[U-Boot-Users] [GIT PULL] Please pull coldfire tree
Wolfgang,
The following changes since commit 74d1e66d22dac91388bc538b2fe19f735edc5b82: Bartlomiej Sieka (1): Fix host tool build breakage, take two
git://www.denx.de/git/u-boot-coldfire.git master
Matthew Fettke (2): ColdFire: Added MCF5275 cpu support. ColdFire: Added M5275EVB support.
TsiChung Liew (6): ColdFire: Update correct FLASHBAR and RAMBAR1 for MCF5282 ColdFire: Fix second memory Chipselect for M5475EVB ColdFire: Define bootdelay in configuration file for M52277EVB ColdFire: Remove R5200 board ColdFire: Add dspi and serial flash support for MCF5445x ColdFire: Fix alignment issue after CONFIG_IDENT_STRING in start.S
CREDITS | 1 + MAINTAINERS | 4 - MAKEALL | 2 +- Makefile | 6 +- board/{r5200 => freescale/m5275evb}/Makefile | 20 +- board/{r5200 => freescale/m5275evb}/config.mk | 2 +- board/freescale/m5275evb/m5275evb.c | 112 ++++++ board/{r5200 => freescale/m5275evb}/mii.c | 22 +- board/{r5200 => freescale/m5275evb}/u-boot.lds | 41 +-- board/freescale/m54455evb/flash.c | 449 +++++++++++++++++++---- board/freescale/m547xevb/m547xevb.c | 3 + board/r5200/r5200.c | 124 ------- cpu/mcf5227x/start.S | 1 + cpu/mcf523x/start.S | 1 + cpu/mcf52x2/config.mk | 4 + cpu/mcf52x2/cpu.c | 66 ++++ cpu/mcf52x2/cpu_init.c | 111 ++++++ cpu/mcf52x2/interrupts.c | 4 +- cpu/mcf52x2/speed.c | 12 +- cpu/mcf52x2/start.S | 65 ++-- cpu/mcf532x/start.S | 1 + cpu/mcf5445x/Makefile | 2 +- cpu/mcf5445x/dspi.c | 73 ++++ cpu/mcf5445x/start.S | 1 + cpu/mcf547x_8x/start.S | 1 + include/asm-m68k/coldfire/dspi.h | 10 + include/asm-m68k/immap.h | 24 ++ include/asm-m68k/immap_5275.h | 469 ++++++++++++++++++++++++ include/asm-m68k/m5275.h | 241 ++++++++++++ include/configs/M52277EVB.h | 1 + include/configs/{r5200.h => M5275EVB.h} | 153 +++++---- include/configs/M54455EVB.h | 28 ++- 32 files changed, 1711 insertions(+), 343 deletions(-) rename board/{r5200 => freescale/m5275evb}/Makefile (75%) rename board/{r5200 => freescale/m5275evb}/config.mk (97%) create mode 100644 board/freescale/m5275evb/m5275evb.c rename board/{r5200 => freescale/m5275evb}/mii.c (92%) rename board/{r5200 => freescale/m5275evb}/u-boot.lds (81%) delete mode 100644 board/r5200/r5200.c create mode 100644 cpu/mcf5445x/dspi.c create mode 100644 include/asm-m68k/immap_5275.h create mode 100644 include/asm-m68k/m5275.h rename include/configs/{r5200.h => M5275EVB.h} (55%)
In message 47F15519.8030401@freescale.com you wrote:
Wolfgang,
Applied, thanks.
John Rigby
