[PATCH] libfdt: Fix build with swig 4.3.0
Call SWIG_AppendOutput instead of SWIG_Python_AppendOutput so that is_void is handled within swig.
Link: https://github.com/swig/swig/commit/cd39cf132c96a0887be07c826b80804d7677a701
Signed-off-by: Rudi Heitbaum rudi@heitbaum.com --- scripts/dtc/pylibfdt/libfdt.i_shipped | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/scripts/dtc/pylibfdt/libfdt.i_shipped b/scripts/dtc/pylibfdt/libfdt.i_shipped index 56cc5d48f4..e4659489a9 100644 --- a/scripts/dtc/pylibfdt/libfdt.i_shipped +++ b/scripts/dtc/pylibfdt/libfdt.i_shipped @@ -1037,7 +1037,7 @@ typedef uint32_t fdt32_t; fdt_string(fdt1, fdt32_to_cpu($1->nameoff))); buff = PyByteArray_FromStringAndSize( (const char *)($1 + 1), fdt32_to_cpu($1->len)); - resultobj = SWIG_Python_AppendOutput(resultobj, buff); + resultobj = SWIG_AppendOutput(resultobj, buff); } }
@@ -1076,7 +1076,7 @@ typedef uint32_t fdt32_t;
%typemap(argout) int *depth { PyObject *val = Py_BuildValue("i", *arg$argnum); - resultobj = SWIG_Python_AppendOutput(resultobj, val); + resultobj = SWIG_AppendOutput(resultobj, val); }
%apply int *depth { int *depth }; @@ -1092,7 +1092,7 @@ typedef uint32_t fdt32_t; if (PyTuple_GET_SIZE(resultobj) == 0) resultobj = val; else - resultobj = SWIG_Python_AppendOutput(resultobj, val); + resultobj = SWIG_AppendOutput(resultobj, val); } }
Dtc is a separate project at https://git.kernel.org/pub/scm/utils/dtc/dtc.git, so the patch should be rebased against it and sent to devicetree-compiler@vger.kernel.org.
} } @@ -1076,7 +1076,7 @@ typedef uint32_t fdt32_t; %typemap(argout) int *depth { PyObject *val = Py_BuildValue("i", *arg$argnum); - resultobj = SWIG_Python_AppendOutput(resultobj, val); + resultobj = SWIG_AppendOutput(resultobj, val); } %apply int *depth { int *depth }; @@ -1092,7 +1092,7 @@ typedef uint32_t fdt32_t; if (PyTuple_GET_SIZE(resultobj) == 0) resultobj = val; else - resultobj = SWIG_Python_AppendOutput(resultobj, val); + resultobj = SWIG_AppendOutput(resultobj, val); } }
Looks like someone independently fixed it upstream: https://github.com/dgibson/dtc/pull/154
I'm doing final tests now and expect to merge shortly.
On Tue, Oct 29, 2024 at 8:10 PM David Gibson david@gibson.dropbear.id.au wrote:
Would be good to tag a release too, so that distros have something to pick up when they update swig.
Rob
Done.
David Gibson
Rob Herring
Rudi Heitbaum
Xi Ruoyao
