[U-Boot-Users] [PATCH] 85xx: Add setting of cache props in the device tree.
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- cpu/mpc85xx/fdt.c | 128 +++++++++++++++++++++++++++++++++++++++++++++++++++++ 1 files changed, 128 insertions(+), 0 deletions(-)
diff --git a/cpu/mpc85xx/fdt.c b/cpu/mpc85xx/fdt.c index bb87740..92952e6 100644 --- a/cpu/mpc85xx/fdt.c +++ b/cpu/mpc85xx/fdt.c @@ -26,6 +26,7 @@ #include <common.h> #include <libfdt.h> #include <fdt_support.h> +#include <asm/processor.h>
extern void ft_qe_setup(void *blob); #ifdef CONFIG_MP @@ -77,6 +78,131 @@ void ft_fixup_cpu(void *blob, u64 memory_limit) } #endif
+#ifdef CONFIG_L2_CACHE +/* return size in kilobytes */ +static inline u32 l2cache_size(void) +{ + volatile ccsr_l2cache_t *l2cache = (void *)CFG_MPC85xx_L2_ADDR; + volatile u32 l2siz_field = (l2cache->l2ctl >> 28) & 0x3; + u32 ver = SVR_SOC_VER(get_svr()); + + switch (l2siz_field) { + case 0x0: + break; + case 0x1: + if (ver == SVR_8540 || ver == SVR_8560 || + ver == SVR_8541 || ver == SVR_8541_E || + ver == SVR_8555 || ver == SVR_8555_E) + return 128; + else + return 256; + break; + case 0x2: + if (ver == SVR_8540 || ver == SVR_8560 || + ver == SVR_8541 || ver == SVR_8541_E || + ver == SVR_8555 || ver == SVR_8555_E) + return 256; + else + return 512; + break; + case 0x3: + return 1024; + break; + } + + return 0; +} + +static inline void ft_fixup_l2cache(void *blob) +{ + int len, off; + u32 *ph; + struct cpu_type *cpu = identify_cpu(SVR_SOC_VER(get_svr())); + char compat_buf[38]; + + const u32 line_size = 32; + const u32 num_ways = 8; + const u32 size = l2cache_size() * 1024; + const u32 num_sets = size / (line_size * num_ways); + + off = fdt_node_offset_by_prop_value(blob, -1, "device_type", "cpu", 4); + if (off < 0) { + debug("no cpu node fount\n"); + return; + } + + ph = (u32 *)fdt_getprop(blob, off, "next-level-cache", 0); + + if (ph == NULL) { + debug("no next-level-cache property\n"); + return ; + } + + off = fdt_node_offset_by_phandle(blob, *ph); + if (off < 0) { + printf("%s: %s\n", __func__, fdt_strerror(off)); + return ; + } + + if (cpu) { + len = sprintf(compat_buf, "fsl,mpc%s-l2-cache-controller", + cpu->name); + sprintf(&compat_buf[len + 1], "cache"); + } + fdt_setprop(blob, off, "cache-unified", NULL, 0); + fdt_setprop_cell(blob, off, "cache-block-size", line_size); + fdt_setprop_cell(blob, off, "cache-line-size", line_size); + fdt_setprop_cell(blob, off, "cache-size", size); + fdt_setprop_cell(blob, off, "cache-sets", num_sets); + fdt_setprop_cell(blob, off, "cache-level", 2); + fdt_setprop(blob, off, "compatible", compat_buf, sizeof(compat_buf)); +} +#else +#define ft_fixup_l2cache(x) +#endif + +static inline void ft_fixup_cache(void *blob) +{ + int off; + + off = fdt_node_offset_by_prop_value(blob, -1, "device_type", "cpu", 4); + + while (off != -FDT_ERR_NOTFOUND) { + u32 l1cfg0 = mfspr(SPRN_L1CFG0); + u32 l1cfg1 = mfspr(SPRN_L1CFG1); + u32 isize, iline_size, inum_sets, inum_ways; + u32 dsize, dline_size, dnum_sets, dnum_ways; + + /* d-side config */ + dsize = (l1cfg0 & 0x7ff) * 1024; + dnum_ways = ((l1cfg0 >> 11) & 0xff) + 1; + dline_size = (((l1cfg0 >> 23) & 0x3) + 1) * 32; + dnum_sets = dsize / (dline_size * dnum_ways); + + fdt_setprop_cell(blob, off, "d-cache-block-size", dline_size); + fdt_setprop_cell(blob, off, "d-cache-line-size", dline_size); + fdt_setprop_cell(blob, off, "d-cache-size", dsize); + fdt_setprop_cell(blob, off, "d-cache-sets", dnum_sets); + + /* i-side config */ + isize = (l1cfg1 & 0x7ff) * 1024; + inum_ways = ((l1cfg1 >> 11) & 0xff) + 1; + iline_size = (((l1cfg1 >> 23) & 0x3) + 1) * 32; + inum_sets = isize / (iline_size * inum_ways); + + fdt_setprop_cell(blob, off, "i-cache-block-size", iline_size); + fdt_setprop_cell(blob, off, "i-cache-line-size", iline_size); + fdt_setprop_cell(blob, off, "i-cache-size", isize); + fdt_setprop_cell(blob, off, "i-cache-sets", inum_sets); + + off = fdt_node_offset_by_prop_value(blob, off, + "device_type", "cpu", 4); + } + + ft_fixup_l2cache(blob); +} + + void ft_cpu_setup(void *blob, bd_t *bd) { #if defined(CONFIG_HAS_ETH0) || defined(CONFIG_HAS_ETH1) ||\ @@ -114,4 +240,6 @@ void ft_cpu_setup(void *blob, bd_t *bd) #ifdef CONFIG_MP ft_fixup_cpu(blob, (u64)bd->bi_memstart + (u64)bd->bi_memsize); #endif + + ft_fixup_cache(blob); }
On Thu, May 29, 2008 at 11:22 AM, Kumar Gala galak@kernel.crashing.org wrote:
case 0x0:
break;
case 0x1:
return 128;
else
return 256;
break;
case 0x2:
return 256;
else
return 512;
break;
case 0x3:
return 1024;
break;
How about we create a feature in the new cpu_type field you created, and use that to flag it. :)
Andy
On Jun 3, 2008, at 7:35 PM, Andy Fleming wrote:
On Thu, May 29, 2008 at 11:22 AM, Kumar Gala <galak@kernel.crashing.org
wrote: Signed-off-by: Kumar Gala galak@kernel.crashing.org
cpu/mpc85xx/fdt.c | 128 +++++++++++++++++++++++++++++++++++++++++++ ++++++++++ 1 files changed, 128 insertions(+), 0 deletions(-)
case 0x0:
break;
case 0x1:
return 128;
else
return 256;
break;
case 0x2:
return 256;
else
return 512;
break;
case 0x3:
return 1024;
break;
Seems overkill for such a small difference and one that is just for the "e500v1" generation of 85xx chips.
- k
Applied, thanks
Andy
Andy Fleming
Kumar Gala
