[U-Boot] [PATCH] CFI: Add geometry reversal for STMicro M29W320ET
Added flash_fixup_stm to fix geometry reversal on STMicro M29W320ET flash chip.
Signed-off-by: Richard Retanubun RichardRetanubun@RuggedCom.com ---
Modeled after flash_fixup_amd. this patch handles the geometry reversal or erase sectors that exist for ST Micro (now Numonyx) M29W320ET flash. Since I cannot test all STM's chips, the detection is implemented as narrow as possible for now.
Any feedback is appreciated.
drivers/mtd/cfi_flash.c | 17 +++++++++++++++++ 1 files changed, 17 insertions(+), 0 deletions(-)
diff --git a/drivers/mtd/cfi_flash.c b/drivers/mtd/cfi_flash.c index e8afe99..7ece71c 100644 --- a/drivers/mtd/cfi_flash.c +++ b/drivers/mtd/cfi_flash.c @@ -1795,6 +1795,20 @@ static void flash_fixup_atmel(flash_info_t *info, struct cfi_qry *qry) cfi_reverse_geometry(qry); }
+static void flash_fixup_stm(flash_info_t *info, struct cfi_qry *qry) +{ + /* check if flash geometry needs reversal */ + if (qry->num_erase_regions > 1) { + /* reverse geometry if top boot part */ + if (info->cfi_version < 0x3131) { + /* CFI < 1.1, guess by device id (only M29W320ET now) */ + if (info->device_id == 0x2256) { + cfi_reverse_geometry(qry); + } + } + } +} + /* * The following code cannot be run from FLASH! * @@ -1868,6 +1882,9 @@ ulong flash_get_size (ulong base, int banknum) case 0x001f: flash_fixup_atmel(info, &qry); break; + case 0x0020: + flash_fixup_stm(info, &qry); + break; }
debug ("manufacturer is %d\n", info->vendor);
this comment should be above the --- and in the changelog imo -mike
ACK. Richard, please resend with this additional description in the main commit text.
Thanks.
Best regards, Stefan
Modeled after flash_fixup_amd, this patch handles the geometry reversal or erase sectors that exist for ST Micro (now Numonyx) M29W320ET flash. Since I cannot test all STM's chips, the detection is implemented as narrow as possible for now.
Applied to u-boot/master. Thanks
Mike Frysinger
Richard Retanubun
Stefan Roese
