[PATCH] include: configs: socfpga: Add environment variables for distro boot
Added environment variables needed to support distro boot.
Signed-off-by: Yau Wai Gan yau.wai.gan@intel.com Signed-off-by: Jit Loon Lim jit.loon.lim@intel.com --- include/configs/socfpga_soc64_common.h | 81 +++++++++++++++++++++++++- 1 file changed, 80 insertions(+), 1 deletion(-)
diff --git a/include/configs/socfpga_soc64_common.h b/include/configs/socfpga_soc64_common.h index 5b1d243153..f7f3bc1f13 100644 --- a/include/configs/socfpga_soc64_common.h +++ b/include/configs/socfpga_soc64_common.h @@ -54,6 +54,84 @@ #define CONFIG_BOOTFILE "Image" #endif
+#if IS_ENABLED(CONFIG_DISTRO_DEFAULTS) +#if IS_ENABLED(CONFIG_CMD_MMC) +#define BOOT_TARGET_DEVICES_MMC(func) func(MMC, mmc, 0) +#else +#define BOOT_TARGET_DEVICES_MMC(func) +#endif + +#if IS_ENABLED(CONFIG_CMD_SF) +#define BOOT_TARGET_DEVICES_QSPI(func) func(QSPI, qspi, na) +#else +#define BOOT_TARGET_DEVICES_QSPI(func) +#endif + +#define BOOTENV_DEV_QSPI(devtypeu, devtypel, instance) \ + "bootcmd_qspi=sf probe && " \ + "sf read ${scriptaddr} ${qspiscriptaddr} ${scriptsize} && " \ + "echo QSPI: Trying to boot script at ${scriptaddr} && " \ + "source ${scriptaddr}; " \ + "echo QSPI: SCRIPT FAILED: continuing...;\0" + +#define BOOTENV_DEV_NAME_QSPI(devtypeu, devtypel, instance) \ + "qspi " + +#if IS_ENABLED(CONFIG_CMD_NAND) +# define BOOT_TARGET_DEVICES_NAND(func) func(NAND, nand, na) +#else +# define BOOT_TARGET_DEVICES_NAND(func) +#endif + +#define BOOTENV_DEV_NAND(devtypeu, devtypel, instance) \ + "bootcmd_nand=ubi part root && " \ + "ubi readvol ${scriptaddr} script && " \ + "echo NAND: Trying to boot script at ${scriptaddr} && " \ + "source ${scriptaddr}; " \ + "echo NAND: SCRIPT FAILED: continuing...;\0" + +#define BOOTENV_DEV_NAME_NAND(devtypeu, devtypel, instance) \ + "nand " + +#define BOOT_TARGET_DEVICES(func) \ + BOOT_TARGET_DEVICES_MMC(func) \ + BOOT_TARGET_DEVICES_QSPI(func) \ + BOOT_TARGET_DEVICES_NAND(func) + +#include <config_distro_bootcmd.h> +#define CONFIG_EXTRA_ENV_SETTINGS \ + "kernel_addr_r=0x2000000\0" \ + "fdt_addr_r=0x6000000\0" \ + "qspiscriptaddr=0x02110000\0" \ + "scriptsize=0x00010000\0" \ + "qspibootimageaddr=0x02120000\0" \ + "bootimagesize=0x03200000\0" \ + "loadaddr=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \ + "bootfile=" CONFIG_BOOTFILE "\0" \ + "mmcroot=/dev/mmcblk0p2\0" \ + "mtdids=" CONFIG_MTDIDS_DEFAULT "\0" \ + "mtdparts=" CONFIG_MTDPARTS_DEFAULT "\0" \ + "linux_qspi_enable=if sf probe; then " \ + "echo Enabling QSPI at Linux DTB...;" \ + "fdt addr ${fdt_addr}; fdt resize;" \ + "fdt set /soc/spi@ff8d2000 status okay;" \ + "if fdt set /soc/clocks/qspi-clk clock-frequency" \ + " ${qspi_clock}; then" \ + " else fdt set /soc/clkmgr/clocks/qspi_clk clock-frequency" \ + " ${qspi_clock}; fi; fi\0" \ + "scriptaddr=0x05FF0000\0" \ + "scriptfile=boot.scr\0" \ + "nandroot=ubi0:rootfs\0" \ + "socfpga_legacy_reset_compat=1\0" \ + "rsu_status=rsu dtb; rsu display_dcmf_version; "\ + "rsu display_dcmf_status; rsu display_max_retry\0" \ + "smc_fid_rd=0xC2000007\0" \ + "smc_fid_wr=0xC2000008\0" \ + "smc_fid_upd=0xC2000009\0 " \ + BOOTENV + +#else + #define CONFIG_EXTRA_ENV_SETTINGS \ "qspibootimageaddr=0x020E0000\0" \ "qspifdtaddr=0x020D0000\0" \ @@ -106,7 +184,8 @@ "rsu display_dcmf_status; rsu display_max_retry\0" \ "smc_fid_rd=0xC2000007\0" \ "smc_fid_wr=0xC2000008\0" \ - "smc_fid_upd=0xC2000009\0 " \ + "smc_fid_upd=0xC2000009\0 " +#endif /*#if IS_ENABLED(CONFIG_DISTRO_DEFAULTS)*/
/* * External memory configurations
Jit Loon Lim
