[U-Boot] [PATCH][v2] powerpc:Rename CONFIG_PBLRCW_CONFIG & CONFIG_SYS_FSL_PBL_PBI
Rename CONFIG_PBLRCW_CONFIG and CONFIG_PBLRCW_CONFIG.
Also add their details in README.
Signed-off-by: Prabhakar Kushwaha prabhakar@freescale.com --- changes for v2: Incorporated Wolfgang's comments - Added more description in README
Makefile | 4 ++-- README | 9 +++++++++ include/configs/B4860QDS.h | 4 ++-- include/configs/P2041RDB.h | 5 +++-- include/configs/T1040QDS.h | 4 ++-- include/configs/T2080QDS.h | 4 ++-- include/configs/T4240QDS.h | 4 ++-- include/configs/corenet_ds.h | 14 +++++++++----- include/configs/km/kmp204x-common.h | 4 ++-- 9 files changed, 33 insertions(+), 19 deletions(-)
diff --git a/Makefile b/Makefile index e6f6edb..beee7ec 100644 --- a/Makefile +++ b/Makefile @@ -419,8 +419,8 @@ $(obj)u-boot.kwb: $(obj)u-boot.bin -a $(CONFIG_SYS_TEXT_BASE) -e $(CONFIG_SYS_TEXT_BASE) -d $< $@
$(obj)u-boot.pbl: $(obj)u-boot.bin - $(obj)tools/mkimage -n $(CONFIG_PBLRCW_CONFIG) \ - -R $(CONFIG_PBLPBI_CONFIG) -T pblimage \ + $(obj)tools/mkimage -n $(CONFIG_SYS_FSL_PBL_RCW) \ + -R $(CONFIG_SYS_FSL_PBL_PBI) -T pblimage \ -d $< $@
$(obj)u-boot.sha1: $(obj)u-boot.bin diff --git a/README b/README index a0646c3..9b3aaf4 100644 --- a/README +++ b/README @@ -472,6 +472,15 @@ The following options need to be configured: Board config to use DDR3. It can be enabled for SoCs with Freescale DDR3 controllers.
+ CONFIG_SYS_FSL_PBL_PBI + It enables addition of RCW (Power on reset configuration) in built image. + Please refer doc/README.pblimage for more details + + CONFIG_SYS_FSL_PBL_RCW + It adds PBI(pre-boot instructions) commands in u-boot build image. + PBI commands can be used to configure SoC before it starts the execution. + Please refer doc/README.pblimage for more details + - Intel Monahans options: CONFIG_SYS_MONAHANS_RUN_MODE_OSC_RATIO
diff --git a/include/configs/B4860QDS.h b/include/configs/B4860QDS.h index c182158..c667229 100644 --- a/include/configs/B4860QDS.h +++ b/include/configs/B4860QDS.h @@ -16,8 +16,8 @@ #ifdef CONFIG_RAMBOOT_PBL #define CONFIG_RAMBOOT_TEXT_BASE CONFIG_SYS_TEXT_BASE #define CONFIG_RESET_VECTOR_ADDRESS 0xfffffffc -#define CONFIG_PBLPBI_CONFIG $(SRCTREE)/board/freescale/b4860qds/b4_pbi.cfg -#define CONFIG_PBLRCW_CONFIG $(SRCTREE)/board/freescale/b4860qds/b4_rcw.cfg +#define CONFIG_SYS_FSL_PBL_PBI $(SRCTREE)/board/freescale/b4860qds/b4_pbi.cfg +#define CONFIG_SYS_FSL_PBL_RCW $(SRCTREE)/board/freescale/b4860qds/b4_rcw.cfg #endif
#ifdef CONFIG_SRIO_PCIE_BOOT_SLAVE diff --git a/include/configs/P2041RDB.h b/include/configs/P2041RDB.h index ee71252..2b81cbe 100644 --- a/include/configs/P2041RDB.h +++ b/include/configs/P2041RDB.h @@ -18,8 +18,9 @@ #ifdef CONFIG_RAMBOOT_PBL #define CONFIG_RAMBOOT_TEXT_BASE CONFIG_SYS_TEXT_BASE #define CONFIG_RESET_VECTOR_ADDRESS 0xfffffffc -#define CONFIG_PBLPBI_CONFIG $(SRCTREE)/board/freescale/corenet_ds/pbi.cfg -#define CONFIG_PBLRCW_CONFIG $(SRCTREE)/board/freescale/corenet_ds/rcw_p2041rdb.cfg +#define CONFIG_SYS_FSL_PBL_PBI $(SRCTREE)/board/freescale/corenet_ds/pbi.cfg +#define CONFIG_SYS_FSL_PBL_RCW \ + $(SRCTREE)/board/freescale/corenet_ds/rcw_p2041rdb.cfg #endif
#ifdef CONFIG_SRIO_PCIE_BOOT_SLAVE diff --git a/include/configs/T1040QDS.h b/include/configs/T1040QDS.h index 7d0bc04..74d8049 100644 --- a/include/configs/T1040QDS.h +++ b/include/configs/T1040QDS.h @@ -32,8 +32,8 @@ #ifdef CONFIG_RAMBOOT_PBL #define CONFIG_RAMBOOT_TEXT_BASE CONFIG_SYS_TEXT_BASE #define CONFIG_RESET_VECTOR_ADDRESS 0xfffffffc -#define CONFIG_PBLPBI_CONFIG $(SRCTREE)/board/freescale/t1040qds/t1040_pbi.cfg -#define CONFIG_PBLRCW_CONFIG $(SRCTREE)/board/freescale/t1040qds/t1040_rcw.cfg +#define CONFIG_SYS_FSL_PBL_PBI $(SRCTREE)/board/freescale/t1040qds/t1040_pbi.cfg +#define CONFIG_SYS_FSL_PBL_RCW $(SRCTREE)/board/freescale/t1040qds/t1040_rcw.cfg #endif
/* High Level Configuration Options */ diff --git a/include/configs/T2080QDS.h b/include/configs/T2080QDS.h index bff001f..b35e107 100644 --- a/include/configs/T2080QDS.h +++ b/include/configs/T2080QDS.h @@ -45,8 +45,8 @@ #ifdef CONFIG_RAMBOOT_PBL #define CONFIG_RAMBOOT_TEXT_BASE CONFIG_SYS_TEXT_BASE #define CONFIG_RESET_VECTOR_ADDRESS 0xfffffffc -#define CONFIG_PBLPBI_CONFIG $(SRCTREE)/board/freescale/t2080qds/t2080_pbi.cfg -#define CONFIG_PBLRCW_CONFIG $(SRCTREE)/board/freescale/t2080qds/t2080_rcw.cfg +#define CONFIG_SYS_FSL_PBL_PBI $(SRCTREE)/board/freescale/t2080qds/t2080_pbi.cfg +#define CONFIG_SYS_FSL_PBL_RCW $(SRCTREE)/board/freescale/t2080qds/t2080_rcw.cfg #endif
#define CONFIG_SRIO_PCIE_BOOT_MASTER diff --git a/include/configs/T4240QDS.h b/include/configs/T4240QDS.h index c96df54..1f1177b 100644 --- a/include/configs/T4240QDS.h +++ b/include/configs/T4240QDS.h @@ -21,8 +21,8 @@ #ifdef CONFIG_RAMBOOT_PBL #define CONFIG_RAMBOOT_TEXT_BASE CONFIG_SYS_TEXT_BASE #define CONFIG_RESET_VECTOR_ADDRESS 0xfffffffc -#define CONFIG_PBLPBI_CONFIG $(SRCTREE)/board/freescale/t4qds/t4_pbi.cfg -#define CONFIG_PBLRCW_CONFIG $(SRCTREE)/board/freescale/t4qds/t4_rcw.cfg +#define CONFIG_SYS_FSL_PBL_PBI $(SRCTREE)/board/freescale/t4qds/t4_pbi.cfg +#define CONFIG_SYS_FSL_PBL_RCW $(SRCTREE)/board/freescale/t4qds/t4_rcw.cfg #endif
#ifdef CONFIG_SRIO_PCIE_BOOT_SLAVE diff --git a/include/configs/corenet_ds.h b/include/configs/corenet_ds.h index 969b990..3a1826d 100644 --- a/include/configs/corenet_ds.h +++ b/include/configs/corenet_ds.h @@ -15,15 +15,19 @@ #ifdef CONFIG_RAMBOOT_PBL #define CONFIG_RAMBOOT_TEXT_BASE CONFIG_SYS_TEXT_BASE #define CONFIG_RESET_VECTOR_ADDRESS 0xfffffffc -#define CONFIG_PBLPBI_CONFIG $(SRCTREE)/board/freescale/corenet_ds/pbi.cfg +#define CONFIG_SYS_FSL_PBL_PBI $(SRCTREE)/board/freescale/corenet_ds/pbi.cfg #if defined(CONFIG_P3041DS) -#define CONFIG_PBLRCW_CONFIG $(SRCTREE)/board/freescale/corenet_ds/rcw_p3041ds.cfg +#define CONFIG_SYS_FSL_PBL_RCW \ + $(SRCTREE)/board/freescale/corenet_ds/rcw_p3041ds.cfg #elif defined(CONFIG_P4080DS) -#define CONFIG_PBLRCW_CONFIG $(SRCTREE)/board/freescale/corenet_ds/rcw_p4080ds.cfg +#define CONFIG_SYS_FSL_PBL_RCW \ + $(SRCTREE)/board/freescale/corenet_ds/rcw_p4080ds.cfg #elif defined(CONFIG_P5020DS) -#define CONFIG_PBLRCW_CONFIG $(SRCTREE)/board/freescale/corenet_ds/rcw_p5020ds.cfg +#define CONFIG_SYS_FSL_PBL_RCW \ + $(SRCTREE)/board/freescale/corenet_ds/rcw_p5020ds.cfg #elif defined(CONFIG_P5040DS) -#define CONFIG_PBLRCW_CONFIG $(SRCTREE)/board/freescale/corenet_ds/rcw_p5040ds.cfg +#define CONFIG_SYS_FSL_PBL_RCW \ + $(SRCTREE)/board/freescale/corenet_ds/rcw_p5040ds.cfg #endif #endif
diff --git a/include/configs/km/kmp204x-common.h b/include/configs/km/kmp204x-common.h index 50330cc..0463fcb 100644 --- a/include/configs/km/kmp204x-common.h +++ b/include/configs/km/kmp204x-common.h @@ -24,8 +24,8 @@ #define CONFIG_RAMBOOT_PBL #define CONFIG_RAMBOOT_TEXT_BASE CONFIG_SYS_TEXT_BASE #define CONFIG_RESET_VECTOR_ADDRESS 0xfffffffc -#define CONFIG_PBLPBI_CONFIG $(SRCTREE)/board/keymile/kmp204x/pbi.cfg -#define CONFIG_PBLRCW_CONFIG $(SRCTREE)/board/keymile/kmp204x/rcw_kmp204x.cfg +#define CONFIG_SYS_FSL_PBL_PBI $(SRCTREE)/board/keymile/kmp204x/pbi.cfg +#define CONFIG_SYS_FSL_PBL_RCW $(SRCTREE)/board/keymile/kmp204x/rcw_kmp204x.cfg
/* High Level Configuration Options */ #define CONFIG_BOOKE
Applied to u-boot-mpc85xx master branch. Awaiting upstream.
York
Prabhakar Kushwaha
York Sun
