[U-Boot] [PATCH 1/4] sf: Unify spi_flash write code
Move common flash write code into spi_flash_write_common().
Signed-off-by: Jagannadha Sutradharudu Teki jaganna@xilinx.com --- drivers/mtd/spi/spi_flash.c | 122 ++++++++++++++++------------------- drivers/mtd/spi/spi_flash_internal.h | 6 ++ 2 files changed, 60 insertions(+), 68 deletions(-)
diff --git a/drivers/mtd/spi/spi_flash.c b/drivers/mtd/spi/spi_flash.c index c439601..f8fd897 100644 --- a/drivers/mtd/spi/spi_flash.c +++ b/drivers/mtd/spi/spi_flash.c @@ -68,22 +68,53 @@ int spi_flash_cmd_write(struct spi_slave *spi, const u8 *cmd, size_t cmd_len, return spi_flash_read_write(spi, cmd, cmd_len, data, NULL, data_len); }
+int spi_flash_write_common(struct spi_flash *flash, const u8 *cmd, + size_t cmd_len, const void *buf, size_t buf_len, unsigned long timeout) +{ + struct spi_slave *spi = flash->spi; + int ret; + + ret = spi_claim_bus(flash->spi); + if (ret) { + debug("SF: Unable to claim SPI bus\n"); + return ret; + } + + ret = spi_flash_cmd_write_enable(flash); + if (ret < 0) { + debug("SF: enabling write failed\n"); + return ret; + } + + ret = spi_flash_cmd_write(spi, cmd, cmd_len, buf, buf_len); + if (ret < 0) { + debug("SF: write cmd failed\n"); + return ret; + } + + ret = spi_flash_cmd_wait_ready(flash, timeout); + if (ret < 0) { + debug("SF: write %s timed out\n", + timeout == SPI_FLASH_PROG_TIMEOUT ? + "program" : "page erase"); + return ret; + } + + spi_release_bus(spi); + + return ret; +} + int spi_flash_cmd_write_multi(struct spi_flash *flash, u32 offset, size_t len, const void *buf) { unsigned long byte_addr, page_size; size_t chunk_len, actual; - int ret; u8 cmd[4]; + int ret = -1;
page_size = flash->page_size;
- ret = spi_claim_bus(flash->spi); - if (ret) { - debug("SF: unable to claim SPI bus\n"); - return ret; - } - cmd[0] = CMD_PAGE_PROGRAM; for (actual = 0; actual < len; actual += chunk_len) { #ifdef CONFIG_SPI_FLASH_BAR @@ -108,27 +139,17 @@ int spi_flash_cmd_write_multi(struct spi_flash *flash, u32 offset, debug("PP: 0x%p => cmd = { 0x%02x 0x%02x%02x%02x } chunk_len = %zu\n", buf + actual, cmd[0], cmd[1], cmd[2], cmd[3], chunk_len);
- ret = spi_flash_cmd_write_enable(flash); - if (ret < 0) { - debug("SF: enabling write failed\n"); - break; - } - - ret = spi_flash_cmd_write(flash->spi, cmd, 4, - buf + actual, chunk_len); + ret = spi_flash_write_common(flash, cmd, sizeof(cmd), + buf + actual, chunk_len, + SPI_FLASH_PROG_TIMEOUT); if (ret < 0) { debug("SF: write failed\n"); break; }
- ret = spi_flash_cmd_wait_ready(flash, SPI_FLASH_PROG_TIMEOUT); - if (ret) - break; - offset += chunk_len; }
- spi_release_bus(flash->spi); return ret; }
@@ -242,8 +263,8 @@ int spi_flash_cmd_wait_ready(struct spi_flash *flash, unsigned long timeout) int spi_flash_cmd_erase(struct spi_flash *flash, u32 offset, size_t len) { u32 erase_size; - int ret; u8 cmd[4]; + int ret = -1;
erase_size = flash->sector_size; if (offset % erase_size || len % erase_size) { @@ -251,12 +272,6 @@ int spi_flash_cmd_erase(struct spi_flash *flash, u32 offset, size_t len) return -1; }
- ret = spi_claim_bus(flash->spi); - if (ret) { - debug("SF: Unable to claim SPI bus\n"); - return ret; - } - if (erase_size == 4096) cmd[0] = CMD_ERASE_4K; else @@ -279,24 +294,17 @@ int spi_flash_cmd_erase(struct spi_flash *flash, u32 offset, size_t len) debug("SF: erase %2x %2x %2x %2x (%x)\n", cmd[0], cmd[1], cmd[2], cmd[3], offset);
- ret = spi_flash_cmd_write_enable(flash); - if (ret) - goto out; - - ret = spi_flash_cmd_write(flash->spi, cmd, sizeof(cmd), NULL, 0); - if (ret) - goto out; - - ret = spi_flash_cmd_wait_ready(flash, SPI_FLASH_PAGE_ERASE_TIMEOUT); - if (ret) - goto out; + ret = spi_flash_write_common(flash, cmd, sizeof(cmd), + NULL, 0, SPI_FLASH_PAGE_ERASE_TIMEOUT); + if (ret < 0) { + debug("SF: erase failed\n"); + break; + }
offset += erase_size; len -= erase_size; }
- out: - spi_release_bus(flash->spi); return ret; }
@@ -305,22 +313,11 @@ int spi_flash_cmd_write_status(struct spi_flash *flash, u8 sr) u8 cmd; int ret;
- ret = spi_flash_cmd_write_enable(flash); - if (ret < 0) { - debug("SF: enabling write failed\n"); - return ret; - } - cmd = CMD_WRITE_STATUS; - ret = spi_flash_cmd_write(flash->spi, &cmd, 1, &sr, 1); - if (ret) { - debug("SF: fail to write status register\n"); - return ret; - } - - ret = spi_flash_cmd_wait_ready(flash, SPI_FLASH_PROG_TIMEOUT); + ret = spi_flash_write_common(flash, &cmd, 1, + &sr, 1, SPI_FLASH_PROG_TIMEOUT); if (ret < 0) { - debug("SF: write status register timed out\n"); + debug("SF: fail to write status register\n"); return ret; }
@@ -339,25 +336,14 @@ int spi_flash_cmd_bankaddr_write(struct spi_flash *flash, u8 bank_sel) }
cmd = flash->bank_cmd[1]; - ret = spi_flash_cmd_write_enable(flash); + ret = spi_flash_write_common(flash, &cmd, 1, + &bank_sel, 1, SPI_FLASH_PROG_TIMEOUT); if (ret < 0) { - debug("SF: enabling write failed\n"); - return ret; - } - - ret = spi_flash_cmd_write(flash->spi, &cmd, 1, &bank_sel, 1); - if (ret) { - debug("SF: fail to write bank addr register\n"); + debug("SF: fail to write bank register\n"); return ret; } flash->bank_curr = bank_sel;
- ret = spi_flash_cmd_wait_ready(flash, SPI_FLASH_PROG_TIMEOUT); - if (ret < 0) { - debug("SF: write bank addr register timed out\n"); - return ret; - } - return 0; }
diff --git a/drivers/mtd/spi/spi_flash_internal.h b/drivers/mtd/spi/spi_flash_internal.h index 8147f27..77d1da8 100644 --- a/drivers/mtd/spi/spi_flash_internal.h +++ b/drivers/mtd/spi/spi_flash_internal.h @@ -108,6 +108,12 @@ int spi_flash_bank_config(struct spi_flash *flash, u8 idcode0); */ int spi_flash_read_common(struct spi_flash *flash, const u8 *cmd, size_t cmd_len, void *data, size_t data_len); +/* + * Same as spi_flash_cmd_write() except it also claims/releases the SPI + * bus. Used as common part of the ->write() operation. + */ +int spi_flash_write_common(struct spi_flash *flash, const u8 *cmd, + size_t cmd_len, const void *buf, size_t buf_len, unsigned long timeout);
/* * Send the read status command to the device and wait for the wip
Hi Jagan,
On Fri, Jun 14, 2013 at 1:18 PM, Jagannadha Sutradharudu Teki < jagannadha.sutradharudu-teki@xilinx.com> wrote:
This looks good except that spi_flash_write_common() is not a great name - only one of the operations is a 'write'. Perhaps spi_flash_oper_common() or similar?
On Wed, Jun 19, 2013 at 10:01 AM, Simon Glass sjg@chromium.org wrote:
Hi Jagan,
I think it's ok to use spi_flash_write_common(). because, I put this name as the write sequence has all theseopers write_enable, write and wait_ready, not by taking only write operation.
May be I will try to put spi_flash_write_oper_common() Any comments.??
Thanks, Jagan.
Hi Jagan,
Hi Jagan,
name -
or
similar?
OK well let's not worry about it too much.
Jagan Teki
