[RFC PATCH v2] sunxi: Add UART4 console support for A64
UART4 port of A64 was in conflict with R_UART of older SoCs, like A23.
This commit adds necessary definitions to use UART4 port on A64.
Signed-off-by: Nazım Gediz Aydındoğmuş gediz.aydindogmus@genemek.com Tested-by: Faruk Kılavuz faruk.kilavuz@genemek.com ---
Changes in v2: - Removed redundant OF_STDOUT_PATH changes - Simplified commit log to meet 80 characters
arch/arm/include/asm/arch-sunxi/gpio.h | 1 + arch/arm/mach-sunxi/board.c | 4 ++++ arch/arm/mach-sunxi/clock_sun6i.c | 3 ++- include/configs/sunxi-common.h | 4 ++++ 4 files changed, 11 insertions(+), 1 deletion(-)
diff --git a/arch/arm/include/asm/arch-sunxi/gpio.h b/arch/arm/include/asm/arch-sunxi/gpio.h index a646ea6a3c..1407aff25f 100644 --- a/arch/arm/include/asm/arch-sunxi/gpio.h +++ b/arch/arm/include/asm/arch-sunxi/gpio.h @@ -176,6 +176,7 @@ enum sunxi_gpio_number { #define SUNXI_GPD_LCD0 2 #define SUNXI_GPD_LVDS0 3 #define SUNXI_GPD_PWM 2 +#define SUN50I_GPD_UART4 3
#define SUN5I_GPE_SDC2 3 #define SUN8I_GPE_TWI2 3 diff --git a/arch/arm/mach-sunxi/board.c b/arch/arm/mach-sunxi/board.c index f40fccd8f8..7d95b7dd29 100644 --- a/arch/arm/mach-sunxi/board.c +++ b/arch/arm/mach-sunxi/board.c @@ -140,6 +140,10 @@ static int gpio_init(void) sunxi_gpio_set_cfgpin(SUNXI_GPL(2), SUN8I_GPL_R_UART); sunxi_gpio_set_cfgpin(SUNXI_GPL(3), SUN8I_GPL_R_UART); sunxi_gpio_set_pull(SUNXI_GPL(3), SUNXI_GPIO_PULL_UP); +#elif CONFIG_CONS_INDEX == 5 && defined(CONFIG_MACH_SUN50I) + sunxi_gpio_set_cfgpin(SUNXI_GPD(2), SUN50I_GPD_UART4); + sunxi_gpio_set_cfgpin(SUNXI_GPD(3), SUN50I_GPD_UART4); + sunxi_gpio_set_pull(SUNXI_GPD(3), SUNXI_GPIO_PULL_UP); #else #error Unsupported console port number. Please fix pin mux settings in board.c #endif diff --git a/arch/arm/mach-sunxi/clock_sun6i.c b/arch/arm/mach-sunxi/clock_sun6i.c index 8e84062bd7..95f8e807f3 100644 --- a/arch/arm/mach-sunxi/clock_sun6i.c +++ b/arch/arm/mach-sunxi/clock_sun6i.c @@ -83,7 +83,8 @@ void clock_init_sec(void)
void clock_init_uart(void) { -#if CONFIG_CONS_INDEX < 5 +#if CONFIG_CONS_INDEX < 5 || \ + defined(CONFIG_MACH_SUN50I) && CONFIG_CONS_INDEX < 6 struct sunxi_ccm_reg *const ccm = (struct sunxi_ccm_reg *)SUNXI_CCM_BASE;
diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index 5b0bec0561..1324d60f60 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -45,8 +45,12 @@ # define CONFIG_SYS_NS16550_COM2 SUNXI_UART1_BASE # define CONFIG_SYS_NS16550_COM3 SUNXI_UART2_BASE # define CONFIG_SYS_NS16550_COM4 SUNXI_UART3_BASE +#if defined(CONFIG_MACH_SUN50I) +# define CONFIG_SYS_NS16550_COM5 SUNXI_UART4_BASE +#else # define CONFIG_SYS_NS16550_COM5 SUNXI_R_UART_BASE #endif +#endif
/* CPU */ #define COUNTER_FREQUENCY 24000000
On Wed, Jul 8, 2020 at 5:41 PM Nazım Gediz Aydındoğmuş gediz.aydindogmus@genemek.com wrote:
I think this cannot be RFC, otherwise
Acked-by: Jagan Teki jagan@amarulasolutions.com
Hello,
I thought it may be suitable to word the subject as RFC because Maxime Ripard pointed out some incomplete parts about the preceding version of the patch (I'm grateful for that) and it made me think that there may be more of it. Is this patch eligible now to send as a non-RFC patch?
Thanks for the review.
Changes in v2:
AFAIK they are needed, but the path was wrong in your original version.
Maxime
Changes in v2:
Maxime
I will inspect it again in order to find a proper patch for a "soc" node on the DTS. Thanks.
Jagan Teki
Maxime Ripard
Nazım Gediz AYDINDOĞMUŞ
