[PATCH v2 1/2] spl: mmc: Pass eMMC HW partition and SW partition to spl_mmc_get_uboot_raw_sector()
Pass both eMMC HW partition and software partition numbers to spl_mmc_get_uboot_raw_sector() so the function can better decide which offset within the partition to load payload from.
Signed-off-by: Fedor Ross fedor.ross@ifm.com Signed-off-by: Marek Vasut marex@denx.de --- Cc: Jaehoon Chung jh80.chung@samsung.com Cc: Peng Fan peng.fan@nxp.com --- V2: No change --- arch/arm/mach-imx/image-container.c | 2 ++ arch/arm/mach-sunxi/board.c | 2 ++ common/spl/spl_mmc.c | 15 +++++++++------ 3 files changed, 13 insertions(+), 6 deletions(-)
diff --git a/arch/arm/mach-imx/image-container.c b/arch/arm/mach-imx/image-container.c index 06ee608c4a4..c8c263fde7e 100644 --- a/arch/arm/mach-imx/image-container.c +++ b/arch/arm/mach-imx/image-container.c @@ -215,6 +215,8 @@ unsigned long spl_spi_get_uboot_offs(struct spi_flash *flash)
#ifdef CONFIG_SPL_MMC unsigned long spl_mmc_get_uboot_raw_sector(struct mmc *mmc, + unsigned long hw_part, + unsigned long raw_part, unsigned long raw_sect) { int end; diff --git a/arch/arm/mach-sunxi/board.c b/arch/arm/mach-sunxi/board.c index 391a65a5495..3be444d84fe 100644 --- a/arch/arm/mach-sunxi/board.c +++ b/arch/arm/mach-sunxi/board.c @@ -324,6 +324,8 @@ uint32_t sunxi_get_spl_size(void) * immediately follow the SPL if that is bigger than that. */ unsigned long spl_mmc_get_uboot_raw_sector(struct mmc *mmc, + unsigned long hw_part, + unsigned long raw_part, unsigned long raw_sect) { unsigned long spl_size = sunxi_get_spl_size(); diff --git a/common/spl/spl_mmc.c b/common/spl/spl_mmc.c index e4135b20487..8a0c7331267 100644 --- a/common/spl/spl_mmc.c +++ b/common/spl/spl_mmc.c @@ -370,6 +370,8 @@ int __weak spl_mmc_boot_partition(const u32 boot_device) #endif
unsigned long __weak spl_mmc_get_uboot_raw_sector(struct mmc *mmc, + unsigned long hw_part, + unsigned long raw_part, unsigned long raw_sect) { return raw_sect; @@ -418,7 +420,7 @@ int spl_mmc_load(struct spl_image_info *spl_image, static struct mmc *mmc; u32 boot_mode; int err = 0; - __maybe_unused int part = 0; + __maybe_unused int hw_part = 0; int mmc_dev;
/* Perform peripheral init only once for an mmc device */ @@ -442,12 +444,12 @@ int spl_mmc_load(struct spl_image_info *spl_image, err = -EINVAL; switch (boot_mode) { case MMCSD_MODE_EMMCBOOT: - part = spl_mmc_emmc_boot_partition(mmc); + hw_part = spl_mmc_emmc_boot_partition(mmc);
if (CONFIG_IS_ENABLED(MMC_TINY)) - err = mmc_switch_part(mmc, part); + err = mmc_switch_part(mmc, hw_part); else - err = blk_dselect_hwpart(mmc_get_blk_desc(mmc), part); + err = blk_dselect_hwpart(mmc_get_blk_desc(mmc), hw_part);
if (err) { #ifdef CONFIG_SPL_LIBCOMMON_SUPPORT @@ -465,7 +467,8 @@ int spl_mmc_load(struct spl_image_info *spl_image, return err; }
- raw_sect = spl_mmc_get_uboot_raw_sector(mmc, raw_sect); + raw_sect = spl_mmc_get_uboot_raw_sector(mmc, hw_part, + raw_part, raw_sect);
#ifdef CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION err = mmc_load_image_raw_partition(spl_image, bootdev, @@ -476,7 +479,7 @@ int spl_mmc_load(struct spl_image_info *spl_image, #endif #ifdef CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR err = mmc_load_image_raw_sector(spl_image, bootdev, mmc, - raw_sect + spl_mmc_raw_uboot_offset(part)); + raw_sect + spl_mmc_raw_uboot_offset(hw_part)); if (!err) return err; #endif
The eMMC HW partition 0 and 7 both mean USER HW partition. Use this as a mean of propagating A/B copy selection within USER HW partition. The spl_mmc_get_uboot_raw_sector() can detect that a USER HW partition is in use and based on whether it is 0 or 7, select appropriate sector to load from.
Signed-off-by: Fedor Ross fedor.ross@ifm.com Signed-off-by: Marek Vasut marex@denx.de --- Cc: Jaehoon Chung jh80.chung@samsung.com Cc: Peng Fan peng.fan@nxp.com --- V2: Initialize the part variable, else it is passed uninitialized to mmc_load_image_raw_sector(..raw_sect + spl_mmc_raw_uboot_offset(part)); and that prevents pine64 from booting. Interestingly enough, there is no warning emitted, which sounds like a compiler bug. --- common/spl/spl_mmc.c | 9 +++++---- 1 file changed, 5 insertions(+), 4 deletions(-)
diff --git a/common/spl/spl_mmc.c b/common/spl/spl_mmc.c index 8a0c7331267..7a3fd3590dd 100644 --- a/common/spl/spl_mmc.c +++ b/common/spl/spl_mmc.c @@ -420,7 +420,7 @@ int spl_mmc_load(struct spl_image_info *spl_image, static struct mmc *mmc; u32 boot_mode; int err = 0; - __maybe_unused int hw_part = 0; + __maybe_unused int part = 0, hw_part = 0; int mmc_dev;
/* Perform peripheral init only once for an mmc device */ @@ -445,11 +445,12 @@ int spl_mmc_load(struct spl_image_info *spl_image, switch (boot_mode) { case MMCSD_MODE_EMMCBOOT: hw_part = spl_mmc_emmc_boot_partition(mmc); + part = hw_part == 7 ? 0 : hw_part;
if (CONFIG_IS_ENABLED(MMC_TINY)) - err = mmc_switch_part(mmc, hw_part); + err = mmc_switch_part(mmc, part); else - err = blk_dselect_hwpart(mmc_get_blk_desc(mmc), hw_part); + err = blk_dselect_hwpart(mmc_get_blk_desc(mmc), part);
if (err) { #ifdef CONFIG_SPL_LIBCOMMON_SUPPORT @@ -479,7 +480,7 @@ int spl_mmc_load(struct spl_image_info *spl_image, #endif #ifdef CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR err = mmc_load_image_raw_sector(spl_image, bootdev, mmc, - raw_sect + spl_mmc_raw_uboot_offset(hw_part)); + raw_sect + spl_mmc_raw_uboot_offset(part)); if (!err) return err; #endif
