[PATCH 1/1] zynq: mtd: nand: remove superfluous if
This sort of code does not make much sense:
if (ondie_ecc_enabled) { if (ondie_ecc_enabled) {
Remove the inner if.
The problem was indicated by cppcheck.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- drivers/mtd/nand/raw/zynq_nand.c | 10 ++++------ 1 file changed, 4 insertions(+), 6 deletions(-)
diff --git a/drivers/mtd/nand/raw/zynq_nand.c b/drivers/mtd/nand/raw/zynq_nand.c index 92db2aa19c..65817ea7f2 100644 --- a/drivers/mtd/nand/raw/zynq_nand.c +++ b/drivers/mtd/nand/raw/zynq_nand.c @@ -1206,12 +1206,10 @@ static int zynq_nand_probe(struct udevice *dev) nand_chip->options |= NAND_SUBPAGE_READ;
/* On-Die ECC spare bytes offset 8 is used for ECC codes */ - if (ondie_ecc_enabled) { - nand_chip->ecc.layout = &ondie_nand_oob_64; - /* Use the BBT pattern descriptors */ - nand_chip->bbt_td = &bbt_main_descr; - nand_chip->bbt_md = &bbt_mirror_descr; - } + nand_chip->ecc.layout = &ondie_nand_oob_64; + /* Use the BBT pattern descriptors */ + nand_chip->bbt_td = &bbt_main_descr; + nand_chip->bbt_md = &bbt_mirror_descr; } else { /* Hardware ECC generates 3 bytes ECC code for each 512 bytes */ nand_chip->ecc.mode = NAND_ECC_HW; -- 2.29.2
} else { /* Hardware ECC generates 3 bytes ECC code for each 512 bytes */ nand_chip->ecc.mode = NAND_ECC_HW;nand_chip->bbt_md = &bbt_mirror_descr;
-- 2.29.2
Applied. M
Michal Simek
