[U-Boot] u-boot 2016.01-rc2 detects BeagleBone Black incorrectly
Hello,
I am running 2016.01-rc on BBB (Embest replica)
printenv shows the following:
findfdt=if test $board_name = A335BONE; then setenv fdtfile am335x-bone.dtb; fi; if test $board_name = A335BNLT; then if test $board_rev = BBG1; then setenv fdtfile am335x-bonegreen.dtb; else setenv fdtfile am335x-boneblack.dtb; fi; fi; if test $board_name = A33515BB; then setenv fdtfile am335x-evm.dtb; fi; if test $board_name = A335X_SK; then setenv fdtfile am335x-evmsk.dtb; fi; if test $fdtfile = undefined; then echo WARNING: Could not determine device tree to use; fi;
after findfdt has been run,
fdtfile=am335x-bonegreen.dtb
But it is not correct. My $board_rev is the following, I have no idea why does it contain line break.
board_name=A335BNLT board_rev=t\ ue
Hi Matwey
On Sat, Dec 12, 2015 at 3:14 AM, Matwey V. Kornilov matwey.kornilov@gmail.com wrote:
Hello,
Yuck, another variation! Can you do me a favor and dump the eeprom:
https://github.com/beagleboard/image-builder/blob/master/readme.md
Download and run:
wget https://raw.githubusercontent.com/RobertCNelson/boot-scripts/master/device/b...
sudo /bin/bash show-eeprom.sh
It uses hexdump and compatible with bb.org' 3.8/4.1/etc..
The green should only trigger on: 0x1a 0x00 0x00 0x00
http://git.denx.de/?p=u-boot.git;a=blobdiff;f=board/ti/am335x/board.c;h=f56d...
Regards,
2015-12-17 3:53 GMT+03:00 Robert Nelson robertcnelson@gmail.com:
Hi Matwey
Hello,
Download and run:
# sudo /bin/bash show-eeprom.sh eeprom: [�U3�A335BNLTt ue] eeprom raw: [00000000 aa 55 33 ee 41 33 33 35 42 4e 4c 54 74 0a 75 65 |.U3.A335BNLTt.ue|]
Regards,
-- Robert Nelson https://rcn-ee.com/
On Thu, Dec 17, 2015 at 11:54 AM, Matwey V. Kornilov matwey.kornilov@gmail.com wrote:
Hi Matwey
Hello,
Download and run:
ah, it's tripping on the "." = "0a" character..
Do you happen to remember where you purchased it and what it was called.. (for git commit)
This patch should work:
https://gist.github.com/RobertCNelson/21f44591c78daed7c637
Please test,
and i've added it to our table:
https://github.com/RobertCNelson/omap-image-builder/commit/620ebf627d3df8c69...
Regards,
2015-12-17 21:08 GMT+03:00 Robert Nelson robertcnelson@gmail.com:
Hi Matwey
Hello,
Download and run:
The patch works good. But could you please explain me? I thought the problem was in 'test' operator. Unlikely test '\0x74\0x0a\0x75\0x65' = BBG1 should be true.
Please test,
Regards,
I saw this when i first booted the Green with the production eeprom, "test" doesn't seem to like non printable characters..
Sorry i didn't look into "test" much further..
Instead i just worked around it with the Green..
Regards,
2015-12-20 1:29 GMT+03:00 Robert Nelson robertcnelson@gmail.com:
Seems, issue is in command parser, not in test itself.
Regards,
Yeah. You may be able to instead use 'cmp.w' and mw to try and keep all of this inside just the script side of things and outside of C. That also however may end up being even uglier.
Matwey V. Kornilov
Robert Nelson
