[PATCH v3] board: phytec: phycore-imx93: Add phyBOARD-Segin-i.MX93 support
Add initial support for the PHYTEC phyBOARD-Segin-i.MX93 board based on the PHYTEC phyCORE-i.MX93 SoM.
Supported features: - 1GB LPDDR4 RAM - eMMC - external SD - debug UART - watchdog
Signed-off-by: Mathieu Othacehe othacehe@gnu.org --- Hello,
This new revision fixes the remarks of Primoz. It uses configuration and an environment files closer to what's inside the downstream project.
Thanks,
Mathieu
v2: https://lists.denx.de/pipermail/u-boot/2024-January/544396.html
arch/arm/dts/Makefile | 3 +- arch/arm/dts/imx93-phyboard-segin-u-boot.dtsi | 293 ++++ arch/arm/dts/imx93-phyboard-segin.dts | 117 ++ arch/arm/dts/imx93-phycore-som.dtsi | 126 ++ arch/arm/mach-imx/imx9/Kconfig | 6 + board/phytec/phycore_imx93/Kconfig | 13 + board/phytec/phycore_imx93/MAINTAINERS | 10 + board/phytec/phycore_imx93/Makefile | 14 + board/phytec/phycore_imx93/lpddr4_timing.c | 1546 +++++++++++++++++ board/phytec/phycore_imx93/phycore-imx93.c | 42 + board/phytec/phycore_imx93/phycore_imx93.env | 85 + board/phytec/phycore_imx93/spl.c | 150 ++ configs/imx93-phyboard-segin_defconfig | 149 ++ doc/board/phytec/imx93-phyboard-segin.rst | 61 + doc/board/phytec/index.rst | 1 + include/configs/phycore_imx93.h | 28 + 16 files changed, 2643 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/imx93-phyboard-segin-u-boot.dtsi create mode 100644 arch/arm/dts/imx93-phyboard-segin.dts create mode 100644 arch/arm/dts/imx93-phycore-som.dtsi create mode 100644 board/phytec/phycore_imx93/Kconfig create mode 100644 board/phytec/phycore_imx93/MAINTAINERS create mode 100644 board/phytec/phycore_imx93/Makefile create mode 100644 board/phytec/phycore_imx93/lpddr4_timing.c create mode 100644 board/phytec/phycore_imx93/phycore-imx93.c create mode 100644 board/phytec/phycore_imx93/phycore_imx93.env create mode 100644 board/phytec/phycore_imx93/spl.c create mode 100644 configs/imx93-phyboard-segin_defconfig create mode 100644 doc/board/phytec/imx93-phyboard-segin.rst create mode 100644 include/configs/phycore_imx93.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index d456a524b36..e7687a1b57d 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -1127,7 +1127,8 @@ dtb-$(CONFIG_ARCH_IMX8M) += \
dtb-$(CONFIG_ARCH_IMX9) += \ imx93-11x11-evk.dtb \ - imx93-var-som-symphony.dtb + imx93-var-som-symphony.dtb \ + imx93-phyboard-segin.dtb
dtb-$(CONFIG_ARCH_IMXRT) += imxrt1050-evk.dtb \ imxrt1020-evk.dtb \ diff --git a/arch/arm/dts/imx93-phyboard-segin-u-boot.dtsi b/arch/arm/dts/imx93-phyboard-segin-u-boot.dtsi new file mode 100644 index 00000000000..c194b009274 --- /dev/null +++ b/arch/arm/dts/imx93-phyboard-segin-u-boot.dtsi @@ -0,0 +1,293 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (C) 2023 PHYTEC Messtechnik GmbH + * Christoph Stoidner c.stoidner@phytec.de + * + * Product homepage: + * phyBOARD-Segin carrier board is reused for the i.MX93 design. + * https://www.phytec.eu/en/produkte/single-board-computer/phyboard-segin-imx6u... + */ + +#include "imx93-u-boot.dtsi" + +/ { + wdt-reboot { + compatible = "wdt-reboot"; + wdt = <&wdog3>; + bootph-pre-ram; + bootph-some-ram; + }; + + aliases { + ethernet0 = &eqos; + ethernet1 = &fec; + }; + + firmware { + optee { + compatible = "linaro,optee-tz"; + method = "smc"; + }; + }; +}; + +&{/soc@0} { + bootph-all; + bootph-pre-ram; +}; + +&aips1 { + bootph-pre-ram; + bootph-all; +}; + +&aips2 { + bootph-pre-ram; + bootph-some-ram; +}; + +&aips3 { + bootph-pre-ram; + bootph-some-ram; +}; + +&iomuxc { + bootph-pre-ram; + bootph-some-ram; +}; + +®_usdhc2_vmmc { + u-boot,off-on-delay-us = <20000>; + bootph-pre-ram; + bootph-some-ram; +}; + +&pinctrl_reg_usdhc2_vmmc { + bootph-pre-ram; +}; + +&pinctrl_uart1 { + bootph-pre-ram; + bootph-some-ram; +}; + +&pinctrl_usdhc1 { + bootph-pre-ram; + bootph-some-ram; +}; + +&pinctrl_usdhc2_cd { + bootph-pre-ram; + bootph-some-ram; +}; + +&pinctrl_usdhc2_default { + bootph-pre-ram; + bootph-some-ram; +}; + +&pinctrl_usdhc2_100mhz { + bootph-pre-ram; + bootph-some-ram; +}; + +&pinctrl_usdhc2_200mhz { + bootph-pre-ram; + bootph-some-ram; +}; + +&gpio1 { + bootph-pre-ram; + bootph-some-ram; +}; + +&gpio2 { + bootph-pre-ram; + bootph-some-ram; +}; + +&gpio3 { + bootph-pre-ram; + bootph-some-ram; +}; + +&gpio4 { + bootph-pre-ram; + bootph-some-ram; +}; + +&lpuart1 { + bootph-pre-ram; + bootph-some-ram; +}; + +&usdhc1 { + bootph-pre-ram; + bootph-some-ram; +}; + +&usdhc2 { + bootph-pre-ram; + bootph-some-ram; + fsl,signal-voltage-switch-extra-delay-ms = <8>; +}; + +&lpi2c1 { + bootph-pre-ram; + bootph-some-ram; +}; + +&lpi2c2 { + bootph-pre-ram; + bootph-some-ram; +}; + +&lpi2c3 { + bootph-pre-ram; + bootph-some-ram; +}; + +&s4muap { + bootph-pre-ram; + bootph-some-ram; + status = "okay"; +}; + +&clk { + bootph-all; + bootph-pre-ram; + /delete-property/ assigned-clocks; + /delete-property/ assigned-clock-rates; + /delete-property/ assigned-clock-parents; +}; + +&osc_32k { + bootph-all; + bootph-pre-ram; +}; + +&osc_24m { + bootph-all; + bootph-pre-ram; +}; + +&clk_ext1 { + bootph-all; + bootph-pre-ram; +}; + +&wdog3 { + bootph-all; + bootph-pre-ram; +}; + +/* + * The two nodes below won't be needed once nxp,pca9451a + * support is added to the Linux kernel. + */ +&iomuxc { + pinctrl_lpi2c3: lpi2c3grp { + bootph-pre-ram; + fsl,pins = < + MX93_PAD_GPIO_IO28__LPI2C3_SDA 0x40000b9e + MX93_PAD_GPIO_IO29__LPI2C3_SCL 0x40000b9e + >; + }; + + pinctrl_pmic: pmicgrp { + bootph-pre-ram; + fsl,pins = < + MX93_PAD_ENET2_RD3__GPIO4_IO27 0x31e + >; + }; +}; + +&lpi2c3 { + bootph-pre-ram; + bootph-some-ram; + clock-frequency = <400000>; + pinctrl-names = "default", "sleep"; + pinctrl-0 = <&pinctrl_lpi2c3>; + pinctrl-1 = <&pinctrl_lpi2c3>; + status = "okay"; + + pmic@25 { + bootph-pre-ram; + bootph-some-ram; + compatible = "nxp,pca9451a"; + reg = <0x25>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_pmic>; + interrupt-parent = <&gpio4>; + interrupts = <27 IRQ_TYPE_LEVEL_LOW>; + + regulators { + bootph-pre-ram; + bootph-some-ram; + buck1: BUCK1 { + regulator-name = "VDD_SOC"; + regulator-min-microvolt = <610000>; + regulator-max-microvolt = <950000>; + regulator-boot-on; + regulator-always-on; + regulator-ramp-delay = <3125>; + }; + + buck2: BUCK2 { + regulator-name = "VDDQ_0V6"; + regulator-min-microvolt = <600000>; + regulator-max-microvolt = <600000>; + regulator-boot-on; + regulator-always-on; + }; + + buck4: BUCK4 { + regulator-name = "VDD_3V3_BUCK"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + }; + + buck5: BUCK5 { + regulator-name = "VDD_1V8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-boot-on; + regulator-always-on; + }; + + buck6: BUCK6 { + regulator-name = "VDD_1V1"; + regulator-min-microvolt = <1100000>; + regulator-max-microvolt = <1100000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo1: LDO1 { + regulator-name = "PMIC_SNVS_1V8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo4: LDO4 { + regulator-name = "VDD_0V8"; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <800000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo5: LDO5 { + regulator-name = "NVCC_SD2"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + }; + }; + }; +}; diff --git a/arch/arm/dts/imx93-phyboard-segin.dts b/arch/arm/dts/imx93-phyboard-segin.dts new file mode 100644 index 00000000000..85fb188b057 --- /dev/null +++ b/arch/arm/dts/imx93-phyboard-segin.dts @@ -0,0 +1,117 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (C) 2023 PHYTEC Messtechnik GmbH + * Author: Wadim Egorov w.egorov@phytec.de, Christoph Stoidner c.stoidner@phytec.de + * Copyright (C) 2024 Mathieu Othacehe m.othacehe@gmail.com + * + * Product homepage: + * phyBOARD-Segin carrier board is reused for the i.MX93 design. + * https://www.phytec.eu/en/produkte/single-board-computer/phyboard-segin-imx6u... + */ +/dts-v1/; + +#include "imx93-phycore-som.dtsi" + +/{ + model = "PHYTEC phyBOARD-Segin-i.MX93"; + compatible = "phytec,imx93-phyboard-segin", "phytec,imx93-phycore-som", + "fsl,imx93"; + + chosen { + stdout-path = &lpuart1; + }; + + reg_usdhc2_vmmc: regulator-usdhc2 { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio3 7 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_reg_usdhc2_vmmc>; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "VCC_SD"; + }; +}; + +/* Console */ +&lpuart1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart1>; + status = "okay"; +}; + +/* eMMC */ +&usdhc1 { + no-1-8-v; +}; + +/* SD-Card */ +&usdhc2 { + pinctrl-names = "default", "state_100mhz", "state_200mhz"; + pinctrl-0 = <&pinctrl_usdhc2_default>, <&pinctrl_usdhc2_cd>; + pinctrl-1 = <&pinctrl_usdhc2_100mhz>, <&pinctrl_usdhc2_cd>; + pinctrl-2 = <&pinctrl_usdhc2_200mhz>, <&pinctrl_usdhc2_cd>; + bus-width = <4>; + cd-gpios = <&gpio3 0 GPIO_ACTIVE_LOW>; + no-mmc; + no-sdio; + vmmc-supply = <®_usdhc2_vmmc>; + status = "okay"; +}; + +&iomuxc { + pinctrl_uart1: uart1grp { + fsl,pins = < + MX93_PAD_UART1_RXD__LPUART1_RX 0x31e + MX93_PAD_UART1_TXD__LPUART1_TX 0x30e + >; + }; + + pinctrl_reg_usdhc2_vmmc: regusdhc2vmmcgrp { + fsl,pins = < + MX93_PAD_SD2_RESET_B__GPIO3_IO07 0x31e + >; + }; + + pinctrl_usdhc2_cd: usdhc2cdgrp { + fsl,pins = < + MX93_PAD_SD2_CD_B__GPIO3_IO00 0x31e + >; + }; + + pinctrl_usdhc2_default: usdhc2grp { + fsl,pins = < + MX93_PAD_SD2_CLK__USDHC2_CLK 0x179e + MX93_PAD_SD2_CMD__USDHC2_CMD 0x139e + MX93_PAD_SD2_DATA0__USDHC2_DATA0 0x138e + MX93_PAD_SD2_DATA1__USDHC2_DATA1 0x138e + MX93_PAD_SD2_DATA2__USDHC2_DATA2 0x138e + MX93_PAD_SD2_DATA3__USDHC2_DATA3 0x139e + MX93_PAD_SD2_VSELECT__USDHC2_VSELECT 0x51e + >; + }; + + pinctrl_usdhc2_100mhz: usdhc2grp { + fsl,pins = < + MX93_PAD_SD2_CLK__USDHC2_CLK 0x179e + MX93_PAD_SD2_CMD__USDHC2_CMD 0x139e + MX93_PAD_SD2_DATA0__USDHC2_DATA0 0x138e + MX93_PAD_SD2_DATA1__USDHC2_DATA1 0x138e + MX93_PAD_SD2_DATA2__USDHC2_DATA2 0x139e + MX93_PAD_SD2_DATA3__USDHC2_DATA3 0x139e + MX93_PAD_SD2_VSELECT__USDHC2_VSELECT 0x51e + >; + }; + + pinctrl_usdhc2_200mhz: usdhc2grp { + fsl,pins = < + MX93_PAD_SD2_CLK__USDHC2_CLK 0x178e + MX93_PAD_SD2_CMD__USDHC2_CMD 0x139e + MX93_PAD_SD2_DATA0__USDHC2_DATA0 0x139e + MX93_PAD_SD2_DATA1__USDHC2_DATA1 0x139e + MX93_PAD_SD2_DATA2__USDHC2_DATA2 0x139e + MX93_PAD_SD2_DATA3__USDHC2_DATA3 0x139e + MX93_PAD_SD2_VSELECT__USDHC2_VSELECT 0x51e + >; + }; +}; diff --git a/arch/arm/dts/imx93-phycore-som.dtsi b/arch/arm/dts/imx93-phycore-som.dtsi new file mode 100644 index 00000000000..88c2657b50e --- /dev/null +++ b/arch/arm/dts/imx93-phycore-som.dtsi @@ -0,0 +1,126 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (C) 2023 PHYTEC Messtechnik GmbH + * Author: Wadim Egorov w.egorov@phytec.de, Christoph Stoidner c.stoidner@phytec.de + * Copyright (C) 2024 Mathieu Othacehe m.othacehe@gmail.com + * + * Product homepage: + * https://www.phytec.eu/en/produkte/system-on-modules/phycore-imx-91-93/ + */ + +#include <dt-bindings/leds/common.h> + +#include "imx93.dtsi" + +/{ + model = "PHYTEC phyCORE-i.MX93"; + compatible = "phytec,imx93-phycore-som", "fsl,imx93"; + + reserved-memory { + ranges; + #address-cells = <2>; + #size-cells = <2>; + + linux,cma { + compatible = "shared-dma-pool"; + reusable; + alloc-ranges = <0 0x80000000 0 0x40000000>; + size = <0 0x10000000>; + linux,cma-default; + }; + }; + + leds { + compatible = "gpio-leds"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_leds>; + + led-0 { + color = <LED_COLOR_ID_GREEN>; + function = LED_FUNCTION_HEARTBEAT; + gpios = <&gpio1 1 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "heartbeat"; + }; + }; +}; + +/* Ethernet */ +&fec { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_fec>; + phy-mode = "rmii"; + phy-handle = <ðphy1>; + fsl,magic-packet; + assigned-clocks = <&clk IMX93_CLK_ENET_TIMER1>, + <&clk IMX93_CLK_ENET_REF>, + <&clk IMX93_CLK_ENET_REF_PHY>; + assigned-clock-parents = <&clk IMX93_CLK_SYS_PLL_PFD1_DIV2>, + <&clk IMX93_CLK_SYS_PLL_PFD1_DIV2>, + <&clk IMX93_CLK_SYS_PLL_PFD1_DIV2>; + assigned-clock-rates = <100000000>, <50000000>, <50000000>; + status = "okay"; + + mdio: mdio { + clock-frequency = <5000000>; + #address-cells = <1>; + #size-cells = <0>; + + ethphy1: ethernet-phy@1 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <1>; + }; + }; +}; + +/* eMMC */ +&usdhc1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usdhc1>; + bus-width = <8>; + non-removable; + status = "okay"; +}; + +/* Watchdog */ +&wdog3 { + status = "okay"; +}; + +&iomuxc { + pinctrl_fec: fecgrp { + fsl,pins = < + MX93_PAD_ENET2_MDC__ENET1_MDC 0x50e + MX93_PAD_ENET2_MDIO__ENET1_MDIO 0x502 + MX93_PAD_ENET2_RD0__ENET1_RGMII_RD0 0x57e + MX93_PAD_ENET2_RD1__ENET1_RGMII_RD1 0x57e + MX93_PAD_ENET2_RXC__ENET1_RX_ER 0x5fe + MX93_PAD_ENET2_RX_CTL__ENET1_RGMII_RX_CTL 0x57e + MX93_PAD_ENET2_TD0__ENET1_RGMII_TD0 0x50e + MX93_PAD_ENET2_TD1__ENET1_RGMII_TD1 0x50e + MX93_PAD_ENET2_TX_CTL__ENET1_RGMII_TX_CTL 0x50e + MX93_PAD_ENET2_TD2__ENET1_TX_CLK 0x4000050e + >; + }; + + pinctrl_leds: ledsgrp { + fsl,pins = < + MX93_PAD_I2C1_SDA__GPIO1_IO01 0x31e + >; + }; + + pinctrl_usdhc1: usdhc1grp { + fsl,pins = < + MX93_PAD_SD1_CLK__USDHC1_CLK 0x179e + MX93_PAD_SD1_CMD__USDHC1_CMD 0x1386 + MX93_PAD_SD1_DATA0__USDHC1_DATA0 0x138e + MX93_PAD_SD1_DATA1__USDHC1_DATA1 0x1386 + MX93_PAD_SD1_DATA2__USDHC1_DATA2 0x138e + MX93_PAD_SD1_DATA3__USDHC1_DATA3 0x1386 + MX93_PAD_SD1_DATA4__USDHC1_DATA4 0x1386 + MX93_PAD_SD1_DATA5__USDHC1_DATA5 0x1386 + MX93_PAD_SD1_DATA6__USDHC1_DATA6 0x1386 + MX93_PAD_SD1_DATA7__USDHC1_DATA7 0x1386 + MX93_PAD_SD1_STROBE__USDHC1_STROBE 0x179e + >; + }; +}; diff --git a/arch/arm/mach-imx/imx9/Kconfig b/arch/arm/mach-imx/imx9/Kconfig index 961d6f527ab..b79485f1f75 100644 --- a/arch/arm/mach-imx/imx9/Kconfig +++ b/arch/arm/mach-imx/imx9/Kconfig @@ -37,9 +37,15 @@ config TARGET_IMX93_VAR_SOM select IMX93 select IMX9_LPDDR4X
+config TARGET_PHYCORE_IMX93 + bool "phycore_imx93" + select IMX93 + select IMX9_LPDDR4X + endchoice
source "board/freescale/imx93_evk/Kconfig" +source "board/phytec/phycore_imx93/Kconfig" source "board/variscite/imx93_var_som/Kconfig"
endif diff --git a/board/phytec/phycore_imx93/Kconfig b/board/phytec/phycore_imx93/Kconfig new file mode 100644 index 00000000000..a70104cb798 --- /dev/null +++ b/board/phytec/phycore_imx93/Kconfig @@ -0,0 +1,13 @@ + +if TARGET_PHYCORE_IMX93 + +config SYS_BOARD + default "phycore_imx93" + +config SYS_VENDOR + default "phytec" + +config SYS_CONFIG_NAME + default "phycore_imx93" + +endif diff --git a/board/phytec/phycore_imx93/MAINTAINERS b/board/phytec/phycore_imx93/MAINTAINERS new file mode 100644 index 00000000000..9e91a29dc31 --- /dev/null +++ b/board/phytec/phycore_imx93/MAINTAINERS @@ -0,0 +1,10 @@ +phyCORE-i.MX93 +M: Mathieu Othacehe m.othacehe@gmail.com +W: https://www.phytec.eu/en/produkte/system-on-modules/phycore-imx-91-93/ +S: Maintained +F: arch/arm/dts/imx93-phyboard-segin.dts +F: arch/arm/dts/imx93-phycore-som.dtsi +F: arch/arm/dts/imx93-phyboard-segin-u-boot.dtsi +F: board/phytec/phycore_imx93/ +F: configs/imx93-phyboard-segin_defconfig +F: include/configs/phycore_imx93.h diff --git a/board/phytec/phycore_imx93/Makefile b/board/phytec/phycore_imx93/Makefile new file mode 100644 index 00000000000..ce35326a156 --- /dev/null +++ b/board/phytec/phycore_imx93/Makefile @@ -0,0 +1,14 @@ +# +# Copyright 2022 NXP +# Copyright (C) 2023 PHYTEC Messtechnik GmbH +# Christoph Stoidner c.stoidner@phytec.de +# Copyright (C) 2024 Mathieu Othacehe m.othacehe@gmail.com +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += phycore-imx93.o + +ifdef CONFIG_SPL_BUILD +obj-y += spl.o lpddr4_timing.o +endif diff --git a/board/phytec/phycore_imx93/lpddr4_timing.c b/board/phytec/phycore_imx93/lpddr4_timing.c new file mode 100644 index 00000000000..2111972a40e --- /dev/null +++ b/board/phytec/phycore_imx93/lpddr4_timing.c @@ -0,0 +1,1546 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2023 NXP + * Copyright (C) 2023 PHYTEC Messtechnik GmbH + * Christoph Stoidner c.stoidner@phytec.de + * + * Code generated with DDR Tool v1.0.0. + */ + +#include <linux/kernel.h> +#include <asm/arch/ddr.h> + +static struct dram_cfg_param ddr_ddrc_cfg[] = { + /** Initialize DDRC registers **/ + {0x4e300110, 0x44100001}, + {0x4e300000, 0x8000bf}, + {0x4e300008, 0x0}, + {0x4e300080, 0x80000412}, + {0x4e300084, 0x0}, + {0x4e300114, 0x1002}, + {0x4e300260, 0x4080}, + {0x4e300f04, 0x80}, + {0x4e300800, 0x43b30002}, + {0x4e300804, 0x1f1f1f1f}, + {0x4e301000, 0x0}, + {0x4e301240, 0x0}, + {0x4e301244, 0x0}, + {0x4e301248, 0x0}, + {0x4e30124c, 0x0}, + {0x4e301250, 0x0}, + {0x4e301254, 0x0}, + {0x4e301258, 0x0}, + {0x4e30125c, 0x0}, + +}; + +/* dram fsp cfg */ +static struct dram_fsp_cfg ddr_dram_fsp_cfg[] = { + { + { + {0x4e300100, 0x24A0421B}, + {0x4e300104, 0xF8EE001B}, + {0x4e300108, 0x2F263233}, + {0x4e30010C, 0x0005E18B}, + {0x4e300124, 0x1C770000}, + {0x4e300160, 0x00009102}, + {0x4e30016C, 0x35F00000}, + {0x4e300170, 0x8B0B0608}, + {0x4e300250, 0x00000028}, + {0x4e300254, 0x00FE00FE}, + {0x4e300258, 0x00000008}, + {0x4e30025C, 0x00000400}, + {0x4e300300, 0x224F2215}, + {0x4e300304, 0x00FE2213}, + {0x4e300308, 0x0A3C0E3C}, + }, + { + {0x01, 0xE4}, + {0x02, 0x36}, + {0x03, 0xF2}, + {0x0b, 0x46}, + {0x0c, 0x11}, + {0x0e, 0x11}, + {0x16, 0x04}, + }, + 0, + }, + +}; + +/* PHY Initialize Configuration */ +static struct dram_cfg_param ddr_ddrphy_cfg[] = { + {0x100a0, 0x0}, + {0x100a1, 0x1}, + {0x100a2, 0x2}, + {0x100a3, 0x3}, + {0x100a4, 0x4}, + {0x100a5, 0x5}, + {0x100a6, 0x6}, + {0x100a7, 0x7}, + {0x110a0, 0x0}, + {0x110a1, 0x1}, + {0x110a2, 0x2}, + {0x110a3, 0x3}, + {0x110a4, 0x4}, + {0x110a5, 0x5}, + {0x110a6, 0x6}, + {0x110a7, 0x7}, + {0x1005f, 0x5ff}, + {0x1015f, 0x5ff}, + {0x1105f, 0x5ff}, + {0x1115f, 0x5ff}, + {0x55, 0x1ff}, + {0x1055, 0x1ff}, + {0x2055, 0x1ff}, + {0x200c5, 0x19}, + {0x2002e, 0x2}, + {0x90204, 0x0}, + {0x20024, 0x1e3}, + {0x2003a, 0x2}, + {0x2007d, 0x212}, + {0x2007c, 0x61}, + {0x20056, 0x3}, + {0x1004d, 0x600}, + {0x1014d, 0x600}, + {0x1104d, 0x600}, + {0x1114d, 0x600}, + {0x10049, 0xe00}, + {0x10149, 0xe00}, + {0x11049, 0xe00}, + {0x11149, 0xe00}, + {0x43, 0x60}, + {0x1043, 0x60}, + {0x2043, 0x60}, + {0x20018, 0x1}, + {0x20075, 0x4}, + {0x20050, 0x0}, + {0x2009b, 0x2}, + {0x20008, 0x3a5}, + {0x20088, 0x9}, + {0x200b2, 0x10c}, + {0x10043, 0x5a1}, + {0x10143, 0x5a1}, + {0x11043, 0x5a1}, + {0x11143, 0x5a1}, + {0x200fa, 0x2}, + {0x20019, 0x1}, + {0x200f0, 0x600}, + {0x200f1, 0x0}, + {0x200f2, 0x4444}, + {0x200f3, 0x8888}, + {0x200f4, 0x5655}, + {0x200f5, 0x0}, + {0x200f6, 0x0}, + {0x200f7, 0xf000}, + {0x20025, 0x0}, + {0x2002d, 0x1}, + {0x2002c, 0x0}, + {0x20021, 0x0}, + {0x200c7, 0x21}, + {0x1200c7, 0x21}, + {0x200ca, 0x24}, + {0x1200ca, 0x24}, + +}; + +/* ddr phy trained csr */ +static struct dram_cfg_param ddr_ddrphy_trained_csr[] = { + {0x1005f, 0x0}, + {0x1015f, 0x0}, + {0x1105f, 0x0}, + {0x1115f, 0x0}, + {0x55, 0x0}, + {0x1055, 0x0}, + {0x2055, 0x0}, + {0x200c5, 0x0}, + {0x2002e, 0x0}, + {0x90204, 0x0}, + {0x20024, 0x0}, + {0x2003a, 0x0}, + {0x2007d, 0x0}, + {0x2007c, 0x0}, + {0x20056, 0x0}, + {0x1004d, 0x0}, + {0x1014d, 0x0}, + {0x1104d, 0x0}, + {0x1114d, 0x0}, + {0x10049, 0x0}, + {0x10149, 0x0}, + {0x11049, 0x0}, + {0x11149, 0x0}, + {0x43, 0x0}, + {0x1043, 0x0}, + {0x2043, 0x0}, + {0x20018, 0x0}, + {0x20075, 0x0}, + {0x20050, 0x0}, + {0x2009b, 0x0}, + {0x20008, 0x0}, + {0x20088, 0x0}, + {0x200b2, 0x0}, + {0x10043, 0x0}, + {0x10143, 0x0}, + {0x11043, 0x0}, + {0x11143, 0x0}, + {0x200fa, 0x0}, + {0x20019, 0x0}, + {0x200f0, 0x0}, + {0x200f1, 0x0}, + {0x200f2, 0x0}, + {0x200f3, 0x0}, + {0x200f4, 0x0}, + {0x200f5, 0x0}, + {0x200f6, 0x0}, + {0x200f7, 0x0}, + {0x20025, 0x0}, + {0x2002d, 0x0}, + {0x2002c, 0x0}, + {0xd0000, 0x0}, + {0x90000, 0x0}, + {0x90001, 0x0}, + {0x90002, 0x0}, + {0x90003, 0x0}, + {0x90004, 0x0}, + {0x90005, 0x0}, + {0x90029, 0x0}, + {0x9002a, 0x0}, + {0x9002b, 0x0}, + {0x9002c, 0x0}, + {0x9002d, 0x0}, + {0x9002e, 0x0}, + {0x9002f, 0x0}, + {0x90030, 0x0}, + {0x90031, 0x0}, + {0x90032, 0x0}, + {0x90033, 0x0}, + {0x90034, 0x0}, + {0x90035, 0x0}, + {0x90036, 0x0}, + {0x90037, 0x0}, + {0x90038, 0x0}, + {0x90039, 0x0}, + {0x9003a, 0x0}, + {0x9003b, 0x0}, + {0x9003c, 0x0}, + {0x9003d, 0x0}, + {0x9003e, 0x0}, + {0x9003f, 0x0}, + {0x90040, 0x0}, + {0x90041, 0x0}, + {0x90042, 0x0}, + {0x90043, 0x0}, + {0x90044, 0x0}, + {0x90045, 0x0}, + {0x90046, 0x0}, + {0x90047, 0x0}, + {0x90048, 0x0}, + {0x90049, 0x0}, + {0x9004a, 0x0}, + {0x9004b, 0x0}, + {0x9004c, 0x0}, + {0x9004d, 0x0}, + {0x9004e, 0x0}, + {0x9004f, 0x0}, + {0x90050, 0x0}, + {0x90051, 0x0}, + {0x90052, 0x0}, + {0x90053, 0x0}, + {0x90054, 0x0}, + {0x90055, 0x0}, + {0x90056, 0x0}, + {0x90057, 0x0}, + {0x90058, 0x0}, + {0x90059, 0x0}, + {0x9005a, 0x0}, + {0x9005b, 0x0}, + {0x9005c, 0x0}, + {0x9005d, 0x0}, + {0x9005e, 0x0}, + {0x9005f, 0x0}, + {0x90060, 0x0}, + {0x90061, 0x0}, + {0x90062, 0x0}, + {0x90063, 0x0}, + {0x90064, 0x0}, + {0x90065, 0x0}, + {0x90066, 0x0}, + {0x90067, 0x0}, + {0x90068, 0x0}, + {0x90069, 0x0}, + {0x9006a, 0x0}, + {0x9006b, 0x0}, + {0x9006c, 0x0}, + {0x9006d, 0x0}, + {0x9006e, 0x0}, + {0x9006f, 0x0}, + {0x90070, 0x0}, + {0x90071, 0x0}, + {0x90072, 0x0}, + {0x90073, 0x0}, + {0x90074, 0x0}, + {0x90075, 0x0}, + {0x90076, 0x0}, + {0x90077, 0x0}, + {0x90078, 0x0}, + {0x90079, 0x0}, + {0x9007a, 0x0}, + {0x9007b, 0x0}, + {0x9007c, 0x0}, + {0x9007d, 0x0}, + {0x9007e, 0x0}, + {0x9007f, 0x0}, + {0x90080, 0x0}, + {0x90081, 0x0}, + {0x90082, 0x0}, + {0x90083, 0x0}, + {0x90084, 0x0}, + {0x90085, 0x0}, + {0x90086, 0x0}, + {0x90087, 0x0}, + {0x90088, 0x0}, + {0x90089, 0x0}, + {0x9008a, 0x0}, + {0x9008b, 0x0}, + {0x9008c, 0x0}, + {0x9008d, 0x0}, + {0x9008e, 0x0}, + {0x9008f, 0x0}, + {0x90090, 0x0}, + {0x90091, 0x0}, + {0x90092, 0x0}, + {0x90093, 0x0}, + {0x90094, 0x0}, + {0x90095, 0x0}, + {0x90096, 0x0}, + {0x90097, 0x0}, + {0x90098, 0x0}, + {0x90099, 0x0}, + {0x9009a, 0x0}, + {0x9009b, 0x0}, + {0x9009c, 0x0}, + {0x9009d, 0x0}, + {0x9009e, 0x0}, + {0x9009f, 0x0}, + {0x900a0, 0x0}, + {0x900a1, 0x0}, + {0x900a2, 0x0}, + {0x900a3, 0x0}, + {0x900a4, 0x0}, + {0x900a5, 0x0}, + {0x900a6, 0x0}, + {0x900a7, 0x0}, + {0x900a8, 0x0}, + {0x900a9, 0x0}, + {0x40000, 0x0}, + {0x40020, 0x0}, + {0x40040, 0x0}, + {0x40060, 0x0}, + {0x40001, 0x0}, + {0x40021, 0x0}, + {0x40041, 0x0}, + {0x40061, 0x0}, + {0x40002, 0x0}, + {0x40022, 0x0}, + {0x40042, 0x0}, + {0x40062, 0x0}, + {0x40003, 0x0}, + {0x40023, 0x0}, + {0x40043, 0x0}, + {0x40063, 0x0}, + {0x40004, 0x0}, + {0x40024, 0x0}, + {0x40044, 0x0}, + {0x40064, 0x0}, + {0x40005, 0x0}, + {0x40025, 0x0}, + {0x40045, 0x0}, + {0x40065, 0x0}, + {0x40006, 0x0}, + {0x40026, 0x0}, + {0x40046, 0x0}, + {0x40066, 0x0}, + {0x40007, 0x0}, + {0x40027, 0x0}, + {0x40047, 0x0}, + {0x40067, 0x0}, + {0x40008, 0x0}, + {0x40028, 0x0}, + {0x40048, 0x0}, + {0x40068, 0x0}, + {0x40009, 0x0}, + {0x40029, 0x0}, + {0x40049, 0x0}, + {0x40069, 0x0}, + {0x4000a, 0x0}, + {0x4002a, 0x0}, + {0x4004a, 0x0}, + {0x4006a, 0x0}, + {0x4000b, 0x0}, + {0x4002b, 0x0}, + {0x4004b, 0x0}, + {0x4006b, 0x0}, + {0x4000c, 0x0}, + {0x4002c, 0x0}, + {0x4004c, 0x0}, + {0x4006c, 0x0}, + {0x4000d, 0x0}, + {0x4002d, 0x0}, + {0x4004d, 0x0}, + {0x4006d, 0x0}, + {0x4000e, 0x0}, + {0x4002e, 0x0}, + {0x4004e, 0x0}, + {0x4006e, 0x0}, + {0x4000f, 0x0}, + {0x4002f, 0x0}, + {0x4004f, 0x0}, + {0x4006f, 0x0}, + {0x40010, 0x0}, + {0x40030, 0x0}, + {0x40050, 0x0}, + {0x40070, 0x0}, + {0x40011, 0x0}, + {0x40031, 0x0}, + {0x40051, 0x0}, + {0x40071, 0x0}, + {0x40012, 0x0}, + {0x40032, 0x0}, + {0x40052, 0x0}, + {0x40072, 0x0}, + {0x40013, 0x0}, + {0x40033, 0x0}, + {0x40053, 0x0}, + {0x40073, 0x0}, + {0x40014, 0x0}, + {0x40034, 0x0}, + {0x40054, 0x0}, + {0x40074, 0x0}, + {0x40015, 0x0}, + {0x40035, 0x0}, + {0x40055, 0x0}, + {0x40075, 0x0}, + {0x40016, 0x0}, + {0x40036, 0x0}, + {0x40056, 0x0}, + {0x40076, 0x0}, + {0x40017, 0x0}, + {0x40037, 0x0}, + {0x40057, 0x0}, + {0x40077, 0x0}, + {0x40018, 0x0}, + {0x40038, 0x0}, + {0x40058, 0x0}, + {0x40078, 0x0}, + {0x40019, 0x0}, + {0x40039, 0x0}, + {0x40059, 0x0}, + {0x40079, 0x0}, + {0x4001a, 0x0}, + {0x4003a, 0x0}, + {0x4005a, 0x0}, + {0x4007a, 0x0}, + {0x900aa, 0x0}, + {0x900ab, 0x0}, + {0x900ac, 0x0}, + {0x900ad, 0x0}, + {0x900ae, 0x0}, + {0x900af, 0x0}, + {0x900b0, 0x0}, + {0x900b1, 0x0}, + {0x900b2, 0x0}, + {0x900b3, 0x0}, + {0x900b4, 0x0}, + {0x900b5, 0x0}, + {0x900b6, 0x0}, + {0x900b7, 0x0}, + {0x900b8, 0x0}, + {0x900b9, 0x0}, + {0x900ba, 0x0}, + {0x900bb, 0x0}, + {0x900bc, 0x0}, + {0x900bd, 0x0}, + {0x900be, 0x0}, + {0x900bf, 0x0}, + {0x900c0, 0x0}, + {0x900c1, 0x0}, + {0x900c2, 0x0}, + {0x900c3, 0x0}, + {0x900c4, 0x0}, + {0x900c5, 0x0}, + {0x900c6, 0x0}, + {0x900c7, 0x0}, + {0x900c8, 0x0}, + {0x900c9, 0x0}, + {0x900ca, 0x0}, + {0x900cb, 0x0}, + {0x900cc, 0x0}, + {0x900cd, 0x0}, + {0x900ce, 0x0}, + {0x900cf, 0x0}, + {0x900d0, 0x0}, + {0x900d1, 0x0}, + {0x900d2, 0x0}, + {0x900d3, 0x0}, + {0x900d4, 0x0}, + {0x900d5, 0x0}, + {0x900d6, 0x0}, + {0x900d7, 0x0}, + {0x900d8, 0x0}, + {0x900d9, 0x0}, + {0x900da, 0x0}, + {0x900db, 0x0}, + {0x900dc, 0x0}, + {0x900dd, 0x0}, + {0x900de, 0x0}, + {0x900df, 0x0}, + {0x900e0, 0x0}, + {0x900e1, 0x0}, + {0x900e2, 0x0}, + {0x900e3, 0x0}, + {0x900e4, 0x0}, + {0x900e5, 0x0}, + {0x900e6, 0x0}, + {0x900e7, 0x0}, + {0x900e8, 0x0}, + {0x900e9, 0x0}, + {0x900ea, 0x0}, + {0x900eb, 0x0}, + {0x900ec, 0x0}, + {0x900ed, 0x0}, + {0x900ee, 0x0}, + {0x900ef, 0x0}, + {0x900f0, 0x0}, + {0x900f1, 0x0}, + {0x900f2, 0x0}, + {0x900f3, 0x0}, + {0x900f4, 0x0}, + {0x900f5, 0x0}, + {0x900f6, 0x0}, + {0x900f7, 0x0}, + {0x900f8, 0x0}, + {0x900f9, 0x0}, + {0x900fa, 0x0}, + {0x900fb, 0x0}, + {0x900fc, 0x0}, + {0x900fd, 0x0}, + {0x900fe, 0x0}, + {0x900ff, 0x0}, + {0x90100, 0x0}, + {0x90101, 0x0}, + {0x90102, 0x0}, + {0x90103, 0x0}, + {0x90104, 0x0}, + {0x90105, 0x0}, + {0x90106, 0x0}, + {0x90107, 0x0}, + {0x90108, 0x0}, + {0x90109, 0x0}, + {0x9010a, 0x0}, + {0x9010b, 0x0}, + {0x9010c, 0x0}, + {0x9010d, 0x0}, + {0x9010e, 0x0}, + {0x9010f, 0x0}, + {0x90110, 0x0}, + {0x90111, 0x0}, + {0x90112, 0x0}, + {0x90113, 0x0}, + {0x90114, 0x0}, + {0x90115, 0x0}, + {0x90116, 0x0}, + {0x90117, 0x0}, + {0x90118, 0x0}, + {0x90119, 0x0}, + {0x9011a, 0x0}, + {0x9011b, 0x0}, + {0x9011c, 0x0}, + {0x9011d, 0x0}, + {0x9011e, 0x0}, + {0x9011f, 0x0}, + {0x90120, 0x0}, + {0x90121, 0x0}, + {0x90122, 0x0}, + {0x90123, 0x0}, + {0x90124, 0x0}, + {0x90125, 0x0}, + {0x90126, 0x0}, + {0x90127, 0x0}, + {0x90128, 0x0}, + {0x90129, 0x0}, + {0x9012a, 0x0}, + {0x9012b, 0x0}, + {0x9012c, 0x0}, + {0x9012d, 0x0}, + {0x9012e, 0x0}, + {0x9012f, 0x0}, + {0x90130, 0x0}, + {0x90131, 0x0}, + {0x90132, 0x0}, + {0x90133, 0x0}, + {0x90134, 0x0}, + {0x90135, 0x0}, + {0x90136, 0x0}, + {0x90137, 0x0}, + {0x90138, 0x0}, + {0x90139, 0x0}, + {0x9013a, 0x0}, + {0x9013b, 0x0}, + {0x9013c, 0x0}, + {0x9013d, 0x0}, + {0x9013e, 0x0}, + {0x9013f, 0x0}, + {0x90140, 0x0}, + {0x90141, 0x0}, + {0x90142, 0x0}, + {0x90143, 0x0}, + {0x90144, 0x0}, + {0x90145, 0x0}, + {0x90146, 0x0}, + {0x90147, 0x0}, + {0x90148, 0x0}, + {0x90149, 0x0}, + {0x9014a, 0x0}, + {0x9014b, 0x0}, + {0x9014c, 0x0}, + {0x9014d, 0x0}, + {0x9014e, 0x0}, + {0x9014f, 0x0}, + {0x90150, 0x0}, + {0x90151, 0x0}, + {0x90152, 0x0}, + {0x90153, 0x0}, + {0x90154, 0x0}, + {0x90155, 0x0}, + {0x90156, 0x0}, + {0x90157, 0x0}, + {0x90158, 0x0}, + {0x90159, 0x0}, + {0x9015a, 0x0}, + {0x9015b, 0x0}, + {0x9015c, 0x0}, + {0x9015d, 0x0}, + {0x9015e, 0x0}, + {0x9015f, 0x0}, + {0x90160, 0x0}, + {0x90161, 0x0}, + {0x90162, 0x0}, + {0x90163, 0x0}, + {0x90164, 0x0}, + {0x90165, 0x0}, + {0x90166, 0x0}, + {0x90167, 0x0}, + {0x90168, 0x0}, + {0x90169, 0x0}, + {0x9016a, 0x0}, + {0x9016b, 0x0}, + {0x9016c, 0x0}, + {0x9016d, 0x0}, + {0x9016e, 0x0}, + {0x9016f, 0x0}, + {0x90170, 0x0}, + {0x90171, 0x0}, + {0x90172, 0x0}, + {0x90173, 0x0}, + {0x90174, 0x0}, + {0x90175, 0x0}, + {0x90176, 0x0}, + {0x90177, 0x0}, + {0x90178, 0x0}, + {0x90179, 0x0}, + {0x9017a, 0x0}, + {0x9017b, 0x0}, + {0x9017c, 0x0}, + {0x9017d, 0x0}, + {0x9017e, 0x0}, + {0x9017f, 0x0}, + {0x90180, 0x0}, + {0x90181, 0x0}, + {0x90182, 0x0}, + {0x90183, 0x0}, + {0x90184, 0x0}, + {0x90006, 0x0}, + {0x90007, 0x0}, + {0x90008, 0x0}, + {0x90009, 0x0}, + {0x9000a, 0x0}, + {0x9000b, 0x0}, + {0xd00e7, 0x0}, + {0x90017, 0x0}, + {0x9001f, 0x0}, + {0x90026, 0x0}, + {0x400d0, 0x0}, + {0x400d1, 0x0}, + {0x400d2, 0x0}, + {0x400d3, 0x0}, + {0x400d4, 0x0}, + {0x400d5, 0x0}, + {0x400d6, 0x0}, + {0x400d7, 0x0}, + {0x200be, 0x0}, + {0x2000b, 0x0}, + {0x2000c, 0x0}, + {0x2000d, 0x0}, + {0x2000e, 0x0}, + {0x9000c, 0x0}, + {0x9000d, 0x0}, + {0x9000e, 0x0}, + {0x9000f, 0x0}, + {0x90010, 0x0}, + {0x90011, 0x0}, + {0x90012, 0x0}, + {0x90013, 0x0}, + {0x20010, 0x0}, + {0x20011, 0x0}, + {0x40080, 0x0}, + {0x40081, 0x0}, + {0x40082, 0x0}, + {0x40083, 0x0}, + {0x40084, 0x0}, + {0x40085, 0x0}, + {0x400fd, 0x0}, + {0x400f1, 0x0}, + {0x10011, 0x0}, + {0x10012, 0x0}, + {0x10013, 0x0}, + {0x10018, 0x0}, + {0x10002, 0x0}, + {0x100b2, 0x0}, + {0x101b4, 0x0}, + {0x102b4, 0x0}, + {0x103b4, 0x0}, + {0x104b4, 0x0}, + {0x105b4, 0x0}, + {0x106b4, 0x0}, + {0x107b4, 0x0}, + {0x108b4, 0x0}, + {0x11011, 0x0}, + {0x11012, 0x0}, + {0x11013, 0x0}, + {0x11018, 0x0}, + {0x11002, 0x0}, + {0x110b2, 0x0}, + {0x111b4, 0x0}, + {0x112b4, 0x0}, + {0x113b4, 0x0}, + {0x114b4, 0x0}, + {0x115b4, 0x0}, + {0x116b4, 0x0}, + {0x117b4, 0x0}, + {0x118b4, 0x0}, + {0x20089, 0x0}, + {0xc0080, 0x0}, + {0x200cb, 0x0}, + {0x10068, 0x0}, + {0x10069, 0x0}, + {0x10168, 0x0}, + {0x10169, 0x0}, + {0x10268, 0x0}, + {0x10269, 0x0}, + {0x10368, 0x0}, + {0x10369, 0x0}, + {0x10468, 0x0}, + {0x10469, 0x0}, + {0x10568, 0x0}, + {0x10569, 0x0}, + {0x10668, 0x0}, + {0x10669, 0x0}, + {0x10768, 0x0}, + {0x10769, 0x0}, + {0x10868, 0x0}, + {0x10869, 0x0}, + {0x100aa, 0x0}, + {0x10062, 0x0}, + {0x10001, 0x0}, + {0x100a0, 0x0}, + {0x100a1, 0x0}, + {0x100a2, 0x0}, + {0x100a3, 0x0}, + {0x100a4, 0x0}, + {0x100a5, 0x0}, + {0x100a6, 0x0}, + {0x100a7, 0x0}, + {0x11068, 0x0}, + {0x11069, 0x0}, + {0x11168, 0x0}, + {0x11169, 0x0}, + {0x11268, 0x0}, + {0x11269, 0x0}, + {0x11368, 0x0}, + {0x11369, 0x0}, + {0x11468, 0x0}, + {0x11469, 0x0}, + {0x11568, 0x0}, + {0x11569, 0x0}, + {0x11668, 0x0}, + {0x11669, 0x0}, + {0x11768, 0x0}, + {0x11769, 0x0}, + {0x11868, 0x0}, + {0x11869, 0x0}, + {0x110aa, 0x0}, + {0x11062, 0x0}, + {0x11001, 0x0}, + {0x110a0, 0x0}, + {0x110a1, 0x0}, + {0x110a2, 0x0}, + {0x110a3, 0x0}, + {0x110a4, 0x0}, + {0x110a5, 0x0}, + {0x110a6, 0x0}, + {0x110a7, 0x0}, + {0x80, 0x0}, + {0x1080, 0x0}, + {0x2080, 0x0}, + {0x10020, 0x0}, + {0x10080, 0x0}, + {0x10081, 0x0}, + {0x100d0, 0x0}, + {0x100d1, 0x0}, + {0x1008c, 0x0}, + {0x1008d, 0x0}, + {0x10180, 0x0}, + {0x10181, 0x0}, + {0x101d0, 0x0}, + {0x101d1, 0x0}, + {0x1018c, 0x0}, + {0x1018d, 0x0}, + {0x100c0, 0x0}, + {0x100c1, 0x0}, + {0x101c0, 0x0}, + {0x101c1, 0x0}, + {0x102c0, 0x0}, + {0x102c1, 0x0}, + {0x103c0, 0x0}, + {0x103c1, 0x0}, + {0x104c0, 0x0}, + {0x104c1, 0x0}, + {0x105c0, 0x0}, + {0x105c1, 0x0}, + {0x106c0, 0x0}, + {0x106c1, 0x0}, + {0x107c0, 0x0}, + {0x107c1, 0x0}, + {0x108c0, 0x0}, + {0x108c1, 0x0}, + {0x100ae, 0x0}, + {0x100af, 0x0}, + {0x11020, 0x0}, + {0x11080, 0x0}, + {0x11081, 0x0}, + {0x110d0, 0x0}, + {0x110d1, 0x0}, + {0x1108c, 0x0}, + {0x1108d, 0x0}, + {0x11180, 0x0}, + {0x11181, 0x0}, + {0x111d0, 0x0}, + {0x111d1, 0x0}, + {0x1118c, 0x0}, + {0x1118d, 0x0}, + {0x110c0, 0x0}, + {0x110c1, 0x0}, + {0x111c0, 0x0}, + {0x111c1, 0x0}, + {0x112c0, 0x0}, + {0x112c1, 0x0}, + {0x113c0, 0x0}, + {0x113c1, 0x0}, + {0x114c0, 0x0}, + {0x114c1, 0x0}, + {0x115c0, 0x0}, + {0x115c1, 0x0}, + {0x116c0, 0x0}, + {0x116c1, 0x0}, + {0x117c0, 0x0}, + {0x117c1, 0x0}, + {0x118c0, 0x0}, + {0x118c1, 0x0}, + {0x110ae, 0x0}, + {0x110af, 0x0}, + {0x90201, 0x0}, + {0x90202, 0x0}, + {0x90203, 0x0}, + {0x90205, 0x0}, + {0x90206, 0x0}, + {0x90207, 0x0}, + {0x90208, 0x0}, + {0x20020, 0x0}, + {0x20077, 0x0}, + {0x20072, 0x0}, + {0x20073, 0x0}, + {0x400c0, 0x0}, + {0x10040, 0x0}, + {0x10140, 0x0}, + {0x10240, 0x0}, + {0x10340, 0x0}, + {0x10440, 0x0}, + {0x10540, 0x0}, + {0x10640, 0x0}, + {0x10740, 0x0}, + {0x10840, 0x0}, + {0x11040, 0x0}, + {0x11140, 0x0}, + {0x11240, 0x0}, + {0x11340, 0x0}, + {0x11440, 0x0}, + {0x11540, 0x0}, + {0x11640, 0x0}, + {0x11740, 0x0}, + {0x11840, 0x0}, + +}; + +/* P0 message block parameter for training firmware */ +static struct dram_cfg_param ddr_fsp0_cfg[] = { + {0xd0000, 0x0}, + {0x54003, 0xe94}, + {0x54004, 0x4}, + {0x54006, 0x15}, + {0x54008, 0x131f}, + {0x54009, 0xc8}, + {0x5400b, 0x4}, + {0x5400d, 0x100}, + {0x5400f, 0x100}, + {0x54012, 0x110}, + {0x54019, 0x36e4}, + {0x5401a, 0xf2}, + {0x5401b, 0x1146}, + {0x5401c, 0x1108}, + {0x5401e, 0x4}, + {0x5401f, 0x36e4}, + {0x54020, 0xf2}, + {0x54021, 0x1146}, + {0x54022, 0x1108}, + {0x54024, 0x4}, + {0x54032, 0xe400}, + {0x54033, 0xf236}, + {0x54034, 0x4600}, + {0x54035, 0x811}, + {0x54036, 0x11}, + {0x54037, 0x400}, + {0x54038, 0xe400}, + {0x54039, 0xf236}, + {0x5403a, 0x4600}, + {0x5403b, 0x811}, + {0x5403c, 0x11}, + {0x5403d, 0x400}, + {0xd0000, 0x1} +}; + +/* P0 2D message block parameter for training firmware */ +static struct dram_cfg_param ddr_fsp0_2d_cfg[] = { + {0xd0000, 0x0}, + {0x54003, 0xe94}, + {0x54004, 0x4}, + {0x54006, 0x15}, + {0x54008, 0x61}, + {0x54009, 0xc8}, + {0x5400b, 0x4}, + {0x5400d, 0x100}, + {0x5400f, 0x100}, + {0x54010, 0x2080}, + {0x54012, 0x110}, + {0x54019, 0x36e4}, + {0x5401a, 0xf2}, + {0x5401b, 0x1146}, + {0x5401c, 0x1108}, + {0x5401e, 0x4}, + {0x5401f, 0x36e4}, + {0x54020, 0xf2}, + {0x54021, 0x1146}, + {0x54022, 0x1108}, + {0x54024, 0x4}, + {0x54032, 0xe400}, + {0x54033, 0xf236}, + {0x54034, 0x4600}, + {0x54035, 0x811}, + {0x54036, 0x11}, + {0x54037, 0x400}, + {0x54038, 0xe400}, + {0x54039, 0xf236}, + {0x5403a, 0x4600}, + {0x5403b, 0x811}, + {0x5403c, 0x11}, + {0x5403d, 0x400}, + {0xd0000, 0x1} +}; + +/* DRAM PHY init engine image */ +static struct dram_cfg_param ddr_phy_pie[] = { + {0xd0000, 0x0}, + {0x90000, 0x10}, + {0x90001, 0x400}, + {0x90002, 0x10e}, + {0x90003, 0x0}, + {0x90004, 0x0}, + {0x90005, 0x8}, + {0x90029, 0xb}, + {0x9002a, 0x480}, + {0x9002b, 0x109}, + {0x9002c, 0x8}, + {0x9002d, 0x448}, + {0x9002e, 0x139}, + {0x9002f, 0x8}, + {0x90030, 0x478}, + {0x90031, 0x109}, + {0x90032, 0x0}, + {0x90033, 0xe8}, + {0x90034, 0x109}, + {0x90035, 0x2}, + {0x90036, 0x10}, + {0x90037, 0x139}, + {0x90038, 0xb}, + {0x90039, 0x7c0}, + {0x9003a, 0x139}, + {0x9003b, 0x44}, + {0x9003c, 0x633}, + {0x9003d, 0x159}, + {0x9003e, 0x14f}, + {0x9003f, 0x630}, + {0x90040, 0x159}, + {0x90041, 0x47}, + {0x90042, 0x633}, + {0x90043, 0x149}, + {0x90044, 0x4f}, + {0x90045, 0x633}, + {0x90046, 0x179}, + {0x90047, 0x8}, + {0x90048, 0xe0}, + {0x90049, 0x109}, + {0x9004a, 0x0}, + {0x9004b, 0x7c8}, + {0x9004c, 0x109}, + {0x9004d, 0x0}, + {0x9004e, 0x1}, + {0x9004f, 0x8}, + {0x90050, 0x30}, + {0x90051, 0x65a}, + {0x90052, 0x9}, + {0x90053, 0x0}, + {0x90054, 0x45a}, + {0x90055, 0x9}, + {0x90056, 0x0}, + {0x90057, 0x448}, + {0x90058, 0x109}, + {0x90059, 0x40}, + {0x9005a, 0x633}, + {0x9005b, 0x179}, + {0x9005c, 0x1}, + {0x9005d, 0x618}, + {0x9005e, 0x109}, + {0x9005f, 0x40c0}, + {0x90060, 0x633}, + {0x90061, 0x149}, + {0x90062, 0x8}, + {0x90063, 0x4}, + {0x90064, 0x48}, + {0x90065, 0x4040}, + {0x90066, 0x633}, + {0x90067, 0x149}, + {0x90068, 0x0}, + {0x90069, 0x4}, + {0x9006a, 0x48}, + {0x9006b, 0x40}, + {0x9006c, 0x633}, + {0x9006d, 0x149}, + {0x9006e, 0x0}, + {0x9006f, 0x658}, + {0x90070, 0x109}, + {0x90071, 0x10}, + {0x90072, 0x4}, + {0x90073, 0x18}, + {0x90074, 0x0}, + {0x90075, 0x4}, + {0x90076, 0x78}, + {0x90077, 0x549}, + {0x90078, 0x633}, + {0x90079, 0x159}, + {0x9007a, 0xd49}, + {0x9007b, 0x633}, + {0x9007c, 0x159}, + {0x9007d, 0x94a}, + {0x9007e, 0x633}, + {0x9007f, 0x159}, + {0x90080, 0x441}, + {0x90081, 0x633}, + {0x90082, 0x149}, + {0x90083, 0x42}, + {0x90084, 0x633}, + {0x90085, 0x149}, + {0x90086, 0x1}, + {0x90087, 0x633}, + {0x90088, 0x149}, + {0x90089, 0x0}, + {0x9008a, 0xe0}, + {0x9008b, 0x109}, + {0x9008c, 0xa}, + {0x9008d, 0x10}, + {0x9008e, 0x109}, + {0x9008f, 0x9}, + {0x90090, 0x3c0}, + {0x90091, 0x149}, + {0x90092, 0x9}, + {0x90093, 0x3c0}, + {0x90094, 0x159}, + {0x90095, 0x18}, + {0x90096, 0x10}, + {0x90097, 0x109}, + {0x90098, 0x0}, + {0x90099, 0x3c0}, + {0x9009a, 0x109}, + {0x9009b, 0x18}, + {0x9009c, 0x4}, + {0x9009d, 0x48}, + {0x9009e, 0x18}, + {0x9009f, 0x4}, + {0x900a0, 0x58}, + {0x900a1, 0xb}, + {0x900a2, 0x10}, + {0x900a3, 0x109}, + {0x900a4, 0x1}, + {0x900a5, 0x10}, + {0x900a6, 0x109}, + {0x900a7, 0x5}, + {0x900a8, 0x7c0}, + {0x900a9, 0x109}, + {0x40000, 0x811}, + {0x40020, 0x880}, + {0x40040, 0x0}, + {0x40060, 0x0}, + {0x40001, 0x4008}, + {0x40021, 0x83}, + {0x40041, 0x4f}, + {0x40061, 0x0}, + {0x40002, 0x4040}, + {0x40022, 0x83}, + {0x40042, 0x51}, + {0x40062, 0x0}, + {0x40003, 0x811}, + {0x40023, 0x880}, + {0x40043, 0x0}, + {0x40063, 0x0}, + {0x40004, 0x720}, + {0x40024, 0xf}, + {0x40044, 0x1740}, + {0x40064, 0x0}, + {0x40005, 0x16}, + {0x40025, 0x83}, + {0x40045, 0x4b}, + {0x40065, 0x0}, + {0x40006, 0x716}, + {0x40026, 0xf}, + {0x40046, 0x2001}, + {0x40066, 0x0}, + {0x40007, 0x716}, + {0x40027, 0xf}, + {0x40047, 0x2800}, + {0x40067, 0x0}, + {0x40008, 0x716}, + {0x40028, 0xf}, + {0x40048, 0xf00}, + {0x40068, 0x0}, + {0x40009, 0x720}, + {0x40029, 0xf}, + {0x40049, 0x1400}, + {0x40069, 0x0}, + {0x4000a, 0xe08}, + {0x4002a, 0xc15}, + {0x4004a, 0x0}, + {0x4006a, 0x0}, + {0x4000b, 0x625}, + {0x4002b, 0x15}, + {0x4004b, 0x0}, + {0x4006b, 0x0}, + {0x4000c, 0x4028}, + {0x4002c, 0x80}, + {0x4004c, 0x0}, + {0x4006c, 0x0}, + {0x4000d, 0xe08}, + {0x4002d, 0xc1a}, + {0x4004d, 0x0}, + {0x4006d, 0x0}, + {0x4000e, 0x625}, + {0x4002e, 0x1a}, + {0x4004e, 0x0}, + {0x4006e, 0x0}, + {0x4000f, 0x4040}, + {0x4002f, 0x80}, + {0x4004f, 0x0}, + {0x4006f, 0x0}, + {0x40010, 0x2604}, + {0x40030, 0x15}, + {0x40050, 0x0}, + {0x40070, 0x0}, + {0x40011, 0x708}, + {0x40031, 0x5}, + {0x40051, 0x0}, + {0x40071, 0x2002}, + {0x40012, 0x8}, + {0x40032, 0x80}, + {0x40052, 0x0}, + {0x40072, 0x0}, + {0x40013, 0x2604}, + {0x40033, 0x1a}, + {0x40053, 0x0}, + {0x40073, 0x0}, + {0x40014, 0x708}, + {0x40034, 0xa}, + {0x40054, 0x0}, + {0x40074, 0x2002}, + {0x40015, 0x4040}, + {0x40035, 0x80}, + {0x40055, 0x0}, + {0x40075, 0x0}, + {0x40016, 0x60a}, + {0x40036, 0x15}, + {0x40056, 0x1200}, + {0x40076, 0x0}, + {0x40017, 0x61a}, + {0x40037, 0x15}, + {0x40057, 0x1300}, + {0x40077, 0x0}, + {0x40018, 0x60a}, + {0x40038, 0x1a}, + {0x40058, 0x1200}, + {0x40078, 0x0}, + {0x40019, 0x642}, + {0x40039, 0x1a}, + {0x40059, 0x1300}, + {0x40079, 0x0}, + {0x4001a, 0x4808}, + {0x4003a, 0x880}, + {0x4005a, 0x0}, + {0x4007a, 0x0}, + {0x900aa, 0x0}, + {0x900ab, 0x790}, + {0x900ac, 0x11a}, + {0x900ad, 0x8}, + {0x900ae, 0x7aa}, + {0x900af, 0x2a}, + {0x900b0, 0x10}, + {0x900b1, 0x7b2}, + {0x900b2, 0x2a}, + {0x900b3, 0x0}, + {0x900b4, 0x7c8}, + {0x900b5, 0x109}, + {0x900b6, 0x10}, + {0x900b7, 0x10}, + {0x900b8, 0x109}, + {0x900b9, 0x10}, + {0x900ba, 0x2a8}, + {0x900bb, 0x129}, + {0x900bc, 0x8}, + {0x900bd, 0x370}, + {0x900be, 0x129}, + {0x900bf, 0xa}, + {0x900c0, 0x3c8}, + {0x900c1, 0x1a9}, + {0x900c2, 0xc}, + {0x900c3, 0x408}, + {0x900c4, 0x199}, + {0x900c5, 0x14}, + {0x900c6, 0x790}, + {0x900c7, 0x11a}, + {0x900c8, 0x8}, + {0x900c9, 0x4}, + {0x900ca, 0x18}, + {0x900cb, 0xe}, + {0x900cc, 0x408}, + {0x900cd, 0x199}, + {0x900ce, 0x8}, + {0x900cf, 0x8568}, + {0x900d0, 0x108}, + {0x900d1, 0x18}, + {0x900d2, 0x790}, + {0x900d3, 0x16a}, + {0x900d4, 0x8}, + {0x900d5, 0x1d8}, + {0x900d6, 0x169}, + {0x900d7, 0x10}, + {0x900d8, 0x8558}, + {0x900d9, 0x168}, + {0x900da, 0x1ff8}, + {0x900db, 0x85a8}, + {0x900dc, 0x1e8}, + {0x900dd, 0x50}, + {0x900de, 0x798}, + {0x900df, 0x16a}, + {0x900e0, 0x60}, + {0x900e1, 0x7a0}, + {0x900e2, 0x16a}, + {0x900e3, 0x8}, + {0x900e4, 0x8310}, + {0x900e5, 0x168}, + {0x900e6, 0x8}, + {0x900e7, 0xa310}, + {0x900e8, 0x168}, + {0x900e9, 0xa}, + {0x900ea, 0x408}, + {0x900eb, 0x169}, + {0x900ec, 0x6e}, + {0x900ed, 0x0}, + {0x900ee, 0x68}, + {0x900ef, 0x0}, + {0x900f0, 0x408}, + {0x900f1, 0x169}, + {0x900f2, 0x0}, + {0x900f3, 0x8310}, + {0x900f4, 0x168}, + {0x900f5, 0x0}, + {0x900f6, 0xa310}, + {0x900f7, 0x168}, + {0x900f8, 0x1ff8}, + {0x900f9, 0x85a8}, + {0x900fa, 0x1e8}, + {0x900fb, 0x68}, + {0x900fc, 0x798}, + {0x900fd, 0x16a}, + {0x900fe, 0x78}, + {0x900ff, 0x7a0}, + {0x90100, 0x16a}, + {0x90101, 0x68}, + {0x90102, 0x790}, + {0x90103, 0x16a}, + {0x90104, 0x8}, + {0x90105, 0x8b10}, + {0x90106, 0x168}, + {0x90107, 0x8}, + {0x90108, 0xab10}, + {0x90109, 0x168}, + {0x9010a, 0xa}, + {0x9010b, 0x408}, + {0x9010c, 0x169}, + {0x9010d, 0x58}, + {0x9010e, 0x0}, + {0x9010f, 0x68}, + {0x90110, 0x0}, + {0x90111, 0x408}, + {0x90112, 0x169}, + {0x90113, 0x0}, + {0x90114, 0x8b10}, + {0x90115, 0x168}, + {0x90116, 0x1}, + {0x90117, 0xab10}, + {0x90118, 0x168}, + {0x90119, 0x0}, + {0x9011a, 0x1d8}, + {0x9011b, 0x169}, + {0x9011c, 0x80}, + {0x9011d, 0x790}, + {0x9011e, 0x16a}, + {0x9011f, 0x18}, + {0x90120, 0x7aa}, + {0x90121, 0x6a}, + {0x90122, 0xa}, + {0x90123, 0x0}, + {0x90124, 0x1e9}, + {0x90125, 0x8}, + {0x90126, 0x8080}, + {0x90127, 0x108}, + {0x90128, 0xf}, + {0x90129, 0x408}, + {0x9012a, 0x169}, + {0x9012b, 0xc}, + {0x9012c, 0x0}, + {0x9012d, 0x68}, + {0x9012e, 0x9}, + {0x9012f, 0x0}, + {0x90130, 0x1a9}, + {0x90131, 0x0}, + {0x90132, 0x408}, + {0x90133, 0x169}, + {0x90134, 0x0}, + {0x90135, 0x8080}, + {0x90136, 0x108}, + {0x90137, 0x8}, + {0x90138, 0x7aa}, + {0x90139, 0x6a}, + {0x9013a, 0x0}, + {0x9013b, 0x8568}, + {0x9013c, 0x108}, + {0x9013d, 0xb7}, + {0x9013e, 0x790}, + {0x9013f, 0x16a}, + {0x90140, 0x1f}, + {0x90141, 0x0}, + {0x90142, 0x68}, + {0x90143, 0x8}, + {0x90144, 0x8558}, + {0x90145, 0x168}, + {0x90146, 0xf}, + {0x90147, 0x408}, + {0x90148, 0x169}, + {0x90149, 0xd}, + {0x9014a, 0x0}, + {0x9014b, 0x68}, + {0x9014c, 0x0}, + {0x9014d, 0x408}, + {0x9014e, 0x169}, + {0x9014f, 0x0}, + {0x90150, 0x8558}, + {0x90151, 0x168}, + {0x90152, 0x8}, + {0x90153, 0x3c8}, + {0x90154, 0x1a9}, + {0x90155, 0x3}, + {0x90156, 0x370}, + {0x90157, 0x129}, + {0x90158, 0x20}, + {0x90159, 0x2aa}, + {0x9015a, 0x9}, + {0x9015b, 0x8}, + {0x9015c, 0xe8}, + {0x9015d, 0x109}, + {0x9015e, 0x0}, + {0x9015f, 0x8140}, + {0x90160, 0x10c}, + {0x90161, 0x10}, + {0x90162, 0x8138}, + {0x90163, 0x104}, + {0x90164, 0x8}, + {0x90165, 0x448}, + {0x90166, 0x109}, + {0x90167, 0xf}, + {0x90168, 0x7c0}, + {0x90169, 0x109}, + {0x9016a, 0x0}, + {0x9016b, 0xe8}, + {0x9016c, 0x109}, + {0x9016d, 0x47}, + {0x9016e, 0x630}, + {0x9016f, 0x109}, + {0x90170, 0x8}, + {0x90171, 0x618}, + {0x90172, 0x109}, + {0x90173, 0x8}, + {0x90174, 0xe0}, + {0x90175, 0x109}, + {0x90176, 0x0}, + {0x90177, 0x7c8}, + {0x90178, 0x109}, + {0x90179, 0x8}, + {0x9017a, 0x8140}, + {0x9017b, 0x10c}, + {0x9017c, 0x0}, + {0x9017d, 0x478}, + {0x9017e, 0x109}, + {0x9017f, 0x0}, + {0x90180, 0x1}, + {0x90181, 0x8}, + {0x90182, 0x8}, + {0x90183, 0x4}, + {0x90184, 0x0}, + {0x90006, 0x8}, + {0x90007, 0x7c8}, + {0x90008, 0x109}, + {0x90009, 0x0}, + {0x9000a, 0x400}, + {0x9000b, 0x106}, + {0xd00e7, 0x400}, + {0x90017, 0x0}, + {0x9001f, 0x2b}, + {0x90026, 0x69}, + {0x400d0, 0x0}, + {0x400d1, 0x101}, + {0x400d2, 0x105}, + {0x400d3, 0x107}, + {0x400d4, 0x10f}, + {0x400d5, 0x202}, + {0x400d6, 0x20a}, + {0x400d7, 0x20b}, + {0x2003a, 0x2}, + {0x200be, 0x3}, + {0x2000b, 0x75}, + {0x2000c, 0xe9}, + {0x2000d, 0x91c}, + {0x2000e, 0x2c}, + {0x9000c, 0x0}, + {0x9000d, 0x173}, + {0x9000e, 0x60}, + {0x9000f, 0x6110}, + {0x90010, 0x2152}, + {0x90011, 0xdfbd}, + {0x90012, 0x2060}, + {0x90013, 0x6152}, + {0x20010, 0x5a}, + {0x20011, 0x3}, + {0x40080, 0xe0}, + {0x40081, 0x12}, + {0x40082, 0xe0}, + {0x40083, 0x12}, + {0x40084, 0xe0}, + {0x40085, 0x12}, + {0x400fd, 0xf}, + {0x400f1, 0xe}, + {0x10011, 0x1}, + {0x10012, 0x1}, + {0x10013, 0x180}, + {0x10018, 0x1}, + {0x10002, 0x6209}, + {0x100b2, 0x1}, + {0x101b4, 0x1}, + {0x102b4, 0x1}, + {0x103b4, 0x1}, + {0x104b4, 0x1}, + {0x105b4, 0x1}, + {0x106b4, 0x1}, + {0x107b4, 0x1}, + {0x108b4, 0x1}, + {0x11011, 0x1}, + {0x11012, 0x1}, + {0x11013, 0x180}, + {0x11018, 0x1}, + {0x11002, 0x6209}, + {0x110b2, 0x1}, + {0x111b4, 0x1}, + {0x112b4, 0x1}, + {0x113b4, 0x1}, + {0x114b4, 0x1}, + {0x115b4, 0x1}, + {0x116b4, 0x1}, + {0x117b4, 0x1}, + {0x118b4, 0x1}, + {0x20089, 0x1}, + {0x20088, 0x19}, + {0xc0080, 0x0}, + {0xd0000, 0x1}, + +}; + +static struct dram_fsp_msg ddr_dram_fsp_msg[] = { + { + /* P0 3733mts 1D */ + .drate = 3733, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp0_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp0_cfg), + + }, + + { + /* P0 3733mts 2D */ + .drate = 3733, + .fw_type = FW_2D_IMAGE, + .fsp_cfg = ddr_fsp0_2d_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp0_2d_cfg), + }, + +}; + +/* ddr timing config params */ +struct dram_timing_info dram_timing = { + .ddrc_cfg = ddr_ddrc_cfg, + .ddrc_cfg_num = ARRAY_SIZE(ddr_ddrc_cfg), + .ddrphy_cfg = ddr_ddrphy_cfg, + .ddrphy_cfg_num = ARRAY_SIZE(ddr_ddrphy_cfg), + .fsp_msg = ddr_dram_fsp_msg, + .fsp_msg_num = ARRAY_SIZE(ddr_dram_fsp_msg), + .ddrphy_trained_csr = ddr_ddrphy_trained_csr, + .ddrphy_trained_csr_num = ARRAY_SIZE(ddr_ddrphy_trained_csr), + .ddrphy_pie = ddr_phy_pie, + .ddrphy_pie_num = ARRAY_SIZE(ddr_phy_pie), + .fsp_table = { 3733, }, + .fsp_cfg = ddr_dram_fsp_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_dram_fsp_cfg), +}; diff --git a/board/phytec/phycore_imx93/phycore-imx93.c b/board/phytec/phycore_imx93/phycore-imx93.c new file mode 100644 index 00000000000..085c8e195a6 --- /dev/null +++ b/board/phytec/phycore_imx93/phycore-imx93.c @@ -0,0 +1,42 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (C) 2023 PHYTEC Messtechnik GmbH + * Author: Christoph Stoidner c.stoidner@phytec.de + * Copyright (C) 2024 Mathieu Othacehe m.othacehe@gmail.com + */ + +#include <asm/arch-imx9/ccm_regs.h> +#include <asm/arch/sys_proto.h> +#include <asm/arch-imx9/imx93_pins.h> +#include <asm/arch/clock.h> +#include <asm/global_data.h> +#include <asm/mach-imx/boot_mode.h> +#include <env.h> + +DECLARE_GLOBAL_DATA_PTR; + +int board_init(void) +{ + return 0; +} + +int board_mmc_get_env_dev(int devno) +{ + return devno; +} + +int board_late_init(void) +{ + switch (get_boot_device()) { + case SD2_BOOT: + env_set_ulong("mmcdev", 1); + break; + case MMC1_BOOT: + env_set_ulong("mmcdev", 0); + break; + default: + break; + } + + return 0; +} diff --git a/board/phytec/phycore_imx93/phycore_imx93.env b/board/phytec/phycore_imx93/phycore_imx93.env new file mode 100644 index 00000000000..464935ba567 --- /dev/null +++ b/board/phytec/phycore_imx93/phycore_imx93.env @@ -0,0 +1,85 @@ +/* SPDX-License-Identifier: (GPL-2.0+ OR MIT) */ + +image=Image +console=ttyLP0 +fdt_addr=0x83000000 +fdto_addr=0x830c0000 +bootenv_addr=0x83500000 +fdt_file=undefined +ipaddr=192.168.3.11 +serverip=192.168.3.10 +netmask=255.255.255.0 +ip_dyn=no +bootenv=bootenv.txt +prepare_mcore=setenv mcore_clk clk-imx93.mcore_booted; +mmc_load_bootenv=fatload mmc ${mmcdev}:${mmcpart} ${bootenv_addr} ${bootenv} +sd_dev=1 +emmc_dev=0 +mmcdev=1 +mmcpart=1 +mmcroot=2 +mmcautodetect=yes +mmcargs=setenv bootargs ${mcore_clk} console=${console},${baudrate} earlycon + root=/dev/mmcblk${mmcdev}p${mmcroot} ${raucargs} rootwait rw +loadimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${image} +findfdt=if test $fdt_file = undefined; then + setenv fdt_file CONFIG_DEFAULT_FDT_FILE ; + fi; + echo fdt_file=${fdt_file}; +loadfdt=run findfdt;fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_file} +mmc_load_overlay=fatload mmc ${mmcdev}:${mmcpart} ${fdto_addr} ${overlay} +mmc_apply_overlays= + fdt address ${fdt_addr}; + for overlay in ${overlays}; + do; + if run mmc_load_overlay; then + fdt resize ${filesize}; + fdt apply ${fdto_addr}; + fi; + done; +mmcboot= + echo Booting from mmc ...; + if run mmc_load_bootenv; then + env import -t ${bootenv_addr} ${filesize}; + fi; + run mmcargs; + if run loadfdt; then + run mmc_apply_overlays; + booti ${loadaddr} - ${fdt_addr}; + else + echo WARN: Cannot load the DT; + fi; +nfsroot=/nfs +netargs=setenv bootargs ${mcore_clk} console=${console},${baudrate} earlycon + root=/dev/nfs ip=${nfsip} nfsroot=${serverip}:${nfsroot},v3,tcp +net_load_bootenv=${get_cmd} ${bootenv_addr} ${bootenv} +net_load_overlay=${get_cmd} ${fdto_addr} ${overlay} +net_apply_overlays= + fdt address ${fdt_addr}; + for overlay in ${overlays}; + do; + if run net_load_overlay; then + fdt resize ${filesize}; + fdt apply ${fdto_addr}; + fi; + done; +netboot= + echo Booting from net ...; + if test ${ip_dyn} = yes; then + setenv nfsip dhcp; + setenv get_cmd dhcp; + else + setenv nfsip ${ipaddr}:${serverip}::${netmask}::eth0:on; + setenv get_cmd tftp; + fi; + if run net_load_bootenv; then + env import -t ${bootenv_addr} ${filesize}; + fi; + run netargs; + ${get_cmd} ${loadaddr} ${image}; + if ${get_cmd} ${fdt_addr} ${fdt_file}; then + run net_apply_overlays; + booti ${loadaddr} - ${fdt_addr}; + else + echo WARN: Cannot load the DT; + fi; diff --git a/board/phytec/phycore_imx93/spl.c b/board/phytec/phycore_imx93/spl.c new file mode 100644 index 00000000000..efdcd60ef5f --- /dev/null +++ b/board/phytec/phycore_imx93/spl.c @@ -0,0 +1,150 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (C) 2023 PHYTEC Messtechnik GmbH + * Author: Christoph Stoidner c.stoidner@phytec.de + * Copyright (C) 2024 Mathieu Othacehe m.othacehe@gmail.com + */ + +#include <asm/arch/clock.h> +#include <asm/arch/ddr.h> +#include <asm/arch/sys_proto.h> +#include <asm/arch/trdc.h> +#include <asm/mach-imx/boot_mode.h> +#include <asm/sections.h> +#include <hang.h> +#include <init.h> +#include <log.h> +#include <power/pmic.h> +#include <power/pca9450.h> +#include <spl.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* + * Will be part of drivers/power/regulator/pca9450.c + * when pca9451a support is added. + */ +#define PCA9450_REG_PWRCTRL_TOFF_DEB BIT(5) + +#define EEPROM_ADDR 0x50 + +int spl_board_boot_device(enum boot_device boot_dev_spl) +{ + return BOOT_DEVICE_BOOTROM; +} + +void spl_board_init(void) +{ + puts("Normal Boot\n"); +} + +void spl_dram_init(void) +{ + ddr_init(&dram_timing); +} + +int power_init_board(void) +{ + struct udevice *dev; + int ret; + unsigned int val = 0; + + ret = pmic_get("pmic@25", &dev); + if (ret == -ENODEV) { + puts("No pca9450@25\n"); + return 0; + } + + if (ret != 0) + return ret; + + /* BUCKxOUT_DVS0/1 control BUCK123 output */ + pmic_reg_write(dev, PCA9450_BUCK123_DVS, 0x29); + + /* enable DVS control through PMIC_STBY_REQ */ + pmic_reg_write(dev, PCA9450_BUCK1CTRL, 0x59); + + ret = pmic_reg_read(dev, PCA9450_PWR_CTRL); + if (ret < 0) + return ret; + val = ret; + + if (IS_ENABLED(CONFIG_IMX9_LOW_DRIVE_MODE)) { + /* 0.8v for Low drive mode */ + if (val & PCA9450_REG_PWRCTRL_TOFF_DEB) { + pmic_reg_write(dev, PCA9450_BUCK1OUT_DVS0, 0x0c); + pmic_reg_write(dev, PCA9450_BUCK3OUT_DVS0, 0x0c); + } else { + pmic_reg_write(dev, PCA9450_BUCK1OUT_DVS0, 0x10); + pmic_reg_write(dev, PCA9450_BUCK3OUT_DVS0, 0x10); + } + } else { + /* 0.9v for Over drive mode */ + if (val & PCA9450_REG_PWRCTRL_TOFF_DEB) { + pmic_reg_write(dev, PCA9450_BUCK1OUT_DVS0, 0x14); + pmic_reg_write(dev, PCA9450_BUCK3OUT_DVS0, 0x14); + } else { + pmic_reg_write(dev, PCA9450_BUCK1OUT_DVS0, 0x18); + pmic_reg_write(dev, PCA9450_BUCK3OUT_DVS0, 0x18); + } + } + + /* set standby voltage to 0.65v */ + if (val & PCA9450_REG_PWRCTRL_TOFF_DEB) + pmic_reg_write(dev, PCA9450_BUCK1OUT_DVS1, 0x0); + else + pmic_reg_write(dev, PCA9450_BUCK1OUT_DVS1, 0x4); + + /* I2C_LT_EN*/ + pmic_reg_write(dev, 0xa, 0x3); + + return 0; +} + +extern int imx9_probe_mu(void *ctx, struct event *event); +void board_init_f(ulong dummy) +{ + int ret; + + /* Clear the BSS. */ + memset(__bss_start, 0, __bss_end - __bss_start); + + timer_init(); + + arch_cpu_init(); + + spl_early_init(); + + preloader_console_init(); + + ret = imx9_probe_mu(NULL, NULL); + if (ret) { + printf("Fail to init ELE API\n"); + } else { + printf("SOC: 0x%x\n", gd->arch.soc_rev); + printf("LC: 0x%x\n", gd->arch.lifecycle); + } + + clock_init(); + + power_init_board(); + + if (!IS_ENABLED(CONFIG_IMX9_LOW_DRIVE_MODE)) + set_arm_core_max_clk(); + + /* Init power of mix */ + soc_power_init(); + + /* Setup TRDC for DDR access */ + trdc_init(); + + /* DDR initialization */ + spl_dram_init(); + + /* Put M33 into CPUWAIT for following kick */ + ret = m33_prepare(); + if (!ret) + printf("M33 prepare ok\n"); + + board_init_r(NULL, 0); +} diff --git a/configs/imx93-phyboard-segin_defconfig b/configs/imx93-phyboard-segin_defconfig new file mode 100644 index 00000000000..228f0aed61f --- /dev/null +++ b/configs/imx93-phyboard-segin_defconfig @@ -0,0 +1,149 @@ +CONFIG_ARM=y +CONFIG_ARCH_IMX9=y +CONFIG_TEXT_BASE=0x80200000 +CONFIG_SYS_MALLOC_LEN=0x2000000 +CONFIG_SYS_MALLOC_F_LEN=0x20000 +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_NR_DRAM_BANKS=2 +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_OFFSET=0x700000 +CONFIG_IMX_CONFIG="arch/arm/mach-imx/imx9/imximage.cfg" +CONFIG_DM_GPIO=y +CONFIG_DEFAULT_DEVICE_TREE="imx93-phyboard-segin" +CONFIG_SPL_TEXT_BASE=0x2049A000 +CONFIG_TARGET_PHYCORE_IMX93=y +CONFIG_PHYTEC_SOM_DETECTION=y +CONFIG_SYS_PROMPT="u-boot=> " +CONFIG_SPL_SERIAL=y +CONFIG_SPL_DRIVERS_MISC=y +CONFIG_SPL_STACK=0x20519dd0 +CONFIG_SPL=y +CONFIG_ENV_OFFSET_REDUND=0x720000 +CONFIG_CMD_DEKBLOB=y +CONFIG_SPL_IMX_ROMAPI_LOADADDR=0x88000000 +CONFIG_SPL_LOAD_IMX_CONTAINER=y +CONFIG_SYS_LOAD_ADDR=0x80400000 +CONFIG_SYS_MEMTEST_START=0x80000000 +CONFIG_SYS_MEMTEST_END=0x90000000 +CONFIG_REMAKE_ELF=y +CONFIG_SYS_MONITOR_LEN=524288 +# CONFIG_ANDROID_BOOT_IMAGE is not set +CONFIG_OF_SYSTEM_SETUP=y +CONFIG_DISTRO_DEFAULTS=y +CONFIG_BOOTCOMMAND="mmc dev ${mmcdev}; if mmc rescan; then if run loadimage; then run mmcboot; else run netboot; fi; fi;" +CONFIG_DEFAULT_FDT_FILE="oftree" +CONFIG_BOARD_LATE_INIT=y +CONFIG_SPL_MAX_SIZE=0x26000 +CONFIG_SPL_HAS_BSS_LINKER_SECTION=y +CONFIG_SPL_BSS_START_ADDR=0x2051a000 +CONFIG_SPL_BSS_MAX_SIZE=0x2000 +CONFIG_SPL_BOARD_INIT=y +CONFIG_SPL_BOOTROM_SUPPORT=y +CONFIG_IMX_CONTAINER_CFG="arch/arm/mach-imx/imx9/container.cfg" +# CONFIG_SPL_SHARES_INIT_SP_ADDR is not set +CONFIG_SYS_SPL_MALLOC=y +CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y +CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x83200000 +CONFIG_SYS_SPL_MALLOC_SIZE=0x80000 +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x1040 +CONFIG_SPL_I2C=y +CONFIG_SPL_POWER=y +CONFIG_SPL_WATCHDOG=y +CONFIG_SYS_MAXARGS=64 +CONFIG_SYS_CBSIZE=2048 +CONFIG_SYS_PBSIZE=2074 +CONFIG_CMD_ERASEENV=y +CONFIG_CMD_NVEDIT_EFI=y +CONFIG_CRC32_VERIFY=y +CONFIG_CMD_EEPROM=y +CONFIG_SYS_I2C_EEPROM_BUS=2 +CONFIG_SYS_I2C_EEPROM_ADDR_LEN=2 +CONFIG_SYS_EEPROM_SIZE=4096 +CONFIG_SYS_EEPROM_PAGE_WRITE_BITS=5 +CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS=5 +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_CLK=y +CONFIG_CMD_DFU=y +CONFIG_CMD_FUSE=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_POWEROFF=y +CONFIG_CMD_SNTP=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EFIDEBUG=y +CONFIG_CMD_RTC=y +CONFIG_CMD_TIME=y +CONFIG_CMD_GETTIME=y +CONFIG_CMD_TIMER=y +CONFIG_CMD_REGULATOR=y +CONFIG_CMD_HASH=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_ENV_SOURCE_FILE="phycore_imx93" +CONFIG_ENV_OVERWRITE=y +CONFIG_ENV_IS_NOWHERE=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_SYS_MMC_ENV_DEV=1 +CONFIG_USE_ETHPRIME=y +CONFIG_ETHPRIME="eth1" +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_SPL_DM=y +CONFIG_SYSCON=y +CONFIG_SPL_CLK_IMX93=y +CONFIG_CLK_IMX93=y +CONFIG_DFU_MMC=y +CONFIG_DFU_RAM=y +CONFIG_GPIO_HOG=y +CONFIG_IMX_RGPIO2P=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_IMX_LPI2C=y +CONFIG_I2C_EEPROM=y +CONFIG_SYS_I2C_EEPROM_ADDR=0x50 +CONFIG_SUPPORT_EMMC_BOOT=y +CONFIG_MMC_IO_VOLTAGE=y +CONFIG_MMC_UHS_SUPPORT=y +CONFIG_MMC_HS400_ES_SUPPORT=y +CONFIG_MMC_HS400_SUPPORT=y +CONFIG_FSL_USDHC=y +CONFIG_SF_DEFAULT_SPEED=40000000 +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_PHY_TI_GENERIC=y +CONFIG_DM_ETH_PHY=y +CONFIG_DWC_ETH_QOS=y +CONFIG_DWC_ETH_QOS_IMX=y +CONFIG_FEC_MXC=y +CONFIG_MII=y +CONFIG_PINCTRL=y +CONFIG_SPL_PINCTRL=y +CONFIG_PINCTRL_IMX93=y +CONFIG_POWER_DOMAIN=y +CONFIG_IMX93_BLK_CTRL=y +CONFIG_DM_PMIC=y +CONFIG_DM_PMIC_PCA9450=y +CONFIG_SPL_DM_PMIC_PCA9450=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_PCA9450=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_DM_RTC=y +CONFIG_DM_SERIAL=y +CONFIG_FSL_LPUART=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_NXP_FSPI=y +CONFIG_SYSRESET=y +CONFIG_SPL_SYSRESET=y +CONFIG_SYSRESET_WATCHDOG=y +CONFIG_DM_THERMAL=y +CONFIG_IMX_TMU=y +CONFIG_ULP_WATCHDOG=y +CONFIG_WDT=y +CONFIG_LZO=y +CONFIG_BZIP2=y +CONFIG_OF_LIBFDT_OVERLAY=y diff --git a/doc/board/phytec/imx93-phyboard-segin.rst b/doc/board/phytec/imx93-phyboard-segin.rst new file mode 100644 index 00000000000..da8772ecd5c --- /dev/null +++ b/doc/board/phytec/imx93-phyboard-segin.rst @@ -0,0 +1,61 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +phyBOARD-Segin-i.MX93 +===================== + +U-Boot for the phyBOARD-Segin-i.MX93. + +Quick Start +----------- + +- Get and Build the ARM Trusted firmware +- Get the DDR firmware +- Get ahab-container.img +- Build U-Boot + +Get and Build the ARM Trusted firmware +-------------------------------------- + +Note: srctree is U-Boot source directory +Get ATF from: https://github.com/nxp-imx/imx-atf/ +branch: lf_v2.8 + +.. code-block:: bash + + $ unset LDFLAGS + $ make PLAT=imx93 bl31 + $ cp build/imx93/release/bl31.bin $(srctree) + +Get the DDR firmware +-------------------- + +.. code-block:: bash + + $ wget https://www.nxp.com/lgfiles/NMG/MAD/YOCTO/firmware-imx-8.21.bin + $ chmod +x firmware-imx-8.21.bin + $ ./firmware-imx-8.21.bin + $ cp firmware-imx-8.21/firmware/ddr/synopsys/lpddr4*.bin $(srctree) + +Get ahab-container.img +--------------------------------------- + +.. code-block:: bash + + $ wget https://www.nxp.com/lgfiles/NMG/MAD/YOCTO/firmware-sentinel-0.10.bin + $ chmod +x firmware-sentinel-0.10.bin + $ ./firmware-sentinel-0.10.bin + $ cp firmware-sentinel-0.10/mx93a0-ahab-container.img $(srctree) + +Build U-Boot +------------ + +.. code-block:: bash + + $ make imx93-phyboard-segin_defconfig + $ make + +Burn the flash.bin to MicroSD card offset 32KB: + +.. code-block:: bash + + $ dd if=flash.bin of=/dev/sd[x] bs=1024 seek=32 conv=notrunc diff --git a/doc/board/phytec/index.rst b/doc/board/phytec/index.rst index 9996bce9741..b2833db684f 100644 --- a/doc/board/phytec/index.rst +++ b/doc/board/phytec/index.rst @@ -7,5 +7,6 @@ PHYTEC :maxdepth: 2
imx8mm-phygate-tauri-l + imx93-phyboard-segin phycore-imx8mm phycore-imx8mp diff --git a/include/configs/phycore_imx93.h b/include/configs/phycore_imx93.h new file mode 100644 index 00000000000..07364dff403 --- /dev/null +++ b/include/configs/phycore_imx93.h @@ -0,0 +1,28 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2022 NXP + * Copyright (C) 2023 PHYTEC Messtechnik GmbH + * Christoph Stoidner c.stoidner@phytec.de + * Copyright (C) 2024 Mathieu Othacehe m.othacehe@gmail.com + */ + +#ifndef __PHYCORE_IMX93_H +#define __PHYCORE_IMX93_H + +#include <linux/sizes.h> +#include <asm/arch/imx-regs.h> + +#define CFG_SYS_UBOOT_BASE \ + (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512) + +#define CFG_SYS_INIT_RAM_ADDR 0x80000000 +#define CFG_SYS_INIT_RAM_SIZE 0x200000 + +#define CFG_SYS_SDRAM_BASE 0x80000000 +#define PHYS_SDRAM 0x80000000 +#define PHYS_SDRAM_SIZE 0x80000000 + +/* Using ULP WDOG for reset */ +#define WDOG_BASE_ADDR WDG3_BASE_ADDR + +#endif /* __PHYCORE_IMX93_H */
Please remove these hardcoded IP addresses.
Hi Mathieu,
thanks for fixing my remarks.
Here are just a few left for v4.
Supported features:
- 1GB LPDDR4 RAM
- eMMC
- external SD
- debug UART
- watchdog
Hello,
Thanks,
Mathieu
- imx93-var-som-symphony.dtb \
- imx93-phyboard-segin.dtb
- Copyright (C) 2023 PHYTEC Messtechnik GmbH
- Christoph Stoidner c.stoidner@phytec.de
- Product homepage:
- phyBOARD-Segin carrier board is reused for the i.MX93 design.
- wdt-reboot {
wdt = <&wdog3>;
bootph-pre-ram;
bootph-some-ram;
- aliases {
ethernet0 = &eqos;
ethernet1 = &fec;
Please make "fec" the primary eth interface here, like so:
aliases { ethernet0 = &fec; ethernet1 = &eqos; };
Reason: FEC's phy is on the SoM while EQOS' phy is on the base-board. To reuse phycore-imx93 code between multiple base-boards PHYTEC prefers to make the SoM's eth interface the primary one.
- firmware {
optee {
method = "smc";
+&{/soc@0} {
- bootph-all;
- bootph-pre-ram;
+&aips1 {
- bootph-pre-ram;
- bootph-all;
+&aips2 {
- bootph-pre-ram;
- bootph-some-ram;
+&aips3 {
- bootph-pre-ram;
- bootph-some-ram;
+&iomuxc {
- bootph-pre-ram;
- bootph-some-ram;
+®_usdhc2_vmmc {
- u-boot,off-on-delay-us = <20000>;
- bootph-pre-ram;
- bootph-some-ram;
- bootph-pre-ram;
+&pinctrl_uart1 {
- bootph-pre-ram;
- bootph-some-ram;
+&pinctrl_usdhc1 {
- bootph-pre-ram;
- bootph-some-ram;
- bootph-pre-ram;
- bootph-some-ram;
- bootph-pre-ram;
- bootph-some-ram;
- bootph-pre-ram;
- bootph-some-ram;
- bootph-pre-ram;
- bootph-some-ram;
+&gpio1 {
- bootph-pre-ram;
- bootph-some-ram;
+&gpio2 {
- bootph-pre-ram;
- bootph-some-ram;
+&gpio3 {
- bootph-pre-ram;
- bootph-some-ram;
+&gpio4 {
- bootph-pre-ram;
- bootph-some-ram;
+&lpuart1 {
- bootph-pre-ram;
- bootph-some-ram;
+&usdhc1 {
- bootph-pre-ram;
- bootph-some-ram;
+&usdhc2 {
- bootph-pre-ram;
- bootph-some-ram;
- fsl,signal-voltage-switch-extra-delay-ms = <8>;
+&lpi2c1 {
- bootph-pre-ram;
- bootph-some-ram;
+&lpi2c2 {
- bootph-pre-ram;
- bootph-some-ram;
+&lpi2c3 {
- bootph-pre-ram;
- bootph-some-ram;
+&s4muap {
- bootph-pre-ram;
- bootph-some-ram;
- status = "okay";
+&clk {
- bootph-all;
- bootph-pre-ram;
- /delete-property/ assigned-clocks;
- /delete-property/ assigned-clock-rates;
- /delete-property/ assigned-clock-parents;
+&osc_32k {
- bootph-all;
- bootph-pre-ram;
+&osc_24m {
- bootph-all;
- bootph-pre-ram;
+&clk_ext1 {
- bootph-all;
- bootph-pre-ram;
+&wdog3 {
- bootph-all;
- bootph-pre-ram;
- The two nodes below won't be needed once nxp,pca9451a
- support is added to the Linux kernel.
+&iomuxc {
- pinctrl_lpi2c3: lpi2c3grp {
- bootph-pre-ram;
- fsl,pins = <
- pinctrl_pmic: pmicgrp {
- bootph-pre-ram;
fsl,pins = <
+&lpi2c3 {
- bootph-pre-ram;
- bootph-some-ram;
- clock-frequency = <400000>;
- pinctrl-names = "default", "sleep";
- pinctrl-0 = <&pinctrl_lpi2c3>;
- pinctrl-1 = <&pinctrl_lpi2c3>;
- status = "okay";
- pmic@25 {
bootph-pre-ram;
bootph-some-ram;
reg = <0x25>;
regulators {
bootph-pre-ram;
bootph-some-ram;
buck1: BUCK1 {
regulator-boot-on;
buck2: BUCK2 {
regulator-boot-on;
buck4: BUCK4 {
regulator-boot-on;
buck5: BUCK5 {
regulator-boot-on;
buck6: BUCK6 {
regulator-boot-on;
ldo1: LDO1 {
regulator-boot-on;
ldo4: LDO4 {
regulator-boot-on;
ldo5: LDO5 {
regulator-boot-on;
- Author: Wadim Egorov w.egorov@phytec.de, Christoph Stoidner c.stoidner@phytec.de
- Copyright (C) 2024 Mathieu Othacehe m.othacehe@gmail.com
- Product homepage:
+/dts-v1/;
- model = "PHYTEC phyBOARD-Segin-i.MX93";
- compatible = "phytec,imx93-phyboard-segin", "phytec,imx93-phycore-som",
"fsl,imx93";
- chosen {
- reg_usdhc2_vmmc: regulator-usdhc2 {
enable-active-high;
- pinctrl-names = "default";
- pinctrl-0 = <&pinctrl_uart1>;
- status = "okay";
- no-1-8-v;
- pinctrl-names = "default", "state_100mhz", "state_200mhz";
- pinctrl-0 = <&pinctrl_usdhc2_default>, <&pinctrl_usdhc2_cd>;
- pinctrl-1 = <&pinctrl_usdhc2_100mhz>, <&pinctrl_usdhc2_cd>;
- pinctrl-2 = <&pinctrl_usdhc2_200mhz>, <&pinctrl_usdhc2_cd>;
- bus-width = <4>;
- cd-gpios = <&gpio3 0 GPIO_ACTIVE_LOW>;
- no-mmc;
- no-sdio;
- vmmc-supply = <®_usdhc2_vmmc>;
- status = "okay";
+&iomuxc {
- pinctrl_uart1: uart1grp {
fsl,pins = <
- pinctrl_reg_usdhc2_vmmc: regusdhc2vmmcgrp {
fsl,pins = <
- pinctrl_usdhc2_cd: usdhc2cdgrp {
fsl,pins = <
- pinctrl_usdhc2_default: usdhc2grp {
fsl,pins = <
- pinctrl_usdhc2_100mhz: usdhc2grp {
fsl,pins = <
- pinctrl_usdhc2_200mhz: usdhc2grp {
fsl,pins = <
- Product homepage:
- model = "PHYTEC phyCORE-i.MX93";
- compatible = "phytec,imx93-phycore-som", "fsl,imx93";
- reserved-memory {
ranges;
#size-cells = <2>;
linux,cma {
reusable;
linux,cma-default;
- leds {
led-0 {
- pinctrl-0 = <&pinctrl_fec>;
- phy-mode = "rmii";
- phy-handle = <ðphy1>;
- fsl,magic-packet;
- assigned-clocks = <&clk IMX93_CLK_ENET_TIMER1>,
- assigned-clock-parents = <&clk IMX93_CLK_SYS_PLL_PFD1_DIV2>,
- assigned-clock-rates = <100000000>, <50000000>, <50000000>;
- status = "okay";
- mdio: mdio {
#size-cells = <0>;
reg = <1>;
- pinctrl-0 = <&pinctrl_usdhc1>;
- bus-width = <8>;
- non-removable;
- status = "okay";
- status = "okay";
+&iomuxc {
- pinctrl_fec: fecgrp {
fsl,pins = <
- pinctrl_leds: ledsgrp {
fsl,pins = <
- pinctrl_usdhc1: usdhc1grp {
fsl,pins = <
- bool "phycore_imx93"
- select IMX93
- select IMX9_LPDDR4X
endchoice
+config SYS_BOARD
- default "phycore_imx93"
+config SYS_VENDOR
- default "phytec"
- Copyright 2023 NXP
- Code generated with DDR Tool v1.0.0.
- /** Initialize DDRC registers **/
- {0x4e300110, 0x44100001},
- {0x4e300000, 0x8000bf},
- {0x4e300008, 0x0},
<snip>
- .fsp_cfg_num = ARRAY_SIZE(ddr_dram_fsp_cfg),
- Author: Christoph Stoidner c.stoidner@phytec.de
- return devno;
- switch (get_boot_device()) {
- case SD2_BOOT:
break;
- case MMC1_BOOT:
break;
- default:
break;
Can you set fdt_file to CONFIG_DEFAULT_FDT_FILE like it was in v2?
I saw Fabio's request to remove static IP configuration.
When you remove it, please
+ip_dyn=no
set ip_dyn=yes.
Please remove prepare_mcore. This only applies to vendor u-boot-imx.
Please remove sd_dev and emmc_dev. They were not in the v2 and only apply to vendor u-boot (uuu).
+mmcdev=1
Please set:
mmcdev=__stringify(CONFIG_SYS_MMC_ENV_DEV)
like in v2.
- root=/dev/mmcblk${mmcdev}p${mmcroot} ${raucargs} rootwait rw
Drop mcore_clk from mmcargs like in v2.
fi;
Please remove findfdt script.
Not needed when you set fdt_file to CONFIG_DEFAULT_FDT_FILE above.
Remove findfdt from loadfdt.
- fdt address ${fdt_addr};
- for overlay in ${overlays};
- do;
fi;
- done;
+mmcboot=
- echo Booting from mmc ...;
- if run mmc_load_bootenv; then
- fi;
- run mmcargs;
- if run loadfdt; then
- else
- fi;
- root=/dev/nfs ip=${nfsip} nfsroot=${serverip}:${nfsroot},v3,tcp
Drop mcore_clk from netargs.
Also hardcode ip=dhcp since you cannot use static IP anymore in v4.
- do;
fi;
- done;
+netboot=
- echo Booting from net ...;
- if test ${ip_dyn} = yes; then
setenv nfsip dhcp;
- else
- fi;
- if run net_load_bootenv; then
- fi;
- run netargs;
- ${get_cmd} ${loadaddr} ${image};
- if ${get_cmd} ${fdt_addr} ${fdt_file}; then
- else
- fi;
netboot script needs to be re-written when you remove static IP configuration in v4.
Please make it something like this:
netboot= echo Booting from net ...; run netargs; if test ${ip_dyn} = yes; then setenv get_cmd dhcp; else setenv get_cmd tftp; fi; if run net_load_bootenv; then env import -t ${bootenv_addr} ${filesize}; fi; ${get_cmd} ${loadaddr} ${image}; if ${get_cmd} ${fdt_addr} ${fdt_file}; then run net_apply_overlays; booti ${loadaddr} - ${fdt_addr}; else echo WARN: Cannot load the DT; fi;
Refer to phycore_imx8mm.h or phycore_imx8mp.h.
- Will be part of drivers/power/regulator/pca9450.c
- when pca9451a support is added.
- return BOOT_DEVICE_BOOTROM;
- puts("Normal Boot\n");
- ddr_init(&dram_timing);
- struct udevice *dev;
- int ret;
- unsigned int val = 0;
- ret = pmic_get("pmic@25", &dev);
- if (ret == -ENODEV) {
- if (ret != 0)
return ret;
- /* BUCKxOUT_DVS0/1 control BUCK123 output */
- pmic_reg_write(dev, PCA9450_BUCK123_DVS, 0x29);
- /* enable DVS control through PMIC_STBY_REQ */
- pmic_reg_write(dev, PCA9450_BUCK1CTRL, 0x59);
- ret = pmic_reg_read(dev, PCA9450_PWR_CTRL);
- if (ret < 0)
return ret;
- val = ret;
- if (IS_ENABLED(CONFIG_IMX9_LOW_DRIVE_MODE)) {
} else {
- } else {
} else {
- /* set standby voltage to 0.65v */
- if (val & PCA9450_REG_PWRCTRL_TOFF_DEB)
- else
- /* I2C_LT_EN*/
- pmic_reg_write(dev, 0xa, 0x3);
- int ret;
- /* Clear the BSS. */
- memset(__bss_start, 0, __bss_end - __bss_start);
- timer_init();
- arch_cpu_init();
- spl_early_init();
- preloader_console_init();
- ret = imx9_probe_mu(NULL, NULL);
- if (ret) {
- } else {
- clock_init();
- power_init_board();
- if (!IS_ENABLED(CONFIG_IMX9_LOW_DRIVE_MODE))
- /* Init power of mix */
- soc_power_init();
- /* Setup TRDC for DDR access */
- trdc_init();
- /* DDR initialization */
- spl_dram_init();
- /* Put M33 into CPUWAIT for following kick */
- ret = m33_prepare();
- if (!ret)
- board_init_r(NULL, 0);
If I do:
make imx93-phyboard-segin_defconfig make savedefconfig cp defconfig configs/imx93-phyboard-segin_defconfig
I get a diff. Mostly reordering issues, but some options from downstream u-boot like:
-CONFIG_PHYTEC_SOM_DETECTION
or
-CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x83200000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x80000
etc...
got included in v3.
Can you sort this out for v4, please?
BR, Primoz
- $ unset LDFLAGS
- $ make PLAT=imx93 bl31
- $ cp build/imx93/release/bl31.bin $(srctree)
- $ wget https://www.nxp.com/lgfiles/NMG/MAD/YOCTO/firmware-imx-8.21.bin
- $ chmod +x firmware-imx-8.21.bin
- $ ./firmware-imx-8.21.bin
- $ cp firmware-imx-8.21/firmware/ddr/synopsys/lpddr4*.bin $(srctree)
- $ wget https://www.nxp.com/lgfiles/NMG/MAD/YOCTO/firmware-sentinel-0.10.bin
- $ chmod +x firmware-sentinel-0.10.bin
- $ ./firmware-sentinel-0.10.bin
- $ cp firmware-sentinel-0.10/mx93a0-ahab-container.img $(srctree)
- $ make imx93-phyboard-segin_defconfig
- $ make
- $ dd if=flash.bin of=/dev/sd[x] bs=1024 seek=32 conv=notrunc
- imx93-phyboard-segin phycore-imx8mm phycore-imx8mp
- Copyright 2022 NXP
- (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512)
Hello,
The reason I used findfdt is that CONFIG_DEFAULT_FDT_FILE is a string so, we end up with:
--8<---------------cut here---------------start------------->8--- fdt_file="oftree" --8<---------------cut here---------------end--------------->8---
which gives:
--8<---------------cut here---------------start------------->8--- u-boot=> run loadfdt Failed to load '"oftree"' --8<---------------cut here---------------end--------------->8---
whereas, if I set:
--8<---------------cut here---------------start------------->8--- u-boot=> setenv fdt_file oftree u-boot=> run loadfdt 24579 bytes read in 5 ms (4.7 MiB/s) --8<---------------cut here---------------end--------------->8---
I then see three options: introduce an unstrigify macro, hardcode fdt_file=oftree in the env file, or use the findfdt hack.
I'm not sure which one is the better?
I will fix all the other remarks in the v4.
Thanks,
Mathieu
Hi Mathieu,
On 30. 01. 24 10:43, Mathieu Othacehe wrote:
Hello,
which gives:
whereas, if I set:
On my side there is no problem, see my output here:
U-Boot 2024.04-rc1-00004-g686cb1ca1391-dirty (Jan 30 2024 - 10:58:24 +0100)
CPU: i.MX93 rev1.1 Model: PHYTEC phyBOARD-Segin-i.MX93 DRAM: 1 GiB Core: 184 devices, 22 uclasses, devicetree: separate WDT: Started wdog@42490000 with servicing every 1000ms (40s timeout) MMC: FSL_SDHC: 0, FSL_SDHC: 1 Loading Environment from MMC... OK In: serial@44380000 Out: serial@44380000 Err: serial@44380000 Net: eth0: ethernet@42890000 Hit any key to stop autoboot: 0 u-boot=> u-boot=> env default -a ## Resetting to default environment u-boot=> saveenv; saveenv Saving Environment to MMC... Writing to redundant MMC(1)... OK Saving Environment to MMC... Writing to MMC(1)... OK u-boot=> printenv fdt_file fdt_file="oftree" u-boot=> run loadfdt 48532 bytes read in 5 ms (9.3 MiB/s) u-boot=> boot switch to partitions #0, OK mmc1 is current device 32688640 bytes read in 411 ms (75.8 MiB/s) Booting from mmc ... 83 bytes read in 1 ms (81.1 KiB/s) 48532 bytes read in 4 ms (11.6 MiB/s) Working FDT set to 83000000 3615 bytes read in 3 ms (1.1 MiB/s) 1209 bytes read in 2 ms (589.8 KiB/s) ## Flattened Device Tree blob at 83000000 Booting using the fdt blob at 0x83000000 Working FDT set to 83000000 Loading Device Tree to 00000000bcf0a000, end 00000000bcf19fff ... OK Working FDT set to bcf0a000
Starting kernel ...
Here is my diff compared to your v3:
--- a/board/phytec/phycore_imx93/phycore_imx93.env +++ b/board/phytec/phycore_imx93/phycore_imx93.env @@ -5,7 +5,7 @@ console=ttyLP0 fdt_addr=0x83000000 fdto_addr=0x830c0000 bootenv_addr=0x83500000 -fdt_file=undefined +fdt_file=CONFIG_DEFAULT_FDT_FILE ipaddr=192.168.3.11 serverip=192.168.3.10 netmask=255.255.255.0 @@ -22,11 +22,7 @@ mmcautodetect=yes mmcargs=setenv bootargs ${mcore_clk} console=${console},${baudrate} earlycon root=/dev/mmcblk${mmcdev}p${mmcroot} ${raucargs} rootwait rw loadimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${image} -findfdt=if test $fdt_file = undefined; then - setenv fdt_file CONFIG_DEFAULT_FDT_FILE ; - fi; - echo fdt_file=${fdt_file}; -loadfdt=run findfdt;fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_file} +loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_file} mmc_load_overlay=fatload mmc ${mmcdev}:${mmcpart} ${fdto_addr} ${overlay} mmc_apply_overlays=
So this should work. We have the same in the downstream u-boot-imx.
Also, in-tree, phycore_am62x.env has the same:
fdtfile=CONFIG_DEFAULT_FDT_FILE loadfdt=load mmc ${mmcdev}:${mmcpart} ${fdtaddr} ${fdtfile}
Can you re-check, please?
Maybe check your include/generated/environment.h?
OK, thanks.
I spotted additional remark that was not fixed in v3:
In file doc/board/phytec/imx93-phyboard-segin.rst, can you please change title from:
phyCORE-i.MX 93 on a phyBOARD-Segin ===================================
to:
phyBOARD-Segin-i.MX93 =====================
and this text from:
U-Boot for the phyCORE-i.MX 93 on a phyBOARD-Segin.
to:
Last but not least, please remove:
from board/phytec/phycore_imx93/spl.c
As support for PHYTEC_EEPROM will come later and that define will be part of that series.
Thanks and best regards, Primoz
Thanks,
Mathieu
Hey,
Thanks for checking. It is strange that you do not reproduce that one.
My include/generated/environment.h looks like:
--8<---------------cut here---------------start------------->8--- #define CONFIG_EXTRA_ENV_TEXT "bootenv=bootenv.txt\0bootenv_addr=0x83500000\0console=ttyLP0\0fdt_addr=0x83000000\0fdt_file="oftree"\0fdto_addr=0x830c0000\0image=Image\0ip_dyn=yes\0loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_file}\0loadimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${image}\0mmc_apply_overlays=fdt address ${fdt_addr}; for overlay in ${overlays}; do; if run mmc_load_overlay; then fdt resize ${filesize}; fdt apply ${fdto_addr}; fi; done;\0mmc_load_bootenv=fatload mmc ${mmcdev}:${mmcpart} ${bootenv_addr} ${bootenv}\0mmc_load_overlay=fatload mmc ${mmcdev}:${mmcpart} ${fdto_addr} ${overlay}\0mmcargs=setenv bootargs console=${console},${baudrate} earlycon root=/dev/mmcblk${mmcdev}p${mmcroot} ${raucargs} rootwait rw\0mmcautodetect=yes\0mmcboot=echo Booting from mmc ...; if run mmc_load_bootenv; then env import -t ${bootenv_addr} ${filesize}; fi; run mmcargs; if run loadfdt; then run mmc_apply_overlays; booti ${loadaddr} - ${fdt_addr}; else echo WARN: Cannot load the DT; fi;\0mmcdev=1\0mmcpart=1\0mmcroot=2\0net_apply_overlays=fdt address ${fdt_addr}; for overlay in ${overlays}; do; if run net_load_overlay; then fdt resize ${filesize}; fdt apply ${fdto_addr}; fi; done;\0net_load_bootenv=${get_cmd} ${bootenv_addr} ${bootenv}\0net_load_overlay=${get_cmd} ${fdto_addr} ${overlay}\0netargs=setenv bootargs console=${console},${baudrate} earlycon root=/dev/nfs ip=${nfsip} nfsroot=${serverip}:${nfsroot},v3,tcp\0netboot=echo Booting from net ...; run netargs; if test ${ip_dyn} = yes; then setenv get_cmd dhcp; else setenv get_cmd tftp; fi; if run net_load_bootenv; then env import -t ${bootenv_addr} ${filesize}; fi; ${get_cmd} ${loadaddr} ${image}; if ${get_cmd} ${fdt_addr} ${fdt_file}; then run net_apply_overlays; booti ${loadaddr} - ${fdt_addr}; else echo WARN: Cannot load the DT; fi;\0nfsroot=/nfs\0" --8<---------------cut here---------------end--------------->8---
Note that fdt_file="oftree" which explains the issue on my side. Do you have a similar environment.h?
What u-boot commit are you based on?
Mathieu
On Tue, Jan 30, 2024 at 01:49:26PM +0100, Mathieu Othacehe wrote:
Hey,
And what awk do you both have? environment.h is generated via scripts/env2string.awk
On my side:
mathieu@meije ~/u-boot [env]$ awk --version GNU Awk 5.2.1, API 3.2, PMA Avon 8-g1
and I have a similar result with:
mathieu@FRMONPC1176:~$ awk --version GNU Awk 5.0.1, API: 2.0 (GNU MPFR 4.0.2, GNU MP 6.2.0)
Mathieu
Hi Mathieu,
On 30. 01. 24 13:49, Mathieu Othacehe wrote:
Hey,
I have the same.
I am based on latest master 6faba41927bd (tag: v2024.04-rc1)
Mathieu
To Tom:
Using Ubuntu 20.04 LTS
$ awk --version GNU Awk 5.0.1, API: 2.0 (GNU MPFR 4.0.2, GNU MP 6.2.0) Copyright (C) 1989, 1991-2019 Free Software Foundation.
BR, Primoz
Hi Mathieu,
That was it. I rebased from 043ca8c8a9b to 6faba41927bd and I now have the same behaviour as you. I cannot find which commit fixed the situation in that interval though.
Preparing the v4,
OK, great.
Can you maybe test my patch:
https://patchwork.ozlabs.org/project/uboot/patch/20240130124337.497748-1-pri...
And see if it fixes Ethernet on the board?
BR, Primoz
participants (5)
Fabio Estevam
Mathieu Othacehe
Mathieu Othacehe
Primoz Fiser
