[U-Boot] [PATCH 01/12] ARM: zynq: Enable the Neon instructions
From: Siva Durga Prasad Paladugu siva.durga.paladugu@xilinx.com
Added the lowlevel_init to enable the Neon instructions.
Initially the u-boot was causing undefined instruction exception if loaded through tcl, and working fine if loaded through FSBL. The exception was causing in convertion formula of given time to ticks. It was because, the Neon instructions were disabled and hence causing the undefined exception. In FSBL case, the FSBL was enabling the Neon instructions. Hence, added the lowlevel_init to enable the Neon instructions.
Signed-off-by: Siva Durga Prasad Paladugu sivadur@xilinx.com Acked-by: Radhey Shyam Pandey radheys@xilinx.com Signed-off-by: Michal Simek michal.simek@xilinx.com ---
arch/arm/cpu/armv7/zynq/Makefile | 1 + arch/arm/cpu/armv7/zynq/cpu.c | 3 --- arch/arm/cpu/armv7/zynq/lowlevel_init.S | 26 ++++++++++++++++++++++++++ 3 files changed, 27 insertions(+), 3 deletions(-) create mode 100644 arch/arm/cpu/armv7/zynq/lowlevel_init.S
diff --git a/arch/arm/cpu/armv7/zynq/Makefile b/arch/arm/cpu/armv7/zynq/Makefile index 3363a3c71b98..901f2ce4cbb7 100644 --- a/arch/arm/cpu/armv7/zynq/Makefile +++ b/arch/arm/cpu/armv7/zynq/Makefile @@ -13,4 +13,5 @@ obj-y += cpu.o obj-y += ddrc.o obj-y += slcr.o obj-y += clk.o +obj-y += lowlevel_init.o obj-$(CONFIG_SPL_BUILD) += spl.o diff --git a/arch/arm/cpu/armv7/zynq/cpu.c b/arch/arm/cpu/armv7/zynq/cpu.c index 816d0c5da7a5..d1bfec9f715e 100644 --- a/arch/arm/cpu/armv7/zynq/cpu.c +++ b/arch/arm/cpu/armv7/zynq/cpu.c @@ -10,9 +10,6 @@ #include <asm/arch/sys_proto.h> #include <asm/arch/hardware.h>
-void lowlevel_init(void) -{ -}
#define ZYNQ_SILICON_VER_MASK 0xF0000000 #define ZYNQ_SILICON_VER_SHIFT 28 diff --git a/arch/arm/cpu/armv7/zynq/lowlevel_init.S b/arch/arm/cpu/armv7/zynq/lowlevel_init.S new file mode 100644 index 000000000000..6d714b711cbe --- /dev/null +++ b/arch/arm/cpu/armv7/zynq/lowlevel_init.S @@ -0,0 +1,26 @@ +/* + * Copyright (C) 2013 Xilinx, Inc. All rights reserved. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <asm-offsets.h> +#include <config.h> +#include <linux/linkage.h> + +ENTRY(lowlevel_init) + + /* Enable the the VFP */ + mrc p15, 0, r1, c1, c0, 2 + orr r1, r1, #(0x3 << 20) + orr r1, r1, #(0x3 << 20) + mcr p15, 0, r1, c1, c0, 2 + isb + fmrx r1, FPEXC + orr r1,r1, #(1<<30) + fmxr FPEXC, r1 + + /* Move back to caller */ + mov pc, lr + +ENDPROC(lowlevel_init) -- 1.8.2.3
Trivial patch.
arch/arm/cpu/armv7/zynq/cpu.c | 1 - 1 file changed, 1 deletion(-)
diff --git a/arch/arm/cpu/armv7/zynq/cpu.c b/arch/arm/cpu/armv7/zynq/cpu.c index d1bfec9f715e..914b1feb6833 100644 --- a/arch/arm/cpu/armv7/zynq/cpu.c +++ b/arch/arm/cpu/armv7/zynq/cpu.c @@ -10,7 +10,6 @@ #include <asm/arch/sys_proto.h> #include <asm/arch/hardware.h>
- #define ZYNQ_SILICON_VER_MASK 0xF0000000 #define ZYNQ_SILICON_VER_SHIFT 28
-- 1.8.2.3
Setup half of memory from ram_size for ECC case. All the time the same board can be configured with or without ECC. Based on ECC case detection use half of memory with the same configuration.
arch/arm/cpu/armv7/zynq/ddrc.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/arm/cpu/armv7/zynq/ddrc.c b/arch/arm/cpu/armv7/zynq/ddrc.c index d74f8dbbc45d..5b20accbcb17 100644 --- a/arch/arm/cpu/armv7/zynq/ddrc.c +++ b/arch/arm/cpu/armv7/zynq/ddrc.c @@ -42,6 +42,8 @@ void zynq_ddrc_init(void) */ /* cppcheck-suppress nullPointer */ memset((void *)0, 0, 1 * 1024 * 1024); + + gd->ram_size /= 2; } else { puts("ECC disabled "); } -- 1.8.2.3
Set only the 0-3 bits of the FPGA_RST_CTRL register as other bits should not be set to 1.
Signed-off-by: Siva Durga Prasad Paladugu sivadur@xilinx.com Reviewed-by: Peter Crosthwaite peter.crosthwaite@xilinx.com Reviewed-by: Nathan Rossi nathan.rossi@xilinx.com Signed-off-by: Michal Simek michal.simek@xilinx.com ---
arch/arm/cpu/armv7/zynq/slcr.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/cpu/armv7/zynq/slcr.c b/arch/arm/cpu/armv7/zynq/slcr.c index 934ccc31c86f..2521589c07e9 100644 --- a/arch/arm/cpu/armv7/zynq/slcr.c +++ b/arch/arm/cpu/armv7/zynq/slcr.c @@ -132,7 +132,7 @@ void zynq_slcr_devcfg_disable(void) zynq_slcr_unlock();
/* Disable AXI interface by asserting FPGA resets */ - writel(0xFFFFFFFF, &slcr_base->fpga_rst_ctrl); + writel(0xF, &slcr_base->fpga_rst_ctrl);
/* Set Level Shifters DT618760 */ writel(0xA, &slcr_base->lvl_shftr_en); -- 1.8.2.3
Use full boot mode list in SPL.
arch/arm/cpu/armv7/zynq/spl.c | 9 +++++++++ arch/arm/include/asm/arch-zynq/hardware.h | 2 ++ 2 files changed, 11 insertions(+)
diff --git a/arch/arm/cpu/armv7/zynq/spl.c b/arch/arm/cpu/armv7/zynq/spl.c index 31627f970efb..3fb876d07ab8 100644 --- a/arch/arm/cpu/armv7/zynq/spl.c +++ b/arch/arm/cpu/armv7/zynq/spl.c @@ -46,12 +46,21 @@ u32 spl_boot_device(void) mode = BOOT_DEVICE_SPI; break; #endif + case ZYNQ_BM_NAND: + mode = BOOT_DEVICE_NAND; + break; + case ZYNQ_BM_NOR: + mode = BOOT_DEVICE_NOR; + break; #ifdef CONFIG_SPL_MMC_SUPPORT case ZYNQ_BM_SD: puts("mmc boot\n"); mode = BOOT_DEVICE_MMC1; break; #endif + case ZYNQ_BM_JTAG: + mode = BOOT_DEVICE_RAM; + break; default: puts("Unsupported boot mode selected\n"); hang(); diff --git a/arch/arm/include/asm/arch-zynq/hardware.h b/arch/arm/include/asm/arch-zynq/hardware.h index 2aede0c552c6..8dfedd7a94ce 100644 --- a/arch/arm/include/asm/arch-zynq/hardware.h +++ b/arch/arm/include/asm/arch-zynq/hardware.h @@ -28,7 +28,9 @@
/* Bootmode setting values */ #define ZYNQ_BM_MASK 0x7 +#define ZYNQ_BM_QSPI 0x1 #define ZYNQ_BM_NOR 0x2 +#define ZYNQ_BM_NAND 0x4 #define ZYNQ_BM_SD 0x5 #define ZYNQ_BM_JTAG 0x0
-- 1.8.2.3
Add missing addresses to the list.
arch/arm/include/asm/arch-zynq/hardware.h | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/arch/arm/include/asm/arch-zynq/hardware.h b/arch/arm/include/asm/arch-zynq/hardware.h index 8dfedd7a94ce..e2e0b7321ad4 100644 --- a/arch/arm/include/asm/arch-zynq/hardware.h +++ b/arch/arm/include/asm/arch-zynq/hardware.h @@ -21,6 +21,9 @@ #define ZYNQ_I2C_BASEADDR1 0xE0005000 #define ZYNQ_SPI_BASEADDR0 0xE0006000 #define ZYNQ_SPI_BASEADDR1 0xE0007000 +#define ZYNQ_QSPI_BASEADDR 0xE000D000 +#define ZYNQ_SMC_BASEADDR 0xE000E000 +#define ZYNQ_NAND_BASEADDR 0xE1000000 #define ZYNQ_DDRC_BASEADDR 0xF8006000 #define ZYNQ_EFUSE_BASEADDR 0xF800D000 #define ZYNQ_USB_BASEADDR0 0xE0002000 -- 1.8.2.3
Show board information in bootlog and enable it by default.
board/xilinx/zynq/board.c | 8 ++++++++ include/configs/zynq-common.h | 1 + 2 files changed, 9 insertions(+)
diff --git a/board/xilinx/zynq/board.c b/board/xilinx/zynq/board.c index 258632e52b0b..e13105654514 100644 --- a/board/xilinx/zynq/board.c +++ b/board/xilinx/zynq/board.c @@ -87,6 +87,14 @@ int board_late_init(void) return 0; }
+#ifdef CONFIG_DISPLAY_BOARDINFO +int checkboard(void) +{ + puts("Board:\tXilinx Zynq\n"); + return 0; +} +#endif + int board_eth_init(bd_t *bis) { u32 ret = 0; diff --git a/include/configs/zynq-common.h b/include/configs/zynq-common.h index 87b4fffeb9fb..3a62ec75dbc9 100644 --- a/include/configs/zynq-common.h +++ b/include/configs/zynq-common.h @@ -181,6 +181,7 @@ #define CONFIG_CMDLINE_EDITING #define CONFIG_AUTO_COMPLETE #define CONFIG_BOARD_LATE_INIT +#define CONFIG_DISPLAY_BOARDINFO #define CONFIG_SYS_LONGHELP #define CONFIG_CLOCKS #define CONFIG_CMD_CLK -- 1.8.2.3
Based on: "am335x_evm: Enable CMD_EXT4 and CMD_FS_GENERIC, add bootpart to env" (sha1: 73a27a84e58cb99b4e64ed6a35eab5bc61f44f29)
Fix filesystem specific commands for loading.
include/configs/zynq-common.h | 5 +++-- 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/include/configs/zynq-common.h b/include/configs/zynq-common.h index 3a62ec75dbc9..f968e7666dc1 100644 --- a/include/configs/zynq-common.h +++ b/include/configs/zynq-common.h @@ -100,6 +100,7 @@ # define CONFIG_DOS_PARTITION # define CONFIG_CMD_EXT4 # define CONFIG_CMD_EXT4_WRITE +# define CONFIG_CMD_FS_GENERIC #endif
#define CONFIG_SYS_I2C_ZYNQ @@ -159,14 +160,14 @@ "cp.b ${nor_flash_off} ${load_addr} ${fit_size} && " \ "bootm ${load_addr}\0" \ "sdboot=echo Copying FIT from SD to RAM... && " \ - "fatload mmc 0 ${load_addr} ${fit_image} && " \ + "load mmc 0 ${load_addr} ${fit_image} && " \ "bootm ${load_addr}\0" \ "jtagboot=echo TFTPing FIT to RAM... && " \ "tftpboot ${load_addr} ${fit_image} && " \ "bootm ${load_addr}\0" \ "usbboot=if usb start; then " \ "echo Copying FIT from USB to RAM... && " \ - "fatload usb 0 ${load_addr} ${fit_image} && " \ + "load usb 0 ${load_addr} ${fit_image} && " \ "bootm ${load_addr}\0" \ "fi\0"
-- 1.8.2.3
No functional chagnes.
include/configs/zynq-common.h | 11 +++++------ 1 file changed, 5 insertions(+), 6 deletions(-)
diff --git a/include/configs/zynq-common.h b/include/configs/zynq-common.h index f968e7666dc1..cbafba1cc395 100644 --- a/include/configs/zynq-common.h +++ b/include/configs/zynq-common.h @@ -47,6 +47,11 @@ # define CONFIG_SYS_FAULT_ECHO_LINK_DOWN # define CONFIG_PHYLIB # define CONFIG_PHY_MARVELL +# define CONFIG_BOOTP_SERVERIP +# define CONFIG_BOOTP_BOOTPATH +# define CONFIG_BOOTP_GATEWAY +# define CONFIG_BOOTP_HOSTNAME +# define CONFIG_BOOTP_MAY_FAIL #endif
/* SPI */ @@ -122,12 +127,6 @@ # define CONFIG_SYS_EEPROM_SIZE 1024 /* Bytes */ #endif
-#define CONFIG_BOOTP_SERVERIP -#define CONFIG_BOOTP_BOOTPATH -#define CONFIG_BOOTP_GATEWAY -#define CONFIG_BOOTP_HOSTNAME -#define CONFIG_BOOTP_MAY_FAIL - /* Total Size of Environment Sector */ #define CONFIG_ENV_SIZE (128 << 10)
-- 1.8.2.3
Dont send always emio value as zero for zynq_gem_initialize send it based on config.
Signed-off-by: Siva Durga Prasad Paladugu sivadur@xilinx.com Signed-off-by: Michal Simek michal.simek@xilinx.com ---
board/xilinx/zynq/board.c | 6 ++++-- include/configs/zynq-common.h | 6 ++++++ 2 files changed, 10 insertions(+), 2 deletions(-)
diff --git a/board/xilinx/zynq/board.c b/board/xilinx/zynq/board.c index e13105654514..47f85c7fb42a 100644 --- a/board/xilinx/zynq/board.c +++ b/board/xilinx/zynq/board.c @@ -119,11 +119,13 @@ int board_eth_init(bd_t *bis) #if defined(CONFIG_ZYNQ_GEM) # if defined(CONFIG_ZYNQ_GEM0) ret |= zynq_gem_initialize(bis, ZYNQ_GEM_BASEADDR0, - CONFIG_ZYNQ_GEM_PHY_ADDR0, 0); + CONFIG_ZYNQ_GEM_PHY_ADDR0, + CONFIG_ZYNQ_GEM_EMIO0); # endif # if defined(CONFIG_ZYNQ_GEM1) ret |= zynq_gem_initialize(bis, ZYNQ_GEM_BASEADDR1, - CONFIG_ZYNQ_GEM_PHY_ADDR1, 0); + CONFIG_ZYNQ_GEM_PHY_ADDR1, + CONFIG_ZYNQ_GEM_EMIO1); # endif #endif return ret; diff --git a/include/configs/zynq-common.h b/include/configs/zynq-common.h index cbafba1cc395..0359e3de917e 100644 --- a/include/configs/zynq-common.h +++ b/include/configs/zynq-common.h @@ -52,6 +52,12 @@ # define CONFIG_BOOTP_GATEWAY # define CONFIG_BOOTP_HOSTNAME # define CONFIG_BOOTP_MAY_FAIL +# if !defined(CONFIG_ZYNQ_GEM_EMIO0) +# define CONFIG_ZYNQ_GEM_EMIO0 0 +# endif +# if !defined(CONFIG_ZYNQ_GEM_EMIO1) +# define CONFIG_ZYNQ_GEM_EMIO1 0 +# endif #endif
/* SPI */ -- 1.8.2.3
Enable DFU functionality in zynq. This DFU functionality helps us to load linux images on to DDR and can boot linux using bootm. In order to load images the user should run dfu command "dfu 0 ram 0" from u-boot prompt and then send the images from host.
The malloc size has been increased to match the DFU buffer requirements.
include/configs/zynq-common.h | 49 +++++++++++++++++++++++++++++++++++++++++-- 1 file changed, 47 insertions(+), 2 deletions(-)
diff --git a/include/configs/zynq-common.h b/include/configs/zynq-common.h index 0359e3de917e..62adfc84af03 100644 --- a/include/configs/zynq-common.h +++ b/include/configs/zynq-common.h @@ -101,6 +101,50 @@ # define CONFIG_USB_ULPI # define CONFIG_EHCI_IS_TDI # define CONFIG_USB_MAX_CONTROLLER_COUNT 2 + +# define CONFIG_CI_UDC /* ChipIdea CI13xxx UDC */ +# define CONFIG_USB_GADGET +# define CONFIG_USB_GADGET_DUALSPEED +# define CONFIG_USBDOWNLOAD_GADGET +# define CONFIG_SYS_DFU_DATA_BUF_SIZE 0x600000 +# define DFU_DEFAULT_POLL_TIMEOUT 300 +# define CONFIG_DFU_FUNCTION +# define CONFIG_DFU_RAM +# define CONFIG_USB_GADGET_VBUS_DRAW 2 +# define CONFIG_G_DNL_VENDOR_NUM 0x03FD +# define CONFIG_G_DNL_PRODUCT_NUM 0x0300 +# define CONFIG_G_DNL_MANUFACTURER "Xilinx" +# define CONFIG_USB_GADGET +# define CONFIG_USB_CABLE_CHECK +# define CONFIG_CMD_DFU +# define DFU_ALT_INFO_RAM \ + "dfu_ram_info=" \ + "set dfu_alt_info " \ + "${kernel_image} ram 0x3000000 0x500000\\;" \ + "${devicetree_image} ram 0x2A00000 0x20000\\;" \ + "${ramdisk_image} ram 0x2000000 0x600000\0" \ + "dfu_ram=run dfu_ram_info && dfu 0 ram 0\0" + +# if defined(CONFIG_ZYNQ_SDHCI0) || defined(CONFIG_ZYNQ_SDHCI1) +# define CONFIG_DFU_MMC +# define DFU_ALT_INFO_MMC \ + "dfu_mmc_info=" \ + "set dfu_alt_info " \ + "${kernel_image} fat 0 1\\;" \ + "${devicetree_image} fat 0 1\\;" \ + "${ramdisk_image} fat 0 1\0" \ + "dfu_mmc=run dfu_mmc_info && dfu 0 mmc 0\0" +# define DFU_ALT_INFO \ + DFU_ALT_INFO_RAM \ + DFU_ALT_INFO_MMC +# else +# define DFU_ALT_INFO \ + DFU_ALT_INFO_RAM +# endif +#endif + +#if !defined(DFU_ALT_INFO) +# define DFU_ALT_INFO #endif
#if defined(CONFIG_ZYNQ_SDHCI) || defined(CONFIG_ZYNQ_USB) @@ -174,7 +218,8 @@ "echo Copying FIT from USB to RAM... && " \ "load usb 0 ${load_addr} ${fit_image} && " \ "bootm ${load_addr}\0" \ - "fi\0" + "fi\0" \ + DFU_ALT_INFO
#define CONFIG_BOOTCOMMAND "run $modeboot" #define CONFIG_BOOTDELAY 3 /* -1 to Disable autoboot */ @@ -205,7 +250,7 @@ #define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE #define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_SDRAM_BASE + 0x1000)
-#define CONFIG_SYS_MALLOC_LEN 0x400000 +#define CONFIG_SYS_MALLOC_LEN 0xC00000 #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_SDRAM_BASE #define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_MALLOC_LEN #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_INIT_RAM_ADDR + \ -- 1.8.2.3
updated the zynq config to support the lthor download protocol. This lthor functionality helps us to load linux images on to DDR/MMC and can boot linux using bootm. In order to load images the user should run lthor command run "thor_ram" from u-boot prompt and then send the images from host using lthor utility.
Define g_dnl_bind_fixup for zynq so that correct vendor and product ids assigned incase of DFU and lthor.
include/configs/zynq-common.h | 9 +++++++-- 1 file changed, 7 insertions(+), 2 deletions(-)
diff --git a/include/configs/zynq-common.h b/include/configs/zynq-common.h index 62adfc84af03..2d28e89dd367 100644 --- a/include/configs/zynq-common.h +++ b/include/configs/zynq-common.h @@ -117,13 +117,16 @@ # define CONFIG_USB_GADGET # define CONFIG_USB_CABLE_CHECK # define CONFIG_CMD_DFU +# define CONFIG_CMD_THOR_DOWNLOAD +# define CONFIG_THOR_FUNCTION # define DFU_ALT_INFO_RAM \ "dfu_ram_info=" \ "set dfu_alt_info " \ "${kernel_image} ram 0x3000000 0x500000\\;" \ "${devicetree_image} ram 0x2A00000 0x20000\\;" \ "${ramdisk_image} ram 0x2000000 0x600000\0" \ - "dfu_ram=run dfu_ram_info && dfu 0 ram 0\0" + "dfu_ram=run dfu_ram_info && dfu 0 ram 0\0" \ + "thor_ram=run dfu_ram_info && thordown 0 ram 0\0"
# if defined(CONFIG_ZYNQ_SDHCI0) || defined(CONFIG_ZYNQ_SDHCI1) # define CONFIG_DFU_MMC @@ -133,7 +136,9 @@ "${kernel_image} fat 0 1\\;" \ "${devicetree_image} fat 0 1\\;" \ "${ramdisk_image} fat 0 1\0" \ - "dfu_mmc=run dfu_mmc_info && dfu 0 mmc 0\0" + "dfu_mmc=run dfu_mmc_info && dfu 0 mmc 0\0" \ + "thor_mmc=run dfu_mmc_info && thordown 0 mmc 0\0" + # define DFU_ALT_INFO \ DFU_ALT_INFO_RAM \ DFU_ALT_INFO_MMC -- 1.8.2.3
Michal Simek
