[PATCH] drivers: watchdog: Add DaVinci's watchdog support
Add support for the DaVinci's watchdog timer
Signed-off-by: Bastien Curutchet bastien.curutchet@bootlin.com --- drivers/watchdog/Kconfig | 7 ++ drivers/watchdog/Makefile | 1 + drivers/watchdog/davinci_wdt.c | 131 +++++++++++++++++++++++++++++++++ 3 files changed, 139 insertions(+) create mode 100644 drivers/watchdog/davinci_wdt.c
diff --git a/drivers/watchdog/Kconfig b/drivers/watchdog/Kconfig index 0c3e991331..a1c50b3f1f 100644 --- a/drivers/watchdog/Kconfig +++ b/drivers/watchdog/Kconfig @@ -169,6 +169,13 @@ config WDT_CORTINA This driver support all CPU ISAs supported by Cortina Access CAxxxx SoCs.
+config WDT_DAVINCI + bool "DaVinci watchdog timer support" + depends on WDT + help + Select this to enable the watchdog timer for DaVinci SoCs such as the + OMAP-L138. + config WDT_GPIO bool "External gpio watchdog support" depends on WDT diff --git a/drivers/watchdog/Makefile b/drivers/watchdog/Makefile index 7b39adcf0f..ad3053998a 100644 --- a/drivers/watchdog/Makefile +++ b/drivers/watchdog/Makefile @@ -29,6 +29,7 @@ obj-$(CONFIG_WDT_BOOKE) += booke_wdt.o obj-$(CONFIG_WDT_CORTINA) += cortina_wdt.o obj-$(CONFIG_WDT_ORION) += orion_wdt.o obj-$(CONFIG_WDT_CDNS) += cdns_wdt.o +obj-$(CONFIG_WDT_DAVINCI) += davinci_wdt.o obj-$(CONFIG_WDT_FTWDT010) += ftwdt010_wdt.o obj-$(CONFIG_WDT_GPIO) += gpio_wdt.o obj-$(CONFIG_WDT_MAX6370) += max6370_wdt.o diff --git a/drivers/watchdog/davinci_wdt.c b/drivers/watchdog/davinci_wdt.c new file mode 100644 index 0000000000..fa8d7842e9 --- /dev/null +++ b/drivers/watchdog/davinci_wdt.c @@ -0,0 +1,131 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * DaVinci Watchdog driver + * + */ + +#include <asm/io.h> +#include <clk.h> +#include <dm.h> +#include <wdt.h> + +/* Control Register */ +#define DAVINCI_WDT_ID 0x00 +#define DAVINCI_WDT_TIM12 0x10 +#define DAVINCI_WDT_TIM34 0x14 +#define DAVINCI_WDT_PRD12 0x18 +#define DAVINCI_WDT_PRD34 0x1C +#define DAVINCI_WDT_TCR 0x20 +#define DAVINCI_WDT_TGCR 0x24 +#define DAVINCI_WDT_WDTCR 0x28 + +#define DAVINCI_TCR_CONT_EN BIT(7) + +#define DAVINCI_TGCR_PLUSEN BIT(4) +#define DAVINCI_TGCR_WDT_MODE BIT(3) +#define DAVINCI_TGCR_TIM34RS BIT(1) +#define DAVINCI_TGCR_TIM12RS BIT(0) + +#define DAVINCI_WDTCR_INVALID_KEY (0x5555 << 16) +#define DAVINCI_WDTCR_WDKEY0 (0xA5C6 << 16) +#define DAVINCI_WDTCR_WDKEY1 (0xDA7E << 16) +#define DAVINCI_WDTCR_WDFLAG BIT(15) +#define DAVINCI_WDTCR_WDEN BIT(14) + +#define DEFAULT_THRESHOLD 0xA03200000 + +struct davinci_wdt_priv { + void __iomem *base; + struct clk *ref_clk; +}; + +static int davinci_wdt_start(struct udevice *dev, u64 timeout_ms, ulong flags) +{ + struct davinci_wdt_priv *priv = dev_get_priv(dev); + ulong rate = clk_get_rate(priv->ref_clk); + u64 threshold; + + if (!rate) + threshold = DEFAULT_THRESHOLD; + else + threshold = rate * timeout_ms / 1000; + + /* Reset control registers */ + writel(0, priv->base + DAVINCI_WDT_TCR); + writel(0, priv->base + DAVINCI_WDT_TGCR); + + /* Enable watchdog mode and timers */ + writel(DAVINCI_TGCR_WDT_MODE | DAVINCI_TGCR_TIM12RS | DAVINCI_TGCR_TIM34RS, + priv->base + DAVINCI_WDT_TGCR); + + /* Reset counters */ + writel(0, priv->base + DAVINCI_WDT_TIM12); + writel(0, priv->base + DAVINCI_WDT_TIM34); + + /* Set timeout threshold */ + writel(threshold & 0xFFFFFFFF, priv->base + DAVINCI_WDT_PRD12); + writel(threshold >> 32, priv->base + DAVINCI_WDT_PRD34); + + /* Enable counter */ + writel(DAVINCI_TCR_CONT_EN, priv->base + DAVINCI_WDT_TCR); + + /* Go to watchdog's active state */ + writel(DAVINCI_WDTCR_WDEN | DAVINCI_WDTCR_WDKEY0, priv->base + DAVINCI_WDT_WDTCR); + writel(DAVINCI_WDTCR_WDEN | DAVINCI_WDTCR_WDKEY1, priv->base + DAVINCI_WDT_WDTCR); + + return 0; +} + +static int davinci_wdt_expire_now(struct udevice *dev, ulong flags) +{ + struct davinci_wdt_priv *priv = dev_get_priv(dev); + + writel(DAVINCI_WDTCR_INVALID_KEY, priv->base + DAVINCI_WDT_WDTCR); + + return 0; +} + +static int davinci_wdt_restart(struct udevice *dev) +{ + struct davinci_wdt_priv *priv = dev_get_priv(dev); + + writel(DAVINCI_WDTCR_WDEN | DAVINCI_WDTCR_WDKEY0, priv->base + DAVINCI_WDT_WDTCR); + writel(DAVINCI_WDTCR_WDEN | DAVINCI_WDTCR_WDKEY1, priv->base + DAVINCI_WDT_WDTCR); + + return 0; +} + +static int davinci_wdt_probe(struct udevice *dev) +{ + struct davinci_wdt_priv *priv = dev_get_priv(dev); + + priv->base = dev_remap_addr_index(dev, 0); + if (!priv->base) + return -EFAULT; + + priv->ref_clk = devm_clk_get(dev, "ref"); + if (IS_ERR(priv->ref_clk)) + return PTR_ERR(priv->ref_clk); + + return 0; +} + +static const struct wdt_ops davinci_wdt_ops = { + .start = davinci_wdt_start, + .reset = davinci_wdt_restart, + .expire_now = davinci_wdt_expire_now, +}; + +static const struct udevice_id davinci_wdt_ids[] = { + {.compatible = "ti,davinci-wdt"}, + {} +}; + +U_BOOT_DRIVER(davinci_wdt) = { + .name = "davinci_wdt", + .id = UCLASS_WDT, + .probe = davinci_wdt_probe, + .of_match = davinci_wdt_ids, + .ops = &davinci_wdt_ops, + .priv_auto = sizeof(struct davinci_wdt_priv), +};
Thanks, Stefan
+config WDT_DAVINCI
- bool "DaVinci watchdog timer support"
- depends on WDT
- help
OMAP-L138.
- config WDT_GPIO bool "External gpio watchdog support" depends on WDT
- DaVinci Watchdog driver
- void __iomem *base;
- struct clk *ref_clk;
- struct davinci_wdt_priv *priv = dev_get_priv(dev);
- ulong rate = clk_get_rate(priv->ref_clk);
- u64 threshold;
- if (!rate)
- else
- /* Reset control registers */
- writel(0, priv->base + DAVINCI_WDT_TCR);
- writel(0, priv->base + DAVINCI_WDT_TGCR);
- /* Enable watchdog mode and timers */
- writel(DAVINCI_TGCR_WDT_MODE | DAVINCI_TGCR_TIM12RS | DAVINCI_TGCR_TIM34RS,
- /* Reset counters */
- writel(0, priv->base + DAVINCI_WDT_TIM12);
- writel(0, priv->base + DAVINCI_WDT_TIM34);
- /* Set timeout threshold */
- writel(threshold & 0xFFFFFFFF, priv->base + DAVINCI_WDT_PRD12);
- writel(threshold >> 32, priv->base + DAVINCI_WDT_PRD34);
- /* Enable counter */
- writel(DAVINCI_TCR_CONT_EN, priv->base + DAVINCI_WDT_TCR);
- /* Go to watchdog's active state */
- writel(DAVINCI_WDTCR_WDEN | DAVINCI_WDTCR_WDKEY0, priv->base + DAVINCI_WDT_WDTCR);
- writel(DAVINCI_WDTCR_WDEN | DAVINCI_WDTCR_WDKEY1, priv->base + DAVINCI_WDT_WDTCR);
- writel(DAVINCI_WDTCR_INVALID_KEY, priv->base + DAVINCI_WDT_WDTCR);
- priv->base = dev_remap_addr_index(dev, 0);
- if (!priv->base)
return -EFAULT;
- priv->ref_clk = devm_clk_get(dev, "ref");
- if (IS_ERR(priv->ref_clk))
- .start = davinci_wdt_start,
- .reset = davinci_wdt_restart,
- .expire_now = davinci_wdt_expire_now,
- {.compatible = "ti,davinci-wdt"},
- .name = "davinci_wdt",
- .id = UCLASS_WDT,
- .probe = davinci_wdt_probe,
- .of_match = davinci_wdt_ids,
- .ops = &davinci_wdt_ops,
- .priv_auto = sizeof(struct davinci_wdt_priv),
Viele Grüße, Stefan Roese
Applied to u-boot-watchdog/master
Thanks, Stefan
+config WDT_DAVINCI
- depends on WDT
- help
OMAP-L138.
- u64 threshold;
- if (!rate)
- else
- if (!priv->base)
return -EFAULT;
- .id = UCLASS_WDT,
Bastien Curutchet
Stefan Roese
