAMPLING_RATE 48000 +#define I2S_BITS_PER_SAMPLE 16 +#define I2S_CHANNELS 2 +#define I2S_RFS 256 +#define I2S_BFS 32 + +/* I2C values */ +#define AUDIO_I2C_BUS 1 +#define AUDIO_I2C_REG 0x1a + +/* Audio Codec */ +#define AUDIO_CODEC "wm8994" + +#define AUDIO_COMPAT 1 +#endif
This patch adds pinmux support for I2S1
Signed-off-by: Rajeshwari Shinde rajeshwari.s@samsung.com Acked-by: Simon Glass sjg@chromium.org --- Changes in V2: - made exynos_i2s_config pinmux function static. Changes in V3: - Incorporated comments from Simon Glass Changes in V4: - None arch/arm/cpu/armv7/exynos/pinmux.c | 13 +++++++++++++ arch/arm/include/asm/arch-exynos/periph.h | 1 + 2 files changed, 14 insertions(+), 0 deletions(-)
diff --git a/arch/arm/cpu/armv7/exynos/pinmux.c b/arch/arm/cpu/armv7/exynos/pinmux.c index 5796d56..d99daa0 100644 --- a/arch/arm/cpu/armv7/exynos/pinmux.c +++ b/arch/arm/cpu/armv7/exynos/pinmux.c @@ -230,6 +230,16 @@ static void exynos5_i2c_config(int peripheral, int flags) } }
+static void exynos5_i2s_config(int peripheral) +{ + int i; + struct exynos5_gpio_part1 *gpio1 = + (struct exynos5_gpio_part1 *) samsung_get_base_gpio_part1(); + + for (i = 0; i < 5; i++) + s5p_gpio_cfg_pin(&gpio1->b0, i, GPIO_FUNC(0x02)); +} + static int exynos5_pinmux_config(int peripheral, int flags) { switch (peripheral) { @@ -257,6 +267,9 @@ static int exynos5_pinmux_config(int peripheral, int flags) case PERIPH_ID_I2C7: exynos5_i2c_config(peripheral, flags); break; + case PERIPH_ID_I2S1: + exynos5_i2s_config(peripheral); + break; default: debug("%s: invalid peripheral %d", __func__, peripheral); return -1; diff --git a/arch/arm/include/asm/arch-exynos/periph.h b/arch/arm/include/asm/arch-exynos/periph.h index 082611c..673f4c7 100644 --- a/arch/arm/include/asm/arch-exynos/periph.h +++ b/arch/arm/include/asm/arch-exynos/periph.h @@ -38,6 +38,7 @@ enum periph_id { PERIPH_ID_I2C5, PERIPH_ID_I2C6, PERIPH_ID_I2C7, + PERIPH_ID_I2S1, PERIPH_ID_SDMMC0, PERIPH_ID_SDMMC1, PERIPH_ID_SDMMC2,
This patch adds base address for I2S
Signed-off-by: Rajeshwari Shinde rajeshwari.s@samsung.com Acked-by: Chander Kashyap chander.kashyap@gmail.com Acked-by: Simon Glass sjg@chromium.org --- Changes in V2: - None Changes in V3: - None Changes in V4: - None arch/arm/include/asm/arch-exynos/cpu.h | 3 +++ 1 files changed, 3 insertions(+), 0 deletions(-)
diff --git a/arch/arm/include/asm/arch-exynos/cpu.h b/arch/arm/include/asm/arch-exynos/cpu.h index 2cd4ae1..ace40e5 100644 --- a/arch/arm/include/asm/arch-exynos/cpu.h +++ b/arch/arm/include/asm/arch-exynos/cpu.h @@ -54,6 +54,7 @@ #define EXYNOS4_PWMTIMER_BASE 0x139D0000 #define EXYNOS4_MODEM_BASE 0x13A00000 #define EXYNOS4_USBPHY_CONTROL 0x10020704 +#define EXYNOS4_I2S_BASE 0xE2100000
#define EXYNOS4_GPIO_PART4_BASE DEVICE_NOT_AVAILABLE #define EXYNOS4_DP_BASE DEVICE_NOT_AVAILABLE @@ -81,6 +82,7 @@ #define EXYNOS5_SROMC_BASE 0x12250000 #define EXYNOS5_UART_BASE 0x12C00000 #define EXYNOS5_I2C_BASE 0x12C60000 +#define EXYNOS5_I2S_BASE 0x12D60000 #define EXYNOS5_PWMTIMER_BASE 0x12DD0000 #define EXYNOS5_GPIO_PART2_BASE 0x13400000 #define EXYNOS5_FIMD_BASE 0x14400000 @@ -156,6 +158,7 @@ SAMSUNG_BASE(dp, DP_BASE) SAMSUNG_BASE(sysreg, SYSREG_BASE) SAMSUNG_BASE(fimd, FIMD_BASE) SAMSUNG_BASE(i2c, I2C_BASE) +SAMSUNG_BASE(i2s, I2S_BASE) SAMSUNG_BASE(mipi_dsim, MIPI_DSIM_BASE) SAMSUNG_BASE(gpio_part1, GPIO_PART1_BASE) SAMSUNG_BASE(gpio_part2, GPIO_PART2_BASE)
This patch adds clock support for I2S
Signed-off-by: R. Chandrasekar rcsekar@samsung.com Signed-off-by: Rajeshwari Shinde rajeshwari.s@samsung.com Acked-by: Simon Glass sjg@chromium.org --- Changes in V2: - None Changes in V3: - Changes clock function names as suggested by Minkyu Kang. Changes in V4: - None arch/arm/cpu/armv7/exynos/clock.c | 120 ++++++++++++++++++++++++++++++ arch/arm/include/asm/arch-exynos/clk.h | 3 + arch/arm/include/asm/arch-exynos/clock.h | 29 +++++++ 3 files changed, 152 insertions(+), 0 deletions(-)
diff --git a/arch/arm/cpu/armv7/exynos/clock.c b/arch/arm/cpu/armv7/exynos/clock.c index 4f3b451..5f7d884 100644 --- a/arch/arm/cpu/armv7/exynos/clock.c +++ b/arch/arm/cpu/armv7/exynos/clock.c @@ -26,6 +26,16 @@ #include <asm/arch/clock.h> #include <asm/arch/clk.h>
+/* Epll Clock division values to achive different frequency output */ +static struct set_epll_con_val exynos5_epll_div[] = { + { 192000000, 0, 48, 3, 1, 0 }, + { 180000000, 0, 45, 3, 1, 0 }, + { 73728000, 1, 73, 3, 3, 47710 }, + { 67737600, 1, 90, 4, 3, 20762 }, + { 49152000, 0, 49, 3, 3, 9961 }, + { 45158400, 0, 45, 3, 3, 10381 }, + { 180633600, 0, 45, 3, 1, 10381 } +}; /* exynos4: return pll clock frequency */ static unsigned long exynos4_get_pll_clk(int pllreg) { @@ -732,6 +742,93 @@ static unsigned long exynos5_get_i2c_clk(void) return aclk_66; }
+int exynos5_set_epll_clk(unsigned long rate) +{ + unsigned int epll_con, epll_con_k; + unsigned int i; + unsigned int lockcnt; + unsigned int start; + struct exynos5_clock *clk = + (struct exynos5_clock *)samsung_get_base_clock(); + + epll_con = readl(&clk->epll_con0); + epll_con &= ~((EPLL_CON0_LOCK_DET_EN_MASK << + EPLL_CON0_LOCK_DET_EN_SHIFT) | + EPLL_CON0_MDIV_MASK << EPLL_CON0_MDIV_SHIFT | + EPLL_CON0_PDIV_MASK << EPLL_CON0_PDIV_SHIFT | + EPLL_CON0_SDIV_MASK << EPLL_CON0_SDIV_SHIFT); + + for (i = 0; i < ARRAY_SIZE(exynos5_epll_div); i++) { + if (exynos5_epll_div[i].freq_out == rate) + break; + } + + if (i == ARRAY_SIZE(exynos5_epll_div)) + return -1; + + epll_con_k = exynos5_epll_div[i].k_dsm << 0; + epll_con |= exynos5_epll_div[i].en_lock_det << + EPLL_CON0_LOCK_DET_EN_SHIFT; + epll_con |= exynos5_epll_div[i].m_div << EPLL_CON0_MDIV_SHIFT; + epll_con |= exynos5_epll_div[i].p_div << EPLL_CON0_PDIV_SHIFT; + epll_con |= exynos5_epll_div[i].s_div << EPLL_CON0_SDIV_SHIFT; + + /* + * Required period ( in cycles) to genarate a stable clock output. + * The maximum clock time can be up to 3000 * PDIV cycles of PLLs + * frequency input (as per spec) + */ + lockcnt = 3000 * exynos5_epll_div[i].p_div; + + writel(lockcnt, &clk->epll_lock); + writel(epll_con, &clk->epll_con0); + writel(epll_con_k, &clk->epll_con1); + + start = get_timer(0); + + while (!(readl(&clk->epll_con0) & + (0x1 << EXYNOS5_EPLLCON0_LOCKED_SHIFT))) { + if (get_timer(start) > TIMEOUT_EPLL_LOCK) { + debug("%s: Timeout waiting for EPLL lock\n", __func__); + return -1; + } + } + return 0; +} + +void exynos5_set_i2s_clk_source(void) +{ + struct exynos5_clock *clk = + (struct exynos5_clock *)samsung_get_base_clock(); + + clrsetbits_le32(&clk->src_peric1, AUDIO1_SEL_MASK, + (CLK_SRC_SCLK_EPLL)); +} + +int exynos5_set_i2s_clk_prescaler(unsigned int src_frq, + unsigned int dst_frq) +{ + struct exynos5_clock *clk = + (struct exynos5_clock *)samsung_get_base_clock(); + unsigned int div; + + if ((dst_frq == 0) || (src_frq == 0)) { + debug("%s: Invalid requency input for prescaler\n", __func__); + debug("src frq = %d des frq = %d ", src_frq, dst_frq); + return -1; + } + + div = (src_frq / dst_frq); + if (div > AUDIO_1_RATIO_MASK) { + debug("%s: Frequency ratio is out of range\n", __func__); + debug("src frq = %d des frq = %d ", src_frq, dst_frq); + return -1; + } + clrsetbits_le32(&clk->div_peric4, AUDIO_1_RATIO_MASK, + (div & AUDIO_1_RATIO_MASK)); + return 0; +} + unsigned long get_pll_clk(int pllreg) { if (cpu_is_exynos5()) @@ -803,3 +900,26 @@ void set_mipi_clk(void) if (cpu_is_exynos4()) exynos4_set_mipi_clk(); } + +int set_i2s_clk_prescaler(unsigned int src_frq, unsigned int dst_frq) +{ + + if (cpu_is_exynos5()) + return exynos5_set_i2s_clk_prescaler(src_frq, dst_frq); + else + return 0; +} + +void set_i2s_clk_source(void) +{ + if (cpu_is_exynos5()) + exynos5_set_i2s_clk_source(); +} + +int set_epll_clk(unsigned long rate) +{ + if (cpu_is_exynos5()) + return exynos5_set_epll_clk(rate); + else + return 0; +} diff --git a/arch/arm/include/asm/arch-exynos/clk.h b/arch/arm/include/asm/arch-exynos/clk.h index 5529025..2bf2c10 100644 --- a/arch/arm/include/asm/arch-exynos/clk.h +++ b/arch/arm/include/asm/arch-exynos/clk.h @@ -38,5 +38,8 @@ void set_mmc_clk(int dev_index, unsigned int div); unsigned long get_lcd_clk(void); void set_lcd_clk(void); void set_mipi_clk(void); +void set_i2s_clk_source(void); +int set_i2s_clk_prescaler(unsigned int src_frq, unsigned int dst_frq); +int set_epll_clk(unsigned long rate);
#endif diff --git a/arch/arm/include/asm/arch-exynos/clock.h b/arch/arm/include/asm/arch-exynos/clock.h index fce38ef..ff6781a 100644 --- a/arch/arm/include/asm/arch-exynos/clock.h +++ b/arch/arm/include/asm/arch-exynos/clock.h @@ -595,9 +595,38 @@ struct exynos5_clock { unsigned int pll_div2_sel; unsigned char res123[0xf5d8]; }; + +/* structure for epll configuration used in audio clock configuration */ +struct set_epll_con_val { + unsigned int freq_out; /* frequency out */ + unsigned int en_lock_det; /* enable lock detect */ + unsigned int m_div; /* m divider value */ + unsigned int p_div; /* p divider value */ + unsigned int s_div; /* s divider value */ + unsigned int k_dsm; /* k value of delta signal modulator */ +}; #endif
#define MPLL_FOUT_SEL_SHIFT 4 +#define EXYNOS5_EPLLCON0_LOCKED_SHIFT 29 /* EPLL Locked bit position*/ +#define TIMEOUT_EPLL_LOCK 1000 + +#define AUDIO_0_RATIO_MASK 0x0f +#define AUDIO_1_RATIO_MASK 0x0f + +#define AUDIO1_SEL_MASK 0xf +#define CLK_SRC_SCLK_EPLL 0x7 + +/* CON0 bit-fields */ +#define EPLL_CON0_MDIV_MASK 0x1ff +#define EPLL_CON0_PDIV_MASK 0x3f +#define EPLL_CON0_SDIV_MASK 0x7 +#define EPLL_CON0_MDIV_SHIFT 16 +#define EPLL_CON0_PDIV_SHIFT 8 +#define EPLL_CON0_SDIV_SHIFT 0 +#define EPLL_CON0_LOCK_DET_EN_SHIFT 28 +#define EPLL_CON0_LOCK_DET_EN_MASK 1 + #define MPLL_FOUT_SEL_MASK 0x1 #define BPLL_FOUT_SEL_SHIFT 0 #define BPLL_FOUT_SEL_MASK 0x1
This patch enables sound support for EXYNOS5
Signed-off-by: Rajeshwari Shinde rajeshwari.s@samsung.com Acked-by: Chander Kashyap chander.kashyap@linaro.org Acked-by: Simon Glass sjg@chromium.org --- Changes in V2: - corrected the commit message. Changes in V3: - None. Changes in V4: - None. include/configs/smdk5250.h | 8 ++++++++ 1 files changed, 8 insertions(+), 0 deletions(-)
diff --git a/include/configs/smdk5250.h b/include/configs/smdk5250.h index 91da167..4cb43b5 100644 --- a/include/configs/smdk5250.h +++ b/include/configs/smdk5250.h @@ -218,6 +218,14 @@ #define CONFIG_MENU #endif
+/* Sound */ +#define CONFIG_CMD_SOUND +#ifdef CONFIG_CMD_SOUND +#define CONFIG_SOUND +#define CONFIG_I2S +#define CONFIG_SOUND_WM8994 +#endif + /* Enable devicetree support */ #define CONFIG_OF_LIBFDT
Hi Rajeshwari,
On Thu, Oct 25, 2012 at 10:49 PM, Rajeshwari Shinde rajeshwari.s@samsung.com wrote:
This patchset adds the audio support for EXYNOS5. This patchset plays a predefined beep sound.
This all looks good to me. You already have my ACKs for each patch.
Rajeshwari Shinde (9): SOUND: SAMSUNG: Add I2S driver SOUND: Add WM8994 codec Sound: Add command for audio playback EXYNOS: Add I2S registers EXYNOS: Add parameters required by I2S EXYNOS: Add pinmux for I2S EXYNOS: Add I2S base address EXYNOS: Add clock for I2S SMDK5250: Enable Sound
Changes in V2:
- renamed i2s.c to samsung-i2s.c.
- corrected the commit message for "Enable sound" patch.
Changes in V3:
- Incorporated comments from Simon Glass and Minkyu Kang.
Changes in V4:
- Corrected the coding style issues suggested by Simon Glass.
Makefile | 1 + arch/arm/cpu/armv7/exynos/clock.c | 120 ++++ arch/arm/cpu/armv7/exynos/pinmux.c | 13 + arch/arm/include/asm/arch-exynos/clk.h | 3 + arch/arm/include/asm/arch-exynos/clock.h | 29 + arch/arm/include/asm/arch-exynos/cpu.h | 3 + arch/arm/include/asm/arch-exynos/i2s-regs.h | 66 +++ arch/arm/include/asm/arch-exynos/periph.h | 1 + arch/arm/include/asm/arch-exynos/sound.h | 44 ++ common/Makefile | 1 + common/cmd_sound.c | 96 ++++ drivers/sound/Makefile | 48 ++ drivers/sound/samsung-i2s.c | 358 ++++++++++++ drivers/sound/sound.c | 228 ++++++++ drivers/sound/wm8994.c | 792 +++++++++++++++++++++++++++ drivers/sound/wm8994.h | 87 +++ drivers/sound/wm8994_registers.h | 299 ++++++++++ include/configs/smdk5250.h | 8 + include/i2s.h | 127 +++++ include/sound.h | 62 +++ 20 files changed, 2386 insertions(+), 0 deletions(-) create mode 100644 arch/arm/include/asm/arch-exynos/i2s-regs.h create mode 100644 arch/arm/include/asm/arch-exynos/sound.h create mode 100644 common/cmd_sound.c create mode 100644 drivers/sound/Makefile create mode 100644 drivers/sound/samsung-i2s.c create mode 100644 drivers/sound/sound.c create mode 100644 drivers/sound/wm8994.c create mode 100644 drivers/sound/wm8994.h create mode 100644 drivers/sound/wm8994_registers.h create mode 100644 include/i2s.h create mode 100644 include/sound.h
-- 1.7.4.4
Changes in V2:
Changes in V3:
Changes in V4:
applied to u-boot-samsung.
Thanks. Minkyu Kang.
Minkyu Kang
Rajeshwari Shinde
