[U-Boot] [PATCH 1/9] mmc: s5p_sdhci: add the s5p_sdhci_core_init function
To reuse the code, added the s5p_sdhci_core_init function. Before applied this patch, didn't use the 8-Bit mode at exynos board. Because it didn't set "MMC_MODE_8BIT".
Signed-off-by: Jaehoon Chung jh80.chung@samsung.com --- drivers/mmc/s5p_sdhci.c | 43 ++++++++++++++++++------------------------- 1 file changed, 18 insertions(+), 25 deletions(-)
diff --git a/drivers/mmc/s5p_sdhci.c b/drivers/mmc/s5p_sdhci.c index ccae4cc..e8a26d4 100644 --- a/drivers/mmc/s5p_sdhci.c +++ b/drivers/mmc/s5p_sdhci.c @@ -65,17 +65,9 @@ static void s5p_sdhci_set_control_reg(struct sdhci_host *host) sdhci_writel(host, ctrl, SDHCI_CONTROL2); }
-int s5p_sdhci_init(u32 regbase, int index, int bus_width) +static int s5p_sdhci_core_init(struct sdhci_host *host) { - struct sdhci_host *host = NULL; - host = (struct sdhci_host *)malloc(sizeof(struct sdhci_host)); - if (!host) { - printf("sdhci__host malloc fail!\n"); - return 1; - } - host->name = S5P_NAME; - host->ioaddr = (void *)regbase;
host->quirks = SDHCI_QUIRK_NO_HISPD_BIT | SDHCI_QUIRK_BROKEN_VOLTAGE | SDHCI_QUIRK_BROKEN_R1B | SDHCI_QUIRK_32BIT_DMA_ADDR | @@ -85,15 +77,29 @@ int s5p_sdhci_init(u32 regbase, int index, int bus_width)
host->set_control_reg = &s5p_sdhci_set_control_reg; host->set_clock = set_mmc_clk; - host->index = index;
host->host_caps = MMC_MODE_HC; - if (bus_width == 8) + if (host->bus_width == 8) host->host_caps |= MMC_MODE_8BIT;
return add_sdhci(host, 52000000, 400000); }
+int s5p_sdhci_init(u32 regbase, int index, int bus_width) +{ + struct sdhci_host *host = NULL; + host = (struct sdhci_host *)malloc(sizeof(struct sdhci_host)); + if (!host) { + printf("sdhci__host malloc fail!\n"); + return 1; + } + host->ioaddr = (void *)regbase; + host->index = index; + host->bus_width = bus_width; + + return s5p_sdhci_core_init(host); +} + #ifdef CONFIG_OF_CONTROL struct sdhci_host sdhci_host[SDHCI_MAX_HOSTS];
@@ -126,20 +132,7 @@ static int do_sdhci_init(struct sdhci_host *host) } }
- host->name = S5P_NAME; - - host->quirks = SDHCI_QUIRK_NO_HISPD_BIT | SDHCI_QUIRK_BROKEN_VOLTAGE | - SDHCI_QUIRK_BROKEN_R1B | SDHCI_QUIRK_32BIT_DMA_ADDR | - SDHCI_QUIRK_WAIT_SEND_CMD; - host->voltages = MMC_VDD_32_33 | MMC_VDD_33_34 | MMC_VDD_165_195; - host->version = sdhci_readw(host, SDHCI_HOST_VERSION); - - host->set_control_reg = &s5p_sdhci_set_control_reg; - host->set_clock = set_mmc_clk; - - host->host_caps = MMC_MODE_HC; - - return add_sdhci(host, 52000000, 400000); + return s5p_sdhci_core_init(host); }
static int sdhci_get_config(const void *blob, int node, struct sdhci_host *host)
Jaehoon Chung
