[U-Boot] [PATCH] MPC52xx, motionpro: update default configuration
Signed-off-by: Wolfgang Denk wd@denx.de --- include/configs/motionpro.h | 70 ++++++++++++++++-------------------------- 1 files changed, 27 insertions(+), 43 deletions(-)
diff --git a/include/configs/motionpro.h b/include/configs/motionpro.h index fa4310b..c47c815 100644 --- a/include/configs/motionpro.h +++ b/include/configs/motionpro.h @@ -45,29 +45,27 @@ #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_HOSTNAME
- /* * Command line configuration. */ #include <config_cmd_default.h>
#define CONFIG_CMD_ASKENV +#define CONFIG_CMD_BEDBUG +#define CONFIG_CMD_DATE #define CONFIG_CMD_DHCP -#define CONFIG_CMD_REGINFO -#define CONFIG_CMD_IMMAP +#define CONFIG_CMD_DTT +#define CONFIG_CMD_EEPROM #define CONFIG_CMD_ELF +#define CONFIG_CMD_FAT +#define CONFIG_CMD_I2C +#define CONFIG_CMD_IDE +#define CONFIG_CMD_IMMAP +#define CONFIG_CMD_JFFS2 #define CONFIG_CMD_MII -#define CONFIG_CMD_BEDBUG #define CONFIG_CMD_NET #define CONFIG_CMD_PING -#define CONFIG_CMD_IDE -#define CONFIG_CMD_FAT -#define CONFIG_CMD_JFFS2 -#define CONFIG_CMD_I2C -#define CONFIG_CMD_DATE -#define CONFIG_CMD_EEPROM -#define CONFIG_CMD_DTT - +#define CONFIG_CMD_REGINFO
/* * Serial console configuration @@ -77,7 +75,6 @@ #define CONFIG_BAUDRATE 115200 #define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200, 230400 }
- /* * Ethernet configuration */ @@ -99,11 +96,14 @@ #define CONFIG_AUTOBOOT_PROMPT "Autobooting in %d seconds, " \ "press "<Esc><Esc>" to stop\n", bootdelay
+#define CONFIG_CMDLINE_EDITING 1 /* add command line history */ +#define CONFIG_SYS_HUSH_PARSER 1 /* use "hush" command parser */ +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " + #define CONFIG_ETHADDR 00:50:C2:40:10:00 #define CONFIG_OVERWRITE_ETHADDR_ONCE 1 #define CONFIG_VERSION_VARIABLE 1 /* include version env variable */
- /* * Default environment settings */ @@ -115,21 +115,22 @@ "serverip=192.168.1.1\0" \ "gatewayip=192.168.1.1\0" \ "console=ttyPSC0,115200\0" \ - "u-boot_addr=100000\0" \ - "kernel_addr=200000\0" \ - "fdt_addr=400000\0" \ - "ramdisk_addr=500000\0" \ + "u-boot_addr=400000\0" \ + "kernel_addr=400000\0" \ + "fdt_addr=700000\0" \ + "ramdisk_addr=800000\0" \ "multi_image_addr=800000\0" \ - "rootpath=/opt/eldk-4.1/ppc_6xx\0" \ - "u-boot=/tftpboot/motionpro/u-boot.bin\0" \ - "bootfile=/tftpboot/motionpro/uImage\0" \ - "fdt_file=/tftpboot/motionpro/motionpro.dtb\0" \ - "ramdisk_file=/tftpboot/motionpro/uRamdisk\0" \ + "rootpath=/opt/eldk/ppc_6xx\0" \ + "u-boot=motionpro/u-boot.bin\0" \ + "bootfile=motionpro/uImage\0" \ + "fdt_file=motionpro/motionpro.dtb\0" \ + "ramdisk_file=motionpro/uRamdisk\0" \ "multi_image_file=kernel+initrd+dtb.img\0" \ "load=tftp ${u-boot_addr} ${u-boot}\0" \ - "update=prot off fff00000 fff3ffff; era fff00000 fff3ffff; " \ + "update=prot off fff00000 +${filesize};" \ + "era fff00000 +${filesize}; " \ "cp.b ${u-boot_addr} fff00000 ${filesize};" \ - "prot on fff00000 fff3ffff\0" \ + "prot on fff00000 +${filesize}\0" \ "ramargs=setenv bootargs root=/dev/ram rw\0" \ "nfsargs=setenv bootargs root=/dev/nfs rw " \ "nfsroot=${serverip}:${rootpath}\0" \ @@ -158,24 +159,20 @@ */ #define CONFIG_BOARD_EARLY_INIT_R 1
- /* * Low level configuration */
- /* * Clock configuration: SYS_XTALIN = 33MHz */ #define CONFIG_SYS_MPC5XXX_CLKIN 33000000
- /* * Set IPB speed to 100MHz */ #define CONFIG_SYS_IPBCLK_EQUALS_XLBCLK
- /* * Memory map */ @@ -184,7 +181,7 @@ * Setting MBAR to otherwise will cause system hang when using SmartDMA such * as network commands. */ -#define CONFIG_SYS_MBAR 0xf0000000 +#define CONFIG_SYS_MBAR 0xf0000000 #define CONFIG_SYS_SDRAM_BASE 0x00000000
/* @@ -216,7 +213,6 @@ #define CONFIG_SYS_MALLOC_LEN (1024 << 10) /* 1 MiB for malloc() */ #define CONFIG_SYS_BOOTMAPSZ (8 << 20) /* initial mem map for Linux */
- /* * Chip selects configuration */ @@ -249,7 +245,6 @@ #define CONFIG_SYS_CS_BURST 0x00000000 #define CONFIG_SYS_CS_DEADCYCLE 0x22222222
- /* * SDRAM configuration */ @@ -259,7 +254,6 @@ #define SDRAM_CONTROL 0x504f0000 #define SDRAM_MODE 0x00cd0000
- /* * Flash configuration */ @@ -297,7 +291,6 @@ #define CONFIG_SYS_ATA_STRIDE 4 #define CONFIG_DOS_PARTITION
- /* * I2C configuration */ @@ -306,7 +299,6 @@ #define CONFIG_SYS_I2C_SPEED 100000 /* 100 kHz */ #define CONFIG_SYS_I2C_SLAVE 0x7F
- /* * EEPROM configuration */ @@ -315,14 +307,12 @@ #define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 5 /* 2ms/cycle + 3ms extra */ #define CONFIG_SYS_I2C_MULTI_EEPROMS 1 /* 2 EEPROMs (addr:50,52) */
- /* * RTC configuration */ #define CONFIG_RTC_DS1337 1 #define CONFIG_SYS_I2C_RTC_ADDR 0x68
- /* * Status LED configuration */ @@ -344,14 +334,12 @@ extern void __led_toggle(led_id_t id); extern void __led_set(led_id_t id, int state); #endif /* __ASSEMBLY__ */
- /* * Temperature sensor */ #define CONFIG_DTT_LM75 1 #define CONFIG_DTT_SENSORS { 0x49 }
- /* * Environment settings */ @@ -379,13 +367,11 @@ extern void __led_set(led_id_t id, int state); */ #define CONFIG_SYS_GPS_PORT_CONFIG 0x1105a004
- /* * Motion-PRO's CPLD revision control register */ #define CPLD_REV_REGISTER (CONFIG_SYS_CS2_START + 0x06)
- /* * Miscellaneous configurable options */ @@ -404,7 +390,6 @@ extern void __led_set(led_id_t id, int state);
#define CONFIG_SYS_HZ 1000 /* decrementer freq: 1 ms ticks */
- /* * Various low-level settings */ @@ -416,7 +401,6 @@ extern void __led_set(led_id_t id, int state);
#define CONFIG_SYS_CACHELINE_SIZE 32 /* For MPC5xxx CPUs */
- /* Not needed for MPC 5xxx U-Boot, but used by tools/updater */ #define CONFIG_SYS_RESET_ADDRESS 0xfff00100
Applied.
