[PATCH v7 00/10] vidconsole: refactoring and support for wider fonts
Version 7 has vidconsole_get_font_size() function reworked to use driver ops.
Version 6 contains entire rebased patch series. New patch 'move vidconsole_get_font_size() to test.h' added.
Version 5 contain minor changes: - move common functions to console-core.c file - remove static keyword from shared functions
In version 4, only first patch sent, because review fixes to this would add large rebase & patch formatting overhead. When it'll receive reviewed tag, I'll resent entire rebased series.
Modern mobile phones typically have high pixel density. Bootmenu is hardly readable on those with 8x16 font.
This patch series aims to add wider fonts for devices with high ppi.
Add 16x32, 12x22 fonts from linux, and allow font size configuration.
There was significant changes in version 2: - fix video tests failures - add runtime font size configuration - add test for 12x22 font
In version 3, 'video console: add select font logic to vidconsole uclass driver' patch was removed in favor of already merged patch 'video: Add font functions to the vidconsole API'
Dzmitry Sankouski (10): video console: refactoring and optimization video console: add support for fonts wider than 1 byte video console: move 8x16 font data in named header video console: implement multiple fonts configuration video console: move vidconsole_get_font_size() logic to driver ops video console: allow font size configuration at runtime video console: add 12x22 Sun font from linux video console: add 16x32 Terminus font from linux video console: sandbox_defconfig: add 12x22 font video console: add 12x22 console simple font test
cmd/Kconfig | 8 + cmd/Makefile | 2 +- cmd/font.c | 6 +- common/splash.c | 17 +- configs/sandbox_defconfig | 5 +- drivers/video/Kconfig | 30 + drivers/video/Makefile | 6 + drivers/video/console_core.c | 212 + drivers/video/console_normal.c | 177 +- drivers/video/console_rotate.c | 371 +- drivers/video/console_truetype.c | 3 +- drivers/video/vidconsole-uclass.c | 11 + drivers/video/vidconsole_internal.h | 120 + include/video_console.h | 14 +- include/video_font.h | 31 +- include/video_font_4x6.h | 11 +- include/video_font_8x16.h | 4624 ++++++++++++++++++++ include/video_font_data.h | 4644 +------------------- include/video_font_sun12x22.h | 6158 +++++++++++++++++++++++++++ include/video_font_ter16x32.h | 2062 +++++++++ test/cmd/font.c | 13 +- test/dm/video.c | 41 + 22 files changed, 13515 insertions(+), 5051 deletions(-) create mode 100644 drivers/video/console_core.c create mode 100644 drivers/video/vidconsole_internal.h create mode 100644 include/video_font_8x16.h create mode 100644 include/video_font_sun12x22.h create mode 100644 include/video_font_ter16x32.h
- move common code to vidconsole_internal.h and console_core.c - unite probe functions - get rid of code duplications in switch across bpp values - extract common pixel fill logic in two functions one per horizontal and vertical filling - rearrange statements in put_xy* methods in unified way - replace types - uint*_t to u*
Signed-off-by: Dzmitry Sankouski dsankouski@gmail.com Reviewed-by: Simon Glass sjg@chromium.org --- Changes for v2: none Changes for v3: none Changes for v4: - move common code to vidconsole_internal.h - unite probe functions Changes for v5: - move common functions to console-core.c file - remove static keyword from shared functions Changes for v6: none Changes for v7: none
drivers/video/Makefile | 6 + drivers/video/console_core.c | 141 +++++++++++++ drivers/video/console_normal.c | 150 ++++---------- drivers/video/console_rotate.c | 308 ++++------------------------ drivers/video/vidconsole_internal.h | 95 +++++++++ 5 files changed, 324 insertions(+), 376 deletions(-) create mode 100644 drivers/video/console_core.c create mode 100644 drivers/video/vidconsole_internal.h
diff --git a/drivers/video/Makefile b/drivers/video/Makefile index cdb7d9a54d..cb3f373645 100644 --- a/drivers/video/Makefile +++ b/drivers/video/Makefile @@ -9,6 +9,12 @@ obj-$(CONFIG_BACKLIGHT_GPIO) += backlight_gpio.o obj-$(CONFIG_BACKLIGHT_PWM) += pwm_backlight.o obj-$(CONFIG_CONSOLE_NORMAL) += console_normal.o obj-$(CONFIG_CONSOLE_ROTATION) += console_rotate.o +ifdef CONFIG_CONSOLE_NORMAL +obj-y += console_core.o +else ifdef CONFIG_CONSOLE_ROTATION +obj-y += console_core.o +endif +obj-$(CONFIG_CONSOLE_ROTATION) += console_core.o obj-$(CONFIG_CONSOLE_TRUETYPE) += console_truetype.o fonts/ obj-$(CONFIG_DISPLAY) += display-uclass.o obj-$(CONFIG_VIDEO_MIPI_DSI) += dsi-host-uclass.o diff --git a/drivers/video/console_core.c b/drivers/video/console_core.c new file mode 100644 index 0000000000..9c2e4cb4ea --- /dev/null +++ b/drivers/video/console_core.c @@ -0,0 +1,141 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (c) 2015 Google, Inc + * (C) Copyright 2015 + * Bernecker & Rainer Industrieelektronik GmbH - http://www.br-automation.com + * (C) Copyright 2023 Dzmitry Sankouski dsankouski@gmail.com + */ + +#include <video.h> +#include <video_console.h> +#include <dm.h> +#include "vidconsole_internal.h" + +int check_bpix_support(int bpix) +{ + if (bpix == VIDEO_BPP8 && IS_ENABLED(CONFIG_VIDEO_BPP8)) + return 0; + else if (bpix == VIDEO_BPP16 && IS_ENABLED(CONFIG_VIDEO_BPP16)) + return 0; + else if (bpix == VIDEO_BPP32 && IS_ENABLED(CONFIG_VIDEO_BPP32)) + return 0; + else + return -ENOSYS; +} + +inline void fill_pixel_and_goto_next(void **dstp, u32 value, int pbytes, int step) +{ + u8 *dst_byte = *dstp; + + if (pbytes == 4) { + u32 *dst = *dstp; + *dst = value; + } + if (pbytes == 2) { + u16 *dst = *dstp; + *dst = value; + } + if (pbytes == 1) { + u8 *dst = *dstp; + *dst = value; + } + *dstp = dst_byte + step; +} + +int fill_char_vertically(uchar *pfont, void **line, struct video_priv *vid_priv, + bool direction) +{ + int step, line_step, pbytes, ret; + void *dst; + + ret = check_bpix_support(vid_priv->bpix); + if (ret) + return ret; + + pbytes = VNBYTES(vid_priv->bpix); + if (direction) { + step = -pbytes; + line_step = -vid_priv->line_length; + } else { + step = pbytes; + line_step = vid_priv->line_length; + } + + for (int row = 0; row < VIDEO_FONT_HEIGHT; row++) { + dst = *line; + uchar bits = pfont[row]; + + for (int i = 0; i < VIDEO_FONT_WIDTH; i++) { + u32 value = (bits & 0x80) ? + vid_priv->colour_fg : + vid_priv->colour_bg; + + fill_pixel_and_goto_next(&dst, + value, + pbytes, + step + ); + bits <<= 1; + } + *line += line_step; + } + return ret; +} + +int fill_char_horizontally(uchar *pfont, void **line, struct video_priv *vid_priv, + bool direction) +{ + int step, line_step, pbytes, ret; + void *dst; + u8 mask = 0x80; + + ret = check_bpix_support(vid_priv->bpix); + if (ret) + return ret; + + pbytes = VNBYTES(vid_priv->bpix); + if (direction) { + step = -pbytes; + line_step = vid_priv->line_length; + } else { + step = pbytes; + line_step = -vid_priv->line_length; + } + for (int col = 0; col < VIDEO_FONT_WIDTH; col++) { + dst = *line; + for (int row = 0; row < VIDEO_FONT_HEIGHT; row++) { + u32 value = (pfont[row * VIDEO_FONT_BYTE_WIDTH] & mask) ? + vid_priv->colour_fg : + vid_priv->colour_bg; + + fill_pixel_and_goto_next(&dst, + value, + pbytes, + step + ); + } + *line += line_step; + mask >>= 1; + } + return ret; +} + +int console_probe(struct udevice *dev) +{ + struct vidconsole_priv *vc_priv = dev_get_uclass_priv(dev); + struct udevice *vid_dev = dev->parent; + struct video_priv *vid_priv = dev_get_uclass_priv(vid_dev); + + vc_priv->x_charsize = VIDEO_FONT_WIDTH; + vc_priv->y_charsize = VIDEO_FONT_HEIGHT; + if (vid_priv->rot % 2) { + vc_priv->cols = vid_priv->ysize / VIDEO_FONT_WIDTH; + vc_priv->rows = vid_priv->xsize / VIDEO_FONT_HEIGHT; + vc_priv->xsize_frac = VID_TO_POS(vid_priv->ysize); + } else { + vc_priv->cols = vid_priv->xsize / VIDEO_FONT_WIDTH; + vc_priv->rows = vid_priv->ysize / VIDEO_FONT_HEIGHT; + } + + return 0; +} diff --git a/drivers/video/console_normal.c b/drivers/video/console_normal.c index 04f022491e..57186bedd8 100644 --- a/drivers/video/console_normal.c +++ b/drivers/video/console_normal.c @@ -1,10 +1,9 @@ // SPDX-License-Identifier: GPL-2.0+ /* * Copyright (c) 2015 Google, Inc - * (C) Copyright 2001-2015 - * DENX Software Engineering -- wd@denx.de - * Compulab Ltd - http://compulab.co.il/ + * (C) Copyright 2015 * Bernecker & Rainer Industrieelektronik GmbH - http://www.br-automation.com + * (C) Copyright 2023 Dzmitry Sankouski dsankouski@gmail.com */
#include <common.h> @@ -12,47 +11,28 @@ #include <video.h> #include <video_console.h> #include <video_font.h> /* Get font data, width and height */ +#include "vidconsole_internal.h"
-static int console_normal_set_row(struct udevice *dev, uint row, int clr) +static int console_set_row(struct udevice *dev, uint row, int clr) { struct video_priv *vid_priv = dev_get_uclass_priv(dev->parent); - void *line, *end; + void *line, *dst, *end; int pixels = VIDEO_FONT_HEIGHT * vid_priv->xsize; int ret; int i; + int pbytes; + + ret = check_bpix_support(vid_priv->bpix); + if (ret) + return ret;
line = vid_priv->fb + row * VIDEO_FONT_HEIGHT * vid_priv->line_length; - switch (vid_priv->bpix) { - case VIDEO_BPP8: - if (IS_ENABLED(CONFIG_VIDEO_BPP8)) { - uint8_t *dst = line; - - for (i = 0; i < pixels; i++) - *dst++ = clr; - end = dst; - break; - } - case VIDEO_BPP16: - if (IS_ENABLED(CONFIG_VIDEO_BPP16)) { - uint16_t *dst = line; - - for (i = 0; i < pixels; i++) - *dst++ = clr; - end = dst; - break; - } - case VIDEO_BPP32: - if (IS_ENABLED(CONFIG_VIDEO_BPP32)) { - uint32_t *dst = line; - - for (i = 0; i < pixels; i++) - *dst++ = clr; - end = dst; - break; - } - default: - return -ENOSYS; - } + dst = line; + pbytes = VNBYTES(vid_priv->bpix); + for (i = 0; i < pixels; i++) + fill_pixel_and_goto_next(&dst, clr, pbytes, pbytes); + end = dst; + ret = vidconsole_sync_copy(dev, line, end); if (ret) return ret; @@ -60,8 +40,8 @@ static int console_normal_set_row(struct udevice *dev, uint row, int clr) return 0; }
-static int console_normal_move_rows(struct udevice *dev, uint rowdst, - uint rowsrc, uint count) +static int console_move_rows(struct udevice *dev, uint rowdst, + uint rowsrc, uint count) { struct video_priv *vid_priv = dev_get_uclass_priv(dev->parent); void *dst; @@ -79,70 +59,30 @@ static int console_normal_move_rows(struct udevice *dev, uint rowdst, return 0; }
-static int console_normal_putc_xy(struct udevice *dev, uint x_frac, uint y, - char ch) +static int console_putc_xy(struct udevice *dev, uint x_frac, uint y, char ch) { struct vidconsole_priv *vc_priv = dev_get_uclass_priv(dev); struct udevice *vid = dev->parent; struct video_priv *vid_priv = dev_get_uclass_priv(vid); - int i, row; - void *start; - void *line; - int ret; + int pbytes = VNBYTES(vid_priv->bpix); + int x, linenum, ret; + void *start, *line; + uchar *pfont = video_fontdata + (u8)ch * VIDEO_FONT_HEIGHT;
- start = vid_priv->fb + y * vid_priv->line_length + - VID_TO_PIXEL(x_frac) * VNBYTES(vid_priv->bpix); + if (x_frac + VID_TO_POS(vc_priv->x_charsize) > vc_priv->xsize_frac) + return -EAGAIN; + linenum = y; + x = VID_TO_PIXEL(x_frac); + start = vid_priv->fb + linenum * vid_priv->line_length + x * pbytes; line = start;
if (x_frac + VID_TO_POS(vc_priv->x_charsize) > vc_priv->xsize_frac) return -EAGAIN;
- for (row = 0; row < VIDEO_FONT_HEIGHT; row++) { - unsigned int idx = (u8)ch * VIDEO_FONT_HEIGHT + row; - uchar bits = video_fontdata[idx]; - - switch (vid_priv->bpix) { - case VIDEO_BPP8: - if (IS_ENABLED(CONFIG_VIDEO_BPP8)) { - uint8_t *dst = line; - - for (i = 0; i < VIDEO_FONT_WIDTH; i++) { - *dst++ = (bits & 0x80) ? - vid_priv->colour_fg : - vid_priv->colour_bg; - bits <<= 1; - } - break; - } - case VIDEO_BPP16: - if (IS_ENABLED(CONFIG_VIDEO_BPP16)) { - uint16_t *dst = line; - - for (i = 0; i < VIDEO_FONT_WIDTH; i++) { - *dst++ = (bits & 0x80) ? - vid_priv->colour_fg : - vid_priv->colour_bg; - bits <<= 1; - } - break; - } - case VIDEO_BPP32: - if (IS_ENABLED(CONFIG_VIDEO_BPP32)) { - uint32_t *dst = line; - - for (i = 0; i < VIDEO_FONT_WIDTH; i++) { - *dst++ = (bits & 0x80) ? - vid_priv->colour_fg : - vid_priv->colour_bg; - bits <<= 1; - } - break; - } - default: - return -ENOSYS; - } - line += vid_priv->line_length; - } + ret = fill_char_vertically(pfont, &line, vid_priv, NORMAL_DIRECTION); + if (ret) + return ret; + ret = vidconsole_sync_copy(dev, start, line); if (ret) return ret; @@ -150,29 +90,15 @@ static int console_normal_putc_xy(struct udevice *dev, uint x_frac, uint y, return VID_TO_POS(VIDEO_FONT_WIDTH); }
-static int console_normal_probe(struct udevice *dev) -{ - struct vidconsole_priv *vc_priv = dev_get_uclass_priv(dev); - struct udevice *vid_dev = dev->parent; - struct video_priv *vid_priv = dev_get_uclass_priv(vid_dev); - - vc_priv->x_charsize = VIDEO_FONT_WIDTH; - vc_priv->y_charsize = VIDEO_FONT_HEIGHT; - vc_priv->cols = vid_priv->xsize / VIDEO_FONT_WIDTH; - vc_priv->rows = vid_priv->ysize / VIDEO_FONT_HEIGHT; - - return 0; -} - -struct vidconsole_ops console_normal_ops = { - .putc_xy = console_normal_putc_xy, - .move_rows = console_normal_move_rows, - .set_row = console_normal_set_row, +struct vidconsole_ops console_ops = { + .putc_xy = console_putc_xy, + .move_rows = console_move_rows, + .set_row = console_set_row, };
U_BOOT_DRIVER(vidconsole_normal) = { .name = "vidconsole0", .id = UCLASS_VIDEO_CONSOLE, - .ops = &console_normal_ops, - .probe = console_normal_probe, + .ops = &console_ops, + .probe = console_probe, }; diff --git a/drivers/video/console_rotate.c b/drivers/video/console_rotate.c index 36c8d0609d..70cc62d178 100644 --- a/drivers/video/console_rotate.c +++ b/drivers/video/console_rotate.c @@ -3,6 +3,7 @@ * Copyright (c) 2015 Google, Inc * (C) Copyright 2015 * Bernecker & Rainer Industrieelektronik GmbH - http://www.br-automation.com + * (C) Copyright 2023 Dzmitry Sankouski dsankouski@gmail.com */
#include <common.h> @@ -10,12 +11,13 @@ #include <video.h> #include <video_console.h> #include <video_font.h> /* Get font data, width and height */ +#include "vidconsole_internal.h"
static int console_set_row_1(struct udevice *dev, uint row, int clr) { struct video_priv *vid_priv = dev_get_uclass_priv(dev->parent); int pbytes = VNBYTES(vid_priv->bpix); - void *start, *line; + void *start, *dst, *line; int i, j; int ret;
@@ -23,34 +25,9 @@ static int console_set_row_1(struct udevice *dev, uint row, int clr) (row + 1) * VIDEO_FONT_HEIGHT * pbytes; line = start; for (j = 0; j < vid_priv->ysize; j++) { - switch (vid_priv->bpix) { - case VIDEO_BPP8: - if (IS_ENABLED(CONFIG_VIDEO_BPP8)) { - uint8_t *dst = line; - - for (i = 0; i < VIDEO_FONT_HEIGHT; i++) - *dst++ = clr; - break; - } - case VIDEO_BPP16: - if (IS_ENABLED(CONFIG_VIDEO_BPP16)) { - uint16_t *dst = line; - - for (i = 0; i < VIDEO_FONT_HEIGHT; i++) - *dst++ = clr; - break; - } - case VIDEO_BPP32: - if (IS_ENABLED(CONFIG_VIDEO_BPP32)) { - uint32_t *dst = line; - - for (i = 0; i < VIDEO_FONT_HEIGHT; i++) - *dst++ = clr; - break; - } - default: - return -ENOSYS; - } + dst = line; + for (i = 0; i < VIDEO_FONT_HEIGHT; i++) + fill_pixel_and_goto_next(&dst, clr, pbytes, pbytes); line += vid_priv->line_length; } ret = vidconsole_sync_copy(dev, start, line); @@ -61,7 +38,7 @@ static int console_set_row_1(struct udevice *dev, uint row, int clr) }
static int console_move_rows_1(struct udevice *dev, uint rowdst, uint rowsrc, - uint count) + uint count) { struct video_priv *vid_priv = dev_get_uclass_priv(dev->parent); int pbytes = VNBYTES(vid_priv->bpix); @@ -76,7 +53,7 @@ static int console_move_rows_1(struct udevice *dev, uint rowdst, uint rowsrc,
for (j = 0; j < vid_priv->ysize; j++) { ret = vidconsole_memmove(dev, dst, src, - VIDEO_FONT_HEIGHT * pbytes * count); + VIDEO_FONT_HEIGHT * pbytes * count); if (ret) return ret; src += vid_priv->line_length; @@ -91,60 +68,22 @@ static int console_putc_xy_1(struct udevice *dev, uint x_frac, uint y, char ch) struct vidconsole_priv *vc_priv = dev_get_uclass_priv(dev); struct udevice *vid = dev->parent; struct video_priv *vid_priv = dev_get_uclass_priv(vid); - uchar *pfont = video_fontdata + (u8)ch * VIDEO_FONT_HEIGHT; int pbytes = VNBYTES(vid_priv->bpix); - int i, col, x, linenum, ret; - int mask = 0x80; + int x, linenum, ret; void *start, *line; + uchar *pfont = video_fontdata + (u8)ch * VIDEO_FONT_HEIGHT;
+ if (x_frac + VID_TO_POS(vc_priv->x_charsize) > vc_priv->xsize_frac) + return -EAGAIN; linenum = VID_TO_PIXEL(x_frac) + 1; x = y + 1; start = vid_priv->fb + linenum * vid_priv->line_length - x * pbytes; line = start; - if (x_frac + VID_TO_POS(vc_priv->x_charsize) > vc_priv->xsize_frac) - return -EAGAIN;
- for (col = 0; col < VIDEO_FONT_HEIGHT; col++) { - switch (vid_priv->bpix) { - case VIDEO_BPP8: - if (IS_ENABLED(CONFIG_VIDEO_BPP8)) { - uint8_t *dst = line; - - for (i = 0; i < VIDEO_FONT_HEIGHT; i++) { - *dst-- = (pfont[i] & mask) ? - vid_priv->colour_fg : - vid_priv->colour_bg; - } - break; - } - case VIDEO_BPP16: - if (IS_ENABLED(CONFIG_VIDEO_BPP16)) { - uint16_t *dst = line; - - for (i = 0; i < VIDEO_FONT_HEIGHT; i++) { - *dst-- = (pfont[i] & mask) ? - vid_priv->colour_fg : - vid_priv->colour_bg; - } - break; - } - case VIDEO_BPP32: - if (IS_ENABLED(CONFIG_VIDEO_BPP32)) { - uint32_t *dst = line; - - for (i = 0; i < VIDEO_FONT_HEIGHT; i++) { - *dst-- = (pfont[i] & mask) ? - vid_priv->colour_fg : - vid_priv->colour_bg; - } - break; - } - default: - return -ENOSYS; - } - line += vid_priv->line_length; - mask >>= 1; - } + ret = fill_char_horizontally(pfont, &line, vid_priv, FLIPPED_DIRECTION); + if (ret) + return ret; + /* We draw backwards from 'start, so account for the first line */ ret = vidconsole_sync_copy(dev, start - vid_priv->line_length, line); if (ret) @@ -157,44 +96,18 @@ static int console_putc_xy_1(struct udevice *dev, uint x_frac, uint y, char ch) static int console_set_row_2(struct udevice *dev, uint row, int clr) { struct video_priv *vid_priv = dev_get_uclass_priv(dev->parent); - void *start, *line, *end; + void *start, *line, *dst, *end; int pixels = VIDEO_FONT_HEIGHT * vid_priv->xsize; int i, ret; + int pbytes = VNBYTES(vid_priv->bpix);
start = vid_priv->fb + vid_priv->ysize * vid_priv->line_length - (row + 1) * VIDEO_FONT_HEIGHT * vid_priv->line_length; line = start; - switch (vid_priv->bpix) { - case VIDEO_BPP8: - if (IS_ENABLED(CONFIG_VIDEO_BPP8)) { - uint8_t *dst = line; - - for (i = 0; i < pixels; i++) - *dst++ = clr; - end = dst; - break; - } - case VIDEO_BPP16: - if (IS_ENABLED(CONFIG_VIDEO_BPP16)) { - uint16_t *dst = line; - - for (i = 0; i < pixels; i++) - *dst++ = clr; - end = dst; - break; - } - case VIDEO_BPP32: - if (IS_ENABLED(CONFIG_VIDEO_BPP32)) { - uint32_t *dst = line; - - for (i = 0; i < pixels; i++) - *dst++ = clr; - end = dst; - break; - } - default: - return -ENOSYS; - } + dst = line; + for (i = 0; i < pixels; i++) + fill_pixel_and_goto_next(&dst, clr, pbytes, pbytes); + end = dst; ret = vidconsole_sync_copy(dev, start, end); if (ret) return ret; @@ -227,8 +140,9 @@ static int console_putc_xy_2(struct udevice *dev, uint x_frac, uint y, char ch) struct udevice *vid = dev->parent; struct video_priv *vid_priv = dev_get_uclass_priv(vid); int pbytes = VNBYTES(vid_priv->bpix); - int i, row, x, linenum, ret; + int linenum, x, ret; void *start, *line; + uchar *pfont = video_fontdata + (u8)ch * VIDEO_FONT_HEIGHT;
if (x_frac + VID_TO_POS(vc_priv->x_charsize) > vc_priv->xsize_frac) return -EAGAIN; @@ -237,52 +151,10 @@ static int console_putc_xy_2(struct udevice *dev, uint x_frac, uint y, char ch) start = vid_priv->fb + linenum * vid_priv->line_length + x * pbytes; line = start;
- for (row = 0; row < VIDEO_FONT_HEIGHT; row++) { - unsigned int idx = (u8)ch * VIDEO_FONT_HEIGHT + row; - uchar bits = video_fontdata[idx]; - - switch (vid_priv->bpix) { - case VIDEO_BPP8: - if (IS_ENABLED(CONFIG_VIDEO_BPP8)) { - uint8_t *dst = line; - - for (i = 0; i < VIDEO_FONT_WIDTH; i++) { - *dst-- = (bits & 0x80) ? - vid_priv->colour_fg : - vid_priv->colour_bg; - bits <<= 1; - } - break; - } - case VIDEO_BPP16: - if (IS_ENABLED(CONFIG_VIDEO_BPP16)) { - uint16_t *dst = line; - - for (i = 0; i < VIDEO_FONT_WIDTH; i++) { - *dst-- = (bits & 0x80) ? - vid_priv->colour_fg : - vid_priv->colour_bg; - bits <<= 1; - } - break; - } - case VIDEO_BPP32: - if (IS_ENABLED(CONFIG_VIDEO_BPP32)) { - uint32_t *dst = line; - - for (i = 0; i < VIDEO_FONT_WIDTH; i++) { - *dst-- = (bits & 0x80) ? - vid_priv->colour_fg : - vid_priv->colour_bg; - bits <<= 1; - } - break; - } - default: - return -ENOSYS; - } - line -= vid_priv->line_length; - } + ret = fill_char_vertically(pfont, &line, vid_priv, FLIPPED_DIRECTION); + if (ret) + return ret; + /* Add 4 bytes to allow for the first pixel writen */ ret = vidconsole_sync_copy(dev, start + 4, line); if (ret) @@ -295,40 +167,15 @@ static int console_set_row_3(struct udevice *dev, uint row, int clr) { struct video_priv *vid_priv = dev_get_uclass_priv(dev->parent); int pbytes = VNBYTES(vid_priv->bpix); - void *start, *line; + void *start, *dst, *line; int i, j, ret;
start = vid_priv->fb + row * VIDEO_FONT_HEIGHT * pbytes; line = start; for (j = 0; j < vid_priv->ysize; j++) { - switch (vid_priv->bpix) { - case VIDEO_BPP8: - if (IS_ENABLED(CONFIG_VIDEO_BPP8)) { - uint8_t *dst = line; - - for (i = 0; i < VIDEO_FONT_HEIGHT; i++) - *dst++ = clr; - break; - } - case VIDEO_BPP16: - if (IS_ENABLED(CONFIG_VIDEO_BPP16)) { - uint16_t *dst = line; - - for (i = 0; i < VIDEO_FONT_HEIGHT; i++) - *dst++ = clr; - break; - } - case VIDEO_BPP32: - if (IS_ENABLED(CONFIG_VIDEO_BPP32)) { - uint32_t *dst = line; - - for (i = 0; i < VIDEO_FONT_HEIGHT; i++) - *dst++ = clr; - break; - } - default: - return -ENOSYS; - } + dst = line; + for (i = 0; i < VIDEO_FONT_HEIGHT; i++) + fill_pixel_and_goto_next(&dst, clr, pbytes, pbytes); line += vid_priv->line_length; } ret = vidconsole_sync_copy(dev, start, line); @@ -367,58 +214,21 @@ static int console_putc_xy_3(struct udevice *dev, uint x_frac, uint y, char ch) struct vidconsole_priv *vc_priv = dev_get_uclass_priv(dev); struct udevice *vid = dev->parent; struct video_priv *vid_priv = dev_get_uclass_priv(vid); - uchar *pfont = video_fontdata + (u8)ch * VIDEO_FONT_HEIGHT; int pbytes = VNBYTES(vid_priv->bpix); - int i, col, x, ret; - int mask = 0x80; + int linenum, x, ret; void *start, *line; + uchar *pfont = video_fontdata + (u8)ch * VIDEO_FONT_HEIGHT;
if (x_frac + VID_TO_POS(vc_priv->x_charsize) > vc_priv->xsize_frac) return -EAGAIN; - x = vid_priv->ysize - VID_TO_PIXEL(x_frac) - 1; - start = vid_priv->fb + x * vid_priv->line_length + y * pbytes; + x = y; + linenum = vid_priv->ysize - VID_TO_PIXEL(x_frac) - 1; + start = vid_priv->fb + linenum * vid_priv->line_length + y * pbytes; line = start; - for (col = 0; col < VIDEO_FONT_HEIGHT; col++) { - switch (vid_priv->bpix) { - case VIDEO_BPP8: - if (IS_ENABLED(CONFIG_VIDEO_BPP8)) { - uint8_t *dst = line; - - for (i = 0; i < VIDEO_FONT_HEIGHT; i++) { - *dst++ = (pfont[i] & mask) ? - vid_priv->colour_fg : - vid_priv->colour_bg; - } - break; - } - case VIDEO_BPP16: - if (IS_ENABLED(CONFIG_VIDEO_BPP16)) { - uint16_t *dst = line; - - for (i = 0; i < VIDEO_FONT_HEIGHT; i++) { - *dst++ = (pfont[i] & mask) ? - vid_priv->colour_fg : - vid_priv->colour_bg; - } - break; - } - case VIDEO_BPP32: - if (IS_ENABLED(CONFIG_VIDEO_BPP32)) { - uint32_t *dst = line; - - for (i = 0; i < VIDEO_FONT_HEIGHT; i++) { - *dst++ = (pfont[i] & mask) ? - vid_priv->colour_fg : - vid_priv->colour_bg; - } - break; - } - default: - return -ENOSYS; - } - line -= vid_priv->line_length; - mask >>= 1; - } + + ret = fill_char_horizontally(pfont, &line, vid_priv, NORMAL_DIRECTION); + if (ret) + return ret; /* Add a line to allow for the first pixels writen */ ret = vidconsole_sync_copy(dev, start + vid_priv->line_length, line); if (ret) @@ -427,36 +237,6 @@ static int console_putc_xy_3(struct udevice *dev, uint x_frac, uint y, char ch) return VID_TO_POS(VIDEO_FONT_WIDTH); }
- -static int console_probe_2(struct udevice *dev) -{ - struct vidconsole_priv *vc_priv = dev_get_uclass_priv(dev); - struct udevice *vid_dev = dev->parent; - struct video_priv *vid_priv = dev_get_uclass_priv(vid_dev); - - vc_priv->x_charsize = VIDEO_FONT_WIDTH; - vc_priv->y_charsize = VIDEO_FONT_HEIGHT; - vc_priv->cols = vid_priv->xsize / VIDEO_FONT_WIDTH; - vc_priv->rows = vid_priv->ysize / VIDEO_FONT_HEIGHT; - - return 0; -} - -static int console_probe_1_3(struct udevice *dev) -{ - struct vidconsole_priv *vc_priv = dev_get_uclass_priv(dev); - struct udevice *vid_dev = dev->parent; - struct video_priv *vid_priv = dev_get_uclass_priv(vid_dev); - - vc_priv->x_charsize = VIDEO_FONT_WIDTH; - vc_priv->y_charsize = VIDEO_FONT_HEIGHT; - vc_priv->cols = vid_priv->ysize / VIDEO_FONT_WIDTH; - vc_priv->rows = vid_priv->xsize / VIDEO_FONT_HEIGHT; - vc_priv->xsize_frac = VID_TO_POS(vid_priv->ysize); - - return 0; -} - struct vidconsole_ops console_ops_1 = { .putc_xy = console_putc_xy_1, .move_rows = console_move_rows_1, @@ -479,19 +259,19 @@ U_BOOT_DRIVER(vidconsole_1) = { .name = "vidconsole1", .id = UCLASS_VIDEO_CONSOLE, .ops = &console_ops_1, - .probe = console_probe_1_3, + .probe = console_probe, };
U_BOOT_DRIVER(vidconsole_2) = { .name = "vidconsole2", .id = UCLASS_VIDEO_CONSOLE, .ops = &console_ops_2, - .probe = console_probe_2, + .probe = console_probe, };
U_BOOT_DRIVER(vidconsole_3) = { .name = "vidconsole3", .id = UCLASS_VIDEO_CONSOLE, .ops = &console_ops_3, - .probe = console_probe_1_3, + .probe = console_probe, }; diff --git a/drivers/video/vidconsole_internal.h b/drivers/video/vidconsole_internal.h new file mode 100644 index 0000000000..0dfcd402c5 --- /dev/null +++ b/drivers/video/vidconsole_internal.h @@ -0,0 +1,95 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (c) 2015 Google, Inc + * (C) Copyright 2015 + * Bernecker & Rainer Industrieelektronik GmbH - http://www.br-automation.com + * (C) Copyright 2023 Dzmitry Sankouski dsankouski@gmail.com + */ + +#include <video_font.h> /* Get font data, width and height */ + +#define VIDEO_FONT_BYTE_WIDTH ((VIDEO_FONT_WIDTH / 8) + (VIDEO_FONT_WIDTH % 8 > 0)) + +#define FLIPPED_DIRECTION 1 +#define NORMAL_DIRECTION 0 + +/** + * Checks if bits per pixel supported. + * + * @param bpix framebuffer bits per pixel. + * + * @returns 0, if supported, or else -ENOSYS. + */ +int check_bpix_support(int bpix); + +/** + * Fill 1 pixel in framebuffer, and go to next one. + * + * @param dstp a pointer to pointer to framebuffer. + * @param value value to write to framebuffer. + * @param pbytes framebuffer bytes per pixel. + * @param step framebuffer pointer increment. Usually is equal to pbytes, + * and may be negative to control filling direction. + */ +void fill_pixel_and_goto_next(void **dstp, u32 value, int pbytes, int step); + +/** + * Fills 1 character in framebuffer vertically. Vertically means we're filling char font data rows + * across the lines. + * + * @param pfont a pointer to character font data. + * @param line a pointer to pointer to framebuffer. It's a point for upper left char corner + * @param vid_priv driver private data. + * @param direction controls character orientation. Can be normal or flipped. + * When normal: When flipped: + *|-----------------------------------------------| + *| line stepping | | + *| | | stepping -> | + *| * | | * * * | + *| * * v | * | + *| * | * | + *| * | * * ^ | + *| * * * | * | | + *| | | | + *| stepping -> | line stepping | + *|---!!we're starting from upper left char corner| + *|-----------------------------------------------| + * + * @returns 0, if success, or else error code. + */ +int fill_char_vertically(uchar *pfont, void **line, struct video_priv *vid_priv, + bool direction); + +/** + * Fills 1 character in framebuffer horizontally. + * Horizontally means we're filling char font data columns across the lines. + * + * @param pfont a pointer to character font data. + * @param line a pointer to pointer to framebuffer. It's a point for upper left char corner + * @param vid_priv driver private data. + * @param direction controls character orientation. Can be normal or flipped. + * When normal: When flipped: + *|-----------------------------------------------| + *| * | line stepping | + *| ^ * * * * * | | | + *| | * * | v * * | + *| | | * * * * * | + *| line stepping | * | + *| | | + *| stepping -> | <- stepping | + *|---!!we're starting from upper left char corner| + *|-----------------------------------------------| + * + * @returns 0, if success, or else error code. + */ +int fill_char_horizontally(uchar *pfont, void **line, struct video_priv *vid_priv, + bool direction); + +/** + * console probe function. + * + * @param dev a pointer to device. + * + * @returns 0, if success, or else error code. + */ +int console_probe(struct udevice *dev);
Hi Dzmitry,
On Mon, 27 Feb 2023 20:37:01 +0300 Dzmitry Sankouski dsankouski@gmail.com wrote:
Changes for v5:
Building console_core.c fails for board configs without CONFIG_VIDEO_COPY, i.e.:
https://source.denx.de/u-boot/custodians/u-boot-video/-/jobs/587261
I fixed it for further build testing by additionally applying:
diff --git a/include/video_console.h b/include/video_console.h index 9d2c0f210e..3e1e00c23f 100644 --- a/include/video_console.h +++ b/include/video_console.h @@ -340,6 +340,9 @@ int vidconsole_sync_copy(struct udevice *dev, void *from, void *to); int vidconsole_memmove(struct udevice *dev, void *dst, const void *src, int size); #else + +#include <string.h> + static inline int vidconsole_sync_copy(struct udevice *dev, void *from, void *to) {
-- Anatolij
Devices with high ppi may benefit from wider fonts.
Current width implementation is limited by 1 byte, i.e. 8 bits. New version iterates VIDEO_FONT_BYTE_WIDTH times, to process all width bytes, thus allowing fonts wider than 1 byte.
Signed-off-by: Dzmitry Sankouski dsankouski@gmail.com Reviewed-by: Simon Glass sjg@chromium.org --- Charges for v2: - replace TAIL_BIT_COUNT macro with c code - rename refactoring Charges for v3: none Charges for v4: N/A Charges for v5: N/A Charges for v6: rebase only Charges for v7: none
drivers/video/console_core.c | 84 ++++++++++++++++++----------- drivers/video/console_normal.c | 2 +- drivers/video/console_rotate.c | 6 +-- drivers/video/vidconsole_internal.h | 1 + 4 files changed, 59 insertions(+), 34 deletions(-)
diff --git a/drivers/video/console_core.c b/drivers/video/console_core.c index 9c2e4cb4ea..de004f585c 100644 --- a/drivers/video/console_core.c +++ b/drivers/video/console_core.c @@ -45,7 +45,7 @@ inline void fill_pixel_and_goto_next(void **dstp, u32 value, int pbytes, int ste int fill_char_vertically(uchar *pfont, void **line, struct video_priv *vid_priv, bool direction) { - int step, line_step, pbytes, ret; + int step, line_step, pbytes, bitcount, width_remainder, ret; void *dst;
ret = check_bpix_support(vid_priv->bpix); @@ -61,23 +61,36 @@ int fill_char_vertically(uchar *pfont, void **line, struct video_priv *vid_priv, line_step = vid_priv->line_length; }
+ width_remainder = VIDEO_FONT_WIDTH % 8; for (int row = 0; row < VIDEO_FONT_HEIGHT; row++) { + uchar bits; + + bitcount = 8; dst = *line; - uchar bits = pfont[row]; - - for (int i = 0; i < VIDEO_FONT_WIDTH; i++) { - u32 value = (bits & 0x80) ? - vid_priv->colour_fg : - vid_priv->colour_bg; - - fill_pixel_and_goto_next(&dst, - value, - pbytes, - step - ); - bits <<= 1; + for (int col = 0; col < VIDEO_FONT_BYTE_WIDTH; col++) { + if (width_remainder) { + bool is_last_iteration = (VIDEO_FONT_BYTE_WIDTH - col == 1); + + if (is_last_iteration) + bitcount = width_remainder; + } + bits = pfont[col]; + + for (int bit = 0; bit < bitcount; bit++) { + u32 value = (bits & 0x80) ? + vid_priv->colour_fg : + vid_priv->colour_bg; + + fill_pixel_and_goto_next(&dst, + value, + pbytes, + step + ); + bits <<= 1; + } } *line += line_step; + pfont += VIDEO_FONT_BYTE_WIDTH; } return ret; } @@ -85,9 +98,9 @@ int fill_char_vertically(uchar *pfont, void **line, struct video_priv *vid_priv, int fill_char_horizontally(uchar *pfont, void **line, struct video_priv *vid_priv, bool direction) { - int step, line_step, pbytes, ret; + int step, line_step, pbytes, bitcount = 8, width_remainder, ret; void *dst; - u8 mask = 0x80; + u8 mask;
ret = check_bpix_support(vid_priv->bpix); if (ret) @@ -101,21 +114,32 @@ int fill_char_horizontally(uchar *pfont, void **line, struct video_priv *vid_pri step = pbytes; line_step = -vid_priv->line_length; } - for (int col = 0; col < VIDEO_FONT_WIDTH; col++) { - dst = *line; - for (int row = 0; row < VIDEO_FONT_HEIGHT; row++) { - u32 value = (pfont[row * VIDEO_FONT_BYTE_WIDTH] & mask) ? - vid_priv->colour_fg : - vid_priv->colour_bg; - - fill_pixel_and_goto_next(&dst, - value, - pbytes, - step - ); + + width_remainder = VIDEO_FONT_WIDTH % 8; + for (int col = 0; col < VIDEO_FONT_BYTE_WIDTH; col++) { + mask = 0x80; + if (width_remainder) { + bool is_last_iteration = (VIDEO_FONT_BYTE_WIDTH - col == 1); + + if (is_last_iteration) + bitcount = width_remainder; + } + for (int bit = 0; bit < bitcount; bit++) { + dst = *line; + for (int row = 0; row < VIDEO_FONT_HEIGHT; row++) { + u32 value = (pfont[row * VIDEO_FONT_BYTE_WIDTH] & mask) ? + vid_priv->colour_fg : + vid_priv->colour_bg; + + fill_pixel_and_goto_next(&dst, + value, + pbytes, + step + ); + } + *line += line_step; + mask >>= 1; } - *line += line_step; - mask >>= 1; } return ret; } diff --git a/drivers/video/console_normal.c b/drivers/video/console_normal.c index 57186bedd8..e499e64852 100644 --- a/drivers/video/console_normal.c +++ b/drivers/video/console_normal.c @@ -67,7 +67,7 @@ static int console_putc_xy(struct udevice *dev, uint x_frac, uint y, char ch) int pbytes = VNBYTES(vid_priv->bpix); int x, linenum, ret; void *start, *line; - uchar *pfont = video_fontdata + (u8)ch * VIDEO_FONT_HEIGHT; + uchar *pfont = video_fontdata + (u8)ch * VIDEO_FONT_CHAR_PIXEL_BYTES;
if (x_frac + VID_TO_POS(vc_priv->x_charsize) > vc_priv->xsize_frac) return -EAGAIN; diff --git a/drivers/video/console_rotate.c b/drivers/video/console_rotate.c index 70cc62d178..64e2f12c2f 100644 --- a/drivers/video/console_rotate.c +++ b/drivers/video/console_rotate.c @@ -71,7 +71,7 @@ static int console_putc_xy_1(struct udevice *dev, uint x_frac, uint y, char ch) int pbytes = VNBYTES(vid_priv->bpix); int x, linenum, ret; void *start, *line; - uchar *pfont = video_fontdata + (u8)ch * VIDEO_FONT_HEIGHT; + uchar *pfont = video_fontdata + (u8)ch * VIDEO_FONT_CHAR_PIXEL_BYTES;
if (x_frac + VID_TO_POS(vc_priv->x_charsize) > vc_priv->xsize_frac) return -EAGAIN; @@ -142,7 +142,7 @@ static int console_putc_xy_2(struct udevice *dev, uint x_frac, uint y, char ch) int pbytes = VNBYTES(vid_priv->bpix); int linenum, x, ret; void *start, *line; - uchar *pfont = video_fontdata + (u8)ch * VIDEO_FONT_HEIGHT; + uchar *pfont = video_fontdata + (u8)ch * VIDEO_FONT_CHAR_PIXEL_BYTES;
if (x_frac + VID_TO_POS(vc_priv->x_charsize) > vc_priv->xsize_frac) return -EAGAIN; @@ -217,7 +217,7 @@ static int console_putc_xy_3(struct udevice *dev, uint x_frac, uint y, char ch) int pbytes = VNBYTES(vid_priv->bpix); int linenum, x, ret; void *start, *line; - uchar *pfont = video_fontdata + (u8)ch * VIDEO_FONT_HEIGHT; + uchar *pfont = video_fontdata + (u8)ch * VIDEO_FONT_CHAR_PIXEL_BYTES;
if (x_frac + VID_TO_POS(vc_priv->x_charsize) > vc_priv->xsize_frac) return -EAGAIN; diff --git a/drivers/video/vidconsole_internal.h b/drivers/video/vidconsole_internal.h index 0dfcd402c5..c7bc387035 100644 --- a/drivers/video/vidconsole_internal.h +++ b/drivers/video/vidconsole_internal.h @@ -9,6 +9,7 @@ #include <video_font.h> /* Get font data, width and height */
#define VIDEO_FONT_BYTE_WIDTH ((VIDEO_FONT_WIDTH / 8) + (VIDEO_FONT_WIDTH % 8 > 0)) +#define VIDEO_FONT_CHAR_PIXEL_BYTES (VIDEO_FONT_HEIGHT * VIDEO_FONT_BYTE_WIDTH)
#define FLIPPED_DIRECTION 1 #define NORMAL_DIRECTION 0
Consistent font data header names needed to add new fonts.
Signed-off-by: Dzmitry Sankouski dsankouski@gmail.com Reviewed-by: Simon Glass sjg@chromium.org --- Changes for v2: N/A Changes for v3: N/A Charges for v4: N/A Charges for v5: N/A Charges for v6: rebase only Charges for v7: none
include/video_font.h | 2 +- include/{video_font_data.h => video_font_8x16.h} | 5 ++--- 2 files changed, 3 insertions(+), 4 deletions(-) rename include/{video_font_data.h => video_font_8x16.h} (99%)
diff --git a/include/video_font.h b/include/video_font.h index 5e23f70f85..b07c07662c 100644 --- a/include/video_font.h +++ b/include/video_font.h @@ -10,7 +10,7 @@ #ifdef CONFIG_VIDEO_FONT_4X6 #include <video_font_4x6.h> #else -#include <video_font_data.h> +#include <video_font_8x16.h> #endif
#endif /* _VIDEO_FONT_ */ diff --git a/include/video_font_data.h b/include/video_font_8x16.h similarity index 99% rename from include/video_font_data.h rename to include/video_font_8x16.h index 6e64198d1a..d3d4295032 100644 --- a/include/video_font_data.h +++ b/include/video_font_8x16.h @@ -6,8 +6,8 @@ * This file contains an 8x16 bitmap font for code page 437. */
-#ifndef _VIDEO_FONT_DATA_ -#define _VIDEO_FONT_DATA_ +#ifndef _VIDEO_FONT_8X16 +#define _VIDEO_FONT_8X16
#define VIDEO_FONT_CHARS 256 #define VIDEO_FONT_WIDTH 8 @@ -4623,7 +4623,6 @@ static unsigned char __maybe_unused video_fontdata[VIDEO_FONT_SIZE] = { 0x00, /* 00000000 */ 0x00, /* 00000000 */ 0x00, /* 00000000 */ - };
#endif
This needed for unit testing different fonts.
Configured fonts are placed in an array of fonts. First font is selected by default upon console probe.
Signed-off-by: Dzmitry Sankouski dsankouski@gmail.com Reviewed-by: Simon Glass sjg@chromium.org --- Changes for v2: N/A Changes for v3: N/A Charges for v4: N/A Charges for v5: N/A Charges for v6: rebase only Charges for v7: - place 8x16 font first in list as default - &fonts[0] - fonts
common/splash.c | 17 +++--- drivers/video/Kconfig | 15 ++++++ drivers/video/console_core.c | 81 +++++++++++++++++------------ drivers/video/console_normal.c | 32 +++++++----- drivers/video/console_rotate.c | 72 ++++++++++++++++--------- drivers/video/vidconsole_internal.h | 20 ++++--- include/video_font.h | 17 +++++- include/video_font_4x6.h | 11 ++-- include/video_font_8x16.h | 8 +-- include/video_font_data.h | 31 +++++++++++ 10 files changed, 207 insertions(+), 97 deletions(-) create mode 100644 include/video_font_data.h
diff --git a/common/splash.c b/common/splash.c index 245ff680eb..1cd9afae2d 100644 --- a/common/splash.c +++ b/common/splash.c @@ -127,6 +127,7 @@ void splash_get_pos(int *x, int *y) #include <dm.h> #include <video_console.h> #include <video_font.h> +#include <video_font_data.h>
void splash_display_banner(void) { @@ -138,13 +139,15 @@ void splash_display_banner(void) if (ret) return;
-#ifdef CONFIG_VIDEO_LOGO - col = BMP_LOGO_WIDTH / VIDEO_FONT_WIDTH + 1; - row = BMP_LOGO_HEIGHT / VIDEO_FONT_HEIGHT + 1; -#else - col = 0; - row = 0; -#endif + if (IS_ENABLED(CONFIG_VIDEO_LOGO)) { + struct video_fontdata *fontdata = fonts; + + col = BMP_LOGO_WIDTH / fontdata->width + 1; + row = BMP_LOGO_HEIGHT / fontdata->height + 1; + } else { + col = 0; + row = 0; + }
display_options_get_banner(false, buf, sizeof(buf)); vidconsole_position_cursor(dev, col, 1); diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index 2a76d19cc8..ce97eb4727 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -16,6 +16,21 @@ config VIDEO
if VIDEO
+config VIDEO_FONT_4X6 + bool "4 x 6 font size" + help + Font for video console driver, 4 x 6 pixels. + Provides character bitmap data in header file. + When selecting multiple fonts, you may want to enable CMD_SELECT_FONT too. + +config VIDEO_FONT_8X16 + bool "8 x 16 font size" + default y + help + Font for video console driver, 8 x 16 pixels + Provides character bitmap data in header file. + When selecting multiple fonts, you may want to enable CMD_SELECT_FONT too. + config VIDEO_LOGO bool "Show the U-Boot logo on the display" default y if !SPLASH_SCREEN diff --git a/drivers/video/console_core.c b/drivers/video/console_core.c index de004f585c..b82ca6d43c 100644 --- a/drivers/video/console_core.c +++ b/drivers/video/console_core.c @@ -9,8 +9,41 @@ #include <video.h> #include <video_console.h> #include <dm.h> +#include <video_font.h> #include "vidconsole_internal.h"
+/** + * console_set_font() - prepare vidconsole for chosen font. + * + * @dev vidconsole device + * @fontdata pointer to font data struct + */ +static int console_set_font(struct udevice *dev, struct video_fontdata *fontdata) +{ + struct console_simple_priv *priv = dev_get_priv(dev); + struct vidconsole_priv *vc_priv = dev_get_uclass_priv(dev); + struct video_priv *vid_priv = dev_get_uclass_priv(dev->parent); + + debug("console_simple: setting %s font\n", fontdata->name); + debug("width: %d\n", fontdata->width); + debug("byte width: %d\n", fontdata->byte_width); + debug("height: %d\n", fontdata->height); + + priv->fontdata = fontdata; + vc_priv->x_charsize = fontdata->width; + vc_priv->y_charsize = fontdata->height; + if (vid_priv->rot % 2) { + vc_priv->cols = vid_priv->ysize / fontdata->width; + vc_priv->rows = vid_priv->xsize / fontdata->height; + vc_priv->xsize_frac = VID_TO_POS(vid_priv->ysize); + } else { + vc_priv->cols = vid_priv->xsize / fontdata->width; + vc_priv->rows = vid_priv->ysize / fontdata->height; + } + + return 0; +} + int check_bpix_support(int bpix) { if (bpix == VIDEO_BPP8 && IS_ENABLED(CONFIG_VIDEO_BPP8)) @@ -43,7 +76,7 @@ inline void fill_pixel_and_goto_next(void **dstp, u32 value, int pbytes, int ste }
int fill_char_vertically(uchar *pfont, void **line, struct video_priv *vid_priv, - bool direction) + struct video_fontdata *fontdata, bool direction) { int step, line_step, pbytes, bitcount, width_remainder, ret; void *dst; @@ -61,17 +94,17 @@ int fill_char_vertically(uchar *pfont, void **line, struct video_priv *vid_priv, line_step = vid_priv->line_length; }
- width_remainder = VIDEO_FONT_WIDTH % 8; - for (int row = 0; row < VIDEO_FONT_HEIGHT; row++) { + width_remainder = fontdata->width % 8; + for (int row = 0; row < fontdata->height; row++) { uchar bits;
bitcount = 8; dst = *line; - for (int col = 0; col < VIDEO_FONT_BYTE_WIDTH; col++) { + for (int col = 0; col < fontdata->byte_width; col++) { if (width_remainder) { - bool is_last_iteration = (VIDEO_FONT_BYTE_WIDTH - col == 1); + bool is_last_col = (fontdata->byte_width - col == 1);
- if (is_last_iteration) + if (is_last_col) bitcount = width_remainder; } bits = pfont[col]; @@ -90,13 +123,13 @@ int fill_char_vertically(uchar *pfont, void **line, struct video_priv *vid_priv, } } *line += line_step; - pfont += VIDEO_FONT_BYTE_WIDTH; + pfont += fontdata->byte_width; } return ret; }
int fill_char_horizontally(uchar *pfont, void **line, struct video_priv *vid_priv, - bool direction) + struct video_fontdata *fontdata, bool direction) { int step, line_step, pbytes, bitcount = 8, width_remainder, ret; void *dst; @@ -115,21 +148,20 @@ int fill_char_horizontally(uchar *pfont, void **line, struct video_priv *vid_pri line_step = -vid_priv->line_length; }
- width_remainder = VIDEO_FONT_WIDTH % 8; - for (int col = 0; col < VIDEO_FONT_BYTE_WIDTH; col++) { + width_remainder = fontdata->width % 8; + for (int col = 0; col < fontdata->byte_width; col++) { mask = 0x80; if (width_remainder) { - bool is_last_iteration = (VIDEO_FONT_BYTE_WIDTH - col == 1); + bool is_last_col = (fontdata->byte_width - col == 1);
- if (is_last_iteration) + if (is_last_col) bitcount = width_remainder; } for (int bit = 0; bit < bitcount; bit++) { dst = *line; - for (int row = 0; row < VIDEO_FONT_HEIGHT; row++) { - u32 value = (pfont[row * VIDEO_FONT_BYTE_WIDTH] & mask) ? - vid_priv->colour_fg : - vid_priv->colour_bg; + for (int row = 0; row < fontdata->height; row++) { + u32 value = (pfont[row * fontdata->byte_width + col] + & mask) ? vid_priv->colour_fg : vid_priv->colour_bg;
fill_pixel_and_goto_next(&dst, value, @@ -146,20 +178,5 @@ int fill_char_horizontally(uchar *pfont, void **line, struct video_priv *vid_pri
int console_probe(struct udevice *dev) { - struct vidconsole_priv *vc_priv = dev_get_uclass_priv(dev); - struct udevice *vid_dev = dev->parent; - struct video_priv *vid_priv = dev_get_uclass_priv(vid_dev); - - vc_priv->x_charsize = VIDEO_FONT_WIDTH; - vc_priv->y_charsize = VIDEO_FONT_HEIGHT; - if (vid_priv->rot % 2) { - vc_priv->cols = vid_priv->ysize / VIDEO_FONT_WIDTH; - vc_priv->rows = vid_priv->xsize / VIDEO_FONT_HEIGHT; - vc_priv->xsize_frac = VID_TO_POS(vid_priv->ysize); - } else { - vc_priv->cols = vid_priv->xsize / VIDEO_FONT_WIDTH; - vc_priv->rows = vid_priv->ysize / VIDEO_FONT_HEIGHT; - } - - return 0; + return console_set_font(dev, fonts); } diff --git a/drivers/video/console_normal.c b/drivers/video/console_normal.c index e499e64852..03e859898c 100644 --- a/drivers/video/console_normal.c +++ b/drivers/video/console_normal.c @@ -16,8 +16,10 @@ static int console_set_row(struct udevice *dev, uint row, int clr) { struct video_priv *vid_priv = dev_get_uclass_priv(dev->parent); + struct console_simple_priv *priv = dev_get_priv(dev); + struct video_fontdata *fontdata = priv->fontdata; void *line, *dst, *end; - int pixels = VIDEO_FONT_HEIGHT * vid_priv->xsize; + int pixels = fontdata->height * vid_priv->xsize; int ret; int i; int pbytes; @@ -26,7 +28,7 @@ static int console_set_row(struct udevice *dev, uint row, int clr) if (ret) return ret;
- line = vid_priv->fb + row * VIDEO_FONT_HEIGHT * vid_priv->line_length; + line = vid_priv->fb + row * fontdata->height * vid_priv->line_length; dst = line; pbytes = VNBYTES(vid_priv->bpix); for (i = 0; i < pixels; i++) @@ -44,14 +46,16 @@ static int console_move_rows(struct udevice *dev, uint rowdst, uint rowsrc, uint count) { struct video_priv *vid_priv = dev_get_uclass_priv(dev->parent); + struct console_simple_priv *priv = dev_get_priv(dev); + struct video_fontdata *fontdata = priv->fontdata; void *dst; void *src; int size; int ret;
- dst = vid_priv->fb + rowdst * VIDEO_FONT_HEIGHT * vid_priv->line_length; - src = vid_priv->fb + rowsrc * VIDEO_FONT_HEIGHT * vid_priv->line_length; - size = VIDEO_FONT_HEIGHT * vid_priv->line_length * count; + dst = vid_priv->fb + rowdst * fontdata->height * vid_priv->line_length; + src = vid_priv->fb + rowsrc * fontdata->height * vid_priv->line_length; + size = fontdata->height * vid_priv->line_length * count; ret = vidconsole_memmove(dev, dst, src, size); if (ret) return ret; @@ -64,10 +68,13 @@ static int console_putc_xy(struct udevice *dev, uint x_frac, uint y, char ch) struct vidconsole_priv *vc_priv = dev_get_uclass_priv(dev); struct udevice *vid = dev->parent; struct video_priv *vid_priv = dev_get_uclass_priv(vid); + struct console_simple_priv *priv = dev_get_priv(dev); + struct video_fontdata *fontdata = priv->fontdata; int pbytes = VNBYTES(vid_priv->bpix); int x, linenum, ret; void *start, *line; - uchar *pfont = video_fontdata + (u8)ch * VIDEO_FONT_CHAR_PIXEL_BYTES; + uchar *pfont = fontdata->video_fontdata + + (u8)ch * fontdata->char_pixel_bytes;
if (x_frac + VID_TO_POS(vc_priv->x_charsize) > vc_priv->xsize_frac) return -EAGAIN; @@ -79,7 +86,7 @@ static int console_putc_xy(struct udevice *dev, uint x_frac, uint y, char ch) if (x_frac + VID_TO_POS(vc_priv->x_charsize) > vc_priv->xsize_frac) return -EAGAIN;
- ret = fill_char_vertically(pfont, &line, vid_priv, NORMAL_DIRECTION); + ret = fill_char_vertically(pfont, &line, vid_priv, fontdata, NORMAL_DIRECTION); if (ret) return ret;
@@ -87,7 +94,7 @@ static int console_putc_xy(struct udevice *dev, uint x_frac, uint y, char ch) if (ret) return ret;
- return VID_TO_POS(VIDEO_FONT_WIDTH); + return VID_TO_POS(fontdata->width); }
struct vidconsole_ops console_ops = { @@ -97,8 +104,9 @@ struct vidconsole_ops console_ops = { };
U_BOOT_DRIVER(vidconsole_normal) = { - .name = "vidconsole0", - .id = UCLASS_VIDEO_CONSOLE, - .ops = &console_ops, - .probe = console_probe, + .name = "vidconsole0", + .id = UCLASS_VIDEO_CONSOLE, + .ops = &console_ops, + .probe = console_probe, + .priv_auto = sizeof(struct console_simple_priv), }; diff --git a/drivers/video/console_rotate.c b/drivers/video/console_rotate.c index 64e2f12c2f..b924bc3459 100644 --- a/drivers/video/console_rotate.c +++ b/drivers/video/console_rotate.c @@ -16,17 +16,19 @@ static int console_set_row_1(struct udevice *dev, uint row, int clr) { struct video_priv *vid_priv = dev_get_uclass_priv(dev->parent); + struct console_simple_priv *priv = dev_get_priv(dev); + struct video_fontdata *fontdata = priv->fontdata; int pbytes = VNBYTES(vid_priv->bpix); void *start, *dst, *line; int i, j; int ret;
start = vid_priv->fb + vid_priv->line_length - - (row + 1) * VIDEO_FONT_HEIGHT * pbytes; + (row + 1) * fontdata->height * pbytes; line = start; for (j = 0; j < vid_priv->ysize; j++) { dst = line; - for (i = 0; i < VIDEO_FONT_HEIGHT; i++) + for (i = 0; i < fontdata->height; i++) fill_pixel_and_goto_next(&dst, clr, pbytes, pbytes); line += vid_priv->line_length; } @@ -41,19 +43,21 @@ static int console_move_rows_1(struct udevice *dev, uint rowdst, uint rowsrc, uint count) { struct video_priv *vid_priv = dev_get_uclass_priv(dev->parent); + struct console_simple_priv *priv = dev_get_priv(dev); + struct video_fontdata *fontdata = priv->fontdata; int pbytes = VNBYTES(vid_priv->bpix); void *dst; void *src; int j, ret;
dst = vid_priv->fb + vid_priv->line_length - - (rowdst + count) * VIDEO_FONT_HEIGHT * pbytes; + (rowdst + count) * fontdata->height * pbytes; src = vid_priv->fb + vid_priv->line_length - - (rowsrc + count) * VIDEO_FONT_HEIGHT * pbytes; + (rowsrc + count) * fontdata->height * pbytes;
for (j = 0; j < vid_priv->ysize; j++) { ret = vidconsole_memmove(dev, dst, src, - VIDEO_FONT_HEIGHT * pbytes * count); + fontdata->height * pbytes * count); if (ret) return ret; src += vid_priv->line_length; @@ -68,10 +72,13 @@ static int console_putc_xy_1(struct udevice *dev, uint x_frac, uint y, char ch) struct vidconsole_priv *vc_priv = dev_get_uclass_priv(dev); struct udevice *vid = dev->parent; struct video_priv *vid_priv = dev_get_uclass_priv(vid); + struct console_simple_priv *priv = dev_get_priv(dev); + struct video_fontdata *fontdata = priv->fontdata; int pbytes = VNBYTES(vid_priv->bpix); int x, linenum, ret; void *start, *line; - uchar *pfont = video_fontdata + (u8)ch * VIDEO_FONT_CHAR_PIXEL_BYTES; + uchar *pfont = fontdata->video_fontdata + + (u8)ch * fontdata->char_pixel_bytes;
if (x_frac + VID_TO_POS(vc_priv->x_charsize) > vc_priv->xsize_frac) return -EAGAIN; @@ -80,7 +87,7 @@ static int console_putc_xy_1(struct udevice *dev, uint x_frac, uint y, char ch) start = vid_priv->fb + linenum * vid_priv->line_length - x * pbytes; line = start;
- ret = fill_char_horizontally(pfont, &line, vid_priv, FLIPPED_DIRECTION); + ret = fill_char_horizontally(pfont, &line, vid_priv, fontdata, FLIPPED_DIRECTION); if (ret) return ret;
@@ -89,20 +96,22 @@ static int console_putc_xy_1(struct udevice *dev, uint x_frac, uint y, char ch) if (ret) return ret;
static int console_set_row_2(struct udevice *dev, uint row, int clr) { struct video_priv *vid_priv = dev_get_uclass_priv(dev->parent); + struct console_simple_priv *priv = dev_get_priv(dev); + struct video_fontdata *fontdata = priv->fontdata; void *start, *line, *dst, *end; - int pixels = VIDEO_FONT_HEIGHT * vid_priv->xsize; + int pixels = fontdata->height * vid_priv->xsize; int i, ret; int pbytes = VNBYTES(vid_priv->bpix);
start = vid_priv->fb + vid_priv->ysize * vid_priv->line_length - - (row + 1) * VIDEO_FONT_HEIGHT * vid_priv->line_length; + (row + 1) * fontdata->height * vid_priv->line_length; line = start; dst = line; for (i = 0; i < pixels; i++) @@ -119,17 +128,19 @@ static int console_move_rows_2(struct udevice *dev, uint rowdst, uint rowsrc, uint count) { struct video_priv *vid_priv = dev_get_uclass_priv(dev->parent); + struct console_simple_priv *priv = dev_get_priv(dev); + struct video_fontdata *fontdata = priv->fontdata; void *dst; void *src; void *end;
end = vid_priv->fb + vid_priv->ysize * vid_priv->line_length; - dst = end - (rowdst + count) * VIDEO_FONT_HEIGHT * + dst = end - (rowdst + count) * fontdata->height * vid_priv->line_length; - src = end - (rowsrc + count) * VIDEO_FONT_HEIGHT * + src = end - (rowsrc + count) * fontdata->height * vid_priv->line_length; vidconsole_memmove(dev, dst, src, - VIDEO_FONT_HEIGHT * vid_priv->line_length * count); + fontdata->height * vid_priv->line_length * count);
return 0; } @@ -139,10 +150,13 @@ static int console_putc_xy_2(struct udevice *dev, uint x_frac, uint y, char ch) struct vidconsole_priv *vc_priv = dev_get_uclass_priv(dev); struct udevice *vid = dev->parent; struct video_priv *vid_priv = dev_get_uclass_priv(vid); + struct console_simple_priv *priv = dev_get_priv(dev); + struct video_fontdata *fontdata = priv->fontdata; int pbytes = VNBYTES(vid_priv->bpix); int linenum, x, ret; void *start, *line; - uchar *pfont = video_fontdata + (u8)ch * VIDEO_FONT_CHAR_PIXEL_BYTES; + uchar *pfont = fontdata->video_fontdata + + (u8)ch * fontdata->char_pixel_bytes;
if (x_frac + VID_TO_POS(vc_priv->x_charsize) > vc_priv->xsize_frac) return -EAGAIN; @@ -151,7 +165,7 @@ static int console_putc_xy_2(struct udevice *dev, uint x_frac, uint y, char ch) start = vid_priv->fb + linenum * vid_priv->line_length + x * pbytes; line = start;
- ret = fill_char_vertically(pfont, &line, vid_priv, FLIPPED_DIRECTION); + ret = fill_char_vertically(pfont, &line, vid_priv, fontdata, FLIPPED_DIRECTION); if (ret) return ret;
@@ -160,21 +174,23 @@ static int console_putc_xy_2(struct udevice *dev, uint x_frac, uint y, char ch) if (ret) return ret;
static int console_set_row_3(struct udevice *dev, uint row, int clr) { struct video_priv *vid_priv = dev_get_uclass_priv(dev->parent); + struct console_simple_priv *priv = dev_get_priv(dev); + struct video_fontdata *fontdata = priv->fontdata; int pbytes = VNBYTES(vid_priv->bpix); void *start, *dst, *line; int i, j, ret;
- start = vid_priv->fb + row * VIDEO_FONT_HEIGHT * pbytes; + start = vid_priv->fb + row * fontdata->height * pbytes; line = start; for (j = 0; j < vid_priv->ysize; j++) { dst = line; - for (i = 0; i < VIDEO_FONT_HEIGHT; i++) + for (i = 0; i < fontdata->height; i++) fill_pixel_and_goto_next(&dst, clr, pbytes, pbytes); line += vid_priv->line_length; } @@ -189,17 +205,19 @@ static int console_move_rows_3(struct udevice *dev, uint rowdst, uint rowsrc, uint count) { struct video_priv *vid_priv = dev_get_uclass_priv(dev->parent); + struct console_simple_priv *priv = dev_get_priv(dev); + struct video_fontdata *fontdata = priv->fontdata; int pbytes = VNBYTES(vid_priv->bpix); void *dst; void *src; int j, ret;
- dst = vid_priv->fb + rowdst * VIDEO_FONT_HEIGHT * pbytes; - src = vid_priv->fb + rowsrc * VIDEO_FONT_HEIGHT * pbytes; + dst = vid_priv->fb + rowdst * fontdata->height * pbytes; + src = vid_priv->fb + rowsrc * fontdata->height * pbytes;
for (j = 0; j < vid_priv->ysize; j++) { ret = vidconsole_memmove(dev, dst, src, - VIDEO_FONT_HEIGHT * pbytes * count); + fontdata->height * pbytes * count); if (ret) return ret; src += vid_priv->line_length; @@ -214,10 +232,13 @@ static int console_putc_xy_3(struct udevice *dev, uint x_frac, uint y, char ch) struct vidconsole_priv *vc_priv = dev_get_uclass_priv(dev); struct udevice *vid = dev->parent; struct video_priv *vid_priv = dev_get_uclass_priv(vid); + struct console_simple_priv *priv = dev_get_priv(dev); + struct video_fontdata *fontdata = priv->fontdata; int pbytes = VNBYTES(vid_priv->bpix); int linenum, x, ret; void *start, *line; - uchar *pfont = video_fontdata + (u8)ch * VIDEO_FONT_CHAR_PIXEL_BYTES; + uchar *pfont = fontdata->video_fontdata + + (u8)ch * fontdata->char_pixel_bytes;
if (x_frac + VID_TO_POS(vc_priv->x_charsize) > vc_priv->xsize_frac) return -EAGAIN; @@ -226,7 +247,7 @@ static int console_putc_xy_3(struct udevice *dev, uint x_frac, uint y, char ch) start = vid_priv->fb + linenum * vid_priv->line_length + y * pbytes; line = start;
- ret = fill_char_horizontally(pfont, &line, vid_priv, NORMAL_DIRECTION); + ret = fill_char_horizontally(pfont, &line, vid_priv, fontdata, NORMAL_DIRECTION); if (ret) return ret; /* Add a line to allow for the first pixels writen */ @@ -234,7 +255,7 @@ static int console_putc_xy_3(struct udevice *dev, uint x_frac, uint y, char ch) if (ret) return ret;
struct vidconsole_ops console_ops_1 = { @@ -260,6 +281,7 @@ U_BOOT_DRIVER(vidconsole_1) = { .id = UCLASS_VIDEO_CONSOLE, .ops = &console_ops_1, .probe = console_probe, + .priv_auto = sizeof(struct console_simple_priv), };
U_BOOT_DRIVER(vidconsole_2) = { @@ -267,6 +289,7 @@ U_BOOT_DRIVER(vidconsole_2) = { .id = UCLASS_VIDEO_CONSOLE, .ops = &console_ops_2, .probe = console_probe, + .priv_auto = sizeof(struct console_simple_priv), };
U_BOOT_DRIVER(vidconsole_3) = { @@ -274,4 +297,5 @@ U_BOOT_DRIVER(vidconsole_3) = { .id = UCLASS_VIDEO_CONSOLE, .ops = &console_ops_3, .probe = console_probe, + .priv_auto = sizeof(struct console_simple_priv), }; diff --git a/drivers/video/vidconsole_internal.h b/drivers/video/vidconsole_internal.h index c7bc387035..99d3c876d7 100644 --- a/drivers/video/vidconsole_internal.h +++ b/drivers/video/vidconsole_internal.h @@ -6,14 +6,18 @@ * (C) Copyright 2023 Dzmitry Sankouski dsankouski@gmail.com */
-#include <video_font.h> /* Get font data, width and height */ - -#define VIDEO_FONT_BYTE_WIDTH ((VIDEO_FONT_WIDTH / 8) + (VIDEO_FONT_WIDTH % 8 > 0)) -#define VIDEO_FONT_CHAR_PIXEL_BYTES (VIDEO_FONT_HEIGHT * VIDEO_FONT_BYTE_WIDTH) - #define FLIPPED_DIRECTION 1 #define NORMAL_DIRECTION 0
+/** + * struct console_simple_priv - Private data for this driver + * + * @video_fontdata font graphical representation data + */ +struct console_simple_priv { + struct video_fontdata *fontdata; +}; + /** * Checks if bits per pixel supported. * @@ -41,6 +45,7 @@ void fill_pixel_and_goto_next(void **dstp, u32 value, int pbytes, int step); * @param pfont a pointer to character font data. * @param line a pointer to pointer to framebuffer. It's a point for upper left char corner * @param vid_priv driver private data. + * @fontdata font graphical representation data * @param direction controls character orientation. Can be normal or flipped. * When normal: When flipped: *|-----------------------------------------------| @@ -59,7 +64,7 @@ void fill_pixel_and_goto_next(void **dstp, u32 value, int pbytes, int step); * @returns 0, if success, or else error code. */ int fill_char_vertically(uchar *pfont, void **line, struct video_priv *vid_priv, - bool direction); + struct video_fontdata *fontdata, bool direction);
/** * Fills 1 character in framebuffer horizontally. @@ -68,6 +73,7 @@ int fill_char_vertically(uchar *pfont, void **line, struct video_priv *vid_priv, * @param pfont a pointer to character font data. * @param line a pointer to pointer to framebuffer. It's a point for upper left char corner * @param vid_priv driver private data. + * @fontdata font graphical representation data * @param direction controls character orientation. Can be normal or flipped. * When normal: When flipped: *|-----------------------------------------------| @@ -84,7 +90,7 @@ int fill_char_vertically(uchar *pfont, void **line, struct video_priv *vid_priv, * @returns 0, if success, or else error code. */ int fill_char_horizontally(uchar *pfont, void **line, struct video_priv *vid_priv, - bool direction); + struct video_fontdata *fontdata, bool direction);
/** * console probe function. diff --git a/include/video_font.h b/include/video_font.h index b07c07662c..00310d0926 100644 --- a/include/video_font.h +++ b/include/video_font.h @@ -7,10 +7,23 @@ #ifndef _VIDEO_FONT_ #define _VIDEO_FONT_
-#ifdef CONFIG_VIDEO_FONT_4X6 +#include <video_font_data.h> + +#if defined(CONFIG_VIDEO_FONT_4X6) #include <video_font_4x6.h> -#else +#endif +#if defined(CONFIG_VIDEO_FONT_8X16) #include <video_font_8x16.h> #endif
+static struct video_fontdata __maybe_unused fonts[] = { +#if defined(CONFIG_VIDEO_FONT_8X16) + FONT_ENTRY(8, 16, 8x16), +#endif +#if defined(CONFIG_VIDEO_FONT_4X6) + FONT_ENTRY(4, 6, 4x6), +#endif + {/* list terminator */} +}; + #endif /* _VIDEO_FONT_ */ diff --git a/include/video_font_4x6.h b/include/video_font_4x6.h index c7e6351b64..1b8c02510b 100644 --- a/include/video_font_4x6.h +++ b/include/video_font_4x6.h @@ -38,15 +38,12 @@ __END__; MSBit to LSBit = left to right. */
-#ifndef _VIDEO_FONT_DATA_ -#define _VIDEO_FONT_DATA_ +#ifndef _VIDEO_FONT_4X6_ +#define _VIDEO_FONT_4X6_
-#define VIDEO_FONT_CHARS 256 -#define VIDEO_FONT_WIDTH 4 -#define VIDEO_FONT_HEIGHT 6 -#define VIDEO_FONT_SIZE (VIDEO_FONT_CHARS * VIDEO_FONT_HEIGHT) +#include <video_font_data.h>
-static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { +static unsigned char video_fontdata_4x6[VIDEO_FONT_SIZE(256, 4, 6)] = {
/*{*/ /* Char 0: ' ' */ diff --git a/include/video_font_8x16.h b/include/video_font_8x16.h index d3d4295032..d8a1d90cee 100644 --- a/include/video_font_8x16.h +++ b/include/video_font_8x16.h @@ -9,13 +9,9 @@ #ifndef _VIDEO_FONT_8X16 #define _VIDEO_FONT_8X16
-#define VIDEO_FONT_CHARS 256 -#define VIDEO_FONT_WIDTH 8 -#define VIDEO_FONT_HEIGHT 16 -#define VIDEO_FONT_SIZE (VIDEO_FONT_CHARS * VIDEO_FONT_HEIGHT) - -static unsigned char __maybe_unused video_fontdata[VIDEO_FONT_SIZE] = { +#include <video_font_data.h>
+static unsigned char video_fontdata_8x16[VIDEO_FONT_SIZE(256, 8, 16)] = { /* 0 0x00 '^@' */ 0x00, /* 00000000 */ 0x00, /* 00000000 */ diff --git a/include/video_font_data.h b/include/video_font_data.h new file mode 100644 index 0000000000..37c3e00336 --- /dev/null +++ b/include/video_font_data.h @@ -0,0 +1,31 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * (C) Copyright 2023 Dzmitry Sankouski dsankouski@gmail.com + */ + +#ifndef _VIDEO_FONT_DATA_ +#define _VIDEO_FONT_DATA_ +#define VIDEO_FONT_BYTE_WIDTH(width) ((width / 8) + (width % 8 > 0)) +#define VIDEO_FONT_CHAR_PIXEL_BYTES(width, height) (height * VIDEO_FONT_BYTE_WIDTH(width)) +#define VIDEO_FONT_SIZE(chars, width, height) (chars * VIDEO_FONT_CHAR_PIXEL_BYTES(width, height)) + +struct video_fontdata { + const char *name; + int width; + int height; + int byte_width; + int char_pixel_bytes; + unsigned char *video_fontdata; +}; + +#define FONT_ENTRY(_font_width, _font_height, _width_x_height) \ +{ \ + .name = #_width_x_height, \ + .width = _font_width, \ + .height = _font_height, \ + .byte_width = VIDEO_FONT_BYTE_WIDTH(_font_width), \ + .char_pixel_bytes = VIDEO_FONT_CHAR_PIXEL_BYTES(_font_width, _font_height), \ + .video_fontdata = video_fontdata_##_width_x_height, \ +} + +#endif /* _VIDEO_FONT_DATA_ */
Since multiple vidconsole drivers exists, vidconsole_get_font_size() implementation cannot longer live in vidconsole_uclass.c file.
Move current vidconsole_get_font_size logic to truetype driver ops.
Signed-off-by: Dzmitry Sankouski dsankouski@gmail.com --- Changes for v2: N/A Changes for v3: N/A Charges for v4: N/A Charges for v5: N/A Charges for v6: N/A Charges for v7: N/A
cmd/font.c | 6 +++++- drivers/video/console_truetype.c | 3 ++- drivers/video/vidconsole-uclass.c | 11 +++++++++++ include/video_console.h | 14 ++++++++++++-- test/cmd/font.c | 13 +++++++------ 5 files changed, 37 insertions(+), 10 deletions(-)
diff --git a/cmd/font.c b/cmd/font.c index 7b4347f32b..fe2d65caaf 100644 --- a/cmd/font.c +++ b/cmd/font.c @@ -61,7 +61,11 @@ static int do_font_size(struct cmd_tbl *cmdtp, int flag, int argc,
if (uclass_first_device_err(UCLASS_VIDEO_CONSOLE, &dev)) return CMD_RET_FAILURE; - font_name = vidconsole_get_font_size(dev, &size); + ret = vidconsole_get_font_size(dev, &font_name, &size); + if (ret) { + printf("Failed (error %d)\n", ret); + return CMD_RET_FAILURE; + }
size = dectoul(argv[1], NULL);
diff --git a/drivers/video/console_truetype.c b/drivers/video/console_truetype.c index 9cac9a6de4..6b5390136a 100644 --- a/drivers/video/console_truetype.c +++ b/drivers/video/console_truetype.c @@ -724,7 +724,7 @@ static int truetype_select_font(struct udevice *dev, const char *name, return 0; }
-const char *vidconsole_get_font_size(struct udevice *dev, uint *sizep) +const char *console_truetype_get_font_size(struct udevice *dev, uint *sizep) { struct console_tt_priv *priv = dev_get_priv(dev); struct console_tt_metrics *met = priv->cur_met; @@ -773,6 +773,7 @@ struct vidconsole_ops console_truetype_ops = { .backspace = console_truetype_backspace, .entry_start = console_truetype_entry_start, .get_font = console_truetype_get_font, + .get_font_size = console_truetype_get_font_size, .select_font = truetype_select_font, };
diff --git a/drivers/video/vidconsole-uclass.c b/drivers/video/vidconsole-uclass.c index 72a13d3052..a5f2350ca1 100644 --- a/drivers/video/vidconsole-uclass.c +++ b/drivers/video/vidconsole-uclass.c @@ -575,6 +575,17 @@ int vidconsole_get_font(struct udevice *dev, int seq, return ops->get_font(dev, seq, info); }
+int vidconsole_get_font_size(struct udevice *dev, const char **name, uint *sizep) +{ + struct vidconsole_ops *ops = vidconsole_get_ops(dev); + + if (!ops->get_font_size) + return -ENOSYS; + + *name = ops->get_font_size(dev, sizep); + return 0; +} + int vidconsole_select_font(struct udevice *dev, const char *name, uint size) { struct vidconsole_ops *ops = vidconsole_get_ops(dev); diff --git a/include/video_console.h b/include/video_console.h index 9d2c0f210e..646c7e292b 100644 --- a/include/video_console.h +++ b/include/video_console.h @@ -160,6 +160,15 @@ struct vidconsole_ops { int (*get_font)(struct udevice *dev, int seq, struct vidfont_info *info);
+ /** + * get_font_size() - get the current font name and size + * + * @dev: vidconsole device + * @sizep: Place to put the font size (nominal height in pixels) + * Returns: Current font name + */ + const char *(*get_font_size)(struct udevice *dev, uint *sizep); + /** * select_font() - Select a particular font by name / size * @@ -303,9 +312,10 @@ void vidconsole_list_fonts(struct udevice *dev); * * @dev: vidconsole device * @sizep: Place to put the font size (nominal height in pixels) - * Returns: Current font name + * @name: pointer to font name, a placeholder for result + * Return: 0 if OK, -ENOSYS if not implemented in driver */ -const char *vidconsole_get_font_size(struct udevice *dev, uint *sizep); +int vidconsole_get_font_size(struct udevice *dev, const char **name, uint *sizep);
#ifdef CONFIG_VIDEO_COPY /** diff --git a/test/cmd/font.c b/test/cmd/font.c index adb353965a..40682e5ce4 100644 --- a/test/cmd/font.c +++ b/test/cmd/font.c @@ -19,6 +19,7 @@ static int font_test_base(struct unit_test_state *uts) { struct udevice *dev; + const char *name; int max_metrics; uint size; int ret; @@ -32,8 +33,8 @@ static int font_test_base(struct unit_test_state *uts) ut_assert_nextline("cantoraone_regular"); ut_assertok(ut_check_console_end(uts));
- ut_asserteq_str("nimbus_sans_l_regular", - vidconsole_get_font_size(dev, &size)); + ut_assertok(vidconsole_get_font_size(dev, &name, &size)); + ut_asserteq_str("nimbus_sans_l_regular", name); ut_asserteq(18, size);
max_metrics = 1; @@ -52,15 +53,15 @@ static int font_test_base(struct unit_test_state *uts) ut_assertok(ret); ut_assertok(ut_check_console_end(uts));
- ut_asserteq_str("cantoraone_regular", - vidconsole_get_font_size(dev, &size)); + ut_assertok(vidconsole_get_font_size(dev, &name, &size)); + ut_asserteq_str("cantoraone_regular", name); ut_asserteq(40, size);
ut_assertok(run_command("font size 30", 0)); ut_assertok(ut_check_console_end(uts));
- ut_asserteq_str("cantoraone_regular", - vidconsole_get_font_size(dev, &size)); + ut_assertok(vidconsole_get_font_size(dev, &name, &size)); + ut_asserteq_str("cantoraone_regular", name); ut_asserteq(30, size);
Allow font size configuration at runtime for console_simple.c driver. This needed for unit testing different fonts.
Configuring is done by `font` command, also used for font selection in true type console.
Signed-off-by: Dzmitry Sankouski dsankouski@gmail.com Reviewed-by: Simon Glass sjg@chromium.org --- Changes for v2: N/A Changes for v3: - move 8x16 font patch extracted - implement multiple fonts patch extracted - add static modifiers, where needed - remove list fonts operation - put fontdata in local var Charges for v4: N/A Charges for v5: N/A Charges for v6: rebase only Charges for v7: rebase only - (&fonts[seq])->name - fonts[seq].name
cmd/Kconfig | 8 ++++++++ cmd/Makefile | 2 +- drivers/video/Kconfig | 1 + drivers/video/console_core.c | 30 +++++++++++++++++++++++++++++ drivers/video/console_normal.c | 3 +++ drivers/video/console_rotate.c | 9 +++++++++ drivers/video/vidconsole_internal.h | 18 +++++++++++++++++ 7 files changed, 70 insertions(+), 1 deletion(-)
diff --git a/cmd/Kconfig b/cmd/Kconfig index 2caa4af71c..a3512836c1 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -2226,6 +2226,14 @@ config CMD_VIDCONSOLE The name 'lcdputs' is a bit of a misnomer, but so named because the video device is often an LCD.
+config CMD_SELECT_FONT + bool "select font size" + depends on VIDEO + default n + help + Enabling this will provide 'font' command. + Allows font selection at runtime. + endmenu
source "cmd/ti/Kconfig" diff --git a/cmd/Makefile b/cmd/Makefile index 36d2daf22a..2d8bb4fc05 100644 --- a/cmd/Makefile +++ b/cmd/Makefile @@ -78,7 +78,7 @@ obj-$(CONFIG_CMD_EXT2) += ext2.o obj-$(CONFIG_CMD_FAT) += fat.o obj-$(CONFIG_CMD_FDT) += fdt.o obj-$(CONFIG_CMD_SQUASHFS) += sqfs.o -obj-$(CONFIG_CONSOLE_TRUETYPE) += font.o +obj-$(CONFIG_CMD_SELECT_FONT) += font.o obj-$(CONFIG_CMD_FLASH) += flash.o obj-$(CONFIG_CMD_FPGA) += fpga.o obj-$(CONFIG_CMD_FPGAD) += fpgad.o diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index ce97eb4727..e1bcc89b30 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -165,6 +165,7 @@ config CONSOLE_ROTATION
config CONSOLE_TRUETYPE bool "Support a console that uses TrueType fonts" + select CMD_SELECT_FONT help TrueTrype fonts can provide outline-drawing capability rather than needing to provide a bitmap for each font and size that is needed. diff --git a/drivers/video/console_core.c b/drivers/video/console_core.c index b82ca6d43c..d830738427 100644 --- a/drivers/video/console_core.c +++ b/drivers/video/console_core.c @@ -180,3 +180,33 @@ int console_probe(struct udevice *dev) { return console_set_font(dev, fonts); } + +const char *console_simple_get_font_size(struct udevice *dev, uint *sizep) +{ + struct console_simple_priv *priv = dev_get_priv(dev); + + *sizep = priv->fontdata->width; + + return priv->fontdata->name; +} + +int console_simple_get_font(struct udevice *dev, int seq, struct vidfont_info *info) +{ + info->name = fonts[seq].name; + + return 0; +} + +int console_simple_select_font(struct udevice *dev, const char *name, uint size) +{ + struct video_fontdata *font; + + for (font = fonts; font->name; font++) { + if (!strcmp(name, font->name)) { + console_set_font(dev, font); + return 0; + } + }; + printf("no such font: %s, make sure it's name has <width>x<height> format\n", name); + return -ENOENT; +} diff --git a/drivers/video/console_normal.c b/drivers/video/console_normal.c index 03e859898c..413c7abee9 100644 --- a/drivers/video/console_normal.c +++ b/drivers/video/console_normal.c @@ -101,6 +101,9 @@ struct vidconsole_ops console_ops = { .putc_xy = console_putc_xy, .move_rows = console_move_rows, .set_row = console_set_row, + .get_font_size = console_simple_get_font_size, + .get_font = console_simple_get_font, + .select_font = console_simple_select_font, };
U_BOOT_DRIVER(vidconsole_normal) = { diff --git a/drivers/video/console_rotate.c b/drivers/video/console_rotate.c index b924bc3459..65358a1c6e 100644 --- a/drivers/video/console_rotate.c +++ b/drivers/video/console_rotate.c @@ -262,18 +262,27 @@ struct vidconsole_ops console_ops_1 = { .putc_xy = console_putc_xy_1, .move_rows = console_move_rows_1, .set_row = console_set_row_1, + .get_font_size = console_simple_get_font_size, + .get_font = console_simple_get_font, + .select_font = console_simple_select_font, };
struct vidconsole_ops console_ops_2 = { .putc_xy = console_putc_xy_2, .move_rows = console_move_rows_2, .set_row = console_set_row_2, + .get_font_size = console_simple_get_font_size, + .get_font = console_simple_get_font, + .select_font = console_simple_select_font, };
struct vidconsole_ops console_ops_3 = { .putc_xy = console_putc_xy_3, .move_rows = console_move_rows_3, .set_row = console_set_row_3, + .get_font_size = console_simple_get_font_size, + .get_font = console_simple_get_font, + .select_font = console_simple_select_font, };
U_BOOT_DRIVER(vidconsole_1) = { diff --git a/drivers/video/vidconsole_internal.h b/drivers/video/vidconsole_internal.h index 99d3c876d7..c41edd4524 100644 --- a/drivers/video/vidconsole_internal.h +++ b/drivers/video/vidconsole_internal.h @@ -100,3 +100,21 @@ int fill_char_horizontally(uchar *pfont, void **line, struct video_priv *vid_pri * @returns 0, if success, or else error code. */ int console_probe(struct udevice *dev); + +/** + * Internal function to be used in as ops. + * See details in video_console.h get_font_size function + **/ +const char *console_simple_get_font_size(struct udevice *dev, uint *sizep); + +/** + * Internal function to be used in as ops. + * See details in video_console.h get_font function + **/ +int console_simple_get_font(struct udevice *dev, int seq, struct vidfont_info *info); + +/** + * Internal function to be used in as ops. + * See details in video_console.h select_font function + **/ +int console_simple_select_font(struct udevice *dev, const char *name, uint size);
Modern mobile phones typically have high pixel density. Bootmenu is hardly readable on those with 8x16 font.
Signed-off-by: Dzmitry Sankouski dsankouski@gmail.com Reviewed-by: Simon Glass sjg@chromium.org --- Changes for v2: N/A Changes for v3: none Charges for v4: N/A Charges for v5: N/A Charges for v6: rebase only Charges for v7: none
drivers/video/Kconfig | 7 + include/video_font.h | 6 + include/video_font_sun12x22.h | 6158 +++++++++++++++++++++++++++++++++ 3 files changed, 6171 insertions(+) create mode 100644 include/video_font_sun12x22.h
diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index e1bcc89b30..a928ae498a 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -31,6 +31,13 @@ config VIDEO_FONT_8X16 Provides character bitmap data in header file. When selecting multiple fonts, you may want to enable CMD_SELECT_FONT too.
+config VIDEO_FONT_SUN12X22 + bool "12 x 22 font size" + help + Font for video console driver, 12 x 22 pixels + Provides character bitmap data in header file. + When selecting multiple fonts, you may want to enable CMD_SELECT_FONT too. + config VIDEO_LOGO bool "Show the U-Boot logo on the display" default y if !SPLASH_SCREEN diff --git a/include/video_font.h b/include/video_font.h index 00310d0926..f354d0cc4d 100644 --- a/include/video_font.h +++ b/include/video_font.h @@ -15,6 +15,9 @@ #if defined(CONFIG_VIDEO_FONT_8X16) #include <video_font_8x16.h> #endif +#if defined(CONFIG_VIDEO_FONT_SUN12X22) +#include <video_font_sun12x22.h> +#endif
static struct video_fontdata __maybe_unused fonts[] = { #if defined(CONFIG_VIDEO_FONT_8X16) @@ -22,6 +25,9 @@ static struct video_fontdata __maybe_unused fonts[] = { #endif #if defined(CONFIG_VIDEO_FONT_4X6) FONT_ENTRY(4, 6, 4x6), +#endif +#if defined(CONFIG_VIDEO_FONT_SUN12X22) + FONT_ENTRY(12, 22, 12x22), #endif {/* list terminator */} }; diff --git a/include/video_font_sun12x22.h b/include/video_font_sun12x22.h new file mode 100644 index 0000000000..47d3b798a8 --- /dev/null +++ b/include/video_font_sun12x22.h @@ -0,0 +1,6158 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Legacy 12x22 font resembling the font used on old Sun workstations. + * Copied from Linux' lib/fonts/font_sun12x22.c. + */ + +#ifndef _VIDEO_FONT_DATA_SUN12X22_ +#define _VIDEO_FONT_DATA_SUN12X22_ + +#include <video_font_data.h> + +static unsigned char __maybe_unused video_fontdata_12x22[VIDEO_FONT_SIZE(256, 12, 22)] = { + /* 0 0x00 '^@' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 1 0x01 '^A' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x1f, 0xc0, /* 000111111100 */ + 0x30, 0x60, /* 001100000110 */ + 0x65, 0x30, /* 011001010011 */ + 0x6d, 0xb0, /* 011011011011 */ + 0x60, 0x30, /* 011000000011 */ + 0x62, 0x30, /* 011000100011 */ + 0x62, 0x30, /* 011000100011 */ + 0x60, 0x30, /* 011000000011 */ + 0x6f, 0xb0, /* 011011111011 */ + 0x67, 0x30, /* 011001110011 */ + 0x30, 0x60, /* 001100000110 */ + 0x1f, 0xc0, /* 000111111100 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 2 0x02 '^B' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x1f, 0xc0, /* 000111111100 */ + 0x3f, 0xe0, /* 001111111110 */ + 0x7a, 0xf0, /* 011110101111 */ + 0x72, 0x70, /* 011100100111 */ + 0x7f, 0xf0, /* 011111111111 */ + 0x7d, 0xf0, /* 011111011111 */ + 0x7d, 0xf0, /* 011111011111 */ + 0x7f, 0xf0, /* 011111111111 */ + 0x70, 0x70, /* 011100000111 */ + 0x78, 0xf0, /* 011110001111 */ + 0x3f, 0xe0, /* 001111111110 */ + 0x1f, 0xc0, /* 000111111100 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 3 0x03 '^C' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x19, 0x80, /* 000110011000 */ + 0x3f, 0xc0, /* 001111111100 */ + 0x7f, 0xe0, /* 011111111110 */ + 0x3f, 0xc0, /* 001111111100 */ + 0x3f, 0xc0, /* 001111111100 */ + 0x1f, 0x80, /* 000111111000 */ + 0x1f, 0x80, /* 000111111000 */ + 0x0f, 0x00, /* 000011110000 */ + 0x0f, 0x00, /* 000011110000 */ + 0x06, 0x00, /* 000001100000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 4 0x04 '^D' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x02, 0x00, /* 000000100000 */ + 0x07, 0x00, /* 000001110000 */ + 0x0f, 0x80, /* 000011111000 */ + 0x0f, 0x80, /* 000011111000 */ + 0x1f, 0xc0, /* 000111111100 */ + 0x1f, 0xc0, /* 000111111100 */ + 0x3f, 0xe0, /* 001111111110 */ + 0x1f, 0xc0, /* 000111111100 */ + 0x1f, 0xc0, /* 000111111100 */ + 0x0f, 0x80, /* 000011111000 */ + 0x0f, 0x80, /* 000011111000 */ + 0x07, 0x00, /* 000001110000 */ + 0x02, 0x00, /* 000000100000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 5 0x05 '^E' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x02, 0x00, /* 000000100000 */ + 0x07, 0x00, /* 000001110000 */ + 0x07, 0x00, /* 000001110000 */ + 0x02, 0x00, /* 000000100000 */ + 0x18, 0xc0, /* 000110001100 */ + 0x3d, 0xe0, /* 001111011110 */ + 0x3d, 0xe0, /* 001111011110 */ + 0x1a, 0xc0, /* 000110101100 */ + 0x02, 0x00, /* 000000100000 */ + 0x07, 0x00, /* 000001110000 */ + 0x0f, 0x80, /* 000011111000 */ + 0x1f, 0xc0, /* 000111111100 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 6 0x06 '^F' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x06, 0x00, /* 000001100000 */ + 0x0f, 0x00, /* 000011110000 */ + 0x1f, 0x80, /* 000111111000 */ + 0x1f, 0x80, /* 000111111000 */ + 0x3f, 0xc0, /* 001111111100 */ + 0x7f, 0xe0, /* 011111111110 */ + 0x7f, 0xe0, /* 011111111110 */ + 0x36, 0xc0, /* 001101101100 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x0f, 0x00, /* 000011110000 */ + 0x1f, 0x80, /* 000111111000 */ + 0x3f, 0xc0, /* 001111111100 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 7 0x07 '^G' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x06, 0x00, /* 000001100000 */ + 0x0f, 0x00, /* 000011110000 */ + 0x0f, 0x00, /* 000011110000 */ + 0x1f, 0x80, /* 000111111000 */ + 0x1f, 0x80, /* 000111111000 */ + 0x3f, 0xc0, /* 001111111100 */ + 0x3f, 0xc0, /* 001111111100 */ + 0x1f, 0x80, /* 000111111000 */ + 0x1f, 0x80, /* 000111111000 */ + 0x0f, 0x00, /* 000011110000 */ + 0x0f, 0x00, /* 000011110000 */ + 0x06, 0x00, /* 000001100000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 8 0x08 '^H' */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + 0xf9, 0xf0, /* 111110011111 */ + 0xf0, 0xf0, /* 111100001111 */ + 0xf0, 0xf0, /* 111100001111 */ + 0xe0, 0x70, /* 111000000111 */ + 0xe0, 0x70, /* 111000000111 */ + 0xc0, 0x30, /* 110000000011 */ + 0xc0, 0x30, /* 110000000011 */ + 0xe0, 0x70, /* 111000000111 */ + 0xe0, 0x70, /* 111000000111 */ + 0xf0, 0xf0, /* 111100001111 */ + 0xf0, 0xf0, /* 111100001111 */ + 0xf9, 0xf0, /* 111110011111 */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + + /* 9 0x09 '^I' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x06, 0x00, /* 000001100000 */ + 0x0f, 0x00, /* 000011110000 */ + 0x0f, 0x00, /* 000011110000 */ + 0x19, 0x80, /* 000110011000 */ + 0x19, 0x80, /* 000110011000 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x19, 0x80, /* 000110011000 */ + 0x19, 0x80, /* 000110011000 */ + 0x0f, 0x00, /* 000011110000 */ + 0x0f, 0x00, /* 000011110000 */ + 0x06, 0x00, /* 000001100000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 10 0x0a '^J' */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + 0xf9, 0xf0, /* 111110011111 */ + 0xf0, 0xf0, /* 111100001111 */ + 0xf0, 0xf0, /* 111100001111 */ + 0xe6, 0x70, /* 111001100111 */ + 0xe6, 0x70, /* 111001100111 */ + 0xcf, 0x30, /* 110011110011 */ + 0xcf, 0x30, /* 110011110011 */ + 0xe6, 0x70, /* 111001100111 */ + 0xe6, 0x70, /* 111001100111 */ + 0xf0, 0xf0, /* 111100001111 */ + 0xf0, 0xf0, /* 111100001111 */ + 0xf9, 0xf0, /* 111110011111 */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + + /* 11 0x0b '^K' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x0f, 0xe0, /* 000011111110 */ + 0x0f, 0xe0, /* 000011111110 */ + 0x01, 0xe0, /* 000000011110 */ + 0x03, 0x60, /* 000000110110 */ + 0x06, 0x60, /* 000001100110 */ + 0x1e, 0x00, /* 000111100000 */ + 0x33, 0x00, /* 001100110000 */ + 0x33, 0x00, /* 001100110000 */ + 0x61, 0x80, /* 011000011000 */ + 0x61, 0x80, /* 011000011000 */ + 0x33, 0x00, /* 001100110000 */ + 0x33, 0x00, /* 001100110000 */ + 0x1e, 0x00, /* 000111100000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 12 0x0c '^L' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x06, 0x00, /* 000001100000 */ + 0x0f, 0x00, /* 000011110000 */ + 0x19, 0x80, /* 000110011000 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x19, 0x80, /* 000110011000 */ + 0x0f, 0x00, /* 000011110000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x3f, 0xc0, /* 001111111100 */ + 0x3f, 0xc0, /* 001111111100 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 13 0x0d '^M' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x0f, 0xe0, /* 000011111110 */ + 0x0c, 0x60, /* 000011000110 */ + 0x0c, 0x60, /* 000011000110 */ + 0x0f, 0xe0, /* 000011111110 */ + 0x0c, 0x00, /* 000011000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x3c, 0x00, /* 001111000000 */ + 0x7c, 0x00, /* 011111000000 */ + 0x78, 0x00, /* 011110000000 */ + 0x30, 0x00, /* 001100000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 14 0x0e '^N' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x1f, 0xe0, /* 000111111110 */ + 0x18, 0x60, /* 000110000110 */ + 0x18, 0x60, /* 000110000110 */ + 0x1f, 0xe0, /* 000111111110 */ + 0x18, 0x60, /* 000110000110 */ + 0x18, 0x60, /* 000110000110 */ + 0x18, 0x60, /* 000110000110 */ + 0x18, 0x60, /* 000110000110 */ + 0x18, 0x60, /* 000110000110 */ + 0x18, 0x60, /* 000110000110 */ + 0x19, 0xe0, /* 000110011110 */ + 0x1b, 0xe0, /* 000110111110 */ + 0x1b, 0xc0, /* 000110111100 */ + 0x79, 0x80, /* 011110011000 */ + 0xf8, 0x00, /* 111110000000 */ + 0xf0, 0x00, /* 111100000000 */ + 0x60, 0x00, /* 011000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 15 0x0f '^O' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x18, 0xc0, /* 000110001100 */ + 0x0d, 0x80, /* 000011011000 */ + 0x6d, 0xb0, /* 011011011011 */ + 0x3d, 0xe0, /* 001111011110 */ + 0x00, 0x00, /* 000000000000 */ + 0x3d, 0xe0, /* 001111011110 */ + 0x6d, 0xb0, /* 011011011011 */ + 0x0d, 0x80, /* 000011011000 */ + 0x18, 0xc0, /* 000110001100 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 16 0x10 '^P' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x20, /* 000000000010 */ + 0x00, 0x60, /* 000000000110 */ + 0x00, 0xe0, /* 000000001110 */ + 0x01, 0xe0, /* 000000011110 */ + 0x03, 0xe0, /* 000000111110 */ + 0x07, 0xe0, /* 000001111110 */ + 0x0f, 0xe0, /* 000011111110 */ + 0x1f, 0xe0, /* 000111111110 */ + 0x3f, 0xe0, /* 001111111110 */ + 0x7f, 0xe0, /* 011111111110 */ + 0x3f, 0xe0, /* 001111111110 */ + 0x1f, 0xe0, /* 000111111110 */ + 0x0f, 0xe0, /* 000011111110 */ + 0x07, 0xe0, /* 000001111110 */ + 0x03, 0xe0, /* 000000111110 */ + 0x01, 0xe0, /* 000000011110 */ + 0x00, 0xe0, /* 000000001110 */ + 0x00, 0x60, /* 000000000110 */ + 0x00, 0x20, /* 000000000010 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 17 0x11 '^Q' */ + 0x00, 0x00, /* 000000000000 */ + 0x40, 0x00, /* 010000000000 */ + 0x60, 0x00, /* 011000000000 */ + 0x70, 0x00, /* 011100000000 */ + 0x78, 0x00, /* 011110000000 */ + 0x7c, 0x00, /* 011111000000 */ + 0x7e, 0x00, /* 011111100000 */ + 0x7f, 0x00, /* 011111110000 */ + 0x7f, 0x80, /* 011111111000 */ + 0x7f, 0xc0, /* 011111111100 */ + 0x7f, 0xe0, /* 011111111110 */ + 0x7f, 0xc0, /* 011111111100 */ + 0x7f, 0x80, /* 011111111000 */ + 0x7f, 0x00, /* 011111110000 */ + 0x7e, 0x00, /* 011111100000 */ + 0x7c, 0x00, /* 011111000000 */ + 0x78, 0x00, /* 011110000000 */ + 0x70, 0x00, /* 011100000000 */ + 0x60, 0x00, /* 011000000000 */ + 0x40, 0x00, /* 010000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 18 0x12 '^R' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x04, 0x00, /* 000001000000 */ + 0x0e, 0x00, /* 000011100000 */ + 0x1f, 0x00, /* 000111110000 */ + 0x3f, 0x80, /* 001111111000 */ + 0x7f, 0xc0, /* 011111111100 */ + 0x0e, 0x00, /* 000011100000 */ + 0x0e, 0x00, /* 000011100000 */ + 0x7f, 0xc0, /* 011111111100 */ + 0x3f, 0x80, /* 001111111000 */ + 0x1f, 0x00, /* 000111110000 */ + 0x0e, 0x00, /* 000011100000 */ + 0x04, 0x00, /* 000001000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 19 0x13 '^S' */ + 0x00, 0x00, /* 000000000000 */ + 0x31, 0x80, /* 001100011000 */ + 0x31, 0x80, /* 001100011000 */ + 0x31, 0x80, /* 001100011000 */ + 0x31, 0x80, /* 001100011000 */ + 0x31, 0x80, /* 001100011000 */ + 0x31, 0x80, /* 001100011000 */ + 0x31, 0x80, /* 001100011000 */ + 0x31, 0x80, /* 001100011000 */ + 0x31, 0x80, /* 001100011000 */ + 0x31, 0x80, /* 001100011000 */ + 0x31, 0x80, /* 001100011000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x31, 0x80, /* 001100011000 */ + 0x31, 0x80, /* 001100011000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 20 0x14 '^T' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x1f, 0xf0, /* 000111111111 */ + 0x3c, 0xc0, /* 001111001100 */ + 0x7c, 0xc0, /* 011111001100 */ + 0x7c, 0xc0, /* 011111001100 */ + 0x7c, 0xc0, /* 011111001100 */ + 0x3c, 0xc0, /* 001111001100 */ + 0x1c, 0xc0, /* 000111001100 */ + 0x0c, 0xc0, /* 000011001100 */ + 0x0c, 0xc0, /* 000011001100 */ + 0x0c, 0xc0, /* 000011001100 */ + 0x0c, 0xc0, /* 000011001100 */ + 0x0c, 0xc0, /* 000011001100 */ + 0x0c, 0xc0, /* 000011001100 */ + 0x1c, 0xe0, /* 000111001110 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 21 0x15 '^U' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x1f, 0x00, /* 000111110000 */ + 0x31, 0x80, /* 001100011000 */ + 0x31, 0x80, /* 001100011000 */ + 0x30, 0x00, /* 001100000000 */ + 0x30, 0x00, /* 001100000000 */ + 0x1f, 0x00, /* 000111110000 */ + 0x31, 0x80, /* 001100011000 */ + 0x31, 0x80, /* 001100011000 */ + 0x1f, 0x00, /* 000111110000 */ + 0x01, 0x80, /* 000000011000 */ + 0x01, 0x80, /* 000000011000 */ + 0x31, 0x80, /* 001100011000 */ + 0x31, 0x80, /* 001100011000 */ + 0x1f, 0x00, /* 000111110000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 22 0x16 '^V' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x7f, 0xe0, /* 011111111110 */ + 0x7f, 0xe0, /* 011111111110 */ + 0x7f, 0xe0, /* 011111111110 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 23 0x17 '^W' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x04, 0x00, /* 000001000000 */ + 0x0e, 0x00, /* 000011100000 */ + 0x1f, 0x00, /* 000111110000 */ + 0x3f, 0x80, /* 001111111000 */ + 0x7f, 0xc0, /* 011111111100 */ + 0x0e, 0x00, /* 000011100000 */ + 0x0e, 0x00, /* 000011100000 */ + 0x7f, 0xc0, /* 011111111100 */ + 0x3f, 0x80, /* 001111111000 */ + 0x1f, 0x00, /* 000111110000 */ + 0x0e, 0x00, /* 000011100000 */ + 0x04, 0x00, /* 000001000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x7f, 0xe0, /* 011111111110 */ + 0x7f, 0xe0, /* 011111111110 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 24 0x18 '^X' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x04, 0x00, /* 000001000000 */ + 0x0e, 0x00, /* 000011100000 */ + 0x1f, 0x00, /* 000111110000 */ + 0x3f, 0x80, /* 001111111000 */ + 0x7f, 0xc0, /* 011111111100 */ + 0x0e, 0x00, /* 000011100000 */ + 0x0e, 0x00, /* 000011100000 */ + 0x0e, 0x00, /* 000011100000 */ + 0x0e, 0x00, /* 000011100000 */ + 0x0e, 0x00, /* 000011100000 */ + 0x0e, 0x00, /* 000011100000 */ + 0x0e, 0x00, /* 000011100000 */ + 0x0e, 0x00, /* 000011100000 */ + 0x0e, 0x00, /* 000011100000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 25 0x19 '^Y' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x0e, 0x00, /* 000011100000 */ + 0x0e, 0x00, /* 000011100000 */ + 0x0e, 0x00, /* 000011100000 */ + 0x0e, 0x00, /* 000011100000 */ + 0x0e, 0x00, /* 000011100000 */ + 0x0e, 0x00, /* 000011100000 */ + 0x0e, 0x00, /* 000011100000 */ + 0x0e, 0x00, /* 000011100000 */ + 0x0e, 0x00, /* 000011100000 */ + 0x0e, 0x00, /* 000011100000 */ + 0x7f, 0xc0, /* 011111111100 */ + 0x3f, 0x80, /* 001111111000 */ + 0x1f, 0x00, /* 000111110000 */ + 0x0e, 0x00, /* 000011100000 */ + 0x04, 0x00, /* 000001000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 26 0x1a '^Z' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x08, 0x00, /* 000010000000 */ + 0x18, 0x00, /* 000110000000 */ + 0x38, 0x00, /* 001110000000 */ + 0x7f, 0xe0, /* 011111111110 */ + 0xff, 0xe0, /* 111111111110 */ + 0x7f, 0xe0, /* 011111111110 */ + 0x38, 0x00, /* 001110000000 */ + 0x18, 0x00, /* 000110000000 */ + 0x08, 0x00, /* 000010000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 27 0x1b '^[' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x01, 0x00, /* 000000010000 */ + 0x01, 0x80, /* 000000011000 */ + 0x01, 0xc0, /* 000000011100 */ + 0x7f, 0xe0, /* 011111111110 */ + 0x7f, 0xf0, /* 011111111111 */ + 0x7f, 0xe0, /* 011111111110 */ + 0x01, 0xc0, /* 000000011100 */ + 0x01, 0x80, /* 000000011000 */ + 0x01, 0x00, /* 000000010000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 28 0x1c '^' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x30, 0x00, /* 001100000000 */ + 0x30, 0x00, /* 001100000000 */ + 0x3f, 0xe0, /* 001111111110 */ + 0x3f, 0xe0, /* 001111111110 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 29 0x1d '^]' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x09, 0x00, /* 000010010000 */ + 0x19, 0x80, /* 000110011000 */ + 0x39, 0xc0, /* 001110011100 */ + 0x7f, 0xe0, /* 011111111110 */ + 0xff, 0xf0, /* 111111111111 */ + 0x7f, 0xe0, /* 011111111110 */ + 0x39, 0xc0, /* 001110011100 */ + 0x19, 0x80, /* 000110011000 */ + 0x09, 0x00, /* 000010010000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 30 0x1e '^^' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x04, 0x00, /* 000001000000 */ + 0x04, 0x00, /* 000001000000 */ + 0x0e, 0x00, /* 000011100000 */ + 0x0e, 0x00, /* 000011100000 */ + 0x1f, 0x00, /* 000111110000 */ + 0x1f, 0x00, /* 000111110000 */ + 0x3f, 0x80, /* 001111111000 */ + 0x3f, 0x80, /* 001111111000 */ + 0x7f, 0xc0, /* 011111111100 */ + 0x7f, 0xc0, /* 011111111100 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 31 0x1f '^_' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x7f, 0xc0, /* 011111111100 */ + 0x7f, 0xc0, /* 011111111100 */ + 0x3f, 0x80, /* 001111111000 */ + 0x3f, 0x80, /* 001111111000 */ + 0x1f, 0x00, /* 000111110000 */ + 0x1f, 0x00, /* 000111110000 */ + 0x0e, 0x00, /* 000011100000 */ + 0x0e, 0x00, /* 000011100000 */ + 0x04, 0x00, /* 000001000000 */ + 0x04, 0x00, /* 000001000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 32 0x20 ' ' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 33 0x21 '!' */ + 0x00, 0x00, /* 000000000000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 34 0x22 '"' */ + 0x00, 0x00, /* 000000000000 */ + 0x19, 0x80, /* 000110011000 */ + 0x19, 0x80, /* 000110011000 */ + 0x19, 0x80, /* 000110011000 */ + 0x19, 0x80, /* 000110011000 */ + 0x19, 0x80, /* 000110011000 */ + 0x19, 0x80, /* 000110011000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 35 0x23 '#' */ + 0x00, 0x00, /* 000000000000 */ + 0x03, 0x30, /* 000000110011 */ + 0x03, 0x30, /* 000000110011 */ + 0x03, 0x30, /* 000000110011 */ + 0x06, 0x60, /* 000001100110 */ + 0x1f, 0xf0, /* 000111111111 */ + 0x1f, 0xf0, /* 000111111111 */ + 0x0c, 0xc0, /* 000011001100 */ + 0x0c, 0xc0, /* 000011001100 */ + 0x19, 0x80, /* 000110011000 */ + 0x19, 0x80, /* 000110011000 */ + 0x7f, 0xc0, /* 011111111100 */ + 0x7f, 0xc0, /* 011111111100 */ + 0x33, 0x00, /* 001100110000 */ + 0x66, 0x00, /* 011001100000 */ + 0x66, 0x00, /* 011001100000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 36 0x24 '$' */ + 0x00, 0x00, /* 000000000000 */ + 0x06, 0x00, /* 000001100000 */ + 0x1f, 0x80, /* 000111111000 */ + 0x3f, 0xc0, /* 001111111100 */ + 0x66, 0xe0, /* 011001101110 */ + 0x66, 0x60, /* 011001100110 */ + 0x66, 0x00, /* 011001100000 */ + 0x3e, 0x00, /* 001111100000 */ + 0x1f, 0x80, /* 000111111000 */ + 0x07, 0xc0, /* 000001111100 */ + 0x06, 0x60, /* 000001100110 */ + 0x06, 0x60, /* 000001100110 */ + 0x66, 0x60, /* 011001100110 */ + 0x7f, 0xc0, /* 011111111100 */ + 0x3f, 0x80, /* 001111111000 */ + 0x06, 0x00, /* 000001100000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 37 0x25 '%' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x38, 0xc0, /* 001110001100 */ + 0x4c, 0xc0, /* 010011001100 */ + 0x45, 0x80, /* 010001011000 */ + 0x65, 0x80, /* 011001011000 */ + 0x3b, 0x00, /* 001110110000 */ + 0x03, 0x00, /* 000000110000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x0d, 0xc0, /* 000011011100 */ + 0x1a, 0x60, /* 000110100110 */ + 0x1a, 0x20, /* 000110100010 */ + 0x33, 0x20, /* 001100110010 */ + 0x31, 0xc0, /* 001100011100 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 38 0x26 '&' */ + 0x00, 0x00, /* 000000000000 */ + 0x07, 0x00, /* 000001110000 */ + 0x0f, 0x80, /* 000011111000 */ + 0x18, 0xc0, /* 000110001100 */ + 0x18, 0xc0, /* 000110001100 */ + 0x18, 0xc0, /* 000110001100 */ + 0x0f, 0x80, /* 000011111000 */ + 0x1e, 0x00, /* 000111100000 */ + 0x3e, 0x00, /* 001111100000 */ + 0x77, 0x00, /* 011101110000 */ + 0x63, 0x60, /* 011000110110 */ + 0x61, 0xe0, /* 011000011110 */ + 0x61, 0xc0, /* 011000011100 */ + 0x61, 0x80, /* 011000011000 */ + 0x3f, 0xe0, /* 001111111110 */ + 0x1e, 0x60, /* 000111100110 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 39 0x27 ''' */ + 0x00, 0x00, /* 000000000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x1e, 0x00, /* 000111100000 */ + 0x1e, 0x00, /* 000111100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x18, 0x00, /* 000110000000 */ + 0x10, 0x00, /* 000100000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 40 0x28 '(' */ + 0x00, 0x00, /* 000000000000 */ + 0x01, 0x80, /* 000000011000 */ + 0x03, 0x00, /* 000000110000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x03, 0x00, /* 000000110000 */ + 0x01, 0x80, /* 000000011000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 41 0x29 ')' */ + 0x00, 0x00, /* 000000000000 */ + 0x18, 0x00, /* 000110000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x03, 0x00, /* 000000110000 */ + 0x03, 0x00, /* 000000110000 */ + 0x03, 0x00, /* 000000110000 */ + 0x03, 0x00, /* 000000110000 */ + 0x03, 0x00, /* 000000110000 */ + 0x03, 0x00, /* 000000110000 */ + 0x03, 0x00, /* 000000110000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x18, 0x00, /* 000110000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 42 0x2a '*' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x0f, 0x00, /* 000011110000 */ + 0x06, 0x00, /* 000001100000 */ + 0x66, 0x60, /* 011001100110 */ + 0x76, 0xe0, /* 011101101110 */ + 0x19, 0x80, /* 000110011000 */ + 0x00, 0x00, /* 000000000000 */ + 0x19, 0x80, /* 000110011000 */ + 0x76, 0xe0, /* 011101101110 */ + 0x66, 0x60, /* 011001100110 */ + 0x06, 0x00, /* 000001100000 */ + 0x0f, 0x00, /* 000011110000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 43 0x2b '+' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x7f, 0xe0, /* 011111111110 */ + 0x7f, 0xe0, /* 011111111110 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 44 0x2c ',' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x1e, 0x00, /* 000111100000 */ + 0x1e, 0x00, /* 000111100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x18, 0x00, /* 000110000000 */ + 0x10, 0x00, /* 000100000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 45 0x2d '-' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x7f, 0xe0, /* 011111111110 */ + 0x7f, 0xe0, /* 011111111110 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 46 0x2e '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x1e, 0x00, /* 000111100000 */ + 0x1e, 0x00, /* 000111100000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 47 0x2f '/' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x60, /* 000000000110 */ + 0x00, 0xc0, /* 000000001100 */ + 0x00, 0xc0, /* 000000001100 */ + 0x01, 0x80, /* 000000011000 */ + 0x01, 0x80, /* 000000011000 */ + 0x03, 0x00, /* 000000110000 */ + 0x03, 0x00, /* 000000110000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x18, 0x00, /* 000110000000 */ + 0x18, 0x00, /* 000110000000 */ + 0x30, 0x00, /* 001100000000 */ + 0x30, 0x00, /* 001100000000 */ + 0x60, 0x00, /* 011000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 48 0x30 '0' */ + 0x00, 0x00, /* 000000000000 */ + 0x07, 0x00, /* 000001110000 */ + 0x0f, 0x80, /* 000011111000 */ + 0x11, 0x80, /* 000100011000 */ + 0x10, 0xc0, /* 000100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0x80, /* 001100001000 */ + 0x18, 0x80, /* 000110001000 */ + 0x1f, 0x00, /* 000111110000 */ + 0x0e, 0x00, /* 000011100000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 49 0x31 '1' */ + 0x00, 0x00, /* 000000000000 */ + 0x02, 0x00, /* 000000100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x0e, 0x00, /* 000011100000 */ + 0x1e, 0x00, /* 000111100000 */ + 0x36, 0x00, /* 001101100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x3f, 0xc0, /* 001111111100 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 50 0x32 '2' */ + 0x00, 0x00, /* 000000000000 */ + 0x1f, 0x00, /* 000111110000 */ + 0x3f, 0x80, /* 001111111000 */ + 0x61, 0xc0, /* 011000011100 */ + 0x40, 0xc0, /* 010000001100 */ + 0x00, 0xc0, /* 000000001100 */ + 0x00, 0xc0, /* 000000001100 */ + 0x00, 0xc0, /* 000000001100 */ + 0x01, 0x80, /* 000000011000 */ + 0x03, 0x00, /* 000000110000 */ + 0x06, 0x00, /* 000001100000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x18, 0x00, /* 000110000000 */ + 0x30, 0x20, /* 001100000010 */ + 0x7f, 0xe0, /* 011111111110 */ + 0x7f, 0xe0, /* 011111111110 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 51 0x33 '3' */ + 0x00, 0x00, /* 000000000000 */ + 0x0f, 0x80, /* 000011111000 */ + 0x1f, 0xc0, /* 000111111100 */ + 0x20, 0xe0, /* 001000001110 */ + 0x40, 0x60, /* 010000000110 */ + 0x00, 0x60, /* 000000000110 */ + 0x00, 0xe0, /* 000000001110 */ + 0x07, 0xc0, /* 000001111100 */ + 0x0f, 0xc0, /* 000011111100 */ + 0x00, 0xe0, /* 000000001110 */ + 0x00, 0x60, /* 000000000110 */ + 0x00, 0x60, /* 000000000110 */ + 0x40, 0x60, /* 010000000110 */ + 0x60, 0x40, /* 011000000100 */ + 0x3f, 0x80, /* 001111111000 */ + 0x1f, 0x00, /* 000111110000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 52 0x34 '4' */ + 0x00, 0x00, /* 000000000000 */ + 0x01, 0x80, /* 000000011000 */ + 0x03, 0x80, /* 000000111000 */ + 0x03, 0x80, /* 000000111000 */ + 0x05, 0x80, /* 000001011000 */ + 0x05, 0x80, /* 000001011000 */ + 0x09, 0x80, /* 000010011000 */ + 0x09, 0x80, /* 000010011000 */ + 0x11, 0x80, /* 000100011000 */ + 0x11, 0x80, /* 000100011000 */ + 0x21, 0x80, /* 001000011000 */ + 0x3f, 0xe0, /* 001111111110 */ + 0x7f, 0xe0, /* 011111111110 */ + 0x01, 0x80, /* 000000011000 */ + 0x01, 0x80, /* 000000011000 */ + 0x01, 0x80, /* 000000011000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 53 0x35 '5' */ + 0x00, 0x00, /* 000000000000 */ + 0x0f, 0xc0, /* 000011111100 */ + 0x0f, 0xc0, /* 000011111100 */ + 0x10, 0x00, /* 000100000000 */ + 0x10, 0x00, /* 000100000000 */ + 0x20, 0x00, /* 001000000000 */ + 0x3f, 0x80, /* 001111111000 */ + 0x31, 0xc0, /* 001100011100 */ + 0x00, 0xe0, /* 000000001110 */ + 0x00, 0x60, /* 000000000110 */ + 0x00, 0x60, /* 000000000110 */ + 0x00, 0x60, /* 000000000110 */ + 0x40, 0x60, /* 010000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x30, 0xc0, /* 001100001100 */ + 0x1f, 0x80, /* 000111111000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 54 0x36 '6' */ + 0x00, 0x00, /* 000000000000 */ + 0x07, 0x00, /* 000001110000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x18, 0x00, /* 000110000000 */ + 0x30, 0x00, /* 001100000000 */ + 0x30, 0x00, /* 001100000000 */ + 0x60, 0x00, /* 011000000000 */ + 0x67, 0x80, /* 011001111000 */ + 0x6f, 0xc0, /* 011011111100 */ + 0x70, 0xe0, /* 011100001110 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x70, 0x40, /* 011100000100 */ + 0x3f, 0x80, /* 001111111000 */ + 0x1f, 0x00, /* 000111110000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 55 0x37 '7' */ + 0x00, 0x00, /* 000000000000 */ + 0x1f, 0xe0, /* 000111111110 */ + 0x3f, 0xe0, /* 001111111110 */ + 0x60, 0x40, /* 011000000100 */ + 0x00, 0x40, /* 000000000100 */ + 0x00, 0xc0, /* 000000001100 */ + 0x00, 0x80, /* 000000001000 */ + 0x00, 0x80, /* 000000001000 */ + 0x01, 0x80, /* 000000011000 */ + 0x01, 0x00, /* 000000010000 */ + 0x01, 0x00, /* 000000010000 */ + 0x03, 0x00, /* 000000110000 */ + 0x02, 0x00, /* 000000100000 */ + 0x02, 0x00, /* 000000100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x04, 0x00, /* 000001000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 56 0x38 '8' */ + 0x00, 0x00, /* 000000000000 */ + 0x0f, 0x00, /* 000011110000 */ + 0x11, 0x80, /* 000100011000 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x18, 0x80, /* 000110001000 */ + 0x0d, 0x00, /* 000011010000 */ + 0x06, 0x00, /* 000001100000 */ + 0x0b, 0x00, /* 000010110000 */ + 0x11, 0x80, /* 000100011000 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x18, 0x80, /* 000110001000 */ + 0x0f, 0x00, /* 000011110000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 57 0x39 '9' */ + 0x00, 0x00, /* 000000000000 */ + 0x0f, 0x80, /* 000011111000 */ + 0x11, 0xc0, /* 000100011100 */ + 0x20, 0xe0, /* 001000001110 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x70, 0xe0, /* 011100001110 */ + 0x3f, 0x60, /* 001111110110 */ + 0x1e, 0x60, /* 000111100110 */ + 0x00, 0x60, /* 000000000110 */ + 0x00, 0xc0, /* 000000001100 */ + 0x00, 0xc0, /* 000000001100 */ + 0x01, 0x80, /* 000000011000 */ + 0x07, 0x00, /* 000001110000 */ + 0x3c, 0x00, /* 001111000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 58 0x3a ':' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x1e, 0x00, /* 000111100000 */ + 0x1e, 0x00, /* 000111100000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x1e, 0x00, /* 000111100000 */ + 0x1e, 0x00, /* 000111100000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 59 0x3b ';' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x1e, 0x00, /* 000111100000 */ + 0x1e, 0x00, /* 000111100000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x1e, 0x00, /* 000111100000 */ + 0x1e, 0x00, /* 000111100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x18, 0x00, /* 000110000000 */ + 0x10, 0x00, /* 000100000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 60 0x3c '<' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x60, /* 000000000110 */ + 0x01, 0xc0, /* 000000011100 */ + 0x07, 0x00, /* 000001110000 */ + 0x1c, 0x00, /* 000111000000 */ + 0x70, 0x00, /* 011100000000 */ + 0x70, 0x00, /* 011100000000 */ + 0x1c, 0x00, /* 000111000000 */ + 0x07, 0x00, /* 000001110000 */ + 0x01, 0xc0, /* 000000011100 */ + 0x00, 0x60, /* 000000000110 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 61 0x3d '=' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x7f, 0xe0, /* 011111111110 */ + 0x7f, 0xe0, /* 011111111110 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x7f, 0xe0, /* 011111111110 */ + 0x7f, 0xe0, /* 011111111110 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 62 0x3e '>' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x60, 0x00, /* 011000000000 */ + 0x38, 0x00, /* 001110000000 */ + 0x0e, 0x00, /* 000011100000 */ + 0x03, 0x80, /* 000000111000 */ + 0x00, 0xe0, /* 000000001110 */ + 0x00, 0xe0, /* 000000001110 */ + 0x03, 0x80, /* 000000111000 */ + 0x0e, 0x00, /* 000011100000 */ + 0x38, 0x00, /* 001110000000 */ + 0x60, 0x00, /* 011000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 63 0x3f '?' */ + 0x00, 0x00, /* 000000000000 */ + 0x0f, 0x00, /* 000011110000 */ + 0x1f, 0x80, /* 000111111000 */ + 0x39, 0xc0, /* 001110011100 */ + 0x20, 0xc0, /* 001000001100 */ + 0x00, 0xc0, /* 000000001100 */ + 0x00, 0xc0, /* 000000001100 */ + 0x01, 0x80, /* 000000011000 */ + 0x03, 0x00, /* 000000110000 */ + 0x06, 0x00, /* 000001100000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 64 0x40 '@' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x0f, 0x80, /* 000011111000 */ + 0x3f, 0xc0, /* 001111111100 */ + 0x30, 0x60, /* 001100000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x67, 0x20, /* 011001110010 */ + 0x6f, 0xa0, /* 011011111010 */ + 0x6c, 0xa0, /* 011011001010 */ + 0x6c, 0xa0, /* 011011001010 */ + 0x67, 0xe0, /* 011001111110 */ + 0x60, 0x00, /* 011000000000 */ + 0x30, 0x00, /* 001100000000 */ + 0x3f, 0xe0, /* 001111111110 */ + 0x0f, 0xe0, /* 000011111110 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 65 0x41 'A' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x0b, 0x00, /* 000010110000 */ + 0x0b, 0x00, /* 000010110000 */ + 0x09, 0x00, /* 000010010000 */ + 0x11, 0x80, /* 000100011000 */ + 0x11, 0x80, /* 000100011000 */ + 0x10, 0x80, /* 000100001000 */ + 0x3f, 0xc0, /* 001111111100 */ + 0x20, 0xc0, /* 001000001100 */ + 0x20, 0x40, /* 001000000100 */ + 0x40, 0x60, /* 010000000110 */ + 0x40, 0x60, /* 010000000110 */ + 0xe0, 0xf0, /* 111000001111 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 66 0x42 'B' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0xff, 0x00, /* 111111110000 */ + 0x60, 0x80, /* 011000001000 */ + 0x60, 0xc0, /* 011000001100 */ + 0x60, 0xc0, /* 011000001100 */ + 0x60, 0xc0, /* 011000001100 */ + 0x61, 0x80, /* 011000011000 */ + 0x7f, 0x80, /* 011111111000 */ + 0x60, 0xc0, /* 011000001100 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0xc0, /* 011000001100 */ + 0xff, 0x80, /* 111111111000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 67 0x43 'C' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x0f, 0xc0, /* 000011111100 */ + 0x10, 0x60, /* 000100000110 */ + 0x20, 0x20, /* 001000000010 */ + 0x20, 0x00, /* 001000000000 */ + 0x60, 0x00, /* 011000000000 */ + 0x60, 0x00, /* 011000000000 */ + 0x60, 0x00, /* 011000000000 */ + 0x60, 0x00, /* 011000000000 */ + 0x60, 0x00, /* 011000000000 */ + 0x60, 0x00, /* 011000000000 */ + 0x20, 0x00, /* 001000000000 */ + 0x30, 0x20, /* 001100000010 */ + 0x18, 0x40, /* 000110000100 */ + 0x0f, 0x80, /* 000011111000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 68 0x44 'D' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0xff, 0x00, /* 111111110000 */ + 0x61, 0xc0, /* 011000011100 */ + 0x60, 0xc0, /* 011000001100 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x40, /* 011000000100 */ + 0x61, 0x80, /* 011000011000 */ + 0xfe, 0x00, /* 111111100000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 69 0x45 'E' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x7f, 0xc0, /* 011111111100 */ + 0x30, 0x40, /* 001100000100 */ + 0x30, 0x40, /* 001100000100 */ + 0x30, 0x00, /* 001100000000 */ + 0x30, 0x00, /* 001100000000 */ + 0x30, 0x80, /* 001100001000 */ + 0x3f, 0x80, /* 001111111000 */ + 0x30, 0x80, /* 001100001000 */ + 0x30, 0x00, /* 001100000000 */ + 0x30, 0x00, /* 001100000000 */ + 0x30, 0x00, /* 001100000000 */ + 0x30, 0x20, /* 001100000010 */ + 0x30, 0x20, /* 001100000010 */ + 0x7f, 0xe0, /* 011111111110 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 70 0x46 'F' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x7f, 0xc0, /* 011111111100 */ + 0x30, 0x40, /* 001100000100 */ + 0x30, 0x40, /* 001100000100 */ + 0x30, 0x00, /* 001100000000 */ + 0x30, 0x00, /* 001100000000 */ + 0x30, 0x80, /* 001100001000 */ + 0x3f, 0x80, /* 001111111000 */ + 0x30, 0x80, /* 001100001000 */ + 0x30, 0x00, /* 001100000000 */ + 0x30, 0x00, /* 001100000000 */ + 0x30, 0x00, /* 001100000000 */ + 0x30, 0x00, /* 001100000000 */ + 0x30, 0x00, /* 001100000000 */ + 0x78, 0x00, /* 011110000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 71 0x47 'G' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x0f, 0xc0, /* 000011111100 */ + 0x10, 0x60, /* 000100000110 */ + 0x20, 0x20, /* 001000000010 */ + 0x20, 0x00, /* 001000000000 */ + 0x60, 0x00, /* 011000000000 */ + 0x60, 0x00, /* 011000000000 */ + 0x60, 0x00, /* 011000000000 */ + 0x60, 0x00, /* 011000000000 */ + 0x61, 0xf0, /* 011000011111 */ + 0x60, 0x60, /* 011000000110 */ + 0x20, 0x60, /* 001000000110 */ + 0x30, 0x60, /* 001100000110 */ + 0x18, 0x60, /* 000110000110 */ + 0x0f, 0x80, /* 000011111000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 72 0x48 'H' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0xf0, 0xf0, /* 111100001111 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x7f, 0xe0, /* 011111111110 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0xf0, 0xf0, /* 111100001111 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 73 0x49 'I' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x1f, 0x80, /* 000111111000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x1f, 0x80, /* 000111111000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 74 0x4a 'J' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x1f, 0x80, /* 000111111000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x04, 0x00, /* 000001000000 */ + 0x38, 0x00, /* 001110000000 */ + 0x30, 0x00, /* 001100000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 75 0x4b 'K' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0xf0, 0xe0, /* 111100001110 */ + 0x61, 0x80, /* 011000011000 */ + 0x63, 0x00, /* 011000110000 */ + 0x66, 0x00, /* 011001100000 */ + 0x6c, 0x00, /* 011011000000 */ + 0x78, 0x00, /* 011110000000 */ + 0x78, 0x00, /* 011110000000 */ + 0x7c, 0x00, /* 011111000000 */ + 0x6e, 0x00, /* 011011100000 */ + 0x67, 0x00, /* 011001110000 */ + 0x63, 0x80, /* 011000111000 */ + 0x61, 0xc0, /* 011000011100 */ + 0x60, 0xe0, /* 011000001110 */ + 0xf0, 0x70, /* 111100000111 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 76 0x4c 'L' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x78, 0x00, /* 011110000000 */ + 0x30, 0x00, /* 001100000000 */ + 0x30, 0x00, /* 001100000000 */ + 0x30, 0x00, /* 001100000000 */ + 0x30, 0x00, /* 001100000000 */ + 0x30, 0x00, /* 001100000000 */ + 0x30, 0x00, /* 001100000000 */ + 0x30, 0x00, /* 001100000000 */ + 0x30, 0x00, /* 001100000000 */ + 0x30, 0x00, /* 001100000000 */ + 0x30, 0x00, /* 001100000000 */ + 0x30, 0x20, /* 001100000010 */ + 0x30, 0x20, /* 001100000010 */ + 0x7f, 0xe0, /* 011111111110 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 77 0x4d 'M' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0xe0, 0x70, /* 111000000111 */ + 0x60, 0xe0, /* 011000001110 */ + 0x70, 0xe0, /* 011100001110 */ + 0x70, 0xe0, /* 011100001110 */ + 0x70, 0xe0, /* 011100001110 */ + 0x59, 0x60, /* 010110010110 */ + 0x59, 0x60, /* 010110010110 */ + 0x59, 0x60, /* 010110010110 */ + 0x4d, 0x60, /* 010011010110 */ + 0x4e, 0x60, /* 010011100110 */ + 0x4e, 0x60, /* 010011100110 */ + 0x44, 0x60, /* 010001000110 */ + 0x44, 0x60, /* 010001000110 */ + 0xe4, 0xf0, /* 111001001111 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 78 0x4e 'N' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0xc0, 0x70, /* 110000000111 */ + 0x60, 0x20, /* 011000000010 */ + 0x70, 0x20, /* 011100000010 */ + 0x78, 0x20, /* 011110000010 */ + 0x58, 0x20, /* 010110000010 */ + 0x4c, 0x20, /* 010011000010 */ + 0x46, 0x20, /* 010001100010 */ + 0x47, 0x20, /* 010001110010 */ + 0x43, 0x20, /* 010000110010 */ + 0x41, 0xa0, /* 010000011010 */ + 0x40, 0xe0, /* 010000001110 */ + 0x40, 0xe0, /* 010000001110 */ + 0x40, 0x60, /* 010000000110 */ + 0xe0, 0x30, /* 111000000011 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 79 0x4f 'O' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x0f, 0x00, /* 000011110000 */ + 0x11, 0xc0, /* 000100011100 */ + 0x20, 0xc0, /* 001000001100 */ + 0x20, 0x60, /* 001000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x20, 0x40, /* 001000000100 */ + 0x30, 0x40, /* 001100000100 */ + 0x18, 0x80, /* 000110001000 */ + 0x0f, 0x00, /* 000011110000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 80 0x50 'P' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x7f, 0x80, /* 011111111000 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0x60, /* 001100000110 */ + 0x30, 0x60, /* 001100000110 */ + 0x30, 0x60, /* 001100000110 */ + 0x30, 0xc0, /* 001100001100 */ + 0x37, 0x80, /* 001101111000 */ + 0x30, 0x00, /* 001100000000 */ + 0x30, 0x00, /* 001100000000 */ + 0x30, 0x00, /* 001100000000 */ + 0x30, 0x00, /* 001100000000 */ + 0x30, 0x00, /* 001100000000 */ + 0x30, 0x00, /* 001100000000 */ + 0x78, 0x00, /* 011110000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 81 0x51 'Q' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x0f, 0x00, /* 000011110000 */ + 0x11, 0xc0, /* 000100011100 */ + 0x20, 0xc0, /* 001000001100 */ + 0x20, 0x60, /* 001000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x30, 0x40, /* 001100000100 */ + 0x38, 0x40, /* 001110000100 */ + 0x1f, 0x80, /* 000111111000 */ + 0x0e, 0x00, /* 000011100000 */ + 0x1f, 0x00, /* 000111110000 */ + 0x23, 0x90, /* 001000111001 */ + 0x01, 0xe0, /* 000000011110 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 82 0x52 'R' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0xff, 0x00, /* 111111110000 */ + 0x61, 0x80, /* 011000011000 */ + 0x60, 0xc0, /* 011000001100 */ + 0x60, 0xc0, /* 011000001100 */ + 0x60, 0xc0, /* 011000001100 */ + 0x60, 0x80, /* 011000001000 */ + 0x7f, 0x00, /* 011111110000 */ + 0x7c, 0x00, /* 011111000000 */ + 0x6e, 0x00, /* 011011100000 */ + 0x67, 0x00, /* 011001110000 */ + 0x63, 0x80, /* 011000111000 */ + 0x61, 0xc0, /* 011000011100 */ + 0x60, 0xe0, /* 011000001110 */ + 0xf0, 0x70, /* 111100000111 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 83 0x53 'S' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x1f, 0xe0, /* 000111111110 */ + 0x30, 0x60, /* 001100000110 */ + 0x60, 0x20, /* 011000000010 */ + 0x60, 0x20, /* 011000000010 */ + 0x70, 0x00, /* 011100000000 */ + 0x3c, 0x00, /* 001111000000 */ + 0x1e, 0x00, /* 000111100000 */ + 0x07, 0x80, /* 000001111000 */ + 0x01, 0xc0, /* 000000011100 */ + 0x00, 0xe0, /* 000000001110 */ + 0x40, 0x60, /* 010000000110 */ + 0x40, 0x60, /* 010000000110 */ + 0x60, 0xc0, /* 011000001100 */ + 0x7f, 0x80, /* 011111111000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 84 0x54 'T' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x7f, 0xe0, /* 011111111110 */ + 0x46, 0x20, /* 010001100010 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x1f, 0x80, /* 000111111000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 85 0x55 'U' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0xf0, 0x70, /* 111100000111 */ + 0x60, 0x20, /* 011000000010 */ + 0x60, 0x20, /* 011000000010 */ + 0x60, 0x20, /* 011000000010 */ + 0x60, 0x20, /* 011000000010 */ + 0x60, 0x20, /* 011000000010 */ + 0x60, 0x20, /* 011000000010 */ + 0x60, 0x20, /* 011000000010 */ + 0x60, 0x20, /* 011000000010 */ + 0x60, 0x20, /* 011000000010 */ + 0x60, 0x20, /* 011000000010 */ + 0x70, 0x40, /* 011100000100 */ + 0x3f, 0xc0, /* 001111111100 */ + 0x1f, 0x80, /* 000111111000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 86 0x56 'V' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0xe0, 0xe0, /* 111000001110 */ + 0x60, 0x40, /* 011000000100 */ + 0x30, 0x80, /* 001100001000 */ + 0x30, 0x80, /* 001100001000 */ + 0x30, 0x80, /* 001100001000 */ + 0x19, 0x00, /* 000110010000 */ + 0x19, 0x00, /* 000110010000 */ + 0x19, 0x00, /* 000110010000 */ + 0x0a, 0x00, /* 000010100000 */ + 0x0e, 0x00, /* 000011100000 */ + 0x0e, 0x00, /* 000011100000 */ + 0x04, 0x00, /* 000001000000 */ + 0x04, 0x00, /* 000001000000 */ + 0x04, 0x00, /* 000001000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 87 0x57 'W' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0xfe, 0xf0, /* 111111101111 */ + 0x66, 0x20, /* 011001100010 */ + 0x66, 0x20, /* 011001100010 */ + 0x66, 0x20, /* 011001100010 */ + 0x76, 0x20, /* 011101100010 */ + 0x77, 0x40, /* 011101110100 */ + 0x33, 0x40, /* 001100110100 */ + 0x37, 0x40, /* 001101110100 */ + 0x3b, 0xc0, /* 001110111100 */ + 0x3b, 0x80, /* 001110111000 */ + 0x19, 0x80, /* 000110011000 */ + 0x19, 0x80, /* 000110011000 */ + 0x19, 0x80, /* 000110011000 */ + 0x19, 0x80, /* 000110011000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 88 0x58 'X' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0xf0, 0x70, /* 111100000111 */ + 0x60, 0x20, /* 011000000010 */ + 0x30, 0x40, /* 001100000100 */ + 0x38, 0x80, /* 001110001000 */ + 0x18, 0x80, /* 000110001000 */ + 0x0d, 0x00, /* 000011010000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x0b, 0x00, /* 000010110000 */ + 0x11, 0x80, /* 000100011000 */ + 0x11, 0xc0, /* 000100011100 */ + 0x20, 0xc0, /* 001000001100 */ + 0x40, 0x60, /* 010000000110 */ + 0xe0, 0xf0, /* 111000001111 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 89 0x59 'Y' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0xf0, 0x70, /* 111100000111 */ + 0x60, 0x20, /* 011000000010 */ + 0x30, 0x40, /* 001100000100 */ + 0x18, 0x80, /* 000110001000 */ + 0x18, 0x80, /* 000110001000 */ + 0x0d, 0x00, /* 000011010000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x0f, 0x00, /* 000011110000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 90 0x5a 'Z' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x3f, 0xe0, /* 001111111110 */ + 0x20, 0xc0, /* 001000001100 */ + 0x00, 0xc0, /* 000000001100 */ + 0x01, 0x80, /* 000000011000 */ + 0x01, 0x80, /* 000000011000 */ + 0x03, 0x00, /* 000000110000 */ + 0x03, 0x00, /* 000000110000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x18, 0x00, /* 000110000000 */ + 0x18, 0x20, /* 000110000010 */ + 0x3f, 0xe0, /* 001111111110 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 91 0x5b '[' */ + 0x00, 0x00, /* 000000000000 */ + 0x0f, 0x80, /* 000011111000 */ + 0x0f, 0x80, /* 000011111000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x0f, 0x80, /* 000011111000 */ + 0x0f, 0x80, /* 000011111000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 92 0x5c '' */ + 0x00, 0x00, /* 000000000000 */ + 0x60, 0x00, /* 011000000000 */ + 0x30, 0x00, /* 001100000000 */ + 0x30, 0x00, /* 001100000000 */ + 0x18, 0x00, /* 000110000000 */ + 0x18, 0x00, /* 000110000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x03, 0x00, /* 000000110000 */ + 0x03, 0x00, /* 000000110000 */ + 0x01, 0x80, /* 000000011000 */ + 0x01, 0x80, /* 000000011000 */ + 0x00, 0xc0, /* 000000001100 */ + 0x00, 0xc0, /* 000000001100 */ + 0x00, 0x60, /* 000000000110 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 93 0x5d ']' */ + 0x00, 0x00, /* 000000000000 */ + 0x1f, 0x00, /* 000111110000 */ + 0x1f, 0x00, /* 000111110000 */ + 0x03, 0x00, /* 000000110000 */ + 0x03, 0x00, /* 000000110000 */ + 0x03, 0x00, /* 000000110000 */ + 0x03, 0x00, /* 000000110000 */ + 0x03, 0x00, /* 000000110000 */ + 0x03, 0x00, /* 000000110000 */ + 0x03, 0x00, /* 000000110000 */ + 0x03, 0x00, /* 000000110000 */ + 0x03, 0x00, /* 000000110000 */ + 0x03, 0x00, /* 000000110000 */ + 0x03, 0x00, /* 000000110000 */ + 0x1f, 0x00, /* 000111110000 */ + 0x1f, 0x00, /* 000111110000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 94 0x5e '^' */ + 0x00, 0x00, /* 000000000000 */ + 0x04, 0x00, /* 000001000000 */ + 0x0e, 0x00, /* 000011100000 */ + 0x1b, 0x00, /* 000110110000 */ + 0x31, 0x80, /* 001100011000 */ + 0x60, 0xc0, /* 011000001100 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 95 0x5f '_' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 96 0x60 '`' */ + 0x00, 0x00, /* 000000000000 */ + 0x01, 0x00, /* 000000010000 */ + 0x03, 0x00, /* 000000110000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x07, 0x80, /* 000001111000 */ + 0x07, 0x80, /* 000001111000 */ + 0x03, 0x00, /* 000000110000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 97 0x61 'a' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x0f, 0x80, /* 000011111000 */ + 0x18, 0xc0, /* 000110001100 */ + 0x10, 0xc0, /* 000100001100 */ + 0x03, 0xc0, /* 000000111100 */ + 0x1c, 0xc0, /* 000111001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x39, 0xc0, /* 001110011100 */ + 0x1e, 0xe0, /* 000111101110 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 98 0x62 'b' */ + 0x00, 0x00, /* 000000000000 */ + 0x20, 0x00, /* 001000000000 */ + 0x60, 0x00, /* 011000000000 */ + 0xe0, 0x00, /* 111000000000 */ + 0x60, 0x00, /* 011000000000 */ + 0x60, 0x00, /* 011000000000 */ + 0x67, 0x80, /* 011001111000 */ + 0x6f, 0xc0, /* 011011111100 */ + 0x70, 0xe0, /* 011100001110 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x70, 0x60, /* 011100000110 */ + 0x78, 0xc0, /* 011110001100 */ + 0x4f, 0x80, /* 010011111000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 99 0x63 'c' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x1f, 0x80, /* 000111111000 */ + 0x31, 0xc0, /* 001100011100 */ + 0x20, 0xc0, /* 001000001100 */ + 0x60, 0x00, /* 011000000000 */ + 0x60, 0x00, /* 011000000000 */ + 0x60, 0x00, /* 011000000000 */ + 0x60, 0x00, /* 011000000000 */ + 0x70, 0x40, /* 011100000100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x1f, 0x80, /* 000111111000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 100 0x64 'd' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x60, /* 000000000110 */ + 0x00, 0xe0, /* 000000001110 */ + 0x00, 0x60, /* 000000000110 */ + 0x00, 0x60, /* 000000000110 */ + 0x00, 0x60, /* 000000000110 */ + 0x0f, 0x60, /* 000011110110 */ + 0x31, 0xe0, /* 001100011110 */ + 0x20, 0xe0, /* 001000001110 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x70, 0xe0, /* 011100001110 */ + 0x39, 0x60, /* 001110010110 */ + 0x1e, 0x70, /* 000111100111 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 101 0x65 'e' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x0f, 0x00, /* 000011110000 */ + 0x30, 0xc0, /* 001100001100 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x7f, 0xe0, /* 011111111110 */ + 0x60, 0x00, /* 011000000000 */ + 0x60, 0x00, /* 011000000000 */ + 0x30, 0x00, /* 001100000000 */ + 0x18, 0x60, /* 000110000110 */ + 0x0f, 0x80, /* 000011111000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 102 0x66 'f' */ + 0x00, 0x00, /* 000000000000 */ + 0x03, 0x80, /* 000000111000 */ + 0x04, 0xc0, /* 000001001100 */ + 0x04, 0xc0, /* 000001001100 */ + 0x0c, 0x00, /* 000011000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x3f, 0x80, /* 001111111000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x1e, 0x00, /* 000111100000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 103 0x67 'g' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x1f, 0x20, /* 000111110010 */ + 0x31, 0xe0, /* 001100011110 */ + 0x60, 0xc0, /* 011000001100 */ + 0x60, 0xc0, /* 011000001100 */ + 0x60, 0xc0, /* 011000001100 */ + 0x31, 0x80, /* 001100011000 */ + 0x3f, 0x00, /* 001111110000 */ + 0x60, 0x00, /* 011000000000 */ + 0x7f, 0xc0, /* 011111111100 */ + 0x3f, 0xe0, /* 001111111110 */ + 0x20, 0x60, /* 001000000110 */ + 0x40, 0x20, /* 010000000010 */ + 0x40, 0x20, /* 010000000010 */ + 0x7f, 0xc0, /* 011111111100 */ + 0x3f, 0x80, /* 001111111000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 104 0x68 'h' */ + 0x00, 0x00, /* 000000000000 */ + 0x10, 0x00, /* 000100000000 */ + 0x30, 0x00, /* 001100000000 */ + 0x70, 0x00, /* 011100000000 */ + 0x30, 0x00, /* 001100000000 */ + 0x30, 0x00, /* 001100000000 */ + 0x37, 0x80, /* 001101111000 */ + 0x39, 0xc0, /* 001110011100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x79, 0xe0, /* 011110011110 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 105 0x69 'i' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x1e, 0x00, /* 000111100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x1f, 0x80, /* 000111111000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 106 0x6a 'j' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0xc0, /* 000000001100 */ + 0x00, 0xc0, /* 000000001100 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x03, 0xc0, /* 000000111100 */ + 0x00, 0xc0, /* 000000001100 */ + 0x00, 0xc0, /* 000000001100 */ + 0x00, 0xc0, /* 000000001100 */ + 0x00, 0xc0, /* 000000001100 */ + 0x00, 0xc0, /* 000000001100 */ + 0x00, 0xc0, /* 000000001100 */ + 0x00, 0xc0, /* 000000001100 */ + 0x00, 0xc0, /* 000000001100 */ + 0x00, 0xc0, /* 000000001100 */ + 0x20, 0xc0, /* 001000001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x38, 0x80, /* 001110001000 */ + 0x1f, 0x00, /* 000111110000 */ + 0x0e, 0x00, /* 000011100000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 107 0x6b 'k' */ + 0x00, 0x00, /* 000000000000 */ + 0x60, 0x00, /* 011000000000 */ + 0xe0, 0x00, /* 111000000000 */ + 0x60, 0x00, /* 011000000000 */ + 0x60, 0x00, /* 011000000000 */ + 0x60, 0x00, /* 011000000000 */ + 0x61, 0xc0, /* 011000011100 */ + 0x63, 0x00, /* 011000110000 */ + 0x66, 0x00, /* 011001100000 */ + 0x7c, 0x00, /* 011111000000 */ + 0x78, 0x00, /* 011110000000 */ + 0x7c, 0x00, /* 011111000000 */ + 0x6e, 0x00, /* 011011100000 */ + 0x67, 0x00, /* 011001110000 */ + 0x63, 0x80, /* 011000111000 */ + 0xf1, 0xe0, /* 111100011110 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 108 0x6c 'l' */ + 0x00, 0x00, /* 000000000000 */ + 0x1e, 0x00, /* 000111100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x1f, 0x80, /* 000111111000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 109 0x6d 'm' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0xdd, 0xc0, /* 110111011100 */ + 0x6e, 0xe0, /* 011011101110 */ + 0x66, 0x60, /* 011001100110 */ + 0x66, 0x60, /* 011001100110 */ + 0x66, 0x60, /* 011001100110 */ + 0x66, 0x60, /* 011001100110 */ + 0x66, 0x60, /* 011001100110 */ + 0x66, 0x60, /* 011001100110 */ + 0x66, 0x60, /* 011001100110 */ + 0xef, 0x70, /* 111011110111 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 110 0x6e 'n' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x27, 0x80, /* 001001111000 */ + 0x79, 0xc0, /* 011110011100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x79, 0xe0, /* 011110011110 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 111 0x6f 'o' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x0f, 0x80, /* 000011111000 */ + 0x11, 0xc0, /* 000100011100 */ + 0x20, 0xe0, /* 001000001110 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x70, 0x40, /* 011100000100 */ + 0x38, 0x80, /* 001110001000 */ + 0x1f, 0x00, /* 000111110000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 112 0x70 'p' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0xef, 0x80, /* 111011111000 */ + 0x71, 0xc0, /* 011100011100 */ + 0x60, 0xe0, /* 011000001110 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x40, /* 011000000100 */ + 0x70, 0x80, /* 011100001000 */ + 0x7f, 0x00, /* 011111110000 */ + 0x60, 0x00, /* 011000000000 */ + 0x60, 0x00, /* 011000000000 */ + 0x60, 0x00, /* 011000000000 */ + 0x60, 0x00, /* 011000000000 */ + 0xf0, 0x00, /* 111100000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 113 0x71 'q' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x0f, 0x20, /* 000011110010 */ + 0x11, 0xe0, /* 000100011110 */ + 0x20, 0xe0, /* 001000001110 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x70, 0x60, /* 011100000110 */ + 0x38, 0xe0, /* 001110001110 */ + 0x1f, 0xe0, /* 000111111110 */ + 0x00, 0x60, /* 000000000110 */ + 0x00, 0x60, /* 000000000110 */ + 0x00, 0x60, /* 000000000110 */ + 0x00, 0x60, /* 000000000110 */ + 0x00, 0xf0, /* 000000001111 */ + 0x00, 0x00, /* 000000000000 */ + + /* 114 0x72 'r' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x73, 0x80, /* 011100111000 */ + 0x34, 0xc0, /* 001101001100 */ + 0x38, 0xc0, /* 001110001100 */ + 0x30, 0x00, /* 001100000000 */ + 0x30, 0x00, /* 001100000000 */ + 0x30, 0x00, /* 001100000000 */ + 0x30, 0x00, /* 001100000000 */ + 0x30, 0x00, /* 001100000000 */ + 0x30, 0x00, /* 001100000000 */ + 0x78, 0x00, /* 011110000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 115 0x73 's' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x1f, 0xc0, /* 000111111100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0x40, /* 001100000100 */ + 0x38, 0x00, /* 001110000000 */ + 0x1e, 0x00, /* 000111100000 */ + 0x07, 0x80, /* 000001111000 */ + 0x01, 0xc0, /* 000000011100 */ + 0x20, 0xc0, /* 001000001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x3f, 0x80, /* 001111111000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 116 0x74 't' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x04, 0x00, /* 000001000000 */ + 0x04, 0x00, /* 000001000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x7f, 0xc0, /* 011111111100 */ + 0x0c, 0x00, /* 000011000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x0c, 0x20, /* 000011000010 */ + 0x0e, 0x40, /* 000011100100 */ + 0x07, 0x80, /* 000001111000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 117 0x75 'u' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x79, 0xe0, /* 011110011110 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x39, 0xc0, /* 001110011100 */ + 0x1e, 0x60, /* 000111100110 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 118 0x76 'v' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0xf0, 0x70, /* 111100000111 */ + 0x60, 0x20, /* 011000000010 */ + 0x30, 0x40, /* 001100000100 */ + 0x30, 0x40, /* 001100000100 */ + 0x18, 0x80, /* 000110001000 */ + 0x18, 0x80, /* 000110001000 */ + 0x0d, 0x00, /* 000011010000 */ + 0x0d, 0x00, /* 000011010000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 119 0x77 'w' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0xff, 0x70, /* 111111110111 */ + 0x66, 0x20, /* 011001100010 */ + 0x66, 0x20, /* 011001100010 */ + 0x66, 0x20, /* 011001100010 */ + 0x37, 0x40, /* 001101110100 */ + 0x3b, 0x40, /* 001110110100 */ + 0x3b, 0x40, /* 001110110100 */ + 0x19, 0x80, /* 000110011000 */ + 0x19, 0x80, /* 000110011000 */ + 0x19, 0x80, /* 000110011000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 120 0x78 'x' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0xf8, 0xf0, /* 111110001111 */ + 0x70, 0x40, /* 011100000100 */ + 0x38, 0x80, /* 001110001000 */ + 0x1d, 0x00, /* 000111010000 */ + 0x0e, 0x00, /* 000011100000 */ + 0x07, 0x00, /* 000001110000 */ + 0x0b, 0x80, /* 000010111000 */ + 0x11, 0xc0, /* 000100011100 */ + 0x20, 0xe0, /* 001000001110 */ + 0xf1, 0xf0, /* 111100011111 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 121 0x79 'y' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0xf0, 0xf0, /* 111100001111 */ + 0x60, 0x20, /* 011000000010 */ + 0x30, 0x40, /* 001100000100 */ + 0x30, 0x40, /* 001100000100 */ + 0x18, 0x80, /* 000110001000 */ + 0x18, 0x80, /* 000110001000 */ + 0x0d, 0x00, /* 000011010000 */ + 0x0d, 0x00, /* 000011010000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x04, 0x00, /* 000001000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x08, 0x00, /* 000010000000 */ + 0x78, 0x00, /* 011110000000 */ + 0x70, 0x00, /* 011100000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 122 0x7a 'z' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x7f, 0xe0, /* 011111111110 */ + 0x60, 0xe0, /* 011000001110 */ + 0x41, 0xc0, /* 010000011100 */ + 0x03, 0x80, /* 000000111000 */ + 0x07, 0x00, /* 000001110000 */ + 0x0e, 0x00, /* 000011100000 */ + 0x1c, 0x00, /* 000111000000 */ + 0x38, 0x20, /* 001110000010 */ + 0x70, 0x60, /* 011100000110 */ + 0x7f, 0xe0, /* 011111111110 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 123 0x7b '{' */ + 0x00, 0x00, /* 000000000000 */ + 0x03, 0x80, /* 000000111000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x38, 0x00, /* 001110000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x03, 0x80, /* 000000111000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 124 0x7c '|' */ + 0x00, 0x00, /* 000000000000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 125 0x7d '}' */ + 0x00, 0x00, /* 000000000000 */ + 0x1c, 0x00, /* 000111000000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x03, 0x00, /* 000000110000 */ + 0x01, 0xc0, /* 000000011100 */ + 0x03, 0x00, /* 000000110000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x1c, 0x00, /* 000111000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 126 0x7e '~' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x1c, 0x20, /* 000111000010 */ + 0x3e, 0x60, /* 001111100110 */ + 0x67, 0xc0, /* 011001111100 */ + 0x43, 0x80, /* 010000111000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 127 0x7f '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + 0x00, 0x00, /* 000000000000 */ + + /* 128 0x80 '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x0f, 0xc0, /* 000011111100 */ + 0x10, 0x60, /* 000100000110 */ + 0x20, 0x20, /* 001000000010 */ + 0x20, 0x00, /* 001000000000 */ + 0x60, 0x00, /* 011000000000 */ + 0x60, 0x00, /* 011000000000 */ + 0x60, 0x00, /* 011000000000 */ + 0x60, 0x00, /* 011000000000 */ + 0x60, 0x00, /* 011000000000 */ + 0x60, 0x00, /* 011000000000 */ + 0x20, 0x00, /* 001000000000 */ + 0x30, 0x20, /* 001100000010 */ + 0x18, 0x40, /* 000110000100 */ + 0x0f, 0x80, /* 000011111000 */ + 0x06, 0x00, /* 000001100000 */ + 0x03, 0x00, /* 000000110000 */ + 0x01, 0x80, /* 000000011000 */ + 0x0f, 0x00, /* 000011110000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 129 0x81 '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x19, 0x80, /* 000110011000 */ + 0x19, 0x80, /* 000110011000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x79, 0xe0, /* 011110011110 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x39, 0xc0, /* 001110011100 */ + 0x1e, 0x60, /* 000111100110 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 130 0x82 '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x01, 0x80, /* 000000011000 */ + 0x03, 0x00, /* 000000110000 */ + 0x06, 0x00, /* 000001100000 */ + 0x00, 0x00, /* 000000000000 */ + 0x0f, 0x00, /* 000011110000 */ + 0x30, 0xc0, /* 001100001100 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x7f, 0xe0, /* 011111111110 */ + 0x60, 0x00, /* 011000000000 */ + 0x60, 0x00, /* 011000000000 */ + 0x30, 0x00, /* 001100000000 */ + 0x18, 0x60, /* 000110000110 */ + 0x0f, 0x80, /* 000011111000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 131 0x83 '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x02, 0x00, /* 000000100000 */ + 0x07, 0x00, /* 000001110000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x18, 0xc0, /* 000110001100 */ + 0x00, 0x00, /* 000000000000 */ + 0x0f, 0x80, /* 000011111000 */ + 0x18, 0xc0, /* 000110001100 */ + 0x10, 0xc0, /* 000100001100 */ + 0x03, 0xc0, /* 000000111100 */ + 0x1c, 0xc0, /* 000111001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x39, 0xc0, /* 001110011100 */ + 0x1e, 0xe0, /* 000111101110 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 132 0x84 '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x19, 0x80, /* 000110011000 */ + 0x19, 0x80, /* 000110011000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x0f, 0x80, /* 000011111000 */ + 0x18, 0xc0, /* 000110001100 */ + 0x10, 0xc0, /* 000100001100 */ + 0x03, 0xc0, /* 000000111100 */ + 0x1c, 0xc0, /* 000111001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x39, 0xc0, /* 001110011100 */ + 0x1e, 0xe0, /* 000111101110 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 133 0x85 '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x06, 0x00, /* 000001100000 */ + 0x03, 0x00, /* 000000110000 */ + 0x00, 0x00, /* 000000000000 */ + 0x0f, 0x80, /* 000011111000 */ + 0x18, 0xc0, /* 000110001100 */ + 0x10, 0xc0, /* 000100001100 */ + 0x03, 0xc0, /* 000000111100 */ + 0x1c, 0xc0, /* 000111001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x39, 0xc0, /* 001110011100 */ + 0x1e, 0xe0, /* 000111101110 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 134 0x86 '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x07, 0x00, /* 000001110000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x07, 0x00, /* 000001110000 */ + 0x00, 0x00, /* 000000000000 */ + 0x0f, 0x80, /* 000011111000 */ + 0x18, 0xc0, /* 000110001100 */ + 0x10, 0xc0, /* 000100001100 */ + 0x03, 0xc0, /* 000000111100 */ + 0x1c, 0xc0, /* 000111001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x39, 0xc0, /* 001110011100 */ + 0x1e, 0xe0, /* 000111101110 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 135 0x87 '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x1f, 0x80, /* 000111111000 */ + 0x31, 0xc0, /* 001100011100 */ + 0x20, 0xc0, /* 001000001100 */ + 0x60, 0x00, /* 011000000000 */ + 0x60, 0x00, /* 011000000000 */ + 0x60, 0x00, /* 011000000000 */ + 0x60, 0x00, /* 011000000000 */ + 0x70, 0x40, /* 011100000100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x1f, 0x80, /* 000111111000 */ + 0x06, 0x00, /* 000001100000 */ + 0x03, 0x00, /* 000000110000 */ + 0x01, 0x80, /* 000000011000 */ + 0x0f, 0x00, /* 000011110000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 136 0x88 '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x02, 0x00, /* 000000100000 */ + 0x07, 0x00, /* 000001110000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x18, 0xc0, /* 000110001100 */ + 0x00, 0x00, /* 000000000000 */ + 0x0f, 0x00, /* 000011110000 */ + 0x30, 0xc0, /* 001100001100 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x7f, 0xe0, /* 011111111110 */ + 0x60, 0x00, /* 011000000000 */ + 0x60, 0x00, /* 011000000000 */ + 0x30, 0x00, /* 001100000000 */ + 0x18, 0x60, /* 000110000110 */ + 0x0f, 0x80, /* 000011111000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 137 0x89 '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x19, 0x80, /* 000110011000 */ + 0x19, 0x80, /* 000110011000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x0f, 0x00, /* 000011110000 */ + 0x30, 0xc0, /* 001100001100 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x7f, 0xe0, /* 011111111110 */ + 0x60, 0x00, /* 011000000000 */ + 0x60, 0x00, /* 011000000000 */ + 0x30, 0x00, /* 001100000000 */ + 0x18, 0x60, /* 000110000110 */ + 0x0f, 0x80, /* 000011111000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 138 0x8a '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x06, 0x00, /* 000001100000 */ + 0x03, 0x00, /* 000000110000 */ + 0x00, 0x00, /* 000000000000 */ + 0x0f, 0x00, /* 000011110000 */ + 0x30, 0xc0, /* 001100001100 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x7f, 0xe0, /* 011111111110 */ + 0x60, 0x00, /* 011000000000 */ + 0x60, 0x00, /* 011000000000 */ + 0x30, 0x00, /* 001100000000 */ + 0x18, 0x60, /* 000110000110 */ + 0x0f, 0x80, /* 000011111000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 139 0x8b '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x19, 0x80, /* 000110011000 */ + 0x19, 0x80, /* 000110011000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x1e, 0x00, /* 000111100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x1f, 0x80, /* 000111111000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 140 0x8c '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x04, 0x00, /* 000001000000 */ + 0x0e, 0x00, /* 000011100000 */ + 0x1b, 0x00, /* 000110110000 */ + 0x31, 0x80, /* 001100011000 */ + 0x00, 0x00, /* 000000000000 */ + 0x1e, 0x00, /* 000111100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x1f, 0x80, /* 000111111000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 141 0x8d '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x18, 0x00, /* 000110000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x06, 0x00, /* 000001100000 */ + 0x00, 0x00, /* 000000000000 */ + 0x1e, 0x00, /* 000111100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x1f, 0x80, /* 000111111000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 142 0x8e '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x19, 0x80, /* 000110011000 */ + 0x19, 0x80, /* 000110011000 */ + 0x00, 0x00, /* 000000000000 */ + 0x04, 0x00, /* 000001000000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x0b, 0x00, /* 000010110000 */ + 0x0b, 0x00, /* 000010110000 */ + 0x19, 0x80, /* 000110011000 */ + 0x11, 0x80, /* 000100011000 */ + 0x3f, 0xc0, /* 001111111100 */ + 0x20, 0xc0, /* 001000001100 */ + 0x60, 0x60, /* 011000000110 */ + 0x40, 0x60, /* 010000000110 */ + 0xe0, 0xf0, /* 111000001111 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 143 0x8f '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x0f, 0x00, /* 000011110000 */ + 0x19, 0x80, /* 000110011000 */ + 0x0f, 0x00, /* 000011110000 */ + 0x04, 0x00, /* 000001000000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x0b, 0x00, /* 000010110000 */ + 0x0b, 0x00, /* 000010110000 */ + 0x19, 0x80, /* 000110011000 */ + 0x11, 0x80, /* 000100011000 */ + 0x3f, 0xc0, /* 001111111100 */ + 0x20, 0xc0, /* 001000001100 */ + 0x60, 0x60, /* 011000000110 */ + 0x40, 0x60, /* 010000000110 */ + 0xe0, 0xf0, /* 111000001111 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 144 0x90 '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x03, 0x00, /* 000000110000 */ + 0x06, 0x00, /* 000001100000 */ + 0x08, 0x00, /* 000010000000 */ + 0x7f, 0xe0, /* 011111111110 */ + 0x30, 0x20, /* 001100000010 */ + 0x30, 0x00, /* 001100000000 */ + 0x30, 0x00, /* 001100000000 */ + 0x30, 0x80, /* 001100001000 */ + 0x3f, 0x80, /* 001111111000 */ + 0x30, 0x80, /* 001100001000 */ + 0x30, 0x00, /* 001100000000 */ + 0x30, 0x00, /* 001100000000 */ + 0x30, 0x20, /* 001100000010 */ + 0x30, 0x20, /* 001100000010 */ + 0x7f, 0xe0, /* 011111111110 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 145 0x91 '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x3d, 0xe0, /* 001111011110 */ + 0x66, 0x30, /* 011001100011 */ + 0x46, 0x30, /* 010001100011 */ + 0x06, 0x30, /* 000001100011 */ + 0x3f, 0xf0, /* 001111111111 */ + 0x66, 0x00, /* 011001100000 */ + 0xc6, 0x00, /* 110001100000 */ + 0xc6, 0x00, /* 110001100000 */ + 0xe7, 0x30, /* 111001110011 */ + 0x7d, 0xe0, /* 011111011110 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 146 0x92 '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x03, 0xf0, /* 000000111111 */ + 0x07, 0x10, /* 000001110001 */ + 0x07, 0x10, /* 000001110001 */ + 0x0b, 0x00, /* 000010110000 */ + 0x0b, 0x00, /* 000010110000 */ + 0x0b, 0x20, /* 000010110010 */ + 0x13, 0xe0, /* 000100111110 */ + 0x13, 0x20, /* 000100110010 */ + 0x3f, 0x00, /* 001111110000 */ + 0x23, 0x00, /* 001000110000 */ + 0x23, 0x00, /* 001000110000 */ + 0x43, 0x10, /* 010000110001 */ + 0x43, 0x10, /* 010000110001 */ + 0xe7, 0xf0, /* 111001111111 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 147 0x93 '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x02, 0x00, /* 000000100000 */ + 0x07, 0x00, /* 000001110000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x18, 0xc0, /* 000110001100 */ + 0x00, 0x00, /* 000000000000 */ + 0x0f, 0x80, /* 000011111000 */ + 0x11, 0xc0, /* 000100011100 */ + 0x20, 0xe0, /* 001000001110 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x70, 0x40, /* 011100000100 */ + 0x38, 0x80, /* 001110001000 */ + 0x1f, 0x00, /* 000111110000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 148 0x94 '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x19, 0x80, /* 000110011000 */ + 0x19, 0x80, /* 000110011000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x0f, 0x80, /* 000011111000 */ + 0x11, 0xc0, /* 000100011100 */ + 0x20, 0xe0, /* 001000001110 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x70, 0x40, /* 011100000100 */ + 0x38, 0x80, /* 001110001000 */ + 0x1f, 0x00, /* 000111110000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 149 0x95 '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x06, 0x00, /* 000001100000 */ + 0x03, 0x00, /* 000000110000 */ + 0x00, 0x00, /* 000000000000 */ + 0x0f, 0x80, /* 000011111000 */ + 0x11, 0xc0, /* 000100011100 */ + 0x20, 0xe0, /* 001000001110 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x70, 0x40, /* 011100000100 */ + 0x38, 0x80, /* 001110001000 */ + 0x1f, 0x00, /* 000111110000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 150 0x96 '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x02, 0x00, /* 000000100000 */ + 0x07, 0x00, /* 000001110000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x18, 0xc0, /* 000110001100 */ + 0x00, 0x00, /* 000000000000 */ + 0x79, 0xe0, /* 011110011110 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x39, 0xc0, /* 001110011100 */ + 0x1e, 0x60, /* 000111100110 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 151 0x97 '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x18, 0x00, /* 000110000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x06, 0x00, /* 000001100000 */ + 0x00, 0x00, /* 000000000000 */ + 0x79, 0xe0, /* 011110011110 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x39, 0xc0, /* 001110011100 */ + 0x1e, 0x60, /* 000111100110 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 152 0x98 '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x19, 0x80, /* 000110011000 */ + 0x19, 0x80, /* 000110011000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0xf0, 0xf0, /* 111100001111 */ + 0x60, 0x20, /* 011000000010 */ + 0x30, 0x40, /* 001100000100 */ + 0x30, 0x40, /* 001100000100 */ + 0x18, 0x80, /* 000110001000 */ + 0x18, 0x80, /* 000110001000 */ + 0x0d, 0x00, /* 000011010000 */ + 0x0d, 0x00, /* 000011010000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x04, 0x00, /* 000001000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x08, 0x00, /* 000010000000 */ + 0x78, 0x00, /* 011110000000 */ + 0x70, 0x00, /* 011100000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 153 0x99 '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x19, 0x80, /* 000110011000 */ + 0x19, 0x80, /* 000110011000 */ + 0x00, 0x00, /* 000000000000 */ + 0x0f, 0x80, /* 000011111000 */ + 0x11, 0xc0, /* 000100011100 */ + 0x20, 0xc0, /* 001000001100 */ + 0x20, 0x60, /* 001000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x20, 0x40, /* 001000000100 */ + 0x30, 0x40, /* 001100000100 */ + 0x18, 0x80, /* 000110001000 */ + 0x0f, 0x00, /* 000011110000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 154 0x9a '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x19, 0x80, /* 000110011000 */ + 0x19, 0x80, /* 000110011000 */ + 0xe0, 0x30, /* 111000000011 */ + 0x60, 0x20, /* 011000000010 */ + 0x60, 0x20, /* 011000000010 */ + 0x60, 0x20, /* 011000000010 */ + 0x60, 0x20, /* 011000000010 */ + 0x60, 0x20, /* 011000000010 */ + 0x60, 0x20, /* 011000000010 */ + 0x60, 0x20, /* 011000000010 */ + 0x60, 0x20, /* 011000000010 */ + 0x60, 0x20, /* 011000000010 */ + 0x70, 0x40, /* 011100000100 */ + 0x3f, 0xc0, /* 001111111100 */ + 0x1f, 0x80, /* 000111111000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 155 0x9b '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x1f, 0x80, /* 000111111000 */ + 0x36, 0xc0, /* 001101101100 */ + 0x26, 0xc0, /* 001001101100 */ + 0x66, 0x00, /* 011001100000 */ + 0x66, 0x00, /* 011001100000 */ + 0x66, 0x00, /* 011001100000 */ + 0x66, 0x00, /* 011001100000 */ + 0x76, 0x40, /* 011101100100 */ + 0x36, 0xc0, /* 001101101100 */ + 0x1f, 0x80, /* 000111111000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 156 0x9c '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x0f, 0x80, /* 000011111000 */ + 0x1c, 0xc0, /* 000111001100 */ + 0x18, 0xc0, /* 000110001100 */ + 0x18, 0x00, /* 000110000000 */ + 0x18, 0x00, /* 000110000000 */ + 0x18, 0x00, /* 000110000000 */ + 0x7e, 0x00, /* 011111100000 */ + 0x7e, 0x00, /* 011111100000 */ + 0x18, 0x00, /* 000110000000 */ + 0x18, 0x00, /* 000110000000 */ + 0x18, 0x00, /* 000110000000 */ + 0x18, 0x00, /* 000110000000 */ + 0x3e, 0x20, /* 001111100010 */ + 0x7f, 0xe0, /* 011111111110 */ + 0x61, 0xc0, /* 011000011100 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 157 0x9d '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x30, 0xc0, /* 001100001100 */ + 0x19, 0x80, /* 000110011000 */ + 0x19, 0x80, /* 000110011000 */ + 0x0f, 0x00, /* 000011110000 */ + 0x06, 0x00, /* 000001100000 */ + 0x1f, 0x80, /* 000111111000 */ + 0x06, 0x00, /* 000001100000 */ + 0x1f, 0x80, /* 000111111000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 158 0x9e '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x7f, 0x80, /* 011111111000 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0x60, /* 001100000110 */ + 0x30, 0x60, /* 001100000110 */ + 0x30, 0x60, /* 001100000110 */ + 0x30, 0xc0, /* 001100001100 */ + 0x37, 0x80, /* 001101111000 */ + 0x30, 0x00, /* 001100000000 */ + 0x33, 0x00, /* 001100110000 */ + 0x37, 0x80, /* 001101111000 */ + 0x33, 0x00, /* 001100110000 */ + 0x33, 0x00, /* 001100110000 */ + 0x33, 0x30, /* 001100110011 */ + 0x31, 0xe0, /* 001100011110 */ + 0x78, 0xc0, /* 011110001100 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 159 0x9f '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0xc0, /* 000000001100 */ + 0x01, 0xe0, /* 000000011110 */ + 0x03, 0x30, /* 000000110011 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x3f, 0xe0, /* 001111111110 */ + 0x7f, 0xc0, /* 011111111100 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0xcc, 0x00, /* 110011000000 */ + 0x78, 0x00, /* 011110000000 */ + 0x30, 0x00, /* 001100000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 160 0xa0 '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x01, 0x80, /* 000000011000 */ + 0x03, 0x00, /* 000000110000 */ + 0x06, 0x00, /* 000001100000 */ + 0x00, 0x00, /* 000000000000 */ + 0x0f, 0x80, /* 000011111000 */ + 0x18, 0xc0, /* 000110001100 */ + 0x10, 0xc0, /* 000100001100 */ + 0x03, 0xc0, /* 000000111100 */ + 0x1c, 0xc0, /* 000111001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x39, 0xc0, /* 001110011100 */ + 0x1e, 0xe0, /* 000111101110 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 161 0xa1 '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x01, 0x80, /* 000000011000 */ + 0x03, 0x00, /* 000000110000 */ + 0x06, 0x00, /* 000001100000 */ + 0x00, 0x00, /* 000000000000 */ + 0x1e, 0x00, /* 000111100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x1f, 0x80, /* 000111111000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 162 0xa2 '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x01, 0x80, /* 000000011000 */ + 0x03, 0x00, /* 000000110000 */ + 0x06, 0x00, /* 000001100000 */ + 0x00, 0x00, /* 000000000000 */ + 0x0f, 0x80, /* 000011111000 */ + 0x11, 0xc0, /* 000100011100 */ + 0x20, 0xe0, /* 001000001110 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x70, 0x40, /* 011100000100 */ + 0x38, 0x80, /* 001110001000 */ + 0x1f, 0x00, /* 000111110000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 163 0xa3 '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x01, 0x80, /* 000000011000 */ + 0x03, 0x00, /* 000000110000 */ + 0x06, 0x00, /* 000001100000 */ + 0x00, 0x00, /* 000000000000 */ + 0x79, 0xe0, /* 011110011110 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x39, 0xc0, /* 001110011100 */ + 0x1e, 0x60, /* 000111100110 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 164 0xa4 '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x1c, 0x40, /* 000111000100 */ + 0x3f, 0xc0, /* 001111111100 */ + 0x23, 0x80, /* 001000111000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x27, 0x80, /* 001001111000 */ + 0x79, 0xc0, /* 011110011100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x79, 0xe0, /* 011110011110 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 165 0xa5 '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x1c, 0x40, /* 000111000100 */ + 0x3f, 0xc0, /* 001111111100 */ + 0x23, 0x80, /* 001000111000 */ + 0xc0, 0x70, /* 110000000111 */ + 0x60, 0x20, /* 011000000010 */ + 0x70, 0x20, /* 011100000010 */ + 0x78, 0x20, /* 011110000010 */ + 0x5c, 0x20, /* 010111000010 */ + 0x4e, 0x20, /* 010011100010 */ + 0x47, 0x20, /* 010001110010 */ + 0x43, 0xa0, /* 010000111010 */ + 0x41, 0xe0, /* 010000011110 */ + 0x40, 0xe0, /* 010000001110 */ + 0x40, 0x60, /* 010000000110 */ + 0xe0, 0x30, /* 111000000011 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 166 0xa6 '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x1f, 0x00, /* 000111110000 */ + 0x31, 0x80, /* 001100011000 */ + 0x01, 0x80, /* 000000011000 */ + 0x07, 0x80, /* 000001111000 */ + 0x19, 0x80, /* 000110011000 */ + 0x31, 0x80, /* 001100011000 */ + 0x31, 0x80, /* 001100011000 */ + 0x33, 0x80, /* 001100111000 */ + 0x1d, 0xc0, /* 000111011100 */ + 0x00, 0x00, /* 000000000000 */ + 0x3f, 0xc0, /* 001111111100 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 167 0xa7 '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x07, 0x00, /* 000001110000 */ + 0x19, 0x80, /* 000110011000 */ + 0x10, 0xc0, /* 000100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0x80, /* 001100001000 */ + 0x19, 0x80, /* 000110011000 */ + 0x0e, 0x00, /* 000011100000 */ + 0x00, 0x00, /* 000000000000 */ + 0x3f, 0xc0, /* 001111111100 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 168 0xa8 '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x03, 0x00, /* 000000110000 */ + 0x03, 0x00, /* 000000110000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x03, 0x00, /* 000000110000 */ + 0x03, 0x00, /* 000000110000 */ + 0x06, 0x00, /* 000001100000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x18, 0x00, /* 000110000000 */ + 0x30, 0x00, /* 001100000000 */ + 0x30, 0x00, /* 001100000000 */ + 0x30, 0x40, /* 001100000100 */ + 0x39, 0xc0, /* 001110011100 */ + 0x1f, 0x80, /* 000111111000 */ + 0x0f, 0x00, /* 000011110000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 169 0xa9 '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x3f, 0xc0, /* 001111111100 */ + 0x3f, 0xc0, /* 001111111100 */ + 0x30, 0x00, /* 001100000000 */ + 0x30, 0x00, /* 001100000000 */ + 0x30, 0x00, /* 001100000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 170 0xaa '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x3f, 0xc0, /* 001111111100 */ + 0x3f, 0xc0, /* 001111111100 */ + 0x00, 0xc0, /* 000000001100 */ + 0x00, 0xc0, /* 000000001100 */ + 0x00, 0xc0, /* 000000001100 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 171 0xab '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x10, 0x00, /* 000100000000 */ + 0x30, 0x00, /* 001100000000 */ + 0x10, 0x00, /* 000100000000 */ + 0x10, 0x40, /* 000100000100 */ + 0x10, 0x80, /* 000100001000 */ + 0x11, 0x00, /* 000100010000 */ + 0x3a, 0x00, /* 001110100000 */ + 0x05, 0xc0, /* 000001011100 */ + 0x0a, 0x20, /* 000010100010 */ + 0x10, 0x20, /* 000100000010 */ + 0x20, 0xc0, /* 001000001100 */ + 0x41, 0x00, /* 010000010000 */ + 0x02, 0x00, /* 000000100000 */ + 0x03, 0xe0, /* 000000111110 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 172 0xac '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x10, 0x00, /* 000100000000 */ + 0x30, 0x00, /* 001100000000 */ + 0x10, 0x00, /* 000100000000 */ + 0x10, 0x40, /* 000100000100 */ + 0x10, 0x80, /* 000100001000 */ + 0x11, 0x00, /* 000100010000 */ + 0x3a, 0x40, /* 001110100100 */ + 0x04, 0xc0, /* 000001001100 */ + 0x09, 0x40, /* 000010010100 */ + 0x12, 0x40, /* 000100100100 */ + 0x24, 0x40, /* 001001000100 */ + 0x47, 0xe0, /* 010001111110 */ + 0x00, 0x40, /* 000000000100 */ + 0x00, 0x40, /* 000000000100 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 173 0xad '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 174 0xae '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x06, 0x60, /* 000001100110 */ + 0x0c, 0xc0, /* 000011001100 */ + 0x19, 0x80, /* 000110011000 */ + 0x33, 0x00, /* 001100110000 */ + 0x66, 0x00, /* 011001100000 */ + 0x33, 0x00, /* 001100110000 */ + 0x19, 0x80, /* 000110011000 */ + 0x0c, 0xc0, /* 000011001100 */ + 0x06, 0x60, /* 000001100110 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 175 0xaf '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x66, 0x00, /* 011001100000 */ + 0x33, 0x00, /* 001100110000 */ + 0x19, 0x80, /* 000110011000 */ + 0x0c, 0xc0, /* 000011001100 */ + 0x06, 0x60, /* 000001100110 */ + 0x0c, 0xc0, /* 000011001100 */ + 0x19, 0x80, /* 000110011000 */ + 0x33, 0x00, /* 001100110000 */ + 0x66, 0x00, /* 011001100000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 176 0xb0 '.' */ + 0x0c, 0x30, /* 000011000011 */ + 0x08, 0x20, /* 000010000010 */ + 0x61, 0x80, /* 011000011000 */ + 0x20, 0x80, /* 001000001000 */ + 0x0c, 0x30, /* 000011000011 */ + 0x08, 0x20, /* 000010000010 */ + 0x61, 0x80, /* 011000011000 */ + 0x20, 0x80, /* 001000001000 */ + 0x0c, 0x30, /* 000011000011 */ + 0x08, 0x20, /* 000010000010 */ + 0x61, 0x80, /* 011000011000 */ + 0x20, 0x80, /* 001000001000 */ + 0x0c, 0x30, /* 000011000011 */ + 0x08, 0x20, /* 000010000010 */ + 0x61, 0x80, /* 011000011000 */ + 0x20, 0x80, /* 001000001000 */ + 0x0c, 0x30, /* 000011000011 */ + 0x08, 0x20, /* 000010000010 */ + 0x61, 0x80, /* 011000011000 */ + 0x20, 0x80, /* 001000001000 */ + 0x0c, 0x30, /* 000011000011 */ + 0x08, 0x20, /* 000010000010 */ + + /* 177 0xb1 '.' */ + 0x77, 0x70, /* 011101110111 */ + 0x22, 0x20, /* 001000100010 */ + 0x88, 0x80, /* 100010001000 */ + 0xdd, 0xd0, /* 110111011101 */ + 0x88, 0x80, /* 100010001000 */ + 0x22, 0x20, /* 001000100010 */ + 0x77, 0x70, /* 011101110111 */ + 0x22, 0x20, /* 001000100010 */ + 0x88, 0x80, /* 100010001000 */ + 0xdd, 0xd0, /* 110111011101 */ + 0x88, 0x80, /* 100010001000 */ + 0x22, 0x20, /* 001000100010 */ + 0x77, 0x70, /* 011101110111 */ + 0x22, 0x20, /* 001000100010 */ + 0x88, 0x80, /* 100010001000 */ + 0xdd, 0xd0, /* 110111011101 */ + 0x88, 0x80, /* 100010001000 */ + 0x22, 0x20, /* 001000100010 */ + 0x77, 0x70, /* 011101110111 */ + 0x22, 0x20, /* 001000100010 */ + 0x88, 0x80, /* 100010001000 */ + 0xdd, 0xd0, /* 110111011101 */ + + /* 178 0xb2 '.' */ + 0xf3, 0xc0, /* 111100111100 */ + 0xf7, 0xd0, /* 111101111101 */ + 0x9e, 0x70, /* 100111100111 */ + 0xdf, 0x70, /* 110111110111 */ + 0xf3, 0xc0, /* 111100111100 */ + 0xf7, 0xd0, /* 111101111101 */ + 0x9e, 0x70, /* 100111100111 */ + 0xdf, 0x70, /* 110111110111 */ + 0xf3, 0xc0, /* 111100111100 */ + 0xf7, 0xd0, /* 111101111101 */ + 0x9e, 0x70, /* 100111100111 */ + 0xdf, 0x70, /* 110111110111 */ + 0xf3, 0xc0, /* 111100111100 */ + 0xf7, 0xd0, /* 111101111101 */ + 0x9e, 0x70, /* 100111100111 */ + 0xdf, 0x70, /* 110111110111 */ + 0xf3, 0xc0, /* 111100111100 */ + 0xf7, 0xd0, /* 111101111101 */ + 0x9e, 0x70, /* 100111100111 */ + 0xdf, 0x70, /* 110111110111 */ + 0xf3, 0xc0, /* 111100111100 */ + 0xf7, 0xd0, /* 111101111101 */ + + /* 179 0xb3 '.' */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + + /* 180 0xb4 '.' */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0xfe, 0x00, /* 111111100000 */ + 0xfe, 0x00, /* 111111100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + + /* 181 0xb5 '.' */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0xfe, 0x00, /* 111111100000 */ + 0xfe, 0x00, /* 111111100000 */ + 0x06, 0x00, /* 000001100000 */ + 0xfe, 0x00, /* 111111100000 */ + 0xfe, 0x00, /* 111111100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + + /* 182 0xb6 '.' */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0xfd, 0x80, /* 111111011000 */ + 0xfd, 0x80, /* 111111011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + + /* 183 0xb7 '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0xff, 0x80, /* 111111111000 */ + 0xff, 0x80, /* 111111111000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + + /* 184 0xb8 '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0xfe, 0x00, /* 111111100000 */ + 0xfe, 0x00, /* 111111100000 */ + 0x06, 0x00, /* 000001100000 */ + 0xfe, 0x00, /* 111111100000 */ + 0xfe, 0x00, /* 111111100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + + /* 185 0xb9 '.' */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0xfd, 0x80, /* 111111011000 */ + 0xfd, 0x80, /* 111111011000 */ + 0x01, 0x80, /* 000000011000 */ + 0xfd, 0x80, /* 111111011000 */ + 0xfd, 0x80, /* 111111011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + + /* 186 0xba '.' */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + + /* 187 0xbb '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0xff, 0x80, /* 111111111000 */ + 0xff, 0x80, /* 111111111000 */ + 0x01, 0x80, /* 000000011000 */ + 0xfd, 0x80, /* 111111011000 */ + 0xfd, 0x80, /* 111111011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + + /* 188 0xbc '.' */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0xfd, 0x80, /* 111111011000 */ + 0xfd, 0x80, /* 111111011000 */ + 0x01, 0x80, /* 000000011000 */ + 0xff, 0x80, /* 111111111000 */ + 0xff, 0x80, /* 111111111000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 189 0xbd '.' */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0xff, 0x80, /* 111111111000 */ + 0xff, 0x80, /* 111111111000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 190 0xbe '.' */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0xfe, 0x00, /* 111111100000 */ + 0xfe, 0x00, /* 111111100000 */ + 0x06, 0x00, /* 000001100000 */ + 0xfe, 0x00, /* 111111100000 */ + 0xfe, 0x00, /* 111111100000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 191 0xbf '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0xfe, 0x00, /* 111111100000 */ + 0xfe, 0x00, /* 111111100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + + /* 192 0xc0 '.' */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x07, 0xf0, /* 000001111111 */ + 0x07, 0xf0, /* 000001111111 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 193 0xc1 '.' */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 194 0xc2 '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + + /* 195 0xc3 '.' */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x07, 0xf0, /* 000001111111 */ + 0x07, 0xf0, /* 000001111111 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + + /* 196 0xc4 '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 197 0xc5 '.' */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + + /* 198 0xc6 '.' */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x07, 0xf0, /* 000001111111 */ + 0x07, 0xf0, /* 000001111111 */ + 0x06, 0x00, /* 000001100000 */ + 0x07, 0xf0, /* 000001111111 */ + 0x07, 0xf0, /* 000001111111 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + + /* 199 0xc7 '.' */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0xf0, /* 000011011111 */ + 0x0d, 0xf0, /* 000011011111 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + + /* 200 0xc8 '.' */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0xf0, /* 000011011111 */ + 0x0d, 0xf0, /* 000011011111 */ + 0x0c, 0x00, /* 000011000000 */ + 0x0f, 0xf0, /* 000011111111 */ + 0x0f, 0xf0, /* 000011111111 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 201 0xc9 '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x0f, 0xf0, /* 000011111111 */ + 0x0f, 0xf0, /* 000011111111 */ + 0x0c, 0x00, /* 000011000000 */ + 0x0d, 0xf0, /* 000011011111 */ + 0x0d, 0xf0, /* 000011011111 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + + /* 202 0xca '.' */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0xfd, 0xf0, /* 111111011111 */ + 0xfd, 0xf0, /* 111111011111 */ + 0x00, 0x00, /* 000000000000 */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 203 0xcb '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + 0x00, 0x00, /* 000000000000 */ + 0xfd, 0xf0, /* 111111011111 */ + 0xfd, 0xf0, /* 111111011111 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + + /* 204 0xcc '.' */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0xf0, /* 000011011111 */ + 0x0d, 0xf0, /* 000011011111 */ + 0x0c, 0x00, /* 000011000000 */ + 0x0d, 0xf0, /* 000011011111 */ + 0x0d, 0xf0, /* 000011011111 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + + /* 205 0xcd '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + 0x00, 0x00, /* 000000000000 */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 206 0xce '.' */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0xfd, 0xf0, /* 111111011111 */ + 0xfd, 0xf0, /* 111111011111 */ + 0x00, 0x00, /* 000000000000 */ + 0xfd, 0xf0, /* 111111011111 */ + 0xfd, 0xf0, /* 111111011111 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + + /* 207 0xcf '.' */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + 0x00, 0x00, /* 000000000000 */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 208 0xd0 '.' */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 209 0xd1 '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + 0x00, 0x00, /* 000000000000 */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + + /* 210 0xd2 '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + + /* 211 0xd3 '.' */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0f, 0xf0, /* 000011111111 */ + 0x0f, 0xf0, /* 000011111111 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 212 0xd4 '.' */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x07, 0xf0, /* 000001111111 */ + 0x07, 0xf0, /* 000001111111 */ + 0x06, 0x00, /* 000001100000 */ + 0x07, 0xf0, /* 000001111111 */ + 0x07, 0xf0, /* 000001111111 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 213 0xd5 '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x07, 0xf0, /* 000001111111 */ + 0x07, 0xf0, /* 000001111111 */ + 0x06, 0x00, /* 000001100000 */ + 0x07, 0xf0, /* 000001111111 */ + 0x07, 0xf0, /* 000001111111 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + + /* 214 0xd6 '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x0f, 0xf0, /* 000011111111 */ + 0x0f, 0xf0, /* 000011111111 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + + /* 215 0xd7 '.' */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + 0x0d, 0x80, /* 000011011000 */ + + /* 216 0xd8 '.' */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + 0x06, 0x00, /* 000001100000 */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + + /* 217 0xd9 '.' */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0xfe, 0x00, /* 111111100000 */ + 0xfe, 0x00, /* 111111100000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 218 0xda '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x07, 0xf0, /* 000001111111 */ + 0x07, 0xf0, /* 000001111111 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + + /* 219 0xdb '.' */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + + /* 220 0xdc '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + + /* 221 0xdd '.' */ + 0xfc, 0x00, /* 111111000000 */ + 0xfc, 0x00, /* 111111000000 */ + 0xfc, 0x00, /* 111111000000 */ + 0xfc, 0x00, /* 111111000000 */ + 0xfc, 0x00, /* 111111000000 */ + 0xfc, 0x00, /* 111111000000 */ + 0xfc, 0x00, /* 111111000000 */ + 0xfc, 0x00, /* 111111000000 */ + 0xfc, 0x00, /* 111111000000 */ + 0xfc, 0x00, /* 111111000000 */ + 0xfc, 0x00, /* 111111000000 */ + 0xfc, 0x00, /* 111111000000 */ + 0xfc, 0x00, /* 111111000000 */ + 0xfc, 0x00, /* 111111000000 */ + 0xfc, 0x00, /* 111111000000 */ + 0xfc, 0x00, /* 111111000000 */ + 0xfc, 0x00, /* 111111000000 */ + 0xfc, 0x00, /* 111111000000 */ + 0xfc, 0x00, /* 111111000000 */ + 0xfc, 0x00, /* 111111000000 */ + 0xfc, 0x00, /* 111111000000 */ + 0xfc, 0x00, /* 111111000000 */ + + /* 222 0xde '.' */ + 0x03, 0xf0, /* 000000111111 */ + 0x03, 0xf0, /* 000000111111 */ + 0x03, 0xf0, /* 000000111111 */ + 0x03, 0xf0, /* 000000111111 */ + 0x03, 0xf0, /* 000000111111 */ + 0x03, 0xf0, /* 000000111111 */ + 0x03, 0xf0, /* 000000111111 */ + 0x03, 0xf0, /* 000000111111 */ + 0x03, 0xf0, /* 000000111111 */ + 0x03, 0xf0, /* 000000111111 */ + 0x03, 0xf0, /* 000000111111 */ + 0x03, 0xf0, /* 000000111111 */ + 0x03, 0xf0, /* 000000111111 */ + 0x03, 0xf0, /* 000000111111 */ + 0x03, 0xf0, /* 000000111111 */ + 0x03, 0xf0, /* 000000111111 */ + 0x03, 0xf0, /* 000000111111 */ + 0x03, 0xf0, /* 000000111111 */ + 0x03, 0xf0, /* 000000111111 */ + 0x03, 0xf0, /* 000000111111 */ + 0x03, 0xf0, /* 000000111111 */ + 0x03, 0xf0, /* 000000111111 */ + + /* 223 0xdf '.' */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + 0xff, 0xf0, /* 111111111111 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 224 0xe0 '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x0f, 0x60, /* 000011110110 */ + 0x13, 0xe0, /* 000100111110 */ + 0x21, 0xc0, /* 001000011100 */ + 0x60, 0xc0, /* 011000001100 */ + 0x60, 0xc0, /* 011000001100 */ + 0x60, 0xc0, /* 011000001100 */ + 0x60, 0xc0, /* 011000001100 */ + 0x70, 0x80, /* 011100001000 */ + 0x39, 0xc0, /* 001110011100 */ + 0x1f, 0x60, /* 000111110110 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 225 0xe1 '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x0f, 0x00, /* 000011110000 */ + 0x19, 0x80, /* 000110011000 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x31, 0x80, /* 001100011000 */ + 0x37, 0x80, /* 001101111000 */ + 0x31, 0x80, /* 001100011000 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x31, 0x80, /* 001100011000 */ + 0x77, 0x00, /* 011101110000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 226 0xe2 '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x3f, 0xe0, /* 001111111110 */ + 0x3f, 0xe0, /* 001111111110 */ + 0x30, 0x60, /* 001100000110 */ + 0x30, 0x60, /* 001100000110 */ + 0x30, 0x00, /* 001100000000 */ + 0x30, 0x00, /* 001100000000 */ + 0x30, 0x00, /* 001100000000 */ + 0x30, 0x00, /* 001100000000 */ + 0x30, 0x00, /* 001100000000 */ + 0x30, 0x00, /* 001100000000 */ + 0x30, 0x00, /* 001100000000 */ + 0x30, 0x00, /* 001100000000 */ + 0x30, 0x00, /* 001100000000 */ + 0x30, 0x00, /* 001100000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 227 0xe3 '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x7f, 0xe0, /* 011111111110 */ + 0x7f, 0xe0, /* 011111111110 */ + 0x19, 0x80, /* 000110011000 */ + 0x19, 0x80, /* 000110011000 */ + 0x19, 0x80, /* 000110011000 */ + 0x19, 0x80, /* 000110011000 */ + 0x19, 0x80, /* 000110011000 */ + 0x19, 0x80, /* 000110011000 */ + 0x19, 0x80, /* 000110011000 */ + 0x19, 0x80, /* 000110011000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 228 0xe4 '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x7f, 0xe0, /* 011111111110 */ + 0x7f, 0xe0, /* 011111111110 */ + 0x60, 0x60, /* 011000000110 */ + 0x30, 0x60, /* 001100000110 */ + 0x30, 0x00, /* 001100000000 */ + 0x18, 0x00, /* 000110000000 */ + 0x18, 0x00, /* 000110000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x18, 0x00, /* 000110000000 */ + 0x18, 0x00, /* 000110000000 */ + 0x30, 0x00, /* 001100000000 */ + 0x30, 0x60, /* 001100000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x7f, 0xe0, /* 011111111110 */ + 0x7f, 0xe0, /* 011111111110 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 229 0xe5 '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x07, 0xe0, /* 000001111110 */ + 0x0f, 0xe0, /* 000011111110 */ + 0x13, 0x80, /* 000100111000 */ + 0x21, 0xc0, /* 001000011100 */ + 0x60, 0xc0, /* 011000001100 */ + 0x60, 0xc0, /* 011000001100 */ + 0x60, 0xc0, /* 011000001100 */ + 0x60, 0xc0, /* 011000001100 */ + 0x70, 0x80, /* 011100001000 */ + 0x39, 0x00, /* 001110010000 */ + 0x1e, 0x00, /* 000111100000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 230 0xe6 '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x39, 0xc0, /* 001110011100 */ + 0x36, 0xe0, /* 001101101110 */ + 0x30, 0x00, /* 001100000000 */ + 0x30, 0x00, /* 001100000000 */ + 0x60, 0x00, /* 011000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 231 0xe7 '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x19, 0x80, /* 000110011000 */ + 0x3f, 0xc0, /* 001111111100 */ + 0x66, 0x60, /* 011001100110 */ + 0x66, 0x60, /* 011001100110 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 232 0xe8 '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x7f, 0xe0, /* 011111111110 */ + 0x7f, 0xe0, /* 011111111110 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x0f, 0x00, /* 000011110000 */ + 0x19, 0x80, /* 000110011000 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x19, 0x80, /* 000110011000 */ + 0x0f, 0x00, /* 000011110000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x7f, 0xe0, /* 011111111110 */ + 0x7f, 0xe0, /* 011111111110 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 233 0xe9 '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x0f, 0x00, /* 000011110000 */ + 0x1f, 0x80, /* 000111111000 */ + 0x30, 0xc0, /* 001100001100 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x7f, 0xe0, /* 011111111110 */ + 0x7f, 0xe0, /* 011111111110 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x30, 0xc0, /* 001100001100 */ + 0x1f, 0x80, /* 000111111000 */ + 0x0f, 0x00, /* 000011110000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 234 0xea '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x1f, 0x00, /* 000111110000 */ + 0x31, 0x80, /* 001100011000 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x19, 0x80, /* 000110011000 */ + 0x19, 0x80, /* 000110011000 */ + 0xd9, 0xb0, /* 110110011011 */ + 0x79, 0xe0, /* 011110011110 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 235 0xeb '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x07, 0x80, /* 000001111000 */ + 0x0c, 0xc0, /* 000011001100 */ + 0x18, 0x60, /* 000110000110 */ + 0x18, 0x00, /* 000110000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x06, 0x00, /* 000001100000 */ + 0x03, 0x00, /* 000000110000 */ + 0x0f, 0x80, /* 000011111000 */ + 0x11, 0xc0, /* 000100011100 */ + 0x20, 0xe0, /* 001000001110 */ + 0x60, 0x60, /* 011000000110 */ + 0x60, 0x60, /* 011000000110 */ + 0x70, 0x40, /* 011100000100 */ + 0x38, 0x80, /* 001110001000 */ + 0x1f, 0x00, /* 000111110000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 236 0xec '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x39, 0xc0, /* 001110011100 */ + 0x6f, 0x60, /* 011011110110 */ + 0x66, 0x60, /* 011001100110 */ + 0xc6, 0x30, /* 110001100011 */ + 0xc6, 0x30, /* 110001100011 */ + 0x66, 0x60, /* 011001100110 */ + 0x6f, 0x60, /* 011011110110 */ + 0x39, 0xc0, /* 001110011100 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 237 0xed '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0xc0, /* 000000001100 */ + 0x00, 0xc0, /* 000000001100 */ + 0x01, 0x80, /* 000000011000 */ + 0x01, 0x80, /* 000000011000 */ + 0x3b, 0xc0, /* 001110111100 */ + 0x6f, 0x60, /* 011011110110 */ + 0x66, 0x60, /* 011001100110 */ + 0xc6, 0x30, /* 110001100011 */ + 0xc6, 0x30, /* 110001100011 */ + 0x66, 0x60, /* 011001100110 */ + 0x6f, 0x60, /* 011011110110 */ + 0x3d, 0xc0, /* 001111011100 */ + 0x18, 0x00, /* 000110000000 */ + 0x18, 0x00, /* 000110000000 */ + 0x30, 0x00, /* 001100000000 */ + 0x30, 0x00, /* 001100000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 238 0xee '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x01, 0xc0, /* 000000011100 */ + 0x03, 0x00, /* 000000110000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x18, 0x00, /* 000110000000 */ + 0x1f, 0xc0, /* 000111111100 */ + 0x18, 0x00, /* 000110000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x03, 0x00, /* 000000110000 */ + 0x01, 0xc0, /* 000000011100 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 239 0xef '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x0f, 0x00, /* 000011110000 */ + 0x1f, 0x80, /* 000111111000 */ + 0x39, 0xc0, /* 001110011100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x30, 0xc0, /* 001100001100 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 240 0xf0 '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x7f, 0xe0, /* 011111111110 */ + 0x7f, 0xe0, /* 011111111110 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x7f, 0xe0, /* 011111111110 */ + 0x7f, 0xe0, /* 011111111110 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x7f, 0xe0, /* 011111111110 */ + 0x7f, 0xe0, /* 011111111110 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 241 0xf1 '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x7f, 0xe0, /* 011111111110 */ + 0x7f, 0xe0, /* 011111111110 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x00, 0x00, /* 000000000000 */ + 0x7f, 0xe0, /* 011111111110 */ + 0x7f, 0xe0, /* 011111111110 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 242 0xf2 '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x60, 0x00, /* 011000000000 */ + 0x38, 0x00, /* 001110000000 */ + 0x0e, 0x00, /* 000011100000 */ + 0x03, 0x80, /* 000000111000 */ + 0x00, 0xe0, /* 000000001110 */ + 0x00, 0xe0, /* 000000001110 */ + 0x03, 0x80, /* 000000111000 */ + 0x0e, 0x00, /* 000011100000 */ + 0x38, 0x00, /* 001110000000 */ + 0x60, 0x00, /* 011000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x7f, 0xe0, /* 011111111110 */ + 0x7f, 0xe0, /* 011111111110 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 243 0xf3 '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x60, /* 000000000110 */ + 0x01, 0xc0, /* 000000011100 */ + 0x07, 0x00, /* 000001110000 */ + 0x1c, 0x00, /* 000111000000 */ + 0x70, 0x00, /* 011100000000 */ + 0x70, 0x00, /* 011100000000 */ + 0x1c, 0x00, /* 000111000000 */ + 0x07, 0x00, /* 000001110000 */ + 0x01, 0xc0, /* 000000011100 */ + 0x00, 0x60, /* 000000000110 */ + 0x00, 0x00, /* 000000000000 */ + 0x7f, 0xe0, /* 011111111110 */ + 0x7f, 0xe0, /* 011111111110 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 244 0xf4 '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x03, 0x80, /* 000000111000 */ + 0x07, 0xc0, /* 000001111100 */ + 0x0c, 0x60, /* 000011000110 */ + 0x0c, 0x60, /* 000011000110 */ + 0x0c, 0x00, /* 000011000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x0c, 0x00, /* 000011000000 */ + + /* 245 0xf5 '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x1c, 0x00, /* 000111000000 */ + 0x3e, 0x00, /* 001111100000 */ + 0x63, 0x00, /* 011000110000 */ + 0x63, 0x00, /* 011000110000 */ + 0x03, 0x00, /* 000000110000 */ + 0x03, 0x00, /* 000000110000 */ + 0x03, 0x00, /* 000000110000 */ + 0x03, 0x00, /* 000000110000 */ + 0x03, 0x00, /* 000000110000 */ + 0x03, 0x00, /* 000000110000 */ + 0x03, 0x00, /* 000000110000 */ + 0x03, 0x00, /* 000000110000 */ + 0x03, 0x00, /* 000000110000 */ + 0x03, 0x00, /* 000000110000 */ + 0x03, 0x00, /* 000000110000 */ + 0x03, 0x00, /* 000000110000 */ + 0x03, 0x00, /* 000000110000 */ + 0x03, 0x00, /* 000000110000 */ + 0x03, 0x00, /* 000000110000 */ + 0x03, 0x00, /* 000000110000 */ + 0x03, 0x00, /* 000000110000 */ + + /* 246 0xf6 '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x7f, 0xe0, /* 011111111110 */ + 0x7f, 0xe0, /* 011111111110 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 247 0xf7 '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x38, 0x00, /* 001110000000 */ + 0x6c, 0x00, /* 011011000000 */ + 0x06, 0x30, /* 000001100011 */ + 0x03, 0x60, /* 000000110110 */ + 0x39, 0xc0, /* 001110011100 */ + 0x6c, 0x00, /* 011011000000 */ + 0x06, 0x30, /* 000001100011 */ + 0x03, 0x60, /* 000000110110 */ + 0x01, 0xc0, /* 000000011100 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 248 0xf8 '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x0f, 0x00, /* 000011110000 */ + 0x19, 0x80, /* 000110011000 */ + 0x19, 0x80, /* 000110011000 */ + 0x19, 0x80, /* 000110011000 */ + 0x0f, 0x00, /* 000011110000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 249 0xf9 '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x1c, 0x00, /* 000111000000 */ + 0x3e, 0x00, /* 001111100000 */ + 0x3e, 0x00, /* 001111100000 */ + 0x3e, 0x00, /* 001111100000 */ + 0x1c, 0x00, /* 000111000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 250 0xfa '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x18, 0x00, /* 000110000000 */ + 0x3c, 0x00, /* 001111000000 */ + 0x3c, 0x00, /* 001111000000 */ + 0x18, 0x00, /* 000110000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 251 0xfb '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x07, 0xe0, /* 000001111110 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x06, 0x00, /* 000001100000 */ + 0xc6, 0x00, /* 110001100000 */ + 0x66, 0x00, /* 011001100000 */ + 0x36, 0x00, /* 001101100000 */ + 0x1e, 0x00, /* 000111100000 */ + 0x0e, 0x00, /* 000011100000 */ + 0x06, 0x00, /* 000001100000 */ + 0x02, 0x00, /* 000000100000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 252 0xfc '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x13, 0x80, /* 000100111000 */ + 0x3d, 0xc0, /* 001111011100 */ + 0x18, 0xc0, /* 000110001100 */ + 0x18, 0xc0, /* 000110001100 */ + 0x18, 0xc0, /* 000110001100 */ + 0x18, 0xc0, /* 000110001100 */ + 0x3d, 0xe0, /* 001111011110 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 253 0xfd '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x0f, 0x00, /* 000011110000 */ + 0x1f, 0x80, /* 000111111000 */ + 0x31, 0x80, /* 001100011000 */ + 0x21, 0x80, /* 001000011000 */ + 0x03, 0x00, /* 000000110000 */ + 0x06, 0x00, /* 000001100000 */ + 0x0c, 0x00, /* 000011000000 */ + 0x18, 0x40, /* 000110000100 */ + 0x3f, 0xc0, /* 001111111100 */ + 0x3f, 0xc0, /* 001111111100 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 254 0xfe '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x3f, 0xc0, /* 001111111100 */ + 0x3f, 0xc0, /* 001111111100 */ + 0x3f, 0xc0, /* 001111111100 */ + 0x3f, 0xc0, /* 001111111100 */ + 0x3f, 0xc0, /* 001111111100 */ + 0x3f, 0xc0, /* 001111111100 */ + 0x3f, 0xc0, /* 001111111100 */ + 0x3f, 0xc0, /* 001111111100 */ + 0x3f, 0xc0, /* 001111111100 */ + 0x3f, 0xc0, /* 001111111100 */ + 0x3f, 0xc0, /* 001111111100 */ + 0x3f, 0xc0, /* 001111111100 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + + /* 255 0xff '.' */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ + 0x00, 0x00, /* 000000000000 */ +}; + +#endif
Modern mobile phones typically have high pixel density. Bootmenu is hardly readable on those with 8x16 font.
Signed-off-by: Dzmitry Sankouski dsankouski@gmail.com Reviewed-by: Simon Glass sjg@chromium.org --- Changes for v2: - edit for runtime configuration Changes for v3: none Charges for v4: N/A Charges for v5: N/A Charges for v6: rebase only Charges for v7: none
drivers/video/Kconfig | 7 + include/video_font.h | 6 + include/video_font_ter16x32.h | 2062 +++++++++++++++++++++++++++++++++ 3 files changed, 2075 insertions(+) create mode 100644 include/video_font_ter16x32.h
diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index a928ae498a..60f4a4bf9c 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -38,6 +38,13 @@ config VIDEO_FONT_SUN12X22 Provides character bitmap data in header file. When selecting multiple fonts, you may want to enable CMD_SELECT_FONT too.
+config VIDEO_FONT_16X32 + bool "16 x 32 font size" + help + Font for video console driver, 16 x 32 pixels + Provides character bitmap data in header file. + When selecting multiple fonts, you may want to enable CMD_SELECT_FONT too. + config VIDEO_LOGO bool "Show the U-Boot logo on the display" default y if !SPLASH_SCREEN diff --git a/include/video_font.h b/include/video_font.h index f354d0cc4d..05d3f989a7 100644 --- a/include/video_font.h +++ b/include/video_font.h @@ -18,6 +18,9 @@ #if defined(CONFIG_VIDEO_FONT_SUN12X22) #include <video_font_sun12x22.h> #endif +#if defined(CONFIG_VIDEO_FONT_16X32) +#include <video_font_ter16x32.h> +#endif
static struct video_fontdata __maybe_unused fonts[] = { #if defined(CONFIG_VIDEO_FONT_8X16) @@ -28,6 +31,9 @@ static struct video_fontdata __maybe_unused fonts[] = { #endif #if defined(CONFIG_VIDEO_FONT_SUN12X22) FONT_ENTRY(12, 22, 12x22), +#endif +#if defined(CONFIG_VIDEO_FONT_16X32) + FONT_ENTRY(16, 32, 16x32), #endif {/* list terminator */} }; diff --git a/include/video_font_ter16x32.h b/include/video_font_ter16x32.h new file mode 100644 index 0000000000..bcf3d4b123 --- /dev/null +++ b/include/video_font_ter16x32.h @@ -0,0 +1,2062 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copied from linux. + */ + +#ifndef _VIDEO_FONT_TER_16X32_ +#define _VIDEO_FONT_TER_16X32_ + +#include <video_font_data.h> + +static unsigned char video_fontdata_16x32[VIDEO_FONT_SIZE(256, 16, 32)] = { + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x7f, 0xfc, 0x7f, 0xfc, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x7f, 0xfc, 0x7f, 0xfc, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 0 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x3f, 0xf8, 0x7f, 0xfc, + 0xf0, 0x1e, 0xe0, 0x0e, 0xe0, 0x0e, 0xe0, 0x0e, + 0xee, 0xee, 0xee, 0xee, 0xe0, 0x0e, 0xe0, 0x0e, + 0xe0, 0x0e, 0xe0, 0x0e, 0xef, 0xee, 0xe7, 0xce, + 0xe0, 0x0e, 0xe0, 0x0e, 0xe0, 0x0e, 0xf0, 0x1e, + 0x7f, 0xfc, 0x3f, 0xf8, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 1 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x3f, 0xf8, 0x7f, 0xfc, + 0xff, 0xfe, 0xff, 0xfe, 0xff, 0xfe, 0xff, 0xfe, + 0xe3, 0x8e, 0xe3, 0x8e, 0xff, 0xfe, 0xff, 0xfe, + 0xff, 0xfe, 0xff, 0xfe, 0xe0, 0x0e, 0xf0, 0x1e, + 0xf8, 0x3e, 0xff, 0xfe, 0xff, 0xfe, 0xff, 0xfe, + 0x7f, 0xfc, 0x3f, 0xf8, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 2 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x78, 0x3c, 0xfc, 0x7e, 0xfe, 0xfe, 0xff, 0xfe, + 0xff, 0xfe, 0xff, 0xfe, 0xff, 0xfe, 0xff, 0xfe, + 0x7f, 0xfc, 0x7f, 0xfc, 0x3f, 0xf8, 0x1f, 0xf0, + 0x0f, 0xe0, 0x07, 0xc0, 0x03, 0x80, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 3 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x03, 0x80, 0x07, 0xc0, 0x0f, 0xe0, + 0x1f, 0xf0, 0x3f, 0xf8, 0x7f, 0xfc, 0xff, 0xfe, + 0xff, 0xfe, 0x7f, 0xfc, 0x3f, 0xf8, 0x1f, 0xf0, + 0x0f, 0xe0, 0x07, 0xc0, 0x03, 0x80, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 4 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x07, 0xc0, 0x0f, 0xe0, + 0x0f, 0xe0, 0x0f, 0xe0, 0x0f, 0xe0, 0x0f, 0xe0, + 0x07, 0xc0, 0x03, 0x80, 0x3b, 0xb8, 0x7f, 0xfc, + 0xff, 0xfe, 0xff, 0xfe, 0xff, 0xfe, 0xff, 0xfe, + 0x7f, 0xfc, 0x3b, 0xb8, 0x03, 0x80, 0x03, 0x80, + 0x0f, 0xe0, 0x0f, 0xe0, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 5 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x03, 0x80, 0x03, 0x80, + 0x07, 0xc0, 0x0f, 0xe0, 0x1f, 0xf0, 0x3f, 0xf8, + 0x7f, 0xfc, 0x7f, 0xfc, 0xff, 0xfe, 0xff, 0xfe, + 0xff, 0xfe, 0xff, 0xfe, 0xff, 0xfe, 0x7b, 0xbc, + 0x3b, 0xb8, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x0f, 0xe0, 0x0f, 0xe0, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 6 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x03, 0xc0, 0x07, 0xe0, 0x0f, 0xf0, 0x0f, 0xf0, + 0x0f, 0xf0, 0x0f, 0xf0, 0x07, 0xe0, 0x03, 0xc0, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 7 */ + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, + 0xfc, 0x3f, 0xf8, 0x1f, 0xf0, 0x0f, 0xf0, 0x0f, + 0xf0, 0x0f, 0xf0, 0x0f, 0xf8, 0x1f, 0xfc, 0x3f, + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* 8 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x03, 0xc0, 0x07, 0xe0, 0x0e, 0x70, 0x0c, 0x30, + 0x0c, 0x30, 0x0e, 0x70, 0x07, 0xe0, 0x03, 0xc0, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 9 */ + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, + 0xfc, 0x3f, 0xf8, 0x1f, 0xf1, 0x8f, 0xf3, 0xcf, + 0xf3, 0xcf, 0xf1, 0x8f, 0xf8, 0x1f, 0xfc, 0x3f, + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* 10 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x03, 0xfe, 0x03, 0xfe, + 0x00, 0x1e, 0x00, 0x3e, 0x00, 0x76, 0x00, 0xe6, + 0x01, 0xc6, 0x03, 0x86, 0x3f, 0xe0, 0x7f, 0xf0, + 0xf0, 0x78, 0xe0, 0x38, 0xe0, 0x38, 0xe0, 0x38, + 0xe0, 0x38, 0xe0, 0x38, 0xe0, 0x38, 0xf0, 0x78, + 0x7f, 0xf0, 0x3f, 0xe0, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 11 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x1f, 0xf0, 0x3f, 0xf8, + 0x78, 0x3c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x78, 0x3c, 0x3f, 0xf8, + 0x1f, 0xf0, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x7f, 0xfc, 0x7f, 0xfc, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 12 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x3f, 0xfc, 0x3f, 0xfc, + 0x38, 0x1c, 0x38, 0x1c, 0x38, 0x1c, 0x38, 0x1c, + 0x3f, 0xfc, 0x3f, 0xfc, 0x38, 0x00, 0x38, 0x00, + 0x38, 0x00, 0x38, 0x00, 0x38, 0x00, 0x38, 0x00, + 0x38, 0x00, 0x38, 0x00, 0x38, 0x00, 0x38, 0x00, + 0xf8, 0x00, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 13 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x7f, 0xfe, 0x7f, 0xfe, + 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, + 0x7f, 0xfe, 0x7f, 0xfe, 0x70, 0x0e, 0x70, 0x0e, + 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, + 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x3e, + 0xf0, 0x3c, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 14 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x73, 0x9c, 0x73, 0x9c, + 0x3b, 0xb8, 0x1f, 0xf0, 0x0f, 0xe0, 0x7c, 0x7c, + 0x7c, 0x7c, 0x0f, 0xe0, 0x1f, 0xf0, 0x3b, 0xb8, + 0x73, 0x9c, 0x73, 0x9c, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 15 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0xc0, 0x00, 0xf0, 0x00, 0xfc, 0x00, 0xff, 0x00, + 0xff, 0xc0, 0xff, 0xf0, 0xff, 0xfc, 0xff, 0xff, + 0xff, 0xff, 0xff, 0xfc, 0xff, 0xf0, 0xff, 0xc0, + 0xff, 0x00, 0xfc, 0x00, 0xf0, 0x00, 0xc0, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 16 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x03, 0x00, 0x0f, 0x00, 0x3f, 0x00, 0xff, + 0x03, 0xff, 0x0f, 0xff, 0x3f, 0xff, 0xff, 0xff, + 0xff, 0xff, 0x3f, 0xff, 0x0f, 0xff, 0x03, 0xff, + 0x00, 0xff, 0x00, 0x3f, 0x00, 0x0f, 0x00, 0x03, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 17 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x03, 0x80, 0x07, 0xc0, + 0x0f, 0xe0, 0x1f, 0xf0, 0x3b, 0xb8, 0x73, 0x9c, + 0x63, 0x8c, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x63, 0x8c, + 0x73, 0x9c, 0x3b, 0xb8, 0x1f, 0xf0, 0x0f, 0xe0, + 0x07, 0xc0, 0x03, 0x80, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 18 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x1c, 0x70, 0x1c, 0x70, + 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, + 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, + 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x1c, 0x70, 0x1c, 0x70, + 0x1c, 0x70, 0x1c, 0x70, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 19 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x1f, 0xfe, 0x3f, 0xfe, + 0x79, 0xce, 0x71, 0xce, 0x71, 0xce, 0x71, 0xce, + 0x71, 0xce, 0x71, 0xce, 0x79, 0xce, 0x3f, 0xce, + 0x1f, 0xce, 0x01, 0xce, 0x01, 0xce, 0x01, 0xce, + 0x01, 0xce, 0x01, 0xce, 0x01, 0xce, 0x01, 0xce, + 0x01, 0xce, 0x01, 0xce, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 20 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x07, 0xe0, 0x0f, 0xf0, 0x1e, 0x78, 0x1c, 0x38, + 0x1c, 0x00, 0x1e, 0x00, 0x0f, 0xc0, 0x0f, 0xe0, + 0x1c, 0xf0, 0x1c, 0x78, 0x1c, 0x38, 0x1c, 0x38, + 0x1c, 0x38, 0x1e, 0x38, 0x0f, 0x38, 0x07, 0xf0, + 0x03, 0xf0, 0x00, 0x78, 0x00, 0x38, 0x1c, 0x38, + 0x1e, 0x78, 0x0f, 0xf0, 0x07, 0xe0, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 21 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x7f, 0xfe, 0x7f, 0xfe, + 0x7f, 0xfe, 0x7f, 0xfe, 0x7f, 0xfe, 0x7f, 0xfe, + 0x7f, 0xfe, 0x7f, 0xfe, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 22 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x03, 0x80, 0x07, 0xc0, + 0x0f, 0xe0, 0x1f, 0xf0, 0x3b, 0xb8, 0x73, 0x9c, + 0x63, 0x8c, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x63, 0x8c, 0x73, 0x9c, 0x3b, 0xb8, + 0x1f, 0xf0, 0x0f, 0xe0, 0x07, 0xc0, 0x03, 0x80, + 0x7f, 0xfc, 0x7f, 0xfc, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 23 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x03, 0x80, 0x07, 0xc0, + 0x0f, 0xe0, 0x1f, 0xf0, 0x3b, 0xb8, 0x73, 0x9c, + 0x63, 0x8c, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 24 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x63, 0x8c, + 0x73, 0x9c, 0x3b, 0xb8, 0x1f, 0xf0, 0x0f, 0xe0, + 0x07, 0xc0, 0x03, 0x80, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 25 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0xc0, 0x00, 0xe0, 0x00, 0x70, + 0x00, 0x38, 0x00, 0x1c, 0x7f, 0xfe, 0x7f, 0xfe, + 0x7f, 0xfe, 0x00, 0x1c, 0x00, 0x38, 0x00, 0x70, + 0x00, 0xe0, 0x00, 0xc0, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 26 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x03, 0x00, 0x07, 0x00, 0x0e, 0x00, + 0x1c, 0x00, 0x38, 0x00, 0x7f, 0xfe, 0x7f, 0xfe, + 0x7f, 0xfe, 0x38, 0x00, 0x1c, 0x00, 0x0e, 0x00, + 0x07, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 27 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x70, 0x00, 0x70, 0x00, + 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, + 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, + 0x7f, 0xfc, 0x7f, 0xfc, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 28 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x06, 0x60, 0x0e, 0x70, 0x1c, 0x38, + 0x38, 0x1c, 0x70, 0x0e, 0xff, 0xff, 0xff, 0xff, + 0xff, 0xff, 0x70, 0x0e, 0x38, 0x1c, 0x1c, 0x38, + 0x0e, 0x70, 0x06, 0x60, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 29 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x01, 0x80, 0x01, 0x80, 0x03, 0xc0, 0x03, 0xc0, + 0x07, 0xe0, 0x07, 0xe0, 0x0f, 0xf0, 0x0f, 0xf0, + 0x1f, 0xf8, 0x1f, 0xf8, 0x3f, 0xfc, 0x3f, 0xfc, + 0x7f, 0xfe, 0x7f, 0xfe, 0xff, 0xff, 0xff, 0xff, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 30 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0xff, 0xff, 0xff, 0xff, 0x7f, 0xfe, 0x7f, 0xfe, + 0x3f, 0xfc, 0x3f, 0xfc, 0x1f, 0xf8, 0x1f, 0xf8, + 0x0f, 0xf0, 0x0f, 0xf0, 0x07, 0xe0, 0x07, 0xe0, + 0x03, 0xc0, 0x03, 0xc0, 0x01, 0x80, 0x01, 0x80, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 31 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 32 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 33 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, + 0x1c, 0x70, 0x1c, 0x70, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 34 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x1c, 0x70, 0x1c, 0x70, + 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x7f, 0xfc, + 0x7f, 0xfc, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, + 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x7f, 0xfc, + 0x7f, 0xfc, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, + 0x1c, 0x70, 0x1c, 0x70, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 35 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x1f, 0xf0, + 0x3f, 0xf8, 0x7b, 0xbc, 0x73, 0x9c, 0x73, 0x80, + 0x73, 0x80, 0x73, 0x80, 0x7b, 0x80, 0x3f, 0xf0, + 0x1f, 0xf8, 0x03, 0xbc, 0x03, 0x9c, 0x03, 0x9c, + 0x03, 0x9c, 0x73, 0x9c, 0x7b, 0xbc, 0x3f, 0xf8, + 0x1f, 0xf0, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 36 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x1f, 0x1c, 0x3f, 0x9c, + 0x3b, 0xb8, 0x3b, 0xb8, 0x3f, 0xf0, 0x1f, 0x70, + 0x00, 0xe0, 0x00, 0xe0, 0x01, 0xc0, 0x01, 0xc0, + 0x03, 0x80, 0x03, 0x80, 0x07, 0x00, 0x07, 0x00, + 0x0e, 0xf8, 0x0f, 0xfc, 0x1d, 0xdc, 0x1d, 0xdc, + 0x39, 0xfc, 0x38, 0xf8, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 37 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x0f, 0xc0, 0x1f, 0xe0, + 0x38, 0x70, 0x38, 0x70, 0x38, 0x70, 0x38, 0x70, + 0x38, 0x70, 0x1c, 0xe0, 0x0f, 0xc0, 0x0f, 0x80, + 0x1f, 0xce, 0x38, 0xee, 0x70, 0x7c, 0x70, 0x38, + 0x70, 0x38, 0x70, 0x38, 0x70, 0x38, 0x78, 0x7c, + 0x3f, 0xee, 0x1f, 0xce, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 38 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 39 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0xe0, 0x01, 0xc0, + 0x03, 0x80, 0x07, 0x00, 0x07, 0x00, 0x0e, 0x00, + 0x0e, 0x00, 0x0e, 0x00, 0x0e, 0x00, 0x0e, 0x00, + 0x0e, 0x00, 0x0e, 0x00, 0x0e, 0x00, 0x0e, 0x00, + 0x0e, 0x00, 0x07, 0x00, 0x07, 0x00, 0x03, 0x80, + 0x01, 0xc0, 0x00, 0xe0, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 40 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x0e, 0x00, 0x07, 0x00, + 0x03, 0x80, 0x01, 0xc0, 0x01, 0xc0, 0x00, 0xe0, + 0x00, 0xe0, 0x00, 0xe0, 0x00, 0xe0, 0x00, 0xe0, + 0x00, 0xe0, 0x00, 0xe0, 0x00, 0xe0, 0x00, 0xe0, + 0x00, 0xe0, 0x01, 0xc0, 0x01, 0xc0, 0x03, 0x80, + 0x07, 0x00, 0x0e, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 41 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x38, 0x38, 0x1c, 0x70, + 0x0e, 0xe0, 0x07, 0xc0, 0x03, 0x80, 0x7f, 0xfc, + 0x7f, 0xfc, 0x03, 0x80, 0x07, 0xc0, 0x0e, 0xe0, + 0x1c, 0x70, 0x38, 0x38, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 42 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x7f, 0xfc, + 0x7f, 0xfc, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 43 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x07, 0x00, 0x0e, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 44 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7f, 0xfc, + 0x7f, 0xfc, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 45 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 46 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x1c, 0x00, 0x1c, + 0x00, 0x38, 0x00, 0x38, 0x00, 0x70, 0x00, 0x70, + 0x00, 0xe0, 0x00, 0xe0, 0x01, 0xc0, 0x01, 0xc0, + 0x03, 0x80, 0x03, 0x80, 0x07, 0x00, 0x07, 0x00, + 0x0e, 0x00, 0x0e, 0x00, 0x1c, 0x00, 0x1c, 0x00, + 0x38, 0x00, 0x38, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 47 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x1f, 0xf0, 0x3f, 0xf8, + 0x78, 0x3c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x3c, + 0x70, 0x7c, 0x70, 0xfc, 0x71, 0xdc, 0x73, 0x9c, + 0x77, 0x1c, 0x7e, 0x1c, 0x7c, 0x1c, 0x78, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x78, 0x3c, + 0x3f, 0xf8, 0x1f, 0xf0, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 48 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x03, 0x80, 0x07, 0x80, + 0x0f, 0x80, 0x1f, 0x80, 0x1f, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x1f, 0xf0, 0x1f, 0xf0, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 49 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x1f, 0xf0, 0x3f, 0xf8, + 0x78, 0x3c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x00, 0x1c, 0x00, 0x38, 0x00, 0x70, + 0x00, 0xe0, 0x01, 0xc0, 0x03, 0x80, 0x07, 0x00, + 0x0e, 0x00, 0x1c, 0x00, 0x38, 0x00, 0x70, 0x00, + 0x7f, 0xfc, 0x7f, 0xfc, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 50 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x1f, 0xf0, 0x3f, 0xf8, + 0x78, 0x3c, 0x70, 0x1c, 0x70, 0x1c, 0x00, 0x1c, + 0x00, 0x1c, 0x00, 0x1c, 0x00, 0x3c, 0x0f, 0xf8, + 0x0f, 0xf8, 0x00, 0x3c, 0x00, 0x1c, 0x00, 0x1c, + 0x00, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x78, 0x3c, + 0x3f, 0xf8, 0x1f, 0xf0, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 51 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x1c, 0x00, 0x3c, + 0x00, 0x7c, 0x00, 0xfc, 0x01, 0xdc, 0x03, 0x9c, + 0x07, 0x1c, 0x0e, 0x1c, 0x1c, 0x1c, 0x38, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x7f, 0xfc, + 0x7f, 0xfc, 0x00, 0x1c, 0x00, 0x1c, 0x00, 0x1c, + 0x00, 0x1c, 0x00, 0x1c, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 52 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x7f, 0xfc, 0x7f, 0xfc, + 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, + 0x70, 0x00, 0x70, 0x00, 0x7f, 0xf0, 0x7f, 0xf8, + 0x00, 0x3c, 0x00, 0x1c, 0x00, 0x1c, 0x00, 0x1c, + 0x00, 0x1c, 0x00, 0x1c, 0x70, 0x1c, 0x78, 0x1c, + 0x3f, 0xf8, 0x1f, 0xf0, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 53 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x1f, 0xf8, 0x3f, 0xf8, + 0x78, 0x00, 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, + 0x70, 0x00, 0x70, 0x00, 0x7f, 0xf0, 0x7f, 0xf8, + 0x70, 0x3c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x78, 0x3c, + 0x3f, 0xf8, 0x1f, 0xf0, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 54 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x7f, 0xfc, 0x7f, 0xfc, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x38, + 0x00, 0x38, 0x00, 0x70, 0x00, 0x70, 0x00, 0xe0, + 0x00, 0xe0, 0x01, 0xc0, 0x01, 0xc0, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 55 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x1f, 0xf0, 0x3f, 0xf8, + 0x78, 0x3c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x78, 0x3c, 0x3f, 0xf8, + 0x3f, 0xf8, 0x78, 0x3c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x78, 0x3c, + 0x3f, 0xf8, 0x1f, 0xf0, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 56 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x1f, 0xf0, 0x3f, 0xf8, + 0x78, 0x3c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x78, 0x1c, + 0x3f, 0xfc, 0x1f, 0xfc, 0x00, 0x1c, 0x00, 0x1c, + 0x00, 0x1c, 0x00, 0x1c, 0x00, 0x1c, 0x00, 0x3c, + 0x3f, 0xf8, 0x3f, 0xf0, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 57 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 58 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x07, 0x00, 0x0e, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 59 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x1c, 0x00, 0x38, + 0x00, 0x70, 0x00, 0xe0, 0x01, 0xc0, 0x03, 0x80, + 0x07, 0x00, 0x0e, 0x00, 0x1c, 0x00, 0x38, 0x00, + 0x38, 0x00, 0x1c, 0x00, 0x0e, 0x00, 0x07, 0x00, + 0x03, 0x80, 0x01, 0xc0, 0x00, 0xe0, 0x00, 0x70, + 0x00, 0x38, 0x00, 0x1c, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 60 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x7f, 0xfc, 0x7f, 0xfc, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x7f, 0xfc, 0x7f, 0xfc, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 61 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x38, 0x00, 0x1c, 0x00, + 0x0e, 0x00, 0x07, 0x00, 0x03, 0x80, 0x01, 0xc0, + 0x00, 0xe0, 0x00, 0x70, 0x00, 0x38, 0x00, 0x1c, + 0x00, 0x1c, 0x00, 0x38, 0x00, 0x70, 0x00, 0xe0, + 0x01, 0xc0, 0x03, 0x80, 0x07, 0x00, 0x0e, 0x00, + 0x1c, 0x00, 0x38, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 62 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x1f, 0xf0, 0x3f, 0xf8, + 0x78, 0x3c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x00, 0x38, 0x00, 0x70, 0x00, 0xe0, + 0x01, 0xc0, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x00, 0x00, 0x00, 0x00, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 63 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x1f, 0xf8, 0x3f, 0xfc, + 0x78, 0x0e, 0x70, 0x06, 0x71, 0xfe, 0x73, 0xfe, + 0x77, 0x8e, 0x77, 0x0e, 0x77, 0x0e, 0x77, 0x0e, + 0x77, 0x0e, 0x77, 0x0e, 0x77, 0x0e, 0x77, 0x9e, + 0x73, 0xfe, 0x71, 0xf6, 0x70, 0x00, 0x78, 0x00, + 0x3f, 0xfe, 0x1f, 0xfe, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 64 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x1f, 0xf0, 0x3f, 0xf8, + 0x78, 0x3c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x7f, 0xfc, 0x7f, 0xfc, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 65 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x7f, 0xf0, 0x7f, 0xf8, + 0x70, 0x3c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x38, 0x7f, 0xf0, 0x7f, 0xf0, + 0x70, 0x38, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x3c, + 0x7f, 0xf8, 0x7f, 0xf0, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 66 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x1f, 0xf0, 0x3f, 0xf8, + 0x78, 0x3c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x00, + 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, + 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, + 0x70, 0x00, 0x70, 0x1c, 0x70, 0x1c, 0x78, 0x3c, + 0x3f, 0xf8, 0x1f, 0xf0, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 67 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x7f, 0xc0, 0x7f, 0xf0, + 0x70, 0x78, 0x70, 0x38, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x38, 0x70, 0x78, + 0x7f, 0xf0, 0x7f, 0xc0, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 68 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x7f, 0xfc, 0x7f, 0xfc, + 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, + 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, 0x7f, 0xe0, + 0x7f, 0xe0, 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, + 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, + 0x7f, 0xfc, 0x7f, 0xfc, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 69 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x7f, 0xfc, 0x7f, 0xfc, + 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, + 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, 0x7f, 0xe0, + 0x7f, 0xe0, 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, + 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, + 0x70, 0x00, 0x70, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 70 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x1f, 0xf0, 0x3f, 0xf8, + 0x78, 0x3c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x00, + 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, 0x71, 0xfc, + 0x71, 0xfc, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x78, 0x3c, + 0x3f, 0xf8, 0x1f, 0xf0, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 71 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x7f, 0xfc, + 0x7f, 0xfc, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 72 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x0f, 0xe0, 0x0f, 0xe0, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x0f, 0xe0, 0x0f, 0xe0, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 73 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0xfe, 0x00, 0xfe, + 0x00, 0x38, 0x00, 0x38, 0x00, 0x38, 0x00, 0x38, + 0x00, 0x38, 0x00, 0x38, 0x00, 0x38, 0x00, 0x38, + 0x00, 0x38, 0x00, 0x38, 0x00, 0x38, 0x00, 0x38, + 0x70, 0x38, 0x70, 0x38, 0x70, 0x38, 0x78, 0x78, + 0x3f, 0xf0, 0x1f, 0xe0, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 74 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x70, 0x0c, 0x70, 0x1c, + 0x70, 0x38, 0x70, 0x70, 0x70, 0xe0, 0x71, 0xc0, + 0x73, 0x80, 0x77, 0x00, 0x7e, 0x00, 0x7c, 0x00, + 0x7c, 0x00, 0x7e, 0x00, 0x77, 0x00, 0x73, 0x80, + 0x71, 0xc0, 0x70, 0xe0, 0x70, 0x70, 0x70, 0x38, + 0x70, 0x1c, 0x70, 0x0c, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 75 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x70, 0x00, 0x70, 0x00, + 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, + 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, + 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, + 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, + 0x7f, 0xfc, 0x7f, 0xfc, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 76 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x70, 0x0e, 0x70, 0x0e, + 0x78, 0x1e, 0x7c, 0x3e, 0x7e, 0x7e, 0x7e, 0x7e, + 0x77, 0xee, 0x73, 0xce, 0x73, 0xce, 0x71, 0x8e, + 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, + 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, + 0x70, 0x0e, 0x70, 0x0e, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 77 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x78, 0x1c, + 0x7c, 0x1c, 0x7e, 0x1c, 0x77, 0x1c, 0x73, 0x9c, + 0x71, 0xdc, 0x70, 0xfc, 0x70, 0x7c, 0x70, 0x3c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 78 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x1f, 0xf0, 0x3f, 0xf8, + 0x78, 0x3c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x78, 0x3c, + 0x3f, 0xf8, 0x1f, 0xf0, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 79 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x7f, 0xf0, 0x7f, 0xf8, + 0x70, 0x3c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x3c, + 0x7f, 0xf8, 0x7f, 0xf0, 0x70, 0x00, 0x70, 0x00, + 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, + 0x70, 0x00, 0x70, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 80 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x1f, 0xf0, 0x3f, 0xf8, + 0x78, 0x3c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x73, 0x9c, 0x79, 0xfc, + 0x3f, 0xf8, 0x1f, 0xf0, 0x00, 0x38, 0x00, 0x1c, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 81 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x7f, 0xf0, 0x7f, 0xf8, + 0x70, 0x3c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x3c, + 0x7f, 0xf8, 0x7f, 0xf0, 0x7e, 0x00, 0x77, 0x00, + 0x73, 0x80, 0x71, 0xc0, 0x70, 0xe0, 0x70, 0x70, + 0x70, 0x38, 0x70, 0x1c, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 82 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x1f, 0xf0, 0x3f, 0xf8, + 0x78, 0x3c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x00, + 0x70, 0x00, 0x70, 0x00, 0x78, 0x00, 0x3f, 0xf0, + 0x1f, 0xf8, 0x00, 0x3c, 0x00, 0x1c, 0x00, 0x1c, + 0x00, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x78, 0x3c, + 0x3f, 0xf8, 0x1f, 0xf0, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 83 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x7f, 0xfc, 0x7f, 0xfc, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 84 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x78, 0x3c, + 0x3f, 0xf8, 0x1f, 0xf0, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 85 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x38, 0x38, + 0x38, 0x38, 0x38, 0x38, 0x38, 0x38, 0x38, 0x38, + 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, + 0x0e, 0xe0, 0x0e, 0xe0, 0x0e, 0xe0, 0x07, 0xc0, + 0x07, 0xc0, 0x07, 0xc0, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 86 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x70, 0x0e, 0x70, 0x0e, + 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, + 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, + 0x71, 0x8e, 0x73, 0xce, 0x73, 0xce, 0x77, 0xee, + 0x7e, 0x7e, 0x7e, 0x7e, 0x7c, 0x3e, 0x78, 0x1e, + 0x70, 0x0e, 0x70, 0x0e, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 87 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x70, 0x1c, 0x70, 0x1c, + 0x38, 0x38, 0x38, 0x38, 0x1c, 0x70, 0x1c, 0x70, + 0x0e, 0xe0, 0x0e, 0xe0, 0x07, 0xc0, 0x07, 0xc0, + 0x07, 0xc0, 0x07, 0xc0, 0x0e, 0xe0, 0x0e, 0xe0, + 0x1c, 0x70, 0x1c, 0x70, 0x38, 0x38, 0x38, 0x38, + 0x70, 0x1c, 0x70, 0x1c, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 88 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x38, 0x38, 0x38, 0x38, 0x1c, 0x70, + 0x1c, 0x70, 0x0e, 0xe0, 0x0e, 0xe0, 0x07, 0xc0, + 0x07, 0xc0, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 89 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x7f, 0xfc, 0x7f, 0xfc, + 0x00, 0x1c, 0x00, 0x1c, 0x00, 0x1c, 0x00, 0x38, + 0x00, 0x70, 0x00, 0xe0, 0x01, 0xc0, 0x03, 0x80, + 0x07, 0x00, 0x0e, 0x00, 0x1c, 0x00, 0x38, 0x00, + 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, + 0x7f, 0xfc, 0x7f, 0xfc, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 90 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x0f, 0xf0, 0x0f, 0xf0, + 0x0e, 0x00, 0x0e, 0x00, 0x0e, 0x00, 0x0e, 0x00, + 0x0e, 0x00, 0x0e, 0x00, 0x0e, 0x00, 0x0e, 0x00, + 0x0e, 0x00, 0x0e, 0x00, 0x0e, 0x00, 0x0e, 0x00, + 0x0e, 0x00, 0x0e, 0x00, 0x0e, 0x00, 0x0e, 0x00, + 0x0f, 0xf0, 0x0f, 0xf0, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 91 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x38, 0x00, 0x38, 0x00, + 0x1c, 0x00, 0x1c, 0x00, 0x0e, 0x00, 0x0e, 0x00, + 0x07, 0x00, 0x07, 0x00, 0x03, 0x80, 0x03, 0x80, + 0x01, 0xc0, 0x01, 0xc0, 0x00, 0xe0, 0x00, 0xe0, + 0x00, 0x70, 0x00, 0x70, 0x00, 0x38, 0x00, 0x38, + 0x00, 0x1c, 0x00, 0x1c, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 92 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x0f, 0xf0, 0x0f, 0xf0, + 0x00, 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, 0x70, + 0x00, 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, 0x70, + 0x00, 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, 0x70, + 0x00, 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, 0x70, + 0x0f, 0xf0, 0x0f, 0xf0, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 93 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x03, 0x80, 0x07, 0xc0, 0x0e, 0xe0, 0x1c, 0x70, + 0x38, 0x38, 0x70, 0x1c, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 94 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7f, 0xfc, + 0x7f, 0xfc, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 95 */ + 0x00, 0x00, 0x00, 0x00, 0x1c, 0x00, 0x0e, 0x00, + 0x07, 0x00, 0x03, 0x80, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 96 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x3f, 0xf0, 0x3f, 0xf8, 0x00, 0x3c, 0x00, 0x1c, + 0x00, 0x1c, 0x1f, 0xfc, 0x3f, 0xfc, 0x78, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x78, 0x1c, + 0x3f, 0xfc, 0x1f, 0xfc, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 97 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x70, 0x00, 0x70, 0x00, + 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, + 0x7f, 0xf0, 0x7f, 0xf8, 0x70, 0x3c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x3c, + 0x7f, 0xf8, 0x7f, 0xf0, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 98 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x1f, 0xf0, 0x3f, 0xf8, 0x78, 0x3c, 0x70, 0x1c, + 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, + 0x70, 0x00, 0x70, 0x00, 0x70, 0x1c, 0x78, 0x3c, + 0x3f, 0xf8, 0x1f, 0xf0, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 99 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x1c, 0x00, 0x1c, + 0x00, 0x1c, 0x00, 0x1c, 0x00, 0x1c, 0x00, 0x1c, + 0x1f, 0xfc, 0x3f, 0xfc, 0x78, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x78, 0x1c, + 0x3f, 0xfc, 0x1f, 0xfc, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 100 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x1f, 0xf0, 0x3f, 0xf8, 0x78, 0x3c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x7f, 0xfc, 0x7f, 0xfc, + 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, 0x78, 0x1c, + 0x3f, 0xfc, 0x1f, 0xf8, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 101 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0xfe, 0x01, 0xfe, + 0x03, 0xc0, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x3f, 0xf8, 0x3f, 0xf8, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 102 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x1f, 0xfc, 0x3f, 0xfc, 0x78, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x78, 0x1c, + 0x3f, 0xfc, 0x1f, 0xfc, 0x00, 0x1c, 0x00, 0x1c, + 0x00, 0x3c, 0x3f, 0xf8, 0x3f, 0xf0, 0x00, 0x00, /* 103 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x70, 0x00, 0x70, 0x00, + 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, + 0x7f, 0xf0, 0x7f, 0xf8, 0x70, 0x3c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 104 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x00, 0x00, 0x00, 0x00, + 0x0f, 0x80, 0x0f, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x0f, 0xe0, 0x0f, 0xe0, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 105 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x38, 0x00, 0x38, + 0x00, 0x38, 0x00, 0x38, 0x00, 0x00, 0x00, 0x00, + 0x00, 0xf8, 0x00, 0xf8, 0x00, 0x38, 0x00, 0x38, + 0x00, 0x38, 0x00, 0x38, 0x00, 0x38, 0x00, 0x38, + 0x00, 0x38, 0x00, 0x38, 0x00, 0x38, 0x00, 0x38, + 0x00, 0x38, 0x00, 0x38, 0x38, 0x38, 0x38, 0x38, + 0x3c, 0x78, 0x1f, 0xf0, 0x0f, 0xe0, 0x00, 0x00, /* 106 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x38, 0x00, 0x38, 0x00, + 0x38, 0x00, 0x38, 0x00, 0x38, 0x00, 0x38, 0x00, + 0x38, 0x1c, 0x38, 0x38, 0x38, 0x70, 0x38, 0xe0, + 0x39, 0xc0, 0x3b, 0x80, 0x3f, 0x00, 0x3f, 0x00, + 0x3b, 0x80, 0x39, 0xc0, 0x38, 0xe0, 0x38, 0x70, + 0x38, 0x38, 0x38, 0x1c, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 107 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x0f, 0x80, 0x0f, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x0f, 0xe0, 0x0f, 0xe0, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 108 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x7f, 0xf0, 0x7f, 0xf8, 0x73, 0xbc, 0x73, 0x9c, + 0x73, 0x9c, 0x73, 0x9c, 0x73, 0x9c, 0x73, 0x9c, + 0x73, 0x9c, 0x73, 0x9c, 0x73, 0x9c, 0x73, 0x9c, + 0x73, 0x9c, 0x73, 0x9c, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 109 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x7f, 0xf0, 0x7f, 0xf8, 0x70, 0x3c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 110 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x1f, 0xf0, 0x3f, 0xf8, 0x78, 0x3c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x78, 0x3c, + 0x3f, 0xf8, 0x1f, 0xf0, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 111 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x7f, 0xf0, 0x7f, 0xf8, 0x70, 0x3c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x3c, + 0x7f, 0xf8, 0x7f, 0xf0, 0x70, 0x00, 0x70, 0x00, + 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, 0x00, 0x00, /* 112 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x1f, 0xfc, 0x3f, 0xfc, 0x78, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x78, 0x1c, + 0x3f, 0xfc, 0x1f, 0xfc, 0x00, 0x1c, 0x00, 0x1c, + 0x00, 0x1c, 0x00, 0x1c, 0x00, 0x1c, 0x00, 0x00, /* 113 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x73, 0xfc, 0x77, 0xfc, 0x7e, 0x00, 0x7c, 0x00, + 0x78, 0x00, 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, + 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, + 0x70, 0x00, 0x70, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 114 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x1f, 0xf0, 0x3f, 0xf8, 0x78, 0x3c, 0x70, 0x00, + 0x70, 0x00, 0x78, 0x00, 0x3f, 0xf0, 0x1f, 0xf8, + 0x00, 0x3c, 0x00, 0x1c, 0x00, 0x1c, 0x78, 0x3c, + 0x3f, 0xf8, 0x1f, 0xf0, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 115 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x07, 0x00, 0x07, 0x00, + 0x07, 0x00, 0x07, 0x00, 0x07, 0x00, 0x07, 0x00, + 0x7f, 0xf0, 0x7f, 0xf0, 0x07, 0x00, 0x07, 0x00, + 0x07, 0x00, 0x07, 0x00, 0x07, 0x00, 0x07, 0x00, + 0x07, 0x00, 0x07, 0x00, 0x07, 0x00, 0x07, 0x80, + 0x03, 0xfc, 0x01, 0xfc, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 116 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x78, 0x1c, + 0x3f, 0xfc, 0x1f, 0xfc, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 117 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x38, 0x38, + 0x38, 0x38, 0x38, 0x38, 0x1c, 0x70, 0x1c, 0x70, + 0x1c, 0x70, 0x0e, 0xe0, 0x0e, 0xe0, 0x07, 0xc0, + 0x07, 0xc0, 0x07, 0xc0, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 118 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x73, 0x9c, 0x73, 0x9c, 0x73, 0x9c, 0x73, 0x9c, + 0x73, 0x9c, 0x73, 0x9c, 0x73, 0x9c, 0x7b, 0xbc, + 0x3f, 0xf8, 0x1f, 0xf0, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 119 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x38, 0x38, + 0x1c, 0x70, 0x0e, 0xe0, 0x07, 0xc0, 0x07, 0xc0, + 0x0e, 0xe0, 0x1c, 0x70, 0x38, 0x38, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 120 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x78, 0x1c, + 0x3f, 0xfc, 0x1f, 0xfc, 0x00, 0x1c, 0x00, 0x1c, + 0x00, 0x3c, 0x3f, 0xf8, 0x3f, 0xf0, 0x00, 0x00, /* 121 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x7f, 0xfc, 0x7f, 0xfc, 0x00, 0x38, 0x00, 0x70, + 0x00, 0xe0, 0x01, 0xc0, 0x03, 0x80, 0x07, 0x00, + 0x0e, 0x00, 0x1c, 0x00, 0x38, 0x00, 0x70, 0x00, + 0x7f, 0xfc, 0x7f, 0xfc, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 122 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x01, 0xf0, 0x03, 0xf0, + 0x07, 0x80, 0x07, 0x00, 0x07, 0x00, 0x07, 0x00, + 0x07, 0x00, 0x07, 0x00, 0x07, 0x00, 0x3e, 0x00, + 0x3e, 0x00, 0x07, 0x00, 0x07, 0x00, 0x07, 0x00, + 0x07, 0x00, 0x07, 0x00, 0x07, 0x00, 0x07, 0x80, + 0x03, 0xf0, 0x01, 0xf0, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 123 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 124 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x3e, 0x00, 0x3f, 0x00, + 0x07, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x01, 0xf0, + 0x01, 0xf0, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x07, 0x80, + 0x3f, 0x00, 0x3e, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 125 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x1e, 0x1c, 0x3f, 0x1c, 0x77, 0x9c, 0x73, 0xdc, + 0x71, 0xf8, 0x70, 0xf0, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 126 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x03, 0x80, 0x07, 0xc0, + 0x0f, 0xe0, 0x1e, 0xf0, 0x3c, 0x78, 0x78, 0x3c, + 0xf0, 0x1e, 0xe0, 0x0e, 0xe0, 0x0e, 0xe0, 0x0e, + 0xe0, 0x0e, 0xe0, 0x0e, 0xe0, 0x0e, 0xe0, 0x0e, + 0xff, 0xfe, 0xff, 0xfe, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 127 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x1f, 0xf0, 0x3f, 0xf8, + 0x78, 0x3c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x00, + 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, + 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, + 0x70, 0x00, 0x70, 0x1c, 0x70, 0x1c, 0x78, 0x3c, + 0x3f, 0xf8, 0x1f, 0xf0, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x07, 0x00, 0x0e, 0x00, 0x00, 0x00, /* 128 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x1c, 0x70, 0x1c, 0x70, + 0x1c, 0x70, 0x1c, 0x70, 0x00, 0x00, 0x00, 0x00, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x78, 0x1c, + 0x3f, 0xfc, 0x1f, 0xfc, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 129 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x70, 0x00, 0xe0, + 0x01, 0xc0, 0x03, 0x80, 0x00, 0x00, 0x00, 0x00, + 0x1f, 0xf0, 0x3f, 0xf8, 0x78, 0x3c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x7f, 0xfc, 0x7f, 0xfc, + 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, 0x78, 0x1c, + 0x3f, 0xfc, 0x1f, 0xf8, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 130 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x03, 0x80, 0x07, 0xc0, + 0x0e, 0xe0, 0x1c, 0x70, 0x00, 0x00, 0x00, 0x00, + 0x3f, 0xf0, 0x3f, 0xf8, 0x00, 0x3c, 0x00, 0x1c, + 0x00, 0x1c, 0x1f, 0xfc, 0x3f, 0xfc, 0x78, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x78, 0x1c, + 0x3f, 0xfc, 0x1f, 0xfc, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 131 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x1c, 0x70, 0x1c, 0x70, + 0x1c, 0x70, 0x1c, 0x70, 0x00, 0x00, 0x00, 0x00, + 0x3f, 0xf0, 0x3f, 0xf8, 0x00, 0x3c, 0x00, 0x1c, + 0x00, 0x1c, 0x1f, 0xfc, 0x3f, 0xfc, 0x78, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x78, 0x1c, + 0x3f, 0xfc, 0x1f, 0xfc, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 132 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x1c, 0x00, 0x0e, 0x00, + 0x07, 0x00, 0x03, 0x80, 0x00, 0x00, 0x00, 0x00, + 0x3f, 0xf0, 0x3f, 0xf8, 0x00, 0x3c, 0x00, 0x1c, + 0x00, 0x1c, 0x1f, 0xfc, 0x3f, 0xfc, 0x78, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x78, 0x1c, + 0x3f, 0xfc, 0x1f, 0xfc, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 133 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x07, 0xc0, 0x0e, 0xe0, + 0x0e, 0xe0, 0x0e, 0xe0, 0x07, 0xc0, 0x00, 0x00, + 0x3f, 0xf0, 0x3f, 0xf8, 0x00, 0x3c, 0x00, 0x1c, + 0x00, 0x1c, 0x1f, 0xfc, 0x3f, 0xfc, 0x78, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x78, 0x1c, + 0x3f, 0xfc, 0x1f, 0xfc, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 134 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x1f, 0xf0, 0x3f, 0xf8, 0x78, 0x3c, 0x70, 0x1c, + 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, + 0x70, 0x00, 0x70, 0x00, 0x70, 0x1c, 0x78, 0x3c, + 0x3f, 0xf8, 0x1f, 0xf0, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x07, 0x00, 0x0e, 0x00, 0x00, 0x00, /* 135 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x03, 0x80, 0x07, 0xc0, + 0x0e, 0xe0, 0x1c, 0x70, 0x00, 0x00, 0x00, 0x00, + 0x1f, 0xf0, 0x3f, 0xf8, 0x78, 0x3c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x7f, 0xfc, 0x7f, 0xfc, + 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, 0x78, 0x1c, + 0x3f, 0xfc, 0x1f, 0xf8, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 136 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x1c, 0x70, 0x1c, 0x70, + 0x1c, 0x70, 0x1c, 0x70, 0x00, 0x00, 0x00, 0x00, + 0x1f, 0xf0, 0x3f, 0xf8, 0x78, 0x3c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x7f, 0xfc, 0x7f, 0xfc, + 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, 0x78, 0x1c, + 0x3f, 0xfc, 0x1f, 0xf8, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 137 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x1c, 0x00, 0x0e, 0x00, + 0x07, 0x00, 0x03, 0x80, 0x00, 0x00, 0x00, 0x00, + 0x1f, 0xf0, 0x3f, 0xf8, 0x78, 0x3c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x7f, 0xfc, 0x7f, 0xfc, + 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, 0x78, 0x1c, + 0x3f, 0xfc, 0x1f, 0xf8, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 138 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x1c, 0x70, 0x1c, 0x70, + 0x1c, 0x70, 0x1c, 0x70, 0x00, 0x00, 0x00, 0x00, + 0x0f, 0x80, 0x0f, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x0f, 0xe0, 0x0f, 0xe0, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 139 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x03, 0x80, 0x07, 0xc0, + 0x0e, 0xe0, 0x1c, 0x70, 0x00, 0x00, 0x00, 0x00, + 0x0f, 0x80, 0x0f, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x0f, 0xe0, 0x0f, 0xe0, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 140 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x1c, 0x00, 0x0e, 0x00, + 0x07, 0x00, 0x03, 0x80, 0x00, 0x00, 0x00, 0x00, + 0x0f, 0x80, 0x0f, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x0f, 0xe0, 0x0f, 0xe0, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 141 */ + 0x00, 0x00, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, + 0x1c, 0x70, 0x00, 0x00, 0x1f, 0xf0, 0x3f, 0xf8, + 0x78, 0x3c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x7f, 0xfc, 0x7f, 0xfc, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 142 */ + 0x00, 0x00, 0x07, 0xc0, 0x0e, 0xe0, 0x0e, 0xe0, + 0x0e, 0xe0, 0x07, 0xc0, 0x1f, 0xf0, 0x3f, 0xf8, + 0x78, 0x3c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x7f, 0xfc, 0x7f, 0xfc, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 143 */ + 0x00, 0x00, 0x00, 0x70, 0x00, 0xe0, 0x01, 0xc0, + 0x03, 0x80, 0x00, 0x00, 0x7f, 0xfc, 0x7f, 0xfc, + 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, + 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, 0x7f, 0xe0, + 0x7f, 0xe0, 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, + 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, + 0x7f, 0xfc, 0x7f, 0xfc, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 144 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x7e, 0xf8, 0x7f, 0xfc, 0x03, 0x9e, 0x03, 0x8e, + 0x03, 0x8e, 0x3f, 0x8e, 0x7f, 0xfe, 0xf3, 0xfe, + 0xe3, 0x80, 0xe3, 0x80, 0xe3, 0x80, 0xf3, 0xce, + 0x7f, 0xfe, 0x3e, 0xfc, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 145 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x3f, 0xfe, 0x7f, 0xfe, + 0xf1, 0xc0, 0xe1, 0xc0, 0xe1, 0xc0, 0xe1, 0xc0, + 0xe1, 0xc0, 0xe1, 0xc0, 0xe1, 0xc0, 0xff, 0xfe, + 0xff, 0xfe, 0xe1, 0xc0, 0xe1, 0xc0, 0xe1, 0xc0, + 0xe1, 0xc0, 0xe1, 0xc0, 0xe1, 0xc0, 0xe1, 0xc0, + 0xe1, 0xfe, 0xe1, 0xfe, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 146 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x03, 0x80, 0x07, 0xc0, + 0x0e, 0xe0, 0x1c, 0x70, 0x00, 0x00, 0x00, 0x00, + 0x1f, 0xf0, 0x3f, 0xf8, 0x78, 0x3c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x78, 0x3c, + 0x3f, 0xf8, 0x1f, 0xf0, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 147 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x1c, 0x70, 0x1c, 0x70, + 0x1c, 0x70, 0x1c, 0x70, 0x00, 0x00, 0x00, 0x00, + 0x1f, 0xf0, 0x3f, 0xf8, 0x78, 0x3c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x78, 0x3c, + 0x3f, 0xf8, 0x1f, 0xf0, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 148 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x1c, 0x00, 0x0e, 0x00, + 0x07, 0x00, 0x03, 0x80, 0x00, 0x00, 0x00, 0x00, + 0x1f, 0xf0, 0x3f, 0xf8, 0x78, 0x3c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x78, 0x3c, + 0x3f, 0xf8, 0x1f, 0xf0, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 149 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x03, 0x80, 0x07, 0xc0, + 0x0e, 0xe0, 0x1c, 0x70, 0x00, 0x00, 0x00, 0x00, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x78, 0x1c, + 0x3f, 0xfc, 0x1f, 0xfc, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 150 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x1c, 0x00, 0x0e, 0x00, + 0x07, 0x00, 0x03, 0x80, 0x00, 0x00, 0x00, 0x00, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x78, 0x1c, + 0x3f, 0xfc, 0x1f, 0xfc, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 151 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x1c, 0x70, 0x1c, 0x70, + 0x1c, 0x70, 0x1c, 0x70, 0x00, 0x00, 0x00, 0x00, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x78, 0x1c, + 0x3f, 0xfc, 0x1f, 0xfc, 0x00, 0x1c, 0x00, 0x1c, + 0x00, 0x3c, 0x3f, 0xf8, 0x3f, 0xf0, 0x00, 0x00, /* 152 */ + 0x00, 0x00, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, + 0x1c, 0x70, 0x00, 0x00, 0x1f, 0xf0, 0x3f, 0xf8, + 0x78, 0x3c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x78, 0x3c, + 0x3f, 0xf8, 0x1f, 0xf0, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 153 */ + 0x00, 0x00, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, + 0x1c, 0x70, 0x00, 0x00, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x78, 0x3c, + 0x3f, 0xf8, 0x1f, 0xf0, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 154 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x1f, 0xf0, 0x3f, 0xf8, 0x7b, 0xbc, 0x73, 0x9c, + 0x73, 0x80, 0x73, 0x80, 0x73, 0x80, 0x73, 0x80, + 0x73, 0x80, 0x73, 0x80, 0x73, 0x9c, 0x7b, 0xbc, + 0x3f, 0xf8, 0x1f, 0xf0, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 155 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x07, 0xe0, 0x0f, 0xf0, + 0x1e, 0x78, 0x1c, 0x38, 0x1c, 0x00, 0x1c, 0x00, + 0x1c, 0x00, 0x1c, 0x00, 0x1c, 0x00, 0x7f, 0xe0, + 0x7f, 0xe0, 0x1c, 0x00, 0x1c, 0x00, 0x1c, 0x00, + 0x1c, 0x00, 0x1c, 0x00, 0x1c, 0x1c, 0x1c, 0x1c, + 0x7f, 0xfc, 0x7f, 0xfc, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 156 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x70, 0x1c, 0x70, 0x1c, + 0x38, 0x38, 0x38, 0x38, 0x1c, 0x70, 0x1c, 0x70, + 0x0e, 0xe0, 0x0e, 0xe0, 0x07, 0xc0, 0x07, 0xc0, + 0x03, 0x80, 0x03, 0x80, 0x3f, 0xf8, 0x3f, 0xf8, + 0x03, 0x80, 0x03, 0x80, 0x3f, 0xf8, 0x3f, 0xf8, + 0x03, 0x80, 0x03, 0x80, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 157 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0xff, 0x00, 0xff, 0x80, + 0xe3, 0xc0, 0xe1, 0xc0, 0xe1, 0xc0, 0xe1, 0xc0, + 0xe1, 0xc0, 0xe1, 0xc0, 0xe3, 0xc0, 0xff, 0xf0, + 0xff, 0x70, 0xe0, 0x70, 0xe3, 0xfe, 0xe3, 0xfe, + 0xe0, 0x70, 0xe0, 0x70, 0xe0, 0x70, 0xe0, 0x70, + 0xe0, 0x7e, 0xe0, 0x3e, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 158 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x01, 0xf8, 0x03, 0xfc, + 0x03, 0x9c, 0x03, 0x9c, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x1f, 0xf0, 0x1f, 0xf0, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x73, 0x80, 0x73, 0x80, + 0x7f, 0x80, 0x3f, 0x00, 0x00, 0x00, 0x00, 0x00, /* 159 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x70, 0x00, 0xe0, + 0x01, 0xc0, 0x03, 0x80, 0x00, 0x00, 0x00, 0x00, + 0x3f, 0xf0, 0x3f, 0xf8, 0x00, 0x3c, 0x00, 0x1c, + 0x00, 0x1c, 0x1f, 0xfc, 0x3f, 0xfc, 0x78, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x78, 0x1c, + 0x3f, 0xfc, 0x1f, 0xfc, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 160 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x70, 0x00, 0xe0, + 0x01, 0xc0, 0x03, 0x80, 0x00, 0x00, 0x00, 0x00, + 0x0f, 0x80, 0x0f, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x0f, 0xe0, 0x0f, 0xe0, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 161 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x70, 0x00, 0xe0, + 0x01, 0xc0, 0x03, 0x80, 0x00, 0x00, 0x00, 0x00, + 0x1f, 0xf0, 0x3f, 0xf8, 0x78, 0x3c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x78, 0x3c, + 0x3f, 0xf8, 0x1f, 0xf0, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 162 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x70, 0x00, 0xe0, + 0x01, 0xc0, 0x03, 0x80, 0x00, 0x00, 0x00, 0x00, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x78, 0x1c, + 0x3f, 0xfc, 0x1f, 0xfc, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 163 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x1f, 0x38, 0x3b, 0xb8, + 0x3b, 0xb8, 0x39, 0xf0, 0x00, 0x00, 0x00, 0x00, + 0x7f, 0xf0, 0x7f, 0xf8, 0x70, 0x3c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 164 */ + 0x00, 0x00, 0x1f, 0x38, 0x3b, 0xb8, 0x3b, 0xb8, + 0x39, 0xf0, 0x00, 0x00, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x78, 0x1c, + 0x7c, 0x1c, 0x7e, 0x1c, 0x77, 0x1c, 0x73, 0x9c, + 0x71, 0xdc, 0x70, 0xfc, 0x70, 0x7c, 0x70, 0x3c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 165 */ + 0x00, 0x00, 0x00, 0x00, 0x1f, 0xe0, 0x1f, 0xf0, + 0x00, 0x38, 0x00, 0x38, 0x0f, 0xf8, 0x1f, 0xf8, + 0x38, 0x38, 0x38, 0x38, 0x38, 0x38, 0x1f, 0xf8, + 0x0f, 0xf8, 0x00, 0x00, 0x00, 0x00, 0x3f, 0xf8, + 0x3f, 0xf8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 166 */ + 0x00, 0x00, 0x00, 0x00, 0x0f, 0xe0, 0x1f, 0xf0, + 0x38, 0x38, 0x38, 0x38, 0x38, 0x38, 0x38, 0x38, + 0x38, 0x38, 0x38, 0x38, 0x38, 0x38, 0x1f, 0xf0, + 0x0f, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x3f, 0xf8, + 0x3f, 0xf8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 167 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x00, 0x00, 0x00, 0x00, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x07, 0x00, + 0x0e, 0x00, 0x1c, 0x00, 0x38, 0x00, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x78, 0x3c, + 0x3f, 0xf8, 0x1f, 0xf0, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 168 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x7f, 0xfc, 0x7f, 0xfc, 0x70, 0x00, 0x70, 0x00, + 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 169 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x7f, 0xfc, 0x7f, 0xfc, 0x00, 0x1c, 0x00, 0x1c, + 0x00, 0x1c, 0x00, 0x1c, 0x00, 0x1c, 0x00, 0x1c, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 170 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x1c, 0x00, 0x3c, 0x00, + 0x7c, 0x06, 0x1c, 0x0e, 0x1c, 0x1c, 0x1c, 0x38, + 0x1c, 0x70, 0x1c, 0xe0, 0x1d, 0xc0, 0x03, 0x80, + 0x07, 0x00, 0x0e, 0xfc, 0x1d, 0xfe, 0x39, 0xce, + 0x71, 0xce, 0x60, 0x1c, 0x00, 0x38, 0x00, 0x70, + 0x00, 0xfe, 0x01, 0xfe, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 171 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x0e, 0x00, 0x1e, 0x00, + 0x3e, 0x00, 0x0e, 0x00, 0x0e, 0x06, 0x0e, 0x0e, + 0x0e, 0x1c, 0x0e, 0x38, 0x0e, 0x70, 0x00, 0xe0, + 0x01, 0xce, 0x03, 0x9e, 0x07, 0x3e, 0x0e, 0x7e, + 0x1c, 0xee, 0x39, 0xce, 0x73, 0xfe, 0x63, 0xfe, + 0x00, 0x0e, 0x00, 0x0e, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 172 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x00, 0x00, 0x00, 0x00, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 173 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x01, 0xce, 0x03, 0x9c, 0x07, 0x38, 0x0e, 0x70, + 0x1c, 0xe0, 0x39, 0xc0, 0x73, 0x80, 0x73, 0x80, + 0x39, 0xc0, 0x1c, 0xe0, 0x0e, 0x70, 0x07, 0x38, + 0x03, 0x9c, 0x01, 0xce, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 174 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x73, 0x80, 0x39, 0xc0, 0x1c, 0xe0, 0x0e, 0x70, + 0x07, 0x38, 0x03, 0x9c, 0x01, 0xce, 0x01, 0xce, + 0x03, 0x9c, 0x07, 0x38, 0x0e, 0x70, 0x1c, 0xe0, + 0x39, 0xc0, 0x73, 0x80, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 175 */ + 0xaa, 0xaa, 0x00, 0x00, 0xaa, 0xaa, 0x00, 0x00, + 0xaa, 0xaa, 0x00, 0x00, 0xaa, 0xaa, 0x00, 0x00, + 0xaa, 0xaa, 0x00, 0x00, 0xaa, 0xaa, 0x00, 0x00, + 0xaa, 0xaa, 0x00, 0x00, 0xaa, 0xaa, 0x00, 0x00, + 0xaa, 0xaa, 0x00, 0x00, 0xaa, 0xaa, 0x00, 0x00, + 0xaa, 0xaa, 0x00, 0x00, 0xaa, 0xaa, 0x00, 0x00, + 0xaa, 0xaa, 0x00, 0x00, 0xaa, 0xaa, 0x00, 0x00, + 0xaa, 0xaa, 0x00, 0x00, 0xaa, 0xaa, 0x00, 0x00, /* 176 */ + 0xaa, 0xaa, 0x55, 0x55, 0xaa, 0xaa, 0x55, 0x55, + 0xaa, 0xaa, 0x55, 0x55, 0xaa, 0xaa, 0x55, 0x55, + 0xaa, 0xaa, 0x55, 0x55, 0xaa, 0xaa, 0x55, 0x55, + 0xaa, 0xaa, 0x55, 0x55, 0xaa, 0xaa, 0x55, 0x55, + 0xaa, 0xaa, 0x55, 0x55, 0xaa, 0xaa, 0x55, 0x55, + 0xaa, 0xaa, 0x55, 0x55, 0xaa, 0xaa, 0x55, 0x55, + 0xaa, 0xaa, 0x55, 0x55, 0xaa, 0xaa, 0x55, 0x55, + 0xaa, 0xaa, 0x55, 0x55, 0xaa, 0xaa, 0x55, 0x55, /* 177 */ + 0xff, 0xff, 0xaa, 0xaa, 0xff, 0xff, 0xaa, 0xaa, + 0xff, 0xff, 0xaa, 0xaa, 0xff, 0xff, 0xaa, 0xaa, + 0xff, 0xff, 0xaa, 0xaa, 0xff, 0xff, 0xaa, 0xaa, + 0xff, 0xff, 0xaa, 0xaa, 0xff, 0xff, 0xaa, 0xaa, + 0xff, 0xff, 0xaa, 0xaa, 0xff, 0xff, 0xaa, 0xaa, + 0xff, 0xff, 0xaa, 0xaa, 0xff, 0xff, 0xaa, 0xaa, + 0xff, 0xff, 0xaa, 0xaa, 0xff, 0xff, 0xaa, 0xaa, + 0xff, 0xff, 0xaa, 0xaa, 0xff, 0xff, 0xaa, 0xaa, /* 178 */ + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, /* 179 */ + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0xff, 0x80, 0xff, 0x80, + 0xff, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, /* 180 */ + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0xff, 0x80, 0xff, 0x80, 0xff, 0x80, 0x03, 0x80, + 0x03, 0x80, 0xff, 0x80, 0xff, 0x80, 0xff, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, /* 181 */ + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, + 0x0e, 0x70, 0x0e, 0x70, 0xfe, 0x70, 0xfe, 0x70, + 0xfe, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, /* 182 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0xff, 0xf0, 0xff, 0xf0, + 0xff, 0xf0, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, /* 183 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0xff, 0x80, 0xff, 0x80, 0xff, 0x80, 0x03, 0x80, + 0x03, 0x80, 0xff, 0x80, 0xff, 0x80, 0xff, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, /* 184 */ + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, + 0xfe, 0x70, 0xfe, 0x70, 0xfe, 0x70, 0x00, 0x70, + 0x00, 0x70, 0xfe, 0x70, 0xfe, 0x70, 0xfe, 0x70, + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, /* 185 */ + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, /* 186 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0xff, 0xf0, 0xff, 0xf0, 0xff, 0xf0, 0x00, 0x70, + 0x00, 0x70, 0xfe, 0x70, 0xfe, 0x70, 0xfe, 0x70, + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, /* 187 */ + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, + 0xfe, 0x70, 0xfe, 0x70, 0xfe, 0x70, 0x00, 0x70, + 0x00, 0x70, 0xff, 0xf0, 0xff, 0xf0, 0xff, 0xf0, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 188 */ + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, + 0x0e, 0x70, 0x0e, 0x70, 0xff, 0xf0, 0xff, 0xf0, + 0xff, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 189 */ + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0xff, 0x80, 0xff, 0x80, 0xff, 0x80, 0x03, 0x80, + 0x03, 0x80, 0xff, 0x80, 0xff, 0x80, 0xff, 0x80, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 190 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0xff, 0x80, 0xff, 0x80, + 0xff, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, /* 191 */ + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0xff, 0x03, 0xff, + 0x03, 0xff, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 192 */ + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0xff, 0xff, 0xff, 0xff, + 0xff, 0xff, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 193 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0xff, 0xff, 0xff, 0xff, + 0xff, 0xff, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, /* 194 */ + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0xff, 0x03, 0xff, + 0x03, 0xff, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, /* 195 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0xff, 0xff, 0xff, 0xff, + 0xff, 0xff, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 196 */ + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0xff, 0xff, 0xff, 0xff, + 0xff, 0xff, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, /* 197 */ + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0xff, 0x03, 0xff, 0x03, 0xff, 0x03, 0x80, + 0x03, 0x80, 0x03, 0xff, 0x03, 0xff, 0x03, 0xff, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, /* 198 */ + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x7f, 0x0e, 0x7f, + 0x0e, 0x7f, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, /* 199 */ + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, + 0x0e, 0x7f, 0x0e, 0x7f, 0x0e, 0x7f, 0x0e, 0x00, + 0x0e, 0x00, 0x0f, 0xff, 0x0f, 0xff, 0x0f, 0xff, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 200 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x0f, 0xff, 0x0f, 0xff, 0x0f, 0xff, 0x0e, 0x00, + 0x0e, 0x00, 0x0e, 0x7f, 0x0e, 0x7f, 0x0e, 0x7f, + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, /* 201 */ + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, + 0xfe, 0x7f, 0xfe, 0x7f, 0xfe, 0x7f, 0x00, 0x00, + 0x00, 0x00, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 202 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x00, 0x00, + 0x00, 0x00, 0xfe, 0x7f, 0xfe, 0x7f, 0xfe, 0x7f, + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, /* 203 */ + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, + 0x0e, 0x7f, 0x0e, 0x7f, 0x0e, 0x7f, 0x0e, 0x00, + 0x0e, 0x00, 0x0e, 0x7f, 0x0e, 0x7f, 0x0e, 0x7f, + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, /* 204 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x00, 0x00, + 0x00, 0x00, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 205 */ + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, + 0xfe, 0x7f, 0xfe, 0x7f, 0xfe, 0x7f, 0x00, 0x00, + 0x00, 0x00, 0xfe, 0x7f, 0xfe, 0x7f, 0xfe, 0x7f, + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, /* 206 */ + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x00, 0x00, + 0x00, 0x00, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 207 */ + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, + 0x0e, 0x70, 0x0e, 0x70, 0xff, 0xff, 0xff, 0xff, + 0xff, 0xff, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 208 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x00, 0x00, + 0x00, 0x00, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, /* 209 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0xff, 0xff, 0xff, 0xff, + 0xff, 0xff, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, /* 210 */ + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, + 0x0e, 0x70, 0x0e, 0x70, 0x0f, 0xff, 0x0f, 0xff, + 0x0f, 0xff, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 211 */ + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0xff, 0x03, 0xff, 0x03, 0xff, 0x03, 0x80, + 0x03, 0x80, 0x03, 0xff, 0x03, 0xff, 0x03, 0xff, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 212 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x03, 0xff, 0x03, 0xff, 0x03, 0xff, 0x03, 0x80, + 0x03, 0x80, 0x03, 0xff, 0x03, 0xff, 0x03, 0xff, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, /* 213 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x0f, 0xff, 0x0f, 0xff, + 0x0f, 0xff, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, /* 214 */ + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, + 0x0e, 0x70, 0x0e, 0x70, 0xff, 0xff, 0xff, 0xff, + 0xff, 0xff, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, + 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, 0x0e, 0x70, /* 215 */ + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x03, 0x80, + 0x03, 0x80, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, /* 216 */ + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0xff, 0x80, 0xff, 0x80, + 0xff, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 217 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x03, 0xff, 0x03, 0xff, + 0x03, 0xff, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, /* 218 */ + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* 219 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* 220 */ + 0xff, 0x00, 0xff, 0x00, 0xff, 0x00, 0xff, 0x00, + 0xff, 0x00, 0xff, 0x00, 0xff, 0x00, 0xff, 0x00, + 0xff, 0x00, 0xff, 0x00, 0xff, 0x00, 0xff, 0x00, + 0xff, 0x00, 0xff, 0x00, 0xff, 0x00, 0xff, 0x00, + 0xff, 0x00, 0xff, 0x00, 0xff, 0x00, 0xff, 0x00, + 0xff, 0x00, 0xff, 0x00, 0xff, 0x00, 0xff, 0x00, + 0xff, 0x00, 0xff, 0x00, 0xff, 0x00, 0xff, 0x00, + 0xff, 0x00, 0xff, 0x00, 0xff, 0x00, 0xff, 0x00, /* 221 */ + 0x00, 0xff, 0x00, 0xff, 0x00, 0xff, 0x00, 0xff, + 0x00, 0xff, 0x00, 0xff, 0x00, 0xff, 0x00, 0xff, + 0x00, 0xff, 0x00, 0xff, 0x00, 0xff, 0x00, 0xff, + 0x00, 0xff, 0x00, 0xff, 0x00, 0xff, 0x00, 0xff, + 0x00, 0xff, 0x00, 0xff, 0x00, 0xff, 0x00, 0xff, + 0x00, 0xff, 0x00, 0xff, 0x00, 0xff, 0x00, 0xff, + 0x00, 0xff, 0x00, 0xff, 0x00, 0xff, 0x00, 0xff, + 0x00, 0xff, 0x00, 0xff, 0x00, 0xff, 0x00, 0xff, /* 222 */ + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 223 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x1f, 0xee, 0x3f, 0xfe, 0x78, 0x3c, 0x70, 0x38, + 0x70, 0x38, 0x70, 0x38, 0x70, 0x38, 0x70, 0x38, + 0x70, 0x38, 0x70, 0x38, 0x70, 0x38, 0x78, 0x3c, + 0x3f, 0xfe, 0x1f, 0xee, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 224 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x3f, 0xe0, 0x7f, 0xf0, + 0x70, 0x78, 0x70, 0x38, 0x70, 0x38, 0x70, 0x38, + 0x70, 0x38, 0x70, 0x70, 0x7f, 0xf0, 0x7f, 0xf0, + 0x70, 0x38, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x3c, + 0x7f, 0xf8, 0x7f, 0xf0, 0x70, 0x00, 0x70, 0x00, + 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, 0x00, 0x00, /* 225 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x7f, 0xfc, 0x7f, 0xfc, + 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, + 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, + 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, + 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, + 0x70, 0x00, 0x70, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 226 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x7f, 0xfc, 0x7f, 0xfc, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 227 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x7f, 0xfc, 0x7f, 0xfc, + 0x70, 0x00, 0x38, 0x00, 0x1c, 0x00, 0x0e, 0x00, + 0x07, 0x00, 0x03, 0x80, 0x01, 0xc0, 0x00, 0xe0, + 0x00, 0xe0, 0x01, 0xc0, 0x03, 0x80, 0x07, 0x00, + 0x0e, 0x00, 0x1c, 0x00, 0x38, 0x00, 0x70, 0x00, + 0x7f, 0xfc, 0x7f, 0xfc, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 228 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x1f, 0xfe, 0x3f, 0xfe, 0x78, 0xf0, 0x70, 0x78, + 0x70, 0x3c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x78, 0x3c, + 0x3f, 0xf8, 0x1f, 0xf0, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 229 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x3c, 0x70, 0x7c, 0x70, 0xfc, + 0x7f, 0xdc, 0x7f, 0x9c, 0x70, 0x00, 0x70, 0x00, + 0x70, 0x00, 0x70, 0x00, 0x70, 0x00, 0x00, 0x00, /* 230 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x7f, 0xfc, 0x7f, 0xfc, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0xc0, + 0x01, 0xf8, 0x00, 0xf8, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 231 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x03, 0x80, 0x03, 0x80, + 0x1f, 0xf0, 0x3f, 0xf8, 0x7b, 0xbc, 0x73, 0x9c, + 0x73, 0x9c, 0x73, 0x9c, 0x73, 0x9c, 0x73, 0x9c, + 0x73, 0x9c, 0x73, 0x9c, 0x73, 0x9c, 0x73, 0x9c, + 0x73, 0x9c, 0x7b, 0xbc, 0x3f, 0xf8, 0x1f, 0xf0, + 0x03, 0x80, 0x03, 0x80, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 232 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x1f, 0xf0, 0x3f, 0xf8, + 0x78, 0x3c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x77, 0xdc, + 0x77, 0xdc, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x78, 0x3c, + 0x3f, 0xf8, 0x1f, 0xf0, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 233 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x1f, 0xf0, 0x3f, 0xf8, + 0x78, 0x3c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x38, 0x38, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, + 0x7c, 0x7c, 0x7c, 0x7c, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 234 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x1f, 0xf0, 0x1f, 0xf0, + 0x0e, 0x00, 0x07, 0x00, 0x03, 0x80, 0x01, 0xc0, + 0x0f, 0xe0, 0x1f, 0xf0, 0x38, 0x38, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x78, 0x3c, + 0x3f, 0xf8, 0x1f, 0xf0, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 235 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3e, 0xf8, + 0x7f, 0xfc, 0xe7, 0xce, 0xe3, 0x8e, 0xe3, 0x8e, + 0xe3, 0x8e, 0xe3, 0x8e, 0xe7, 0xce, 0x7f, 0xfc, + 0x3e, 0xf8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 236 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x1c, 0x00, 0x1c, + 0x00, 0x38, 0x00, 0x38, 0x0f, 0xf0, 0x1f, 0xf8, + 0x38, 0xfc, 0x38, 0xfc, 0x39, 0xdc, 0x39, 0xdc, + 0x3b, 0x9c, 0x3b, 0x9c, 0x3f, 0x1c, 0x3f, 0x1c, + 0x1f, 0xf8, 0x0f, 0xf0, 0x1c, 0x00, 0x1c, 0x00, + 0x38, 0x00, 0x38, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 237 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x07, 0xfc, 0x1f, 0xfc, 0x3c, 0x00, + 0x38, 0x00, 0x70, 0x00, 0x70, 0x00, 0x7f, 0xfc, + 0x7f, 0xfc, 0x70, 0x00, 0x70, 0x00, 0x38, 0x00, + 0x3c, 0x00, 0x1f, 0xfc, 0x07, 0xfc, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 238 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x07, 0xc0, 0x1f, 0xf0, + 0x3c, 0x78, 0x38, 0x38, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, 0x70, 0x1c, + 0x70, 0x1c, 0x70, 0x1c, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 239 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x7f, 0xfc, 0x7f, 0xfc, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7f, 0xfc, + 0x7f, 0xfc, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x7f, 0xfc, 0x7f, 0xfc, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 240 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x7f, 0xfc, + 0x7f, 0xfc, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x00, 0x00, 0x00, 0x00, + 0x7f, 0xfc, 0x7f, 0xfc, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 241 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x1c, 0x00, 0x0e, 0x00, + 0x07, 0x00, 0x03, 0x80, 0x01, 0xc0, 0x00, 0xe0, + 0x00, 0x70, 0x00, 0x38, 0x00, 0x38, 0x00, 0x70, + 0x00, 0xe0, 0x01, 0xc0, 0x03, 0x80, 0x07, 0x00, + 0x0e, 0x00, 0x1c, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x3f, 0xfc, 0x3f, 0xfc, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 242 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x38, 0x00, 0x70, + 0x00, 0xe0, 0x01, 0xc0, 0x03, 0x80, 0x07, 0x00, + 0x0e, 0x00, 0x1c, 0x00, 0x1c, 0x00, 0x0e, 0x00, + 0x07, 0x00, 0x03, 0x80, 0x01, 0xc0, 0x00, 0xe0, + 0x00, 0x70, 0x00, 0x38, 0x00, 0x00, 0x00, 0x00, + 0x3f, 0xfc, 0x3f, 0xfc, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 243 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x01, 0xf8, 0x03, 0xfc, + 0x03, 0x9c, 0x03, 0x9c, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, /* 244 */ + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x73, 0x80, 0x73, 0x80, + 0x7f, 0x80, 0x3f, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 245 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x00, 0x00, 0x00, 0x00, 0x7f, 0xfc, + 0x7f, 0xfc, 0x00, 0x00, 0x00, 0x00, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x03, 0x80, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 246 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3e, 0x1c, + 0x7f, 0xbc, 0x7b, 0xfc, 0x70, 0xf8, 0x00, 0x00, + 0x00, 0x00, 0x3e, 0x1c, 0x7f, 0xbc, 0x7b, 0xfc, + 0x70, 0xf8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 247 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x0f, 0xe0, 0x1f, 0xf0, 0x1c, 0x70, 0x1c, 0x70, + 0x1c, 0x70, 0x1c, 0x70, 0x1f, 0xf0, 0x0f, 0xe0, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 248 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x03, 0xc0, 0x07, 0xe0, 0x07, 0xe0, + 0x07, 0xe0, 0x07, 0xe0, 0x03, 0xc0, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 249 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x03, 0x80, 0x03, 0x80, + 0x03, 0x80, 0x03, 0x80, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 250 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3e, + 0x00, 0x3e, 0x00, 0x38, 0x00, 0x38, 0x00, 0x38, + 0x00, 0x38, 0x00, 0x38, 0x00, 0x38, 0x00, 0x38, + 0x00, 0x38, 0x00, 0x38, 0x00, 0x38, 0x70, 0x38, + 0x70, 0x38, 0x70, 0x38, 0x78, 0x38, 0x3c, 0x38, + 0x1e, 0x38, 0x0f, 0x38, 0x07, 0xb8, 0x03, 0xf8, + 0x01, 0xf8, 0x00, 0xf8, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 251 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x1f, 0xe0, 0x1f, 0xf0, 0x1c, 0x38, 0x1c, 0x38, + 0x1c, 0x38, 0x1c, 0x38, 0x1c, 0x38, 0x1c, 0x38, + 0x1c, 0x38, 0x1c, 0x38, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 252 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0f, 0xe0, + 0x1f, 0xf0, 0x1c, 0x70, 0x1c, 0x70, 0x00, 0xe0, + 0x01, 0xc0, 0x03, 0x80, 0x07, 0x00, 0x0e, 0x00, + 0x1f, 0xf0, 0x1f, 0xf0, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 253 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x1f, 0xf8, 0x1f, 0xf8, + 0x1f, 0xf8, 0x1f, 0xf8, 0x1f, 0xf8, 0x1f, 0xf8, + 0x1f, 0xf8, 0x1f, 0xf8, 0x1f, 0xf8, 0x1f, 0xf8, + 0x1f, 0xf8, 0x1f, 0xf8, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 254 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* 255 */ +}; + +#endif
Add 12x22 font in order to write a test for it. Run savedefconfig.
Signed-off-by: Dzmitry Sankouski dsankouski@gmail.com --- Changes for v2: N/A Changes for v3: N/A Charges for v4: N/A Charges for v5: N/A Charges for v6: N/A Charges for v7: none
configs/sandbox_defconfig | 5 ++--- 1 file changed, 2 insertions(+), 3 deletions(-)
diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index 34c342b6f5..a0fbdad20a 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -2,6 +2,7 @@ CONFIG_TEXT_BASE=0 CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SIZE=0x2000 CONFIG_DEFAULT_DEVICE_TREE="sandbox" +CONFIG_DM_RESET=y CONFIG_PRE_CON_BUF_ADDR=0xf0000 CONFIG_BOOTSTAGE_STASH_ADDR=0x0 CONFIG_SYS_LOAD_ADDR=0x0 @@ -100,7 +101,6 @@ CONFIG_CMD_ETHSW=y CONFIG_CMD_BMP=y CONFIG_CMD_BOOTCOUNT=y CONFIG_CMD_EFIDEBUG=y -CONFIG_CMD_EFICONFIG=y CONFIG_CMD_RTC=y CONFIG_CMD_TIME=y CONFIG_CMD_PAUSE=y @@ -263,7 +263,6 @@ CONFIG_DM_REBOOT_MODE=y CONFIG_DM_REBOOT_MODE_GPIO=y CONFIG_DM_REBOOT_MODE_RTC=y CONFIG_REMOTEPROC_SANDBOX=y -CONFIG_DM_RESET=y CONFIG_SANDBOX_RESET=y CONFIG_RESET_SYSCON=y CONFIG_RESET_SCMI=y @@ -299,10 +298,10 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_USB_ETHER=y CONFIG_USB_ETH_CDC=y CONFIG_VIDEO=y +CONFIG_VIDEO_FONT_SUN12X22=y CONFIG_VIDEO_COPY=y CONFIG_CONSOLE_ROTATION=y CONFIG_CONSOLE_TRUETYPE=y -CONFIG_CONSOLE_TRUETYPE_MAX_METRICS=10 CONFIG_CONSOLE_TRUETYPE_CANTORAONE=y CONFIG_I2C_EDID=y CONFIG_VIDEO_SANDBOX_SDL=y
Tests fonts wider than a byte.
Signed-off-by: Dzmitry Sankouski dsankouski@gmail.com Reviewed-by: Simon Glass sjg@chromium.org --- Changes for v2: N/A Changes for v2: none Charges for v4: N/A Charges for v5: N/A Charges for v6: - rebase - move sandbox defconfig change to separate patch - run savedefconfig Charges for v7: none
test/dm/video.c | 41 +++++++++++++++++++++++++++++++++++++++++ 1 file changed, 41 insertions(+)
diff --git a/test/dm/video.c b/test/dm/video.c index 17a33cc7af..30778157d9 100644 --- a/test/dm/video.c +++ b/test/dm/video.c @@ -151,6 +151,8 @@ static int dm_test_video_text(struct unit_test_state *uts)
ut_assertok(select_vidconsole(uts, "vidconsole0")); ut_assertok(video_get_nologo(uts, &dev)); + ut_assertok(uclass_get_device(UCLASS_VIDEO_CONSOLE, 0, &con)); + ut_assertok(vidconsole_select_font(con, "8x16", 0)); ut_asserteq(46, compress_frame_buffer(uts, dev));
ut_assertok(uclass_get_device(UCLASS_VIDEO_CONSOLE, 0, &con)); @@ -175,6 +177,42 @@ static int dm_test_video_text(struct unit_test_state *uts) } DM_TEST(dm_test_video_text, UT_TESTF_SCAN_PDATA | UT_TESTF_SCAN_FDT);
+static int dm_test_video_text_12x22(struct unit_test_state *uts) +{ + struct udevice *dev, *con; + int i; + +#define WHITE 0xffff +#define SCROLL_LINES 100 + + ut_assertok(select_vidconsole(uts, "vidconsole0")); + ut_assertok(video_get_nologo(uts, &dev)); + ut_assertok(uclass_get_device(UCLASS_VIDEO_CONSOLE, 0, &con)); + ut_assertok(vidconsole_select_font(con, "12x22", 0)); + ut_asserteq(46, compress_frame_buffer(uts, dev)); + + ut_assertok(uclass_get_device(UCLASS_VIDEO_CONSOLE, 0, &con)); + vidconsole_putc_xy(con, 0, 0, 'a'); + ut_asserteq(89, compress_frame_buffer(uts, dev)); + + vidconsole_putc_xy(con, 0, 0, ' '); + ut_asserteq(46, compress_frame_buffer(uts, dev)); + + for (i = 0; i < 20; i++) + vidconsole_putc_xy(con, VID_TO_POS(i * 8), 0, ' ' + i); + ut_asserteq(363, compress_frame_buffer(uts, dev)); + + vidconsole_set_row(con, 0, WHITE); + ut_asserteq(46, compress_frame_buffer(uts, dev)); + + for (i = 0; i < 20; i++) + vidconsole_putc_xy(con, VID_TO_POS(i * 8), 0, ' ' + i); + ut_asserteq(363, compress_frame_buffer(uts, dev)); + + return 0; +} +DM_TEST(dm_test_video_text_12x22, UT_TESTF_SCAN_PDATA | UT_TESTF_SCAN_FDT); + /* Test handling of special characters in the console */ static int dm_test_video_chars(struct unit_test_state *uts) { @@ -184,6 +222,7 @@ static int dm_test_video_chars(struct unit_test_state *uts) ut_assertok(select_vidconsole(uts, "vidconsole0")); ut_assertok(video_get_nologo(uts, &dev)); ut_assertok(uclass_get_device(UCLASS_VIDEO_CONSOLE, 0, &con)); + ut_assertok(vidconsole_select_font(con, "8x16", 0)); vidconsole_put_string(con, test_string); ut_asserteq(466, compress_frame_buffer(uts, dev));
@@ -201,6 +240,7 @@ static int dm_test_video_ansi(struct unit_test_state *uts) ut_assertok(select_vidconsole(uts, "vidconsole0")); ut_assertok(video_get_nologo(uts, &dev)); ut_assertok(uclass_get_device(UCLASS_VIDEO_CONSOLE, 0, &con)); + ut_assertok(vidconsole_select_font(con, "8x16", 0));
/* reference clear: */ video_clear(con->parent); @@ -249,6 +289,7 @@ static int check_vidconsole_output(struct unit_test_state *uts, int rot,
ut_assertok(video_get_nologo(uts, &dev)); ut_assertok(uclass_get_device(UCLASS_VIDEO_CONSOLE, 0, &con)); + ut_assertok(vidconsole_select_font(con, "8x16", 0)); ut_asserteq(46, compress_frame_buffer(uts, dev));
/* Check display wrap */
Hi Dzmitry,
On Mon, 27 Feb 2023 20:37:10 +0300 Dzmitry Sankouski dsankouski@gmail.com wrote:
- rebase
- run savedefconfig
I've applied this patch series for build testing, this test fails:
https://source.denx.de/u-boot/custodians/u-boot-video/-/jobs/587666
Could you please fix it? Thanks!
-- Anatolij
чт, 2 мар. 2023 г. в 01:20, Anatolij Gustschin agust@denx.de:
Hi Dzmitry,
- rebase
- run savedefconfig
Seems like CONFIG_VIDEO_FONT_SUN12X22 should be enabled somewhere
Anatolij Gustschin
Dzmitry Sankouski
