[U-Boot] [PATCH] mmc: Add JZ47xx SD/MMC controller driver
Add driver for the JZ47xx MSC controller.
Signed-off-by: Marek Vasut marex@denx.de Cc: Daniel Schwierzeck daniel.schwierzeck@gmail.com Cc: Paul Burton paul.burton@imgtec.com --- drivers/mmc/Kconfig | 6 + drivers/mmc/Makefile | 1 + drivers/mmc/jz_mmc.c | 443 +++++++++++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 450 insertions(+) create mode 100644 drivers/mmc/jz_mmc.c
diff --git a/drivers/mmc/Kconfig b/drivers/mmc/Kconfig index c80efc3..da9c86b 100644 --- a/drivers/mmc/Kconfig +++ b/drivers/mmc/Kconfig @@ -58,6 +58,12 @@ config MMC_UNIPHIER help This selects support for the SD/MMC Host Controller on UniPhier SoCs.
+config JZ47XX_MMC + bool "Ingenic JZ47xx SD/MMC Host Controller support" + depends on ARCH_JZ47XX + help + This selects support for the SD Card Controller on Ingenic JZ47xx SoCs. + config SANDBOX_MMC bool "Sandbox MMC support" depends on MMC && SANDBOX diff --git a/drivers/mmc/Makefile b/drivers/mmc/Makefile index 4d986cb..4c381c5 100644 --- a/drivers/mmc/Makefile +++ b/drivers/mmc/Makefile @@ -55,6 +55,7 @@ obj-$(CONFIG_SPEAR_SDHCI) += spear_sdhci.o obj-$(CONFIG_TEGRA_MMC) += tegra_mmc.o obj-$(CONFIG_MMC_UNIPHIER) += uniphier-sd.o obj-$(CONFIG_ZYNQ_SDHCI) += zynq_sdhci.o +obj-$(CONFIG_JZ47XX_MMC) += jz_mmc.o
ifdef CONFIG_SPL_BUILD obj-$(CONFIG_SPL_MMC_BOOT) += fsl_esdhc_spl.o diff --git a/drivers/mmc/jz_mmc.c b/drivers/mmc/jz_mmc.c new file mode 100644 index 0000000..68f5a21 --- /dev/null +++ b/drivers/mmc/jz_mmc.c @@ -0,0 +1,443 @@ +/* + * Ingenic JZ MMC driver + * + * Copyright (c) 2013 Imagination Technologies + * Author: Paul Burton paul.burton@imgtec.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <malloc.h> +#include <mmc.h> +#include <asm/io.h> +#include <asm/errno.h> +#include <asm/unaligned.h> +#include <mach/jz4780.h> + +/* Registers */ +#define MSC_STRPCL 0x000 +#define MSC_STAT 0x004 +#define MSC_CLKRT 0x008 +#define MSC_CMDAT 0x00c +#define MSC_RESTO 0x010 +#define MSC_RDTO 0x014 +#define MSC_BLKLEN 0x018 +#define MSC_NOB 0x01c +#define MSC_SNOB 0x020 +#define MSC_IMASK 0x024 +#define MSC_IREG 0x028 +#define MSC_CMD 0x02c +#define MSC_ARG 0x030 +#define MSC_RES 0x034 +#define MSC_RXFIFO 0x038 +#define MSC_TXFIFO 0x03c +#define MSC_LPM 0x040 +#define MSC_DMAC 0x044 +#define MSC_DMANDA 0x048 +#define MSC_DMADA 0x04c +#define MSC_DMALEN 0x050 +#define MSC_DMACMD 0x054 +#define MSC_CTRL2 0x058 +#define MSC_RTCNT 0x05c +#define MSC_DBG 0x0fc + +/* MSC Clock and Control Register (MSC_STRPCL) */ + +#define MSC_STRPCL_EXIT_MULTIPLE BIT(7) +#define MSC_STRPCL_EXIT_TRANSFER BIT(6) +#define MSC_STRPCL_START_READWAIT BIT(5) +#define MSC_STRPCL_STOP_READWAIT BIT(4) +#define MSC_STRPCL_RESET BIT(3) +#define MSC_STRPCL_START_OP BIT(2) +#define MSC_STRPCL_CLOCK_CONTROL_STOP BIT(0) +#define MSC_STRPCL_CLOCK_CONTROL_START BIT(1) + +/* MSC Status Register (MSC_STAT) */ + +#define MSC_STAT_AUTO_CMD_DONE BIT(31) +#define MSC_STAT_IS_RESETTING BIT(15) +#define MSC_STAT_SDIO_INT_ACTIVE BIT(14) +#define MSC_STAT_PRG_DONE BIT(13) +#define MSC_STAT_DATA_TRAN_DONE BIT(12) +#define MSC_STAT_END_CMD_RES BIT(11) +#define MSC_STAT_DATA_FIFO_AFULL BIT(10) +#define MSC_STAT_IS_READWAIT BIT(9) +#define MSC_STAT_CLK_EN BIT(8) +#define MSC_STAT_DATA_FIFO_FULL BIT(7) +#define MSC_STAT_DATA_FIFO_EMPTY BIT(6) +#define MSC_STAT_CRC_RES_ERR BIT(5) +#define MSC_STAT_CRC_READ_ERROR BIT(4) +#define MSC_STAT_CRC_WRITE_ERROR BIT(2) +#define MSC_STAT_CRC_WRITE_ERROR_NOSTS BIT(4) +#define MSC_STAT_TIME_OUT_RES BIT(1) +#define MSC_STAT_TIME_OUT_READ BIT(0) + +/* MSC Bus Clock Control Register (MSC_CLKRT) */ +#define MSC_CLKRT_CLK_RATE_MASK 0x7 + +/* MSC Command Sequence Control Register (MSC_CMDAT) */ + +#define MSC_CMDAT_IO_ABORT BIT(11) +#define MSC_CMDAT_BUS_WIDTH_1BIT (0x0 << 9) +#define MSC_CMDAT_BUS_WIDTH_4BIT (0x2 << 9) +#define MSC_CMDAT_DMA_EN BIT(8) +#define MSC_CMDAT_INIT BIT(7) +#define MSC_CMDAT_BUSY BIT(6) +#define MSC_CMDAT_STREAM_BLOCK BIT(5) +#define MSC_CMDAT_WRITE BIT(4) +#define MSC_CMDAT_DATA_EN BIT(3) +#define MSC_CMDAT_RESPONSE_MASK (0x7 << 0) +#define MSC_CMDAT_RESPONSE_NONE (0x0 << 0) /* No response */ +#define MSC_CMDAT_RESPONSE_R1 (0x1 << 0) /* Format R1 and R1b */ +#define MSC_CMDAT_RESPONSE_R2 (0x2 << 0) /* Format R2 */ +#define MSC_CMDAT_RESPONSE_R3 (0x3 << 0) /* Format R3 */ +#define MSC_CMDAT_RESPONSE_R4 (0x4 << 0) /* Format R4 */ +#define MSC_CMDAT_RESPONSE_R5 (0x5 << 0) /* Format R5 */ +#define MSC_CMDAT_RESPONSE_R6 (0x6 << 0) /* Format R6 */ + +/* MSC Interrupts Mask Register (MSC_IMASK) */ + +#define MSC_IMASK_TIME_OUT_RES BIT(9) +#define MSC_IMASK_TIME_OUT_READ BIT(8) +#define MSC_IMASK_SDIO BIT(7) +#define MSC_IMASK_TXFIFO_WR_REQ BIT(6) +#define MSC_IMASK_RXFIFO_RD_REQ BIT(5) +#define MSC_IMASK_END_CMD_RES BIT(2) +#define MSC_IMASK_PRG_DONE BIT(1) +#define MSC_IMASK_DATA_TRAN_DONE BIT(0) + + +/* MSC Interrupts Status Register (MSC_IREG) */ + +#define MSC_IREG_TIME_OUT_RES BIT(9) +#define MSC_IREG_TIME_OUT_READ BIT(8) +#define MSC_IREG_SDIO BIT(7) +#define MSC_IREG_TXFIFO_WR_REQ BIT(6) +#define MSC_IREG_RXFIFO_RD_REQ BIT(5) +#define MSC_IREG_END_CMD_RES BIT(2) +#define MSC_IREG_PRG_DONE BIT(1) +#define MSC_IREG_DATA_TRAN_DONE BIT(0) + +struct jz_mmc_priv { + struct mmc_config cfg; + void __iomem *regs; + u32 flags; /* FIXME */ +/* priv flags */ +#define JZ_MMC_BUS_WIDTH_MASK 0x3 +#define JZ_MMC_BUS_WIDTH_1 0x0 +#define JZ_MMC_BUS_WIDTH_4 0x2 +#define JZ_MMC_BUS_WIDTH_8 0x3 +#define JZ_MMC_SENT_INIT BIT(2) +}; + +static int jz_mmc_clock_rate(void) +{ + return 24000000; +} + +static int jz_mmc_send_cmd(struct mmc *mmc, struct mmc_cmd *cmd, + struct mmc_data *data) +{ + struct jz_mmc_priv *priv = mmc->priv; + u32 stat, mask, cmdat = 0; + + /* stop the clock */ + writel(MSC_STRPCL_CLOCK_CONTROL_STOP, priv->regs + MSC_STRPCL); + /* FIXME -- wait_bit() */ + while (readl(priv->regs + MSC_STAT) & MSC_STAT_CLK_EN); + + writel(0, priv->regs + MSC_DMAC); + + /* setup command */ + writel(cmd->cmdidx, priv->regs + MSC_CMD); + writel(cmd->cmdarg, priv->regs + MSC_ARG); + + if (data) { + /* setup data */ + cmdat |= MSC_CMDAT_DATA_EN; + if (data->flags & MMC_DATA_WRITE) + cmdat |= MSC_CMDAT_WRITE; + + writel(data->blocks, priv->regs + MSC_NOB); + writel(data->blocksize, priv->regs + MSC_BLKLEN); + } else { + writel(0, priv->regs + MSC_NOB); + writel(0, priv->regs + MSC_BLKLEN); + } + + /* setup response */ + switch (cmd->resp_type) { + case MMC_RSP_NONE: + break; + case MMC_RSP_R1: + case MMC_RSP_R1b: + cmdat |= MSC_CMDAT_RESPONSE_R1; + break; + case MMC_RSP_R2: + cmdat |= MSC_CMDAT_RESPONSE_R2; + break; + case MMC_RSP_R3: + cmdat |= MSC_CMDAT_RESPONSE_R3; + break; + default: + break; + } + + if (cmd->resp_type & MMC_RSP_BUSY) + cmdat |= MSC_CMDAT_BUSY; + + /* set init for the first command only */ + if (!(priv->flags & JZ_MMC_SENT_INIT)) { + cmdat |= MSC_CMDAT_INIT; + priv->flags |= JZ_MMC_SENT_INIT; + } + + cmdat |= (priv->flags & JZ_MMC_BUS_WIDTH_MASK) << 9; + + /* write the data setup */ + writel(cmdat, priv->regs + MSC_CMDAT); + + /* unmask interrupts */ + mask = 0xffffffff & ~(MSC_IMASK_END_CMD_RES | MSC_IMASK_TIME_OUT_RES); + if (data) { + mask &= ~MSC_IMASK_DATA_TRAN_DONE; + if (data->flags & MMC_DATA_WRITE) + mask &= ~MSC_IMASK_TXFIFO_WR_REQ; + else + mask &= ~(MSC_IMASK_RXFIFO_RD_REQ | MSC_IMASK_TIME_OUT_READ); + } + writel(mask, priv->regs + MSC_IMASK); + + /* clear interrupts */ + writel(0xffffffff, priv->regs + MSC_IREG); + + /* start the command (& the clock) */ + writel(MSC_STRPCL_START_OP | MSC_STRPCL_CLOCK_CONTROL_START, priv->regs + MSC_STRPCL); + + /* wait for completion */ + /* FIXME -- wait_bit() */ + while (!(stat = (readl(priv->regs + MSC_IREG) & (MSC_IREG_END_CMD_RES | MSC_IREG_TIME_OUT_RES)))) + mdelay(1); + writel(stat, priv->regs + MSC_IREG); + if (stat & MSC_IREG_TIME_OUT_RES) + return TIMEOUT; + + if (cmd->resp_type & MMC_RSP_PRESENT) { + /* read the response */ + if (cmd->resp_type & MMC_RSP_136) { + u16 a, b, c, i; + a = readw(priv->regs + MSC_RES); + for (i = 0; i < 4; i++) { + b = readw(priv->regs + MSC_RES); + c = readw(priv->regs + MSC_RES); + cmd->response[i] = (a << 24) | (b << 8) | (c >> 8); + a = c; + } + } else { + cmd->response[0] = readw(priv->regs + MSC_RES) << 24; + cmd->response[0] |= readw(priv->regs + MSC_RES) << 8; + cmd->response[0] |= readw(priv->regs + MSC_RES) & 0xff; + } + } + + if (data && (data->flags & MMC_DATA_WRITE)) { + /* write the data */ + int sz = DIV_ROUND_UP(data->blocks * data->blocksize, 4); + const void *buf = data->src; + + while (sz--) { + u32 val = get_unaligned_le32(buf); + while (!(readl(priv->regs + MSC_IREG) & MSC_IREG_TXFIFO_WR_REQ)); + writel(val, priv->regs + MSC_TXFIFO); + buf += 4; + } + } else if (data && (data->flags & MMC_DATA_READ)) { + /* read the data */ + int sz = data->blocks * data->blocksize; + void *buf = data->dest; + + do { + stat = readl(priv->regs + MSC_STAT); + + if (stat & MSC_STAT_TIME_OUT_READ) + return TIMEOUT; + if (stat & MSC_STAT_CRC_READ_ERROR) + return COMM_ERR; + if (stat & MSC_STAT_DATA_FIFO_EMPTY) { + udelay(10); + continue; + } + do { + u32 val = readl(priv->regs + MSC_RXFIFO); + + if (sz == 1) + *(u8 *)buf = (u8)val; + else if (sz == 2) + put_unaligned_le16(val, buf); + else if (sz >= 4) + put_unaligned_le32(val, buf); + buf += 4; + sz -= 4; + stat = readl(priv->regs + MSC_STAT); + } while (!(stat & MSC_STAT_DATA_FIFO_EMPTY)); + } while (!(stat & MSC_STAT_DATA_TRAN_DONE)); + } + + return 0; +} + +static void jz_mmc_set_ios(struct mmc *mmc) +{ + struct jz_mmc_priv *priv = mmc->priv; + u32 real_rate = jz_mmc_clock_rate(); + u8 clk_div = 0; + + /* calculate clock divide */ + while ((real_rate > mmc->clock) && (clk_div < 7)) { + real_rate >>= 1; + clk_div++; + } + writel(clk_div & MSC_CLKRT_CLK_RATE_MASK, priv->regs + MSC_CLKRT); + + /* set the bus width for the next command */ + priv->flags &= ~JZ_MMC_BUS_WIDTH_MASK; + if (mmc->bus_width == 8) + priv->flags |= JZ_MMC_BUS_WIDTH_8; + else if (mmc->bus_width == 4) + priv->flags |= JZ_MMC_BUS_WIDTH_4; + else + priv->flags |= JZ_MMC_BUS_WIDTH_1; +} + +static int jz_mmc_core_init(struct mmc *mmc) +{ + struct jz_mmc_priv *priv = mmc->priv; + + /* Reset */ + writel(MSC_STRPCL_RESET, priv->regs + MSC_STRPCL); + /* FIXME -- wait_bit() */ + while (readl(priv->regs + MSC_STAT) & MSC_STAT_IS_RESETTING); + + /* Maximum timeouts */ + writel(0xffff, priv->regs + MSC_RESTO); + writel(0xffffffff, priv->regs + MSC_RDTO); + + /* Enable low power mode */ + writel(0x1, priv->regs + MSC_LPM); + + return 0; +} + +static const struct mmc_ops jz_msc_ops = { + .send_cmd = jz_mmc_send_cmd, + .set_ios = jz_mmc_set_ios, + .init = jz_mmc_core_init, +}; + +#ifdef CONFIG_MMC_TINY +static struct jz_mmc_priv jz_mmc_priv_static = { + .cfg = { + .name = "MSC", + .ops = &jz_msc_ops, + + .voltages = MMC_VDD_27_28 | MMC_VDD_28_29 | MMC_VDD_29_30 | + MMC_VDD_30_31 | MMC_VDD_31_32 | MMC_VDD_32_33 | + MMC_VDD_33_34 | MMC_VDD_34_35 | MMC_VDD_35_36, + .host_caps = MMC_MODE_4BIT | MMC_MODE_HS_52MHz | MMC_MODE_HS, + + .f_min = 375000, + .f_max = 48000000, + .b_max = CONFIG_SYS_MMC_MAX_BLK_COUNT, + }, +}; + +int jz_mmc_init(void __iomem *base) +{ + struct mmc *mmc; + + jz_mmc_priv_static.regs = base; + + mmc = mmc_create(&jz_mmc_priv_static.cfg, &jz_mmc_priv_static); + + return mmc ? 0 : -ENODEV; +} +#endif + +#ifdef CONFIG_DM_MMC +#include <dm.h> +DECLARE_GLOBAL_DATA_PTR; + +static int jz_mmc_ofdata_to_platdata(struct udevice *dev) +{ + struct jz_mmc_priv *priv = dev_get_priv(dev); + const void *fdt = gd->fdt_blob; + int node = dev->of_offset; + struct mmc_config *cfg; + int val; + + priv->regs = map_physmem(dev_get_addr(dev), 0x100, MAP_NOCACHE); + cfg = &priv->cfg; + + cfg->host_caps = MMC_MODE_HS_52MHz | MMC_MODE_HS; + val = fdtdec_get_int(fdt, node, "bus-width", -1); + if (val < 0) { + printf("error: bus-width property missing\n"); + return -ENOENT; + } + + switch (val) { + case 0x8: + cfg->host_caps |= MMC_MODE_8BIT; + case 0x4: + cfg->host_caps |= MMC_MODE_4BIT; + break; + default: + printf("error: invalid bus-width property\n"); + return -ENOENT; + } + + cfg->f_min = 400000; + cfg->f_max = fdtdec_get_int(fdt, node, "max-frequency", 52000000); + + + + cfg->voltages = MMC_VDD_32_33 | MMC_VDD_33_34 | MMC_VDD_165_195; + cfg->b_max = CONFIG_SYS_MMC_MAX_BLK_COUNT; + + return 0; +} + +static int jz_mmc_probe(struct udevice *dev) +{ + struct mmc_uclass_priv *upriv = dev_get_uclass_priv(dev); + struct jz_mmc_priv *priv = dev_get_priv(dev); + struct mmc_config *cfg = &priv->cfg; + struct mmc *mmc; + + cfg->name = "MSC"; + cfg->ops = &jz_msc_ops; + + mmc = mmc_create(cfg, priv); + if (!mmc) + return -ENODEV; + + mmc->dev = dev; + upriv->mmc = mmc; + + return 0; +} +static const struct udevice_id jz_mmc_ids[] = { + { .compatible = "ingenic,jz4780-mmc" }, + { } +}; + +U_BOOT_DRIVER(jz_mmc_drv) = { + .name = "jz_mmc", + .id = UCLASS_MMC, + .of_match = jz_mmc_ids, + .ofdata_to_platdata = jz_mmc_ofdata_to_platdata, + .probe = jz_mmc_probe, + .priv_auto_alloc_size = sizeof(struct jz_mmc_priv), +}; +#endif
