[U-Boot] [PATCH 0/2] Add Rock960 board support
This patchset adds board support for Vamrs Limited Rock960, which is one of the 96Boards Consumer Edition platform based on Rockchip RK3399 SoC.
On this board, U-Boot will be loaded by ATF as a BL33 image which in turn loads Linux kernel from eMMC or SD card. Instructions for building and flashing the images are specified in board README.md file.
More information about this board can be found in 96Boards product page: https://www.96boards.org/product/rock960/
The board support includes only the necessary interfaces required to boot Linux kernel.
Thanks, Mani
Manivannan Sadhasivam (2): arm: dts: Add Rock960 devicetree support board: Add Vamrs Limited Rock960 board support
arch/arm/dts/rk3399-rock960.dts | 348 ++++++++++++++++++++ arch/arm/mach-rockchip/rk3399/Kconfig | 16 + board/vamrs/rock960_rk3399/Kconfig | 15 + board/vamrs/rock960_rk3399/MAINTAINERS | 6 + board/vamrs/rock960_rk3399/Makefile | 6 + board/vamrs/rock960_rk3399/README | 79 +++++ board/vamrs/rock960_rk3399/rock960-rk3399.c | 50 +++ configs/rock960-rk3399_defconfig | 62 ++++ include/configs/rock960_rk3399.h | 15 + 9 files changed, 597 insertions(+) create mode 100644 arch/arm/dts/rk3399-rock960.dts create mode 100644 board/vamrs/rock960_rk3399/Kconfig create mode 100644 board/vamrs/rock960_rk3399/MAINTAINERS create mode 100644 board/vamrs/rock960_rk3399/Makefile create mode 100644 board/vamrs/rock960_rk3399/README create mode 100644 board/vamrs/rock960_rk3399/rock960-rk3399.c create mode 100644 configs/rock960-rk3399_defconfig create mode 100644 include/configs/rock960_rk3399.h
Add devicetree support for Vamrs Limited Rock960. This board is one of the 96Boards Consumer Edition platform.
Signed-off-by: Manivannan Sadhasivam manivannan.sadhasivam@linaro.org --- arch/arm/dts/rk3399-rock960.dts | 348 ++++++++++++++++++++++++++++++++ 1 file changed, 348 insertions(+) create mode 100644 arch/arm/dts/rk3399-rock960.dts
diff --git a/arch/arm/dts/rk3399-rock960.dts b/arch/arm/dts/rk3399-rock960.dts new file mode 100644 index 00000000000..8662548e642 --- /dev/null +++ b/arch/arm/dts/rk3399-rock960.dts @@ -0,0 +1,348 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2018 Manivannan Sadhasivam manivannan.sadhasivam@linaro.org + */ + +/dts-v1/; +#include <dt-bindings/pwm/pwm.h> +#include <dt-bindings/pinctrl/rockchip.h> +#include "rk3399.dtsi" +#include "rk3399-sdram-lpddr3-4GB-1600.dtsi" + +/ { + model = "Vamrs Limited Rock960 96Board"; + compatible = "rockchip,rk3399-rock960", "rockchip,rk3399"; + + chosen { + stdout-path = &uart2; + u-boot,spl-boot-order = \ + &sdhci, &sdmmc; + }; + + vccsys: vccsys { + compatible = "regulator-fixed"; + regulator-name = "vccsys"; + regulator-boot-on; + regulator-always-on; + }; + + vcc3v3_sys: vcc3v3-sys { + compatible = "regulator-fixed"; + regulator-name = "vcc3v3_sys"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; + + vcc5v0_sys: vcc5v0-sys { + compatible = "regulator-fixed"; + regulator-name = "vcc5v0_sys"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + }; + + vcc5v0_usb: vcc5v0-usb { + compatible = "regulator-fixed"; + regulator-name = "vcc5v0_usb"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + }; + + vcc5v0_host0: vcc5v0-host0-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc5v0_host0"; + gpio = <&gpio4 25 GPIO_ACTIVE_HIGH>; + }; + + vcc5v0_host1: vcc5v0-host1-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc5v0_host1"; + gpio = <&gpio4 25 GPIO_ACTIVE_HIGH>; + }; + + vcc5v0_host2: vcc5v0-host2-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc5v0_host2"; + gpio = <&gpio4 25 GPIO_ACTIVE_HIGH>; + }; + + vbus_typec: vbus-typec-regulator { + compatible = "regulator-fixed"; + regulator-name = "vbus_typec"; + gpio = <&gpio1 3 GPIO_ACTIVE_HIGH>; + }; + + vdd_log: vdd-log { + compatible = "pwm-regulator"; + pwms = <&pwm2 0 25000 1>; + regulator-name = "vdd_log"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <1400000>; + regulator-init-microvolt = <900000>; + }; +}; + +&emmc_phy { + status = "okay"; +}; + +&pwm0 { + status = "okay"; +}; + +&pwm2 { + status = "okay"; +}; + +&pwm3 { + status = "okay"; +}; + +&saradc { + status = "okay"; +}; + +&sdmmc { + u-boot,dm-pre-reloc; + bus-width = <4>; + status = "okay"; +}; + +&sdhci { + bus-width = <8>; + mmc-hs400-1_8v; + mmc-hs400-enhanced-strobe; + non-removable; + status = "okay"; +}; + +&uart2 { + status = "okay"; +}; + +&i2c0 { + status = "okay"; + clock-frequency = <400000>; + i2c-scl-falling-time-ns = <50>; + i2c-scl-rising-time-ns = <100>; + u-boot,dm-pre-reloc; + + rk808: pmic@1b { + compatible = "rockchip,rk808"; + reg = <0x1b>; + interrupt-parent = <&gpio1>; + interrupts = <21 IRQ_TYPE_LEVEL_LOW>; + #clock-cells = <1>; + clock-output-names = "rtc_clko_soc", "rtc_clko_wifi"; + pinctrl-names = "default"; + pinctrl-0 = <&pmic_int_l>; + rockchip,system-power-controller; + wakeup-source; + + vcc1-supply = <&vcc5v0_sys>; + vcc2-supply = <&vcc5v0_sys>; + vcc3-supply = <&vcc5v0_sys>; + vcc4-supply = <&vcc5v0_sys>; + vcc6-supply = <&vcc5v0_sys>; + vcc7-supply = <&vcc5v0_sys>; + vcc8-supply = <&vcc5v0_sys>; + vcc9-supply = <&vcc5v0_sys>; + vcc10-supply = <&vcc5v0_sys>; + vcc11-supply = <&vcc5v0_sys>; + vcc12-supply = <&vcc3v3_sys>; + vcc13-supply = <&vcc5v0_sys>; + vcc14-supply = <&vcc5v0_sys>; + vddio-supply = <&vcc_1v8>; + + regulators { + vdd_center: DCDC_REG1 { + regulator-name = "vdd_center"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <750000>; + regulator-max-microvolt = <1350000>; + regulator-ramp-delay = <6001>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_cpu_l: DCDC_REG2 { + regulator-name = "vdd_cpu_l"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <750000>; + regulator-max-microvolt = <1350000>; + regulator-ramp-delay = <6001>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_ddr: DCDC_REG3 { + regulator-name = "vcc_ddr"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-state-mem { + regulator-on-in-suspend; + }; + }; + + vcc_1v8: DCDC_REG4 { + regulator-name = "vcc_1v8"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vcc1v8_dvp: LDO_REG1 { + regulator-name = "vcc1v8_dvp"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcca1v8_hdmi: LDO_REG2 { + regulator-name = "vcca1v8_hdmi"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcca_1v8: LDO_REG3 { + regulator-name = "vcca_1v8"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vcc_sdio: LDO_REG4 { + regulator-name = "vcc_sdio"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3000000>; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3000000>; + }; + }; + + vcca1v8_mipi: LDO_REG5 { + regulator-name = "vcca1v8_mipi"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_1v5: LDO_REG6 { + regulator-name = "vcc_1v5"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1500000>; + regulator-max-microvolt = <1500000>; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1500000>; + }; + }; + + vcca0v9_hdmi: LDO_REG7 { + regulator-name = "vcca0v9_hdmi"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <900000>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_3v0: LDO_REG8 { + regulator-name = "vcc_3v0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3000000>; + }; + }; + }; + }; + + vdd_cpu_b: regulator@40 { + compatible = "silergy,syr827"; + reg = <0x40>; + fcs,suspend-voltage-selector = <0>; + regulator-name = "vdd_cpu_b"; + regulator-min-microvolt = <712500>; + regulator-max-microvolt = <1500000>; + regulator-ramp-delay = <1000>; + regulator-always-on; + regulator-boot-on; + vin-supply = <&vcc5v0_sys>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_gpu: regulator@41 { + compatible = "silergy,syr828"; + reg = <0x41>; + fcs,suspend-voltage-selector = <1>; + regulator-name = "vdd_gpu"; + regulator-min-microvolt = <712500>; + regulator-max-microvolt = <1500000>; + regulator-ramp-delay = <1000>; + regulator-always-on; + regulator-boot-on; + vin-supply = <&vcc5v0_sys>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; +}; + +&pinctrl { + pmic { + pmic_int_l: pmic-int-l { + rockchip,pins = + <1 21 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; +};
Add board support for Vamrs Limited Rock960 board, which is one of the 96Boards Consumer Edition platform.
Rock960 features: * CPU: ARMv8 64bit Big-Little architecture, * Big: dual-core Cortex-A72 * Little: quad-core Cortex-A53 * IRAM: 200KB * DRAM: 2GB/4GB LPDDR3 @ 1866MHz * eMMC: 16/32GB eMMC 5.1 * PMU: RK808 * SD/MMC * USB: * 1x USB 3.0 type A, 1x USB 2.0 type A (host mode only) and 1x USB 3.0 type C OTG * Display: * 1x HDMI 2.0(Type A - full) up to 4Kx2K@60Hz, 1x 4L - MIPI DSI up to 1080p@60Hz, 1x DP 1.2(Type C) up to 4Kx2K@60 * Camera: 2x 4-lane MIPI CSI * PCI-E: 4- lane M.2 PCI-E 2.1 * Low Speed Expansion Connector * High Speed Expansion Connector
Signed-off-by: Manivannan Sadhasivam manivannan.sadhasivam@linaro.org --- arch/arm/mach-rockchip/rk3399/Kconfig | 16 +++++ board/vamrs/rock960_rk3399/Kconfig | 15 ++++ board/vamrs/rock960_rk3399/MAINTAINERS | 6 ++ board/vamrs/rock960_rk3399/Makefile | 6 ++ board/vamrs/rock960_rk3399/README | 79 +++++++++++++++++++++ board/vamrs/rock960_rk3399/rock960-rk3399.c | 50 +++++++++++++ configs/rock960-rk3399_defconfig | 62 ++++++++++++++++ include/configs/rock960_rk3399.h | 15 ++++ 8 files changed, 249 insertions(+) create mode 100644 board/vamrs/rock960_rk3399/Kconfig create mode 100644 board/vamrs/rock960_rk3399/MAINTAINERS create mode 100644 board/vamrs/rock960_rk3399/Makefile create mode 100644 board/vamrs/rock960_rk3399/README create mode 100644 board/vamrs/rock960_rk3399/rock960-rk3399.c create mode 100644 configs/rock960-rk3399_defconfig create mode 100644 include/configs/rock960_rk3399.h
diff --git a/arch/arm/mach-rockchip/rk3399/Kconfig b/arch/arm/mach-rockchip/rk3399/Kconfig index 415466a49bb..ce4605187e3 100644 --- a/arch/arm/mach-rockchip/rk3399/Kconfig +++ b/arch/arm/mach-rockchip/rk3399/Kconfig @@ -28,6 +28,21 @@ config TARGET_PUMA_RK3399 * HDMI, eDP, MIPI-DSI, MIPI-DSI/CSI and MIPI-CSI * SPI, I2C, I2S, UART, GPIO, ...
+config TARGET_ROCK960_RK3399 + bool "Vamrs Limited Rock960 board" + help + Support for Rock960 board. This board complies with + 96Board Consumer Edition Specification. + + Features: + * Rockchip RK3399 SoC (2xCortex A72, 4xCortex A53, ARM Mali T860MP4) + * 2GiB/4GiB RAM + * 16/32GB eMMC, uSD slot + * WiFi, Bluetooth + * 1x USB 3.0 type A, 1x USB 2.0 type A (host mode only), 1x USB 3.0 type C OTG + * HDMI + * 20-pin low speed and 40-pin high speed expanders, 6 LED, 3 buttons + endchoice
config SYS_SOC @@ -38,5 +53,6 @@ config SYS_MALLOC_F_LEN
source "board/rockchip/evb_rk3399/Kconfig" source "board/theobroma-systems/puma_rk3399/Kconfig" +source "board/vamrs/rock960_rk3399/Kconfig"
endif diff --git a/board/vamrs/rock960_rk3399/Kconfig b/board/vamrs/rock960_rk3399/Kconfig new file mode 100644 index 00000000000..cacc53f3780 --- /dev/null +++ b/board/vamrs/rock960_rk3399/Kconfig @@ -0,0 +1,15 @@ +if TARGET_ROCK960_RK3399 + +config SYS_BOARD + default "rock960_rk3399" + +config SYS_VENDOR + default "vamrs" + +config SYS_CONFIG_NAME + default "rock960_rk3399" + +config BOARD_SPECIFIC_OPTIONS # dummy + def_bool y + +endif diff --git a/board/vamrs/rock960_rk3399/MAINTAINERS b/board/vamrs/rock960_rk3399/MAINTAINERS new file mode 100644 index 00000000000..9f3fe75f4fb --- /dev/null +++ b/board/vamrs/rock960_rk3399/MAINTAINERS @@ -0,0 +1,6 @@ +ROCK960-RK3399 +M: Manivannan Sadhasivam manivannan.sadhasivam@linaro.org +S: Maintained +F: board/rockchip/rock960_rk3399 +F: include/configs/rock960_rk3399.h +F: configs/rock960-rk3399_defconfig diff --git a/board/vamrs/rock960_rk3399/Makefile b/board/vamrs/rock960_rk3399/Makefile new file mode 100644 index 00000000000..6c3e475b3a8 --- /dev/null +++ b/board/vamrs/rock960_rk3399/Makefile @@ -0,0 +1,6 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (C) 2018 Manivannan Sadhasivam manivannan.sadhasivam@linaro.org +# + +obj-y += rock960-rk3399.o diff --git a/board/vamrs/rock960_rk3399/README b/board/vamrs/rock960_rk3399/README new file mode 100644 index 00000000000..be6b5cd1d34 --- /dev/null +++ b/board/vamrs/rock960_rk3399/README @@ -0,0 +1,79 @@ +Introduction +============ + +Rock960 is a 96Boards Consumer Edition platform featuring the Rockchip +RK3399 SoC. + +Rock960 features: + * CPU: ARMv8 64bit Big-Little architecture, + * Big: dual-core Cortex-A72 + * Little: quad-core Cortex-A53 + * IRAM: 200KB + * DRAM: 2GB/4GB LPDDR3 @ 1866MHz + * eMMC: 16/32GB eMMC 5.1 + * PMU: RK808 + * SD/MMC + * USB: + * 1x USB 3.0 type A, 1x USB 2.0 type A (host mode only) and + 1x USB 3.0 type C OTG + * Display: + * 1x HDMI 2.0(Type A - full) up to 4Kx2K@60Hz, + 1x 4L - MIPI DSI up to 1080p@60Hz, + 1x DP 1.2(Type C) up to 4Kx2K@60 + * Camera: 2x 4-lane MIPI CSI + * PCI-E: 4- lane M.2 PCI-E 2.1 + * Low Speed Expansion Connector + * High Speed Expansion Connector + +Here is the step-by-step to boot to U-Boot on rk3399. + +Get the Source and prebuild binary +================================== + + > git clone https://github.com/96rocks/rkbin.git + > git clone https://github.com/rockchip-linux/rkdeveloptool.git + +Compile the U-Boot +================== + + > cd ../u-boot + > export ARCH=arm64 + > export CROSS_COMPILE=aarch64-linux-gnu- + > make rock960-rk3399_defconfig + > make + +Compile the rkdeveloptool +========================= + Follow instructions in latest README + > cd ../rkdeveloptool + > autoreconf -i + > ./configure + > make + > sudo make install + +Package the image +================= + +Package the image for Rockchip miniloader +------------------------------------------ + > cd ../rkbin + > ./tools/loaderimage --pack --uboot u-boot/u-boot-dtb.bin uboot.img 0x200000 + + > ../u-boot/tools/mkimage -n rk3399 -T rksd -d rk3399_ddr_933MHz_v1.08.bin idbloader.img + > cat ./rk33/rk3399_miniloader_v1.06.bin >> idbloader.img + + Get uboot.img and idbloader.img in this step. + +Flash the image to eMMC +======================= + +Flash the image with Rockchip miniloader +---------------------------------------- +Power on(or reset with RESET KEY) with MASKROM KEY preesed, and then: + > rkdeveloptool db ./rk33/rk3399_loader_v1.08.106.bin + > rkdeveloptool wl 0x40 idbloader.img + > rkdeveloptool wl 0x4000 uboot.img + > rkdeveloptool wl 0x6000 ./img/rk3399/trust.img + > rkdeveloptool rd + +You should be able to get U-Boot log in console/UART2(baurdrate 1500000) diff --git a/board/vamrs/rock960_rk3399/rock960-rk3399.c b/board/vamrs/rock960_rk3399/rock960-rk3399.c new file mode 100644 index 00000000000..d3775b22191 --- /dev/null +++ b/board/vamrs/rock960_rk3399/rock960-rk3399.c @@ -0,0 +1,50 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2018 Manivannan Sadhasivam manivannan.sadhasivam@linaro.org + */ + +#include <common.h> +#include <dm.h> +#include <dm/pinctrl.h> +#include <dm/uclass-internal.h> +#include <asm/arch/periph.h> +#include <power/regulator.h> +#include <spl.h> + +int board_init(void) +{ + int ret; + + ret = regulators_enable_boot_on(false); + if (ret) + debug("%s: Cannot enable boot on regulator\n", __func__); + + return 0; +} + +void spl_board_init(void) +{ + struct udevice *pinctrl; + int ret; + + ret = uclass_get_device(UCLASS_PINCTRL, 0, &pinctrl); + if (ret) { + debug("%s: Cannot find pinctrl device\n", __func__); + goto err; + } + + /* Enable debug UART */ + ret = pinctrl_request_noflags(pinctrl, PERIPH_ID_UART_DBG); + if (ret) { + debug("%s: Failed to set up console UART\n", __func__); + goto err; + } + + preloader_console_init(); + return; +err: + printf("%s: Error %d\n", __func__, ret); + + /* No way to report error here */ + hang(); +} diff --git a/configs/rock960-rk3399_defconfig b/configs/rock960-rk3399_defconfig new file mode 100644 index 00000000000..998c7a4b707 --- /dev/null +++ b/configs/rock960-rk3399_defconfig @@ -0,0 +1,62 @@ +CONFIG_ARM=y +CONFIG_ARCH_ROCKCHIP=y +CONFIG_SYS_TEXT_BASE=0x00200000 +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SYS_MALLOC_F_LEN=0x4000 +CONFIG_ROCKCHIP_RK3399=y +CONFIG_ROCKCHIP_SPL_RESERVE_IRAM=0x4000 +CONFIG_TARGET_ROCK960_RK3399=y +CONFIG_DEBUG_UART_BASE=0xFF1A0000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_BAUDRATE=1500000 +CONFIG_SPL_STACK_R_ADDR=0x80000 +CONFIG_DEFAULT_DEVICE_TREE="rk3399-rock960" +CONFIG_DEBUG_UART=y +CONFIG_FIT=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-rockchip/make_fit_atf.py" +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-rock960.dtb" +CONFIG_SYS_PROMPT="rock960 => " +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_STACK_R=y +CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x4000 +CONFIG_SPL_ATF=y +CONFIG_SPL_ATF_NO_PLATFORM_PARAM=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_GPT=y +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_TIME=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_SPL_OF_PLATDATA=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_REGMAP=y +CONFIG_SPL_REGMAP=y +CONFIG_SYSCON=y +CONFIG_SPL_SYSCON=y +CONFIG_CLK=y +CONFIG_SPL_CLK=y +CONFIG_ROCKCHIP_GPIO=y +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MMC_DW=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_ROCKCHIP=y +CONFIG_PINCTRL=y +CONFIG_SPL_PINCTRL=y +CONFIG_PINCTRL_ROCKCHIP_RK3399=y +CONFIG_DM_PMIC=y +CONFIG_PMIC_RK8XX=y +CONFIG_REGULATOR_PWM=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_REGULATOR_RK8XX=y +CONFIG_PWM_ROCKCHIP=y +CONFIG_RAM=y +CONFIG_SPL_RAM=y +CONFIG_SYSRESET=y +CONFIG_USE_TINY_PRINTF=y +CONFIG_ERRNO_STR=y diff --git a/include/configs/rock960_rk3399.h b/include/configs/rock960_rk3399.h new file mode 100644 index 00000000000..746d24cbff5 --- /dev/null +++ b/include/configs/rock960_rk3399.h @@ -0,0 +1,15 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2018 Manivannan Sadhasivam manivannan.sadhasivam@linaro.org + */ + +#ifndef __ROCK960_RK3399_H +#define __ROCK960_RK3399_H + +#include <configs/rk3399_common.h> + +#define CONFIG_SYS_MMC_ENV_DEV 1 + +#define SDRAM_BANK_SIZE (2UL << 30) + +#endif
On 21 August 2018 at 14:09, Manivannan Sadhasivam manivannan.sadhasivam@linaro.org wrote:
help
Features:
* 2GiB/4GiB RAM
* WiFi, Bluetooth
* HDMI
endchoice
+config SYS_BOARD
+config SYS_VENDOR
default "vamrs"
def_bool y
+Rock960 features:
* IRAM: 200KB
* PMU: RK808
* SD/MMC
* USB:
* Display:
git clone https://github.com/96rocks/rkbin.git git clone https://github.com/rockchip-linux/rkdeveloptool.git+Compile the U-Boot +==================
cd ../u-boot export ARCH=arm64 export CROSS_COMPILE=aarch64-linux-gnu- make rock960-rk3399_defconfig make+Compile the rkdeveloptool +=========================
- Follow instructions in latest README
cd ../rkdeveloptool autoreconf -i ./configure make sudo make install+Package the image +=================
Is there any reason to use the miniloader instead of SPL?
Regards, Ezequiel
Hi Ezequiel,
help
Features:
* 2GiB/4GiB RAM
* WiFi, Bluetooth
* HDMI
endchoice
+config SYS_BOARD
+config SYS_VENDOR
default "vamrs"
def_bool y
+Rock960 features:
* IRAM: 200KB
* PMU: RK808
* SD/MMC
* USB:
* Display:
I had some issues flashing the image using SPL initially. So decided to use miniloader till I'm able to find time for it.
Thanks, Mani
Regards, Ezequiel
-- Ezequiel García, VanguardiaSur www.vanguardiasur.com.ar
Hi Manivannan,
What are the differences between this consumer edition board, and the enterprise edition (aka Ficus) Vamrs board?
Perhaps the devicetree and the board support can be shared with ficus support?
I submitted v2 moments ago:
https://patchwork.ozlabs.org/patch/963241/ https://patchwork.ozlabs.org/patch/963242/
Regards, Ezequiel
Hi Ezequiel,
On Wed, Aug 29, 2018 at 03:11:17AM -0300, Ezequiel Garcia wrote:
Hi Manivannan,
I asked Vamrs about this and they said the difference is very minimal.
I'm fine with it but you seem to have added Ficus board under evb_rk3399 which I think not the good place. Since the board manufacturer is different, I would suggest you to place it under boards/vamrs as I have done here. Also with more boards coming from Vamrs, this makes much more sense.
Please let me know your thoughts!
Thanks, Mani
Regards, Ezequiel
On 30 August 2018 at 00:00, Manivannan Sadhasivam manivannan.sadhasivam@linaro.org wrote:
Hi Ezequiel,
Hi Manivannan,
In that case, you should try to leverage the Linux ficus.dts:
https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/tree/arch...
If no differences, using the ficus dts should do. If there are differences, we can create a common rock960.dtsi and then enterprise and consumer edition dts.
Well, I've reused the evb support, because there was no reason to have board-specific code. If we have now a reason, then of course having a board dir makes sense.
When possible, we should try to avoid code duplication and scattering. For instance, the instructions in the README look RK3399 generic and not board specific. We should consolidate that.
Hi Ezequiel,
Hi Manivannan,
Okay. Here are the differences between Ficus and Rock960 CE:
1. Different host enable GPIO for USB (vcc5v0_host) 2. Different power and reset for PCI-E (vcc3v3_pcie, pcie0) 3. No Ethernet port on Rock960 (gmac)
So, I would suggest keeping USB, PCI-E and GMAC related nodes on the board specific devicetree and rest on the rk3399-rock960.dtsi. What do you think?
Same applies to Linux also!
Thanks, Mani
When possible, we should try to avoid code duplication and scattering. For instance, the instructions in the README look RK3399 generic and not board specific. We should consolidate that. -- Ezequiel García, VanguardiaSur www.vanguardiasur.com.ar
Hi Ezequiel,
Hi Manivannan,
- Different host enable GPIO for USB (vcc5v0_host)
- Different power and reset for PCI-E (vcc3v3_pcie, pcie0)
- No Ethernet port on Rock960 (gmac)
Yes, I think a rk3399-rock960.dtsi with the differences in two .dts would be great, and even better a single U-Boot which can detect the board and load the right DT, but I do think it should be a separate config to evb as Mani mentioned.
Peter
Hi Ezequiel,
Hi Manivannan,
Sounds good. If you have some cycles to work on the dts/dtsi split, that would be great.
Sounds good too. That'd make board-specific hooks easier.
On the other side, the documentation should be merged somewhere.
Seems nonsense to have a README per board, with more or less the same instructions each time.
Thanks!
Hi Ezequiel,
Hi Manivannan,
On 21 August 2018 at 14:09, Manivannan Sadhasivam manivannan.sadhasivam@linaro.org wrote: > This patchset adds board support for Vamrs Limited Rock960, > which is one of the 96Boards Consumer Edition platform based > on Rockchip RK3399 SoC. >
Sure, will do it for Linux now. Once your u-boot patches gets in, will tackle it also.
Thanks Peter for your thoughts!
This has other side as well. If we continue to merge board specific instructions onto evb-rk3399, it will become messy. So, IMO it's better to have it separate. If you have other ideas, please let me know.
Thanks, Mani
Thanks!
On 31 August 2018 at 09:24, Manivannan Sadhasivam manivannan.sadhasivam@linaro.org wrote:
Hi Ezequiel,
On Wed, Aug 29, 2018 at 03:11:17AM -0300, Ezequiel Garcia wrote: > Hi Manivannan, > > On 21 August 2018 at 14:09, Manivannan Sadhasivam > manivannan.sadhasivam@linaro.org wrote: > > This patchset adds board support for Vamrs Limited Rock960, > > which is one of the 96Boards Consumer Edition platform based > > on Rockchip RK3399 SoC. > > > > What are the differences between this consumer edition board, > and the enterprise edition (aka Ficus) Vamrs board? >
Well, I think we can tackle u-boot from scratch. No need to merge my patches if we think they are already wrong :-)
Bootloader wise, there is no such thing as board specific instructions, is it?
On 30 August 2018 at 00:00, Manivannan Sadhasivam manivannan.sadhasivam@linaro.org wrote: > Hi Ezequiel, > > On Wed, Aug 29, 2018 at 03:11:17AM -0300, Ezequiel Garcia wrote: >> Hi Manivannan, >> >> On 21 August 2018 at 14:09, Manivannan Sadhasivam >> manivannan.sadhasivam@linaro.org wrote: >> > This patchset adds board support for Vamrs Limited Rock960, >> > which is one of the 96Boards Consumer Edition platform based >> > on Rockchip RK3399 SoC. >> > >> >> What are the differences between this consumer edition board, >> and the enterprise edition (aka Ficus) Vamrs board? >> > > I asked Vamrs about this and they said the difference is very minimal. >
Makes sense!
Yeah, but I'm thinking about the overhead of having a common doc for boards which might come in future (like Rock960c have an optional eMMC module).
Even in Rock960 CE, we need to specify the load address for u-boot while preparing the uboot.img (not sure why it is required)...
I'm kind of skeptical here.
Peter, any thoughts?
Ezequiel Garcia
Peter Robinson
