[U-Boot] [PATCH v2 0/3] Add Bluewater Systems Snapper 9260/9G20 module support
Add support for Bluewater Systems Snapper9260/9G20 modules. The modules are based on the AT91SAM9260 and AT91SAM9G20 processors respectively and support NAND flash and Ethernet.
This patches apply against the rework101229 branch of git://git.denx.de/u-boot-atmel.git.
Changes since v1: - Updated for recent at91 changes - Use CONFIG_AT91FAMILY in soft_i2c driver - Fixed missing snapper9260.h config file - Add config to boards.cfg not Makefile - Removed config.mk (now in snapper9260.h)
Ryan Mallon (3): Fix at91 includes in soft_i2c driver Add support for Bluewater Systems Snapper 9260 and 9G20 modules Add Bluewater Systems Snapper 9260 and 9G20 modules to top-level boards.cfg
board/bluewater/snapper9260/Makefile | 53 ++++++++ board/bluewater/snapper9260/snapper9260.c | 169 +++++++++++++++++++++++++ boards.cfg | 2 + drivers/i2c/soft_i2c.c | 4 +- include/configs/snapper9260.h | 191 +++++++++++++++++++++++++++++ 5 files changed, 416 insertions(+), 3 deletions(-) create mode 100644 board/bluewater/snapper9260/Makefile create mode 100644 board/bluewater/snapper9260/snapper9260.c create mode 100644 include/configs/snapper9260.h
Signed-off-by: Ryan Mallon ryan@bluewatersys.com --- drivers/i2c/soft_i2c.c | 4 +--- 1 files changed, 1 insertions(+), 3 deletions(-)
diff --git a/drivers/i2c/soft_i2c.c b/drivers/i2c/soft_i2c.c index 1a1809a..d3803a2 100644 --- a/drivers/i2c/soft_i2c.c +++ b/drivers/i2c/soft_i2c.c @@ -30,9 +30,7 @@ #include <ioports.h> #include <asm/io.h> #endif -#if defined(CONFIG_AT91RM9200) || \ - defined(CONFIG_AT91SAM9260) || defined(CONFIG_AT91SAM9261) || \ - defined(CONFIG_AT91SAM9263) +#if defined(CONFIG_AT91RM9200) || defined(CONFIG_AT91FAMILY) #include <asm/io.h> #include <asm/arch/hardware.h> #include <asm/arch/at91_pio.h>
Signed-off-by: Ryan Mallon ryan@bluewatersys.com --- board/bluewater/snapper9260/Makefile | 53 ++++++++ board/bluewater/snapper9260/snapper9260.c | 169 +++++++++++++++++++++++++ include/configs/snapper9260.h | 191 +++++++++++++++++++++++++++++ 3 files changed, 413 insertions(+), 0 deletions(-) create mode 100644 board/bluewater/snapper9260/Makefile create mode 100644 board/bluewater/snapper9260/snapper9260.c create mode 100644 include/configs/snapper9260.h
diff --git a/board/bluewater/snapper9260/Makefile b/board/bluewater/snapper9260/Makefile new file mode 100644 index 0000000..4fccdaa --- /dev/null +++ b/board/bluewater/snapper9260/Makefile @@ -0,0 +1,53 @@ +# +# (C) Copyright 2003-2008 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# (C) Copyright 2011 Bluewater Systems +# Ryan Mallon ryan@bluewatersys.com +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +COBJS-y += snapper9260.o + +SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS-y)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(call cmd_link_o_target, $(OBJS) $(SOBJS)) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak $(obj).depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/bluewater/snapper9260/snapper9260.c b/board/bluewater/snapper9260/snapper9260.c new file mode 100644 index 0000000..6bb2ee0 --- /dev/null +++ b/board/bluewater/snapper9260/snapper9260.c @@ -0,0 +1,169 @@ +/* + * Bluewater Systems Snapper 9260/9G20 modules + * + * (C) Copyright 2011 Bluewater Systems + * Author: Andre Renaud andre@bluewatersys.com + * Author: Ryan Mallon ryan@bluewatersys.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/at91sam9260_matrix.h> +#include <asm/arch/at91sam9_smc.h> +#include <asm/arch/at91_common.h> +#include <asm/arch/at91_pmc.h> +#include <asm/arch/at91_rstc.h> +#include <asm/arch/gpio.h> +#include <net.h> +#include <netdev.h> +#include <i2c.h> +#include <pca953x.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* IO Expander pins */ +#define IO_EXP_ETH_RESET (0 << 1) +#define IO_EXP_ETH_POWER (1 << 1) + +static void macb_hw_init(void) +{ + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; + struct at91_port *pioa = (struct at91_port *)ATMEL_BASE_PIOA; + struct at91_rstc *rstc = (struct at91_rstc *)ATMEL_BASE_RSTC; + unsigned long erstl; + + /* Enable clock */ + writel(1 << ATMEL_ID_EMAC0, &pmc->pcer); + + /* Disable pull-ups to prevent PHY going into test mode */ + writel(pin_to_mask(AT91_PIN_PA14) | + pin_to_mask(AT91_PIN_PA15) | + pin_to_mask(AT91_PIN_PA18), + &pioa->pudr); + + /* Power down ethernet */ + pca953x_set_dir(0x28, IO_EXP_ETH_POWER, PCA953X_DIR_OUT); + pca953x_set_val(0x28, IO_EXP_ETH_POWER, 1); + + /* Hold ethernet in reset */ + pca953x_set_dir(0x28, IO_EXP_ETH_RESET, PCA953X_DIR_OUT); + pca953x_set_val(0x28, IO_EXP_ETH_RESET, 0); + + /* Enable ethernet power */ + pca953x_set_val(0x28, IO_EXP_ETH_POWER, 0); + + /* Need to reset PHY -> 500ms reset */ + erstl = readl(&rstc->mr) & AT91_RSTC_MR_ERSTL_MASK; + writel(AT91_RSTC_KEY | AT91_RSTC_MR_ERSTL(13) | + AT91_RSTC_MR_URSTEN, &rstc->mr); + writel(AT91_RSTC_KEY | AT91_RSTC_CR_EXTRST, &rstc->cr); + + /* Wait for end hardware reset */ + while (!(readl(&rstc->sr) & AT91_RSTC_SR_NRSTL)) + ; + + /* Restore NRST value */ + writel(AT91_RSTC_KEY | erstl | AT91_RSTC_MR_URSTEN, &rstc->mr); + + /* Bring the ethernet out of reset */ + pca953x_set_val(0x28, IO_EXP_ETH_RESET, 1); + + /* The phy internal reset take 21ms */ + udelay(21 * 1000); + + /* Re-enable pull-up */ + writel(pin_to_mask(AT91_PIN_PA14) | + pin_to_mask(AT91_PIN_PA15) | + pin_to_mask(AT91_PIN_PA18), + &pioa->puer); + + at91_macb_hw_init(); +} + +static void nand_hw_init(void) +{ + struct at91_smc *smc = (struct at91_smc *)ATMEL_BASE_SMC; + struct at91_matrix *matrix = (struct at91_matrix *)ATMEL_BASE_MATRIX; + unsigned long csa; + + /* Enable CS3 as NAND/SmartMedia */ + csa = readl(&matrix->ebicsa); + csa |= AT91_MATRIX_CS3A_SMC_SMARTMEDIA; + writel(csa, &matrix->ebicsa); + + /* Configure SMC CS3 for NAND/SmartMedia */ + writel(AT91_SMC_SETUP_NWE(2) | AT91_SMC_SETUP_NCS_WR(0) | + AT91_SMC_SETUP_NRD(2) | AT91_SMC_SETUP_NCS_RD(0), + &smc->cs[3].setup); + writel(AT91_SMC_PULSE_NWE(4) | AT91_SMC_PULSE_NCS_WR(4) | + AT91_SMC_PULSE_NRD(4) | AT91_SMC_PULSE_NCS_RD(4), + &smc->cs[3].pulse); + writel(AT91_SMC_CYCLE_NWE(7) | AT91_SMC_CYCLE_NRD(7), + &smc->cs[3].cycle); + writel(AT91_SMC_MODE_RM_NRD | AT91_SMC_MODE_WM_NWE | + AT91_SMC_MODE_EXNW_DISABLE | + AT91_SMC_MODE_DBW_8 | + AT91_SMC_MODE_TDF_CYCLE(3), + &smc->cs[3].mode); + + /* Configure RDY/BSY */ + at91_set_gpio_input(CONFIG_SYS_NAND_READY_PIN, 1); + + /* Enable NandFlash */ + at91_set_gpio_output(CONFIG_SYS_NAND_ENABLE_PIN, 1); +} + +int board_init(void) +{ + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; + + /* Enable PIO clocks */ + writel((1 << ATMEL_ID_PIOA) | + (1 << ATMEL_ID_PIOB) | + (1 << ATMEL_ID_PIOC), &pmc->pcer); + + /* The mach-type is the same for both Snapper 9260 and 9G20 */ + gd->bd->bi_arch_number = MACH_TYPE_SNAPPER_9260; + + /* Address of boot parameters */ + gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE + 0x100; + + /* Initialise peripherals */ + at91_seriald_hw_init(); + i2c_init(CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE); + nand_hw_init(); + macb_hw_init(); + + return 0; +} + +int board_eth_init(bd_t *bis) +{ + return macb_eth_initialize(0, (void *)ATMEL_BASE_EMAC0, 0x1f); +} + +int dram_init(void) +{ + gd->ram_size = get_ram_size((void *)CONFIG_SYS_SDRAM_BASE, + CONFIG_SYS_SDRAM_SIZE); + return 0; +} + +void reset_phy(void) +{ +} diff --git a/include/configs/snapper9260.h b/include/configs/snapper9260.h new file mode 100644 index 0000000..753be77 --- /dev/null +++ b/include/configs/snapper9260.h @@ -0,0 +1,191 @@ +/* + * Bluewater Systems Snapper 9260 and 9G20 modules + * + * (C) Copyright 2011 Bluewater Systems + * Author: Andre Renaud andre@bluewatersys.com + * Author: Ryan Mallon ryan@bluewatersys.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* SoC type is defined in boards.cfg */ +#include <asm/hardware.h> +#include <asm/sizes.h> + +#define CONFIG_SYS_TEXT_BASE 0x23f00000 + +/* ARM asynchronous clock */ +#define CONFIG_SYS_AT91_MAIN_CLOCK 18432000 /* External Crystal, in Hz */ +#define CONFIG_SYS_AT91_SLOW_CLOCK 32768 +#define CONFIG_SYS_HZ 1000 + +/* CPU */ +#define CONFIG_ARCH_CPU_INIT +#undef CONFIG_USE_IRQ + +#define CONFIG_CMDLINE_TAG 1 /* enable passing of ATAGs */ +#define CONFIG_SETUP_MEMORY_TAGS 1 +#define CONFIG_INITRD_TAG 1 +#define CONFIG_SKIP_LOWLEVEL_INIT +#define CONFIG_SKIP_RELOCATE_UBOOT +#define CONFIG_DISPLAY_CPUINFO 1 +#define CONFIG_FIT 1 + +/* SDRAM */ +#define CONFIG_NR_DRAM_BANKS 1 +#define CONFIG_SYS_SDRAM_BASE ATMEL_BASE_CS1 +#define CONFIG_SYS_SDRAM_SIZE SZ_64M +#define CONFIG_SYS_INIT_SP_ADDR (ATMEL_BASE_SRAM1 + 0x1000 - \ + GENERATED_GBL_DATA_SIZE) + +/* Mem test settings */ +#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_SDRAM_BASE + SZ_1M) + +/* NAND Flash */ +#define CONFIG_NAND_ATMEL +#define CONFIG_SYS_NO_FLASH 1 +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_SYS_NAND_BASE ATMEL_BASE_CS3 +#define CONFIG_SYS_NAND_DBW_8 1 +#define CONFIG_SYS_NAND_MASK_ALE (1 << 21) /* AD21 */ +#define CONFIG_SYS_NAND_MASK_CLE (1 << 22) /* AD22 */ +#define CONFIG_SYS_NAND_ENABLE_PIN AT91_PIN_PC14 +#define CONFIG_SYS_NAND_READY_PIN AT91_PIN_PC13 + +/* Ethernet */ +#define CONFIG_MACB 1 +#define CONFIG_RMII 1 +#define CONFIG_NET_MULTI 1 +#define CONFIG_NET_RETRY_COUNT 20 +#define CONFIG_RESET_PHY_R 1 +#define CONFIG_TFTP_PORT +#define CONFIG_TFTP_TSIZE + +/* USB */ +#define CONFIG_USB_ATMEL +#define CONFIG_USB_OHCI_NEW 1 +#define CONFIG_DOS_PARTITION 1 +#define CONFIG_SYS_USB_OHCI_CPU_INIT 1 +#define CONFIG_SYS_USB_OHCI_REGS_BASE ATMEL_UHP_BASE +#define CONFIG_SYS_USB_OHCI_SLOT_NAME "at91sam9260" +#define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 2 +#define CONFIG_USB_STORAGE 1 + +/* GPIOs and IO expander */ +#define CONFIG_AT91_LEGACY +#define CONFIG_ATMEL_LEGACY +#define CONFIG_AT91_GPIO +#define CONFIG_AT91_GPIO_PULLUP 1 +#define CONFIG_PCA953X +#define CONFIG_SYS_I2C_PCA953X_ADDR 0x28 +#define CONFIG_SYS_I2C_PCA953X_WIDTH {{0x28, 16}} + +/* UARTs/Serial console */ +#define CONFIG_ATMEL_USART +#define CONFIG_USART_BASE ATMEL_BASE_DBGU +#define CONFIG_USART_ID ATMEL_ID_SYS +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE {115200 , 19200, 38400, 57600, 9600 } +#define CONFIG_SYS_PROMPT "Snapper> " + +/* I2C - Bit-bashed */ +#define CONFIG_SOFT_I2C 1 +#define CONFIG_SYS_I2C_SPEED 100000 +#define CONFIG_SYS_I2C_SLAVE 0x7F +#define CONFIG_SOFT_I2C_READ_REPEATED_START 1 +#define CONFIG_I2C_MULTI_BUS 1 +#define I2C_INIT do { \ + at91_set_gpio_output(AT91_PIN_PA23, 1); \ + at91_set_gpio_output(AT91_PIN_PA24, 1); \ + at91_set_pio_multi_drive(AT91_PIO_PORTA, 23, 1); \ + at91_set_pio_multi_drive(AT91_PIO_PORTA, 24, 1); \ + } while (0) +#define I2C_SOFT_DECLARATIONS +#define I2C_ACTIVE +#define I2C_TRISTATE at91_set_gpio_input(AT91_PIN_PA23, 1); +#define I2C_READ at91_get_gpio_value(AT91_PIN_PA23); +#define I2C_SDA(bit) do { \ + if (bit) { \ + at91_set_gpio_input(AT91_PIN_PA23, 1); \ + } else { \ + at91_set_gpio_output(AT91_PIN_PA23, 1); \ + at91_set_gpio_value(AT91_PIN_PA23, bit); \ + } \ + } while (0) +#define I2C_SCL(bit) at91_set_pio_value(AT91_PIO_PORTA, 24, bit) +#define I2C_DELAY udelay(2) + +/* Boot options */ +#define CONFIG_SYS_LOAD_ADDR 0x23000000 +#define CONFIG_BOOTDELAY 3 +#define CONFIG_ZERO_BOOTDELAY_CHECK + +#define CONFIG_BOOTP_BOOTFILESIZE 1 +#define CONFIG_BOOTP_BOOTPATH 1 +#define CONFIG_BOOTP_GATEWAY 1 +#define CONFIG_BOOTP_HOSTNAME 1 + +/* Environment settings */ +#define CONFIG_ENV_IS_IN_NAND 1 +#define CONFIG_ENV_OFFSET SZ_512K +#define CONFIG_ENV_SIZE SZ_256K +#define CONFIG_ENV_OVERWRITE +#define CONFIG_BOOTARGS "console=ttyS0,115200 ip=any" + +/* Console settings */ +#define CONFIG_SYS_CBSIZE 256 +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_LONGHELP 1 +#define CONFIG_SYS_EXTBDINFO 1 +#define CONFIG_CMDLINE_EDITING 1 +#define CONFIG_AUTO_COMPLETE +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " + +/* U-Boot memory settings */ +#define CONFIG_SYS_MALLOC_LEN SZ_1M +#define CONFIG_STACKSIZE SZ_256K + +/* Command line configuration */ +#include <config_cmd_default.h> +#undef CONFIG_CMD_BDI +#undef CONFIG_CMD_FPGA +#undef CONFIG_CMD_IMI +#undef CONFIG_CMD_IMLS +#undef CONFIG_CMD_LOADS +#undef CONFIG_CMD_SOURCE + +#define CONFIG_CMD_PING 1 +#define CONFIG_CMD_DHCP 1 +#define CONFIG_CMD_FAT 1 +#define CONFIG_CMD_I2C 1 +#define CONFIG_CMD_GPIO 1 +#define CONFIG_CMD_USB 1 +#define CONFIG_CMD_MII 1 +#define CONFIG_CMD_NAND 1 +#define CONFIG_CMD_PCA953X 1 +#define CONFIG_CMD_PCA953X_INFO 1 + +#endif /* __CONFIG_H */
Signed-off-by: Ryan Mallon ryan@bluewatersys.com --- boards.cfg | 2 ++ 1 files changed, 2 insertions(+), 0 deletions(-)
diff --git a/boards.cfg b/boards.cfg index 9b15026..370ab02 100644 --- a/boards.cfg +++ b/boards.cfg @@ -113,6 +113,8 @@ imx27lite arm arm926ejs imx27lite logicpd magnesium arm arm926ejs imx27lite logicpd mx27 omap5912osk arm arm926ejs - ti omap edminiv2 arm arm926ejs - LaCie orion5x +snapper9260 arm arm926ejs - bluewater at91 snapper9260:AT91SAM9260 +snapper9g20 arm arm926ejs snapper9260 bluewater at91 snapper9260:AT91SAM9G20 ca9x4_ct_vxp arm armv7 vexpress armltd mx51evk arm armv7 mx51evk freescale mx5 vision2 arm armv7 vision2 ttcontrol mx5
Dear Ryan Mallon,
In message b31f9ead63a567931f8dbf5170bbd34a4adb2612.1295995460.git.ryan@bluewatersys.com you wrote:
This needs to be folded into previous patch.
Dear Ryan Mallon,
In message e3e679839f735fff180547840a3fe3cec2b1d535.1295995460.git.ryan@bluewatersys.com you wrote:
Entry to MAINTAINERS and boards.cfg missing.
Dear Wolfgang Denk,
Dear Ryan Mallon,
In messagee3e679839f735fff180547840a3fe3cec2b1d535.1295995460.git.ryan@bluewatersys.com you wrote:
Signed-off-by: Ryan Mallonryan@bluewatersys.com
I am already engaged into this. There are minor coding issues involved, I will comment on them later.
Best Regards, Reinhard
On 01/26/2011 08:40 PM, Reinhard Meyer wrote:
Dear Wolfgang Denk,
Dear Ryan Mallon,
Hi Reinhard,
Did you have any additional changes you want made for the Snapper9260/9G20 patches other than adding a MAINTAINERS entry and rolling the boards.cfg change into a single patch?
Thanks, ~Ryan
Dear Ryan Mallon,
Yes, the following things should be changed:
1. sort the boards.cfg entry to the right place. See top of boards.cfg for the rules. bluewater would be between atmel and emk ;)
2. #define SOMETHING 1. The "1" is depreciated if it serves no numeric meaning. Remove them in your board config. (Make sure the white space goes as well)
3. SZ_* macros are depreciated. Use numeric values. (256 << 20) is preferred to denote 256MiB.
Sorry I had no time to look deeper into details, but it looked good otherwise.
Can you confirm that the code builds and runs after the changes? I can't verify the "runs" part...
Dear Heiko & Reinhard,
In message 7bc3ea96fb41d5e41ac53281d77d3158bffd3b21.1295995460.git.ryan@bluewatersys.com Ryan Mallon wrote:
I think this one goes through as a bug fix, i. e. for the upcoming release.
The other patches of this series go into next.
Hello Wolfgang and Reinhard,
Ok. Reinhard? Do you pick up this patch? If so, I give my:
Acked-by: Heiko Schocher hs@denx.de
bye, Heiko
Dear Heiko Schocher,
Dear Heiko& Reinhard,
In message7bc3ea96fb41d5e41ac53281d77d3158bffd3b21.1295995460.git.ryan@bluewatersys.com Ryan Mallon wrote:
Acked-by: Heiko Schocherhs@denx.de
I was going to complain that it was not alphabetically sorted as I suggested to him, however I am now considering to remove the AT91RM9200 case altogether. That one has to be forced into AT91FAMILY.
Once corrected, I will pickup this patch then.
Hello Reinhard,
Ok, thanks!
bye, Heiko
Dear Ryan Mellon, dear Heiko Schocher:
I made up my mind, it should only test for AT91FAMILY.
AT91RM9200 is supposed to join AT91FAMILY anyway, so lets do this correctly right now.
#if defined(CONFIG_AT91FAMILY)
If its done that way, here is my Acked-by: Reinhard Meyeru-boot@emk-elektronik.de
Ryan, can you please change it as such, and preferably post it as a separate patch (not with your new board)? So Heiko can pick it up and make it go as a bug fix to mainline faster than I could do it right now through the "atmel" tree.
Dear Reinhard Meyer,
Am 26.01.2011 um 09:18 schrieb Reinhard Meyer:
that is the plan ...
regards
Andreas Bießmann
participants (5)
Andreas Bießmann
Heiko Schocher
Reinhard Meyer
Ryan Mallon
