[U-Boot] [PATCH 2/5] ehci-hcd: Boost transfer speed
This patch takes advantage of the hardware EHCI qTD queuing mechanism to avoid software overhead and to make transfers as fast as possible.
The only drawback is a call to memalign. However, this is fast compared to the transfer timings, and the heap size to allocate is small, e.g. a little bit more than 100 kB for a transfer length of 65535 packets of 512 bytes.
Tested on i.MX25 and i.MX35. In my test conditions, the speedup was about 15x using page-aligned buffers, which is really appreciable when accessing large files.
Signed-off-by: Benoît Thébaudeau benoit.thebaudeau@advansee.com Cc: Marek Vasut marex@denx.de Cc: Ilya Yanok ilya.yanok@cogentembedded.com Cc: Stefan Herbrechtsmeier stefan@herbrechtsmeier.net --- .../drivers/usb/host/ehci-hcd.c | 94 ++++++++++++++------ 1 file changed, 65 insertions(+), 29 deletions(-)
diff --git u-boot-usb-1b4bd0e.orig/drivers/usb/host/ehci-hcd.c u-boot-usb-1b4bd0e/drivers/usb/host/ehci-hcd.c index 5b3b906..b5645fa 100644 --- u-boot-usb-1b4bd0e.orig/drivers/usb/host/ehci-hcd.c +++ u-boot-usb-1b4bd0e/drivers/usb/host/ehci-hcd.c @@ -208,7 +208,8 @@ ehci_submit_async(struct usb_device *dev, unsigned long pipe, void *buffer, int length, struct devrequest *req) { ALLOC_ALIGN_BUFFER(struct QH, qh, 1, USB_DMA_MINALIGN); - ALLOC_ALIGN_BUFFER(struct qTD, qtd, 3, USB_DMA_MINALIGN); + struct qTD *qtd; + int qtd_count = 0; int qtd_counter = 0;
volatile struct qTD *vtd; @@ -229,8 +230,25 @@ ehci_submit_async(struct usb_device *dev, unsigned long pipe, void *buffer, le16_to_cpu(req->value), le16_to_cpu(req->value), le16_to_cpu(req->index));
+ if (req != NULL) /* SETUP + ACK */ + qtd_count += 1 + 1; + if (length > 0 || req == NULL) { /* buffer */ + if ((uint32_t)buffer & 4095) /* page-unaligned */ + qtd_count += (((uint32_t)buffer & 4095) + length + + (QT_BUFFER_CNT - 1) * 4096 - 1) / + ((QT_BUFFER_CNT - 1) * 4096); + else /* page-aligned */ + qtd_count += (length + QT_BUFFER_CNT * 4096 - 1) / + (QT_BUFFER_CNT * 4096); + } + qtd = memalign(USB_DMA_MINALIGN, qtd_count * sizeof(struct qTD)); + if (qtd == NULL) { + printf("unable to allocate TDs\n"); + return -1; + } + memset(qh, 0, sizeof(struct QH)); - memset(qtd, 0, 3 * sizeof(*qtd)); + memset(qtd, 0, qtd_count * sizeof(*qtd));
toggle = usb_gettoggle(dev, usb_pipeendpoint(pipe), usb_pipeout(pipe));
@@ -291,31 +309,46 @@ ehci_submit_async(struct usb_device *dev, unsigned long pipe, void *buffer, }
if (length > 0 || req == NULL) { - /* - * Setup request qTD (3.5 in ehci-r10.pdf) - * - * qt_next ................ 03-00 H - * qt_altnext ............. 07-04 H - * qt_token ............... 0B-08 H - * - * [ buffer, buffer_hi ] loaded with "buffer". - */ - qtd[qtd_counter].qt_next = cpu_to_hc32(QT_NEXT_TERMINATE); - qtd[qtd_counter].qt_altnext = cpu_to_hc32(QT_NEXT_TERMINATE); - token = (toggle << 31) | - (length << 16) | - ((req == NULL ? 1 : 0) << 15) | - (0 << 12) | - (3 << 10) | - ((usb_pipein(pipe) ? 1 : 0) << 8) | (0x80 << 0); - qtd[qtd_counter].qt_token = cpu_to_hc32(token); - if (ehci_td_buffer(&qtd[qtd_counter], buffer, length) != 0) { - printf("unable construct DATA td\n"); - goto fail; - } - /* Update previous qTD! */ - *tdp = cpu_to_hc32((uint32_t)&qtd[qtd_counter]); - tdp = &qtd[qtd_counter++].qt_next; + uint8_t *buf_ptr = buffer; + int left_length = length; + + do { + int xfr_bytes = min(left_length, + (QT_BUFFER_CNT * 4096 - + ((uint32_t)buf_ptr & 4095)) & + ~4095); + + /* + * Setup request qTD (3.5 in ehci-r10.pdf) + * + * qt_next ................ 03-00 H + * qt_altnext ............. 07-04 H + * qt_token ............... 0B-08 H + * + * [ buffer, buffer_hi ] loaded with "buffer". + */ + qtd[qtd_counter].qt_next = + cpu_to_hc32(QT_NEXT_TERMINATE); + qtd[qtd_counter].qt_altnext = + cpu_to_hc32(QT_NEXT_TERMINATE); + token = (toggle << 31) | + (xfr_bytes << 16) | + ((req == NULL ? 1 : 0) << 15) | + (0 << 12) | + (3 << 10) | + ((usb_pipein(pipe) ? 1 : 0) << 8) | (0x80 << 0); + qtd[qtd_counter].qt_token = cpu_to_hc32(token); + if (ehci_td_buffer(&qtd[qtd_counter], buf_ptr, + xfr_bytes) != 0) { + printf("unable construct DATA td\n"); + goto fail; + } + /* Update previous qTD! */ + *tdp = cpu_to_hc32((uint32_t)&qtd[qtd_counter]); + tdp = &qtd[qtd_counter++].qt_next; + buf_ptr += xfr_bytes; + left_length -= xfr_bytes; + } while (left_length > 0); }
if (req != NULL) { @@ -346,7 +379,8 @@ ehci_submit_async(struct usb_device *dev, unsigned long pipe, void *buffer, flush_dcache_range((uint32_t)qh_list, ALIGN_END_ADDR(struct QH, qh_list, 1)); flush_dcache_range((uint32_t)qh, ALIGN_END_ADDR(struct QH, qh, 1)); - flush_dcache_range((uint32_t)qtd, ALIGN_END_ADDR(struct qTD, qtd, 3)); + flush_dcache_range((uint32_t)qtd, + ALIGN_END_ADDR(struct qTD, qtd, qtd_count));
/* Set async. queue head pointer. */ ehci_writel(&hcor->or_asynclistaddr, (uint32_t)qh_list); @@ -377,7 +411,7 @@ ehci_submit_async(struct usb_device *dev, unsigned long pipe, void *buffer, invalidate_dcache_range((uint32_t)qh, ALIGN_END_ADDR(struct QH, qh, 1)); invalidate_dcache_range((uint32_t)qtd, - ALIGN_END_ADDR(struct qTD, qtd, 3)); + ALIGN_END_ADDR(struct qTD, qtd, qtd_count));
token = hc32_to_cpu(vtd->qt_token); if (!(token & 0x80)) @@ -450,9 +484,11 @@ ehci_submit_async(struct usb_device *dev, unsigned long pipe, void *buffer, ehci_readl(&hcor->or_portsc[1])); }
+ free(qtd); return (dev->status != USB_ST_NOT_PROC) ? 0 : -1;
fail: + free(qtd); return -1; }
Signed-off-by: Benoît Thébaudeau benoit.thebaudeau@advansee.com Cc: Marek Vasut marex@denx.de Cc: Ilya Yanok ilya.yanok@cogentembedded.com Cc: Stefan Herbrechtsmeier stefan@herbrechtsmeier.net --- Changes for v2: - Use DIV_ROUND_UP to make code more readable.
.../drivers/usb/host/ehci-hcd.c | 92 ++++++++++++++------ 1 file changed, 63 insertions(+), 29 deletions(-)
diff --git u-boot-usb-1b4bd0e.orig/drivers/usb/host/ehci-hcd.c u-boot-usb-1b4bd0e/drivers/usb/host/ehci-hcd.c index 5b3b906..cf9ab92 100644 --- u-boot-usb-1b4bd0e.orig/drivers/usb/host/ehci-hcd.c +++ u-boot-usb-1b4bd0e/drivers/usb/host/ehci-hcd.c @@ -208,7 +208,8 @@ ehci_submit_async(struct usb_device *dev, unsigned long pipe, void *buffer, int length, struct devrequest *req) { ALLOC_ALIGN_BUFFER(struct QH, qh, 1, USB_DMA_MINALIGN); - ALLOC_ALIGN_BUFFER(struct qTD, qtd, 3, USB_DMA_MINALIGN); + struct qTD *qtd; + int qtd_count = 0; int qtd_counter = 0;
volatile struct qTD *vtd; @@ -229,8 +230,23 @@ ehci_submit_async(struct usb_device *dev, unsigned long pipe, void *buffer, le16_to_cpu(req->value), le16_to_cpu(req->value), le16_to_cpu(req->index));
+ if (req != NULL) /* SETUP + ACK */ + qtd_count += 1 + 1; + if (length > 0 || req == NULL) { /* buffer */ + if ((uint32_t)buffer & 4095) /* page-unaligned */ + qtd_count += DIV_ROUND_UP(((uint32_t)buffer & 4095) + + length, (QT_BUFFER_CNT - 1) * 4096); + else /* page-aligned */ + qtd_count += DIV_ROUND_UP(length, QT_BUFFER_CNT * 4096); + } + qtd = memalign(USB_DMA_MINALIGN, qtd_count * sizeof(struct qTD)); + if (qtd == NULL) { + printf("unable to allocate TDs\n"); + return -1; + } + memset(qh, 0, sizeof(struct QH)); - memset(qtd, 0, 3 * sizeof(*qtd)); + memset(qtd, 0, qtd_count * sizeof(*qtd));
@@ -291,31 +307,46 @@ ehci_submit_async(struct usb_device *dev, unsigned long pipe, void *buffer, }
if (req != NULL) { @@ -346,7 +377,8 @@ ehci_submit_async(struct usb_device *dev, unsigned long pipe, void *buffer, flush_dcache_range((uint32_t)qh_list, ALIGN_END_ADDR(struct QH, qh_list, 1)); flush_dcache_range((uint32_t)qh, ALIGN_END_ADDR(struct QH, qh, 1)); - flush_dcache_range((uint32_t)qtd, ALIGN_END_ADDR(struct qTD, qtd, 3)); + flush_dcache_range((uint32_t)qtd, + ALIGN_END_ADDR(struct qTD, qtd, qtd_count));
/* Set async. queue head pointer. */ ehci_writel(&hcor->or_asynclistaddr, (uint32_t)qh_list); @@ -377,7 +409,7 @@ ehci_submit_async(struct usb_device *dev, unsigned long pipe, void *buffer, invalidate_dcache_range((uint32_t)qh, ALIGN_END_ADDR(struct QH, qh, 1)); invalidate_dcache_range((uint32_t)qtd, - ALIGN_END_ADDR(struct qTD, qtd, 3)); + ALIGN_END_ADDR(struct qTD, qtd, qtd_count));
token = hc32_to_cpu(vtd->qt_token); if (!(token & 0x80)) @@ -450,9 +482,11 @@ ehci_submit_async(struct usb_device *dev, unsigned long pipe, void *buffer, ehci_readl(&hcor->or_portsc[1])); }
Am 20.07.2012 13:26, schrieb Benoît Thébaudeau:
Changes for v2:
struct qTD *qtd;
- if (req != NULL) /* SETUP + ACK */
qtd_count += 1 + 1;
- if (length > 0 || req == NULL) { /* buffer */
- qtd = memalign(USB_DMA_MINALIGN, qtd_count * sizeof(struct qTD));
- if (qtd == NULL) {
return -1;
- memset(qh, 0, sizeof(struct QH));
(length << 16) |
(0 << 12) |
(3 << 10) |
goto fail;
do {
~4095);
Why you align the length to 4096?
(xfr_bytes << 16) |
(0 << 12) |
(3 << 10) |
xfr_bytes) != 0) {
goto fail;
if (req != NULL) {
fail:
~4095);
It's to guarantee that each transfer length is a multiple of the max packet length. Otherwise, early short packets are issued, which breaks the transfer and results in time-out error messages.
Regards, Benoît
Dear Benoît Thébaudeau,
~4095);
Early short packets ? What do you mean?
Regards, Benoît
Best regards, Marek Vasut
Dear Marek Vasut,
~4095);
During a USB transfer, all packets must have a length of max packet length for the pipe/endpoint, except the final one that can be a short packet. Without the alignment I make for xfr_bytes, short packets can occur within a transfer, because the hardware starts a new packet for each new queued qTD it handles.
Best regards, Benoît
Am 20.07.2012 15:56, schrieb Benoît Thébaudeau:
Dear Marek Vasut,
~4095);
But if I am right, the max packet length is 512 for bulk and 1024 for Interrupt transfer.
Regards, Stefan
Dear Marek Vasut,
~4095);
There are indeed different max packet lengths for different transfer types, but it does not matter since the chosen alignment guarantees a multiple of all these possible max packet lengths.
Am 20.07.2012 17:03, schrieb Benoît Thébaudeau:
Dear Marek Vasut,
Am 20.07.2012 13:26, schrieb Benoît Thébaudeau: > + int xfr_bytes = min(left_length, > + (QT_BUFFER_CNT * 4096 - > + ((uint32_t)buf_ptr & 4095)) & > + ~4095); Why you align the length to 4096?
But thereby you limit the transfer to 4 qT buffers for unaligned transfers.
Best regards, Stefan
Dear Marek Vasut,
On Friday 20 July 2012 13:37:37 Stefan Herbrechtsmeier wrote: > Am 20.07.2012 13:26, schrieb Benoît Thébaudeau: >> + int xfr_bytes = min(left_length, >> + (QT_BUFFER_CNT * 4096 - >> + ((uint32_t)buf_ptr & 4095)) & >> + ~4095); > Why you align the length to 4096? It's to guarantee that each transfer length is a multiple of the max packet length. Otherwise, early short packets are issued, which breaks the transfer and results in time-out error messages.
Not exactly. The 5 qt_buffers are used for page-unaligned buffers, but that results in only 4 full pages of unaligned data, requiring 5 aligned pages.
For page-aligned buffers, the 5 qt_buffers result in 5 full pages of aligned data.
The unaligned case could be a little bit improved to always use as many packets as possible per qTD, but that would over-complicate things for a very negligible speed and memory gain.
Am 20.07.2012 17:35, schrieb Benoît Thébaudeau:
Dear Marek Vasut,
> On Friday 20 July 2012 13:37:37 Stefan Herbrechtsmeier wrote: >> Am 20.07.2012 13:26, schrieb Benoît Thébaudeau: >>> + int xfr_bytes = min(left_length, >>> + (QT_BUFFER_CNT * 4096 - >>> + ((uint32_t)buf_ptr & 4095)) & >>> + ~4095); >> Why you align the length to 4096? > It's to guarantee that each transfer length is a multiple of > the > max packet > length. Otherwise, early short packets are issued, which breaks > the > transfer and results in time-out error messages. Early short packets ? What do you mean?
Sorry I mean 4 full pages of unaligned data.
Sure.
In my use case (fragmented file on usb storage) the gain would be nearly 20%. The reason is that the data are block aligned (512) and could be aligned to 4096 with the first transfer (5 qt_buffers).
My suggestion would be to truncate the xfr_bytes with the max wMaxPacketSize (1024) and for the qtd_count use:
if ((uint32_t)buffer & 1023) /* wMaxPacketSize unaligned */ qtd_count += DIV_ROUND_UP(((uint32_t)buffer & 4095) + length, (QT_BUFFER_CNT - 1) * 4096); else /* wMaxPacketSize aligned */ qtd_count += DIV_ROUND_UP(((uint32_t)buffer & 4095) + length, QT_BUFFER_CNT * 4096);
This allows 50% of unaligned block data (512) to be transferred with min qTDs.
Dear Marek Vasut,
On Friday 20 July 2012 15:44:01 Marek Vasut wrote: >> On Friday 20 July 2012 13:37:37 Stefan Herbrechtsmeier wrote: >>> Am 20.07.2012 13:26, schrieb Benoît Thébaudeau: >>>> + int xfr_bytes = min(left_length, >>>> + (QT_BUFFER_CNT * 4096 - >>>> + ((uint32_t)buf_ptr & 4095)) & >>>> + ~4095); >>> Why you align the length to 4096? >> It's to guarantee that each transfer length is a multiple of >> the >> max packet >> length. Otherwise, early short packets are issued, which >> breaks >> the >> transfer and results in time-out error messages. > Early short packets ? What do you mean? During a USB transfer, all packets must have a length of max packet length for the pipe/endpoint, except the final one that can be a short packet. Without the alignment I make for xfr_bytes, short packets can occur within a transfer, because the hardware starts a new packet for each new queued qTD it handles.
Sure.
Can you explain where this gain would come from? In both cases, the data in USB transfers would be organized in the same way, and it would be accessed in memory also in the same way (regarding bursts). The only difference would be the fetch time of a little bit more qTDs, which is extremely fast and insignificant compared to the transfer time of the payload, which remains unchanged.
Moreover, in your use case, if you are e.g. using FAT, on the one hand, the buffers in fat.c are never aligned to more than the DMA min alignment, and on the other hand, if you can align your user buffers to 512 bytes, you can also align them directly to 4 kB.
That would also require a realignment-to-page stage. This is specific code for specific buffer alignment from the upper layers. We could also skip the realignment to page and always keep the same qTD transfer size except for the last one, by adding as many packets as possible for the buffer alignment.
But I still don't see a significant reason to complicate code to do that.
BTW, the 15x speed gain that I gave in my patch description was compared to an older version of the original code that used 20 blocks per transfer in usb_storage.c. This is now 40 blocks per transfer with a page-aligned buffer, so the speed gain compared to the current code should be rather about 7x. I should update that.
Am 23.07.2012 19:15, schrieb Benoît Thébaudeau:
Am 20.07.2012 15:56, schrieb Benoît Thébaudeau: > Dear Marek Vasut, > > On Friday 20 July 2012 15:44:01 Marek Vasut wrote: >>> On Friday 20 July 2012 13:37:37 Stefan Herbrechtsmeier wrote: >>>> Am 20.07.2012 13:26, schrieb Benoît Thébaudeau: >>>>> + int xfr_bytes = min(left_length, >>>>> + (QT_BUFFER_CNT * 4096 - >>>>> + ((uint32_t)buf_ptr & 4095)) & >>>>> + ~4095); >>>> Why you align the length to 4096? >>> It's to guarantee that each transfer length is a multiple of >>> the >>> max packet >>> length. Otherwise, early short packets are issued, which >>> breaks >>> the >>> transfer and results in time-out error messages. >> Early short packets ? What do you mean? > During a USB transfer, all packets must have a length of max > packet > length for > the pipe/endpoint, except the final one that can be a short > packet. > Without the > alignment I make for xfr_bytes, short packets can occur within > a > transfer, > because the hardware starts a new packet for each new queued > qTD > it > handles. But if I am right, the max packet length is 512 for bulk and 1024 for Interrupt transfer.
Sure.
You are right, the speed different will be minimal, only the memory usage will be lower.
The user buffer is aligned to 4kB, but this doesn't matter as a file load from a storage device (ex. fatload) can be segmented in partial USB transfers. This can lead to any block aligned buffer for a partial transfer.
What you mean by realignment-to-page stage?
I don't understand where you expect to complicate the code.
You limit the size of one transfer (xfr_bytes) to (QT_BUFFER_CNT - 1) * 4kB for unaligned buffers. But you only need to limit it to a multiple of the maximal possible wMaxPacketSize (1kB) to make sure that you always send full packages.
I only suggest to replace the causeless 4kB alignment with a reasonable 1kB alignment and adapte the qtd_count caluclation.
int xfr_bytes = min(left_length, (QT_BUFFER_CNT * 4096 - ((uint32_t)buf_ptr & 4095)) & - ~4095); + ~1023);
I'm sure that there is a significant speed gain but you shouldn't miss the heap usage as the main CONFIG_SYS_MALLOC_LEN is 128kB.
Maybe you should also add a worst case heap usage and I'm not sure, if your calculation are right, as the size of struct qTD is allays 32B and thereby I get 50kB or 64kB.
Dear Stefan,
Sorry for the delay. I'm very busy, and there is much to tell on this topic.
On Friday 20 July 2012 16:51:33 Stefan Herbrechtsmeier wrote: > Am 20.07.2012 15:56, schrieb Benoît Thébaudeau: >> Dear Marek Vasut, >> >> On Friday 20 July 2012 15:44:01 Marek Vasut wrote: >>>> On Friday 20 July 2012 13:37:37 Stefan Herbrechtsmeier >>>> wrote: >>>>> Am 20.07.2012 13:26, schrieb Benoît Thébaudeau: >>>>>> + int xfr_bytes = min(left_length, >>>>>> + (QT_BUFFER_CNT * 4096 - >>>>>> + ((uint32_t)buf_ptr & 4095)) & >>>>>> + ~4095); >>>>> Why you align the length to 4096? >>>> It's to guarantee that each transfer length is a multiple >>>> of >>>> the >>>> max packet >>>> length. Otherwise, early short packets are issued, which >>>> breaks >>>> the >>>> transfer and results in time-out error messages. >>> Early short packets ? What do you mean? >> During a USB transfer, all packets must have a length of max >> packet >> length for >> the pipe/endpoint, except the final one that can be a short >> packet. >> Without the >> alignment I make for xfr_bytes, short packets can occur >> within >> a >> transfer, >> because the hardware starts a new packet for each new queued >> qTD >> it >> handles. > But if I am right, the max packet length is 512 for bulk and > 1024 > for > Interrupt transfer. There are indeed different max packet lengths for different transfer types, but it does not matter since the chosen alignment guarantees a multiple of all these possible max packet lengths.
Sure.
If your point is only the memory gain, I agree. With your suggestion, there are roughly 25% less qTDs used in the "(max wMaxPacketSize)-aligned but not page-aligned" case since the number of qTDs is about (total transfer size) / 5 instead of (total transfer size) / 4. But this is still small compared to usual heap sizes (at least on the kind of hardware I use).
What do you mean by "partial USB transfers"? As seen from EHCI users like the MSC driver (usb_storage.c), USB transfers either succeed or fail, but they cannot be "segmented".
On its side, the MSC driver will only segment the FAT layer requests if they are larger than 65535 blocks, so still not what you describe.
As to the FAT stack, it will only read whole clusters while accessing file payload, and the most usual cluster sizes are by default a multiple of 4 kiB (see http://support.microsoft.com/kb/140365).
So I don't see "segmentation" anywhere, and for usual cluster sizes, the EHCI buffer alignment is fully determined by the applicative buffer alignment and the file position corresponding to the beginning of the applicative buffer. But there are indeed some unusual use cases (e.g. smaller clusters) for which only a block-aligned buffer will reach EHCI despite a page-aligned applicative buffer.
I mean that the alignment of the transfer to 1024 instead of 4096 can make the first qTD transfer larger than the following ones, which guarantees that the following qTD transfers are page-aligned, even if the first one was only aligned to 1024. For the 1024-aligned case, this results in the change that you suggest, but it also changes things for the unaligned case, which makes this part of the code inaccurate. See below.
~4095);
~1023);
I agree for this part of the code. But for the allocation part, your suggestion is already a little bit more complicated than my original code, while still incomplete. Besides that, the "((uint32_t)buffer & 4095) +" for the page-unaligned case in my code was actually useless, which emphasizes the difference, even if it's a light complication.
For the allocation part, the appropriate code for your suggestion would be:
if ((uint32_t)buffer & 1023) /* max-wMaxPacketSize-unaligned */ qtd_count += DIV_ROUND_UP(max(length > 0, length - (4096 - ((uint32_t)buf_ptr & 4095) & ~1023)), (QT_BUFFER_CNT - 1) * 4096); else /* max-wMaxPacketSize-aligned */ qtd_count += DIV_ROUND_UP(((uint32_t)buffer & 4095) + length, QT_BUFFER_CNT * 4096);
This code allocates exactly the required number of qTDs, no less, no more. It's clearly more complicated than the 4096 version.
A test should also be added to make sure that qtd_count is never 0. Otherwise, ZLPs are broken (this applies to my original code too).
If we want to compromise accuracy for simplicity, we can change that to:
qtd_count += 2 + length / ((QT_BUFFER_CNT - !!((uint32_t)buffer & 1023)) * 4096);
This code allocates enough qTDs for all cases, with at worst 2 extra qTDs (i.e. a total of 128 bytes) that will be left unused. It also handles intrinsically ZLPs.
Now, let's consider the possible values of wMaxPacketSize: - control endpoints: * LS: 8, * FS: 8, 16, 32 or 64, * HS: 64, - isochronous endpoints: not supported by ehci-hcd.c, - interrupt endpoints: * LS: <= 8, * FS: <= 64, * HS: <= 1024 (1x to 3x for high-bandwidth), - bulk endpoints: * LS: N/A, * FS: 8, 16, 32 or 64, * HS: 512.
My code assumes that wMaxPacketSize is a power of 2. This is not always true for interrupt endpoints. Let's talk about these. Their handling is currently broken in U-Boot since their transfers are made asynchronous instead of periodic. Devices shouldn't care too much about that, as long as transfers do not exceed wMaxPacketSize, in which case my code still works because wMaxPacketSize always fits in a single qTD. Interrupt transfers larger than wMaxPacketSize do not seem to be used by U-Boot. If they were used, the current code in U-Boot would have a timing issue because the asynchronous scheme would break the interval requested by devices, which could at worst make them fail in some way. So the only solution would be that such transfers be split by the caller of submit_int_msg, in which case my code still works. What would you think about failing with an error message in submit_int_msg if length is larger than wMaxPacketSize? Marek, what do you think?
For all other cases, wMaxPacketSize is a power of 2, so everything is fine, except that in those cases wMaxPacketSize is at most 512, which means that with the suggested limitation applied to submit_int_msg, your suggested 1024 could be replaced with 512, which is good news since this is also the most common storage sector size.
We could even use usb_maxpacket(dev, pipe) instead of 512, with some restrictions. If we don't want to alter the misalignment check in ehci_td_buffer, max(usb_maxpacket(dev, pipe), ARCH_DMA_MINALIGN) would actually have to be used. This misalignment check could be limited to the first qTD transfer of a USB transfer, but that would complicate things, all the more the corresponding call to flush_dcache_range would have to be modified to fix alignments.
So we have to make two choices: - between 4096, 1024, 512 and max(usb_maxpacket(dev, pipe), ARCH_DMA_MINALIGN), - between the accurate and simple allocations. That makes a total of 8 working possibilities. What do you guys think we should choose? On my side, I like max(usb_maxpacket(dev, pipe), ARCH_DMA_MINALIGN) with the simple allocation. It's efficient as to code speed, size and readability, as well as to RAM usage.
I have checked all the config files. Among those using EHCI, most have a heap size >= 1 MiB. The only exceptions are:
--------------------------------------------- | Heap Size | Board | RAM Size | |-------------------------------------------| | 512 kiB | MERGERBOX | > 10 MiB | | | MPC8315ERDB | 128 MiB | | | MVBLM7 | 512 MiB | |-------------------------------------------| | 256 kiB | MPC8349ITX | 256 MiB | | | omap4_panda | 1 GiB | |-------------------------------------------| | 128 kiB | adp-ag102 | 256 MiB | | | at91sam9m10g45ek | 128 MiB | | | edminiv2 | 64 MiB | | | M52277EVB | 64 MiB | | | omap3_beagle | >= 128 MiB | ---------------------------------------------
As you can see, these small heap sizes are not linked to any hardware constraint, but only to the lack of need to have larger heaps, so they could be easily enlarged if needed. But even 128 kiB should be enough for common usage.
From ehci.h:
struct qTD { /* this part defined by EHCI spec */ uint32_t qt_next; /* see EHCI 3.5.1 */ #define QT_NEXT_TERMINATE 1 uint32_t qt_altnext; /* see EHCI 3.5.2 */ uint32_t qt_token; /* see EHCI 3.5.3 */ uint32_t qt_buffer[5]; /* see EHCI 3.5.4 */ uint32_t qt_buffer_hi[5]; /* Appendix B */ /* pad struct for 32 byte alignment */ uint32_t unused[3]; };
So sizeof(struct qTD) is 16 * 32 bits = 64 bytes. For the worst alignment case, the number of qTDs to allocate for 65535 blocks of 512 bytes (worst MSC case with 512-byte sectors) is DIV_ROUND_UP(65535 * 512, 4 * 4096) = 2048 qTDs, i.e. 128 kiB. For the same transfer size with the best alignment case, it is DIV_ROUND_UP(65535 * 512, 5 * 4096) = 1639 qTDs, i.e. 104896 B.
But if we consider extreme cases, these figures can get even larger, e.g. with 4-kiB storage sectors.
So we could perhaps issue a #error in ehci-hcd or in usb_storage if CONFIG_SYS_MALLOC_LEN is not large enough, but I don't think it's a good idea because: - the threshold value would have to depend on runtime block sizes or something, which could lead to a big worst worst case that would almost never happen in real life, so giving such an unrealistic heap size constraint would be cumbersome, - reaching the top sizes would mean reading a huge file or something to a large buffer (much larger than the qTDs this transfer requires), which would very likely be heap-allocated (except for commands like fatload), so CONFIG_SYS_MALLOC_LEN would already have to be large for the application, - for command line operations like fatload, transfers of uncontrolled lengths could simply crash U-Boot if they go too far in memory, which means that users of such commands need to know what they are doing anyway, so they have to control transfer sizes, - there is already a runtime error displayed in case of allocation failure.
Ok, I see the point. I understand it's not really a bug, just an improvement. Maybe we can do a subsequent patch on top of these from Benoit and see how it fares?
Segmented -- like multiple transfers being issues with small payload? You can not put these together at the USB-level, since it's the issuing code that has to be fixed.
512b is minimum and it's quite often used.
I don't quite get this one.
~4095);
~1023);
DIV_ROUND_UP( max( length > 0, length - (4096 - ((uint32_t)buf_ptr & 4095) & ~1023) ), (QT_BUFFER_CNT - 1) * 4096 );
Ok, I now think I understand what's going on here. I still have to wonder how much would the compiler optimize of this if you "decompressed" your code -- to make it more easy to understand.
- LS: 8,
- FS: 8, 16, 32 or 64,
- HS: 64,
- LS: <= 8,
- FS: <= 64,
- HS: <= 1024 (1x to 3x for high-bandwidth),
- bulk endpoints:
- LS: N/A,
- HS: 512.
Let's do that ... I think the interrupt endpoint is only used for keyboard and if someone needs it for something else, the code will be there, just needing improvement. Comment and error message are OK.
Won't maxpacket fall below 512 on occasions, which might cause trouble?
For now, I'd go for the safest, easiest and dumbest solution and see how it fares. Subsequent patch can be submitted to improve that and measurements made.
"We should forget about small efficiencies, say about 97% of the time; premature optimization is the root of all evil" -- Donald E. Knuth, Structured Programming with go to Statements [...]
#warning then?
Why, because they overwrite it?
failure.
Ok
Had a good evening with the EHCI r10 spec, hope I answered most of your questions.
Dear Marek Vasut,
Exactly.
If you wish. I'll do that.
OK.
I meant that 512 bytes (most usual storage block size) is what we should aim at to optimize the number of qTDs.
~4095);
~1023);
I wouldn't go for this complicated version since it's not really useful compared to the simpler yet less accurate solution I gave below.
It's this solution I'd like to use to optimize the number of qTDs (with 1023 or something else).
- LS: 8,
- HS: 64,
- LS: <= 8,
- FS: <= 64,
- bulk endpoints:
- LS: N/A,
- HS: 512.
OK. I have thought of another solution for this. You'll tell me which one you prefer.
The ehci_submit_async code currently in U-Boot checks through ehci_td_buffer that length fits in the single qTD reserved for data payload only after work has begun, possibly after a SETUP transfer. With my series, this is checked at the very beginning, before the allocation. We could detect that wMaxPacketSize is not a power of 2 (e.g. with __builtin_popcount), in which case the allocation for the data payload would be restricted to 1 qTD like now, and there would be a check at the very beginning to test if length fits in this qTD. In that way, there could be several packets per interrupt transfer as long as it fits in a single qTD, just like now, contrary to the limitation imposed by the error in submit_int_msg. But I'm not sure it's a good idea to allow this behavior.
Sure.
Why?
OK, so I'll stick to my original series, rework it lightly as we said, add Jim's patch, and add a further patch for these optimizations.
#warning then?
With which limit if so?
Yes. U-Boot expands down its allocation during startup, so it's often located at the end of the embedded RAM, which means that fatload will very likely use the beginning of the RAM.
failure.
Ok
So #warning or not besides this?
Yes, thanks.
Am 31.07.2012 03:06, schrieb Benoît Thébaudeau:
Dear Marek Vasut,
Exactly.
Right.
If the segmentation comes from the file system handling we can not avoid this.
OK.
In my example I use a FAT partition with 128 MB and 1 KB clusters. The file is read in two segments in which the first transfer starts 4 kB aligned but stops 1 kB aligned but not 4 kB aligned and leads to unaligned second transfer.
Right.
You are right. It maximise the first transfer. All other transfers are 5 * 4 KB (aligned) or 4 * 4 KB (unaligned) long.
~4095);
~1023);
You are right, but your complicate code only saves one qTD.
This sounds reasonable.
- LS: 8,
- HS: 64,
- LS: <= 8,
- FS: <= 64,
- bulk endpoints:
- LS: N/A,
- HS: 512.
I think this is not needed, as there is only one user (keyboard) with max size of 8 byte.
Sure.
I would go with 512 as it also the most common storage sector size.
Why?
Okay.
#warning then?
I would expect more than 128kB as this is a common worst case (512 B block size).
failure.
Ok
Yes, thanks.
Regards, Stefan
Dear Stefan Herbrechtsmeier,
Right.
If the FS code is shitty or the device is fragmented, noone can help that.
I agree, but for a different reason. Let's aim for a simple implementation first that doesn't change behavior and add this change later _if_ needed.
idea because:
or
#warning then?
Seems to be reasonable.
Dear Marek Vasut,
Yes, thanks.
Sorry again for the delay. I still have a few urgent issues to address (caused by U-Boot :( ) in priority. Hopefully, next week will be the good one. I now have tens of new patches to post :) , not all for you ;) .
Dear Marek Vasut,
Yes, thanks.
I'm myself really juiced out, so take your time ;-)
Dear Marek Vasut,
Yes, thanks.
I was close to posting it tonight. I have only a few comments and tests left to do. That will be for tomorrow.
How will you handle the merge with http://patchwork.ozlabs.org/patch/175887/ ? Do you want to apply it before or after my series? If before, do you want me to factor my series as if this patch had been applied?
Dear Marek Vasut,
Yes, thanks.
After, your series seems to be ready for application. Can you rebase your series on current u-boot-usb/master btw ?
Dear Benoît
Am 29.07.2012 02:48, schrieb Benoît Thébaudeau:
No problem. Hopefully I don't make you to much extra trouble.
You are right.
Maybe you should also add a worst case heap usage and I'm not sure, if your calculation are right, as the size of struct qTD is allays 32B and thereby I get 50kB or 64kB. From ehci.h:
Sorry, you are right. I had missed the arrays.
Regards, Stefan
qtd_count += 1 + 1;
Ok, now I almost see it.
return -1;
I'm cool with the rest, I'll think about the calculation a bit though, since I'm not certain about it right away and let you know. Will you be submitting the series again or shall I just merge 3/5 and 4/5, apply this one and be done with it?
Dear Marek,
return -1;
I'll resubmit the whole series. I'll first answer Stefan in this thread when possible.
Regards, Benoît
Dear Marek,
if (qtd == NULL) {
return -1;
Please do, and see how Jim is with the timeout patch please.
Regards, Benoît
This patch takes advantage of the hardware EHCI qTD queuing mechanism to avoid software and transfer splitting overhead so as to make transfers as fast as possible.
The only drawback is a call to memalign. However, this is fast compared to the transfer timings, and the heap size to allocate is small, e.g. 128 kiB in the worst case for a transfer length of 65535 packets of 512 bytes.
Tested on i.MX25, i.MX35 and i.MX51. In my test conditions, the speed gain was very significant (several times faster), which is really appreciable when accessing large files.
Signed-off-by: Benoît Thébaudeau benoit.thebaudeau@advansee.com Cc: Marek Vasut marex@denx.de Cc: Ilya Yanok ilya.yanok@cogentembedded.com Cc: Stefan Herbrechtsmeier stefan@herbrechtsmeier.net --- Changes for v2: - Use DIV_ROUND_UP to make code more readable. Changes for v3: - Remove extra unalignment term in the computation of qtd_count. - Fix ZLP support. - Add #warning if CONFIG_SYS_MALLOC_LEN is likely to be too small. - Make code more readable. - Add comments.
.../drivers/usb/host/ehci-hcd.c | 171 ++++++++++++++++---- 1 file changed, 139 insertions(+), 32 deletions(-)
diff --git u-boot-usb-8d5fb14.orig/drivers/usb/host/ehci-hcd.c u-boot-usb-8d5fb14/drivers/usb/host/ehci-hcd.c index a4c84a3..84c7d08 100644 --- u-boot-usb-8d5fb14.orig/drivers/usb/host/ehci-hcd.c +++ u-boot-usb-8d5fb14/drivers/usb/host/ehci-hcd.c @@ -208,8 +208,8 @@ ehci_submit_async(struct usb_device *dev, unsigned long pipe, void *buffer, int length, struct devrequest *req) { ALLOC_ALIGN_BUFFER(struct QH, qh, 1, USB_DMA_MINALIGN); -#define QTD_COUNT 3 - ALLOC_ALIGN_BUFFER(struct qTD, qtd, QTD_COUNT, USB_DMA_MINALIGN); + struct qTD *qtd; + int qtd_count = 0; int qtd_counter = 0;
volatile struct qTD *vtd; @@ -230,8 +230,74 @@ ehci_submit_async(struct usb_device *dev, unsigned long pipe, void *buffer, le16_to_cpu(req->value), le16_to_cpu(req->value), le16_to_cpu(req->index));
+ /* + * The USB transfer is split into qTD transfers. Eeach qTD transfer is + * described by a transfer descriptor (the qTD). The qTDs form a linked + * list with a queue head (QH). + * + * Each qTD transfer starts with a new USB packet, i.e. a packet cannot + * have its beginning in a qTD transfer and its end in the following + * one, so the qTD transfer lengths have to be chosen accordingly. + * + * Each qTD transfer uses up to QT_BUFFER_CNT data buffers, mapped to + * single pages. The first data buffer can start at any offset within a + * page (not considering the cache-line alignment issues), while the + * following buffers must be page-aligned. There is no alignment + * constraint on the size of a qTD transfer. + */ + if (req != NULL) + /* 1 qTD will be needed for SETUP, and 1 for ACK. */ + qtd_count += 1 + 1; + if (length > 0 || req == NULL) { + /* + * Determine the qTD transfer size that will be used for the + * data payload (not considering the final qTD transfer, which + * may be shorter). + * + * In order to keep each packet within a qTD transfer, the qTD + * transfer size is aligned to EHCI_PAGE_SIZE, which is a + * multiple of wMaxPacketSize (except in some cases for + * interrupt transfers, see comment in submit_int_msg()). + * + * By default, i.e. if the input buffer is page-aligned, + * QT_BUFFER_CNT full pages will be used. + */ + int xfr_sz = QT_BUFFER_CNT; + /* + * However, if the input buffer is not page-aligned, the qTD + * transfer size will be one page shorter, and the first qTD + * data buffer of each transfer will be page-unaligned. + */ + if ((uint32_t)buffer & (EHCI_PAGE_SIZE - 1)) + xfr_sz--; + /* Convert the qTD transfer size to bytes. */ + xfr_sz *= EHCI_PAGE_SIZE; + /* + * Determine the number of qTDs that will be required for the + * data payload. This value has to be rounded up since the final + * qTD transfer may be shorter than the regular qTD transfer + * size that has just been computed. + */ + qtd_count += DIV_ROUND_UP(length, xfr_sz); + /* ZLPs also need a qTD. */ + if (!qtd_count) + qtd_count++; + } +/* + * Threshold value based on the worst-case total size of the qTDs to allocate + * for a mass-storage transfer of 65535 blocks of 512 bytes. + */ +#if CONFIG_SYS_MALLOC_LEN <= 128 * 1024 +#warning CONFIG_SYS_MALLOC_LEN may be too small for EHCI +#endif + qtd = memalign(USB_DMA_MINALIGN, qtd_count * sizeof(struct qTD)); + if (qtd == NULL) { + printf("unable to allocate TDs\n"); + return -1; + } + memset(qh, 0, sizeof(struct QH)); - memset(qtd, 0, QTD_COUNT * sizeof(*qtd)); + memset(qtd, 0, qtd_count * sizeof(*qtd));
@@ -296,33 +362,65 @@ ehci_submit_async(struct usb_device *dev, unsigned long pipe, void *buffer, }
if (length > 0 || req == NULL) { - /* - * Setup request qTD (3.5 in ehci-r10.pdf) - * - * qt_next ................ 03-00 H - * qt_altnext ............. 07-04 H - * qt_token ............... 0B-08 H - * - * [ buffer, buffer_hi ] loaded with "buffer". - */ - qtd[qtd_counter].qt_next = cpu_to_hc32(QT_NEXT_TERMINATE); - qtd[qtd_counter].qt_altnext = cpu_to_hc32(QT_NEXT_TERMINATE); - token = (toggle << QT_TOKEN_DT) | - (length << QT_TOKEN_TOTALBYTES) | - ((req == NULL) << QT_TOKEN_IOC) | - (0 << QT_TOKEN_CPAGE) | - (3 << QT_TOKEN_CERR) | - ((usb_pipein(pipe) ? QT_TOKEN_PID_IN : QT_TOKEN_PID_OUT) << - QT_TOKEN_PID) | - (QT_TOKEN_STATUS_ACTIVE << QT_TOKEN_STATUS); - qtd[qtd_counter].qt_token = cpu_to_hc32(token); - if (ehci_td_buffer(&qtd[qtd_counter], buffer, length) != 0) { - printf("unable construct DATA td\n"); - goto fail; - } - /* Update previous qTD! */ - *tdp = cpu_to_hc32((uint32_t)&qtd[qtd_counter]); - tdp = &qtd[qtd_counter++].qt_next; + uint8_t *buf_ptr = buffer; + int left_length = length; + + do { + /* + * Determine the size of this qTD transfer. By default, + * QT_BUFFER_CNT full pages can be used. + */ + int xfr_bytes = QT_BUFFER_CNT * EHCI_PAGE_SIZE; + /* + * However, if the input buffer is not page-aligned, the + * portion of the first page before the buffer start + * offset within that page is unusable. + */ + xfr_bytes -= (uint32_t)buf_ptr & (EHCI_PAGE_SIZE - 1); + /* + * In order to keep each packet within a qTD transfer, + * align the qTD transfer size to EHCI_PAGE_SIZE. + */ + xfr_bytes &= ~(EHCI_PAGE_SIZE - 1); + /* + * This transfer may be shorter than the available qTD + * transfer size that has just been computed. + */ + xfr_bytes = min(xfr_bytes, left_length); + + /* + * Setup request qTD (3.5 in ehci-r10.pdf) + * + * qt_next ................ 03-00 H + * qt_altnext ............. 07-04 H + * qt_token ............... 0B-08 H + * + * [ buffer, buffer_hi ] loaded with "buffer". + */ + qtd[qtd_counter].qt_next = + cpu_to_hc32(QT_NEXT_TERMINATE); + qtd[qtd_counter].qt_altnext = + cpu_to_hc32(QT_NEXT_TERMINATE); + token = (toggle << QT_TOKEN_DT) | + (xfr_bytes << QT_TOKEN_TOTALBYTES) | + ((req == NULL) << QT_TOKEN_IOC) | + (0 << QT_TOKEN_CPAGE) | + (3 << QT_TOKEN_CERR) | + ((usb_pipein(pipe) ? QT_TOKEN_PID_IN : + QT_TOKEN_PID_OUT) << QT_TOKEN_PID) | + (QT_TOKEN_STATUS_ACTIVE << QT_TOKEN_STATUS); + qtd[qtd_counter].qt_token = cpu_to_hc32(token); + if (ehci_td_buffer(&qtd[qtd_counter], buf_ptr, + xfr_bytes) != 0) { + printf("unable construct DATA td\n"); + goto fail; + } + /* Update previous qTD! */ + *tdp = cpu_to_hc32((uint32_t)&qtd[qtd_counter]); + tdp = &qtd[qtd_counter++].qt_next; + buf_ptr += xfr_bytes; + left_length -= xfr_bytes; + } while (left_length > 0); }
if (req != NULL) { @@ -356,7 +454,7 @@ ehci_submit_async(struct usb_device *dev, unsigned long pipe, void *buffer, ALIGN_END_ADDR(struct QH, qh_list, 1)); flush_dcache_range((uint32_t)qh, ALIGN_END_ADDR(struct QH, qh, 1)); flush_dcache_range((uint32_t)qtd, - ALIGN_END_ADDR(struct qTD, qtd, QTD_COUNT)); + ALIGN_END_ADDR(struct qTD, qtd, qtd_count));
/* Set async. queue head pointer. */ ehci_writel(&hcor->or_asynclistaddr, (uint32_t)qh_list); @@ -387,7 +485,7 @@ ehci_submit_async(struct usb_device *dev, unsigned long pipe, void *buffer, invalidate_dcache_range((uint32_t)qh, ALIGN_END_ADDR(struct QH, qh, 1)); invalidate_dcache_range((uint32_t)qtd, - ALIGN_END_ADDR(struct qTD, qtd, QTD_COUNT)); + ALIGN_END_ADDR(struct qTD, qtd, qtd_count));
token = hc32_to_cpu(vtd->qt_token); if (!(token & (QT_TOKEN_STATUS_ACTIVE << QT_TOKEN_STATUS))) @@ -463,9 +561,11 @@ ehci_submit_async(struct usb_device *dev, unsigned long pipe, void *buffer, ehci_readl(&hcor->or_portsc[1])); }
@@ -842,6 +942,13 @@ submit_int_msg(struct usb_device *dev, unsigned long pipe, void *buffer, /* * Interrupt transfers requiring several transactions are not supported * because bInterval is ignored. + * + * Also, ehci_submit_async() relies on wMaxPacketSize being a power of 2 + * if several qTDs are required, while the USB specification does not + * constrain this for interrupt transfers. That means that + * ehci_submit_async() would support interrupt transfers requiring + * several transactions only as long as the transfer size does not + * require more than a single qTD. */ if (length > usb_maxpacket(dev, pipe)) { printf("%s: Interrupt transfers requiring several transactions "
Seems fine :)
struct qTD *qtd;
qtd_count += 1 + 1;
Ok, maybe you can please elaborate on this crazy calculation in here? Or somehow clarify it? Also, won't the macros in include/common.h help in a way? (like ROUND() etc).
I don't really graps what you're trying to calculate here, so maybe even a comment would help.
Same here, also please avoid using those 4096 and such constants ... maybe #define them in ehci.h ?
So your code can alloc more than 5 qTDs ? How does it chain them then? Into more QHs ?
return -1;
(length << 16) |
(0 << 12) |
(3 << 10) |
goto fail;
do {
~4095);
Magic formula yet again ... comment would again be welcome please.
(xfr_bytes << 16) |
(0 << 12) |
(3 << 10) |
If you could fix all this magic afterwards (not in these patches), that'd be great.
xfr_bytes) != 0) {
goto fail;
if (req != NULL) {
- free(qtd); return (dev->status != USB_ST_NOT_PROC) ? 0 : -1;
fail:
- free(qtd); return -1;
Dear Marek Vasut,
struct qTD *qtd;
qtd_count += 1 + 1;
I have already posted a v2 for this specific patch (only 2/5) that does exactly that. Please review only the latest versions of patches.
I'll do that.
Yes. It was already everywhere, so I went on the same way. Do you think using PAGE_SIZE from <linux/compat.h> would be fine since these 4096 are nothing more than page sizes?
It's done in exactly the same way as for the original 3 qTDs, only with more qTDs, but still with 5 qt_buffers per qTD.
return -1;
(length << 16) |
(0 << 12) |
(3 << 10) |
goto fail;
do {
~4095);
OK.
(xfr_bytes << 16) |
(0 << 12) |
(3 << 10) |
Do you only mean #defining all those values?
xfr_bytes) != 0) {
goto fail;
if (req != NULL) {
3));
fail:
Best regards, Benoît Thébaudeau
I'll do that.
I'm not exactly proud of the state of the usb stack, you know :(
Isn't that intel-specific?
I'm starting to see what you're trying to do. That's really cool :)
(xfr_bytes << 16) |
(0 << 12) |
(3 << 10) |
Yes, but let's do this in a subsequent patch. It can wait for later.
Dear Marek,
I don't know. The code does not say so. What is sure is that page sizes should be arch-specific, even with several possible page sizes per arch. But this #define seems to fit our needs, so why not use it? The only thing that would make me reluctant to using it is that this code might change without further notice.
qTD));
OK.
(xfr_bytes << 16) |
(0 << 12) |
(3 << 10) |
OK.
Regards, Benoît
Dear Marek,
That's exactly my point. And it'll break anything with pages smaller than 4k. Please define it in ehci.h [..] Best regards, Marek Vasut
Dear Marek,
(xfr_bytes << 16) |
(0 << 12) |
(3 << 10) |
OK.
What would you think about merging that together with the definition of 4096 into the current patch 1/5? In the next version, this patch would thus become a general cosmetic patch for EHCI to define all used constants.
Dear Marek,
(xfr_bytes << 16) |
(0 << 12) |
(3 << 10) |
0);
OK.
That's all right with me.
Dear Marek Vasut,
> + token = (toggle << 31) | > + (xfr_bytes << 16) | > + ((req == NULL ? 1 : 0) << 15) | > + (0 << 12) | > + (3 << 10) | > + ((usb_pipein(pipe) ? 1 : 0) << 8) | (0x80 <<
0);
OK.
Great. There are also questions for you in my answer to Stefan. Please take a look at these. I know, it's long to read, sorry.
Dear Marek Vasut,
> > + token = (toggle << 31) | > > + (xfr_bytes << 16) | > > + ((req == NULL ? 1 : 0) << 15) | > > + (0 << 12) | > > + (3 << 10) | > > + ((usb_pipein(pipe) ? 1 : 0) << 8) |
(0x80 <<
0);
> If you could fix all this magic afterwards (not in these > patches), > that'd be > great.
OK.
I'm still trying to make some sense of it, gimme one more day please.
Benoît Thébaudeau
