[PATCH v1 0/2] arm: octeontx2: Add base support for Marvell OcteonTX2 CN9132 DB
This patchset adds the base support for the Marvell OcteonTX2 CN9132 DB board and includes required dts/dtsi files and the defconfig files for this.
Thanks, Stefan
Stefan Roese (2): arm: octeontx2: Add dtsi/dts files for Octeon TX2 CN9132 DB arm: octeontx2: Add Octeon TX2 CN9132 DB support
arch/arm/dts/Makefile | 6 + arch/arm/dts/cn9130-db-A.dts | 212 ++++++++++++++++++++ arch/arm/dts/cn9130-db-B.dts | 223 +++++++++++++++++++++ arch/arm/dts/cn9130-db-dev-info.dtsi | 44 ++++ arch/arm/dts/cn9130-db.dtsi | 133 ++++++++++++ arch/arm/dts/cn9131-db-A.dts | 54 +++++ arch/arm/dts/cn9131-db-B.dts | 69 +++++++ arch/arm/dts/cn9131-db.dtsi | 166 +++++++++++++++ arch/arm/dts/cn9132-db-A.dts | 103 ++++++++++ arch/arm/dts/cn9132-db-B.dts | 103 ++++++++++ arch/arm/dts/cn9132-db.dtsi | 130 ++++++++++++ board/Marvell/octeontx2_cn913x/MAINTAINERS | 2 + configs/mvebu_db_cn9132_defconfig | 88 ++++++++ configs/mvebu_db_cn9132_nand_defconfig | 89 ++++++++ 14 files changed, 1422 insertions(+) create mode 100644 arch/arm/dts/cn9130-db-A.dts create mode 100644 arch/arm/dts/cn9130-db-B.dts create mode 100644 arch/arm/dts/cn9130-db-dev-info.dtsi create mode 100644 arch/arm/dts/cn9130-db.dtsi create mode 100644 arch/arm/dts/cn9131-db-A.dts create mode 100644 arch/arm/dts/cn9131-db-B.dts create mode 100644 arch/arm/dts/cn9131-db.dtsi create mode 100644 arch/arm/dts/cn9132-db-A.dts create mode 100644 arch/arm/dts/cn9132-db-B.dts create mode 100644 arch/arm/dts/cn9132-db.dtsi create mode 100644 configs/mvebu_db_cn9132_defconfig create mode 100644 configs/mvebu_db_cn9132_nand_defconfig
This patch adds the dtsi/dts files needed to support the Marvell Octeon TX2 CN9132 DB. This is only the base port with not all interfaces supported fully.
Signed-off-by: Konstantin Porotchkin kostap@marvell.com Signed-off-by: Stefan Roese sr@denx.de ---
arch/arm/dts/Makefile | 6 + arch/arm/dts/cn9130-db-A.dts | 212 +++++++++++++++++++++++++ arch/arm/dts/cn9130-db-B.dts | 223 +++++++++++++++++++++++++++ arch/arm/dts/cn9130-db-dev-info.dtsi | 44 ++++++ arch/arm/dts/cn9130-db.dtsi | 133 ++++++++++++++++ arch/arm/dts/cn9131-db-A.dts | 54 +++++++ arch/arm/dts/cn9131-db-B.dts | 69 +++++++++ arch/arm/dts/cn9131-db.dtsi | 166 ++++++++++++++++++++ arch/arm/dts/cn9132-db-A.dts | 103 +++++++++++++ arch/arm/dts/cn9132-db-B.dts | 103 +++++++++++++ arch/arm/dts/cn9132-db.dtsi | 130 ++++++++++++++++ 11 files changed, 1243 insertions(+) create mode 100644 arch/arm/dts/cn9130-db-A.dts create mode 100644 arch/arm/dts/cn9130-db-B.dts create mode 100644 arch/arm/dts/cn9130-db-dev-info.dtsi create mode 100644 arch/arm/dts/cn9130-db.dtsi create mode 100644 arch/arm/dts/cn9131-db-A.dts create mode 100644 arch/arm/dts/cn9131-db-B.dts create mode 100644 arch/arm/dts/cn9131-db.dtsi create mode 100644 arch/arm/dts/cn9132-db-A.dts create mode 100644 arch/arm/dts/cn9132-db-B.dts create mode 100644 arch/arm/dts/cn9132-db.dtsi
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index a5cae010c263..92e68ca4361b 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -237,6 +237,12 @@ dtb-$(CONFIG_ARCH_MVEBU) += \ armada-xp-maxbcm.dtb \ armada-xp-synology-ds414.dtb \ armada-xp-theadorable.dtb \ + cn9130-db-A.dtb \ + cn9130-db-B.dtb \ + cn9131-db-A.dtb \ + cn9131-db-B.dtb \ + cn9132-db-A.dtb \ + cn9132-db-B.dtb \ cn9130-crb-A.dtb \ cn9130-crb-B.dtb
diff --git a/arch/arm/dts/cn9130-db-A.dts b/arch/arm/dts/cn9130-db-A.dts new file mode 100644 index 000000000000..ab61eb97f0a8 --- /dev/null +++ b/arch/arm/dts/cn9130-db-A.dts @@ -0,0 +1,212 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2018 Marvell International Ltd. + */ + +#include "cn9130-db.dtsi" + +/ { + model = "Marvell CN9130 development board (CP NOR) setup(A)"; + compatible = "marvell,cn9130-db", "marvell,cn91xx", "marvell,cn9030-vd", + "marvell,cn9030", "marvell,armada-ap806-quad", + "marvell,armada-ap806"; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + aliases { + i2c0 = &cp0_i2c0; + spi0 = &cp0_spi1; + gpio0 = &ap_gpio0; + gpio1 = &cp0_gpio0; + gpio2 = &cp0_gpio1; + }; + + memory@00000000 { + device_type = "memory"; + reg = <0x0 0x0 0x0 0x80000000>; + }; +}; + +&uart0 { + status = "okay"; +}; + +/* + * AP related configuration + */ +&ap_pinctl { + /* MPP Bus: + * SDIO [0-10, 12] + * UART0 [11,19] + */ + /* 0 1 2 3 4 5 6 7 8 9 */ + pin-func = < 1 1 1 1 1 1 1 1 1 1 + 1 3 1 0 0 0 0 0 0 3 >; +}; + +/* + * CP related configuration + */ +&cp0_pinctl { + /* MPP Bus: + * [0-11] RGMII1 + * [12] GPIO GE-IN + * [13-16] SPI1 + * [17-27] NAND + * [28] MSS_GPIO[5] XXX:(mode nr from a3900) + * [29-30] SATA + * [31] MSS_GPIO[4] XXX:(mode nr from a3900) + * [32,34] SMI + * [33] SDIO + * [35-36] I2C1 + * [37-38] I2C0 + * [39-43] SDIOctrl + * [44-55] RGMII2 + * [56-62] SDIO + */ + + /* 0 1 2 3 4 5 6 7 8 9 */ + pin-func = < 3 3 3 3 3 3 3 3 3 3 + 3 3 0 3 3 3 3 1 1 1 + 1 1 1 1 1 1 1 1 3 9 + 9 3 7 6 7 2 2 2 2 1 + 1 1 1 1 1 1 1 1 1 1 + 1 1 1 1 1 1 0xe 0xe 0xe 0xe + 0xe 0xe 0xe>; +}; + +&cp0_i2c0 { + pinctrl-names = "default"; + pinctrl-0 = <&cp0_i2c0_pins>; + status = "okay"; + clock-frequency = <100000>; +}; + +&cp0_i2c1 { + status = "okay"; +}; + +/* CON 28 */ +&cp0_sdhci0 { + pinctrl-names = "default"; + pinctrl-0 = <&cp0_sdhci_pins>; + bus-width = <4>; + status = "okay"; +}; + +/* U54 */ +&cp0_nand { + status = "disabled"; +}; + +/* U55 */ +&cp0_spi1 { + pinctrl-names = "default"; + pinctrl-0 = <&cp0_spi0_pins>; + reg = <0x700680 0x50>, /* control */ + <0x2000000 0x1000000>, /* CS0 */ + <0 0xffffffff>, /* CS1 */ + <0 0xffffffff>, /* CS2 */ + <0 0xffffffff>; /* CS3 */ + status = "okay"; + + spi-flash@0 { + #address-cells = <0x1>; + #size-cells = <0x1>; + compatible = "jedec,spi-nor", "spi-flash"; + reg = <0x0>; + /* On-board MUX does not allow higher frequencies */ + spi-max-frequency = <40000000>; + + partitions { + compatible = "fixed-partitions"; + #address-cells = <1>; + #size-cells = <1>; + + partition@0 { + label = "U-Boot"; + reg = <0x0 0x200000>; + }; + + partition@400000 { + label = "Filesystem"; + reg = <0x200000 0xe00000>; + }; + }; + }; +}; + +&cp0_comphy { + + phy0 { + phy-type = <COMPHY_TYPE_PEX0>; + }; + + phy1 { + phy-type = <COMPHY_TYPE_PEX0>; + }; + + phy2 { + phy-type = <COMPHY_TYPE_PEX0>; + }; + + phy3 { + phy-type = <COMPHY_TYPE_PEX0>; + }; + + phy4 { + phy-type = <COMPHY_TYPE_SFI0>; + phy-speed = <COMPHY_SPEED_10_3125G>; + }; + + phy5 { + phy-type = <COMPHY_TYPE_SATA1>; + }; +}; + +/* SLM-1521-V2, CON6 */ +&cp0_pcie0 { + num-lanes = <4>; + status = "disabled"; +}; + +&cp0_mdio { + status = "okay"; + phy0: ethernet-phy@0 { + reg = <0>; + }; + phy1: ethernet-phy@1 { + reg = <1>; + }; +}; + +&cp0_ethernet { + status = "okay"; +}; + +/* SLM-1521-V2, CON9 */ +&cp0_eth0 { + status = "okay"; + phy-mode = "sfi"; +}; + +/* CON56 */ +&cp0_eth1 { + status = "okay"; + phy = <&phy0>; + phy-mode = "rgmii-id"; +}; + +/* CON57 */ +&cp0_eth2 { + status = "okay"; + phy = <&phy1>; + phy-mode = "rgmii-id"; +}; + +/* SLM-1521-V2, CON2 */ +&cp0_sata0 { + status = "okay"; +}; diff --git a/arch/arm/dts/cn9130-db-B.dts b/arch/arm/dts/cn9130-db-B.dts new file mode 100644 index 000000000000..ba897dff7332 --- /dev/null +++ b/arch/arm/dts/cn9130-db-B.dts @@ -0,0 +1,223 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2018 Marvell International Ltd. + */ + +#include "cn9130-db.dtsi" + +/ { + model = "Marvell CN9130 development board (CP NAND) setup(B)"; + compatible = "marvell,cn9130-db", "marvell,cn91xx", "marvell,cn9030-vd", + "marvell,cn9030", "marvell,armada-ap806-quad", + "marvell,armada-ap806"; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + aliases { + i2c0 = &cp0_i2c0; + gpio0 = &ap_gpio0; + gpio1 = &cp0_gpio0; + gpio2 = &cp0_gpio1; + }; + + memory@00000000 { + device_type = "memory"; + reg = <0x0 0x0 0x0 0x80000000>; + }; +}; + +&uart0 { + status = "okay"; +}; + +/* + * AP related configuration + */ +&ap_pinctl { + /* MPP Bus: + * SDIO [0-10, 12] + * UART0 [11,19] + */ + /* 0 1 2 3 4 5 6 7 8 9 */ + pin-func = < 1 1 1 1 1 1 1 1 1 1 + 1 3 1 0 0 0 0 0 0 3 >; +}; + +/* + * CP related configuration + */ +&cp0_pinctl { + cp0_nand_pins: cp0-nand-pins { + marvell,pins = <15 16 17 18 19 20 21 22 23 24 25 26 27 >; + marvell,function = <1>; + }; + cp0_nand_rb: cp0-nand-rb { + marvell,pins = < 13 >; + marvell,function = <2>; + }; +}; + +&cp0_pinctl { + /* MPP Bus: + * [0-11] RGMII1 + * [12] GPIO GE-IN + * [13-14] SPI1 + * [15-27] NAND + * [28] MSS_GPIO[5] XXX:(mode nr from a3900) + * [29-30] SATA + * [31] MSS_GPIO[4] XXX:(mode nr from a3900) + * [32,34] SMI + * [33] SDIO + * [35-36] I2C1 + * [37-38] I2C0 + * [39-43] SDIOctrl + * [44-55] RGMII2 + * [56-62] SDIO + */ + + /* 0 1 2 3 4 5 6 7 8 9 */ + pin-func = < 3 3 3 3 3 3 3 3 3 3 + 3 3 0 2 3 1 1 1 1 1 + 1 1 1 1 1 1 1 1 3 9 + 9 3 7 6 7 2 2 2 2 1 + 1 1 1 1 1 1 1 1 1 1 + 1 1 1 1 1 1 0xe 0xe 0xe 0xe + 0xe 0xe 0xe>; +}; + +&cp0_i2c0 { + pinctrl-names = "default"; + pinctrl-0 = <&cp0_i2c0_pins>; + status = "okay"; + clock-frequency = <100000>; +}; + +&cp0_i2c1 { + status = "okay"; +}; + +/* CON 28 */ +&cp0_sdhci0 { + pinctrl-names = "default"; + pinctrl-0 = <&cp0_sdhci_pins>; + bus-width = <4>; + status = "okay"; +}; + +/* U54 */ +&cp0_nand { + pinctrl-names = "default"; + pinctrl-0 = <&cp0_nand_pins &cp0_nand_rb>; + status = "okay"; +}; + +/* U55 */ +&cp0_spi1 { + pinctrl-names = "default"; + pinctrl-0 = <&cp0_spi0_pins>; + reg = <0x700680 0x50>, /* control */ + <0x2000000 0x1000000>, /* CS0 */ + <0 0xffffffff>, /* CS1 */ + <0 0xffffffff>, /* CS2 */ + <0 0xffffffff>; /* CS3 */ + status = "disabled"; + + spi-flash@0 { + #address-cells = <0x1>; + #size-cells = <0x1>; + compatible = "jedec,spi-nor", "spi-flash"; + reg = <0x0>; + /* On-board MUX does not allow higher frequencies */ + spi-max-frequency = <40000000>; + + partitions { + compatible = "fixed-partitions"; + #address-cells = <1>; + #size-cells = <1>; + + partition@0 { + label = "U-Boot"; + reg = <0x0 0x200000>; + }; + + partition@400000 { + label = "Filesystem"; + reg = <0x200000 0xe00000>; + }; + }; + }; +}; + +&cp0_comphy { + phy0 { + phy-type = <COMPHY_TYPE_PEX0>; + }; + + phy1 { + phy-type = <COMPHY_TYPE_PEX0>; + }; + + phy2 { + phy-type = <COMPHY_TYPE_PEX0>; + }; + + phy3 { + phy-type = <COMPHY_TYPE_PEX0>; + }; + + phy4 { + phy-type = <COMPHY_TYPE_SFI0>; + phy-speed = <COMPHY_SPEED_10_3125G>; + }; + + phy5 { + phy-type = <COMPHY_TYPE_SATA1>; + }; +}; + +/* SLM-1521-V2, CON6 */ +&cp0_pcie0 { + num-lanes = <4>; + status = "disabled"; +}; + +&cp0_mdio { + status = "okay"; + phy0: ethernet-phy@0 { + reg = <0>; + }; + phy1: ethernet-phy@1 { + reg = <1>; + }; +}; + +&cp0_ethernet { + status = "okay"; +}; + +/* SLM-1521-V2, CON9 */ +&cp0_eth0 { + status = "okay"; + phy-mode = "sfi"; +}; + +/* CON56 */ +&cp0_eth1 { + status = "okay"; + phy = <&phy0>; + phy-mode = "rgmii-id"; +}; + +/* CON57 */ +&cp0_eth2 { + status = "okay"; + phy = <&phy1>; + phy-mode = "rgmii-id"; +}; + +/* SLM-1521-V2, CON2 */ +&cp0_sata0 { + status = "okay"; +}; diff --git a/arch/arm/dts/cn9130-db-dev-info.dtsi b/arch/arm/dts/cn9130-db-dev-info.dtsi new file mode 100644 index 000000000000..f2e7c033b718 --- /dev/null +++ b/arch/arm/dts/cn9130-db-dev-info.dtsi @@ -0,0 +1,44 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2018 Marvell International Ltd. + */ +/ { + /* This should go only into devel boards */ + compatible = "marvell,cp110"; + sar { + #address-cells = <1>; + #size-cells = <0>; + + sar_fields { + compatible = "marvell,sample-at-reset"; + reg = <0x4c 0x4e>; + chip_count = <2>; + bit_width = <5>; + freq { + key = "freq"; + description = "CPU/DDR and PIDI frequencies"; + start-bit = <0>; + bit-length = <4>; + option-cnt = <3>; + options = "0x0", "CPU/DDR = 0x0: 2000/1200 Mhz, PIDI = 0: 1Ghz", + "0x2", "CPU/DDR = 0x6: 2200/1200 Mhz, PIDI = 0: 1Ghz", + "0x4", "CPU/DDR = 0xD: 1600/1200 Mhz, PIDI = 0: 1Ghz"; + default = <0x2>; + status = "okay"; + }; + boot_mode { + key = "boot_mode"; + description = "Boot mode options"; + start-bit = <4>; + bit-length = <6>; + option-cnt = <4>; + options = "0xE", "CP0_NAND PIDI BW-8bit, PS-4KB, ECC-4bit\t(supported configuration: B)", + "0xF", "CP0_NAND PIDI BW-8bit, PS-4KB, ECC-8bit\t(supported configuration: B)", + "0x2A", "AP_EMMC", + "0x32", "CP1_SPI_1 24bits"; + default = <0x32>; + status = "okay"; + }; + }; + }; +}; diff --git a/arch/arm/dts/cn9130-db.dtsi b/arch/arm/dts/cn9130-db.dtsi new file mode 100644 index 000000000000..c2e70f0e9f33 --- /dev/null +++ b/arch/arm/dts/cn9130-db.dtsi @@ -0,0 +1,133 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2018 Marvell International Ltd. + */ + +#include "cn9130.dtsi" /* include SoC device tree */ +#include "cn9130-db-dev-info.dtsi" + +/ { + model = "DB-CN-9130"; + compatible = "marvell,cn9030", "marvell,armada-ap806-quad", + "marvell,armada-ap806"; + + cp0 { + config-space { + i2c@701000 { + /* U36 */ + expander0: pca953x@21 { + compatible = "nxp,pca9555"; + #gpio-cells = <2>; + reg = <0x21>; + status = "okay"; + }; + }; + sdhci@780000 { + vqmmc-supply = <&cp0_reg_sd_vccq>; + vmmc-supply = <&cp0_reg_sd_vcc>; + }; + + ap_reg_mmc_vccq: ap_mmc_vccq@0 { + compatible = "regulator-gpio"; + regulator-name = "ap_mmc_vccq"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + gpios = <&expander0 8 GPIO_ACTIVE_HIGH>; + states = <1800000 0x1 + 3300000 0x0>; + }; + cp0_reg_usb3_vbus0: cp0_usb3_vbus@0 { + compatible = "regulator-fixed"; + regulator-name = "cp0-xhci0-vbus"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + startup-delay-us = <100000>; + regulator-force-boot-off; + gpio = <&expander0 0 GPIO_ACTIVE_HIGH>; + }; + + cp0_reg_usb3_vbus1: cp0_usb3_vbus@1 { + compatible = "regulator-fixed"; + regulator-name = "cp0-xhci1-vbus"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + startup-delay-us = <100000>; + regulator-force-boot-off; + gpio = <&expander0 1 GPIO_ACTIVE_HIGH>; + }; + cp0_reg_sd_vccq: cp0_sd_vccq@0 { + compatible = "regulator-gpio"; + regulator-name = "cp0_sd_vccq"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + gpios = <&expander0 15 GPIO_ACTIVE_HIGH>; + states = <1800000 0x1 + 3300000 0x0>; + }; + cp0_reg_sd_vcc: cp0_sd_vcc@0 { + compatible = "regulator-fixed"; + regulator-name = "cp0_sd_vcc"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + gpio = <&expander0 14 GPIO_ACTIVE_HIGH>; + enable-active-high; + regulator-always-on; + }; + cp0_reg_usb3_current_lim0:cp0_usb3_current_limiter@0 { + compatible = "regulator-fixed"; + regulator-min-microamp = <900000>; + regulator-max-microamp = <900000>; + regulator-force-boot-off; + gpio = <&expander0 4 GPIO_ACTIVE_HIGH>; + }; + + cp0_reg_usb3_current_lim1: cp0_usb3_current_limiter@1 { + compatible = "regulator-fixed"; + regulator-min-microamp = <900000>; + regulator-max-microamp = <900000>; + regulator-force-boot-off; + gpio = <&expander0 5 GPIO_ACTIVE_HIGH>; + }; + }; + }; +}; + +/* on-board eMMC - U9 */ +&ap_sdhci0 { + pinctrl-names = "default"; + pinctrl-0 = <&ap_emmc_pins>; + vqmmc-supply = <&ap_reg_mmc_vccq>; + bus-width = <8>; + mmc-ddr-1_8v; + mmc-hs400-1_8v; + status = "okay"; +}; + +/* + * CP0 + */ +&cp0_utmi0 { + status = "okay"; +}; + +&cp0_utmi1 { + status = "okay"; +}; + +&cp0_usb3_0 { + status = "okay"; + vbus-supply = <&cp0_reg_usb3_vbus0>; + current-limiter = <&cp0_reg_usb3_current_lim0>; + vbus-disable-delay = <500>; +}; + +&cp0_usb3_1 { + status = "okay"; + vbus-supply = <&cp0_reg_usb3_vbus1>; + current-limiter = <&cp0_reg_usb3_current_lim1>; + vbus-disable-delay = <500>; +}; + +&cp0_pcie0 { + status = "okay"; +}; diff --git a/arch/arm/dts/cn9131-db-A.dts b/arch/arm/dts/cn9131-db-A.dts new file mode 100644 index 000000000000..30513198397f --- /dev/null +++ b/arch/arm/dts/cn9131-db-A.dts @@ -0,0 +1,54 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2018 Marvell International Ltd. + */ + +#include "cn9130-db-A.dts" +#include "cn9131-db.dtsi" + +/ { + model = "Marvell CN9131 development board (CP NOR) setup(A)"; + compatible = "marvell,cn9131-db", "marvell,armada-ap806-quad", + "marvell,armada-ap806"; +}; + +&cp1_comphy { + /* Serdes Configuration: + * Lane 0: PCIe0 (x2) + * Lane 1: PCIe0 (x2) + * Lane 2: unconnected + * Lane 3: USB1 + * Lane 4: SFP (port 0) + * Lane 5: SATA1 + */ + phy0 { + phy-type = <COMPHY_TYPE_PEX0>; + }; + phy1 { + phy-type = <COMPHY_TYPE_PEX0>; + }; + phy2 { + phy-type = <COMPHY_TYPE_UNCONNECTED>; + }; + phy3 { + phy-type = <COMPHY_TYPE_USB3_HOST1>; + }; + phy4 { + phy-type = <COMPHY_TYPE_SFI0>; + phy-speed = <COMPHY_SPEED_10_3125G>; + }; + phy5 { + phy-type = <COMPHY_TYPE_SATA1>; + }; +}; + +&cp1_ethernet { + status = "okay"; +}; + +/* CON50 */ +&cp1_eth0 { + status = "okay"; + phy-mode = "sfi"; /* lane-4 */ + marvell,sfp-tx-disable-gpio = <&cp1_gpio0 9 GPIO_ACTIVE_HIGH>; +}; diff --git a/arch/arm/dts/cn9131-db-B.dts b/arch/arm/dts/cn9131-db-B.dts new file mode 100644 index 000000000000..f8363d22cf57 --- /dev/null +++ b/arch/arm/dts/cn9131-db-B.dts @@ -0,0 +1,69 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 Marvell International Ltd. + */ + +#include "cn9130-db-B.dts" +#include "cn9131-db.dtsi" + +/ { + model = "Marvell CN9131 development board (CP NAND) setup(B)"; + compatible = "marvell,cn9131-db", "marvell,armada-ap806-quad", + "marvell,armada-ap806"; +}; + +&cp1_comphy { + /* Serdes Configuration: + * Lane 0: PCIe0 (x2) + * Lane 1: PCIe0 (x2) + * Lane 2: SFI (port 0) + * Lane 3: USB1 + * Lane 4: SGMII (port 1) + * Lane 5: SATA1 + */ + phy0 { + phy-type = <COMPHY_TYPE_PEX0>; + }; + phy1 { + phy-type = <COMPHY_TYPE_PEX0>; + }; + phy2 { + phy-type = <COMPHY_TYPE_SFI0>; + phy-speed = <COMPHY_SPEED_10_3125G>; + }; + phy3 { + phy-type = <COMPHY_TYPE_USB3_HOST1>; + }; + phy4 { + phy-type = <COMPHY_TYPE_SGMII1>; + phy-speed = <COMPHY_SPEED_1_25G>; + }; + phy5 { + phy-type = <COMPHY_TYPE_SATA1>; + }; +}; + +&cp1_ethernet { + status = "okay"; +}; + +/* 3310 RJ45 CON55 */ +&cp1_eth0 { + status = "okay"; + phy-mode = "sfi"; /* lane-2 */ + phy = <&sfi_phy8>; /* required by 3310 fw download */ +}; + +/* CON50 */ +&cp1_eth1 { + status = "okay"; + phy-mode = "sgmii"; /* lane-4 */ + marvell,sfp-tx-disable-gpio = <&cp1_gpio0 9 GPIO_ACTIVE_HIGH>; +}; + +&cp1_xmdio { + status = "okay"; + sfi_phy8: ethernet-phy@8 { + reg = <8>; + }; +}; diff --git a/arch/arm/dts/cn9131-db.dtsi b/arch/arm/dts/cn9131-db.dtsi new file mode 100644 index 000000000000..64fdfd05da03 --- /dev/null +++ b/arch/arm/dts/cn9131-db.dtsi @@ -0,0 +1,166 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2018 Marvell International Ltd. + */ + +#undef CP110_NAME +#undef CP110_NUM +#undef CP110_PCIE_MEM_SIZE +#undef CP110_PCIEx_CPU_MEM_BASE +#undef CP110_PCIEx_BUS_MEM_BASE + +/* CP110-1 Settings */ +#define CP110_NAME cp1 +#define CP110_NUM 1 +#define CP110_PCIE_MEM_SIZE(iface) (0xf00000) +#define CP110_PCIEx_CPU_MEM_BASE(iface) (0xe2000000 + (iface) * 0x1000000) +#define CP110_PCIEx_BUS_MEM_BASE(iface) (CP110_PCIEx_CPU_MEM_BASE(iface)) + +#include "armada-cp110.dtsi" + +/ { + model = "Marvell CN9131 development board"; + compatible = "marvell,cn9131-db"; + + aliases { + gpio3 = &cp1_gpio0; + gpio4 = &cp1_gpio1; + }; + + cp1 { + config-space { + cp1_reg_usb3_vbus0: cp1_usb3_vbus@0 { + compatible = "regulator-fixed"; + pinctrl-names = "default"; + pinctrl-0 = <&cp1_xhci0_vbus_pins>; + regulator-name = "cp1-xhci0-vbus"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + startup-delay-us = <100000>; + regulator-force-boot-off; + gpio = <&cp1_gpio0 3 GPIO_ACTIVE_HIGH>; + }; + cp1_reg_usb3_current_lim0: cp1_usb3_current_limiter@0 { + compatible = "regulator-fixed"; + regulator-min-microamp = <900000>; + regulator-max-microamp = <900000>; + regulator-force-boot-off; + gpio = <&cp1_gpio0 2 GPIO_ACTIVE_HIGH>; + }; + cp1_pcie_reset_pins: cp1-pcie-reset-pins { + marvell,pins = <0>; + marvell,function = <0>; + }; + }; + }; +}; + +&cp1_i2c0 { + pinctrl-names = "default"; + pinctrl-0 = <&cp1_i2c0_pins>; + status = "okay"; + clock-frequency = <100000>; +}; + +/* CON40 */ +&cp1_pcie0 { + pinctrl-names = "default"; + pinctrl-0 = <&cp1_pcie_reset_pins>; + marvell,reset-gpio = <&cp1_gpio0 0 GPIO_ACTIVE_LOW>; + status = "okay"; + num-lanes = <2>; + /* non-prefetchable memory */ + ranges = <0x82000000 0 0xe2000000 0 0xe2000000 0 0xf00000>; +}; + +&cp1_pinctl { + compatible = "marvell,mvebu-pinctrl", + "marvell,cp115-standalone-pinctrl"; + bank-name ="cp1-110"; + + /* MPP Bus: + * [0-12] GPIO + * [13-16] SPI1 + * [17-27] GPIO (Default) + * [28] SATA1_PRESENT_ACTIVEn + * [29-34] GPIO (Default) + * [35-36] xSMI + * [37-38] I2C0 + * [39-62] GPIO + */ + /* 0 1 2 3 4 5 6 7 8 9 */ + pin-func = < 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 + 0x0 0x0 0x0 0x3 0x3 0x3 0x3 0x0 0x0 0x0 + 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x9 0x0 + 0x0 0x0 0x0 0x0 0x0 0x7 0x7 0x2 0x2 0x0 + 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 + 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 + 0x0 0x0 0x0 >; + + cp1_i2c0_pins: cp1-i2c-pins-0 { + marvell,pins = < 37 38 >; + marvell,function = <2>; + }; + cp1_spi0_pins: cp1-spi-pins-0 { + marvell,pins = < 13 14 15 16 >; + marvell,function = <3>; + }; + cp1_xhci0_vbus_pins: cp1-xhci0-vbus-pins { + marvell,pins = <3>; + marvell,function = <0>; + }; +}; + +/* CON32 */ +&cp1_sata0 { + status = "okay"; +}; + +/* U24 */ +&cp1_spi1 { + pinctrl-names = "default"; + pinctrl-0 = <&cp1_spi0_pins>; + reg = <0x700680 0x50>, /* control */ + <0x2000000 0x1000000>, /* CS0 */ + <0 0xffffffff>, /* CS1 */ + <0 0xffffffff>, /* CS2 */ + <0 0xffffffff>; /* CS3 */ + status = "okay"; + + spi-flash@0 { + #address-cells = <0x1>; + #size-cells = <0x1>; + compatible = "jedec,spi-nor", "spi-flash"; + reg = <0x0>; + /* On-board MUX does not allow higher frequencies */ + spi-max-frequency = <40000000>; + + partitions { + compatible = "fixed-partitions"; + #address-cells = <1>; + #size-cells = <1>; + + partition@0 { + label = "U-Boot"; + reg = <0x0 0x200000>; + }; + + partition@400000 { + label = "Filesystem"; + reg = <0x200000 0xe00000>; + }; + }; + }; +}; + +/* CON58 */ +&cp1_usb3_1 { + vbus-supply = <&cp1_reg_usb3_vbus0>; + current-limiter = <&cp1_reg_usb3_current_lim0>; + vbus-disable-delay = <500>; + status = "okay"; +}; + +&cp1_utmi1 { + status = "okay"; +}; diff --git a/arch/arm/dts/cn9132-db-A.dts b/arch/arm/dts/cn9132-db-A.dts new file mode 100644 index 000000000000..35f807012b4f --- /dev/null +++ b/arch/arm/dts/cn9132-db-A.dts @@ -0,0 +1,103 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2018 Marvell International Ltd. + */ + +#include "cn9131-db-A.dts" +#include "cn9132-db.dtsi" + +/ { + model = "Marvell CN9132 development board (CP NOR) setup(A)"; + compatible = "marvell,cn9132-db", "marvell,armada-ap806-quad", + "marvell,armada-ap806"; +}; + +&cp2_comphy { + phy0 { + phy-type = <COMPHY_TYPE_PEX0>; + }; + + phy1 { + phy-type = <COMPHY_TYPE_PEX0>; + }; + + phy2 { + phy-type = <COMPHY_TYPE_SATA0>; + }; + + phy3 { + phy-type = <COMPHY_TYPE_USB3_HOST1>; + }; + + phy4 { + phy-type = <COMPHY_TYPE_SFI0>; + phy-speed = <COMPHY_SPEED_10_3125G>; + }; + + phy5 { + phy-type = <COMPHY_TYPE_PEX2>; + }; +}; + +&cp2_ethernet { + status = "okay"; +}; + +/* SLM-1521-V2, CON9 */ +&cp2_eth0 { + status = "okay"; + phy-mode = "sfi"; +}; + +/* SLM-1521-V2, CON6 */ +&cp2_pcie0 { + num-lanes = <2>; + status = "okay"; +}; + +/* SLM-1521-V2, CON8 */ +&cp2_pcie2 { + num-lanes = <1>; + status = "okay"; +}; + +&cp2_pinctl { + /* MPP Bus: + * [0-26] GPIO + * [27] SATA0_PRESENT_ACTIVEn + * [28] SATA1_PRESENT_ACTIVEn + * [29-31, 33] GPIO (Default) + * [32,34] SMI + * [37-38] I2C0 + * [39-53] GPIO + * [54] SD_CRD_RSTn (out) + * [55] SD_CRD_DT (in) + * [56-62] SDIO + */ + /* 0 1 2 3 4 5 6 7 8 9 */ + pin-func = < 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 + 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 + 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x9 0x9 0x0 + 0x0 0x0 0x8 0x0 0x8 0x0 0x0 0x2 0x2 0x0 + 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 + 0x0 0x0 0x0 0x0 0xa 0xb 0xe 0xe 0xe 0xe + 0xe 0xe 0xe >; +}; + +/* SLM-1521-V2, CON4 */ +&cp2_sata0 { + status = "okay"; +}; + +/* CON 2 on SLM-1683 - microSD */ +&cp2_sdhci0 { + pinctrl-names = "default"; + pinctrl-0 = <&cp2_sdhci_pins>; + bus-width = <4>; + status = "okay"; +}; + +/* SLM-1521-V2, CON11 */ +&cp2_usb3_1 { + status = "okay"; +}; diff --git a/arch/arm/dts/cn9132-db-B.dts b/arch/arm/dts/cn9132-db-B.dts new file mode 100644 index 000000000000..f9d41235cbac --- /dev/null +++ b/arch/arm/dts/cn9132-db-B.dts @@ -0,0 +1,103 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 Marvell International Ltd. + */ + +#include "cn9131-db-B.dts" +#include "cn9132-db.dtsi" + +/ { + model = "Marvell CN9132 development board (CP NAND) setup(B)"; + compatible = "marvell,cn9132-db-B", "marvell,armada-ap806-quad", + "marvell,armada-ap806"; +}; + +&cp2_comphy { + phy0 { + phy-type = <COMPHY_TYPE_PEX0>; + }; + + phy1 { + phy-type = <COMPHY_TYPE_PEX0>; + }; + + phy2 { + phy-type = <COMPHY_TYPE_SATA0>; + }; + + phy3 { + phy-type = <COMPHY_TYPE_USB3_HOST1>; + }; + + phy4 { + phy-type = <COMPHY_TYPE_SFI0>; + phy-speed = <COMPHY_SPEED_10_3125G>; + }; + + phy5 { + phy-type = <COMPHY_TYPE_PEX2>; + }; +}; + +&cp2_ethernet { + status = "okay"; +}; + +/* SLM-1521-V2, CON9 */ +&cp2_eth0 { + status = "okay"; + phy-mode = "sfi"; +}; + +/* SLM-1521-V2, CON6 */ +&cp2_pcie0 { + num-lanes = <2>; + status = "okay"; +}; + +/* SLM-1521-V2, CON8 */ +&cp2_pcie2 { + num-lanes = <1>; + status = "okay"; +}; + +&cp2_pinctl { + /* MPP Bus: + * [0-26] GPIO + * [27] SATA0_PRESENT_ACTIVEn + * [28] SATA1_PRESENT_ACTIVEn + * [29-31, 33] GPIO (Default) + * [32,34] SMI + * [37-38] I2C0 + * [39-53] GPIO + * [54] SD_CRD_RSTn (out) + * [55] SD_CRD_DT (in) + * [56-62] SDIO + */ + /* 0 1 2 3 4 5 6 7 8 9 */ + pin-func = < 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 + 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 + 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x9 0x9 0x0 + 0x0 0x0 0x8 0x0 0x8 0x0 0x0 0x2 0x2 0x0 + 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 + 0x0 0x0 0x0 0x0 0xa 0xb 0xe 0xe 0xe 0xe + 0xe 0xe 0xe >; +}; + +/* SLM-1521-V2, CON4 */ +&cp2_sata0 { + status = "okay"; +}; + +/* CON 2 on SLM-1683 - microSD */ +&cp2_sdhci0 { + pinctrl-names = "default"; + pinctrl-0 = <&cp2_sdhci_pins>; + bus-width = <4>; + status = "okay"; +}; + +/* SLM-1521-V2, CON11 */ +&cp2_usb3_1 { + status = "okay"; +}; diff --git a/arch/arm/dts/cn9132-db.dtsi b/arch/arm/dts/cn9132-db.dtsi new file mode 100644 index 000000000000..6528f78b7b4e --- /dev/null +++ b/arch/arm/dts/cn9132-db.dtsi @@ -0,0 +1,130 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2018 Marvell International Ltd. + */ + +#undef CP110_NAME +#undef CP110_NUM +#undef CP110_PCIE_MEM_SIZE +#undef CP110_PCIEx_CPU_MEM_BASE +#undef CP110_PCIEx_BUS_MEM_BASE + +/* CP110-2 Settings */ +#define CP110_NAME cp2 +#define CP110_NUM 2 +#define CP110_PCIE_MEM_SIZE(iface) (0xf00000) +#define CP110_PCIEx_CPU_MEM_BASE(iface) (0xe5000000 + (iface) * 0x1000000) +#define CP110_PCIEx_BUS_MEM_BASE(iface) (CP110_PCIEx_CPU_MEM_BASE(iface)) + +#include "armada-cp110.dtsi" + +/ { + model = "Marvell CN9132 development board"; + compatible = "marvell,cn9132-db"; + + aliases { + gpio5 = &cp2_gpio0; + gpio6 = &cp2_gpio1; + }; + + cp2 { + config-space { + sdhci@780000 { + vqmmc-supply = <&cp2_reg_sd_vccq>; + }; + cp2_reg_usb3_vbus0: cp2_usb3_vbus@0 { + compatible = "regulator-fixed"; + regulator-name = "cp2-xhci0-vbus"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + startup-delay-us = <100000>; + regulator-force-boot-off; + gpio = <&cp2_gpio0 2 GPIO_ACTIVE_HIGH>; + }; + + cp2_reg_usb3_vbus1: cp2_usb3_vbus@1 { + compatible = "regulator-fixed"; + regulator-name = "cp2-xhci1-vbus"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + startup-delay-us = <100000>; + regulator-force-boot-off; + gpio = <&cp2_gpio0 3 GPIO_ACTIVE_HIGH>; + }; + cp2_reg_sd_vccq: cp2_sd_vccq@0 { + compatible = "regulator-gpio"; + regulator-name = "cp2_sd_vcc"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + /* cp2_mpp49 */ + gpios = <&cp2_gpio1 17 GPIO_ACTIVE_HIGH>; + states = <1800000 0x1 + 3300000 0x0>; + }; + cp2_reg_usb3_current_lim0: cp2_usb3_current_limiter@0 { + compatible = "regulator-fixed"; + regulator-min-microamp = <900000>; + regulator-max-microamp = <900000>; + regulator-force-boot-off; + gpio = <&cp2_gpio0 0 GPIO_ACTIVE_HIGH>; + }; + + cp2_reg_usb3_current_lim1: cp2_usb3_current_limiter@1 { + compatible = "regulator-fixed"; + regulator-min-microamp = <900000>; + regulator-max-microamp = <900000>; + regulator-force-boot-off; + gpio = <&cp2_gpio0 1 GPIO_ACTIVE_HIGH>; + }; + }; + }; +}; + +&cp2_i2c0 { + pinctrl-names = "default"; + pinctrl-0 = <&cp2_i2c0_pins>; + status = "okay"; + clock-frequency = <100000>; +}; + +&cp2_pcie0 { + /* non-prefetchable memory */ + ranges =<0x82000000 0 0xe5000000 0 0xe5000000 0 0x1000000>; +}; + +&cp2_pinctl { + compatible = "marvell,mvebu-pinctrl", + "marvell,cp115-standalone-pinctrl"; + bank-name ="cp2-110"; + + cp2_i2c0_pins: cp2-i2c-pins-0 { + marvell,pins = < 37 38 >; + marvell,function = <2>; + }; + cp2_sdhci_pins: cp2-sdhi-pins-0 { + marvell,pins = < 56 57 58 59 60 61 >; + marvell,function = <14>; + }; +}; + +&cp2_usb3_0 { + status = "okay"; + vbus-supply = <&cp2_reg_usb3_vbus0>; + current-limiter = <&cp2_reg_usb3_current_lim0>; + vbus-disable-delay = <500>; +}; + +&cp2_usb3_1 { + status = "okay"; + vbus-supply = <&cp2_reg_usb3_vbus1>; + current-limiter = <&cp2_reg_usb3_current_lim1>; + vbus-disable-delay = <500>; +}; + +&cp2_utmi0 { + status = "okay"; +}; + +&cp2_utmi1 { + status = "okay"; +};
This patch adds the base support for the Marvell Octeon TX2 CN9132 DB. Two versions are currently added via different defconfig's, one for booting via SPI NOR and one for NAND booting. Not all interfaces are supported fully yet.
board/Marvell/octeontx2_cn913x/MAINTAINERS | 2 + configs/mvebu_db_cn9132_defconfig | 88 +++++++++++++++++++++ configs/mvebu_db_cn9132_nand_defconfig | 89 ++++++++++++++++++++++ 3 files changed, 179 insertions(+) create mode 100644 configs/mvebu_db_cn9132_defconfig create mode 100644 configs/mvebu_db_cn9132_nand_defconfig
diff --git a/board/Marvell/octeontx2_cn913x/MAINTAINERS b/board/Marvell/octeontx2_cn913x/MAINTAINERS index d469e16ea753..5ce23c80f6b2 100644 --- a/board/Marvell/octeontx2_cn913x/MAINTAINERS +++ b/board/Marvell/octeontx2_cn913x/MAINTAINERS @@ -3,3 +3,5 @@ M: Kostya Porotchkin kostap@marvell.com S: Maintained F: board/Marvell/octeontx2_cn913x/ F: configs/mvebu_crb_cn9130_defconfig +F: configs/mvebu_db_cn9132_defconfig +F: configs/mvebu_db_cn9132_nand_defconfig diff --git a/configs/mvebu_db_cn9132_defconfig b/configs/mvebu_db_cn9132_defconfig new file mode 100644 index 000000000000..7efb690c66a4 --- /dev/null +++ b/configs/mvebu_db_cn9132_defconfig @@ -0,0 +1,88 @@ +CONFIG_ARM=y +CONFIG_ARCH_CPU_INIT=y +CONFIG_ARCH_MVEBU=y +CONFIG_SYS_TEXT_BASE=0x00000000 +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_NR_DRAM_BANKS=2 +CONFIG_TARGET_OCTEONTX2_CN913x=y +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_OFFSET=0x3f0000 +CONFIG_ENV_SECT_SIZE=0x10000 +CONFIG_DM_GPIO=y +CONFIG_DEBUG_UART_BASE=0xf0512000 +CONFIG_DEBUG_UART_CLOCK=200000000 +CONFIG_DEFAULT_DEVICE_TREE="cn9132-db-A" +CONFIG_DEBUG_UART=y +CONFIG_AHCI=y +CONFIG_DISTRO_DEFAULTS=y +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_USE_PREBOOT=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y +# CONFIG_DISPLAY_CPUINFO is not set +# CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_ARCH_EARLY_INIT_R=y +CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SYS_PROMPT="Marvell>> " +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_MTD=y +CONFIG_CMD_PCI=y +CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_TFTPPUT=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_TIME=y +CONFIG_CMD_MVEBU_BUBT=y +CONFIG_MVEBU_MMC_BOOT=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_MAC_PARTITION=y +CONFIG_ENV_OVERWRITE=y +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_SYS_MMC_ENV_DEV=1 +CONFIG_AHCI_MVEBU=y +CONFIG_DM_GPIO_LOOKUP_LABEL=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_MVTWSI=y +CONFIG_MISC=y +CONFIG_MVEBU_SAR=y +CONFIG_MMC_BROKEN_CD=y +CONFIG_DM_MMC=y +CONFIG_MMC_HS200_SUPPORT=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_XENON=y +CONFIG_MTD=y +CONFIG_DM_MTD=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SPI_FLASH_SFDP_SUPPORT=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_SST=y +CONFIG_SPI_FLASH_WINBOND=y +CONFIG_SPI_FLASH_MTD=y +CONFIG_PHY_MARVELL=y +CONFIG_PHY_GIGE=y +CONFIG_MVPP2=y +CONFIG_NVME=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_PCIE_DW_MVEBU=y +CONFIG_MVEBU_COMPHY_SUPPORT=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_ARMADA_8K=y +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_DEBUG_UART_ANNOUNCE=y +CONFIG_SYS_NS16550=y +CONFIG_KIRKWOOD_SPI=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_ETHER_ASIX=y +CONFIG_USB_ETHER_MCS7830=y +CONFIG_USB_ETHER_RTL8152=y +CONFIG_USB_ETHER_SMSC95XX=y diff --git a/configs/mvebu_db_cn9132_nand_defconfig b/configs/mvebu_db_cn9132_nand_defconfig new file mode 100644 index 000000000000..ee6e01091404 --- /dev/null +++ b/configs/mvebu_db_cn9132_nand_defconfig @@ -0,0 +1,89 @@ +CONFIG_ARM=y +CONFIG_ARCH_CPU_INIT=y +CONFIG_ARCH_MVEBU=y +CONFIG_SYS_TEXT_BASE=0x00000000 +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_NR_DRAM_BANKS=2 +CONFIG_TARGET_OCTEONTX2_CN913x=y +CONFIG_ENV_SIZE=0x40000 +CONFIG_ENV_OFFSET=0x3c0000 +CONFIG_DM_GPIO=y +CONFIG_DEBUG_UART_BASE=0xf0512000 +CONFIG_DEBUG_UART_CLOCK=200000000 +CONFIG_DEFAULT_DEVICE_TREE="cn9132-db-B" +CONFIG_DEBUG_UART=y +CONFIG_AHCI=y +CONFIG_DISTRO_DEFAULTS=y +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_USE_PREBOOT=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y +# CONFIG_DISPLAY_CPUINFO is not set +# CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_ARCH_EARLY_INIT_R=y +CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SYS_PROMPT="Marvell>> " +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_MTD=y +CONFIG_CMD_PCI=y +CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_TFTPPUT=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_TIME=y +CONFIG_CMD_MVEBU_BUBT=y +CONFIG_MVEBU_NAND_BOOT=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_MAC_PARTITION=y +CONFIG_ENV_OVERWRITE=y +CONFIG_ENV_IS_IN_NAND=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_SYS_MMC_ENV_DEV=1 +CONFIG_AHCI_MVEBU=y +CONFIG_DM_GPIO_LOOKUP_LABEL=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_MVTWSI=y +CONFIG_MISC=y +CONFIG_MVEBU_SAR=y +CONFIG_MMC_BROKEN_CD=y +CONFIG_DM_MMC=y +CONFIG_MMC_HS200_SUPPORT=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_XENON=y +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y +CONFIG_SYS_NAND_USE_FLASH_BBT=y +CONFIG_NAND_PXA3XX=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SPI_FLASH_SFDP_SUPPORT=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_SST=y +CONFIG_SPI_FLASH_WINBOND=y +CONFIG_SPI_FLASH_MTD=y +CONFIG_PHY_MARVELL=y +CONFIG_PHY_GIGE=y +CONFIG_MVPP2=y +CONFIG_NVME=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_PCIE_DW_MVEBU=y +CONFIG_MVEBU_COMPHY_SUPPORT=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_ARMADA_8K=y +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_DEBUG_UART_ANNOUNCE=y +CONFIG_SYS_NS16550=y +CONFIG_KIRKWOOD_SPI=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_ETHER_ASIX=y +CONFIG_USB_ETHER_MCS7830=y +CONFIG_USB_ETHER_RTL8152=y +CONFIG_USB_ETHER_SMSC95XX=y
Stefan Roese
